08-System Volume
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Ethernet Switches Command Manual(Release 6300 series V1.03)08-System Volume
05-SNMP Commands
05-SNMP Commands 136.71 KB
SNMP Configuration Commands
display snmp-agent community
View
Default Level
1: Monitor level
read: Displays the information of communities with read-only access right.
write: Displays the information of communities with read and write access right.
Use the display snmp-agent community command to display community information for SNMPv1 or SNMPv2c.
# Display the information for all the current communities.
<Sysname> display snmp-agent community
   Community name: aa
       Group name: aa
       Acl:2001
       Storage-type: nonVolatile
   Community name: bb
       Group name: bb
       Storage-type: nonvolatile
   Community name: userv1
       Group name: testv1
Table 1-1 display snmp-agent community command output description
Community name
Community name
l      If a community name is created by using the snmp-agent community command, the community name will be displayed.
l      If a community name is created by using the snmp-agent usm-user { v1 | v2c } command, the user name will be displayed.
Group name
SNMP group name
l      If a community name is created by using the snmp-agent community command, the group name  and the community name are the same, which means the community name will be displayed.
l      If a community name is created by using the snmp-agent usm-user { v1 | v2c } command, the name of the group to which the user belongs will be displayed.
Acl
The number of the ACL in use
After an ACL is configured, only the Network Management Station (NMS) with the IP address that matches the ACL rule can access the device.
Storage-type
Storage type, which could be:
l      volatile: Information will be lost if the system is rebooted
l      nonVolatile: Information will not be lost if the system is rebooted
l      permanent: Information will not be lost if the system is rebooted. Modification is permitted, but deletion is forbidden
l      readOnly: Information will not be lost if the system is rebooted. Read only, that is, no modification, no deletion
l      other: Other storage types
display snmp-agent group
display snmp-agent group [ group-name ]
View
Default Level
1: Monitor level
group-name: Specifies the SNMP group name, a string of 1 to 32 characters, case sensitive.
Use the display snmp-agent group command to display information for the SNMP agent group, including group name, security model, MIB view, storage type, and so on. Absence of the group-name parameter indicates that information for all groups will be displayed.
# Display the information of all SNMP agent groups.
<Sysname> display snmp-agent group
   Group name: groupv3
       Security model: v3 noAuthnoPriv
       Readview: ViewDefault
       Writeview: <no specified>
       Notifyview: <no specified>
Table 1-2 display snmp-agent group command output description
Group name
SNMP group name
Security model
Security model of the SNMP group, which can be: authPriv (authentication with privacy), authNoPriv (authentication without privacy), or noAuthNoPriv (no authentication no privacy).
Readview
The read only MIB view associated with the SNMP group
Writeview
The writable MIB view associated with the SNMP group
Notifyview
The notify MIB view associated with the SNMP group, the view with entries that can generate traps
Storage-type
Storage type, which includes: volatile, nonVolatile, permanent, readOnly, and other. For detailed information, refer to Table 1-1.
display snmp-agent local-engineid
View
Default Level
1: Monitor level
None
Use the display snmp-agent local-engineid command to display the local SNMP agent engine ID.
SNMP engine ID identifies an SNMP entity uniquely within an SNMP domain. SNMP engine is an indispensable part of an SNMP entity. It provides the SNMP message allocation, message handling, authentication, and access control.
# Display the local SNMP agent engine ID.
<Sysname> display snmp-agent local-engineid
SNMP local EngineID: 800007DB7F0000013859
display snmp-agent mib-view
display snmp-agent mib-view [ exclude | include | viewname view-name ]
View
Default Level
1: Monitor level
exclude: Displays MIB view information of the excluded type.
include: Displays MIB view information of the included type.
viewname view-name: Displays MIB view information with a specified MIB view name, where view-name is the name of the specified MIB view.
Use the display snmp-agent mib-view command to display SNMP MIB view information. Absence of parameters indicates that information for all MIB views will be displayed.
# Display all SNMP MIB views of the device.
<Sysname> display snmp-agent mib-view
   View name:ViewDefault
       MIB Subtree:iso
       Subtree mask:
       View Type:included
       View status:active
       MIB Subtree:snmpUsmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpVacmMIB
       Subtree mask:
       View Type:excluded
       View status:active
       MIB Subtree:snmpModules.18
       Subtree mask:
       View Type:excluded
       View status:active
ViewDefault is the default view of the device. When you access the device through the ViewDefault view, you can access all the MIB objects of the iso subtree except for the MIB objects under the snmpUsmMIB, snmpVacmMIB, and snmpModules.18 subtrees.
Table 1-3 display snmp-agent mib-view command output description
View name
MIB view name
MIB Subtree
MIB subtree corresponding to the MIB view
Subtree mask
MIB subtree mask
Storage-type
Storage type
View Type
View type, which can be included or excluded:
l      Included indicates that all nodes of the MIB tree are included in current view, namely, you are allowed to access all the MIB objects of the subtree
l      Excluded indicates that none of the nodes of the MIB tree are included in current view, namely, you are allowed to access none of the MIB objects of the subtree
View status
The status of MIB view
display snmp-agent statistics
View
Default Level
1: Monitor level
None
Use the display snmp-agent statistics command to display SNMP statistics.
