11-High Availability Configuration Examples
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Configuration Examples-Release1825P01-6W10011-High Availability Configuration Examples
05-S12500_BFD_Configuration_Examples
05-S12500_BFD_Configuration_Examples 362.5 KB
Introduction· 1
Prerequisites 1
General configuration restriction and guidelines 1
Example: Configuring BFD for the VRRP backup to monitor the master 1
Network requirements 1
Software version used· 2
Configuration procedures 2
Configuring Switch A·· 2
Configuring Switch B· 3
Verifying the configuration· 4
Configuration files 5
Example: Configuring BFD for the VRRP master to monitor the uplink· 6
Network requirements 6
Software version used· 7
Configuration procedures 7
Configuring Switch A·· 7
Configuring Switch B· 8
Verifying the configuration· 9
Configuration files 11
Example: Configuring BFD for OSPF· 12
Network requirements 12
Software version used· 12
Configuration restrictions and guidelines 13
Configuration procedures 13
Configuring Switch A·· 13
Configuring Switch B· 13
Verifying the configuration· 14
Configuration files 16
Example: Configure BFD for IS-IS· 17
Network requirements 17
Software version used· 17
Configuration restrictions and guidelines 17
Configuration procedures 17
Configuring Switch A·· 17
Configuring Switch B· 18
Verifying the configuration· 19
Configuration files 20
Example: Configuring BFD for RIP (single-hop detection in BFD echo packet mode) 21
Network requirements 21
Software version used· 22
Configuration procedures 22
Configuring Switch A·· 22
Configuring Switch B· 22
Verifying the configuration· 23
Configuration files 24
Example: Configuring BFD for RIP (bidirectional detection in BFD control packet mode) 25
Network requirements 25
Software version used· 26
Configuration restrictions and guidelines 26
Configuration procedures 26
Configuring Switch A·· 26
Configuring Switch B· 27
Configuring Switch C·· 27
Verifying the configuration· 28
Configuration files 29
Example: Configuring BFD for BGP· 30
Network requirements 30
Software version used· 31
Configuration restrictions and guidelines 31
Configuration procedures 31
Configuring Switch A·· 31
Configuring Switch B· 32
Verifying the configuration· 32
Configuration files 34
Example: Configuring BFD echo packet mode for static routing (single-hop detection) 35
Network requirements 35
Software version used· 36
Configuration procedures 36
Configuring Switch A·· 36
Verifying the configuration· 37
Configuration files 38
Related documentation· 39
Introduction
This document provides bidirectional forwarding detection (BFD) configuration examples.
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of links in IP. BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols.
This document assumes that you have basic knowledge of BFD.
IP tunnels, for example, IPv6 over IPv4 tunnels, IPv6 over IPv6 tunnels, IPv4 over IPv6 tunnels, and IPv4 over IPv4 tunnels, do not support BFD.
As shown in Figure 1, the enterprise assigns departments to different areas. Devices in each area access the core switches (Switch A and Switch B) through a Layer 2 switch. Create a VRRP group on Switch A and Switch B, and configure Switch A as the master and Switch B as the backup.
Configure BFD to monitor the state of the master on the backup. When the master fails, BFD immediately notifies the VRRP module of the failure. The backup becomes the new master, and link switchover is implemented.
Figure 1 Network diagram
This configuration example was created and verified on S12500-CMW520-R1825P01.
# Configure the IP address of the VLAN interface.
[SwitchA] vlan 2
[SwitchA–vlan2] port GigabitEthernet 3/0/1
[SwitchA–vlan2] quit
[SwitchA] interface GigabitEthernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] undo shutdown
[SwitchA-GigabitEthernet3/0/1] quit
[SwitchA–Vlan-interface2] undo shutdown
[SwitchA–Vlan-interface2] ip address 192.168.0.101 24
# Create VRRP group 1, and configure the virtual IP address for the VRRP group.
[SwitchA–Vlan-interface2] vrrp vrid 1 virtual-ip 192.168.0.10
# Set the priority of Switch A in VRRP group 1 to 110, which is higher than the priority of Switch B (default setting 100).
[SwitchA–Vlan-interface2] vrrp vrid 1 priority 110
[SwitchA–Vlan-interface2] return
# Configure the IP address of the VLAN-interface.
[SwitchB] vlan 2
[SwitchB–vlan2] port GigabitEthernet 3/0/1
[SwitchB–vlan2] quit
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] undo shutdown
[SwitchB-GigabitEthernet3/0/1] quit
[SwitchB–Vlan-interface2] undo shutdown
[SwitchB–Vlan-interface2] ip address 192.168.0.102 24
[SwitchB–Vlan-interface2] vrrp vrid 1 virtual-ip 192.168.0.10
[SwitchB–Vlan-interface2] quit
# Configure the source IP address of BFD echo packets (VRRP supports only BFD echo packet mode), which cannot be on the same network segment as any local interface's IP address.
