H3C Access Controllers Web-Based Configuration Guide(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W103
HomeSupportConfigure & DeployUser ManualsH3C Access Controllers Web-Based Configuration Guide(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W103
02-Web overview
02-Web overview 225.63 KB
Web overview
This chapter describes the Web interface, functions available on the Web interface, Web user levels you must have to perform a function, and common icons and buttons on the Web pages.
Web interface
The Web interface consists of the navigation tree, title area, and body area.
Figure 1 Web-based configuration interface
(1) Navigation area
(2) Body area
(3) Title area
·     Navigation areaOrganizes the Web-based NM function menus in the form of a navigation tree, where you can select function menus as needed. The result is displayed in the body area. The Web network management functions not supported by the device are not displayed in the navigation area.
·     Body areaThe area where you can configure and display a function.
·     Title areaOn the left, displays the path of the current configuration interface in the navigation area; on the right, provides the Save button to quickly save the current configuration, the Help button to display the Web related help information, and the Logout button to log out of the Web interface.
Web user level
Web user levels, ranging from low to high, are visitor, monitor, configure, and management. A user with a higher level has all the operating rights of a user with a lower level.
·     VisitorUsers can use the network diagnostic tools ping and Trace Route, but they can neither access the device data nor configure the device.
·     MonitorUsers can only access the device data, but they cannot configure the device.
·     ConfigureUsers can access device data and configure the device, but they cannot upgrade the host software, add/delete/modify users, or backup/restore configuration files.
·     ManagementUsers of this level can perform any operations to the device.
Web-based NM functions
Support for the configuration items depends on the device model. For more information, see About the H3C Access Controllers Web-Based Configuration Guide.
A user level in Table 1 indicates that users of this level or users of a higher level can perform the corresponding operations.
Table 1 Web-based NM function description
Function menu
User level
Quick Start
Perform quick configuration of the device.
Configure
Summary
Device Info
Display and refresh system resource state, device interface information, and recent system operation logs.
Monitor
Wireless Service
Display the information of the queried WLAN service, including the detailed information, statistics, and connection history.
Monitor
AP
Display the information of the queried AP, including wireless service, connection history, radio, and detailed information.
Monitor
Reboot an AP.
Configure
Client
Display the detailed information, statistics, roaming, and link information of the client.
Monitor
Clear statistics of the client, disconnect the connection, and add the client into the blacklist.
Configure
Device
License
License
Display license information.
Monitor
Add licenses.
Configure
Enhanced License
Display enhanced license information.
Management
Register enhanced licenses.
Management
Basic
System Name
Display and configure the system name.
Configure
Web Idle Timeout
Display and configure the idle timeout time for a logged-in user.
Configure
Device Maintenance
Software Upgrade
Upload the file to be upgraded from the local host to upgrade the system software.
Management
Reboot
Reboot the device.
Management
Diagnostic Information
Generate a diagnostic information file, view the file, or save the file to the local host.
Management
System Time
System Time
Display the system date and time.
Configure
Manually set the system date and time.
Configure
Time Zone
Display configurations about system time zone and daylight saving time
Configure
Configure system time zone and daylight saving time.
Configure
Net Time
Display time synchronization status and network time configuration.
Configure
Set local and external clock sources and system time zone.
Configure
Syslog
Loglist
Display and refresh system logs.
Monitor
Clear system logs.
Configure
Loghost
Display and configure the loghost.
Configure
Log Setup
Display and configure the buffer capacity, and refresh interval for displaying system logs.
Configure
Configuration
Backup
Back up the configuration file for the next startup to the host of the current user.
Management
Restore
Upgrade the configuration file on the host of the current user to the device for the next startup.
Management
Save
Save the current configuration to the configuration file for the next startup.
Configure
Initialize
Restore the system to factory defaults.
Management
File management
Manage files on the device, including displaying file list, downloading a file, uploading a file, removing a file, and setting the main boot file.
Management
Display interface information and statistics.
Monitor
Create, modify, and delete an interface, and clear interface statistics.
Configure
Port Mirroring
Summary
Display the configuration information of a port mirroring group.
Monitor
Add
Create a port mirroring group.
Configure
Remove
Remove a port mirroring group.
Configure
Modify Port
Configure ports for a mirroring group.
Configure
Users
Summary
Display brief information of Web, FTP and Telnet users.