# Display the statistics on the current SNMP.
<Sysname> display snmp-agent statistics
  1684 Messages delivered to the SNMP entity
  5 Messages which were for an unsupported version
  0 Messages which used a SNMP community name not known
  0 Messages which represented an illegal operation for the community supplied
  0 ASN.1 or BER errors in the process of decoding
  1679 Messages passed from the SNMP entity
  0 SNMP PDUs which had badValue error-status
  0 SNMP PDUs which had genErr error-status
  0 SNMP PDUs which had noSuchName error-status
  0 SNMP PDUs which had tooBig error-status (Maximum packet size 1500)
  16544 MIB objects retrieved successfully
  2 MIB objects altered successfully
  7 GetRequest-PDU accepted and processed
  7 GetNextRequest-PDU accepted and processed
  1653 GetBulkRequest-PDU accepted and processed
  1669 GetResponse-PDU accepted and processed
  2 SetRequest-PDU accepted and processed
  0 Trap PDUs accepted and processed
  0 Alternate Response Class PDUs dropped silently
  0 Forwarded Confirmed Class PDUs dropped silently
Table 1-4 display snmp-agent statistics command output description
Number of packets delivered to the SNMP agent
Number of packets from a device with an SNMP version that is not supported by the current SNMP agent
Number of packets that use an unknown community name
Number of packets carrying an operation that the community has no right to perform
Number of packets with ASN.1 or BER errors in the process of decoding
Number of packets sent by an SNMP Agent
Number of SNMP PDUs with a badValue error
Number of SNMP PDUs with a genErr error
Number of PDUs with a noSuchName error
 Number of PDUs with a tooBig error (the maximum packet size is 1,500 bytes)
Number of MIB objects that have been successfully retrieved
Number of MIB objects that have been successfully modified
Number of get requests that have been received and processed
Number of getNext requests that have been received and processed
Number of getBulk requests that have been received and processed
Number of get responses that have been received and processed
Number of set requests that have been received and processed
Number of traps that have been received and processed
Number of dropped response packets
Number of forwarded packets that have been dropped
display snmp-agent sys-info
display snmp-agent sys-info [ contact | location | version ] *
View
Default Level
1: Monitor level
contact: Displays the contact information of the current network administrator.
location: Displays the location information of the current device.
version: Displays the version of the current SNMP agent.
Use the display snmp-agent sys-info command to display the current SNMP system information.
If no keyword is specified, all SNMP agent system information will be displayed.
# Display the current SNMP agent system information.
<Sysname> display snmp-agent sys-info
   The contact person for this managed node:
           Hangzhou H3C Technologies Co., Ltd.
   The physical location of this node:
           Hangzhou, China
   SNMP version running in the system:
           SNMPv3
display snmp-agent trap queue
View
Default Level
1: Monitor level
None
Use the display snmp-agent trap queue command to display basic information of the trap queue, including trap queue name, queue length and the number of traps in the queue currently.
Related commands: snmp-agent trap life, snmp-agent trap queue-size.
# Display the current configuration and usage of the trap queue.
<Sysname> display snmp-agent trap queue
   Queue name: SNTP
   Queue size: 100
   Message number: 6
Table 1-5 display snmp-agent trap queue command output description
Queue name
Trap queue name
Queue size
Trap queue size
Message number
Number of traps in the current trap queue
display snmp-agent trap-list
View
Default Level
1: Monitor level
None
Use the display snmp-agent trap-list command to display the modules that can generate traps and whether their trap function is enabled or not. If a module comprises multiple sub-modules, then as long as one sub-module has the trap function enabled, the whole module will be displayed as being enabled with the trap function.
Related commands: snmp-agent trap enable.
# Display the modules that can generate traps and whether their trap function is enabled or not.
<Sysname> display snmp-agent trap-list
   bgp trap enable
   configuration trap enable
   flash trap enable
   fr trap enable
   isdn trap enable
   mpls trap enable
   ospf trap enable
   standard trap enable
   system trap enable
   voice trap enable
   vrrp trap enable
   Enable traps: 11; Disable traps: 0
In the above output, enable indicates that the module is allowed to generate traps whereas disable indicates the module is not allowed to generate traps. You can configure the trap function (enable or disable) of each module through command lines.
display snmp-agent usm-user
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] *
View
Default Level
1: Monitor level
engineid engineid: Displays SNMPv3 user information for a specified engine ID, where engineid indicates the SNMP engine ID.
username user-name: Displays SNMPv3 user information for a specified user name. It is case sensitive.
group group-name: Displays SNMPv3 user information for a specified SNMP group name. It is case sensitive.
Use the display snmp-agent usm-user command to display SNMPv3 user information.
# Display SNMPv3 information of all created users.
<Sysname> display snmp-agent usm-user
   User name: userv3
   Group name: mygroupv3
       Engine ID: 800063A203000FE240A1A6
       UserStatus: active
   User name: userv3code
   Group name: groupv3code
       UserStatus: active
Table 1-6 display snmp-agent usm-user command output description
User name
SNMP user name
Group name
SNMP group name
Engine ID
Engine ID for an SNMP entity
Storage-type
Storage type, which can be the following:
l      volatile
l      nonvolatile
l      permanent
l      readOnly
l      other
See Table 1-1for details.
UserStatus
SNMP user status
enable snmp trap updown
undo enable snmp trap updown
View
Interface view
Default Level
2: System level
None
Use the enable snmp trap updown command to enable the trap function for interface state changes.
Use the undo enable snmp trap updown command to disable the trap function for interface state changes.
By default, the trap function for interface state changes is enabled.
Note that:
To enable an interface to generate linkUp/linkDown traps when its state changes, you need to enable the Link up/down trap function on the interface and globally. Use the enable snmp trap updown command to enable this function on an interface, and use the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command to enable this function globally.
Related commands: snmp-agent target-host, snmp-agent trap enable.
# Enable the sending of linkUp/linkDown SNMP traps on port GigabitEthernet 2/0/1 and use the community name public.
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] enable snmp trap updown
snmp-agent
snmp-agent
undo snmp-agent
View
Default Level
3: Manage level
None
Use the snmp-agent command to enable SNMP agent.