[SwitchB] bfd echo-source-ip 10.10.10.10
# Configure the minimum BFD echo packet receiving interval on the interface and the detection multiplier.
[SwitchB–Vlan-interface2] bfd min-echo-receive-interval 10
[SwitchB–Vlan-interface2] bfd detect-multiplier 3
# Create the track object.
[SwitchB] track 1 bfd echo interface vlan-interface 2 remote ip 192.168.0.101 local ip 192.168.0.102
# Configure VRRP to monitor the status of track entry 1. When the status of the track entry becomes Negative, Switch B quickly becomes the master.
[SwitchB–Vlan-interface2] vrrp vrid 1 track 1 switchover
[SwitchB–Vlan-interface2] return
# Display the detailed information of VRRP group 1 on Switch A.
<SwitchA> display vrrp verbose
IPv4 Standby Information:
     Run Mode       : Standard
     Run Method     : Virtual MAC
   Interface Vlan-interface2
     VRID           : 1                    Adver Timer  : 1
     Admin Status   : Up                   State        : Master
     Config Pri     : 110                  Running Pri  : 110
     Preempt Mode   : Yes                  Delay Time   : 0
     Auth Type      : None
     Virtual IP     : 192.168.0.10
     Virtual MAC    : 0000-5e00-0101
     Master IP      : 192.168.0.101
# Display the detailed information of VRRP group 1 on Switch B.
<SwitchB> display vrrp verbose
     Run Mode       : Standard
     Admin Status   : Up                   State        : Backup
     Config Pri     : 100                  Running Pri  : 100
     Become Master  : 3100ms left
     Auth Type      : None
   VRRP Track Information:
     Track Object   : 1                    State : Positive   Switchover
# Display BFD session information.
<SwitchB> display bfd session
 Total session number: 1   Up session number: 1   Init mode: Active
 IPv4 session working under Echo mode:
 LD            SourceAddr      DestAddr        State Holdtime Interface
 1             192.168.0.102   192.168.0.101   Up    30ms     Vlan2
The output shows that Switch A in VRRP group 1 is the master and Switch B is the backup.
# When Switch A is down, use the display vrrp command to display the state information of the VRRP group. (Switch B becomes the master.)
     Run Mode       : Standard
     Auth Type      : None
     Virtual IP     : 192.168.1.10
     Master IP      : 192.168.1.102
     Track Object   : 1                    State : Negative   Switchover
 1             192.168.0.102   192.168.0.101   Down     /     Vlan2
# Display the detailed information of the track object on Switch B. (The track entry status is Negative.)
<SwitchB> display track 1
Track ID: 1
  Status: Negative
  Duration: 0 days 0 hours 1 minutes 17 seconds
  Notification delay: Positive 0, Negative 0 (in seconds)
  Reference object:
    BFD session:
    Packet type: Echo
    Interface  : Vlan-interface2
    Remote IP  : 192.168.1.101
    Local IP   : 192.168.1.102
Configuration files
·     Switch A:
 vlan 2
interface Vlan-interface2
 ip address 192.168.0.101 255.255.255.0
interface GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 2
·     Switch B:
 vlan 2
 ip address 192.168.0.102 255.255.255.0
 port access vlan 2
track 1 bfd echo interface Vlan-interface2 remote ip 192.168.0.101 local ip 192.168.0.102
As shown in Figure 2, the enterprise assigns departments to different areas. Devices in each area access the core switches (Switch A and Switch B) through a Layer 2 switch. Create a VRRP group on Switch A and Switch B, and configure Switch A as the master and Switch B as the backup.
When the uplink of the master fails, VRRP cannot detect the failure, and users still forward traffic to the master (Switch A). To resolve this issue, configure BFD to monitor the state of uplink on the master. When the uplink of the master fails, BFD immediately notifies the VRRP module of the failure. The backup becomes the new master, and link switchover is implemented.
