H3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
HomeSupportSwitchesH3C S3100 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
36-DNS Operation
36-DNS Operation 102.63 KB
Chapter 1  DNS Configuration
&  Note:
This chapter covers only IPv4 DNS configuration. For details about IPv6 DNS, refer to IPv6 Management Operation.
1.1  DNS Overview
Domain name system (DNS) is a mechanism used for TCP/IP applications to provide domain name-to-IP address translation. With DNS, you can use memorizable and meaningful domain names in some applications and let the DNS server resolve it into correct IP addresses.
There are two types of DNS services, static and dynamic. Each time the DNS server receives a name query, it checks its static DNS database before looking up the dynamic DNS database. Reduction of the searching time in the dynamic DNS database would increase efficiency. Some frequently used addresses can be put in the static DNS database.
1.1.1  Static Domain Name Resolution
The static domain name resolution means manually setting up mappings between domain names and IP addresses. IP addresses of the corresponding domain names can be found in the static domain name resolution table for applications, such as Telnet.
1.1.2  Dynamic Domain Name Resolution
I. Resolution procedure
Dynamic domain name resolution is implemented by querying the DNS server. The resolution procedure is as follows:
1)         A user program sends a name query to the resolver in the DNS client.
2)         The DNS resolver looks up the local domain name cache for a match. If a match is found, it sends the corresponding IP address back. If not, it sends the query to the DNS server.
3)         The DNS server looks up its DNS database for a match. If no match is found, it sends a query to a higher-level DNS server. This process continues until a result, success or failure, is returned.
4)         The DNS client performs the next operation according to the result.
Figure 1-1 Dynamic domain name resolution
Figure 1-1 shows the relationship between user program, DNS client, and DNS server.
The resolver and cache comprise the DNS client. The user program and DNS client run on the same device, while the DNS server and the DNS client usually run on different devices.
Dynamic domain name resolution allows the DNS client to store latest mappings between name and IP address in the dynamic domain name cache of the DNS client. There is no need to send a request to the DNS server for a repeated query request next time. The aged mappings are removed from the cache after some time, and latest entries are required from the DNS server. The DNS server decides how long a mapping is valid, and the DNS client gets the information from DNS messages.
II. DNS suffixes
The DNS client normally holds a list of suffixes which can be defined by users. It is used when the name to be resolved is not complete. The resolver can supply the missing part (automatic domain name addition). For example, a user can configure com as the suffix for aabbcc.com. The user only needs to type aabbcc to get the IP address of aabbcc.com. The resolver can add the suffix and delimiter before passing the name to the DNS server.
l           If there is no dot in the domain name, such as aabbcc, the resolver will consider this as a host name and add a DNS suffix before processing. The original name such as aabbcc is used if all DNS lookups fail.
l           If there is a dot in the domain name, such as www.aabbcc or aabbcc., it indicates that no DNS suffix needs to be added and the resolver will use this domain name to do DNS lookup first. If the lookup fails, the resolver adds a DNS suffix for another lookup.
1.2  Configuring Domain Name Resolution
1.2.1  Configuring Static Domain Name Resolution
Table 1-1 Configure static domain name resolution
Operation
Remarks
Enter system view
Configure a mapping between a host name and an IP address
ip host hostname ip-address
Required
No IP address is assigned to a host name by default.
&  Note:
l      The IP address you assign to a host name last time will overwrite the previous one if there is any.
l      You may create up to 50 static mappings between domain names and IP addresses.
1.2.2  Configuring Dynamic Domain Name Resolution
Table 1-2 Configure dynamic domain name resolution
Operation
Remarks
Enter the system view
Enable dynamic domain name resolution
dns resolve
Required
Disabled by default
Configure an IP address for the DNS server
dns server ip-address
Required
No IP address is configured for the DNS server by default.
Configure DNS suffixes
dns domain domain-name
Optional
No DNS suffix is configured by default
&  Note:
You may configure up to six DNS servers and ten DNS suffixes.
