10-Security Command Reference
HomeSupportRoutersH3C SR8800 Router SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10310-Security Command Reference
04-Portal Commands
04-Portal Commands 165.77 KB
display portal acl
display portal acl { all | dynamic | static } interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all portal access control lists (ACLs), including dynamic ones and static ones.
dynamic: Displays dynamic portal ACLs, namely, ACLs generated after a user passes portal authentication.
static: Displays static portal ACLs, namely, ACLs generated by related configurations.
interface interface-type interface-number: Displays the ACLs on the specified interface.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display portal acl command to display the ACLs on a specific interface.
# Display all ACLs on interface GigabitEthernet 2/1/1.
<Sysname> display portal acl all interface GigabitEthernet2/1/1
GigabitEthernet2/1/1 portal ACL rule:
 Rule 0
 Inbound interface : GigabitEthernet2/1/1
 Type              : static
 Action            : permit
 Source:
    IP        : 1.1.1.1
    Mask      : 255.255.255.255
    MAC       : 0000-0000-0000
    Interface : any
    VLAN      : 0
    Protocol  : 0
 Destination:
    IP        : 192.168.0.111
 Rule 1
 Type              : dynamic
 Action            : permit
 Source:
    IP        : 3.3.3.0
    Mask      : 255.255.255.0
    Interface : any
    VLAN      : 0
    Protocol  : 0
 Destination:
    IP        : 192.168.0.111
 Rule 2
 Type              : dynamic
 Action            : permit
 Source:
    IP        : 1.1.2.3
    Interface : any
    VLAN      : 0
    Protocol  : 0
 Destination:
    IP        : 2.2.2.0
Author ACL:
    Number   : 3001
Table 1 Output description
Rule
Sequence number of the generated ACL, which is numbered from 0 in ascending order.
Inbound interface
Interface to which portal ACLs are bound.
Type of the portal ACL.
Action
Match action in the portal ACL.
Source
Source information in the portal ACL.
IP
Source IP address in the portal ACL.
Mask
Subnet mask of the source IP address in the portal ACL.
MAC
Source MAC address in the portal ACL.
Source interface in the portal ACL.
VLAN
Source VLAN in the portal ACL.
Protocol
Protocol type in the portal ACL.
Destination
Destination information in the portal ACL
IP
Destination IP address in the portal ACL.
Mask
Subnet mask of the destination IP address in the portal ACL.
Author ACL
Authorization ACL of portal ACL. It is displayed only when the Type field has a value of dynamic.
Number
Authorization ACL number assigned by the server. None indicates that the server did not assign any ACL.
display portal connection statistics
display portal connection statistics { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Specifies all interfaces.
Use the display portal connection statistics command to display portal connection statistics on a specific interface or all interfaces.
# Display portal connection statistics on interface GigabitEthernet 2/1/1.
<Sysname> display portal connection statistics interface GigabitEthernet2/1/1
 ---------------Interface: GigabitEthernet2/1/1-----------------------
 User state statistics:
 State-Name                User-Num
 VOID                      0
 DISCOVERED                0
 WAIT_AUTHEN_ACK           0
 WAIT_AUTHOR_ACK           0
 WAIT_LOGIN_ACK            0
 WAIT_ACL_ACK              0
 WAIT_NEW_IP               0
 WAIT_USERIPCHANGE_ACK     0
 ONLINE                    0
 WAIT_LOGOUT_ACK           0
 WAIT_LEAVING_ACK          0
 Message statistics:
Msg-Name                  Total         Err           Discard
 MSG_AUTHEN_ACK            0             0             0
 MSG_AUTHOR_ACK            0             0             0
 MSG_LOGIN_ACK             0             0             0
 MSG_LOGOUT_ACK            0             0             0
 MSG_LEAVING_ACK           0             0             0
 MSG_CUT_REQ               0             0             0
 MSG_AUTH_REQ              0             0             0
 MSG_LOGIN_REQ             0             0             0
 MSG_LOGOUT_REQ            0             0             0
 MSG_LEAVING_REQ           0             0             0
 MSG_ARPPKT                0             0             0
 MSG_PORT_REMOVE           0             0             0
