11-Security Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command Reference-Release1728-6W17011-Security Command Reference
04-Portal Commands
04-Portal Commands 177.78 KB
display portal acl
display portal acl { all | dynamic | static } interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all portal access control lists (ACLs), including dynamic and static portal ACLs.
dynamic: Displays dynamic portal ACLs—ACLs generated dynamically after a user passes portal authentication.
static: Displays static portal ACLs—ACLs generated through portal related configuration, such as portal-free rule configuration.
interface interface-type interface-number: Displays the ACLs on the specified interface.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display portal acl command to display the ACLs on a specific interface.
# Display all ACLs on interface VLAN-interface 4.
<Sysname> display portal acl all interface Vlan-interface 4
Vlan-interface4 portal ACL rule:
 Rule 0
 Inbound interface = all
 Type              = static
 Action            = permit
 Source:
    IP        = 0.0.0.0
    Mask      = 0.0.0.0
    MAC       = 0000-0000-0000
    Interface = any
    VLAN      = 4
    Protocol  = 0
 Destination:
    IP        = 192.168.111.1
    Mask      = 255.255.255.255
 Rule 1
 Type              = dynamic
 Action            = permit
 Source:
    IP        = 14.14.2.250
    Interface = any
    VLAN      = 4
    Protocol  = 0
 Destination:
    IP        = 0.0.0.0
    Mask      = 0.0.0.0
 Author ACL:
    Number    = NONE
 Rule 2
 Type              = static
 Action            = redirect
 Source:
    IP        = 0.0.0.0
    Mask      = 0.0.0.0
    Interface = any
    VLAN      = 4
    Protocol  = 6
 Destination:
    IP        = 0.0.0.0
    Mask      = 0.0.0.0
 Rule 3
 Type              = static
 Action            = deny
 Source:
    IP        = 0.0.0.0
    Mask      = 0.0.0.0
    Interface = any
    VLAN      = 4
    Protocol  = 0
 Destination:
    IP        = 0.0.0.0
Mask      = 0.0.0.0
Table 1 Output description
Rule
Sequence number of the portal ACL, which is numbered from 0 in ascending order.
Inbound interface
Interface to which the portal ACL is bound.
Type of the portal ACL.
Action
Match action in the portal ACL.
Source
Source information in the portal ACL.
IP
Source IP address in the portal ACL.
Mask
Subnet mask of the source IP address in the portal ACL.
MAC
Source MAC address in the portal ACL.
Source interface in the portal ACL.
VLAN
Source VLAN in the portal ACL.
Protocol
Protocol type in the portal ACL.
Destination
Destination information in the portal ACL.
IP
Destination IP address in the portal ACL.
Mask
Subnet mask of the destination IP address in the portal ACL.
Author ACL
Authorization ACL information. It is displayed only when the value of the Type field is dynamic.
Number
Authorization ACL number assigned by the RADIUS server. None indicates that the server did not assign any ACL.
display portal connection statistics
display portal connection statistics { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Specifies all interfaces.
Use the display portal connection statistics command to display portal connection statistics on a specific interface or all interfaces.