Figure 2 Network diagram
# Configure the uplink VLAN interface and its IP address.
[SwitchA] vlan 3
[SwitchA–vlan3] port GigabitEthernet 3/0/1
[SwitchA–vlan3] quit
[SwitchA–Vlan-interface3] undo shutdown
[SwitchA–Vlan-interface3] ip address 1.1.1.1 24
[SwitchA–Vlan-interface3] quit
# Configure the VLAN interface to be enabled with VRRP, and configure its IP address.
[SwitchA] vlan 2
[SwitchA–vlan2] port GigabitEthernet 3/0/2
[SwitchA] interface GigabitEthernet 3/0/2
[SwitchA-GigabitEthernet3/0/2] undo shutdown
[SwitchA-GigabitEthernet3/0/2] quit
[SwitchA–Vlan-interface2] quit
[SwitchA] bfd echo-source-ip 10.10.10.10
# Configure the minimum BFD echo packet receiving interval on the interface.
[SwitchA–Vlan-interface3] bfd min-echo-receive-interval 10
# Configure the detection multiplier.
[SwitchA–Vlan-interface3] bfd detect-multiplier 3
# Create the track entry associated with the BFD session, and specify the local and remote IP addresses of BFD echo packets.
[SwitchA] track 1 bfd echo interface vlan-interface 3 remote ip 1.1.1.2 local ip 1.1.1.1
# Configure VRRP group 1 to monitor the status of track entry 1. When the status of the track entry becomes Negative, the priority of Switch A decreases by 20. Switch B then becomes the new master, and link switchover is implemented.
[SwitchA–Vlan-interface2] vrrp vrid 1 track 1 reduced 20
# Configure the VLAN interface to be enabled with VRRP and its IP address.
[SwitchB] vlan 2
# Create VRRP group 1 and configure its virtual IP address.
     Run Mode       : Standard
     Auth Type      : None
     Track Object   : 1                    State : Positive   Pri Reduced : 20
     Run Mode       : Standard
     Auth Type      : None
# Display BFD session information on Switch A.
<SwitchA> display bfd session
 1             1.1.1.1         1.1.1.2         Up    30ms     Vlan3
# When the uplink monitored by Switch A is down, use the display vrrp command to display the state information of the VRRP group. When the uplink monitored by Switch A is down, display the detailed VRRP group information of Switch A.
     Run Mode       : Standard
     Config Pri     : 110                  Running Pri  : 90
     Auth Type      : None
     Master IP      : 192.168.0.102
     Track Object   : 1                    State : Negative   Pri Reduced : 20
# When the uplink monitored by Switch A is down, display the detailed VRRP group information of Switch B.
     Run Mode       : Standard
     Auth Type      : None
 1             1.1.1.1         1.1.1.2         Down     /     Vlan2
# Display the detailed information of the track object on Switch A.
<SwitchA> display track 1
Track ID: 1
  Status: Negative
  Duration: 0 days 0 hours 3 minutes 33 seconds
  Reference object:
    BFD session:
    Packet type: Echo
    Interface  : Vlan-interface3
    Remote IP  : 1.1.12
    Local IP   : 1.1.1.1
Configuration files
·     Switch A:
 vlan 2
 vlan 3
interface Vlan-interface3
 ip address 1.1.1.1 255.255.255.0
 port access vlan 3
interface GigabitEthernet3/0/2
 port access vlan 2
track 1 bfd echo interface Vlan-interface3 remote ip 1.1.1.2 local ip 1.1.1.1
·     Switch B:
 vlan 2
 vlan 3
 port access vlan 2
As shown in Figure 3, the egress switches (Switch A and Switch B) of two departments are connected through a Layer 2 switch. Run OSPF on Switch A and Switch B so that they can establish neighbor relationship.
When the link between Switch B and the Layer 2 switch fails, Switch A cannot detect the failure until the neighbor relationship with Switch B is terminated. To implement fast link fault detection, configure BFD for OSPF. When the link between Switch B and the Layer 2 switch fails, Switch A can quickly detect the failure and displays prompt messages for the network administrator to locate the link fault.
Figure 3 Network diagram
In BFD control packet mode, at least one end must operate in active mode for a BFD session to be established.