Monitor
Super Password
Configure the password for a lower-level user to switch from the current access level to the management level.
Configure
Create
Create a Web, FTP, or Telnet user.
Configure
Modify
Modify Web, FTP, or Telnet user information.
Configure
Remove
Remove a Web, FTP, or Telnet user.
Configure
Switch To Management
Switch the current user level to the management level.
Monitor
SNMP
Setup
Display and refresh SNMP configuration and statistics information.
Management
Configure SNMP.
Management
Community
Display SNMP community information.
Management
Create, modify, and delete an SNMP community.
Management
Group
Display SNMP group information.
Management
Create, modify, and delete an SNMP group.
Management
User
Display SNMP user information.
Management
Create, modify, and delete an SNMP user.
Management
Trap
Display the status of the SNMP trap function and information about target hosts.
Management
Enable or disable the SNMP trap function, or create, modify, and delete a target host.
Management
View
Display SNMP view information.
Management
Create, modify, and delete an SNMP view.
Management
Loopback
Perform the loopback test on Ethernet interfaces.
Monitor
Network
MAC
MAC
Display MAC address information.
Monitor
Create or remove MAC addresses.
Configure
Setup
Display and configure MAC address aging time.
Configure
VLAN
VLAN
Display all VLANs on the device and information about their member ports.
Monitor
Create, modify, and delete VLANs.
Configure
Port
Display VLANs to which a port on the device belongs.
Monitor
Modify the VLANs to which a port belongs.
Configure
ARP Management
ARP Table
Display ARP table information.
Monitor
Add, modify, or delete an ARP entry.
Configure
Gratuitous ARP
Display configuration information of gratuitous ARP.
Monitor
Configure gratuitous ARP.
Management
ARP Anti-Attack
ARP Detection
Display the configuration information of ARP detection.
Monitor
Configure ARP detection.
Management
Advanced Configuration
Display the configuration information of source MAC address based ARP attack detection, ARP active acknowledgement, and ARP packet source MAC address consistency check.
Monitor
Configure source MAC address based ARP attack detection, ARP active acknowledgement, and ARP packet source MAC address consistency check.
Management
IGMP Snooping
Basic
Display global IGMP Snooping configuration information and the IGMP Snooping configuration information in a VLAN, and view the IGMP Snooping multicast entry information.
Monitor
Configure IGMP Snooping globally and in a VLAN.
Configure
Advance
Display the IGMP Snooping configuration information on a port.
Monitor
Configure IGMP Snooping on a port.
Configure
IPv4 Routing
Summary
Display the IPv4 active route table.
Monitor
Create
Create an IPv4 static route.
Configure
Remove
Delete the selected IPv4 static routes.
Configure
IPv6 Routing
Summary
Display the IPv6 active route table.
Monitor
Create
Create an IPv6 static route.
Configure
Remove
Delete the selected IPv6 static routes.
Configure
DHCP
DHCP Server
Display the DHCP service status, the DHCP address pool information, the DHCP server status on an interface, and addresses in use.
Monitor
Set the DHCP service status, add, modify, or delete a DHCP address pool, and modify the DHCP server status on an interface.
Configure
DHCP Relay
Display the status of a DHCP service and advanced configuration information of DHCP relay, display information of a DHCP group, and status of the DHCP relay agent on an interface, and view the DHCP relay user information.
Monitor
Configure the status of a DHCP service and advanced configuration information of DHCP relay, add or delete a DHCP group, and modify the status of the DHCP relay agent on an interface.
Configure
DHCP Snooping
Display the status of the DHCP Snooping function, and the trusted and untrusted attributes of a port, and view the DHCP Snooping user information.
Monitor
Configure the status of the DHCP Snooping function, and modify the trusted and untrusted attributes of a port.
Configure
Link aggregation
Summary
Display information about the aggregate interface and member ports.
Monitor
Create
Create a link aggregation group.
Configure
Modify
Modify the selected link aggregation group.
Configure
Remove
Delete the selected link aggregation group.
Configure
LACP
Summary
Display information about the LACP-enabled ports and their remote ports.
Monitor
Setup
Configure the LACP priority.
Configure
LLDP
Port Setup
Search and set the LLDP status and work mode on a port.
Configure
Global Setup
Configure and modify LLDP parameters on a port.
Configure
Global Summary
Display global LLDP statistics and local LLDP information.
Configure
Neighbor Summary
Display neighbor information.
