- H3C S9500 Command Manual-Release2132[V2.03]-03 IP Routing Volume
- 00-1Cover
- 01-IP Routing Table Display Commands
- 02-BGP Commands
- 03-IS-IS Commands
- 04-OSPF Commands
- 05-RIP Commands
- 06-Routing Policy Commands
- 07-Static Routing Commands
- 08-IPv6 BGP Commands
- 09-IPv6 IS-IS Commands
- 10-IPv6 OSPFv3 commands
- 11-IPv6 RIPng Commands
- 12-IPv6 Static Routing Commands
04-OSPF Commands | 275.82 KB |
Table of Contents
Chapter 1 OSPF Configuration Commands
1.1 OSPF Configuration Commands
1.1.1 abr-summary (OSPF area view)
1.1.5 bandwidth-reference (OSPF view)
1.1.13 default-cost (OSPF area view)
1.1.14 default-route-advertise (OSPF view)
1.1.15 description (OSPF/OSPF area view)
1.1.17 display ospf asbr-summary
1.1.19 display ospf cumulative
1.1.25 display ospf peer statistics
1.1.26 display ospf request-queue
1.1.27 display ospf retrans-queue
1.1.32 filter-policy export (OSPF view)
1.1.33 filter-policy import (OSPF view)
1.1.35 import-route (OSPF view)
1.1.38 lsa-generation-interval
1.1.40 maximum load-balancing (OSPF view)
1.1.42 network (OSPF area view)
1.1.44 opaque-capability enable
1.1.46 ospf authentication-mode
1.1.61 reset ospf redistribution
1.1.63 silent-interface (OSPF view)
1.1.64 snmp-agent trap enable ospf
1.1.68 vlink-peer (OSPF area view)
& Note:
l Refer to MPLS TE Commands for OSPF TE related commands.
l Refer to GR Commands for OSPF GR related commands.
l Refer to MPLS L3VPN Commands for OSPF VPN related commands.
abr-summary ip-address { mask | mask-length } [ advertise | not-advertise ] [ cost cost ]
undo abr-summary ip-address { mask | mask-length }
View
OSPF area view
Default Level
2: System level
ip-address: IP address of the summary route, in dotted decimal format.
mask: Mask of the IP address in dotted decimal format.
mask-length: Mask length, in the range 0 to 32 bits.
advertise | not-advertise: Advertises or not to advertise the summary route. By default, the summary route is advertised.
cost cost: Specifies the cost of the summary route. The default cost is the biggest cost value among routes that are summarized.
Use the abr-summary command to configure a summary route on the Area Border Router.
Use the undo abr-summary command to remove a summary route.
By default, no route summarization is available on an ABR.
You can configure to advertise or not to advertise the summary route, and specify a route cost.
This command is usable only on an ABR. Multiple contiguous networks may be available in an area, where you can summarize them with one network on the ABR for advertisement. The ABR advertises only the summary route to other areas.
With the undo abr-summary command used, summarized routes will be advertised.
# Summarize networks 36.42.10.0/24 and 36.42.110.0/24 in Area 1 with 36.42.0.0/16 for advertisement to other areas.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
1.1.2 area (OSPF view)
area area-id
undo area area-id
View
OSPF view
Default Level
2: System level
area-id: ID of an area, a decimal integer, or an IP address.
Use the area command to create an area and enter area view.
Use the undo area command to remove a specified area.
# Create Area0 and enter Area 0 view
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
1.1.3 asbr-summary
asbr-summary ip-address { mask | mask-length } [ tag tag | not-advertise | cost cost ]*
undo asbr-summary ip-address { mask | mask-length }
View
OSPF view
Default Level
2: System level
ip-address: IP address of the summary route in dotted decimal notation.
mask: IP address mask in dotted decimal notation.
mask-length: Mask length.
not-advertise: Specifies not to advertise the summary route. If the keyword is not specified, the route is advertised.
tag tag: Specifies a tag value for the summary route, used by a route policy to control route advertisement. The value defaults to 1.
cost cost: Specifies the cost of the summary route. For Type-1 external routes, the cost defaults to the biggest cost among routes that are summarized. For Type-2 external routes, the cost defaults to the value of the biggest cost among routes that are summarized plus 1.
