13-Network Management and Monitoring Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command Reference-Release1728-6W17013-Network Management and Monitoring Command Reference
07-RMON Commands
07-RMON Commands 151.49 KB
RMON configuration commands
display rmon alarm
display rmon alarm [ entry-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
entry-number: Index of an RMON alarm entry, in the range of 1 to 65535. If no entry is specified, the configuration of all alarm entries is displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display rmon alarm command to display the configuration of the specified or all RMON alarm entries.
Related commands: rmon alarm.
# Display the configuration of all RMON alarm table entries.
<Sysname> display rmon alarm
AlarmEntry 1 owned by user1 is VALID.
  Samples type          : absolute
  Variable formula      : 1.3.6.1.2.1.16.1.1.1.4.1<etherStatsOctets.1>
  Sampling interval     : 10(sec)
  Rising threshold      : 50(linked with event 1)
  Falling threshold     : 5(linked with event 2)
  When startup enables  : risingOrFallingAlarm
  Latest value          : 0
Table 1 Output description
AlarmEntry entry-number owned by owner is status
The status of the alarm entry entry-number created by the owner is status:
·       entry-number—Alarm entry, corresponding to the management information base (MIB) node alarmIndex.
·       ownerOwner of the entry, corresponding to the MIB node alarmOwner.
·       status–Status of the entry identified by the index (VALID means the entry is valid, and UNDERCREATION means invalid. You can use the display rmon command to view the invalid entry, while with the display current-configuration and display this commands you cannot view the corresponding rmon commands.), corresponding to the MIB node alarmStatus.
Samples type
The sampling type (the value can be absolute or delta), corresponding to the MIB node alarmSampleType.
Variable formula
Alarm variable, namely, the monitored MIB node, corresponding to the MIB node alarmVariable.
Sampling interval
Sampling interval, in seconds, corresponding to the MIB node alarmInterval.
Rising threshold
Alarm rising threshold (When the sampling value is greater than or equal to this threshold, a rising alarm is triggered.), corresponding to the MIB node alarmRisingThreshold.
Falling threshold
Alarm falling threshold (When the sampling value is smaller than or equal to this threshold, a falling alarm is triggered.), corresponding to the MIB node alarmFallingThreshold.
How an alarm can be triggered, corresponding to the MIB node alarmStartupAlarm.
Latest value
The last sampled value, corresponding to the MIB node alarmValue.
display rmon event
display rmon event [ entry-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
entry-number: Index of an RMON event entry, in the range of 1 to 65535. If no entry is specified, the configuration of all event entries is displayed.
Use the display rmon event command to display the configuration of the specified or all RMON event entries.
Displayed information includes event index, event owner, event description, action triggered by the event (such as sending log or trap messages), and last time the event occurred (the elapsed time since system initialization/startup) in seconds.
Related commands: rmon event.
# Display the configuration of all RMON event entries.
<Sysname> display rmon event
EventEntry 1 owned by user1 is VALID.
  Description: null.
  Will cause log-trap when triggered, last triggered at 0days 00h:02m:27s.
Table 2 Output description
EventEntry
Event entry, corresponding to the MIB node eventIndex.
owned by
Event entry owner, corresponding to the MIB node eventOwner.
VALID
Status of the alarm entry for the event entry:
·       VALID—The entry is valid.
·       UNDERCREATION—The entry is invalid.
The display rmon command can display invalid entries, but the display current-configuration and display this commands do not display their related rmon commands.
The status value is stored in the MIB node eventStatus.
Event description, corresponding to the MIB node eventDescription.
The actions that the system will take when the event is triggered:
·       none—The system will take no action.
·       logThe system will log the event.
·       snmp-trap—The system will send a trap to the NMS.
·       log-and-trap—The system will log the event and send a trap to the NMS.
This field corresponds to the MIB node eventType.
last triggered at
Time when the last event was triggered, corresponding to the MIB node eventLastTimeSent.
display rmon eventlog
display rmon eventlog [ entry-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
entry-number: Index of an event entry, in the range of 1 to 65535.