Configure
DNS
Static
Display, create, modify, or delete a static host name-to-IP address mapping.
Configure
Dynamic
Display and configure related parameters for dynamic domain name resolution. Display, create, or delete an IP address and the domain name suffix.
Configure
DDNS
Display information about DDNS.
Monitor
PPPoE
Client Information
Display information about PPPoE client.
Monitor
Create, modify, or delete a PPPoE client.
Configure
Session Information
Display brief information and statistics about PPPoE sessions.
Monitor
Service
Display the states of the services: enabled or disabled.
Monitor
Specify whether to enable various services, and set related parameters.
Management
Diagnostic Tools
IPv4 Ping
Ping an IPv4 address or host and display the result.
Visitor
IPv6 Ping
Ping an IPv6 address or host and display the result.
Visitor
Trace Route
Perform trace route operations and display the result.
Visitor
NAT
Dynamic Address Translation
Display information about address pool, and configure dynamic address translation.
Monitor
Create, modify, or delete an address pool, and configure dynamic address translation.
Configure
Static Address Translation
Display information about static address mapping, and configure static address translation.
Monitor
Create, modify, or delete a static address mapping, and configure static address translation.
Configure
Internal Server
Display information about internal server and DNS mapping.
Monitor
Create, modify, or delete an internal server and DNS mapping.
Configure
Application Layer Protocol Detection
Display configurations of application layer protocol detection.
Monitor
Configure application layer protocol detection.
Configure
AP
AP Setup
Display AP-related information, including AP name, AP IP address, serial ID, model and status.
Monitor
Add an AP and modify the AP configuration.
Configure
Auto AP
Display auto AP information after auto AP is enabled, including AP name, model, serial ID and IP address.
Monitor
Enable auto AP.
Configure
AP Group
Display AP group information.
Monitor
Create and configure an AP group.
Configure
Wireless Service
Access Service
Access Service
Display an access service, including security type, detailed information, service status, and binding status.
Monitor
Create and configure an access service, map an access service to an AP radio, and add a MAC authentication list.
Configure
Forwarding Policy
Display forwarding policy and rule.
Monitor
Configure forwarding policy and rule.
Configure
Mesh Service
Mesh Service
Display a mesh service, including its detailed information, status, and binding information.
Monitor
Create and configure a mesh service, including security settings.
Configure
Mesh Policy
Display mesh policies.
Monitor
Create and configure a mesh policy.
Configure
Global Setup
Display mesh global setting, including basic setting, mesh DFS, and mesh portal service.
Monitor
Configure mesh global setting, including basic setting, mesh DFS, and mesh portal service.
Configure
Mesh Channel Optimize
Display radio information and channel switch information in a mesh network.
Monitor
Configure mesh channel optimization.
Configure
Mesh Link Info
Display mesh link status information.
Monitor
Monitor mesh link status and refresh mesh link status information.
Monitor
Mesh Link Test
Display mesh link test results.
Monitor
Test mesh links and refresh mesh link test results.
Configure
Roam
Roam Group
Display a roaming group and its members.
Monitor
Configure a roaming group and add a group member.
Configure
Roam Client
Display client information, including MAC address, BSSID, VLAN ID, home AC and roaming direction.
Monitor
Radio
Radio
Display radio status, including radio mode and radio status.
Monitor
Configure radio parameters, including 802.11n settings.
Configure
Rate
Display rate settings.
Monitor
Configure rates, including MCS index.
Configure
Channel Scan
Display channel scanning, including scanning mode, scanning type and scanning interval.
Monitor
Configure channel scanning, including scanning mode and scanning type.
Configure
Calibration
Operation
Display or refresh AP status, including channel status, neighbor information, and history information.
Monitor
Manual calibration
Configure
Display basic setup, channel setup and power setup.
Monitor
Configure channel calibration parameters.
Configure
Radio Group
Display radio group configuration.
Monitor
Configure a radio group.
Configure
Antenna Switch
Configure the antenna of an AP.
Configure
Spectrum Analysis
802.11a
Display spectrum analysis configuration of a 5 GHz radio.
Monitor
Configure spectrum analysis on a 5 GHz radio.
Configure
802.11bg
Display spectrum analysis configuration of a 2.4 GHz radio.
Monitor
Configure spectrum analysis on a 2.4 GHz radio.
Configure
Radio
Display spectrum analysis status.