 MSG_VLAN_REMOVE           0             0             0
 MSG_IF_REMOVE             1             0             0
 MSG_IF_SHUT               0             0             0
 MSG_IF_DISPORTAL          0             0             0
 MSG_IF_UP                 0             0             0
 MSG_ACL_RESULT            0             0             0
 MSG_CUT_L3IF              0             0             0
 MSG_IP_REMOVE             0             0             0
 MSG_ALL_REMOVE            0             0             0
 MSG_IFIPADDR_CHANGE       0             0             0
 MSG_SOCKET_CHANGE         2             0             0
 MSG_VLAN_BATCH            0             0             0
 MSG_ACL_DELETE            0             0             0
 MSG_ACL_UPDATE            0             0             0
Table 2 Output description
Statistics on portal users
State-Name
Name of a user state
User-Num
Number of users in a specific state
VOID
Number of users in void state
DISCOVERED
Number of users in discovered state
WAIT_AUTHEN_ACK
Number of users in wait_authen_ack state
WAIT_AUTHOR_ACK
Number of users in wait_author_ack state
WAIT_LOGIN_ACK
Number of users in wait_login_ack state
WAIT_ACL_ACK
Number of users in wait_acl_ack state
WAIT_NEW_IP
Number of users in wait_new_ip state
Number of users wait_useripchange_ack state
ONLINE
Number of users in online state
WAIT_LOGOUT_ACK
Number of users in wait_logout_ack state
WAIT_LEAVING_ACK
Number of users in wait_leaving_ack state
Message statistics
Statistics on messages
Msg-Name
Message type
Total
Total number of messages of a specific type
Err
Number of erroneous messages of a specific type
Discard
Number of discarded messages of a specific type
MSG_AUTHEN_ACK
Authentication acknowledgment message
MSG_AUTHOR_ACK
Authorization acknowledgment message
MSG_LOGIN_ACK
Accounting acknowledgment message
MSG_LOGOUT_ACK
Accounting-stop acknowledgment message
MSG_LEAVING_ACK
Leaving acknowledgment message
MSG_CUT_REQ
Cut request message
MSG_AUTH_REQ
Authentication request message
MSG_LOGIN_REQ
Accounting request message
MSG_LOGOUT_REQ
Accounting-stop request message
MSG_LEAVING_REQ
Leaving request message
MSG_ARPPKT
ARP message
MSG_PORT_REMOVE
Users-of-a-Layer-2-port-removed message
MSG_VLAN_REMOVE
VLAN-user-removed message
MSG_IF_REMOVE
Message indicating the users on a Layer 3 interface were removed because the Layer 3 interface was removed.
MSG_IF_SHUT
Layer 3 interface shutdown message
MSG_IF_DISPORTAL
Portal-disabled-on-interface message
MSG_IF_UP
Layer 3-interface-came-up message
MSG_ACL_RESULT
ACL deployment failure message
MSG_CUT_L3IF
Message indicating the users on a Layer 3 interface were removed because they were logged out.
MSG_IP_REMOVE
User-with-an-IP-removed message
MSG_ALL_REMOVE
All-users-removed message
MSG_IFIPADDR_CHANGE
Interface IP address change message
MSG_SOCKET_CHANGE
Socket change message
MSG_VLAN_BATCH
VLAN batch assignment message
MSG_NOTIFY
Notification message
MSG_SETPOLICY
Set policy message for assigning security ACL
MSG_SETPOLICY_RESULT
Set policy response message
display portal free-rule
display portal free-rule [ rule-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
rule-number: Number of a portal-free rule. The value ranges from 0 to 63.
Use the display portal free-rule command to display information about a specific portal-free rule or all portal-free rules.
Related commands: portal free-rule.
# Display information about portal-free rule 0.
<Sysname> display portal free-rule 0
 Rule-Number  0:
 Source:
   IP        : 1.1.2.3
   Interface : any
   Vlan      : 0
 Destination:
   IP        : 2.2.2.0
Table 3 Output description
Rule-Number
Number of the portal-free rule
Source
Source information in the portal-free rule
IP
Source IP address in the portal-free rule
Mask
Subnet mask of the source IP address in the portal-free rule
MAC
Source MAC address in the portal-free rule
Source interface in the portal-free rule
Vlan
Source VLAN in the portal-free rule
Destination
Destination information in the portal-free rule
IP
Destination IP address in the portal-free rule
Mask
Subnet mask of the destination IP address in the portal-free rule
display portal interface
display portal interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display portal interface command to display the portal configuration of an interface.
