- H3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
- 00-1Cover
- 01-CLI Commands
- 02-Login Commands
- 03-Configuration File Management Commands
- 04-VLAN Commands
- 05-Management VLAN Commands
- 06-IP Address-IP Performance Commands
- 07-Voice VLAN Commands
- 08-GVRP Commands
- 09-Port Basic Configuration Commands
- 10-Link Aggregation Commands
- 11-Port Isolation Commands
- 12-Port Security-Port Binding Commands
- 13-DLDP Commands
- 14-MAC Address Table Management Commands
- 15-MSTP Commands
- 16-Multicast Commands
- 17-802.1x-System Guard Commands
- 18-AAA Commands
- 19-MAC Address Authentication Commands
- 20-ARP Commands
- 21-DHCP Commands
- 22-ACL Commands
- 23-QoS-QoS Profile Commands
- 24-Mirroring Commands
- 25-Stack-Cluster Commands
- 26-PoE-PoE Profile Commands
- 27-SNMP-RMON Commands
- 28-NTP Commands
- 29-SSH Commands
- 30-File System Management Commands
- 31-FTP-SFTP-TFTP Commands
- 32-Information Center Commands
- 33-System Maintenance and Debugging Commands
- 34-VLAN-VPN Commands
- 35-HWPing Commands
- 36-IPv6 Management Commands
- 37-DNS Commands
- 38-Smart Link-Monitor Link Commands
- 39-Appendix
00-1Cover | 75.68 KB |
H3C S3100 Series Ethernet Switches |
Command Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: 20090710-C-1.06 |
Copyright © 2007-2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro,
SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
http://www.h3c.com
About This Manual
Organization
H3C S3100 Series Ethernet Switches Command Manual is organized as follows:
Part |
Contents |
1 CLI |
Introduces the commands used for switching between the command levels and command level setting. |
2 Login |
Introduces the commands used for logging into the Ethernet switch. |
3 Configuration File Management |
Introduces the commands used for configuration file management. |
4 VLAN |
Introduces the commands used for configuring VLAN. |
5 Management VLAN |
Introduces the commands used for configuring the management VLAN. |
6 IP Address-IP Performance |
Introduces the commands used for IP address configuration and IP performance configuration. |
7 Voice VLAN |
Introduces the commands used for voice VLAN configuration. |
8 GVRP |
Introduces the commands used for GVRP configuration. |
9 Port Basic Configuration |
Introduces the commands used for basic port configuration. |
10 Link Aggregation |
Introduces the commands used for link aggregation. |
11 Port Isolation |
Introduces the commands used for port isolation. |
12 Port Security-Port Binding |
Introduces the commands used for port security configuration and port binding. |
13 DLDP |
Introduces the commands used for DLDP configuration. |
14 MAC Address Table Management |
Introduces the commands used for MAC address forwarding table management. |
15 MSTP |
Introduces the STP-related commands. |
16 Multicast |
Introduces the commands used for multicast configuration. |
17 802.1x-System Guard |
Introduces the commands used for 802.1x-System Guard configuration. |
18 AAA |
Introduces the commands used for AAA, RADIUS, HWTACACS, and EAD configuration. |
19 MAC Address Authentication |
Introduces the commands used for MAC address authentication configuration. |
20 ARP |
Introduces the ARP-related commands. |
21 DHCP |
Introduces the commands used for DHCP, DHCP-snooping configuration. |
22 ACL |
Introduces the ACL-related commands. |
23 QoS-QoS Profile |
Introduces the commands used for QoS and QoS profile configuration. |
24 Mirroring |
Introduces the commands used for port mirroring. |
25 Stack-Cluster |
Introduces the commands used for cluster management. |
26 PoE-PoE Profile |
Introduces the commands used for PoE and PoE profile configuration. |
27 SNMP-RMON |
Introduces the commands used for SNMP and RMON configuration. |
28 NTP |
Introduces the NTP-related commands. |
29 SSH |
Introduces the commands used for SSH configuration. |
30 File System Management |
Introduces the commands used for file system management. |
31 FTP-SFTP-TFTP |
Introduces the FTP-/SFTP-/TFTP-related commands. |
32 Information Center |
Introduces the commands used for information center configuration. |
33 System Maintenance and Debugging |
Introduces the commands used for system maintenance and debugging. |
34 VLAN-VPN |
Introduces the commands used for VLAN VPN configuration. |
35 HWPing |
Introduces the commands used for HWPing configuration. |
36 IPv6 Management |
Introduces the commands used for IPv6 Management configuration. |
37 DNS |
Introduces the commands used for DNS configuration. |
38 Smart Link-Monitor Link |
Introduces the commands used for Smart Link, Monitor Link configuration |
39 Appendix |
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given. |
Conventions
The manual uses the following conventions:
Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means an action or information that needs special attention to ensure successful configuration or good performance. |
Means a complementary description. |
Means techniques helpful for you to make configuration with ease. |
Related Documentation
In addition to this manual, each H3C S3100 Series Ethernet Switches documentation set includes the following:
Manual |
H3C S3100 Series Ethernet Switches Installation Manual |
It provides information for the system installation. |
H3C S3100 Series Ethernet Switches Operation Manual |
It is used for assisting the users in data configurations and typical applications. |
H3C S3100 Series Ethernet Switches Compliance and Safety Manual |
It lists the regulatory compliance statements and provides the safety information of H3C S3100 series Ethernet switches. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