Use the asbr-summary command to configure a summary route.
Use the undo asbr-summary command to remove a summary route.
No route summarization is configured by default.
With the asbr-summary command configured on an ASBR, it summarizes redistributed routes that fall into the specified address range with a single route. If the ASBR resides in an NSSA area, it advertises the summary route in a Type-7 LSA into the area.
With the asbr-summary command configured on an NSSA ABR, it summarizes routes in Type-5 LSAs translated from Type-7 LSAs with a single route and advertises the summary route to other areas. This command does not take effect on non NSSA ABRs.
With the undo asbr-summary command used, summarized routes will be advertised.
Related commands: display ospf asbr-summary.
# Summarize redistributed routes with a single route.
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
1.1.4 authentication-mode
authentication-mode { simple | md5 }
undo authentication-mode
View
OSPF area view
Default Level
2: System level
simple: Specifies the simple authentication mode.
md5: Specifies the MD5 ciphertext authentication mode.
Use the authentication-mode command to specify an authentication mode for the OSPF area.
Use the undo authentication-mode command to cancel a specified authentication mode.
By default, no authentication mode is configured for an OSPF area.
Devices that reside in the same area must have the same authentication mode: non-authentication, simple, or MD5.
Related commands: ospf authentication-mode.
# Specify the MD5 ciphertext authentication mode for OSPF area0.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5
bandwidth-reference value
undo bandwidth-reference
View
OSPF view
Default Level
2: System level
value: Bandwidth reference value for link cost calculation, in Mbps.
Use the bandwidth-reference command to specify a reference bandwidth value for link cost calculation.
Use the undo bandwidth-reference command to restore the default.
The default value is 100 Mbps.
When links have no cost values configured, OSPF calculates their cost values: Cost = Reference bandwidth value/Link bandwidth. If the calculated cost is greater than 65535, the value of 65535 is used.
# Specify the reference bandwidth value as 1000 Mbps.
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
1.1.6 debugging ospf event
debugging ospf [ process-id ] event [ bfd | error | graceful-restart | interface | neighbor ]
undo debugging ospf [ process-id ] event [ bfd | error | graceful-restart | interface | neighbor ]
View
Default level
1: Monitor level
process-id: OSPF process ID.
bfd: Enables OSPF BFD event debugging.
error: Enables OSPF error event debugging.
graceful-restart: Enables OSPF graceful restart (GR) event debugging.
interface: Enables interface event debugging.
neighbor: Enables OSPF neighbor event debugging.
Use the debugging ospf event command to enable OSPF event debugging.
Use the undo debugging ospf event command to disable OSPF event debugging.
By default, OSPF event debugging is disabled.
Table 1-1 Description on the fields of the debugging ospf event bfd command
OSPF 1: OSPF received packet having conflicted Router ID :rt-id |
OSPF received a packet with a conflicting Router ID. rt-id: router ID of the neighbor |
OSPF-BFD: Message type msg-type, Connect type conn-type, Src IP Address src-ip, Src IFIndex if-index, Dst IP Address dst-ip |
Detailed OSPF BFD message information l msg-type: BFD message type, which can be delete session, rcv BFD down, create session, or disable BFD. l conn-type: connection type. The default is direct-connect. |
Table 1-2 Description on the fields of the debugging ospf event interface command
OSPF process-id |
OSPF process ID |
Intf intf-ip Rcv intf-event State pre-state -> cur-state |
Detailed information of interface state changes: l intf-ip: Interface IP address. l intf-event: Event triggering the interface state change. It can be InterfaceUp, WaitTimer, LoopInd, BackupSeen, NeighborChange, UnloopInd, and InterfaceDown. l pre-state/cur-state: Previous and current interface state. Down means the interface is down; Loopback means the interface is in the loopback state; Watiting means the interface is in the waiting state; Point-to-point means the interface is connected to a P2P network or on a virtual link; DR means the router is a DR; Backup means the router is a BDR; DROther means the router is neither DR nor BDR. |