# Display the portal configuration of interface GigabitEthernet 2/1/1.
<Sysname> display portal interface GigabitEthernet2/1/1
 Interface portal configuration:
 GigabitEthernet2/1/1: Portal running
Portal server: newpt
 Authentication type: Layer3
 Authentication domain: my-domain
Authentication network:
 address : 1.1.1.1  mask : 255.255.255.255
 address : 3.3.3.0  mask : 255.255.255.0
Table 4 Output description
Portal configuration on the interface
Status of the portal authentication on the interface:
·       disabled—Portal authentication is disabled.
·       enabled—Portal authentication is enabled but is not functioning.
·       running—Portal authentication is functioning.
Portal server
Portal server referenced by the interface
Authentication type
Authentication mode enabled on the interface
Mandatory authentication domain of the interface
Information of the portal authentication source subnet and destination subnet
address
IP address of the portal authentication subnet
mask
Subnet mask of the IP address of the portal authentication subnet
display portal server
display portal server [ server-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
server-name: Name of a portal server, a case-sensitive string of 1 to 32 characters.
Use the display portal server command to display information about a specific portal server or all portal servers.
Related commands: portal server.
# Display information about portal server newpt.
<Sysname> display portal server newpt
 Portal server:
  1) newpt:
    IP   : 192.168.0.111
    VPN instance : vpn1
    Port         : 50100
    Key  : portal
    URL  : http://192.168.0.111
    Status  :Up
Table 5 Output description
1)
Number of the portal server.
newpt
Name of the portal server.
VPN instance
MPLS L3VPN to which the portal server belongs.
IP
IP address of the portal server.
Port
Listening port on the portal server.
Key
Shared key for exchanges between the router and portal server.
Not configured will be displayed if no key is configured.
URL
Address the packets are to be redirected to.
Not configured will be displayed if no address is configured.
Status
Current status of the portal server, which can be one of the following values:
·       N/A—The server is not referenced on any interface, or the server detection function is not enabled. The reachability of the portal server is unknown.
·       Up—The portal server is referenced on an interface and the portal server detection function is enabled, and currently the portal server is reachable.
·       Down—The portal server is referenced on an interface and the portal server detection function is enabled, but currently the portal server is unreachable.
display portal server statistics
display portal server statistics { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies an interface by its type and name.
Use the display portal server statistics command to display portal server statistics on a specific interface or all interfaces.
With the all keyword specified, the command displays portal server statistics by interface and therefore statistics about a portal server referenced by more than one interface may be displayed repeatedly.
# Display portal server statistics on GigabitEthernet 2/1/1.
<Sysname> display portal server statistics interface GigabitEthernet 2/1/1
 Server name:  newpt
 Invalid packets: 0
 Pkt-Name                          Total   Discard  Checkerr
REQ_CHALLENGE                       0        0        0
ACK_CHALLENGE                       0        0        0
REQ_AUTH                            0        0        0
ACK_AUTH                            0        0        0
REQ_LOGOUT                          0        0        0
ACK_LOGOUT                          0        0        0
AFF_ACK_AUTH                        0        0        0
NTF_LOGOUT                          0        0        0
REQ_INFO                            0        0        0
ACK_INFO                            0        0        0
NTF_USERDISCOVER                    0        0        0
NTF_USERIPCHANGE                    0        0        0
AFF_NTF_USERIPCHANGE                0        0        0
ACK_NTF_LOGOUT                      0        0        0
NTF_USERSYNC                        2        0        0
ACK_NTF_USERSYNC                    0        0        0
Table 6 Output description
Interface referencing the portal server
Server name
Invalid packets
Number of invalid packets
Pkt-Name
Packet type
Total
Total number of packets
Discard
Number of discarded packets
Checkerr
Number of erroneous packets
REQ_CHALLENGE
Challenge request message the portal server sends to the router
ACK_CHALLENGE
Challenge acknowledgment message the router sends to the portal server
REQ_AUTH
Authentication request message the portal server sends to the router
ACK_AUTH
Authentication acknowledgment message the router sends to the portal server
REQ_LOGOUT
Logout request message the portal server sends to the router
ACK_LOGOUT
Logout acknowledgment message the router sends to the portal server
AFF_ACK_AUTH
Affirmation message the portal server sends to the router after receiving an authentication acknowledgement message
NTF_LOGOUT
Forced logout notification message the router sends to the portal server
REQ_INFO
Information request message
ACK_INFO
Information acknowledgment message
NTF_USERDISCOVER
User discovery notification message the portal server sends to the router
NTF_USERIPCHANGE
User IP change notification message the router sends to the portal server
User IP change success notification message the portal server sends to the router
ACK_NTF_LOGOUT
Forced logout acknowledgment message from the portal server
NTF_USERSYNC
User synchronization packet the router received from the portal server
ACK_NTF_USERSYNC
User synchronization acknowledgment packet the router sent to the portal server
display portal tcp-cheat statistics
display portal tcp-cheat statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display portal tcp-cheat statistics command to display TCP spoofing statistics.