Use the display rmon eventlog command to display log information for the specified or all event entries.
If entry-number is not specified, the log information for all event entries is displayed.
If you use the rmon event command to configure the system to log an event when the event is triggered, the event is recorded into the RMON log. You can use this command to display the details of the log table, which includes event index, current event state, time the event was logged (the elapsed time in seconds since system initialization/startup), and event description.
# Display RMON log information for event entry 1.
<Sysname> display rmon eventlog 1
LogEntry 1 owned by null is VALID.
  Generates eventLog 1.1 at 0day(s) 00h:00m:33s.
  Description: The alarm formula defined in prialarmEntry 1,
     uprise 80 with alarm value 85. Alarm sample type is absolute.
  Generates eventLog 1.2 at 0day(s) 00h:42m:03s.
  Description: The alarm formula defined in prialarmEntry 2,
     less than(or =) 5 with alarm value 0. Alarm sample type is delta.
Table 3 Output description
LogEntry
Event log entry, corresponding to the MIB node logIndex.
owned by
Owner of the entry, corresponding to the MIB node eventOwner.
VALID
Status of the alarm entry for the event log entry:
Generates eventLog at
Time when the log was created (time passed since the switch was booted), corresponding to the MIB node logTime.
Log description, corresponding to the MIB node logDescription.
The above example shows that event 1 has generated two logs:
·           eventLog 1.1, generated by private alarm entry 1, which is triggered because the alarm value (85) exceeds the rising threshold (80). The sampling type is absolute.
·           eventLog 1.2, generated by private alarm entry 2, which is triggered because the alarm value (0) is lower than the falling threshold (5). The sampling type is delta.
display rmon history
display rmon history [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display rmon history command to display RMON history control entry and history sampling information.
After you have created history control entry on an interface, the system calculates the information of the interface periodically and saves the information to the etherHistoryEntry table. You can use this command to display the entries in this table.
To configure the number of history sampling records that can be displayed and the history sampling interval, use the rmon history command.
Related commands: rmon history.
# Display RMON history control entry and history sampling information for interface GigabitEthernet 3/0/18.
<Sysname> display rmon history GigabitEthernet 3/0/18
HistoryControlEntry 1 owned by null is VALID
  Samples interface     : GigabitEthernet 3/0/18 <ifIndex.18>
  Sampling interval     : 10(sec) with 5 buckets max
  Sampled values of record 1 :
    dropevents        : 0         , octets               : 3166
    packets           : 43        , broadcast packets    : 3
    multicast packets : 6         , CRC alignment errors : 0
    undersize packets : 0         , oversize packets     : 0
    fragments         : 0         , jabbers              : 0
    collisions        : 0         , utilization          : 0
  Sampled values of record 2 :
    dropevents        : 0         , octets               : 834
    packets           : 8         , broadcast packets    : 1
  Sampled values of record 3 :
    dropevents        : 0         , octets               : 1001
    packets           : 9         , broadcast packets    : 1
    multicast packets : 7         , CRC alignment errors : 0
  Sampled values of record 4 :
    dropevents        : 0         , octets               : 766
    packets           : 7         , broadcast packets    : 0
Table 4 Output description
HistoryControlEntry
History control entry, corresponding to the MIB node etherHistoryIndex.
owned by
Owner of the entry, corresponding to the MIB node historyControlOwner.
VALID
Status of the entry identified by the index, which corresponds to MIB node historyControlStatus.
VALID means the entry is valid, and UNDERCREATION means invalid. You can use the display rmon command to view the invalid entry; while with the display current-configuration and display this commands you cannot view the corresponding rmon commands.
Samples Interface
The sampled interface.
Sampling interval
Sampling period, in seconds, which corresponds to MIB node historyControlInterval. The system periodically samples the information of an interface.
buckets max
The maximum number of history table entries that can be saved, corresponding to the MIB node historyControlBucketsGranted.