Monitor
Enable spectrum analysis.
Configure
Interfering Device
Display and refresh interfering device status.
Monitor
Channel Quality
Display and refresh channel quality status.
Monitor
Authentication
802.1X
Display the global 802.1X information and 802.1X information of a port.
Monitor
Configure the global 802.1X features and 802.1X features of a port.
Configure
Portal
Portal Server
Display configuration information about the portal server and advanced parameters for portal authentication.
Monitor
Add and delete a portal server, and modify advanced parameters for portal authentication.
Configure
Free Rule
Display the portal-free rule configuration information.
Monitor
Add and delete a portal-free rule.
Configure
AAA
Domain Setup
Display ISP domain configuration information.
Monitor
Add and remove ISP domains.
Management
Authentication
Display the authentication method configuration information of an ISP domain.
Monitor
Specify authentication methods for an ISP domain.
Management
Authorization
Display the authorization method configuration information of an ISP domain.
Monitor
Specify authorization methods for an ISP domain.
Management
Accounting
Display the accounting method configuration information of an ISP domain.
Monitor
Specify accounting methods for an ISP domain.
Management
RADIUS
Display and add, modify, and delete a RADIUS scheme.
Management
Local EAP Server
Display the configuration information of the local EAP service.
Monitor
Configure the local EAP service.
Configure
Users
Local User
Display local users' configuration information.
Monitor
Add, modify, and remove local users.
Management
User Group
Display user groups' configuration information.
Monitor
Add, modify, and remove user groups.
Management
Guest
Display guest users' configuration information.
Monitor
Add, modify, and remove guest users.
Management
User Profile
Display user profile configuration information.
Monitor
Add, modify, remove, enable, and disable user profiles.
Configure
Certificate Management
Entity
Display information about PKI entities.
Monitor
Add, modify, and delete a PKI entity.
Configure
Domain
Display information about PKI domains.
Monitor
Add, modify, and delete a PKI domain.
Configure
Certificate
Display the certificate information of PKI domains and view the contents of a certificate.
Monitor
Generate a key pair, destroy a key pair, retrieve a certificate, request a certificate, and delete a certificate.
Configure
CRL
Display the contents of the CRL.
Monitor
Receive the CRL of a domain.
Configure
Security
Rogue Detection
AP Monitor
Display AP operating mode.
Monitor
Configure AP operating mode.
Configure
Rule List
Display list types for the rogue device detection and the detection rules.
Monitor
Configure list types for rogue device detection and the rules.
Configure
Monitor Record
Display monitor record of rogue device detection.
Monitor
Clear monitor record of rogue device detection, and add rogue devices to blacklist.
Configure
History Record
Display rogue device detection history.
Monitor
Clear history of rogue device detection and add rogue devices to blacklist.
Configure
WIDS
WIDS Setup
Display IDS configuration.
Monitor
Configure IDS detection, including flood attack detection, spoofing attack detection, and weak IV detection.
Configure
History Record
Display IDS attack detection history.
Monitor
Clear history record of IDS attack detection and add the detected devices that initiate attacks to blacklist.
Configure
Statistics
Display statistics of IDS attack detection.
Monitor
Clear the statistics.
Configure
Filter
Blacklist
Display dynamic and static blacklists.
Monitor
Clear dynamic blacklist and static blacklist; enable dynamic blacklist; add entries to the static blacklist.
Configure
White List
Display white list.
Monitor
Clear white list and add entries to the white list.
Configure
Authorized IP
Summary
Display the configurations of the authorized IP, the associated IPv4 ACL rule list, and the associated IPv6 ACL rule list.
Management
Setup
Configure the authorized IP.
Management
User Isolation
Display, add, modify, and remove user isolation configuration.
Management
Session Management
Session List
Display the session list on the device.
Monitor
Delete the session list on the device.
Configure
Basic Settings
Display configurations about one-way flow detection, long connection session rule, session layer protocol ageing time, and application layer protocol aging time.
Monitor
QoS
Time Range
Summary
Display time range configuration information.
Monitor
Add
Create a time range.
Configure
Remove
Delete a time range.
Configure
ACL IPv4
Summary
Display IPv4 ACL configuration information.
Monitor
Add
Create an IPv4 ACL.
Configure
Basic Setup
Configure a rule for a basic IPv4 ACL.
Configure
Advanced Setup
Configure a rule for an advanced IPv4 ACL.