# Create a VLAN interface and configure its IP address.
[SwitchA] vlan 10
[SwitchA-vlan10] port GigabitEthernet 3/0/1
[SwitchA-vlan10] quit
[SwitchA-Vlan-interface10] undo shutdown
[SwitchA-Vlan-interface10] ip address 10.1.0.102 24
# Configure OSPF basic functions and enable BFD for OSPF (OSPF supports only BFD control packet mode).
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[SwitchA-ospf-1] quit
[SwitchA-Vlan-interface10] ospf bfd enable
# Configure BFD operating mode and relevant parameters.
[SwitchA-Vlan-interface10] bfd min-transmit-interval 100
[SwitchA-Vlan-interface10] bfd min-receive-interval 100
[SwitchA-Vlan-interface10] bfd detect-multiplier 3
[SwitchA] quit
[SwitchB] vlan 10
[SwitchB-vlan10] port GigabitEthernet 3/0/2
[SwitchB-vlan10] quit
[SwitchB] interface GigabitEthernet 3/0/2
[SwitchB-GigabitEthernet3/0/2] undo shutdown
[SwitchB-GigabitEthernet3/0/2] quit
[SwitchB-Vlan-interface10] undo shutdown
[SwitchB-Vlan-interface10] ip address 10.1.0.100 24
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[SwitchB-ospf-1] quit
[SwitchB-Vlan-interface10] ospf bfd enable
[SwitchB] bfd session init-mode active
[SwitchB] interface vlan 10
[SwitchB-Vlan-interface10] bfd min-transmit-interval 100
[SwitchB-Vlan-interface10] bfd min-receive-interval 100
[SwitchB-Vlan-interface10] bfd detect-multiplier 3
[SwitchB] quit
# Display information about OSPF neighbors.
[SwitchA]display ospf peer verbose
                  Neighbors
 Area 0.0.0.0 interface 10.1.0.102(Vlan-interface10)'s neighbors
 Router ID: 1.1.1.1          Address: 10.1.0.100       GR State: Normal
   State: Full  Mode: Nbr is Slave  Priority: 1
   DR: 10.1.0.102  BDR: 10.1.0.100  MTU: 0
   Dead timer due in 32  sec
   Neighbor is up for 00:21:37
   Neighbor state change count: 5
 Last Neighbor Down Event:
 Router ID: 1.1.1.1
 Local Address: 10.1.0.102
 Remote Address: 10.1.0.100
 Time: Jan  7 10:04:26 2009
 Reason: DeadInterval timer expired
# Display BFD session information. A BFD session is created and is up.
[SwitchA] display bfd session verbose
 IPv4 session working under Ctrl mode:
     Local Discr: 10                  Remote Discr: 1
       Source IP: 10.1.0.102        Destination IP: 10.1.0.100
   Session State: Up                     Interface: Vlan-interface10
 Min Trans Inter: 100ms            Act Trans Inter: 100ms
  Min Recv Inter: 100ms           Act Detect Inter: 300ms
  Running Up for: 00:24:03               Auth mode: None
    Connect Type: Direct                 Board Num: 0
        Protocol: OSPF
       Diag Info: No Diagnostic
[SwitchB] display bfd session verbose
     Local Discr: 1                   Remote Discr: 10
       Source IP: 10.1.0.100        Destination IP: 10.1.0.102
  Running Up for: 00:27:56               Auth mode: None
    Connect Type: Direct                 Board Num: 1
        Protocol: OSPF
When the link between Switch B and the Layer 2 switch fails, BFD can quickly detect the failure and notify OSPF of the failure.
%Apr  2 11:34:26:880 2013 SwitchA BFD/5/BFD_CHANGE_FSM: Sess[10.1.0.102/10.1.0.100,1026/1026
,Vlan10,Ctrl], Sta: UP->DOWN, Diag: 5
%Apr  2 11:34:27:011 2013 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 10.1.0.100Vlan-interface10) from Full to Down.
# Execute the display ospf peer verbose command. The OSPF neighbor state changes to down.
[SwitchA] display ospf peer verbose
 Router ID: 1.1.1.1
 Time: Apr  2 11:34:47 2013
 Reason: BFD session down
Configuration files
·     Switch A:
 Vlan 10
interface Vlan-interface10
 ip address 10.1.0.102 255.255.255.0
 ospf bfd enable
 port access vlan 10
ospf 1
 area 0.0.0.0
·     Switch B:
 Vlan 10
 ip address 10.1.0.100 255.255.255.0
 ospf bfd enable
 port access vlan 10
ospf 1
 area 0.0.0.0
As shown in Figure 4, the egress switches (Switch A and Switch B) of two departments are connected through a Layer 2 switch. Run IS-IS on Switch A and Switch B so that they can establish neighbor relationship.
When the link between Switch B and the Layer 2 switch fails, Switch A cannot detect the failure until the neighbor relationship with Switch B is terminated. To implement fast link fault detection, configure BFD for IS-IS. When the link between Switch B and the Layer 2 switch fails, Switch A can quickly detect the failure and displays prompt messages for the network administrator to locate the link fault.