If the specified value of the buckets argument exceeds the history table size supported by the switch, the supported history table size is displayed.
If the current number of the entries in the table has reached the maximum number, the system will delete the earliest entry to save the latest one.
Sampled values of record number
The (number)th statistics recorded in the system cache. Statistics records are numbered according to the order of time they are saved into the cache.
dropevents
Dropped packets during the sampling period, corresponding to the MIB node etherHistoryDropEvents.
octets
Number of octets received during the sampling period, corresponding to the MIB node etherHistoryOctets.
packets
Number of packets received during the sampling period, corresponding to the MIB node etherHistoryPkts.
broadcastpackets
Number of broadcasts received during the sampling period, corresponding to the MIB node etherHistoryBroadcastPkts.
multicastpackets
Number of multicasts received during the sampling period, corresponding to the MIB node etherHistoryMulticastPkts.
Number of packets received with CRC alignment errors during the sampling period, corresponding to the MIB node etherHistoryCRCAlignErrors.
undersize packets
Number of undersize packets received during the sampling period, corresponding to the MIB node etherHistoryUndersizePkts.
oversize packets
Number of oversize packets received during the sampling period, corresponding to the MIB node etherHistoryOversizePkts.
fragments
Number of fragments received during the sampling period, corresponding to the MIB node etherHistoryFragments.
jabbers
Number of jabbers received during the sampling period (not supported currently, and the statistics is displayed as 0), corresponding to the MIB node etherHistoryJabbers.
collisions
Number of colliding packets received during the sampling period, corresponding to the MIB node etherHistoryCollisions.
utilization
Bandwidth utilization during the sampling period, corresponding to the MIB node etherHistoryUtilization.
display rmon prialarm
display rmon prialarm [ entry-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
entry-number: Private alarm entry index, in the range of 1 to 65535. If no entry is specified, the configuration of all private alarm entries is displayed.
Use the display rmon prialarm command to display the configuration of the specified or all private alarm entries.
Related commands: rmon prialarm.
# Display the configuration of all private alarm entries.
<Sysname> display rmon prialarm
PrialarmEntry 1 owned by user1 is VALID.
  Variable formula      : (.1.3.6.1.2.1.16.1.1.1.6.1*100/.1.3.6.1.2.1.16.1.1.1.5.1)
  Description           : ifUtilization.GigabitEthernet 3/0/18
  Rising threshold      : 80(linked with event 1)
  This entry will exist : forever
  Latest value          : 85
Table 5 Output description
PrialarmEntry
The entry of the private alarm table.
owned by
Owner of the entry, user1 in this example.
VALID
Status of the entry identified by the index.
Samples type
Sampling type, whose value can be absolute or delta.
Description of the private alarm entry.
Sampling interval
Sampling interval, in seconds. The system performs absolute sample or delta sample to sampling variables according to the sampling interval.
Rising threshold
Alarm rising threshold. An event is triggered when the sampled value is greater than or equal to this threshold.
Falling threshold
Alarm falling threshold. An event is triggered when the sampled value is less than or equal to this threshold.
linked with event
Event index associated with the prialarm.
How can an alarm be triggered.
The lifetime of the entry, which can be forever or span the specified period.
Latest value
The count result of the last sample.
display rmon statistics
display rmon statistics [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display rmon statistics command to display RMON statistics.
This command displays the interface statistics during the period from the time the statistics entry is created to the time the command is executed. The statistics are cleared when the switch reboots.
Related commands: rmon statistics.
# Display RMON statistics for interface GigabitEthernet 3/0/18.
<Sysname> display rmon statistics GigabitEthernet 3/0/18
EtherStatsEntry 1 owned by null is VALID.