Configure
Link Setup
Create a rule for an Ethernet frame header ACL.
Configure
Wireless Setup
Configure a rule for a WLAN-AP ACL.
Configure
Remove
Delete an IPv4 ACL or its rules.
Configure
ACL IPv6
Summary
Display IPv6 ACL configuration information.
Monitor
Add
Create an IPv6 ACL.
Configure
Basic Setup
Configure a rule for a basic IPv6 ACL.
Configure
Advanced Setup
Configure a rule for an advanced IPv6 ACL.
Configure
Remove
Delete an IPv6 ACL or its rules.
Configure
Wireless QoS
Wireless QoS
Display wireless QoS, including SVP mapping, CAC admission policy, radio EDCA and client EDCA.
Monitor
Configure wireless QoS, including SVP mapping, CAC admission policy, radio EDCA and client EDCA.
Configure
Radio Statistics
Display radio statistics, including WMM status and detailed radio information.
Monitor
Display radio statistics, including WMM status and detailed radio information, and clear the radio statistics.
Configure
Client Statistics
Display client statistics, including WMM status and detailed client information.
Monitor
Display client statistics, including WMM status and detailed client information, and clear the client statistics.
Configure
Client Rate Limit
Display the configured client rate limit information.
Monitor
Configure and modify client rate limiting mode, direction and rate.
Configure
Bandwidth Guarantee
Display bandwidth settings for different radio types.
Monitor
Configure bandwidth guarantee settings.
Configure
Line Rate
Summary
Display line rate configuration information.
Monitor
Setup
Configure the line rate.
Configure
Port Priority
Display the priority and trust mode of a port.
Monitor
Modify the priority and trust mode of a port.
Configure
Trust Mode
Display priority trust mode configuration information.
Management
Configure the priority trust mode.
Management
Classifier
Summary
Display classifier configuration information.
Monitor
Add
Create a class.
Configure
Setup
Configure the classification rules for a class.
Configure
Remove
Delete a class or its classification rules.
Configure
Behavior
Summary
Display traffic behavior configuration information.
Monitor
Add
Create a traffic behavior.
Configure
Setup
Configure actions for a traffic behavior.
Configure
Remove
Delete a traffic behavior.
Configure
QoS Policy
Summary
Display QoS policy configuration information.
Monitor
Add
Create a QoS policy.
Configure
Setup
Configure the classifier-behavior associations for a QoS policy.
Configure
Remove
Delete a QoS policy or its classifier-behavior associations.
Configure
Port Policy
Summary
Display the QoS policy applied to a port.
Monitor
Setup
Apply a QoS policy to a port.
Configure
Remove
Remove the QoS policy from the port.
Configure
Service Policy
Display the QoS policy applied to a WLAN-ESS port.
Monitor
Configure the QoS policy applied to a WLAN-ESS port.
Configure
Advanced
Country/Region Code
Display the country/region code.
Monitor
Modify the country/region code.
Configure
AC Backup
Setup
Display the address of the backup AC.
Monitor
Configure the address of the backup AC.
Configure
Status
Display the status of the AC.
Monitor
Continuous Transmit
Display the continuous transmitting mode of an AP.
Monitor
Switch the continuous transmitting mode of an AP.
Configure
Channel Busy Test
Display channel busy rate test results.
Monitor
Test busy rate of channels, and output test results.
Configure
Load Balancing
Load Balance
Display the load balancing mode and the current connection status.
Monitor
Configure the load balancing mode and refresh the current connection status.
Configure
Load Balance Group
Display load balancing group configuration.
Monitor
Configure a load balancing group.
Configure
AP
AP Module
Display the AP version, including the AP model and software version.
Monitor
Match and upgrade the software.
Configure
Switch to fat AP
Display the model and IP address of the AP.
Monitor
Switch to fat AP.
Configure
Wireless Location
Display wireless location settings.
Monitor
Configure, enable, and disable wireless location.
Configure
Wireless Sniffer
Display wireless sniffer configuration.
Monitor
Configure, enable, and disable wireless sniffer parameters.
Configure
AP Provision
Display AP provision, non AP provision, and global AP provision settings.
Monitor
Set AP provision, non AP provision, and global AP provision.
Configure
Band Navigation
Display band navigation settings.
Monitor
Set band navigation parameters.
Configure
BAS AC
Display BAS AC settings.