# Display portal connection statistics on interface VLAN-interface 100.
<Sysname> display portal connection statistics interface Vlan-interface 100
 ---------------Interface: Vlan-interface100-----------------------
 User state statistics:
 State-Name                User-Num
 VOID                       0
 DISCOVERED                0
 WAIT_AUTHEN_ACK          0
 WAIT_AUTHOR_ACK          0
 WAIT_LOGIN_ACK           0
 WAIT_ACL_ACK              0
 WAIT_NEW_IP               0
 WAIT_USERIPCHANGE_ACK   0
 ONLINE                     1
 WAIT_LOGOUT_ACK          0
 WAIT_LEAVING_ACK         0
 Message statistics:
 Msg-Name                  Total         Err           Discard
 MSG_AUTHEN_ACK           3              0             0
 MSG_AUTHOR_ACK           3              0             0
 MSG_LOGIN_ACK            3              0             0
 MSG_LOGOUT_ACK           2              0             0
 MSG_LEAVING_ACK          0              0             0
 MSG_CUT_REQ               0              0             0
 MSG_AUTH_REQ              3              0             0
 MSG_LOGIN_REQ             3              0             0
 MSG_LOGOUT_REQ            2              0             0
 MSG_LEAVING_REQ           0              0             0
 MSG_ARPPKT                 0              0             0
 MSG_PORT_REMOVE           0              0             0
 MSG_VLAN_REMOVE           0              0             0
 MSG_IF_REMOVE             6              0             0
 MSG_L3IF_SHUT             0              0             0
 MSG_IF_DISPORTAL          0             0             0
 MSG_IF_UP                  0             0             0
 MSG_ACL_RESULT            0             0             0
 MSG_AAACUTBKREQ           0             0             0
 MSG_CUT_BY_USERINDEX      0             0             0
 MSG_CUT_L3IF               0             0             0
 MSG_IP_REMOVE             0              0             0
 MSG_ALL_REMOVE            1              0             0
 MSG_IFIPADDR_CHANGE      0              0             0
 MSG_SOCKET_CHANGE        8              0             0
 MSG_NOTIFY                 0             0             0
 MSG_SETPOLICY             0             0             0
 MSG_SETPOLICY_RESULT     0             0             0
Table 2 Output description
Statistics on portal users
State-Name
Name of a user state
User-Num
Number of users in a specific state
Message statistics
Statistics on messages
Msg-Name
Message type
Total
Total number of messages of a specific type
Err
Number of erroneous messages of a specific type
Discard
Number of discarded messages of a specific type
MSG_AUTHEN_ACK
Authentication acknowledgment message
MSG_AUTHOR_ACK
Authorization acknowledgment message
MSG_LOGIN_ACK
Accounting acknowledgment message
MSG_LOGOUT_ACK
Accounting-stop acknowledgment message
MSG_LEAVING_ACK
Leaving acknowledgment message
MSG_CUT_REQ
Cut request message
MSG_AUTH_REQ
Authentication request message
MSG_LOGIN_REQ
Accounting request message
MSG_LOGOUT_REQ
Accounting-stop request message
MSG_LEAVING_REQ
Leaving request message
MSG_ARPPKT
ARP message
MSG_PORT_REMOVE
Users-of-a-Layer-2-port-removed message
MSG_VLAN_REMOVE
VLAN user removed message
MSG_IF_REMOVE
Users-removed message, indicating the users on a Layer 3 interface were removed because the Layer 3 interface was removed
MSG_IF_SHUT
Layer 3 interface shutdown message
MSG_IF_DISPORTAL
Portal-disabled-on-interface message
MSG_IF_UP
Layer 3 interface came up message
MSG_ACL_RESULT
ACL deployment failure message
MSG_AAACUTBKREQ
Message that AAA uses to notify portal to delete backup user information
Force-user-offline message
MSG_CUT_L3IF
Users-removed message, indicating the users on a Layer 3 interface were removed because they were logged out
MSG_IP_REMOVE
User-with-an-IP-removed message
MSG_ALL_REMOVE
All-users-removed message
MSG_IFIPADDR_CHANGE
Interface IP address change message
MSG_SOCKET_CHANGE
Socket change message
MSG_NOTIFY
Notification message
MSG_SETPOLICY
Set policy message for assigning security ACL
Set policy response message
display portal free-rule
display portal free-rule [ rule-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
rule-number: Number of a portal-free rule, in the range of 0 to 63.
Use the display portal free-rule command to display information about a specific portal-free rule or all portal-free rules.
Related commands: portal free-rule.
# Display information about portal-free rule 1.
<Sysname> display portal free-rule 1
 Rule-Number  1:
 Source:
   IP        : 2.2.2.0
   Mask      : 255.255.255.0
   MAC       : 0000-0000-0000
   Interface : any
   Vlan      : 0
 Destination:
   IP        : 0.0.0.0
   Mask      : 0.0.0.0
Table 3 Output description
Rule-Number
Number of the portal-free rule
Source
Source information in the portal-free rule
IP
Source IP address in the portal-free rule
Mask
Subnet mask of the source IP address in the portal-free rule
MAC
Source MAC address in the portal-free rule
Source interface in the portal-free rule
Vlan
Source VLAN in the portal-free rule
Destination
Destination information in the portal-free rule
IP
Destination IP address in the portal-free rule
Mask
Subnet mask of the destination IP address in the portal-free rule
display portal interface
display portal interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display portal interface command to display the portal configuration of an interface.