Tunnel Interface Insert Info: Dest: dest-ip Nbr ID: nbr-id Tunnel Metric Type: metric-type Tunnel Metric: metric Tunnel Final Cost: cost Holddown Timer: interval Holddown TimerID: tmr-id Tunnel Type: tunnel-type Tunnel State: state |
Detailed information of a tunnel interface l metric-type: Metric type of the tunnel interface. It can be Relative or Absolute. l metric: Tunnel interface cost set by RM. l cost: Tunnel interface cost l interval: Value of holddown timer l tmr-id: Holddown timer ID l tunnel-type: Tunnel interface type, 1 for IGP-shortcut; 2 for Forwarding Adjacency; 4 for common TE. l state: Tunnel interface state, 1 for DOWN and 2 for UP. |
Table 1-3 Description on the fields of the debugging ospf event neighbor command
OSPF process-id |
OSPF process ID |
Nbr nbr-ip Rcv nbr-event State original-state -> current-state |
Detailed information of neighbor state changes: l nbr-ip: Neighbor interface IP address. l nbr-event: Event triggering the neighbor state change. It can be Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, or Full. l original-state/current-state: Previous and current neighbor state. The state can be HelloReceived, Start, 2WayReceived, NegotiationDone, ExchangeDone, BadLSReq, LoadingDone, AdjOK?, 1-Way, KillNbr, Inactivity Timer, or LLDown. |
# Switch A and Switch B are interconnected over a broadcast network. Enable OSPF interface event debugging on Switch A.
<Sysname> debugging ospf event interface
%Dec 12 09:24:58:978 2006 Sysname IFNET/4/UPDOWN:
Line protocol on the interface Vlan-interface 100 is UP
OSPF 1: Intf 150.1.1.1 Rcv InterfaceUp State Down -> Waiting.
// The interface state changed from Down to Waiting.
OSPF 1: Intf 150.1.1.1 Rcv BackupSeen State Waiting -> BackupDR.
// The interface state changed from Waiting to BackupDR.
1.1.7 debugging ospf lsa
debugging ospf [ process-id ] lsa [ generate | install ]
undo debugging ospf [ process-id ] lsa [ generate | install ]
View
Default level
1: Monitor level
generate: Enables debugging for LSA generation.
install: Enables debugging for the installation of LSAs into the LSDB.
Use the debugging ospf lsa command to enable OSPF LSA debugging.
Use the undo debugging ospf lsa command to disable OSPF LSA debugging.
By default, OSPF LSA debugging is disabled.
Table 1-4 Description on the fields of the debugging ospf lsa command
OSPF process-id |
OSPF process ID |
op-type LSA at x ms |
Operation on LSAs: op-type: Type of operation to perform on LSAs. Generate means generating LSAS; Install means installing LSAs. |
LSAType: ls-type LinkStateId: link-state-id Advertising Rtr: rt-id |
LSA header information l ls-type: LSA type, 1 for Router LSA, 2 for network LSA, 3 for net-summary LSA, 4 for ASBR-summary LSA, 5 for AS-external–LSA, 7 for NSSA LSA, 9, 10, and 11 for Opaque LSA. l Link-state-id: LSA ID l rt-id: ID of the advertising router |
LSA Age: age Options : ExRouting: ON/OFF |
LSA header information l age: LSA age l ON/OFF: Indicates whether external routing is supported. |
Length: ls-len Seq: seq-num CheckSum:checksum |
LSA header information l Ls-len: LS length l Seq-num: LS sequence number l Checksum: Checksum of the whole LSA except the LSA age field |
Capabilities: VBit: Ebit: Bbit: Link#: link-count TOS# tos-num Metric cost |
Router LSA contents l VBit: 0x40 for a virtual link. l Ebit: 0x200 for an External LSA. l Bbit: 0x100 for an ABR. l Link-count: Number of links in the Router LSA l tos-num: Number of TOSs in the Router LSA l cost: Link cost |
Net Mask: net-mask Attached Router: rt-id |
Network LSA contents l net-mask: Network mask l rt-id: ID of a neighbor |
Net Mask: net-mask Metric: cost |
Contents of Summary and ASBR-Summary LSAs l net-mask: Network mask l cost: Link cost |
Net Mask: net-mask TOS: tos Metric: cost FwdAddr: fwd-addr Tag: rt-tag |
Contents of AS_External LSA and NSSA LSA l net-mask: Network mask l tos: Type of Service l cost: Link cost l fwd-addr: Forwarding address l rt-tag: External route tag |
# Switch A and Switch B are interconnected over a broadcast network. Enable debugging for LSA generation on Switch A.
<Sysname> debugging ospf lsa generate
<Sysname>
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:OSPF 1: Generate LSA at 6352610 ms:
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:LSAType: 1.