Monitor
Configure an AC as BAS AC and set BAS AC parameters.
Configure
VLAN Pool
Display VLAN pool information, number of online clients for each VLAN, and VLAN pool binding information.
Monitor
Create a VLAN pool and set VLAN pool parameters.
Configure
Multicast Optimization
Display multicast optimization settings.
Monitor
Configure multicast optimization.
Configure
Guest Tunnel
Display guest tunnel settings and status.
Monitor
Set the AC type and guest tunnel parameters.
Configure
Bonjour Gateway
Bonjour Gateway
Enable and configure a Bonjour gateway.
Monitor
Display configuration for a Bonjour gateway.
Configure
Bonjour Policy
Configure Bonjour policies.
Monitor
Display configuration information for Bonjour policies.
Configure
Bonjour Service
Display Bonjour services discovered by the AC.
Monitor
Hotspot2.0 Service
Search and configure a hotspot 2.0 policy.
Configure
High Reliability
Stateful Failover
Display stateful failover information.
Monitor
Modify stateful failover configuration.
Configure
VPN
IKE
Global Setting
Display and modify IKE global parameters.
Configure
DPD
Display IKE DPD information.
Monitor
Create, modify, or delete an IKE DPD.
Configure
Peer
Display IKE peer information.
Monitor
Create, modify, or delete an IKE peer.
Configure
Security Proposal
Display IKE security proposal information.
Monitor
Create, modify, or delete an IKE security proposal.
Configure
Security Association
Display IKE security association information.
Monitor
Delete an IKE security association.
Configure
IPSec
Application
Display IPsec policy groups adopted on the interface of the device.
Monitor
Enable or disable IPsec policy groups on the interface of the device.
Configure
Security Proposal
Display IPsec security proposal information.
Monitor
Create, modify, or delete an IPsec security proposal.
Configure
Template Configuration
Display information about IPsec security policy template.
Monitor
Create, modify, or delete an IPsec security policy template.
Configure
Policy
Display IPSec security policy information.
Monitor
Create, modify, or delete an IPsec security policy.
Configure
Display IPsec security association information.
Monitor
Delete an IPsec security association.
Configure
Packet Statistics
Display IPsec packet statistics.
Monitor
Clear IPsec packet statistics.
Configure
SSL VPN
View User Information
Online Users
Display SSL VPN online users.
Monitor
Log off all SSL VPN online users by force.
Configure
History Information
Display history information for SSL VPN users.
Monitor
Add User
Display local user information.
Monitor
Create, modify, or delete local users.
Configure
Import Users
Import local users in batches.
Configure
Configure User Group
Display user group information.
Monitor
Create, modify, or delete user groups.
Configure
Customize Page
Text Information
Display configuration information for the SSL VPN login and service pages.
Monitor
Configure the SSL VPN login and service pages.
Configure
Login Page Logo
Configure the logo for the SSL VPN login page.
Configure
Service Page Logo
Configure the logo for the SSL VPN service page.
Configure
Service Page Background
Configure the background for the SSL VPN service page.
Configure
Customize Page by File
Display configuration information for SSL VPN service page full customization.
Monitor
Set the parameters for SSL VPN service page full customization.
Configure
Manage Web Proxy
Display information about Web proxies.
Monitor
Create, modify, or delete Web proxies and configure the single sign-on (SSO) feature for the Web proxies.
Configure
Manage TCP Application
Remote Access Service
Display remote access services.
Monitor
Create, modify, or delete remote access services.
Configure
Desktop Share Service
Display desktop share services.
Monitor
Create, modify, or delete desktop share services.
Configure
Email Service
Display email services.
Monitor
Create, modify, or delete email services.
Configure
Notes Service
Display Notes services.
Monitor
Create, modify, or delete Notes services.
Configure
TCP Service
Display TCP services.
Monitor
Create, modify, or delete TCP services.
Configure
Manage IP Network
Global Configuration
Display the global settings for the IP network.
Monitor
Configure the global parameters for the IP network.
Configure
Host Configuration
Display configuration information for the hosts.
Monitor
Create, modify, or delete hosts.
Configure
User-IP Binding
Display user-IP binding information.
Monitor
Create, modify, or delete user-IP bindings.
Configure
Predefined Domain Name
Display predefined domain names.
Monitor
Create, modify, or delete predefined domain names.
Configure
Manage Resource Group
Display resource group information.