Use the undo snmp-agent command to disable SNMP agent.
By default, SNMP agent is disabled.
You can enable SNMP agent through any commands that begin with snmp-agent.
# Enable SNMP agent on the device.
snmp-agent calculate-password
snmp-agent calculate-password plain-password mode { 3desmd5 | 3dessha | md5 | sha } { local-engineid | specified-engineid engineid }
View
Default Level
3: Manage level
plain-password: Plain text password to be encrypted.
mode: Specifies the encryption algorithm and authentication algorithm. The two encryption algorithms Advanced Encryption Standard (AES), Data Encryption Standard (DES) are in descending order in terms of security. Higher security means more complex implementation mechanism and lower speed. DES is enough to meet general requirements. Message-Digest Algorithm 5 (MD5) and Secure Hash Algorithm (SHA-1) are the two authentication algorithms. MD5 is faster than SHA-1, while SHA-1 provides higher security than MD5.
l          3desmd5: Converts a plain text encryption password to a cipher text encryption password. In this case, the authentication protocol must be MD5, and the encryption algorithm must be 3DES.
l          3dessha: Converts a plain text encryption password to a cipher text encryption password. In this case, the authentication protocol must be SHA-1, and the encryption algorithm must be 3DES.
l          md5: Converts a plain text authentication password to a cipher text authentication password. In this case, the authentication protocol must be MD5. Or, this algorithm can convert the plain text encryption password to a cipher text encryption password, In this case, the authentication protocol must be MD5, and the encryption algorithm can be either AES or DES (when the authentication protocol is specified as MD5, cipher text passwords are the same by using the encryption algorithms AES and DES).
l          sha: Converts the plain text authentication password to a cipher text authentication password. In this case, the authentication protocol must be SHA-1. Or, this algorithm can convert the plain text encryption password to a cipher text encryption password, In this case, the authentication protocol must be SHA-1, and the encryption algorithm can be either AES or DES (when the authentication protocol is specified as SHA-1, cipher text passwords are the same by using the encryption algorithms AES and DES).
local-engineid: Uses local engine ID to calculate cipher text password. For engine ID-related configuration, refer to the snmp-agent local-engineid command.
specified-engineid: Uses user-defined engine ID to calculate cipher text password.
engineid: The engine ID string, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent calculate-password command to convert the user-defined plain text password to a cipher text password.
Note that:
l          The cipher text password converted with the sha keyword specified in this command is a string of 40 hexadecimal characters. For an authentication password, all of the 40 hexadecimal characters are valid; while for a privacy password, only the first 32 hexadecimal characters are valid.
l          Enable SNMP on the device before executing the command.
When creating an SNMPv3 user, if you specify to use the cipher text authentication/encryption password, you can use this command to generate a cipher text password.
The converted password is associated with the engine ID, namely, the password is valid only under the specified engine ID based on which the password was configured.
Related commands: snmp-agent usm-user v3.
# Use local engine ID and MD5 authentication protocol to convert the plain text password authkey.
[Sysname] snmp-agent calculate-password authkey mode md5 local-engineid
The secret key is: 09659EC5A9AE91BA189E5845E1DDE0CC
snmp-agent community { read | write } community-name [ acl acl-number | mib-view view-name ] *
undo snmp-agent community community-name
View
Default Level
3: Manage level
read: Indicates that the community has read only access right to the MIB objects; that is, the NMS can perform read-only operations when it uses this community name to access the agent.
write: Indicates that the community has read and write access right to the MIB objects; that is, the NMS can perform read and write operations when it uses this community name to access the agent.
community-name: Community name, a string of 1 to 32 characters.
acl acl-number: Associates a basic ACL with the community name. acl-number is in the range 2,000 to 2,999. By using an ACL, you can configure to allow or prohibit the access to the agent from the NMS with the specified source IP address.
mib-view view-name: Specifies the MIB view name associated with community-name, where view-name represents the MIB view name, a string of 1 to 32 characters. If no keyword is specified, the default view is ViewDefault (The view created by the system after SNMP agent is enabled).
Use the snmp-agent community command to create a new SNMP community. Parameters to be configured include access right, community name, ACL, and accessible MIB views.
Use the undo snmp-agent community command to delete a specified community.
The community name configured with this command is only valid for the SNMP v1 and v2c agent.
A community is composed of NMSs and SNMP agents, and is identified by the community name, which functions as a password. In a community, when devices communicate with each other, they use community name for authentication. The NMS and the SNMP agent can access each other only when they are configured with the same community name. Typically, public is used as the read-only community name, and private is used as the read and write community name. For security purposes, you are recommended to configure a community name other than public and private.
l          The keyword acl specifies that only the NMS with a qualified IP address can access the agent.
l          The argument community-name specifies the community name used by the NMS when it accesses the agent.
l          The keyword mib-view specifies the MIB objects which the NMS can access.
l          The keywords read and write specify the access type.
Related commands: snmp-agent mib-view.
# Create a community with the name of readaccess, allowing read-only access right using this community name.
[Sysname] snmp-agent sys-info version v1 v2c
[Sysname] snmp-agent community read readaccess
l          Set the SNMP version on the NMS to SNMPv1 or SNMPv2c
l          Fill in the read-only community name readaccess
l          Establish a connection, and the NMS can perform read-only operations to the MIB objects in the ViewDefault view on the device
# Create a community with the name of writeaccess, allowing only the NMS with the IP address of 1.1.1.1 to configure the values of the agent MIB objects by using this community name; other NMSs are not allowed to perform the write operations by using this community name.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 1.1.1.1 0.0.0.0
[Sysname-acl-basic-2001] rule deny source any
[Sysname-acl-basic-2001] quit
[Sysname] snmp-agent sys-info version v2c
[Sysname] snmp-agent community write writeaccess acl 2001
l          Set the IP address of the NMS to 1.1.1.1
l          Set the SNMP version on the NMS to SNMPv2c
l          Fill in the write community name writeaccess; namely, the NMS can perform read-only operations to the MIB objects in the ViewDefault view on the device
# Create a community with the name of wr-sys-acc. The NMS can perform the read and write operations to the MIB objects of the system subtree (with the OID of 1.3.6.1.2.1.1).