# Display the portal configuration of interface VLAN-interface 100.
<Sysname> display portal interface Vlan-interface 100
 Interface portal configuration:
 Vlan-interface100: Portal running
 Portal server: servername
 Authentication type: : Layer3
 Authentication domain: my-domain
 Authentication network:
 address = 1.1.1.1  mask : 255.255.0.0
Table 4 Output description
Portal configuration on the interface.
Vlan-interface100
Status of the portal authentication on the interface:
·       disabled—Portal authentication is disabled.
·       enabled—Portal authentication is enabled but is not functioning.
·       running—Portal authentication is functioning.
Portal server
Portal server referenced by the interface.
Authentication type
Authentication mode enabled on the interface.
Mandatory authentication domain of the interface.
Information of the portal authentication subnet.
address
IP address of the portal authentication subnet.
mask
Subnet mask of the IP address of the portal authentication subnet.
display portal server
display portal server [ server-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
server-name: Name of a portal server, a case-sensitive string of 1 to 32 characters.
Use the display portal server command to display information about a specific portal server or all portal servers.
Related commands: portal server.
# Display information about portal server aaa.
<Sysname> display portal server aaa
 Portal server:
  1)aaa:
    IP             : 192.168.0.111
    VPN instance : vpn1
    Port           : 50100
    Key            : portal
    URL            : http://192.168.0.111
    Status        : Up
Table 5 Output description
1)
Number of the portal server.
aaa
Name of the portal server.
VPN instance
MPLS L3VPN to which the portal server belongs.
IP
IP address of the portal server.
Port
Listening port on the portal server.
Key
Shared key for exchanges between the access device and portal server.
Not configured will be displayed if no key is configured.
URL
Address the packets are to be redirected to.
Not configured will be displayed if no address is configured.
Status
Current status of the portal server. Possible values include:
·       N/A—The server is not referenced on any interface, or the server detection function is not enabled. The reachability of the portal server is unknown.
·       Up—The portal server is referenced on an interface and the portal server detection function is enabled, and the portal server is reachable.
·       Down—The portal server is referenced on an interface and the portal server detection function is enabled, but the portal server is unreachable.
display portal server statistics
display portal server statistics { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies an interface by its type and name.
Use the display portal server statistics command to display portal server statistics on a specific interface or all interfaces.
With the all keyword specified, the command displays portal server statistics by interface and therefore statistics about a portal server referenced by more than one interface may be displayed repeatedly.
# Display portal server statistics on VLAN-interface 100.
<Sysname> display portal server statistics interface Vlan-interface 100
 Server name:  st
 Invalid packets: 0
 Pkt-Name                          Total   Discard  Checkerr
 REQ_CHALLENGE                       3        0        0
 ACK_CHALLENGE                       3        0        0
 REQ_AUTH                             3        0        0
 ACK_AUTH                             3        0        0
 REQ_LOGOUT                           1        0        0
 ACK_LOGOUT                           1        0        0
 AFF_ACK_AUTH                         3        0        0
 NTF_LOGOUT                           1        0        0
 REQ_INFO                              6        0        0
 ACK_INFO                              6        0        0
 NTF_USERDISCOVER                    0        0        0
 NTF_USERIPCHANGE                    0        0        0
 AFF_NTF_USERIPCHANGE               0         0        0
 ACK_NTF_LOGOUT                      1         0        0
 NTF_USERSYNC                        2         0        0
 ACK_NTF_USERSYNC                    0         0        0
 NTF_CHALLENGE                       0         0        0
 NTF_USER_NOTIFY                     0         0        0
 AFF_NTF_USER_NOTIFY                0         0        0
Table 6 Output description
Interface referencing the portal server
Server name
Invalid packets
Number of invalid packets
Pkt-Name
Packet type
Total
Total number of packets
Discard
Number of discarded packets
Checkerr
Number of erroneous packets
REQ_CHALLENGE
Challenge request message the portal server sends to the access device
ACK_CHALLENGE
Challenge acknowledgment message the access device sends to the portal server
REQ_AUTH
Authentication request message the portal server sends to the access device
ACK_AUTH
Authentication acknowledgment message the access device sends to the portal server
REQ_LOGOUT
Logout request message the portal server sends to the access device
ACK_LOGOUT
Logout acknowledgment message the access device sends to the portal server
AFF_ACK_AUTH
Affirmation message the portal server sends to the access device after receiving an authentication acknowledgement message
NTF_LOGOUT
Forced logout notification message the access device sends to the portal server
REQ_INFO
Information request message
ACK_INFO
Information acknowledgment message
NTF_USERDISCOVER
User discovery notification message the portal server sends to the access device
NTF_USERIPCHANGE
User IP change notification message the access device sends to the portal server
User IP change success notification message the portal server sends to the access device
ACK_NTF_LOGOUT
Forced logout acknowledgment message from the portal server
NTF_USERSYNC
User synchronization packet the access device received from the portal server
ACK_NTF_USERSYNC
User synchronization acknowledgment packet the access device sent to the portal server
NTF_CHALLENGE
Challenge request the access device sent to the portal server
NTF_USER_NOTIFY
User information notification message the access device sent to the portal server
AFF_NTF_USER_NOTIFY
NTF_USER_NOTIFY acknowledgment message the access device sent to the portal server
display portal tcp-cheat statistics
display portal tcp-cheat statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display portal tcp-cheat statistics command to display TCP spoofing statistics.
