H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesH3C S3600 Switch SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
14-MSTP Configuration Guide
14-MSTP Configuration Guide 167.81 KB
Configuring MSTP
The Ethernet switches listed in Applicable Product Matrix support the Multiple Spanning Tree Protocol (MSTP), which allows you to map one or multiple VLANs to a multiple spanning tree instance (MSTI). Note that one VLAN can be mapped to only one MSTI. With MSTP, the packets of a specific VLAN are transmitted in the MSTI to which the VLAN is mapped, thus saving overhead and reducing resource utilization.
Network Diagram
Figure 1-1 Network diagram for MSTP configuration
VLAN
MSTI
VLAN 10
MSTI 1
VLAN 20
MSTI 0
VLAN 30
MSTI 3
VLAN 40
MSTI 4
Networking and Configuration Requirements
Configure MSTP in the network shown in Figure 1-1 to enable packets of different VLANs to travel along different MSTIs. Do the following:
l          Assign all switches in the network to the same MST region.
l          Enable packets of VLAN 10, VLAN 30, VLAN 40, and VLAN 20 to travel along MSTI 1, MSTI 3, MSTI 4, and MSTI 0 respectively.
In this network, Switch A and Switch B are operating at the distribution layer; Switch C and Switch D are operating at the access layer. VLAN 10 and VLAN 30 are terminated at the distribution layer and VLAN 40 is terminated at the access layer. Configure Switch A as the root bridge of MSTI 1, Switch B as the root bridge of MSTI 3, and Switch C as the root bridge of MSTI 4.
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
1)        Configuration on Switch A
# Enter MST region view.
[SwitchA] stp region-configuration
# Configure the region name, VLAN-to-MSTI mapping, and revision level of the MST region.
[SwitchA-mst-region] region-name example
[SwitchA-mst-region] instance 1 vlan 10
[SwitchA-mst-region] instance 3 vlan 30
[SwitchA-mst-region] instance 4 vlan 40
[SwitchA-mst-region] revision-level 0
# Activate the MST region configuration manually.
[SwitchA-mst-region] active region-configuration
[SwitchA-mst-region] quit
# Specify Switch A as the root bridge of MSTI 1.
[SwitchA] stp instance 1 root primary
2)        Configuration on Switch B
[SwitchB] stp region-configuration
[SwitchB-mst-region] region-name example
[SwitchB-mst-region] instance 1 vlan 10
[SwitchB-mst-region] instance 3 vlan 30
[SwitchB-mst-region] instance 4 vlan 40
[SwitchB-mst-region] revision-level 0
[SwitchB-mst-region] active region-configuration
[SwitchB-mst-region] quit
# Specify Switch B as the root bridge of MSTI 3.
[SwitchB] stp instance 3 root primary
3)        Configuration on Switch C
# Configure the MST region.
[SwitchC] stp region-configuration
[SwitchC-mst-region] region-name example
[SwitchC-mst-region] instance 1 vlan 10
[SwitchC-mst-region] instance 3 vlan 30
[SwitchC-mst-region] instance 4 vlan 40
[SwitchC-mst-region] revision-level 0
[SwitchC-mst-region] active region-configuration
[SwitchC-mst-region] quit
# Specify Switch C as the root bridge of MSTI 4.
[SwitchC] stp instance 4 root primary
4)        Configuration on Switch D
<SwitchD> system-view
[SwitchD] stp region-configuration
[SwitchD-mst-region] region-name example
[SwitchD-mst-region] instance 1 vlan 10
[SwitchD-mst-region] instance 3 vlan 30
[SwitchD-mst-region] instance 4 vlan 40
[SwitchD-mst-region] revision-level 0
[SwitchD-mst-region] active region-configuration
Complete Configuration
l          Configuration on Switch A
 region-name example
 instance 1 vlan 10
 instance 3 vlan 30
 instance 4 vlan 40
l          Configuration on Switch B
 region-name example
 instance 1 vlan 10
 instance 3 vlan 30
 instance 4 vlan 40
l          Configuration on Switch C
 region-name example
 instance 1 vlan 10
 instance 3 vlan 30
 instance 4 vlan 40
l          Configuration on Switch D
 instance 1 vlan 10
 instance 3 vlan 30
 instance 4 vlan 40
Precautions
None
Configuring VLAN-VPN Tunneling
VLAN-VPN tunneling enables BPDUs to be transparently transmitted between geographically dispersed customer networks through a specific VLAN VPN over the service provider network. This allows the customer networks to share a spanning tree independent of that of the service provider network.