[Sysname] snmp-agent mib-view included test system
[Sysname] snmp-agent community write wr-sys-acc mib-view system
l          Fill in the write community name wr-sys-acc
l          Establish a connection, and the NMS can perform read and write operations to the MIB objects in system view on the device
snmp-agent group
The following syntax applies to SNMPv1 and SNMP v2c:
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group { v1 | v2c } group-name
The following syntax applies to SNMPv3:
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
undo snmp-agent group v3 group-name [ authentication | privacy ]
View
Default Level
3: Manage level
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
group-name: Group name, a string of 1 to 32 characters.
authentication: Specifies the security model of the SNMP group to be authentication only (without privacy).
privacy: Specifies the security model of the SNMP group to be authentication and privacy.
read-view read-view: Read view, a string of 1 to 32 characters. The default read view is ViewDefault.
write-view write-view: Write view, a string of 1 to 32 characters. By default, no write view is configured, namely, the NMS cannot perform the write operations to all MIB objects on the device.
notify-view notify-view: Notify view, for sending traps, a string of 1 to 32 characters. By default, no notify view is configured, namely, the agent does not send traps to the NMS.
acl acl-number: Associates a basic ACL with the group. acl-number is in the range 2000 to 2999. By using a basic ACL, you can restrict the source IP address of SNMP packets, that is, you can configure to allow or prohibit SNMP packets with a specific source IP address, so as to restrict the intercommunication between NMS and Agent.
Use the snmp-agent group command to configure a new SNMP group and specify its access right.
Use the undo snmp-agent group command to delete a specified SNMP group.
By default, SNMP groups configured by the snmp-agent group v3 command use a no-authentication-no-privacy security model.
An SNMP group defines security model, access right, and so on. A user in this SNMP group has all these public properties.
Related commands: snmp-agent mib-view, snmp-agent usm-user.
# Create an SNMP group group1 on an SNMPv3 enabled device, no authentication, no privacy.
[Sysname] snmp-agent group v3 group1
undo snmp-agent local-engineid
View
Default Level
3: Manage level
engineid: Engine ID, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent local-engineid command to configure a local engine ID for an SNMP entity.
Use the undo snmp-agent local-engineid command to restore the default local engine ID.
By default, the engine ID of a device is the combination of company ID and device ID. Device ID varies by product; it could be an IP address, a MAC address, or a self-defined string of hexadecimal numbers.
An engine ID has two functions:
l          For all devices managed by one NMS, each device needs a unique engine ID to identify the SNMP agent. By default, each device has an engine ID. The network administrator has to ensure that there is no repeated engine ID within an SNMP domain.
l          In SNMPv3, the user name and cipher text password are associated with the engine ID. Therefore, if the engine ID changes, the user name and cipher text password configured under the engine ID become invalid.
Typically, the device uses its default engine ID. For ease of remembrance, you can set engine IDs for the devices according to the network planning. For example, if both device 1 and device 2 are on the first floor of building A, you can set the engine ID of device 1 to 000Af0010001, and that of device 2 to 000Af0010002.
Related commands: snmp-agent usm-user.
# Configure the local engine ID as 123456789A.
[Sysname] snmp-agent local-engineid 123456789A
snmp-agent log
snmp-agent log { all | get-operation | set-operation }
undo snmp-agent log { all | get-operation | set-operation }
View
Default Level
3: Manage level
all: Enables logging of SNMP GET and SET operations.
get-operation: Enables logging of SNMP GET operation.
set-operation: Enables logging of SNMP SET operation.
Use the snmp-agent log command to enable SNMP logging.
Use the undo snmp-agent log command to restore the default.
By default, SNMP logging is disabled.
If a specified SNMP logging is enabled, when NMS performs a specified operation on SNMP Agent, the latter records the operation-related information and saves it to the information center. With parameters for the information center set, output rules of the SNMP logs are decided (that is, whether logs are permitted to output and the output destinations).
# Enable logging of SNMP GET operation.
[Sysname] snmp-agent log get-operation
# Enable logging of SNMP SET operation.
[Sysname] snmp-agent log set-operation
snmp-agent mib-view
undo snmp-agent mib-view view-name
View
Default Level
3: Manage level
excluded: Indicates that no nodes of the MIB tree are included in current view.
included: Indicates that all nodes of the MIB tree are included in current view.
view-name: View name, a string of 1 to 32 characters.
oid-tree: MIB subtree, identified by the OID of the subtree root node, such as 1.4.5.3.1, or the name of the subtree root node, such as “system”. OID is made up of a series of integers, which marks the position of the node in the MIB tree and uniquely identifies a MIB object.
mask mask-value: Mask for a MIB subtree, in the range 1 to 32 hexadecimal digits. It must be an even digit.
Use the snmp-agent mib-view command to create or update MIB view information so that MIB objects can be specified.
Use the undo snmp-agent mib-view command to delete the current configuration.
By default, MIB view name is ViewDefault.
MIB view is a subset of MIB, and it may include all nodes of a MIB subtree (that is, the access to all nodes of this MIB subtree is permitted), or may exclude all nodes of a MIB subtree (that is, the access to all nodes of this MIB subtree is forbidden).