  Interface : GigabitEthernet 3/0/18 <ifIndex.3>
  etherStatsOctets         : 43393306  , etherStatsPkts          : 619825
  etherStatsBroadcastPkts  : 503581    , etherStatsMulticastPkts : 44013
  etherStatsUndersizePkts  : 0         , etherStatsOversizePkts  : 0
  etherStatsFragments      : 0         , etherStatsJabbers       : 0
  etherStatsCRCAlignErrors : 0         , etherStatsCollisions    : 0
  etherStatsDropEvents (insufficient resources): 0
  Packets received according to length:
  64     : 0         ,  65-127  : 0         ,  128-255  : 0
  256-511: 0         ,  512-1023: 0         ,  1024-1518: 0
Table 6 Output description
EtherStatsEntry
The entry of the statistics table, which corresponds to MIB node etherStatsIndex.
VALID
Status of the entry identified by the index, which corresponds to MIB node etherStatsStatus.
Interface on which statistics are gathered, which corresponds to the MIB node etherStatsDataSource.
etherStatsOctets
Number of octets received by the interface during the statistical period, corresponding to the MIB node etherStatsOctets.
etherStatsPkts
Number of packets received by the interface during the statistical period, corresponding to the MIB node etherStatsPkts.
Number of broadcast packets received by the interface during the statistical period, corresponding to the MIB node etherStatsBroadcastPkts.
Number of multicast packets received by the interface during the statistical period, corresponding to the MIB node etherStatsMulticastPkts.
Number of undersize packets received by the interface during the statistical period, corresponding to the MIB node etherStatsUndersizePkts.
Number of oversize packets received by the interface during the statistical period, corresponding to the MIB node etherStatsOversizePkts.
etherStatsFragments
Number of undersize packets with CRC errors received by the interface during the statistical period, corresponding to the MIB node etherStatsFragments.
etherStatsJabbers
Number of oversize packets with CRC errors received by the interface during the statistical period (not supported currently, and the statistics are displayed as 0), corresponding to the MIB node etherStatsJabbers.
Number of packets with CRC errors received on the interface during the statistical period, corresponding to the MIB node etherStatsCRCAlignErrors.
Number of collisions received on the interface during the statistical period, corresponding to the MIB node etherStatsCollisions.
Total number of drop events received on the interface during the statistical period, corresponding to the MIB node etherStatsDropEvents.
Statistics of packets received according to length during the statistical period (Ethernet interface cards do not support this field and the statistics are displayed as 0).
rmon alarm
rmon alarm entry-number alarm-variable sampling-interval { absolute | delta } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 [ owner text ]
undo rmon alarm entry-number
View
Default level
2: System level
entry-number: Alarm entry index, which ranges from 1 to 65535.
alarm-variable: Alarm variable, a string of 1 to 256 characters. It can be in dotted object identifier (OID) format (in the format of entry.integer.instance or leaf node name.instance, for example, 1.3.6.1.2.1.2.1.10.1), or a node name like ifInOctets.1. Only variables that can be parsed into INTEGER (INTEGER, Counter, Gauge, or Time Ticks) in the ASN.1 can be used for the alarm-variable argument, such as the instance of the leaf node (like etherStatsOctets, etherStatsPkts, etherStatsBroadcastPkts, and so on) of the etherStatsEntry entry, the instance of the leaf node (like ifInOctets, ifInUcastPkts, ifInNUcastPkts, and so on) of the ifEntry entry.
sampling-interval: Sampling interval, in the range of 5 to 65,535 seconds.
absolute: Sets the sampling type to absolute. In other words, the system obtains the value of the variable when the sampling time is reached.
delta: Sets the sampling type to delta. In other words, the system obtains the variation value of the variable during the sampling interval when the sampling time is reached.
rising-threshold threshold-value1 event-entry1: Sets the rising threshold, where threshold-value1 represents the rising threshold, which ranges from –2,147,483,648 to +2,147,483,647, and event-entry1 represents the index of the event triggered when the rising threshold is reached. event-entry1 ranges from 0 to 65,535, where 0 means no corresponding event is triggered and no event action is taken when an alarm is triggered.
falling-threshold threshold-value2 event-entry2: Sets the falling threshold, where threshold-value2 represents the falling threshold, which ranges from –2,147,483,648 to +2,147,483,647 and event-entry2 represents the index of the event triggered when the falling threshold is reached. event-entry2 ranges from 1 to 65,535.
owner text: Owner of the entry, a case-sensitive string of 1 to 127 characters that can contain spaces.