# Display TCP spoofing statistics.
<Sysname> display portal tcp-cheat statistics
 TCP Cheat Statistic:
 Total Opens: 0
 Resets Connections: 0
 Current Opens: 0
 Packets Received: 0
 Packets Sent: 0
 Packets Retransmitted: 0
 Packets Dropped: 0
 HTTP Packets Sent: 0
 Connection State:
          SYN_RECVD: 0
          ESTABLISHED: 0
          CLOSE_WAIT: 0
          LAST_ACK: 0
          FIN_WAIT_1: 0
          FIN_WAIT_2: 0
          CLOSING: 0
Table 7 Output description
TCP Cheat Statistic
Total Opens
Total number of opened connections
Resets Connections
Number of connections reset through RST packets
Current Opens
Number of connections being set up
Packets Received
Number of received packets
Packets Sent
Number of sent packets
Number of retransmitted packets
Packets Dropped
Number of dropped packets
HTTP Packets Sent
Number of HTTP packets sent
Connection State
Statistics of connections in various states
ESTABLISHED
Number of connections in ESTABLISHED state
CLOSE_WAIT
Number of connections in CLOSE_WAIT state
LAST_ACK
Number of connections in LAST-ACK state
FIN_WAIT_1
Number of connections in FIN_WAIT_1 state
FIN_WAIT_2
Number of connections in FIN_WAIT_2 state
CLOSING
Number of connections in CLOSING state
display portal user
display portal user { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display portal user command to display information about portal users on a specific interface or all interfaces.
# Display information about portal users on all interfaces.
<Sysname> display portal user all
 Index:3
 State:WAIT_LOGOUT_ACK
 SubState:NONE
 ACL:NONE
 Work-mode:stand-alone
 VPN instance:NONE
 MAC                IP                 Vlan   Interface
 0000-0000-0000   33.2.0.2          3002   Vlan-interface3002
 Total 1 user(s) matched, 1 listed.
Table 8 Output description
Index
Index of the portal user.
Current status of the portal user.
SubState
Current sub-status of the portal user.
ACL
Authorization ACL of the portal user.
Work-mode
User’s working mode:
·       Primary
·       Secondary
·       Stand-alone
VPN instance
MAC
MAC address of the portal user. The switch does not display the real MAC address of the portal user but display 0000-0000-0000 instead.
IP
IP address of the portal user.
Vlan
VLAN to which the portal user belongs.
Interface to which the portal user is attached.
Total number of portal users.
portal auth-network
portal auth-network network-address { mask-length | mask }
undo portal auth-network { network-address | all }
View
Interface view
Default level
2: System level
network-address: IP address of the authentication subnet.
mask-length: Length of the subnet mask, in the range of 0 to 32.
mask: Subnet mask, in dotted decimal notation.
all: Specifies all authentication subnets.
Use the portal auth-network command to configure a portal authentication subnet on an interface. You can use this command to configure multiple portal authentication subnets on an interface. Then, only HTTP packets from the subnets can trigger portal authentication on the interface. If an unauthenticated user is not on any authentication subnet, the access device discards all the user’s packets that do not match any portal-free rule.
Use the undo portal auth-network command to remove a specific portal authentication subnet or all portal authentication subnets.
By default, the portal authentication subnet is 0.0.0.0/0, meaning that users in all subnets must pass portal authentication.