# Display TCP spoofing statistics.
<Sysname> display portal tcp-cheat statistics
 TCP Cheat Statistic:
 Total Opens: 0
 Reset Connections: 0
 Current Opens: 0
 Packets Received: 0
 Packets Sent: 0
 Packets Retransmitted: 0
 Packets Dropped: 0
 HTTP Packets Sent: 0
 Connection State:
          SYN_RECVD: 0
          ESTABLISHED: 0
          CLOSE_WAIT: 0
          LAST_ACK: 0
          FIN_WAIT_1: 0
          FIN_WAIT_2: 0
          CLOSING: 0
Table 7 Output description
TCP Cheat Statistic
Total Opens
Total number of opened connections
Resets Connections
Number of connections reset through RST packets
Current Opens
Number of connections currently being setting up
Packets Received
Number of received packets
Packets Sent
Number of sent packets
Number of retransmitted packets
Packets Dropped
Number of dropped packets
HTTP Packets Sent
Number of HTTP packets sent
Connection State
Statistics of connections in various state
SYN_RECVD:
Indicates that it has received the SYN packet from the peer
ESTABLISHED
Number of connections in ESTABLISHED state
CLOSE_WAIT
Number of connections in CLOSE_WAIT state
LAST_ACK
Number of connections in LAST-ACK state
FIN_WAIT_1
Number of connections in FIN_WAIT_1 state
FIN_WAIT_2
Number of connections in FIN_WAIT_2 state
CLOSING
Number of connections in CLOSING state
display portal user
display portal user { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display portal user command to display information about portal users on a specific interface or all interfaces.
# Display information about portal users on all interfaces.
<Sysname> display portal user all
Index:71
 State:ONLINE
 SubState:NONE
ACL:NONE
VPN instance:NONE
MAC                 IP                Vlan   Interface
 0000-0000-0000   2.2.2.2           0       GigabitEthernet3/1/1
Index:3
 State:ONLINE
 SubState: NONE
 ACL:3000
VPN instance: vpn1
 000d-88f8-0eac   2.2.2.3           0      GigabitEthernet3/1/1
 Total 2 user(s) matched, 2 listed.
Table 8 Output description
Index
Index of the portal user
Current status of the portal user
SubState
Current sub-status of the portal user
ACL
Authorization ACL of the portal user
VPN instance
MPLS L3VPN to which the portal user belongs
MAC
MAC address of the portal user
IP
IP address of the portal user
Vlan
VLAN to which the portal user belongs
Interface to which the portal user is attached
Total 1 user(s) matched, 1 listed
Total number of portal users
portal auth-network
portal auth-network network-address { mask-length | mask }
undo portal auth-network { network-address | all }
View
Interface view
Default level
2: System level
network-address: IP address of the authentication source subnet.
mask-length: Length of the subnet mask, in the range of 0 to 32.
mask: Subnet mask, in dotted decimal notation.
all: Specifies all authentication source subnets.
Use the portal auth-network command to configure a portal authentication source subnet on an interface. Then, only HTTP packets from the specified subnet can trigger portal authentication on the interface. If an unauthenticated user is not on any authentication source subnet, the access device discards all the user’s packets that do not match any portal-free rule.
Use the undo portal auth-network command to remove a specific portal authentication source subnet or all portal authentication subnets.
By default, the portal authentication source subnet is 0.0.0.0/0, meaning that users in all subnets must pass portal authentication.