Use the rmon alarm command to create an entry in the RMON alarm table.
Use the undo rmon alarm command to remove a specified entry from the RMON alarm table.
This command defines an alarm entry to trigger the specified event when abnormity occurs. The event defines how to deal with the abnormity. If you define an alarm entry, the system obtains the value of the monitored alarm variable at specified interval, and compares the sampled values with the predefined threshold. Then the system triggers the event specified by the event-entry1 argument when the rising threshold is reached, and triggers the event specified by the event-entry2 argument when the falling threshold is reached.
Before creating an alarm entry, define the events to be referenced in the event table with the rmon event command; otherwise, although the alarm entry can be created, no alarm event is triggered.
If the alarm variable is an instance of the leaf node of the Ethernet statistics table etherStatsEntry with the OID of 1.3.6.1.2.1.16.1.1.1, you must create a statistics entry on the monitored Ethernet interface with the rmon statistics command; if the alarm variable is an instance of the leaf node of the history record table etherHistoryEntry with the OID of 1.3.6.1.2.1.16.2.2.1, you must create a history entry on the monitored Ethernet interface with the rmon history command. Otherwise, although the alarm entry can be created, no alarm event is triggered.
An entry cannot be created if the values of the specified alarm variable (alarm-variable), sampling interval (sampling-interval), sampling type (absolute or delta), rising threshold (threshold-value1) and falling threshold (threshold-value2) are identical to those of the existing alarm entry in the system.
You can create up to 60 alarm entries.
Related commands: display rmon alarm, rmon event, rmon history, and rmon statistics.
# Add entry 1 in the alarm table and sample the node 1.3.6.1.2.1.16.1.1.1.4.1 at a sampling interval of 10 seconds in absolute sampling type. Trigger event 1 when the sampled value is greater than or equal to the rising threshold of 5000, and event 2 when the sampled value is less than or equal to the falling threshold of 5. Set the owner of the entry to be user1.
[Sysname] rmon event 1 log
[Sysname] rmon event 2 none
[Sysname] interface GigabitEthernet 3/0/18
[Sysname-GigabitEthernet3/0/18] rmon statistics 1
[Sysname-GigabitEthernet3/0/18] quit
[Sysname] rmon alarm 1 1.3.6.1.2.1.16.1.1.1.4.1 10 absolute rising-threshold 5000 1 falling-threshold 5 2 owner user1
1.3.6.1.2.1.16.1.1.1.4 is the OID of the leaf node etherStatsOctets. It represents the statistics of the received packets on the interface, in bytes. In the above example, you can use etherStatsOctets.1 to replace the parameter 1.3.6.1.2.1.16.1.1.1.4.1, where 1 indicates the serial number of the interface statistics entry. Therefore, if you execute the rmon statistics 5 command, you can use etherStatsOctets.5 to replace the parameter.
The above configuration implements the following:
·           Sampling and monitoring interface GigabitEthernet 3/0/18.
·           Obtaining the absolute value of the number of received packets every ten seconds. If the total bytes of the received packets reach 5,000, the system will log the event; if the total bytes of the received packets are no more than 5, the system will take no action.
rmon event
rmon event entry-number [ description string ] { log | log-trap log-trapcommunity | none | trap trap-community } [ owner text ]
undo rmon event entry-number
View
Default level
2: System level
entry-number: Event entry index, in the range of 1 to 65,535.
description string: Event description, a string of 1 to 127 characters.
log: Logs the event when it occurs.
log-trap log-trapcommunity: Log and trap events. The system performs both logging and trap sending when the event occurs. log-trapcommunity indicates the community name of the network management system that receives trap messages, a string of 1 to 127 characters.
none: Performs no action when the event occurs.
trap trap-community: Trap event. The system sends a trap with a community name when the event occurs. trap-community specifies the community name of the network management system that receives trap messages, a string of 1 to 127 characters.