This command is only applicable for cross-subnet authentication (layer3). The portal authentication subnet for re-DHCP authentication (redhcp) is the one determined by the private IP address of the interface connecting the users.
You can configure multiple authentication subnets by executing the portal auth-network command repeatedly.
# Configure a portal authentication source subnet of 10.10.10.0/24 on interface VLAN-interface 2 to allow users from subnet 10.10.10.0/24 to trigger portal authentication.
[Sysname–Vlan-interface2] portal auth-network 10.10.10.0 24
portal delete-user
portal delete-user { ip-address | all | interface interface-type interface-number }
View
Default level
2: System level
ip-address: Logs off the user with the specified IP address.
all: Logs off all users.
interface interface-type interface-number: Logs off all users on the specified interface.
Use the portal delete-user command to log off users.
Related commands: display portal user.
# Log out the user whose IP address is 1.1.1.1.
[Sysname] portal delete-user 1.1.1.1
portal domain
portal domain domain-name
undo portal domain
View
Interface view
Default level
2: System level
domain-name: ISP domain name, a case-insensitive string of 1 to 24 characters. The domain specified by this argument must already exist.
Use the portal domain command to specify an authentication domain for an interface. Then, the switch will use the authentication domain for authentication, authorization and accounting (AAA) of the portal users on the interface.
Use the undo portal domain command to restore the default.
By default, no authentication domain is specified for an interface.
Related commands: display portal interface.
# Configure the authentication domain to be used for portal users on VLAN-interface 100 as my-domain.
[Sysname–Vlan-interface100] portal domain my-domain
portal free-rule
portal free-rule rule-number { destination { any | ip { ip-address mask { mask-length | mask } | any } } | source { any | [ interface interface-type interface-number | ip { ip-address mask { mask-length | mask } | any } | vlan vlan-id ] * } } *
undo portal free-rule { rule-number | all }
View
Default level
2: System level
rule-number: Number for the portal-free rule, in the range of 0 to 63.
any: Imposes no limitation on the previous keyword.
ip ip-address: Specifies an IP address.
mask { mask-length | mask }: Specifies a mask or mask length for the IP address. mask is a subnet mask in dotted decimal notation. mask-length is a subnet mask length, an integer in the range of 0 to 32.
interface interface-type interface-number: Specifies a source interface.
vlan vlan-id: Specifies a source VLAN ID.
all: Specifies all portal-free rules.
Use the portal free-rule command to configure a portal-free rule and specify the source filtering condition, destination filtering condition, or both.
Use the undo portal free-rule command to remove a specific portal-free rule or all portal-free rules.
If you specify both a VLAN and an interface in a portal-free rule, the interface must belong to the VLAN. Otherwise, the rule does not take effect.
You cannot configure a portal-free rule to have the same filtering criteria as that of an existing one. When attempted, the system prompts that the rule already exists.
No matter whether portal authentication is enabled on an interface, you can only add or remove a portal-free rule, rather than modifying it.
A Layer 2 interface in an aggregation group cannot be specified as the source interface of a portal-free rule, and the source interface of a portal-free rule cannot be added to an aggregation group.
Related commands: display portal free-rule.
# Configure a portal-free rule, allowing any packet whose source IP address is 10.10.10.1/24 to bypass portal authentication.
[Sysname] portal free-rule 15 source ip 10.10.10.1 mask 24 destination ip any
portal max-user
portal max-user max-number
undo portal max-user
View
Default level
2: System level
max-number: Maximum number of online portal users allowed in the system, in the range of 1 to 8192.
Use the portal max-user command to set the maximum number of online portal users allowed in the system.
Use the undo portal max-user command to restore the default.
By default, the maximum number of portal users allowed is 8192.
If the maximum number of portal users specified in the command is less than that of the current online portal users, the command can be executed successfully and will not impact the online portal users, but the system will not allow new portal users to log in until the number drops down below the limit.
# Set the maximum number of portal users allowed in the system to 100.
[Sysname] portal max-user 100
portal nas-id-profile
portal nas-id-profile profile-name
undo portal nas-id-profile
View
Interface view
Default level
2: System level
profile-name: Name of the profile that defines the binding relationship between VLANs and NAS IDs, a case-insensitive string of 1 to 16 characters. The profile can be configured by using the aaa nas-id profile command. For more information about this command, see the chapter “AAA configuration commands.”
Use the portal nas-id-profile command to specify a NAS ID profile for the interface.