This command is only applicable to cross-subnet authentication (layer3). The portal authentication source subnet for re-DHCP authentication (redhcp) is the one determined by the private IP address of the interface connecting the users.
You can configure multiple authentication source subnets by executing the portal auth-network command repeatedly. The router supports up to 4096 authentication source subnets.
If both an authentication source subnet and destination subnet are configured on an interface, only the authentication destination subnet takes effect.
# Configure a portal authentication source subnet of 10.10.10.0/24 on GigabitEthernet 3/1/1, so that only users from subnet 10.10.10.0/24 trigger portal authentication. Users from other subnets are denied access.
[Sysname] interface Gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] portal auth-network 10.10.10.0 24
portal delete-user
portal delete-user { ip-address | all | interface interface-type interface-number }
View
Default level
2: System level
ip-address: IP address of a user.
all: Logs out all users.
interface interface-type interface-number: Logs out all users on the specified interface.
Use the portal delete-user command to log out users.
Related commands: display portal user.
# Log out the user whose IP address is 1.1.1.1.
[Sysname] portal delete-user 1.1.1.1
portal domain
portal domain domain-name
undo portal domain
View
Interface view
Default level
2: System level
domain-name: ISP domain name, a case-insensitive string of 1 to 24 characters. The domain specified by this argument must already exist.
Use the portal domain command to specify an authentication domain for an interface. Then, the router will use the authentication domain for authentication, authorization and accounting (AAA) of the portal users on the interface.
Use the undo portal domain command to restore the default.
By default, no authentication domain is specified for an interface.
Related commands: display portal interface.
# Configure the authentication domain to be used for portal users on GigabitEthernet 3/1/1 as my-domain.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] portal domain my-domain
portal free-rule
portal free-rule rule-number { destination { any | ip { ip-address mask { mask-length | netmask } | any } } | source { any | [ interface interface-type interface-number | ip { ip-address mask { mask-length | netmask } | any } | vlan vlan-id ] * } } *
undo portal free-rule { rule-number | all }
View
Default level
2: System level
rule-number: Number for the portal-free rule. The value ranges from 0 to 63.
any: Imposes no limitation on the previous keyword.
ip ip-address: Specifies an IP address.
mask { mask-length | netmask }: Specifies the mask of the IP address, which can be in dotted decimal notation or an integer in the range of 0 to 32.
interface interface-type interface-number: Specifies a source interface for the portal free rule.
vlan vlan-id: Specifies a source VLAN ID. The value ranges from 1 to 4094.
all: Specifies all portal-free rules.
Use the portal free-rule command to configure a portal-free rule and specify the source filtering condition and/or destination filtering condition.
Use the undo portal free-rule command to remove a specific portal-free rule or all portal-free rules.
If you specify both a VLAN and an interface in a portal-free rule, the interface must belong to the VLAN. Otherwise, the rule does not take effect.
You cannot configure a portal-free rule to have the same filtering criteria as that of an existing one. Otherwise, the system prompts that the rule already exists.
No matter whether portal authentication is enabled on an interface, you can only add or remove a portal-free rule, rather than modifying it.
Related commands: display portal free-rule.
# Configure a portal-free rule, allowing any packet whose source IP address is 10.10.10.1/24 and source interface is GigabitEthernet 3/2/1 to bypass portal authentication.
[Sysname] portal free-rule 15 source ip 10.10.10.1 mask 24 interface Gigabitethernet 3/2/1 destination ip any
portal max-user
portal max-user max-number
undo portal max-user
View
Default level
2: System level
max-number: Maximum number of online portal users allowed in the system. Its value range depends on the system working mode:
·           In SPE mode, the value range is from 1 to 4096.
·           In SPC mode, the value range is from 1 to 7680.
·           In hybrid mode, if the ACL mode is 1 or 2, the value range is from 1 to 7680; if the ACL mode is 3 or 4, the value range is from 1 to 4096.
For information about the system working modes, see Fundamentals Configuration Guide.
Use the portal max-user command to set the maximum number of online portal users allowed in the system.
Use the undo portal max-user command to restore the default.
By default, the maximum number of online portal users depends on the system working mode:
·           SPE mode—4096
·           SPC mode—7680
·           Hybrid mode—7680 when the ACL mode is 1 or 2, and 4096 when the ACL mode is 3 or 4.