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:LinkStateId: 1.1.1.1.
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:Advertising Rtr: 1.1.1.1.
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:LSA Age: 0 Options: ExRouting:ON.
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:Length: 36 Seq# 8000002c CheckSum: 3185.
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:Capabilities: VBit:0 EBit: 0 BBit: 0 Link# 1.
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:LinkID: 150.1.1.0 LinkData: 255.255.255.0 LinkType: 3.
*Dec 12 11:07:33:610 2006 Sysname RM/6/RMDEBUG:TOS# 0 Metric 10.
// A Router LSA was generated.
%Dec 12 11:07:33:708 2006 Sysname RM/3/RMLOG:OSPF-NBRCHANGE: Process 1, Neighbour 150.1.1.2(Vlan-interface 100) from Loading to Full
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:OSPF 1: Generate LSA at 6357625 ms:
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:LSAType: 1.
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:LinkStateId: 1.1.1.1.
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:Advertising Rtr: 1.1.1.1.
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:LSA Age: 0 Options: ExRouting:ON.
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:Length: 36 Seq# 8000002d CheckSum: 44595.
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:Capabilities: VBit:0 EBit: 0 BBit: 0 Link# 1.
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:LinkID: 150.1.1.2 LinkData: 150.1.1.1 LinkType: 2.
*Dec 12 11:07:38:630 2006 Sysname RM/6/RMDEBUG:TOS# 0 Metric 10.
// After entering the Full state, the neighbor generated a Router LSA.
1.1.8 debugging ospf mpls-te
debugging ospf [ process-id ] mpls-te
undo debugging ospf [ process-id ] mpls-te
View
Default level
1: Monitor level
Use the debugging ospf mpls-te command to enable debugging for OSPF MPLS traffic engineering.
Use the undo debugging ospf mpls-te command to disable debugging for OSPF MPLS traffic engineering.
By default, debugging for OSPF MPLS traffic engineering is disabled.
Table 1-5 Description on the fields of the debugging ospf mpls-te command
OSPF TE |
OSPF TE debug information |
Status Update Message from RM: Status Received = |
OSPF received a TE state update message from RM. |
Status Update SUCCESS by OSPF: Status Updated = |
OSPF processed the TE state update message received from RM successfully. |
Received Link Info from RM Process: process-id Area : area-id Link Type: link-type TE Metric: TE-metric Max BW : max-bw Max Resv BW : Admin Grp: |
OSPF received the link information from RM: l process-id: OSPF process ID. l area-id: Area ID l link-type: Link type l TE-metric: TE metric l max-bw: Maximum bandwidth, in bytes/s. l max-resv-bw: Maximum reserved bandwidth, in bytes/s. |
Message Send to CSPF SUCCESS!!! Router ID: rt-id Process ID: process-id Area ID: area-id Link Type: link-type Link ID: link-id TE Metric: TE-metric IGP Metric: IGP-metric Max BW: max-bw Max Resv BW: max-res-bw Event Type: event-type |
OSPF sent TE information to CSPF successfully. l Router ID: Router ID l Process ID: OSPF process ID. l Area ID: Area ID l Link Type: Link type l Link ID: link ID l TE Metric: TE metric l IGP Metric: IGP metric l max-bw: Maximum bandwidth, in bit/s. l Max Resv BW: Maximum reserved bandwidth l Event Type: Event type |
Received Network LSA by OSPF TE Process ID: process-id Area ID: area-id Link Id : link-id Attached Rtr Count : attach-rt-count Advtg Router ID: adv-rt-id |
