04-IP Multicast Volume
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E Series Ethernet Switches Operation Manual(Release 6300 series V1.03)04-IP Multicast Volume
00-IP Multicast Volume Organization
00-IP Multicast Volume Organization 36.86 KB
Manual Version
20091105-C-1.03
Product Version
Release 6300 series
Organization
The IP Multicast Volume is organized as follows:
Features
Multicast Overview
This document describes the main concepts in multicast:
l      Introduction to Multicast
l      Multicast Models
l      Multicast Architecture
l      Multicast Packets Forwarding Mechanism
l      Multi-Instance Multicast
Multicast Routing and Forwarding
Multicast routing and forwarding refer to some policies that filter RPF routing information for IP multicast support. This document describes:
l      Multicast routing and forwarding overview
l      Multicast routing and forwarding configuration
IGMP
Internet Group Management Protocol (IGMP) is a protocol in the TCP/IP suite responsible for management of IP multicast members. This document describes:
l      IGMP overview
l      Configuring basic functions of IGMP
l      Configuring IGMP performance parameters
l      Configuring IGMP SSM Mapping
PIM
PIM leverages the unicast routing table created by any unicast routing protocol to provide routing information for IP multicast. This document describes:
l      Configuring PIM-DM
l      Configuring PIM-SM
l      Configuring PIM-SSM
l      Configuring PIM Common Features
MSDP
Multicast source discovery protocol (MSDP) describes interconnection mechanism of multiple PIM-SM domains. It is used is to discover multicast source information in other PIM-SM domains. This document describes:
l      MSDP configuration
l      Configuring an MSDP Peer Connection
l      Configuring SA Messages Related Parameters
MBGP
As a multicast extension of MP-BGP, MBGP enables BGP to provide routing information for multicast applications. This document describes:
l      Configuring MBGP Basic Functions
l      Configuring MBGP Route Attributes
l      Configuring a Large Scale MBGP Network
Multicast VPN
l      Multicast VPN overview
l      How MD-VPN works
l      Configuring MD VPN
IGMP Snooping
Running at the data link layer, IGMP Snooping is a multicast control mechanism on the Layer 2 Ethernet switch and it is used for multicast group management and control. This document describes:
l      Configuring Basic Functions of IGMP Snooping
l      Configuring IGMP Snooping Port Functions
l      Configuring IGMP Snooping Querier
l      Configuring IGMP Snooping Policy
Multicast VLAN
Multicast VLAN configuration
l      Configuring Sub-VLAN-Based Multicast VLAN
l      Configuring Port-Based Multicast VLAN
IPv6 Multicast Routing and Forwarding
IPv6 multicast routing and forwarding refer to some policies that filter RPF routing information for IPv6 multicast support. This document describes:
l      IPv6 Multicast routing and forwarding overview
l      IPv6 Multicast routing and forwarding configuration
MLD
MLD is used by an IPv6 router or a Ethernet Switch to discover the presence of multicast listeners on directly-attached subnets. This document describes:
l      Configuring Basic Functions of MLD
l      Adjusting MLD Performance
l      Configuring MLD SSM Mapping
IPv6 PIM
IPv6 PIM discovers multicast source and delivers information to the receivers. This document describes:
l      Configuring IPv6 PIM-DM
l      Configuring IPv6 PIM-SM
l      Configuring IPv6 PIM-SSM
l      Configuring IPv6 PIM Common Features
IPv6 MBGP
As an IPv6 multicast extension of MP-BGP, IPv6 MBGP enables BGP to provide routing information for IPv6 multicast applications. This document describes:
l      Configuring IPv6 MBGP Basic Functions
l      Configuring IPv6 MBGP Route Attributes
l      Configuring a Large Scale IPv6 MBGP Network
MLD Snooping
Multicast Listener Discovery Snooping (MLD Snooping) is an IPv6 multicast constraining mechanism that runs on Layer 2 devices to manage and control IPv6 multicast groups. This document describes:
l      Configuring Basic Functions of MLD Snooping
l      Configuring MLD Snooping Port Functions
l      Configuring MLD Snooping Querier
l      Configuring MLD Snooping Policy
IPv6 Multicast VLAN
IPv6 Multicast VLAN configuration
l      Configuring Sub-VLAN-Based IPv6 Multicast VLAN
l      Configuring Port-Based IPv6 Multicast VLAN