Network Diagram
Figure 1-2 Network diagram for VLAN-VPN tunneling configuration
l          Use Switch C and Switch D (which can be S3600 series switches or S5600 series switches) as access devices of the service provider network.
l          Use Switch A and Switch B (which can be S3100 series switches or S5100 series switches) as access devices of the customer networks.
l          Connect Switch C and Switch D through trunk ports. Enable VLAN-VPN tunneling in system view to achieve transparent STP BPDU transmission between the customer networks over the service provider network.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
# Enable MSTP.
[SwitchA] stp enable
# Add Ethernet 1/0/1 to VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] port Ethernet1/0/1
# Enable MSTP.
[SwitchB] stp enable
[SwitchB] vlan 10
[SwitchB-vlan10] port Ethernet1/0/1
# Enable MSTP.
[SwitchC] stp enable
# Enable VLAN-VPN tunneling.
[SwitchC] vlan-vpn tunnel
[SwitchC] vlan 10
[SwitchC-vlan10] port Ethernet1/0/1
[SwitchC-vlan10] quit
# Enable VLAN VPN.
[SwitchC] interface Ethernet1/0/1
[SwitchC-Ethernet1/0/1] vlan-vpn enable
[SwitchC-Ethernet1/0/1] quit
# Configure Ethernet 1/0/2 as a trunk port, and assign the port to VLAN 10.
[SwitchC] interface Ethernet1/0/2
[SwitchC-Ethernet1/0/2] port link-type trunk
[SwitchC-Ethernet1/0/2] port trunk permit vlan 10
# Enable MSTP.
[SwitchD] stp enable
[SwitchD] vlan-vpn tunnel
# Add Ethernet 1/0/2 to VLAN 10.
[SwitchD] vlan 10
[SwitchD-vlan10] port Ethernet1/0/2
[SwitchD-vlan10] quit
# Enable VLAN VPN.
[SwitchD] interface Ethernet1/0/2
[SwitchD-Ethernet1/0/2] vlan-vpn enable
[SwitchD-Ethernet1/0/2] quit
# Configure Ethernet 1/0/1 as a trunk port, and assign the port to VLAN 10.
[SwitchD] interface Ethernet1/0/1
[SwitchD-Ethernet1/0/1] port link-type trunk
[SwitchD-Ethernet1/0/1] port trunk permit vlan 10
stp enable
 port access vlan 10
 stp enable
 port access vlan 10
stp enable
vlan-vpn tunnel
 stp disable
 port access vlan 10
 vlan-vpn enable
 port trunk permit vlan 1 10
stp enable
vlan-vpn tunnel
 stp disable
 port access vlan 10
 vlan-vpn enable
Precautions
The bpdu-tunnel stp command is mutually exclusive with the vlan-vpn tunnel command.
Configuring RSTP
The switches listed inApplicable Product Matrix work in MSTP mode by default. To implement RSTP, configure the stp mode command on them to have them work in RSTP mode.
Network Diagram
Figure 1-3 Network diagram for RSTP configuration
l          Switch A is operating at the core.
l          Switch B and Switch C are operating at the distribution layer.
l          Switch D, Switch E, and Switch F are operating at the access layer.
At the distribution layer:
l          Switch C is operating as the backup switch of Switch B. When Switch B fails, Switch C takes over.
l          Switch C and Switch B are connected through two links. When a link fails, another link takes over.
At the access layer:
l          Switch D, Switch E, and Switch F are directly connected to PCs.
l          Switch D, Switch E, and Switch F are connected to Switch C and Switch B.