You can use the display snmp-agent mib-view command to view the access right of the default view. Also, you can use the undo snmp-agent mib-view command to remove the default view, after that, however, you may not be able to read or write all MIB nodes on the agent.
Related commands: snmp-agent group.
# Create a MIB view mibtest, which includes all objects of the subtree mib-2, and excludes all objects of the subtree ip.
[Sysname] snmp-agent mib-view included mibtest 1.3.6.1
[Sysname] snmp-agent mib-view excluded mibtest ip
[Sysname] snmp-agent community read public mib-view mibtest
If the SNMP version on the NMS is set to SNMPv1, when the NMS uses the community name public to access the device, it cannot access all objects of the ip subtree (such as the ipForwarding node, the ipDefaultTTL node, and so on), but it can access all objects of the mib-2 subtree.
snmp-agent packet max-size
undo snmp-agent packet max-size
View
Default Level
3: Manage level
byte-count: Maximum number of bytes of an SNMP packet that can be received or sent by an agent, in the range 484 to 17,940. The default value is 1,500 bytes.
Use the snmp-agent packet max-size command to configure the maximum size of the SNMP packets that can be received or sent by the agent.
Use the undo snmp-agent packet max-size command to restore the default packet size.
By default, the maximum size of the SNMP packets that can be received or sent by the agent is 1,500 bytes.
If devices not supporting fragmentation exist on the routing path between the NMS and the agent, you can use the command to configure the maximum SNMP packet size, and thus to prevent giant packets from being discarded.
Typically, you are recommended to apply the default value.
# Configure the maximum number of bytes that can be received or sent by an SNMP agent as 1,042 bytes.
[Sysname] snmp-agent packet max-size 1042
snmp-agent sys-info
snmp-agent sys-info { contact sys-contact | location sys-location | version { all | { v1 | v2c | v3 }* } }
undo snmp-agent sys-info { contact | location | version { all | { v1 | v2c | v3 }* } }
View
Default Level
3: Manage level
contact sys-contact: A string of 1 to 200 characters that describes the contact information for system maintenance.
location sys-location: A string of 1 to 200 characters that describes the location of the device.
version: The SNMP version in use.
l          all: Specifies SNMPv1, SNMPv2c, and SNMPv3.
l          v1: SNMPv1.
l          v2c: SNMPv2c.
l          v3: SNMPv3.
Use the snmp-agent sys-info command to configure system information, including the contact information, the location, and the SNMP version in use.
Use the undo snmp-agent sys-info contact and undo snmp-agent sys-info location command to restore the default.
Use the undo snmp-agent sys-info version command to disable use of the SNMP function of the specified version.
By default, the location information is Hangzhou China, version is SNMPv3, and the contact is Hangzhou H3C Technologies Co., Ltd.
The device can process the SNMP packets of the corresponding version only if SNMP of a specific version is enabled. If SNMPv1 is enabled, the device will drop the received SNMPv2c packets; if SNMPv2c is enabled, the device will drop the received SNMPv1 packets. To enable the device to communicate with different NMSs, you can enable SNMP of different versions on a device.
Related commands: display snmp-agent sys-info.
Network maintenance engineers can use the system contact information to get in touch with the manufacturer in case of network failures. The system location information is a management variable under the system branch as defined in RFC1213-MIB, identifying the location of the managed object.
# Configure the contact information as “Dial System Operator at beeper # 27345”.
[Sysname] snmp-agent sys-info contact Dial System Operator at beeper # 27345
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
undo snmp-agent target-host { ip-address | ipv6 ipv6-address } securityname security-string [ vpn-instance vpn-instance-name ]
View
Default Level
3: Manage level
trap: Specifies the host to be the target host which will receive traps and notifications from the device.
address: Specifies the destination IP address in the SNMP messages sent from the device.
udp-domain: Indicates that the trap is transmitted using UDP.
ip-address: The IPv4 address of the trap target host.
ipv6 ipv6-address: Specifies the IPv6 address of the trap target host.
udp-port port-number: Specifies the number of the port on the target host to receive traps.
vpn-instance vpn-instance-name: Specifies the VPN where the target host resides, where vpn-instance-name indicates the VPN instance name and is a string of 1 to 31 characters. It is case sensitive and is applicable only in a network supporting IPv4. If you execute the command with this keyword and argument combination, you need to add the agent into this VPN domain, and ensure that the route between the agent and the NMS is available.
params securityname security-string: Specifies the authentication related parameter, which is an SNMPv1 or SNMPv2c community name or an SNMPv3 user name, a string of 1 to 32 characters.
v1: SNMPv1.
v2c: SNMPv2c.
v3: SNMPv3.
l          authentication: Specifies the security model to be authentication without privacy. Authentication is a process to check whether the packet is integral and whether it has been tampered. You need to configure the authentication password when creating an SNMPv3 user.
l          privacy: Specifies the security model to be authentication with privacy. Privacy is to encrypt the data part of a packet to prevent it from being intercepted. You need to configure the authentication password and privacy password when creating an SNMPv3 user.
Use the snmp-agent target-host command to configure the related settings for a trap target host.
Use the undo snmp-agent target-host command to remove the current settings. According to the networking requirements, you can use this command for multiple times to configure different settings for a target host, enabling the device to send trap messages to different NMSs. The number of target hosts that can be configured varies with the device model.
l          If udp-port port-number is not specified, port number 162 is used.
l          If the key words v1, v2 and v3 are not specified, v1 is used.
l          If the key words authentication and privacy are not specified, the authentication mode is no authentication, no privacy.
