H3C WX Series Access Controllers Web-Based Configuration Manual-6PW103
HomeSupportWirelessConfigurationUser ManualH3C WX Series Access Controllers Web-Based Configuration Manual-6PW103
00-1Cover
00-1Cover 58.93 KB
Hangzhou H3C Technologies Co., Ltd.
Manual Version: 6PW103-20090710
Product Version: R1108P04 (WX5002/LS8M1WCMA0)
R2102 (WX5004)
R3106P08 (WX3000 series)
R2109P04 (WX6000 series)
Copyright © 2008-2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
H3C Technologies Co., Ltd., a subsidiary of 3Com Corporation.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
About This Manual
Organization
H3C WX Series Access Controllers  Web-Based Configuration Manual is organized as follows:
Part
1 Quick Start
Introduces the quick start function provided by the Web-based management interface. It guides you to specify basic device parameters, thus simplifying your configuration.
2 Web Overview
Introduces the login, Web interface, Web-based NM functions, controls and configuration guidelines of the Web-based management interface.
3 Summary
Introduces the device summary information and the display information of WLAN service, AP and client.
4 Device
Introduces the configuration related to license, device basic information, system time, syslog, configuration management, software upgrade, file management, reboot, interface management, port mirroring, user management, and loopback test.
5 Network
Introduces the configuration related to MAC address, VLAN, ARP, IGMP snooping, DHCP, DNS, IPv4 and IPv6 routing, service management, and diagnostic tools.
6 AP Configuration
Introduces the configuration related to AP, auto AP, and AP group.
7 WLAN Service Configuration
Introduces the configuration related to WLAN access service.
8 WLAN Roaming Configuration
Introduces WLAN roaming and related configurations.
9 Radio Configuration
Introduces the configuration related to radio, including data transmit rates and channel scanning.
10 Authentication
Introduces the configuration related to authentication, including 802.1x, portal, AAA, RADIUS, local EAP service, PKI and user configuration.
11 Security
Introduces the configuration related to security, including rogue detection, IDS attack detection, blacklist and white list, authorized IP, and user isolation.
12 QoS
Introduces the configuration related to QoS, including ACL, QoS and wireless QoS.
13 SNMP
Introduces the configuration related to SNMP.
14 Advanced Settings
Introduces advanced settings, including district code, AC backup, load balancing, AP version upgrade and working mode switchover.
Conventions
The manual uses the following conventions:
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
Related Documentation
In addition to this manual, each H3C WX Series Access Controllers documentation set includes the following:
Manual
H3C WX5002 Series Access Controllers  Installation Manual
Introduces the installation process, startup, and hardware and software maintenance of WX5002 series access controllers.
H3C WX5004 Access Controller  Installation Manual
Introduces the installation process, startup, and hardware and software maintenance of a WX5004 access controller.
H3C WX6103 Access Controller  Installation Manual
Introduces the installation process, startup, and hardware and software maintenance of a WX6103 access controller.
H3C WX3000 Series Unified Switches  Installation Manual
Introduces the installation process, startup, and hardware and software maintenance of WX3000 Series unified switches.
H3C LS8M1WCMA0 Access Controller Module  Installation Manual
Introduces installation process, startup, and hardware and software maintenance of an LS8M1WCMA0 access controller module used on the H3C S7502/7503/7506/7506R Ethernet switches.
H3C LSQM1WCMB0 Access Controller Module  Installation Manual
Introduces installation process, startup, and hardware and software maintenance of an LSQM1WCMB0 access controller module used on the H3C S7502E/S7503E/S7506E/S7506E-V/S7510E Ethernet switches.
H3C LSBM1WCM2A0 Access Controller Module  Installation Manual
Introduces installation process, startup, and hardware and software maintenance of an LSBM1WCM2A0 access controller module used on the H3C S9512/S9508/S9508V/S9505 Ethernet switches.
H3C WX6103 Access Controller Switch Interface Board  Operation Manual
Provides a guide to the operation of H3C WX6103 access controller switch interface board. It covers configurations of CLI, VLAN, MSTP, system maintenance and debugging, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, and description of the acronyms used throughout the manual.
H3C WX6103 Access Controller Switch Interface Board  Command Manual
Elaborates on the operation commands for H3C WX6103 access controller switch interface board. It covers the configuration commands for CLI, VLAN, MSTP, system maintenance and debugging, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, and a command index of the whole manual.