Monitor
Create, modify, or delete resource groups.
Configure
Configure Basic Settings
Domain Policy
Display SSL VPN domain policies.
Monitor
Configure SSL VPN domain policies.
Configure
Caching Policy
Display caching policies for SSL VPN domains.
Monitor
Configure caching policies for SSL VPN domains.
Configure
Bulletin Management
Display bulletins for SSL VPN domains.
Monitor
Create, modify, or delete bulletins.
Configure
Configure AuthN Policy
Local Authentication
Display configuration information for local authentication for SSL VPN domains.
Monitor
Configure local authentication for SSL VPN domains.
Configure
RADIUS Authentication
Display configuration information for RADIUS authentication for SSL VPN domains.
Monitor
Configure RADIUS authentication for SSL VPN domains.
Configure
LDAP Authentication
Display configuration information for LDAP authentication for SSL VPN domains.
Monitor
Configure LDAP authentication for SSL VPN domains.
Configure
AD Authentication
Display configuration information for AD authentication for SSL VPN domains.
Monitor
Configure AD authentication for SSL VPN domains.
Configure
Combined Authentication
Display configuration information for combined authentication for SSL VPN domains.
Monitor
Configure combined authentication for SSL VPN domains.
Configure
Configure Security Policy
Display security policies for SSL VPN domains.
Monitor
Create, modify, or delete security policies.
Configure
Enable Service
Display configuration information for SSL VPN services.
Monitor
Configure SSL VPN services.
Configure
Common items on the Web pages
Buttons and icons
Table 2 Commonly used buttons and icons
Button and icon
Applies the configuration on the current page.
Cancels the configuration on the current page, and returns to the corresponding list page or the Device Info page.
Refreshes the current page.
Clears all entries in a list or all statistics.
Adds an item.
Removes the selected items.
Selects all the entries in a list, or selects all ports on the device panel.
Clears all the entries in a list, or clears all ports on the device panel.
Restores the values of all the entries on the current page to the default.
Buffers settings you made and proceeds to the next step without applying the settings.
This button is typically present on the configuration wizard.
Buffers settings you made and returns to the previous step without applying the settings.
Applies all settings you made at each step and finishes the configuration task.
icon_mdf
Accesses a configuration page to modify settings.
This icon is typically present in the Operation column in a list,
icon_del
Deletes an entry.
Page display
The Web interface can display contents by pages, as shown in Figure 2. You can set the number of entries displayed per page, and view the contents on the first, previous, next, and last pages, or go to any page that you want to check.
A list can contain a maximum of 20000 entries if displayed in pages.
Figure 2 Content display by pages
Search function
The Web interface provides you with the basic and advanced search functions to display only the entries that match specific searching criteria.
·     Basic searchAs shown in Figure 2, input the keyword in the text box above the list, select a search item from the list and click Search to display the entries that match the criteria. Figure 3 shows an example of searching for entries with 00e0 included in the MAC address.
Figure 3 Basic search function example
·     Advanced searchAdvanced search function: As shown in Figure 2, you can click the Advanced Search link to open the advanced search page, as shown in Figure 4. Specify the search criteria, and click Apply to display the entries that match the criteria.
Figure 4 Advanced search
Take the ARP table shown in Figure 2 as an example. If you want to search for the ARP entries with 000f at the beginning of the MAC address, and IP address range being 192.168.1.50 to 192.168.1.59, follow these steps:
1.     Click the Advanced Search link, specify the search criteria on the advanced search page as shown in Figure 5, and click Apply. The ARP entries with 000f at the beginning of the MAC address are displayed.
Figure 5 Advanced search function example (1)
2.     Click the Advanced Search link, specify the search criteria on the advanced search page as shown in Figure 6, and click Apply. The ARP entries with 000f at the beginning of the MAC address and IP address range 192.168.1.50 to 192.168.1.59 are displayed as shown in Figure 7.
Figure 6 Advanced search function example (2)
Figure 7 Advanced search function example (III)
Sort function
The Web interface provides you with the basic functions to display entries in certain orders.
On a list page, you can click the blue heading item of each column to sort the entries based on the heading item you selected. After your clicking, the heading item is displayed with an arrow beside it as shown in Figure 8. The upward arrow indicates the ascending order, and the downward arrow indicates the descending order.
Figure 8 Basic sorting function example (based on IP address in the descending order)
