03-IP Routing Volume
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Ethernet Switches Command Manual(Release 6300 series V1.03)03-IP Routing Volume
00-IP Routing Volume Organization
00-IP Routing Volume Organization 29.3 KB
Manual Version
20091105-C-1.03
Product Version
Release 6300 series
Organization
The IP Routing Volume is organized as follows:
Features
IP Routing Table Display
This document introduces the Display commands for IP Routing Table.
Static Routing
This document introduces the commands for Static Routing.
RIP
Routing Information Protocol (RIP) is a simple Interior Gateway Protocol (IGP), mainly used in small-sized networks.  This document introduces the commands for RIP configuration.
OSPF
Open Shortest Path First (OSPF) is an Interior Gateway Protocol based on the link state developed by IETF. This document introduces the commands for OSPF configuration.
IS-IS
Intermediate System-to-Intermediate System (IS-IS) is a link state protocol, which uses the shortest path first (SPF) algorithm. This document introduces the commands for IS-IS configuration.
BGP
Border gateway protocol (BGP) is an inter-autonomous system (inter-AS) dynamic route discovery protocol. This document introduces the commands for BGP configuration.
IPv6 Static Routing
Similar to IPv4 static routes, IPv6 static routes work well in simple IPv6 network environments. This document introduces the commands for IPv6 Static Routing configuration.
IPv6 RIPng
RIP next generation (RIPng) is an extension of RIP-2 for IPv4. RIPng for IPv6 is IPv6 RIPng. This document introduces the commands for RIPng configuration.
IPv6 OSPFv3
OSPFv3 is OSPF version 3 for short, supporting IPv6 and compliant with RFC2740 (OSPF for IPv6). This document introduces the commands for OSPFv3 configuration.
IPv6 IS-IS
IS-IS with IPv6 support is called IPv6 IS-IS dynamic routing protocol. This document introduces the commands for IPv6 IS-IS configuration.
IPv6 BGP
To support multiple network layer protocols, IETF extended BGP-4 by introducing IPv6 BGP. This document introduces the commands for IPv6 BGP configuration.
Route Policy
Routing policy is used on the router for route inspection, filtering, attributes modifying when routes are received, advertised, or redistributed. This document introduces the commands for Routing Policy configuration.