Figure 4 Network diagram
[SwitchA] vlan 10
[SwitchA-Vlan-interface10] ip address 167.1.1.1 24
# Configure IS-IS basic functions and enable BFD for IS-IS (IS-IS supports only BFD control packet mode).
[SwitchA] isis
[SwitchA-isis-1] network-entity 00.0000.0000.0000.0001.00
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface10] isis enable
[SwitchA-Vlan-interface10] isis bfd enable
[SwitchA] quit
[SwitchB] vlan 10
[SwitchB-Vlan-interface10] ip address 167.1.1.2 24
[SwitchB] isis
[SwitchB-isis-1] network-entity 00.0000.0000.0000.0002.00
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface10] isis enable
[SwitchB-Vlan-interface10] isis bfd enable
[SwitchB] quit
# Display information about IS-IS neighbors.
[SwitchA] display isis peer verbose
                          Peer information for ISIS(1)
  System Id: 0000.0000.0002
  Interface: Vlan10                  Circuit Id: 0000.0000.0001.01
  State: Up     HoldTime: 29s        Type: L1(L1L2)     PRI: 64
  Area Address(es):00.0000
  Peer IP Address(es): 167.1.1.2
  Uptime: 00:21:20
  Adj Protocol:  IPv4
  State: Up     HoldTime: 30s        Type: L2(L1L2)     PRI: 64
  Uptime: 00:21:16
  Adj Protocol:  IPv4
     Local Discr: 11                  Remote Discr: 2
       Source IP: 167.1.1.1        Destination IP: 167.1.1.2
  Running Up for: 00:22:14               Auth mode: None
        Protocol: ISIS_BR_L1/ISIS_BR_L2
     Local Discr: 2                   Remote Discr: 11
       Source IP: 167.1.1.2        Destination IP: 167.1.1.1
  Running Up for: 00:23:52               Auth mode: None
When the link between Switch B and the Layer 2 switch fails, BFD can quickly detect the failure and notify IS-IS of the failure.
%Apr  2 13:43:37:133 2013 SwitchA BFD/5/BFD_CHANGE_FSM: Sess[167.1.1.1/167.1.1.2,1025/1025
%Apr  2 13:43:37:265 2013 SwitchA ISIS/5/ISIS_NBR_CHG: ISIS 1 Adjacency to 0000.0000.0
002 (Vlan10) DOWN, Level-1 Adjacency clear.
%Apr  2 13:43:37:396 2013 SwitchA ISIS/5/ISIS_NBR_CHG: ISIS 1 Adjacency to 0000.0000.0
002 (Vlan10) DOWN, Level-2 Adjacency clear.
Configuration files
·     Switch A:
 vlan 10
isis 1
 ip address 167.1.1.1 255.255.255.0
 isis enable 1
 isis bfd enable
 port access vlan 10
·     Switch B:
 vlan 10
isis 1
 ip address 167.1.1.2 255.255.255.0
 isis enable 1
 isis bfd enable
 port access vlan 10
As shown in Figure 5, the egress switches (Switch A and Switch B) of two departments are connected through a Layer 2 switch. Run RIP on Switch A and Switch B so that they can establish neighbor relationship.
When the link between Switch B and the Layer 2 switch fails, Switch A cannot detect the failure until the neighbor relationship with Switch B is terminated. To implement fast link fault detection, configure BFD for RIP. When the link between Switch B and the Layer 2 switch fails, Switch A can quickly detect the failure and displays prompt messages for the network administrator to locate the link fault.
Figure 5 Network diagram
[SwitchA] vlan 100
[SwitchA-vlan100] port GigabitEthernet 3/0/1
[SwitchA-vlan100] quit
[SwitchA-Vlan-interface100] undo shutdown
[SwitchA-Vlan-interface100] ip address 198.168.1.1 24
# Configure RIP basic functions and enable BFD for RIP.
[SwitchA] rip 1
[SwitchA-rip-1] network 198.168.1.0
[SwitchA-rip-1] import-route direct
[SwitchA-rip-1] quit
[SwitchA-Vlan-interface100] rip bfd enable
# Configure BFD parameters. (Because Switch B is one hop away, you only need to configure BFD echo packet mode.)
[SwitchA] bfd echo-source-ip 11.11.11.11
[SwitchA-Vlan-interface100] bfd min-echo-receive-interval 100
[SwitchA-Vlan-interface100] bfd detect-multiplier 3
[SwitchA] quit
[SwitchB] vlan 100
[SwitchB-vlan100] port GigabitEthernet 3/0/2
[SwitchB-vlan100] quit
[SwitchB-Vlan-interface100] undo shutdown
[SwitchB-Vlan-interface100] ip address 198.168.1.2 24
# Configure RIP basic functions and enable direct route redistribution (so that Switch B sends all direct routes to Switch A).
