01-Access Volume
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E Series Ethernet Switches Operation Manual(Release 6300 series V1.03)01-Access Volume
03-Port Isolation Configuration
03-Port Isolation Configuration 47.57 KB
When configuring port isolation, go to these sections for information you are interested in:
l          Introduction to Port Isolation
l          Configuring the Isolation Group
l          Displaying and Maintaining Isolation Groups
l          Port Isolation Configuration Example
Usually, Layer 2 isolation is achieved by assigning ports to different VLANs. This undertaking, however, wastes limited VLAN resources. To address the issue, port isolation was developed. It allows you to isolate ports within the same VLAN by assigning them to isolation groups, achieving flexibility and security.
Currently:
l          The devices support only one isolation group that is created automatically by the system as isolation group 1.. Users can neither remove the isolation group nor create other isolation groups on such devices.
l          There is no restriction on the number of ports to be assigned to an isolation group.
l          The ports in an isolation group can exchange Layer-2 traffic with ports outside of the group, but they cannot exchange traffic with each other.
Assigning a Port to the Isolation Group
Follow these steps to add a port to the isolation group:
To do…
Use the command…
Remarks
Enter system view
Enter interface view or, port group view
Enter Ethernet interface view
Required
Use one of the commands.
l      In Ethernet interface view, the subsequent configurations apply to the current port.
l      In Layer-2 aggregate interface view, the subsequent configurations apply to the Layer-2 aggregate interface and all its member ports.
l      In port group view, the subsequent configurations apply to all ports in the port group.
Enter Layer-2 aggregate interface view
Enter port group view
port-group manual port-group-name
Assign the port or ports to the isolation group as an isolated port or ports
port-isolate enable
Required
No ports are added to the isolation group by default.
After you configure a command on a Layer-2 aggregate interface, the system starts applying the configuration to the aggregate interface and its aggregation member ports. If the system fails to do that on the aggregate interface, it stops applying the configuration to the aggregation member ports. If it fails to do that on an aggregation member port, it simply skips the port and moves to the next port.
To do…
Use the command…
Remarks
Display the isolation group information on a device
display port-isolate group
Available in any view
Networking Requirement
l          Users Host A, Host B, and Host C are connected to Ethernet 2/0/1, Ethernet 2/0/2, and Ethernet 2/0/3 of Device.
l          Device is connected to the Internet through Ethernet 2/0/4.
l          Ethernet 2/0/1, Ethernet 2/0/2, Ethernet 2/0/3, and Ethernet 2/0/4 belong to the same VLAN.
It is required that Host A, Host B, and Host C can access the Internet while being isolated from one another.
Networking diagram
Figure 1-1 Networking diagram for port isolation configuration
Configuration procedure
# Add ports Ethernet 2/0/1, Ethernet 2/0/2 and Ethernet 2/0/3 to the isolation group.
[Device] interface ethernet 2/0/1
[Device-Ethernet2/0/1] port-isolate enable
[Device-Ethernet2/0/1] quit
[Device] interface ethernet 2/0/2
[Device-Ethernet2/0/2] port-isolate enable
[Device-Ethernet2/0/2] quit
[Device] interface ethernet 2/0/3
[Device-Ethernet2/0/3] port-isolate enable
[Device-Ethernet2/0/3] return
# Display the information about the isolation group.
<Device> display port-isolate group
 Port-isolate group information:
 Uplink port support: NO
 Group ID: 1
   Ethernet2/0/1     Ethernet2/0/2     Ethernet2/0/3