If the maximum number of portal users specified in the command is less than that of the current online portal users, the command can be executed successfully and will not impact the online portal users, but the system will not allow new portal users to log in until the number drops down below the limit.
# Set the maximum number of portal users allowed in the system to 100.
[Sysname] portal max-user 100
portal nas-id-profile
portal nas-id-profile profile-name
undo portal nas-id-profile
View
Interface view
Default level
2: System level
profile-name: Name of the profile that defines the binding relationship between VLANs and NAS IDs, a case-insensitive string of 1 to 16 characters. The profile can be configured by using the aaa nas-id profile command. For more information, see the chapter “AAA configuration.”
Use the portal nas-id-profile command to specify a NAS ID profile for an interface.
Use the undo portal nas-id-profile command to cancel the configuration.
By default, an interface is not specified with any NAS ID profile.
If an interface is specified with a NAS ID profile, the interface prefers to use the binding defined in the profile. If no NAS ID profile is specified for an interface or no matching binding is found in the specified profile, the device name will be used as the interface’s NAS ID.
# Specify NAS ID profile aaa for GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] portal nas-id-profile aaa
portal nas-ip
portal nas-ip ip-address
undo portal nas-ip
View
Interface view
Default level
2: System level
ip-address: Source IP address for portal packets. This IP address must be a local IP address, and cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
Use the portal nas-ip command to configure the source IP address for the interface to use for portal packets to be sent.
Use the undo portal nas-ip command to restore the default.
By default, no source IP address is specified, and the IP address of the user access interface is used as the source IP address of the portal packets.
# Configure the source IP address for portal packets to be sent on GigabitEthernet 3/1/1 as 2.2.2.2.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] portal nas-ip 2.2.2.2
portal nas-port-type
portal nas-port-type { ethernet | wireless }
undo portal nas-port-type
View
Interface view
Default level
2: System level
ethernet: Specifies the access port type as Ethernet, which corresponds to code 15.
wireless: Specifies the access port type as IEEE 802.11 standard wireless interface, which corresponds to code 19. This keyword is usually specified on an interface for wireless portal users, ensuring that the NAS-Port-Type value delivered by the router to the RADIUS server is wireless.
Use the portal nas-port-type command to specify the access port type (indicated by the NAS-Port-Type value) on the current interface. The specified NAS-Port-Type value will be carried in the RADIUS requests sent from the router to the RADIUS server.
Use the undo portal nas-port-type command to restore the default.
By default, the access port type of an interface is not specified, and the NAS-Port-Type value carried in RADIUS requests is the user access port type obtained by the router.
# Specify the NAS-Port-Type value of GigabitEthernet 3/1/1 as IEEE 802.11 standard wireless interface.
[Sysname-GigabitEthernet3/1/1] portal nas-port-type wireless
portal server
portal server server-name ip ip-address [ key key-string | port port-id | url url-string | vpn-instance vpn-instance-name ] *
undo portal server server-name [ key | port | url | vpn-instance ]
View
Default level
2: System level
server-name: Name of the portal server, a case-sensitive string of 1 to 32 characters.
ip-address: IP address of the portal server.
key-string: Shared key for communication with the portal server, a case-sensitive string of 1 to 16 characters. Portal packets exchanged between the access device and the portal server carry an authenticator, which is generated with the shared key. The receiver uses the authenticator to check the correctness of the received portal packets.
port-id: Destination port number used when the router sends a message to the portal server unsolicitedly, in the range of 1 to 65534. The default is 50100.
url-string: Uniform resource locator (URL) to which web packets are to be redirected. The default URL is in the format http://ip-address, where ip-address is the IP address of the portal server. You can also specify the domain name of the portal server, in which case you need to use the portal free-rule command to configure the IP address of the DNS server as a portal authentication-free destination IP address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the portal server belongs. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the portal server is on the public network, do not specify this option.
Use the portal server command to specify a portal server and the portal server parameters for Layer 3 portal authentication.
Use the undo portal server command to remove a portal server, restore the default destination port number or URL, or delete the shared key.
By default, no portal server is specified.
Note the following:
·           If the specified portal server exists and there is no user on the interfaces referencing the portal server, the undo portal server server-name command removes the specified portal server. With keyword port or url also provided, the command restores the destination port number or URL address to the default.