OSPF TE received a Network LSA. l process-id: OSPF process ID l area-id: Area ID l link-id: Link ID l attach-rt-count: Number of attached routers l adv-rt-id: ID of the advertising router |
Send Network LSA to CSPF SUCCESS Process ID: process-id Area ID: area-id Attached Rtr Count: attach-rt-count MPLS DR Router ID: lsr id DR Intf Addr: ip-addr |
OSPF sent a network LSA to CSPF successfully. l process-id: OSPF process ID. l area-id: Area ID l attach-rt-count: Number of attached routers l lsr id: MPLS LS ID l ip-addr: DR IP address |
Opaque LSA removed when Nbr DOWN Process ID: process-id Area ID: area-id Link ID/ Opq ID: opq-id |
OSPF removed the TE Opaque LSA when the neighbor was down. l process-id: OSPF process ID. l area-id: Area ID l opq-id: opq ID |
Received MPLS Router ID= lsr id from RM |
OSPF received the notification of MPLS LSR ID from RM lsr id: MPLS LS ID |
OPAQUE LSA GENERATION SUCCESS for Area: area-id Opaque Id: opq-id |
An opaque LSA was generated successfully. l area-id: Area ID l opq-id: opq ID |
OPAQUE LSA REMOVE SUCCESS Process ID: process-id Advtg Router: adv-rtr Opq ID: opq-id |
An opaque LSA was deleted successfully. l process-id: OSPF process ID. l adv-rtr: ID of the advertising router. l opq-id: opq ID |
OPAQUE LSA UPDATE SUCCESS Process ID: process-id Advtg Router: adv-rtr Opq ID: opq-id |
The Opaque LSA was updated successfully. l process-id: OSPF process ID. l adv-rtr: ID of the advertising router. l opq-id: opq ID |
TE successfully enabled for OSPF Area = area-id under OSPF Process = process-id |
TE was enabled successfully in the OSPF area. l area-id: Area ID l process-id: OSPF process ID. |
# Switch A is configured with MPLS TE, OSPF, and LDP. Loopback 0 is created on Switch A, with an IP address of 1.1.1.1/32. Switch A and Switch B are interconnected over a broadcast network. Enable OSPF MPLS-TE debugging on Switch A.
<Sysname> debugging 1 ospf mpls-te
*Dec 20 15:01:37:86 2006 Sysname RM/6/RMDEBUG:OSPF TE
NSM_LoadingDone: LOADING DONE
HandleNeighborStateChg: BROADCAST
GetBroadCastNewGenNbr: Nbr DR, NbrIp = 2.2.2.2
GetBroadCastNewGenNbr: SUCCESS, MultiCastTeNbrID = 2.2.2.2
Process : 1
Area : 0.0.0.0
Link Type : 4
TE Metric : 0
Max BW : 0
Max Resv BW : 0
Admin Grp : 0
Process ID : 1
Area ID : 0.0.0.0
Link Id : 150.1.1.2
Attached Rtr Count : 2
Advtg Router ID : 2.2.2.2
Process ID : 1
Area ID : 0.0.0.0
MPLS DR Router ID : 2.2.2.2
DR Intf Addr : 150.1.1.2
Process ID : 1
Area ID : 0.0.0.0
Link Id : 150.1.1.2
*Dec 20 15:01:37:98 2006 Sysname RM/6/RMDEBUG:OSPF TE
Process ID : 1
Area ID : 0.0.0.0
*Dec 20 15:01:37:118 2006 Sysname RM/6/RMDEBUG:OSPF TE
UpdateNetworkLsa - MODIFY
Process ID : 1
Area ID : 0.0.0.0
Link Id : 150.1.1.2
Process ID : 1
Area ID : 0.0.0.0
Process ID : 1
Area ID : 0.0.0.0
Link Id : 150.1.1.2
*Dec 20 15:01:37:130 2006 Sysname RM/6/RMDEBUG:OSPF TE
Process ID : 1
Area ID : 0.0.0.0
ReceiveOpqLsa: Processed Success
*Dec 20 15:01:40:194 2006 Sysname RM/6/RMDEBUG:OSPF TE
Process ID : 1
Area ID : 0.0.0.0
Link Id : 3.1.1.2
Advtg Router ID : 3.3.3.3
*Dec 20 15:01:50:194 2006 Sysname RM/6/RMDEBUG:OSPF TE
Process ID : 1
Area ID : 0.0.0.0
Link Id : 3.1.1.2
*Dec 20 15:01:52:194 2006 Sysname RM/6/RMDEBUG:OSPF TE
Process ID : 1
Area ID : 0.0.0.0
1.1.9 debugging ospf packet
debugging ospf [ process-id ] packet [ ack | dd | hello | request | update ] [ filter { destination | source } { acl-number | prefix ip-prefix-name } ]
undo debugging ospf packet [ ack | dd | hello | request | update ] [ filter { destination | source } { acl-number | prefix ip-prefix-name } ]
View
Default level
1: Monitor level
ack: Enables debugging for LSAck packets.