[SwitchB] rip 1
[SwitchB-rip-1] network 198.168.1.0
[SwitchB-rip-1] import-route direct
[SwitchB-rip-1] quit
# Display RIP route information on Switch A. Switch A learns the direct route advertised by Switch B.
[SwitchA] display ip routing-table protocol rip
Public Routing Table : RIP
Summary Count : 4
RIP Routing table Status : < Active>
Summary Count : 1
53.0.0.0/24         RIP    100  1            198.168.1.2     Vlan100
RIP Routing table Status : < Inactive>
Summary Count : 3
20.0.0.0/24         RIP    100  1            198.168.1.2     Vlan100
30.0.0.0/24         RIP    100  1            198.168.1.2     Vlan100
100.0.0.0/16        RIP    100  1            198.168.1.2     Vlan100
     Local Discr: 1391
       Source IP: 198.168.1.1       Destination IP: 198.168.1.2
   Session State: Up                     Interface: Vlan-interface100
  Min Recv Inter: 100ms            Act Trans Inter: 100ms
Act Detect Inter: 300ms             Running Up for: 00:51:31
        Protocol: RIP
When the link between Switch B and the Layer 2 switch fails, BFD can quickly detect the failure and notify RIP of the failure.
%Apr  2 13:52:02:638 2013 SwitchA BFD/5/BFD_CHANGE_FSM: Sess[192.168.1.1/192.168.1.2,1027/0,Vlan100,Echo], Sta: UP->DOWN, Diag: 5
# Display information about RIP routes. The routes learned through RIP are deleted.
Summary Count : 0
Summary Count : 0
Summary Count : 0
Configuration files
·     Switch A:
 vlan 100
interface Vlan-interface100
 ip address 198.168.1.1 255.255.255.0
 rip bfd enable
 port access vlan 100
rip 1
 network 198.168.1.0
 import-route direct
·     Switch B:
 vlan 100
 ip address 198.168.1.2 255.255.255.0
rip 1
 network 198.168.1.0
 import-route direct
As shown in Figure 6, the egress switches (Switch A and Switch C) of two departments are connected to the Internet through a core switch Switch B. Configure static routes between Switch A and Switch C, and establish RIP neighbor relationship between them.
When the link between Switch A and Switch B or between Switch B and Switch C fails, the switches cannot detect the failure until the RIP neighbor relationship is terminated. To implement fast link fault detection, configure BFD for RIP. When the link between Switch A and Switch B or between Switch B and Switch C fails, Switch A and Switch C can quickly detect the failure and displays prompt messages for the network administrator to locate the link fault.
Figure 6 Network diagram
[SwitchA] vlan 100
# Configure RIP basic functions and enable BFD for RIP. (Because Switch C is not directly connected, you must configure BFD control packet mode.)
[SwitchA] rip 1
[SwitchA-rip-1] peer 198.168.2.2
[SwitchA-rip-1] undo validate-source-address
[SwitchA-Vlan-interface100] bfd min-transmit-interval 100
[SwitchA-Vlan-interface100] bfd min-receive-interval 100
# Configure a static route to Switch C.
[SwitchA] ip route-static 198.168.2.0 24 vlan-interface 100 198.168.1.2
[SwitchB] vlan 100
[SwitchB] vlan 200
[SwitchB-vlan200] port GigabitEthernet 3/0/1
[SwitchB-vlan200] quit
[SwitchB-Vlan-interface200] undo shutdown
[SwitchB-Vlan-interface200] ip address 198.168.2.1 24
[SwitchC] vlan 200
[SwitchC-vlan200] port GigabitEthernet 3/0/1
[SwitchC-vlan200] quit
[SwitchC] interface GigabitEthernet 3/0/1
[SwitchC-GigabitEthernet3/0/1] undo shutdown
[SwitchC-GigabitEthernet3/0/1] quit
[SwitchC-Vlan-interface200] undo shutdown
[SwitchC-Vlan-interface200] ip address 198.168.2.2 24
# Configure RIP basic functions and enable BFD for RIP. (Because Switch A is not directly connected, you must configure BFD control packet mode.)