1.3  Displaying and Maintaining DNS
After the above configuration, you can execute the display command and the nslookup type command in any view to display the DNS configuration information and the DNS resolution result to verify the configuration effect. You can execute the reset command in user view to clear the information stored in the dynamic domain name resolution cache.
Table 1-3 Display and maintain DNS
Operation
Command…
Remarks
Display static DNS database
display ip host
Available in any view
Display the DNS server information
display dns server [ dynamic ]
Display the DNS suffixes
display dns domain [ dynamic ]
Display the information in the dynamic domain name cache
display dns dynamic-host
Display the DNS resolution result
nslookup type { ptr ip-address | a domain-name }
Clear the information in the dynamic domain name cache
reset dns dynamic-host
Available in user view
1.4  DNS Configuration Example
1.4.1  Static Domain Name Resolution Configuration Example
I. Network requirements
The switch uses static domain name resolution to access host 10.1.1.2 through domain name host.com.
II. Network diagram
Figure 1-2 Network diagram for static DNS configuration
III. Configuration procedure
# Configure a mapping between host name host.com and IP address 10.1.1.2.
[Sysname] ip host host.com 10.1.1.2
# Execute the ping host.com command to verify that the device can use static domain name resolution to get the IP address 10.1.1.2 corresponding to host.com.
[Sysname] ping host.com
  PING host.com (10.1.1.2): 56  data bytes, press CTRL_C to break
    Reply from 10.1.1.2: bytes=56 Sequence=1 ttl=127 time=3 ms
    Reply from 10.1.1.2: bytes=56 Sequence=2 ttl=127 time=3 ms
    Reply from 10.1.1.2: bytes=56 Sequence=3 ttl=127 time=2 ms
    Reply from 10.1.1.2: bytes=56 Sequence=4 ttl=127 time=5 ms
    Reply from 10.1.1.2: bytes=56 Sequence=5 ttl=127 time=3 ms
  --- host.com ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 2/3/5 ms
1.4.2  Dynamic Domain Name Resolution Configuration Example
As shown in Figure 1-3, the switch serving as a DNS client uses dynamic domain name resolution to access the host at 3.1.1.1/16 through its domain name host. The DNS server has the IP address 2.1.1.2/16. The DNS suffix is com.
II. Network diagram
Figure 1-3 Network diagram for dynamic DNS configuration
&  Note:
Before doing the following configuration, make sure that:
l      The routes between the DNS server, Switch, and Host are reachable.
l      Necessary configurations are done on the devices. For the IP addresses of the interfaces, see the figure above.
l      There is a mapping between domain name host and IP address 3.1.1.1/16 on the DNS server.
l      The DNS server works normally.
# Enable dynamic domain name resolution.
[Sysname] dns resolve
# Configure the IP address 2.1.1.2 for the DNS server.
[Sysname] dns server 2.1.1.2
# Configure com as the DNS suffix
[Sysname] dns domain com
Execute the ping host command on Switch to verify that the communication between Switch and Host is normal and that the corresponding IP address is 3.1.1.1.
[Sysname] ping host
 Trying DNS server (2.1.1.2)
  PING host.com (3.1.1.1): 56  data bytes, press CTRL_C to break
    Reply from 3.1.1.1: bytes=56 Sequence=1 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=2 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=3 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=4 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=5 ttl=125 time=5 ms
    0.00% packet loss
    round-trip min/avg/max = 4/4/5 ms
1.5  Troubleshooting DNS
I. Symptom
After enabling the dynamic domain name resolution, the user cannot get the correct IP address.
II. Solution
l           Use the display dns dynamic-host command to check that the specified domain name is in the cache.
l           If there is no defined domain name, check that dynamic domain name resolution is enabled and the DNS client can communicate with the DNS server.
l           If the specified domain name exists in the cache but the IP address is incorrect, check that the DNS client has the correct IP address of the DNS server.
l           Check that the mapping between the domain name and IP address is correct on the DNS server.