dd: Enables debugging for Database Description (DD) packets.
hello: Enables debugging for hello packets.
request: Enables debugging for LSR packets.
update: Enables debugging for LSU packets.
filter: Specifies a filtering policy.
destination: Applies the filtering policy on the destination IP address of the packets.
source: Applies the filtering policy on the source IP address of the packets.
acl-number: Number of an ACL used to filter the packets for debugging, in the range 2000 to 3999.
ip-prefix-name: Name of an IP prefix list used to filter the packets for debugging, a string of 1 to 19 characters.
Use the debugging ospf packet command to enable OSPF packet debugging.
Use the undo debugging ospf packet command to disable OSPF packet debugging.
By default, OSPF packet debugging is disabled.
If no process ID is specified, the debugging information of all the OSPF processes will be displayed.
Table 1-6 Description on the fields of the debugging ospf packet command
Ver# ver, Type: pkt-type, Length: pkt-len |
OSPF packet header information: l ver: OSPF version. At present, it is 2. l pkt-type: OSPF packet type. 1 is for Hello, 2 for DD, 3 for LSR, 4 for LSU, and 5 for LSAck. l pkt-len: OSPF packet length |
Router: rt-id, Area: area-id, Chksum: chksum |
OSPF packet header information: l rt-id: ID of the advertising router. l area-id: Area ID of the sending interface. l chksum: Checksum of the entire packet starting from the OSPF header, excluding the 64-bit authentication field. |
AuType: auth-type, Key(ascii): key |
OSPF packet header information l au-type: OSPF packet authentication type. 00 is for non-authentication, 01 for simple authentication, and 02 for MD5 authentication. l key: Authentication key. |
Net Mask: net-mask, Hello Int: hello-interval, Option: opt |
OSPF hello packet information l net-mask: Network mask of the sending interface l hello-interval: Hello interval, in seconds. l opt: Optional capabilities supported by the router. E bit means external route support, the "N" and "P" in N/P bit mean NSSA capability and Type 7 to Type 5 conversion, respectively, and L bit means the packet carries GR-related extended data. |
Rtr Priority: rt-pri, Dead Int: dead-interval, DR: ip-addr, BDR: ip-addr |
OSPF hello packet information l rt-pri: Router priority. l dead-interval: Neighbor dead interval , in seconds. l ip-addr: IP address of the DR or BDR on the interface network segment. |
Attached Neighbor: rt-id |
OSPF hello packet information rt-id: Router ID of the neighbor discovered by OSPF |
Hello: hello timer mismatch |
OSPF hello packet information Hello intervals of the router and the neighbor are different. |
Hello: dead timer mismatch |
OSPF hello packet information Dead intervals of the router and the neighbor are different. |
Hello: netmask mismatch |
OSPF hello packet information Network masks of the router and the neighbor are different. |
Hello: extern option mismatch |
OSPF hello packet information The optional capability support of the router and that of the neighbor are different. |
Extended Options(LLS Data): opt |
OSPF hello and DD packet information opt: GR-related options. LR means OOB negotiation and RS means notifying the neighbor to enter the GR (Graceful Restart) state. |
MTU:mtu-val, Option: opt, R_I_M_MS Bit: bits |