Related commands: enable snmp trap updown, snmp-agent trap enable, snmp-agent trap source, snmp-agent trap life.
# Enable the device to send SNMP traps to 10.1.1.1, using the community name of public.
[Sysname] snmp-agent trap enable standard
# Enable the device to send SNMP traps to the device which is in VPN 1 and has an IP address of 10.1.1.1, using the community name of public.
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 vpn-instance vpn1 params securityname public
snmp-agent trap enable [ bgp | configuration | flash | mpls | ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | iftxretransmit | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | vifcfgerror | virifauthfail | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] * | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
undo snmp-agent trap enable [ bgp | configuration | flash | mpls | ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | iftxretransmit | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | vifcfgerror | virifauthfail | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] * | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
View
Default Level
3: Manage level
bgp: Enables the sending of traps of the BGP module.
configuration: Enables the sending of configuration traps.
flash: Enables the sending of FLASH-related traps.
mpls: Enables the sending of traps of the MPLS module.
ospf: Enables the sending of traps of the OSPF module.
l          process-id: OSPF process ID, in the range 1 to 65535.
l          ifauthfail: Traps for interface authentication failure.
l          ifcfgerror: Traps for interface configuration error.
l          ifrxbadpkt: Traps for receiving incorrect packets.
l          ifstatechange: Traps for interface state change.
l          iftxretransmit: Traps for the interface to receive and forward packets.
l          lsdbapproachoverflow: Traps for LSDB to be overflowed.
l          lsdboverflow: Traps for LSDB overflow.
l          maxagelsa: Traps for LSA max age.
l          nbrstatechange: Traps for neighbor state change.
l          originatelsa: Traps for local LSA generation.
l          vifcfgerror: Traps for virtual interface configuration error.
l          virifauthfail: Traps for virtual interface authentication failure.
l          virifrxbadpkt: Traps for virtual interface receiving error packets.
l          virifstatechange: Traps for virtual interface state changes.
l          viriftxretransmit: Traps for virtual interface receiving and forwarding packets.
l          virnbrstatechange: Traps for neighbor state change of the virtual interface.
standard: Standard traps.
l          authentication: Enables the sending of authentication failure traps in the event of authentication failure.
l          coldstart: Sends coldstart traps when the device restarts.
l          linkdown: Sends linkdown traps when the port is in a linkdown status. It should be configured globally.
l          linkup: Sends linkup traps when the port is in a linkup status. It should be configured globally.
l          warmstart: Sends warmstart traps when the SNMP restarts.
system: Sends H3C-SYS-MAN-MIB (a private MIB) traps.
vrrp: Traps of the VRRP module.
l          authfailure: Traps for VRRP authentication failure.
l          newmaster: Enables the sending of VRRP newmaster traps when the device becomes the master.
Use the snmp-agent trap enable command to enable the trap function globally.
Use the undo snmp-agent trap enable command to disable the trap function globally.
By default, the trap function is enabled globally.
Only after the trap function is enabled can each module generate corresponding traps.
Note that:
To enable an interface to generate linkUp/linkDown traps when its state changes, you need to enable the Linkup/Linkdown trap function on the interface and globally. Use the enable snmp trap updown command to enable this function on an interface, and use the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command to enable this function globally.
Related commands: snmp-agent target-host, enable snmp trap updown.
# Enable the device to send SNMP authentication failure packets to 10.1.1.1, using the community name public.
[Sysname] snmp-agent trap enable standard authentication
snmp-agent trap if-mib link extended
undo snmp-agent trap if-mib link extended
View
Default Level
3: Manage level
None
Use the snmp-agent trap if-mib link extended command to extend the standard linkUp/linkDown traps defined in RFC. An extended linkUp/linkDown trap is the standard linkUp/linkDown trap defined in RFC appended with the interface description and interface type information.
Use the undo snmp-agent trap if-mib link extended command to restore the default.
By default, standard linkUp/linkDown traps defined in RFC are used.
l          A standard linkUp trap is in the following format:
#Apr 24 11:48:04:896 2008 Sysname IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983555 is Up, ifAdminStatus is 1, ifOperStatus is 1
l          An extended linkUp trap is in the following format:
#Apr 24 11:43:09:896 2008 Sysname IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983555 is Up, ifAdminStatus is 1, ifOperStatus is 1, ifDescr is Ethernet1/1, ifType is 6
l          A standard linkDown trap is in the following format:
#Apr 24 11:47:35:224 2008 Sysname IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983555 is Down, ifAdminStatus is 2, ifOperStatus is 2
l          An extended linkDown trap is in the following format:
#Apr 24 11:42:54:314 2008 AR29.46 IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983555 is Down, ifAdminStatus is 2, ifOperStatus is 2, ifDescr is Ethernet1/1, ifType is 6
The format of an extended linkup/linkDown trap is the standard format followed with the ifDescr and ifType information, facilitating problem location.
Note that after this command is configured, the device sends extended linkUp/linkDown traps. If the extended messages are not supported on NMS, the device may not be able to resolve the messages.
# Extend standard linkUp/linkDown traps defined in RFC.
[Sysname] snmp-agent trap if-mib link extended
snmp-agent trap life seconds
undo snmp-agent trap life
View
Default Level
3: Manage level
seconds: Timeout time, in the range 1 to 2,592,000 seconds.
Use the snmp-agent trap life command to configure the holding time of the traps in the queue. Traps will be discarded when the holding time expires.
Use the undo snmp-agent trap life command to restore the default holding time of traps in the queue.
By default, the holding time of SNMP traps in the queue is 120 seconds.
The SNMP module sends traps in queues. As soon as the traps are saved in the trap queue, a timer is started. If traps are not sent out until the timer times out (namely, the holding time configured by using this command expires), the system removes the traps from the trap sending queue.