H3C WX3000 Series Unified Switches Switching Engine  Operation Manual
Provides a guide to the operation on WX3000 series unified switches switching engines. It covers configurations of CLI, login, VLAN, GVRP, basic port configurations, MAC address table management, MSTP, 802.1x, AAA, ACL, QoS, SNMP, RMON, NTP, and SSH.
H3C WX3000 Series Unified Switches Switching Engine  Command Manual
Elaborates on the operation commands for WX3000 series unified switches switching engines. It covers the operation commands for CLI, login, VLAN, GVRP, basic port configurations, MAC address table management, MSTP, 802.1x, AAA, ACL, QoS, SNMP, RMON, NTP, and SSH.
H3C WX Series Access Controllers  User Manual
Provides a guide to the operation of H3C series access controller products (including access controllers, access controller modules, and the access controller engine of unified switches). It covers configurations of CLI, VLAN, system maintenance and debugging, WLAN, IPv4, IPv6, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, description of the acronyms used throughout the manual, and a command index.
Obtaining Documentation and Technical Support
To obtain up-to-date documentation and technical support, go to http://www.h3c.com and select your country or region. Depending on your selection, you will be redirected to either of the following websites:
At http://www.h3c.com
Documentation
Go to the following columns for different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation and configuration.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Technical Support
[email protected]
http://www.h3c.com
At http://www.h3cnetworks.com
Documentation
1)           Select Drivers & Downloads in the Support area.
2)           Select Documentation for Type of File and select Product Category.
Technical Support
Register Your Product
Warranty and other service benefits start from the date of purchase, so it is important to register your product quickly to ensure you get full use of the warranty and other service benefits available to you.
Warranty and other service benefits are enabled through product registration. Register your product at http://www.h3cnetworks.com, go to Support, Product Registration. Support services are based on accounts that you create or have authorization to access. First time users must apply for a user name and password that provides access to a number of eSupport features including Product Registration, Repair Services, and Service Request. If you have trouble registering your product, please contact 3Com Global Services for assistance.
Purchase Value-Added Services
To enhance response times or extend warranty benefits, contact 3Com or your authorized reseller. Value-added services like ExpressSM and GuardianSM can include 24x7 telephone technical support, software upgrades, onsite assistance or advance hardware replacement. Experienced engineers are available to manage your installation with minimal disruption to your network. Expert assessment and implementation services are offered to fill resource gaps and ensure the success of your networking projects. More information on 3Com maintenance and Professional Services is available at http://www.h3cnetworks.com.
Contact your authorized reseller or 3Com for a complete list of the value-added services available in your area.
Troubleshoot Online
You will find support tools posted on the web site at http://www.h3cnetworks.com/ under Support, Knowledgebase. The Knowledgebase helps you troubleshoot H3C products. This query-based interactive tool contains thousands of technical solutions.
Access Software Downloads
Software Updates are the bug fix / maintenance releases for the version of software initially purchased with the product. In order to access these Software Updates you must first register your product on the web site at http://www.h3cnetworks.com, go to Support, Product Registration.
First time users will need to apply for a user name and password. A link to software downloads can be found at http://www.h3cnetworks.com, under Support, Drivers and downloads.
Software Upgrades are the software releases that follow the software version included with your original product. In order to access upgrades and related documentation you must first purchase a service contract from 3Com or your reseller.
Telephone Technical Support and Repair
To enable telephone support and other service benefits, you must first register your product at http://www.h3cnetworks.com/
When you contact 3Com for assistance, please have the following information ready:
l              Product model name, part number, and serial number
l              Proof of purchase, if you have not pre-registered your product
l              A list of system hardware and software, including revision level
l              Diagnostic error messages
l              Details about recent configuration changes, if applicable
To send a product directly to 3Com for repair, you must first obtain a return authorization number (RMA). Products sent to 3Com, without authorization numbers clearly marked on the outside of the package, will be returned to the sender unopened, at the sender’s expense. If your product is registered and under warranty, you can obtain an RMA number online at http://www.h3cnetworks.com under support, Repair & Replacement Request. First time users will need to apply for a user name and password.
Contact Us
3Com offers telephone, e-mail and internet access to technical support and repair services. To access these services for your region, use the appropriate telephone number, URL or e-mail address.
Find a current directory of contact information posted on the web site at http://www.h3cnetworks.com under Support, Technical Support Contact..
Documentation Feedback
We appreciate your comments.