OSPF DD packet information l mtu-val: Maximum size of IP packet that can be sent through the interface without fragmentation, in bytes. It is 0 if the MTU of the DD packets is not configured as that of the sending interface. l opt: Optional capabilities supported by the router. E bit means external route support, the "N" and "P" in N/P bit mean NSSA capability and Type 7 to Type 5 conversion, respectively, and L bit means the packet carries GR-related extended data. l bits: DD packet negotiation bit. I bit means the negotiation starts, M bit means more DD packets are to be exchanged, MS bit means it is the master, and R bit means OOB negotiation begins. The value of this argument can be the combination of the above-mentioned values. |
DD SeqNumber: seq-num |
OSPF DD packet information seq-num: DD packet sequence number |
LSAType: ls-type, LinkStateId: ls-id, Advertising Rtr: rt-id |
OSPF DD, LSR, and LSAck packet information Contents of the LSAs in the LSDB described in the OSPF packet l ls-type: LSA type. 1 is for Router LSA, 2 for network LSA, 3 for net-summary LSA, 4 for ASBR-summary LSA, 5 for AS-external–LSA, 7 for NSSA LSA, and 9, 10, and 11 for Opaque LSA. l ls-id: LSA link ID. l rt-id: ID of the advertising router. |
LSA Age: ls-age, Options: ExRouting:ON/OFF |
OSPF DD and LSAck packet information l ls-age: LSA age. l ON/OFF: Indicates whether the router supports external routing. |
Length: ls-len, Seq# seq-num, CheckSum: chksum |
OSPF DD and LSAck packet information l ls-len: LSA packet length. l seq-num: LSA sequence number. l chksum: LSA checksum. |
LSACount: ls-count |
OSPF LSU packet information ls-count: Number of LSAs in the LSU packet. |
# Switch A and Switch B are interconnected over a broadcast network. Enable OSPF hello packet debugging on Switch A.
<Sysname> debugging ospf packet hello
<Sysname>
*May 10 10:50:03:687 2007 Sysname RM/6/RMDEBUG:OSPF 1: SEND Packet.
*May 10 10:50:03:774 2007 Sysname RM/6/RMDEBUG:Source Address: 150.1.1.1
*May 10 10:50:03:874 2007 Sysname RM/6/RMDEBUG:Destination Address: 224.0.0.5
*May 10 10:50:03:964 2007 Sysname RM/6/RMDEBUG:Ver# 2, Type: 1, Length: 44.
*May 10 10:50:04:84 2007 Sysname RM/6/RMDEBUG:Router: 201.1.1.1, Area: 0.0.0.0, Chksum: 39833.
*May 10 10:50:04:194 2007 Sysname RM/6/RMDEBUG:AuType: 00, Key(ascii): 0 0 0 0 0 0 0 0.
*May 10 10:50:04:315 2007 Sysname RM/6/RMDEBUG:Net Mask: 255.255.255.0, Hello Int: 10, Option: _E_.
*May 10 10:50:04:444 2007 Sysname RM/6/RMDEBUG:Rtr Priority: 1, Dead Int: 40, DR: 150.1.1.1, BDR:0.0.0.0.
1.1.10 debugging ospf spf
debugging ospf [ process-id ] spf { all | brief | intra | { asbr-summary | ase | net-summary | nssa } [ filter { acl acl-number | ip-prefix ip-prefix-name } ] }
undo debugging ospf [ process-id ] spf { all | asbr-summary | ase | brief | intra | net-summary | nssa }
View
Default level
1: Monitor level
all: Enables all the SPF scheduling and calculation debugging.
brief: Enables SPF job scheduling debugging.
intra: Enables SPF debugging for intra-area LSAs.
asbr-summary: Enables SPF debugging for ASBR-Summary LSAs.
ase: Enables SPF debugging for ASE LSAs.
net-summary: Enables SPF debugging for inter-area LSAs.
nssa: Enables SPF debugging for NSSA LSAs.
filter: Filters the output SPF debugging information.
acl acl-number: Specifies an basic ACL for the filtering.
ip-prefix ip-prefix-name: Specifies an IP prefix list for the filtering.
Use the debugging ospf spf command to enable OSPF SPF debugging.