·           The configured portal server and its parameters can be removed or modified only when the portal server is not referenced by an interface. To remove or modify the settings of a portal server that has been referenced by an interface, you must first disable portal configuration on the interface by using the undo portal command.
Related commands: display portal server.
CAUTION
CAUTION:
·       If the portal feature is enabled on an interface, you cannot remove the portal server that the interface references. If there are users on this interface, you cannot modify the parameters of the portal server.
·       You must disable portal authentication on an interface before removing the portal server applied to the interface.
# Configure the portal server name as pts, specify the server’s IP address 192.168.0.111, shared key as portal, and the redirection URL as http://192.168.0.111/portal.
[Sysname] portal server pts ip 192.168.0.111 key portal url http://192.168.0.111/portal
portal server method
portal server server-name method { layer3 | redhcp }
undo portal
View
Interface view
Default level
2: System level
method: Specifies the authentication mode to be used.
·           layer3: Cross-subnet authentication.
·           redhcp: Re-DHCP authentication.
Use the portal server command to enable portal authentication on an interface, and specify the portal server to be referenced and the authentication mode.
Use the undo portal command to disable portal authentication on an interface.
By default, portal authentication is disabled on an interface.
The portal server to be referenced must exist.
# Enable portal authentication on interface GigabitEthernet 3/2/1, setting the portal server to pts and the authentication mode to layer3.
[Sysname] interface Gigabitethernet 3/2/1
[Sysname-GigabitEthernet3/2/1] portal server pts method layer3
portal server server-detect
portal server server-name server-detect method { http | portal-heartbeat } * action { log | permit-all | trap } * [ interval interval ] [ retry retries ]
undo portal server server-name server-detect
View
Default level
2: System level
server-name: Name of a portal server, a case-sensitive string of 1 to 32 characters. The specified portal server must have existed.
server-detect method { http | portal-heartbeat }: Specifies the portal server detection method. Two detection methods are available:
·           http: Probes the portal server by establishing HTTP connections. In this method, the access device periodically sends TCP connection requests to the HTTP service port of the portal servers enabled on its interfaces. If the TCP connection with a portal server can be established, the access device considers that the HTTP service of the portal server is open and the portal server is reachable, that is, the detection succeeds. If the TCP connection cannot be established, the access device considers that the detection fails, that is, the portal server is unreachable. If a portal server does not support the portal server heartbeat function, you can configure the access device to use the HTTP probe method to detect the reachability of the portal server.
·           portal-heartbeat: Probes the portal server by checking portal heartbeat packets. Portal servers periodically send portal heartbeat packets to the access devices. If the access device receives a portal heartbeat packet from a portal server within the specified interval, the access device considers that the probe succeeds and the portal server is reachable; otherwise, it considers that the probe fails and the portal server is unreachable. This method is effective to only portal servers that support the portal heartbeat function. Currently, only the portal server of iMC supports this function. To implement detection with this method, you also need to configure the portal server heartbeat function on the iMC portal server and make sure that the server heartbeat interval configured on the portal server is shorter than or equal to the probe interval configured on the access device.
action { log | permit-all | trap }: Specifies the actions to be taken when the status of a portal server changes. Three actions are available:
·           log: Specifies the action as sending a log message. When the status (reachable/unreachable) of a portal server changes, the access device sends a log message. The log message contains the portal server name and the current state and original state of the portal server.
·           permit-all: Specifies the action as disabling portal authentication, that is, enabling portal escape. When the access device detects that a portal server is unreachable, it disables portal authentication on the interface referencing the portal server, that is, it allows all portal users on this interface to access network resources. Then, if the access device receives the portal server heartbeat packets or authentication packets (such as login requests and logout requests), it re-enables the portal authentication function.
·           trap: Specifies the action as sending a trap message. When the status (reachable/unreachable) of a portal server changes, the access device sends a trap message to the network management server (NMS). Trap message contains the portal server name and the current state of the portal server.
interval interval: Interval at which probe attempts are made. The interval argument ranges from 20 to 600 and defaults to 20, in seconds.
retry retries: Maximum number of probe attempts. The retries argument ranges from 1 to 5 and defaults to 3. If the number of consecutive, failed probes reaches this value, the access device considers that the portal server is unreachable.