Related commands: snmp-agent trap enable, snmp-agent target-host.
# Configure the holding time of traps in the queue as 60 seconds.
[Sysname] snmp-agent trap life 60
undo snmp-agent trap queue-size
View
Default Level
3: Manage level
size: Number of traps that can be stored in the trap sending queue, in the range 1 to 1,000.
Use the snmp-agent trap queue-size command to set the size of the trap sending queue.
Use the undo snmp-agent trap queue-size command to restore the default queue size.
By default, up to 100 traps can be stored in the trap sending queue.
After traps are generated, they will be saved into the trap sending queue. The size of the queue determines the maximum number of the traps that can be stored in the queue. When the size of the trap sending queue reaches the configured value, the newly generated traps are saved into the queue, and the earliest ones are discarded.
Related commands: snmp-agent trap enable, snmp-agent target-host, snmp-agent trap life.
# Set the maximum number of traps that can be stored in the trap sending queue to 200.
[Sysname] snmp-agent trap queue-size 200
snmp-agent trap source interface-type interface-number
undo snmp-agent trap source
View
Default Level
3: Manage level
interface-type interface-number: Specifies the interface type and interface number.
Use the snmp-agent trap source command to specify the source IP address contained in the trap.
Use the undo snmp-agent trap source command to restore the default.
By default, SNMP chooses the IP address of an interface to be the source IP address of the trap.
Upon the execution of this command, the system uses the primary IP address of the specified interface as the source IP address of the traps, and the NMS will use this IP address to uniquely identify the agent. Even if the agent sends out traps through different interfaces, the NMS uses this IP address to filter all traps sent from the agent.
Use this command to trace a specific event by the source IP address of a trap.
Note that:
Before you can configure the IP address of a particular interface as the source IP address of the trap, ensure that the interface already exists and that it has a legal IP address. Otherwise, if the configured interface does not exist, the configurations will fail; if the specified IP address is illegal, the configuration will be invalid. After a legal IP address is configured for the interface, the configuration becomes valid automatically.
# Configure the IP address of Vlan-interface 1 as the source address for traps.
[Sysname] snmp-agent trap source Vlan-interface 1
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ]
undo snmp-agent usm-user { v1 | v2c } user-name group-name
View
Default Level
3: Manage level
v1: The configured user name should be applied in the SNMPv1 networking environment. If the agent and the NMS use SNMPv1 packets to communicate with each other, this keyword is needed.
v2c: The configured user name should be applied in the SNMPv2c networking environment. If the agent and the NMS use SNMPv2c packets to communicate with each other, this keyword is needed..
user-name: User name, a string of 1 to 32 characters. It is case sensitive.
group-name: Group name, a string of 1 to 32 characters. It is case sensitive.
acl acl-number: Associates a basic ACL with the user. acl-number is in the range 2000 to 2999. By using a basic ACL, you can restrict the source IP address of SNMP packets, that is, you can configure to allow or prohibit SNMP packets with a specific source IP address, so as to allow or prohibit the specified NMS to access the agent by using this user name.
Use the snmp-agent usm-user { v1 | v2c } command to add a user to an SNMP group.
Use the undo snmp-agent usm-user { v1 | v2c } command to delete a user from an SNMP group.
As defined in the SNMP protocol, in SNMPv1 and SNMPv2c networking applications, the NMS and the agent use community name to authenticate each other; in SNMPv3 networking applications, they use user name to authenticate each other. If you prefer using the user name in the authentication, the device supports configuration of SNMPv1 and SNMPv2c users. Creating an SNMPv1 or SNMPv2c user equals adding of a new read-only community name. After you add the user name into the read-only community name field of the NMS, the NMS can establish SNMP connection with the device.
To make the configured user take effect, create an SNMP group first.
Related commands: snmp-agent group, snmp-agent community, snmp-agent usm-user v3.
# Create a v2c user userv2c in group readCom.
[Sysname] snmp-agent group v2c readCom
[Sysname] snmp-agent usm-user v2c userv2c readCom
l          Fill in the read community name userv2c, and then the NMS can access the agent
# Create a v2c user userv2c in group readCom, allowing only the NMS with the IP address of 1.1.1.1 to access the agent by using this user name; other NMSs are not allowed to access the agent by using this user name.
[Sysname] snmp-agent usm-user v2c userv2c readCom acl 2001
l          Fill in both the read community and write community options with userv2c, and then the NMS can access the agent.
snmp-agent usm-user v3 user-name group-name [ [ cipher ] authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | des56 } priv-password ] ] [ acl acl-number ]
undo snmp-agent usm-user v3 user-name group-name { local | engineid engineid-string }
View
Default Level
3: Manage level
cipher: Specifies that auth-password and priv-password are cipher text passwords, which can be calculated by using the snmp-agent calculate-password command.
authentication-mode: Specifies the security model to be authentication. MD5 is faster than SHA, while SHA provides a higher security than MD5.
l          md5: Specifies the authentication protocol as MD5.
l          sha: Specifies the authentication protocol as SHA-1.
auth-password: Authentication password. If the cipher keyword is not specified, auth-password indicates a plain text password, which is a string of 1 to 64 visible characters. If the cipher keyword is specified, auth-password indicates a cipher text password. If the md5 keyword is specified, auth-password is a string of 32 hexadecimal characters. If the sha keyword is specified, auth-password is a string of 40 hexadecimal characters.
privacy-mode:Specifies the security model to be privacy. The three encryption algorithms AES, DES are in descending order in terms of security. Higher security means more complex implementation mechanism and lower speed. DES is enough to meet general requirements.
l          des56: Specifies the privacy protocol to be data encryption standard (DES).
l          aes128: Specifies the privacy protocol to be advanced encryption standard (AES).
priv-password: The privacy password. If the cipher keyword is not specified, priv-password indicates a plain text password, which is a string of 1 to 64 characters; if the cipher keyword is specified, priv-password indicates a cipher text password.if the aes128 keyword is specified, priv-password is a string of 40 hexadecimal characters; if the des56 keyword is specified, priv-password is a string of 40 hexadecimal characters.
local: Represents a local SNMP entity user.
engineid engineid-string: The engine ID string, an even number of hexadecimal characters, in the range 10 to 64. Its length must not be an odd number, and the all-zero and all-F strings are invalid.