Use the undo portal nas-id-profile command to cancel the configuration.
By default, an interface is not specified with any NAS ID profile.
If an interface is specified with a NAS ID profile, the interface will prefer to use the binding defined in the profile. If no NAS ID profile is specified for an interface or no matching binding is found in the specified profile, the switch name will be used as the interface NAS-ID.
# Specify NAS ID profile aaa for VLAN-interface 2.
[Sysname-Vlan-interface2] portal nas-id-profile aaa
portal nas-ip
portal nas-ip ip-address
undo portal nas-ip
View
Interface view
Default level
2: System level
ip-address: Source IP address to be specified for portal packets. This IP address must be a local IP address, and cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
Use the portal nas-ip command to configure the source IP address for the interface to use for portal packets to be sent.
Use the undo portal nas-ip command to restore the default.
By default, no source IP address is specified, and the IP address of the user access interface is used as the source IP address of the portal packets.
# Configure the source IP address for portal packets to be sent on VLAN-interface 5 as 2.2.2.2.
[Sysname] interface vlan-interface 5
[Sysname-Vlan-interface5] portal nas-ip 2.2.2.2
portal nas-port-type
portal nas-port-type { ethernet | wireless }
undo portal nas-port-type
View
Interface view
Default level
2: System level
ethernet: Specifies the access port type as Ethernet, which corresponds to code 15.
wireless: Specifies the access port type as IEEE 802.11 standard wireless interface, which corresponds to code 19. This keyword is usually specified on an interface for wireless portal users, making sure that the NAS-Port-Type value delivered by the access device to the RADIUS server is wireless.
Use the portal nas-port-type command to specify the access port type (indicated by the NAS-Port-Type value) on the current interface. The specified NAS-Port-Type value will be carried in the RADIUS requests sent from the switch to the RADIUS server.
Use the undo portal nas-port-type command to restore the default.
By default, the access port type of an interface is not specified, and the NAS-Port-Type value carried in RADIUS requests is the user access port type obtained by the access device.
# Specify the NAS-Port-Type value of VLAN-interface 2 as IEEE 802.11 standard wireless interface.
[Sysname-Vlan-interface2] portal nas-port-type wireless
portal redirect-url
portal redirect-url url-string [ wait-time period ]
undo portal redirect-url
View
Default level
2: System level
url-string: Automatic redirection URL for authenticated portal users, a string of 1 to 127 characters. It must start with http:// or https:// and must be a fully qualified URL.
wait-time period: Time that the device must wait before redirecting a user passing portal authentication to the automatic redirection URL. It ranges from 1 to 90 and defaults to 5, in seconds. The switch does not support the wait-time period option.
Use the portal redirect-url command to specify an automatic redirection URL for authenticated portal users.
Use the undo portal redirect-url command to restore the default.
By default, a user authenticated is redirected to the URL the user entered in the address bar before portal authentication.
With Layer 3 portal authentication, this feature requires the cooperation of an iMC server that supports the page auto-redirection function.
# Configure the switch to redirect a portal user to http://www.testpt.cn after the user passes portal authentication.
[Sysname] portal redirect-url http://www.testpt.cn
portal server
portal server server-name ip ip-address [ key key-string | port port-id | url url-string | vpn-instance vpn-instance-name ] *
undo portal server server-name [ key | port | url | vpn-instance ]
View
Default level
2: System level
server-name: Name of the portal server, a case-sensitive string of 1 to 32 characters.
ip-address: IP address of the portal server.
key-string: Shared key for communication with the portal server, a case-sensitive string of 1 to 16 characters. Portal packets exchanged between the access device (the switch) and the portal server carry an authenticator, which is generated with the shared key. The receiver uses the authenticator to check the correctness of the received portal packets.
port-id: Destination port number used when the switch sends an unsolicited message to the portal server, in the range of 1 to 65534. The default is 50100.
url-string: Uniform resource locator (URL) to which HTTP packets are to be redirected. The default URL is in the http://ip-address format, where ip-address is the IP address of the portal server. You can also specify the domain name of the portal server, in which case you need to use the portal free-rule command to configure the IP address of the DNS server as a portal authentication-free destination IP address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the portal server belongs. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the portal server is on the public network, do not specify this option.
Use the portal server command to configure a portal server for Layer 3 portal authentication.