Use the portal server server-detect command to configure portal server detection, including the detection method, action, probe interval, and maximum number of probe attempts. With this function configured, the router (access device) checks the status of the specified server periodically and takes the specified actions when the server status changes.
Use the undo portal server server-detect command to cancel the detection of the specified portal server.
By default, the portal server detection function is not configured.
You can specify one or more detection methods and actions to be taken.
If both detection methods are specified, a portal server is considered unreachable as long as one detection method fails, and an unreachable portal server is considered recovered only when both detection methods succeed.
If multiple actions are specified, the system will execute all the specified actions when the status of a portal server changes.
Deleting a portal server on the router will disable the detection function for the portal server.
If you configure the detection function for a portal server for multiple times, the last configuration will take effect. If you do not specify an optional parameter, the default setting of the parameter will be used.
The portal server detection function takes effect only when the portal server is referenced and enabled on an interface.
Authentication-related packets from a portal server, such as logon requests and logoff requests, have the same effect as the portal heartbeat packets for the portal server detection function.
Related command: display portal server.
# Configure the router to detect portal server pts:
·           Specifying both the HTTP probe and portal heartbeat probe methods
·           Setting the probe interval to 600 seconds
·           Specifying the router to send a server unreachable trap message, send a log message and disable portal authentication to permit unauthenticated portal users, if two consecutive probes fail.
[Sysname] portal server pts server-detect method http portal-heartbeat action log permit-all trap interval 600 retry 2
portal server user-sync
portal server server-name user-sync [ interval interval ] [ retry retries ]
undo portal server server-name user-sync
View
Default level
2: System level
user-sync: Enables the portal user synchronization function.
interval interval: Interval at which the router checks for user synchronization packets. The interval argument ranges from 60 to 3600 and defaults to 300, in seconds.
retry retries: Specifies the maximum number of consecutive failed checks. The retries argument ranges from 1 to 5 and defaults to 4. If the router finds that one of its users does not exist in the user synchronization packets from the portal server within N consecutive probe intervals (N = retries), it considers that the user does not exist on the portal server and logs the user off.
Use the portal server user-sync command to configure portal user information synchronization with a specific portal server. With this function configured, the router periodically checks and responds to user synchronization packets received from the specified portal server, so as to keep its online user information consistent with that on the portal server.
Use the undo portal server user-sync command to cancel the portal user information synchronization configuration with the specified portal server.
By default, the portal user synchronization function is not configured.
The user information synchronization function requires that a portal server supports the portal user heartbeat function (currently only the portal server of iMC supports portal user heartbeat). To implement the portal user synchronization function, you also need to configure the user heartbeat function on the portal server and make sure that the user heartbeat interval configured on the portal server is shorter than or equal to the synchronization probe interval configured on the router.
Deleting a portal server on the router will delete the portal user synchronization configuration with the portal server.
If you configure the user synchronization function for a portal server for multiple times, the last configuration takes effect. If you do not specify an optional parameter, the default setting of the parameter will be used.
For redundant user information on the router, that is, information of the users considered as nonexistent on the portal server, the router will delete the information during the (N+1)th probe interval, where N equals to the value of retries configured in the portal server user-sync command.
# Configure the router to synchronize portal user information with portal server pts at an interval of 600 seconds and log off users whose information does not exist in the user synchronization packets received from the server in two consecutive probe intervals.
[Sysname] portal server pts user-sync interval 600 retry 2
reset portal connection statistics
reset portal connection statistics { all | interface interface-type interface-number }
View
Default level
1: Monitor level
Use the reset portal connection statistics command to clear portal connection statistics on a specific interface or all interfaces.
# Clear portal connection statistics on interface GigabitEthernet 3/2/1.
<Sysname> reset portal connection statistics interface GigabitEthernet3/2/1
reset portal server statistics
reset portal server statistics { all | interface interface-type interface-number }
View
Default level
1: Monitor level
Use the reset portal server statistics command to clear portal server statistics on a specific interface or all interfaces.
# Clear portal server statistics on interface GigabitEthernet 3/2/1.
<Sysname> reset portal server statistics interface GigabitEthernet3/2/1
reset portal tcp-cheat statistics
View
Default level
1: Monitor level
None
Use the reset portal tcp-cheat statistics command to clear TCP spoofing statistics.
# Clear TCP spoofing statistics.
<Sysname> reset portal tcp-cheat statistics