Use the rmon event command to create an entry in the RMON event table.
Use the undo rmon event command to remove a specified entry from the RMON event table.
When create an event entry, you can define the actions that the system takes when the event is triggered by its associated alarm in the alarm table. The system can log the event, send a trap, do both, or do neither at all based on your configuration.
Related commands: display rmon event, rmon alarm, and rmon prialarm.
·       An entry cannot be created if the values of the specified event description (description string), event type (log, trap, logtrap or none), and community name (trap-community or log-trapcommunity) are identical to those of the existing event entry in the system.
·       Up to 60 event entries can be created.
# Create event 10 in the RMON event table.
[Sysname] rmon event 10 log owner user1
rmon history
rmon history entry-number buckets number interval sampling-interval [ owner text ]
undo rmon history entry-number
View
Ethernet interface view
Default level
2: System level
entry-number: History control entry index, in the range of 1 to 65535.
buckets number: History table size for the entry, in the range of 1 to 65,535.
interval sampling-interval: Sampling period, in the range of 5 to 3600 seconds.
Use the rmon history command to create an entry in the RMON history control table.
Use the undo rmon history command to remove a specified entry from the RMON history control table.
When an entry is created, the system periodically samples the number of packets received/sent on the current interface, and saves the statistics as an instance under the leaf node of the etherHistoryEntry table. The maximum number of statistics records can be saved for the entry is specified by buckets number. If the maximum number of the statistics records for the entry has been reached, the system deletes the earliest record to save the latest one. The statistics include total number of received packets on the current interface, total number of broadcast packets, total number of multicast packets in a sampling period, and so on.
After you create an entry in the history control table, if the specified history table size for the entry exceeds that supported by the switch, the entry is created. However, the validated value of the history table size for the entry is that supported by the switch. To view the configuration result, use the display rmon history command.
·       An entry cannot be created if the value of the specified sampling interval (interval sampling-interval) is identical to that of the existing history entry on the same interface.
·       Up to 100 history entries can be created.
Related commands: display rmon history.
# Create RMON history control entry 1 for interface GigabitEthernet 3/0/18.
[Sysname-GigabitEthernet3/0/18] rmon history 1 buckets 10 interval 5 owner user1
rmon prialarm
rmon prialarm entry-number prialarm-formula prialarm-des sampling-interval { absolute | changeratio | delta } rising-threshold threshold-value1 event-entry1 falling-threshold threshold-value2 event-entry2 entrytype { forever | cycle cycle-period } [ owner text ]
undo rmon prialarm entry-number
View
Default level
2: System level
entry-number: Index of a private alarm entry, in the range of 1 to 65535.
prialarm-formula: Private alarm variable formula, a string of 1 to 256 characters. The variables in the formula must be represented in OID format that starts with a point “.”, the formula (.1.3.6.1.2.1.2.1.10.1)*8 for example. You can customize the formula and perform the basic operations of addition, subtraction, multiplication, and division on these variables. The operations should yield a long integer. To prevent errors, make sure that the result of each calculating step falls into the value range for long integers.
prialarm-des: Private alarm entry description, which is a string of 1 to 127 characters.
sampling-interval: Sampling interval, which ranges from 10 to 65,535 seconds.
absolute | changeratio | delta: Sets the sampling type to absolute, delta, or change ratio. Absolute sampling is to obtain the value of the variable when the sampling time is reached. Delta sampling is to obtain the variation value of the variable during the sampling interval when the sampling time is reached. Change ratio sampling is not supported at present.
forever: Indicates that the lifetime of the private alarm entry is infinite.
cycle cycle-period: Sets the lifetime period of the private alarm entry, which ranges from 0 to 2,147,483,647 seconds.
