Layer 2 - WAN Command Reference
HomeSupportWLANH3C WA2200 Series WLAN Access PointsReference GuidesCommand ReferencesH3C WA Series WLAN Access Points Command Reference-6W100Layer 2 - WAN Command Reference
00-Preface
00-Preface 65.93 KB
Preface
The H3C WA documentation set includes 10 command references, which describe the commands and command syntax options available for the H3C WA series WLAN access points.
The Layer 2 – WAN Command Reference describes PPP configuration commands.
This preface includes:
l          Audience
l          Conventions
l          About the H3C WA Documentation Set
l          Obtaining Documentation
l          Documentation Feedback
Audience
l          Network planners
l          Field technical support and servicing engineers
l          Network administrators working with the WA series
Conventions
This section describes the conventions used in this documentation.
Command conventions
Convention
Boldface
italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
The H3C WA documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Hardware specifications and installation
Compliance and safety manual
Provides regulatory information and the safety instructions that must be followed during installation.
Quick start
Guides you through initial installation and setup procedures to help you quickly set up and use your AP with the minimum configuration.
Installation guide
Guides you through hardware specifications and installation methods to help you install your AP.
Software configuration
Getting started guide
Guides you through the main functions of your AP, and describes how to install and log in to your AP, perform basic configurations, maintain software, and troubleshoot your AP.
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
User FAQ
Provides answers to some of the most frequently asked questions on how to troubleshoot your AP.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, getting started, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
We appreciate your comments.
  • Become a Partner
  • Partner Resources