[SwitchC] rip 1
[SwitchC-rip-1] network 198.168.2.0
[SwitchC-rip-1] peer 198.168.1.1
[SwitchC-rip-1] undo validate-source-address
[SwitchC-rip-1] import-route direct
[SwitchC-rip-1] quit
[SwitchC-Vlan-interface200] rip bfd enable
[SwitchC] bfd session init-mode active
[SwitchC] interface vlan 200
[SwitchC-Vlan-interface200] bfd min-transmit-interval 100
[SwitchC-Vlan-interface200] bfd min-receive-interval 100
[SwitchC-Vlan-interface200] bfd detect-multiplier 3
# Configure a static route to Switch A.
[SwitchC] ip route-static 198.168.1.0 24 vlan-interface 200 198.168.2.1
# Display BFD session information when the link is normal.
 LD/RD         SourceAddr      DestAddr        State Holdtime Interface
 1393/693      198.168.1.1     198.168.2.2     Up    200ms    Vlan100
# Display the routing information of RIP process 1.
[SwitchA] display rip 1 route
 Peer 198.168.2.2  on Vlan-interface100
      Destination/Mask        Nexthop     Cost    Tag   Flags   Sec
          3.0.0.0/8        198.168.2.2      1       0    RA      14
         65.0.0.0/8        198.168.2.2      1       0    RA      14
      198.168.1.0/24       198.168.2.2      1       0    RA      14
# Display BFD session information when the link fails. The BFD session is down, the routes are deleted, and the BFD session is deleted.
Configuration files
·     Switch A:
vlan 100
 rip bfd enable
rip 1
 peer 198.168.2.2
 network 198.168.1.0
 import-route direct
ip route-static 198.168.2.0 255.255.255.0 Vlan-interface100 198.168.1.2
·     Switch B:
 vlan 100
 vlan 200
interface Vlan-interface200
 ip address 198.168.2.1 255.255.255.0
 port access vlan 200
·     Switch C:
 vlan 200
 ip address 198.168.2.2 255.255.255.0
 rip bfd enable
rip 1
 peer 198.168.1.1
 network 198.168.2.0
 import-route direct
ip route-static 198.168.1.0 255.255.255.0 Vlan-interface200 198.168.2.1
As shown in Figure 7, the egress switches (Switch A and Switch B) of two departments are connected through a Layer 2 switch. Switch A and Switch B establish an IBGP neighbor relationship.
When the link between Switch B and the Layer 2 switch fails, Switch A cannot detect the failure until the IBGP neighbor relationship with Switch B is terminated. To implement fast link fault detection, configure BFD for BGP. When the link between Switch B and the Layer 2 switch fails, Switch A can quickly detect the failure and displays prompt messages for the network administrator to locate the link fault.
Figure 7 Network diagram
[SwitchA] vlan 10
# Configure BGP basic functions and enable BFD for BGP (BGP supports only BFD control packet mode).
[SwitchA] bgp 100
[SwitchA-bgp] peer 10.1.0.100 as-number 100
[SwitchA-bgp] peer 10.1.0.100 bfd
[SwitchA-bgp] quit
[SwitchA] quit
[SwitchB] vlan 10
[SwitchB] bgp 100
[SwitchB-bgp] peer 10.1.0.102 as-number 100
[SwitchB-bgp] peer 10.1.0.102 bfd
[SwitchB-bgp] quit
[SwitchB] quit
# Display detailed information about BGP peers.
[SwitchA] display bgp peer verbose
         Peer: 10.1.0.100        Local: 2.2.2.2
         Type: IBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 01h51m18s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 1024     Remote - 179
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Peer support bgp route AS4 capability
         Address family IPv4 Unicast: advertised and received
 Received: Total 100 messages, Update messages 0
 Sent: Total 111 messages, Update messages 0
 Threshold: 75%
 Minimum time between advertisement runs is 15 seconds
 Optional capabilities:
 Peer Preferred Value: 0
 BFD: Enabled
 Routing policy configured:
     Local Discr: 12                  Remote Discr: 3
  Running Up for: 01:51:58               Auth mode: None
        Protocol: BGP
     Local Discr: 3                   Remote Discr: 12
  Running Up for: 01:52:35               Auth mode: None
        Protocol: BGP
When the link between Switch B and the Layer 2 switch fails, BFD can quickly detect the failure and notify BGP of the failure.
%Apr  2 14:27:22:171 2013 SwitchA BFD/5/BFD_CHANGE_FSM: Sess[10.1.0.102/10.1.0.100,1025/1025,Vlan10,Ctrl], Sta: UP->DOWN, Diag: 5
%Apr  2 14:27:22:303 2013 SwitchA BGP/5/BGP_STATE_CHANGED:
 10.1.0.100 state is changed from ESTABLISHED to IDLE.
Configuration files
·     Switch A:
 vlan 10
 port access vlan 10
bgp 100
 undo synchronization
 peer 10.1.0.100 bfd
·     Device B:
 vlan 10
 port access vlan 10
bgp 100
 peer 10.1.0.102 bfd
As shown in Figure 8, Switch A has two paths to reach Switch C, with next hops being Switch B and Switch D. Switch A and Switch C are connected to the Internet through Switch B. Switch A and Switch B are connected through a Layer 2 switch.