Use the snmp-agent usm-user v3 command to add a user to an SNMP group.
Use the undo snmp-agent usm-user v3 command to delete a user from an SNMP group.
The user name configured by using this command is applicable to the SNMPv3 networking environments, If the agent and the NMS use SNMPv3 packets to communicate with each other, you need to create an SNMPv3 user.
To make the configured user valid, create an SNMP group first. Configure the authentication and encryption modes when you create a group, and configure the authentication and encryption passwords when you create a user.
l          If you specify the cipher keyword, the system considers the arguments auth-password and priv-password as cipher text passwords. In this case, the command supports copy and paste, meaning if the engine IDs of the two devices are the same, you can copy and paste the SNMPv3 configuration commands in the configuration file on device A to device B and execute the commands on device B. The cipher text password and plain text password on the two devices are the same.
l          If you do not specify the cipher keyword, the system considers the arguments auth-password and priv-password as plain text passwords. In this case, if you perform the copy and paste operation, the system will encrypt these two passwords, resulting in inconsistency of the cipher text and plain text passwords of the two devices.
Note that:
l          If you use the snmp-agent usm-user v3 cipher command, the pri-password argument in this command can be obtained by the snmp-agent calculate-password command. To make the calculated cipher text password applicable to the snmp-agent usm-user v3 cipher command and have the same effect as that in the snmp-agent usm-user v3 cipher command, ensure that the same privacy protocol is specified for the two commands and the local engine ID specified in the snmp-agent usm-user v3 cipher command is consistent with the SNMP entity engine ID specified in the snmp-agent calculate-password command.
l          If you execute this command repeatedly to configure the same user (namely, the user names are the same, no limitation to other keywords and arguments), the last configuration takes effect.
l          A plain text password is required when the NMS accesses the device; therefore, please remember the user name and the plain text password when you create a user.
Related commands: snmp-agent calculate-password, snmp-agent group, snmp-agent usm-user { v1 | v2c }.
# Add a user testUser to the SNMPv3 group testGroup. Configure the security model as authentication without privacy, the authentication protocol as MD5, the plain-text authentication password as authkey.
[Sysname] snmp-agent group v3 testGroup authentication
[Sysname] snmp-agent usm-user v3 testUser testGroup authentication-mode md5 authkey
l          Set the SNMP version on the NMS to SNMPv3
l          Fill in the user name testUser,
l          Set the authentication protocol to MD5
l          Set the authentication password to authkey
l          Establish a connection, and the NMS can access the MIB objects in the ViewDefault view on the device
# Add a user testUser to the SNMPv3 group testGroup. Configure the security model as authentication and privacy, the authentication protocol as MD5, the privacy protocol as DES56, the plain-text authentication password as authkey, and the plain-text privacy password as prikey.
[Sysname] snmp-agent group v3 testGroup privacy
[Sysname] snmp-agent usm-user v3 testUser testGroup authentication-mode md5 authkey privacy-mode des56 prikey
l          Set the privacy protocol to DES
l          Set the privacy password to prikey
# Add a user testUser to the SNMPv3 group testGroup with the cipher keyword specified. Configure the security model as authentication and privacy, the authentication protocol as MD5, the privacy protocol as DES56, the plain-text authentication password as authkey, and the plain-text privacy password as prikey
[Sysname] snmp-agent calculate-password prikey mode md5 local-engineid
The secret key is: 800D7F26E786C4BECE61BF01E0A22705
[Sysname] snmp-agent usm-user v3 testUser testGroup cipher authentication-mode md5 09659EC5A9AE91BA189E5845E1DDE0CC privacy-mode des56 800D7F26E786C4BECE61BF01E0A22705
display mib-style
display mib-style
View
Default Level
3: Manage level
None
Use the display mib-style command to display the MIB style of the device.
Two MIB styles are available on the device: new and compatible. After obtaining the MIB style, you can select matched H3C network management software based on the MIB style.
Related commands: mib-style.
# After getting the device ID from node sysObjectID, you find that it is an H3C device, and hope to know the current MIB style or the MIB style after next boot of the device.
<Sysname> display mib-style
 Current MIB style: compatible
 Next reboot MIB style: compatible
The above output information indicates that the current MIB style of the device is compatible, and the MIB style after next boot is still compatible.
mib-style
mib-style [ new | compatible ]
View
Default Level
3: Manage level
new: Specifies the MIB style of the device as H3C new; that is, both sysOID and private MIB of the device are located under the H3C enterprise ID 25506.
compatible: Specifies the MIB style of the device as H3C compatible; that is, sysOID of the device is located under the H3C enterprise ID 25506, and private MIB is located under the enterprise ID 2011.
Use the mib-style command to set the MIB style of the device.
By default, the MIB style of the device is compatible.
Note that the configuration takes effect only after the device reboots.
# Modify the MIB style of the device as new.
[Sysname] mib-style new
[Sysname] quit
 Next reboot MIB style: new
<Sysname> reboot