In the configuration procedure below, only RSTP-related configurations are provided. Switch A is the root bridge. Switch D through Switch F are mostly consistent in the configuration, so only the configuration on Switch D is listed.
l          In most cases, Switch A is a high-end switch or middle-range switch, such as a S9500 switch or S7500 switch.
l          In most cases, Switch B and Switch C are low-end switches such as S3600 series switches and S5600 series switches.
l          In most cases, Switch D, Switch E, and Switch F are S3100 series switches and S5100 series switches of the low-end switches.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
# Configure Switch A to work in RSTP-compatible mode.
[SwitchA] stp mode rstp
# Configure Switch A as the root bridge in one of the following two methods:
l          Set the bridge priority of Switch A to 0.
[SwitchA] stp priority 0
l          Use the following command to specify Switch A as the root bridge.
[SwitchA] stp root primary
# Enable the root guard function on the designated ports connected to Switch B and Switch C.
[SwitchA] interface GigabitEthernet 2/0/1
[SwitchA -GigabitEthernet2/0/1] stp root-protection
[SwitchA -GigabitEthernet2/0/1] quit
[SwitchA] interface GigabitEthernet 2/0/2
[SwitchA -GigabitEthernet2/0/2] stp root-protection
[SwitchA -GigabitEthernet2/0/2] quit
# Enable the TC-BPDU attack guard function on Switch A.
[SwitchA] stp tc-protection enable
# Enable RSTP on Switch A.
# Disable RSTP on all ports that do not participate in RSTP calculation, GigabitEthernet 2/0/4 for example. (You need to do this because enabling RSTP on a switch enables RSTP on all ports by default.)
[SwitchA] interface GigabitEthernet 2/0/4
[SwitchA-GigabitEthernet2/0/4] stp disable
# Configure Switch B to work in RSTP-compatible mode.
[SwitchB] stp mode rstp
# Configure Switch C and Switch B to back up each other, and set the bridge priority of Switch B to 4096.
[SwitchB] stp priority 4096
# Enable the root guard function on each designated port.
[SwitchB] interface Ethernet 1/0/4
[SwitchB-Ethernet1/0/4] stp root-protection
[SwitchB-Ethernet1/0/4] quit
[SwitchB] interface Ethernet 1/0/5
[SwitchB-Ethernet1/0/5] stp root-protection
[SwitchB-Ethernet1/0/5] quit
[SwitchB] interface Ethernet 1/0/6
[SwitchB-Ethernet1/0/6] stp root-protection
[SwitchB-Ethernet1/0/6] quit
# Enable RSTP on Switch B.
# Disable RSTP on all ports that do not participate in RSTP calculation, Ethernet 1/0/8 for example.
[SwitchB] interface Ethernet 1/0/8
[SwitchB-Ethernet1/0/8] stp disable
# Adopt the default RSTP time-related parameters and port parameters.
# Configure Switch C to work in RSTP-compatible mode.
[SwitchC] stp mode rstp
# Configure Switch C and Switch B to back up each other, and set the bridge priority of Switch C to 8192.
[SwitchC] stp priority 8192
[SwitchC] interface Ethernet 1/0/1
[SwitchC-Ethernet1/0/1] stp root-protection
[SwitchC] interface Ethernet 1/0/2
[SwitchC-Ethernet1/0/2] stp root-protection
[SwitchC-Ethernet1/0/2] quit
[SwitchC] interface Ethernet 1/0/3
[SwitchC-Ethernet1/0/3] stp root-protection
[SwitchC-Ethernet1/0/3] quit
# Enable RSTP on Switch C.
[SwitchC] interface Ethernet 1/0/8
[SwitchC-Ethernet1/0/8] stp disable
# Configure Switch D to work in RSTP-compatible mode.
[SwitchD] stp mode rstp
# Configure the ports directly connected to users as edge ports and enable the BPDU guard function on these ports. Take Ethernet 1/0/3 for example.