When the link between Switch B and the Layer 2 switch fails, Switch A cannot detect the failure. To implement fast link fault detection, configure BFD for static routes. When the link between Switch B and the Layer 2 switch fails, Switch A can quickly detect the failure (within 1 second) and switch the forwarding path.
Figure 8 Network diagram
# Create VLAN interfaces and configure their IP addresses.
[SwitchA] vlan 10
[SwitchA-vlan10] port GigabitEthernet 4/0/1
[SwitchA] interface GigabitEthernet 4/0/1
[SwitchA-GigabitEthernet4/0/1] undo shutdown
[SwitchA-GigabitEthernet4/0/1] quit
[SwitchA-Vlan-interface10] ip address 10.1.1.102 24
[SwitchA] vlan 11
[SwitchA-vlan11] port GigabitEthernet 9/0/48
[SwitchA-vlan11] quit
[SwitchA] interface GigabitEthernet 9/0/48
[SwitchA-GigabitEthernet9/0/48] undo shutdown
[SwitchA-GigabitEthernet9/0/48] quit
[SwitchA-Vlan-interface11] undo shutdown
[SwitchA-Vlan-interface11] ip address 11.1.1.1 24
# Configure two static routes with the same destination IP address and different preferences. Configure the BFD echo packet mode (because Switch B is one hop away) for the preferred static route (Switch A –> Switch B –> Switch C). Specify an IP address that is not used by any interface as the source IP address of BFD echo packets.
[SwitchA] ip route-static 120.1.1.1 32 Vlan-interface 10 10.1.1.100 bfd echo-packet preference 40
[SwitchA] ip route-static 120.1.1.1 32 Vlan-interface 11 11.1.1.2 preference 50
[SwitchA-Vlan-interface10] bfd min-echo-receive-interval 10
# Display static route information. The static route with a lower preference is active.
[SwitchA] display ip routing-table protocol static verbose
Routing Table : Public
Summary Count : 2
  Destination: 120.1.1.1/32
     Protocol: Static          Process ID: 0
   Preference: 40                    Cost: 0
      NextHop: 10.1.1.100       Interface: Vlan-interface10
    BkNextHop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
  BKTunnel ID: 0x0                BKLabel: NULL
        State: Active Adv Bfd         Age: 00h02m13s
          Tag: 0
   Preference: 50                    Cost: 0
      NextHop: 11.1.1.2         Interface: Vlan-interface11
        State: Inactive Adv           Age: 00h00m32s
          Tag: 0
     Local Discr: 13
       Source IP: 10.1.1.102        Destination IP: 10.1.1.100
  Min Recv Inter: 10ms             Act Trans Inter: 10ms
Act Detect Inter: 30ms              Running Up for: 00:03:33
        Protocol: STATIC
When the link between Switch B and the Layer 2 switch fails, the BFD session goes down and the other static route becomes active.
%Jan  7 14:23:39:786 2009 125/6697 BFD/4/LOG:Sess[10.1.1.102/10.1.1.100,Vlan10,Echo], Sta: UP->DOWN, Diag: 5
*Jan  7 14:23:39:786 2009 125/6697 RM/3/RMDEBUG:Route with Dest : 120.1.1.1, Mask : 255.255.255.255, Nexthop : 10.1.1.100, Neighbor
: 0.0.0.0 made Inactive
 Calculate active route with 120.1.1.1/32 protocol:0 TableID:1
*Jan  7 14:23:39:787 2009 125/6697 RM/3/RMDEBUG:Route with Dest : 120.1.1.1, Mask : 255.255.255.255, Nexthop : 11.1.1.2, Neighbor :
0.0.0.0 made active
Summary Count : 2
        State: Invalid Adv Bfd        Age: 00h10m58s
          Tag: 0
        State: Active Adv             Age: 00h09m17s
          Tag: 0
Configuration files
 vlan 10
 vlan 11
 ip address 10.1.1.102 255.255.255.0
interface Vlan-interface11
 ip address 11.1.1.1 255.255.255.0
interface GigabitEthernet4/0/1
 port access vlan 10
interface GigabitEthernet9/0/48
 port access vlan 11
ip route-static 120.1.1.1 255.255.255.255 Vlan-interface10 10.1.1.100 bfd echo-packet preference 40
 ip route-static 120.1.1.1 255.255.255.255 Vlan-interface11 11.1.1.2 preference 50
·     H3C S12500 Routing Switch Series High Availability Configuration Guide
·     H3C S12500 Routing Switch Series High Availability Command Reference