Use the rmon prialarm command to create an entry in the private alarm table of RMON.
Use the undo rmon prialarm command to remove a private alarm entry from the private alarm table of RMON.
The system handles private alarm entries as follows:
1.       Samples the private alarm variables in the private alarm formula at the specified sampling interval.
2.       Performs calculation on the sampled values with the formula.
3.       Compares the calculation result with the predefined thresholds and does the following:
¡  If the result is equal to or greater than the rising threshold, triggers the event specified by the event-entry1 argument.
¡  If the result is equal to or smaller than the falling threshold, triggers the event specified by the event-entry2 argument.
·       Before creating an alarm entry, define the events to be referenced in the event table with the rmon event command.
·       An entry cannot be created if the values of the specified alarm variable formula (prialarm-formula), sampling type (absolute changeratio or delta), rising threshold (threshold-value1) and falling threshold (threshold-value2) are identical to those of the existing alarm entry in the system.
·       Up to 50 pri-alarm entries can be created.
Related commands: display rmon prialarm, rmon event, rmon history, and rmon statistics.
# Monitor the ratio of the broadcast packets received on the interface by using the private alarm.
Create entry 5 in the private alarm table. Calculate the private alarm variables with the (1.3.6.1.2.1.16.1.1.1.6.1*100/.1.3.6.1.2.1.16.1.1.1.5.1) formula and sample the corresponding variables at intervals of 10 seconds. Rising threshold of 80 corresponds to event 1 (and record the event into the log table); falling threshold of 5 corresponds to event 2 (but neither log it nor send a trap). Set the lifetime of the entry to forever and owner to user1. (Broadcast packet ratio= total number of broadcast packets received on the interface/total number of packets received on the interface; the formula is customized by users.)
[Sysname] rmon prialarm 1 (.1.3.6.1.2.1.16.1.1.1.6.1*100/.1.3.6.1.2.1.16.1.1.1.5.1) BroadcastPktsRatioOfGigabitEthernet3/0/18 10 absolute rising-threshold 80 1 falling-threshold 5 2 entrytype forever owner user1
1.3.6.1.2.1.16.1.1.1.6.1 is the OID of the node etherStatsBroadcastPkts.1, and 1.3.6.1.2.1.16.1.1.1.5.1 is the OID of the node etherStatsPkts.1. 1 indicates the serial number of the interface statistics entry. Therefore, if you execute the rmon statistics 5 command, you should use 1.3.6.1.2.1.16.1.1.1.6.5 and 1.3.6.1.2.1.16.1.1.1.5.5.
·           If the portion of broadcast packets received in the total packets is greater than or equal to 80%, the system will log the event; if the portion is less than or equal to 5%, the system takes no action.
To view the event log, use the display rmon eventlog command.
rmon statistics
rmon statistics entry-number [ owner text ]
undo rmon statistics entry-number
View
Default level
2: System level
entry-number: Index of statistics entry, in the range of 1 to 65535.
owner text: Owner of the entry, a string of case-sensitive 1 to 127 characters that can contain spaces.
Use the rmon statistics command to create an entry in the RMON statistics table.
Use the undo rmon statistics command to remove a specified entry from the RMON statistics table.
When an entry is created, the system continuously calculates the information of the interface. Statistics include number of collisions, CRC alignment errors, number of undersize or oversize packets, number of broadcasts, number of multicasts, number of bytes received, number of packets received. The statistics are cleared after the switch reboots.
To display information for the RMON statistics table, use the display rmon statistics command.
·       Only one statistics entry can be created on one interface.
·       Up to 100 statistics entries can be created.
# Create an entry with an index 20 and the owner user1 in the RMON statistics table for interface GigabitEthernet 3/0/18.
[Sysname-GigabitEthernet3/0/18] rmon statistics 20 owner user1
  • Become a Partner
  • Partner Resources