[SwitchD-Ethernet1/0/3] stp edged-port enable
[SwitchD-Ethernet1/0/3] quit
[SwitchD] stp bpdu-protection
# Enable RSTP on Switch D.
# Disable RSTP on all ports that do not participate in RSTP calculation, Ethernet 1/0/3 for example.
[SwitchD] interface Ethernet 1/0/3
[SwitchD-Ethernet1/0/3] stp disable
# The configuration on Switch E and Switch F are the same as that on Switch D.
stp mode rstp
stp instance 0 priority 0
(stp instance 0 root primary)
stp TC-protection enable
stp enable
interface GigabitEthernet2/0/1
 stp root-protection
interface GigabitEthernet2/0/2
 stp root-protection
interface GigabitEthernet2/0/4
 stp disable
stp mode rstp
stp instance 0 priority 4096
stp enable
interface Ethernet1/0/4
 stp root-protection
interface Ethernet1/0/5
 stp root-protection
interface Ethernet1/0/6
 stp root-protection
interface Ethernet1/0/8
 stp disable
stp mode rstp
stp instance 0 priority 8192
stp enable
 stp root-protection
 stp root-protection
interface Ethernet1/0/3
 stp root-protection
 stp disable
stp mode rstp
stp enable
 stp disable
 interface Ethernet3/0/5
 stp bpdu-protection
Precautions
None
Configuring Digest Snooping and Rapid Transition
Digest Snooping
The H3C switches listed in Applicable Product Matrix support MSTP. On a network comprising devices of multiple vendors, H3C switches cannot interoperate with switches that run proprietary spanning tree protocols in the same MSTP region, even if they are configured with the same MST region-related settings.
To address the problem, you can enable digest snooping on the ports connected to switches running proprietary spanning tree protocols.
Rapid Transition
The proprietary spanning tree protocols of some vendors provide port state transition mechanisms similar to RSTP. For a switch running such a proprietary protocol, its rapid port state transition mechanism may fail on the designation port when the switch is downlinked to an MSTP-enabled H3C switch.
To address the problem, you can enable the rapid transition feature on the downstream H3C switch.
Network Diagram
Figure 1-4 Network diagram for digest snooping and rapid transition configuration
l          Use another vendor’s switch, Switch A in this scenario, as the root switch.
l          Switch B and Switch C are connected to Switch A.
For Switch B:
l          Set the priority of Switch B to 4096.
l          Enable rapid transition and digest snooping on Switch B.
For Switch C:
l          Set the priority of Switch C to 8192.
l          Enable rapid transition and digest snooping on Switch C.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
1)        Configuration on Switch B
# Enable MSTP.
# Set the priority of Switch B to 4096.
# Enable digest snooping on Switch B.
[SwitchB] stp config-digest-snooping
# Enable digest snooping on the root port Ethernet 1/0/1.
[SwitchB] interface Ethernet 1/0/1
[SwitchB-Ethernet1/0/1] stp config-digest-snooping
# Enable rapid transition on the root port Ethernet 1/0/1.
[SwitchB-Ethernet1/0/1] stp no-agreement-check
[SwitchB-Ethernet1/0/1] quit
2)        Configuration on Switch C
# Enable MSTP.
# Set the priority of Switch C to 8192.
# Enable digest snooping on Switch C.
[SwitchC] stp config-digest-snooping
# Enable digest snooping on the root port Ethernet 1/0/2.
[SwitchC-Ethernet1/0/2] stp config-digest-snooping
# Enable rapid transition on Ethernet 1/0/1.
[SwitchC-Ethernet1/0/1] stp no-agreement-check
 stp enable
 stp enable
Precautions
l          The digest snooping feature is needed only when your switch is connected to another manufacturer’s switches adopting proprietary spanning tree protocols.
l          To enable the digest snooping feature successfully, you must first enable it on all the ports of your switch that are connected to another manufacturer’s switches adopting proprietary spanning tree protocols and then enable it globally.
l          To enable the digest snooping feature, the interconnected switches and another manufacturer’s switch adopting proprietary spanning tree protocols must be configured with exactly the same MST region-related configurations (including region name, revision level, and VLAN-to-MSTI mapping).
l          The digest snooping feature must be enabled on all the switch ports that connect to another manufacturer’s switches adopting proprietary spanning tree protocols in the same MST region.
l          The digest snooping feature is not applicable to boundary ports in an MST region.
l          The digest snooping feature is not applicable to edge ports in an MST region.
l          The rapid transition feature can be enabled only on root ports or alternate ports.
l          You can enable rapid transition on a designated port, but the configuration cannot take effect on the port.