Use the undo portal server command to remove a portal server, restore the default destination port and default URL address, or delete the shared key or the VPN instance configuration.
By default, no portal server is configured for Layer 3 portal authentication.
If the specified portal server exists and no user is on the interfaces referencing the portal server, using the undo portal server server-name command removes the specified portal server, and if keyword port or url is also provided, the command will restore the destination port number or URL address to the default.
The configured portal server and its parameters can be removed or modified only when the portal server is not referenced by an interface. To remove or modify the settings of a portal server that has been referenced by an interface, you must first remove the portal configuration on the interface by using the undo portal command.
Related commands: display portal server.
# Configure portal server pts, setting the IP address to 192.168.0.111, the key to portal, and the redirection URL to http://192.168.0.111/portal.
[Sysname] portal server pts ip 192.168.0.111 key portal url http://192.168.0.111/portal
portal server method
portal server server-name method { layer3 | redhcp }
undo portal
View
Interface view
Default level
2: System level
method: Specifies the authentication mode to be used.
layer3: Cross-subnet authentication.
redhcp: Re-DHCP authentication.
Use the portal server method command to enable Layer 3 portal authentication on an interface, and specify the portal server and the authentication mode to be used.
Use the undo portal command to disable Layer 3 portal authentication on an interface.
By default, Layer 3 portal authentication is disabled on an interface.
The specified portal server must exist.
# Enable Layer 3 portal authentication on interface VLAN-interface 100, referencing portal server pts and setting the authentication mode to layer3.
[Sysname–Vlan-interface100] portal server pts method layer3
portal server server-detect
portal server server-name server-detect method { http | portal-heartbeat } * action { log | permit-all | trap } * [ interval interval ] [ retry retries ]
undo portal server server-name server-detect
View
Default level
2: System level
server-name: Name of a portal server, a case-sensitive string of 1 to 32 characters. The specified portal server must have existed.
server-detect method { http | portal-heartbeat }: Specifies the portal server detection method. Two detection methods are available:
·           http: Probes HTTP connections. In this method, the switch (the access device) periodically sends TCP connection requests to the HTTP service port of the portal servers enabled on its interfaces. If the TCP connection with a portal server can be established, the access device considers that the HTTP service of the portal server is open and the portal server is reachable—the detection succeeds. If the TCP connection cannot be established, the access device considers that the detection fails—the portal server is unreachable. If a portal server does not support the portal server heartbeat function, you can configure the switch to use the HTTP probe method to detect the reachability of the portal server.
·           portal-heartbeat: Probes portal heartbeat packets. Portal servers periodically send portal heartbeat packets to the access devices. If the access device receives a portal heartbeat packet from a portal server within the specified interval, the access device considers that the probe succeeds and the portal server is reachable; otherwise, it considers that the probe fails and the portal server is unreachable. This method is effective to only portal servers that support the portal heartbeat function. Currently, only the iMC portal server supports this function. To implement detection with this method, you also need to configure the portal server heartbeat function on the iMC portal server and make sure that the server heartbeat interval configured on the portal server is shorter than or equal to the probe interval configured on the switch.
action { log | permit-all | trap }: Specifies the actions to be taken when the status of a portal server changes. The following actions are available:
·           log: Specifies the action as sending a log message. When the status (reachable/unreachable) of a portal server changes, the access device sends a log message. The log message contains the portal server name and the current state and original state of the portal server.
·           permit-all: Specifies the action as disabling portal authentication—enabling portal authentication bypass. When the access device detects that a portal server is unreachable, it disables portal authentication on the interface referencing the portal server, allowing all portal users on this interface to access network resources. When the access device receives the portal server heartbeat packets or authentication packets (such as login requests and logout requests), it re-enables the portal authentication function.
·           trap: Specifies the action as sending a trap message. When the status (reachable/unreachable) of a portal server changes, the access device sends a trap message to the network management server (NMS). Trap message contains the portal server name and the current state of the portal server.
interval interval: Interval at which probe attempts are made. The interval argument ranges from 20 to 600 and defaults to 20, in seconds.
retry retries: Maximum number of probe attempts. The retries argument ranges from 1 to 5 and defaults to 3. If the number of consecutive, failed probes reaches this value, the access device considers that the portal server is unreachable.
Use the portal server server-detect command to configure portal server detection, including the detection method, action, probe interval, and maximum number of probe attempts. With this function configured, the switch checks the status of the specified server periodically and takes the specified actions when the server status changes.
Use the undo portal server server-detect command to cancel the detection of the specified portal server.
By default, the portal server detection function is not configured.
You can specify one or more detection methods and the actions to be taken.
If both detection methods are specified, a portal server will be regarded as unreachable as long as one detection method fails, and an unreachable portal server will be regarded as recovered only when both detection methods succeed.
If multiple actions are specified, the system will execute all the specified actions when the status of a portal server changes.
Deleting a portal server on the switch will delete the detection function for the portal server.
If you configure the detection function for a portal server for multiple times, the last configuration will take effect. If you do not specify an optional parameter, the default setting of the parameter will be used.
The portal server detection function takes effect only when the portal server is referenced on an interface.
Authentication-related packets from a portal server, such as logon requests and logoff requests, have the same effect as the portal heartbeat packets for the portal server detection function.
Related command: display portal server.
# Configure the switch to detect portal server pts:
·           Specifying both the HTTP probe and portal heartbeat probe methods
·           Setting the probe interval to 600 seconds
·           Specifying the switch to send a server unreachable trap message, send a log message and disable portal authentication to permit unauthenticated portal users, if two consecutive probes fail.
[Sysname] portal server pts server-detect method http portal-heartbeat action log permit-all trap interval 600 retry 2
portal server user-sync
portal server server-name user-sync [ interval interval ] [ retry retries ]
undo portal server server-name user-sync
View
Default level
2: System level
user-sync: Enables the portal user synchronization function.
interval interval: Specifies the interval at which the switch checks the user synchronization packets. The interval argument ranges from 60 to 3600 and defaults to 300, in seconds.
retry retries: Specifies the maximum number of consecutive failed checks. The retries argument ranges from 1 to 5 and defaults to 4. If the switch finds that one of its users does not exist in the user synchronization packets from the portal server within N consecutive probe intervals (N = retries), it considers that the user does not exist on the portal server and logs the user off.
Use the portal server user-sync command to configure portal user information synchronization with a specific portal server. With this function configured, the switch periodically checks and responds to the user synchronization packet received from the specified portal server, so as to keep the consistency of the online user information on the switch and the portal server.
Use the undo portal server user-sync command to cancel the portal user information synchronization configuration with the specified portal server.
By default, the portal user synchronization function is not configured.
The user information synchronization function requires that a portal server supports the portal user heartbeat function (currently only the iMC portal server supports portal user heartbeat). To implement the portal user synchronization function, you also need to configure the user heartbeat function on the portal server and make sure that the user heartbeat interval configured on the portal server is shorter than or equal to the synchronization probe interval configured on the switch.
Deleting a portal server on the switch will delete the portal user synchronization configuration with the portal server.
If you configure the user synchronization function for a portal server for multiple times, the last configuration will take effect. If you do not specify an optional parameter, the default setting of the parameter will be used.
For redundant user information on the switch—information of the users considered as nonexistent on the portal server, the switch will delete the information during the (N+1)th probe interval, where N equals to the value of retries configured in the portal server user-sync command.
# Configure the switch to synchronize portal user information with portal server pts:
·           Setting the synchronization probe interval to 600 seconds
·           Specifying the switch to log off users if information of the users does not exist in the user synchronization packets sent from the server in two consecutive probe intervals.
[Sysname] portal server pts user-sync interval 600 retry 2
reset portal connection statistics
reset portal connection statistics { all | interface interface-type interface-number }
View
Default level
1: Monitor level
Use the reset portal connection statistics command to clear portal connection statistics on a specific interface or all interfaces.
# Clear portal connection statistics on interface VLAN-interface 100.
<Sysname> reset portal connection statistics interface Vlan-interface 100
reset portal server statistics
reset portal server statistics { all | interface interface-type interface-number }
View
Default level
1: Monitor level
Use the reset portal server statistics command to clear portal server statistics on a specific interface or all interfaces.
# Clear portal server statistics on interface VLAN-interface 100.
<Sysname> reset portal server statistics interface Vlan-interface 100
reset portal tcp-cheat statistics
View
Default level
1: Monitor level
None
Use the reset portal tcp-cheat statistics command to clear TCP spoofing statistics.
# Clear TCP spoofing statistics.
<Sysname> reset portal tcp-cheat statistics
  • Become a Partner
  • Partner Resources