Use the undo debugging ospf spf command to disable OSPF SPF debugging.
By default, OSPF SPF debugging is disabled.
Table 1-7 Description on the fields of the debugging ospf spf brief command
OSPF process-id |
OSPF process ID |
Schedule Event: schedule-event at X ms |
SPF schedule event schedule-event: SPF schedule event. It can be 0x80000000, 0x40000000, 0x10000000, 0x00008000, 0x00004000, 0x00000020, or 0x00000010. |
Schedule Flag: schedule-flag SPF is Scheduled |
SPF schedule flag schedule-flag: Schedule flag. It can be 0x80000000, 0x40000000, 0x20000000, 0x10000000, 0x08000000, 0x00008000, 0x00004000, 0x00002000, 0x00001000, 0x00000080, 0x00000020, or 0x00000010. |
Schedule Flag: schedule-flag SPF is Stopped |
Schedule flag indicating SPF is stopped schedule-flag: Schedule flag. It can be 0x80000000, 0x40000000, 0x20000000, 0x10000000, 0x08000000, 0x00008000, 0x00004000, 0x00002000, 0x00001000, 0x00000080, 0x00000020, or 0x00000010. |
Pre Proc: Schedule: schedule -flag |
Present SPF schedule flag schedule –flag: Schedule flag. It can be 0x80000000, 0x40000000, 0x20000000, 0x10000000, 0x08000000, 0x00008000, 0x00004000, 0x00002000, 0x00001000, 0x00000080, 0x00000020, or 0x00000010. |
Pre Proc: Running: running-flag |
Present SPF calculation flag running –flag: Running flag. It can be 0x80000000, 0x40000000, 0x20000000, 0x10000000, 0x08000000, 0x00008000, 0x00004000, 0x00002000, 0x00001000, 0x00000080, 0x00000040, 0x00000020, 0x00000008, 0x00000004, or a combination of some of these values. |
SPF Initial Schedule |
Initial SPF schedule |
Tunnel Info: Dest: dest-ip Metric: cost Metric Type: metric-type Path Type: path-type |
Tunnel information l Dest-ip: Destination IP address. l Cost: path cost. l Metric-type: Metric type. It can be Relative or Absolute. l Path-type: Path type. It can be IGP, Shortcut or Forwarding Adjacency. |
Table 1-8 Description on the fields of the debugging ospf spf intra command
Rtr-LSA link-id, adv rt-id, link count link-count |
Information of the router LSA associated with candidate nodes l link-id: Link ID of the router LSA. l rt-id: ID of the advertising router. l link-count: Number of links in the router LSA. |
Net-LSA link-id, adv rt-id, router count : rt-count |
Information of the network LSA associated with candidate nodes l link-id: Link ID of the network LSA. l rt-id: ID of the advertising router. l rt-count: Number of routers listed in the network LSA. |
link-type Link link-id, Data link-data, cost cost |
Description of each link in the router LSA l link-type: Link type. It can be P-2-P, TransNet, StubNet, or Virtual. l link-id: Link ID. l link-data: Link data. l cost: Link cost. |
Attach Router: router-id |
Neighbor described in the network LSA router-id: ID of the router. |
Drop for reason |
Reason for dropping a candidate node reason: Reason for dropping the candidate node. It can be maxage, not found neighbor, cost exceeds LSInfinity, no back link, check neighbor in SPF tree fail, in spf tree, nexthop calculation fail, no next hop, add into candidate list fail, find candidate list fail, or old vertex is better. |
Drop neighbor Rtr-Lsa link-id for reason |
Reason for dropping a candidate node (router node) l link-id: Link ID of the router LSA. l reason: Reason for dropping the node. |
Drop neighbor Net-Lsa link-id net-mask for reason |
Reason for dropping a candidate node (network node) l link-id: Link ID of the network LSA. l net-mask: Network mask in the network LSA. l reason: Reason for dropping the node. |
op-type vertex:Rtr-Lsa link-id, Cost to root cost, Nh next-hop |
Operation on the current candidate node (router node) l op-type: Type of operation to perform on the candidate node. It can be Add, Update, Remove, or Get. l link-id: Link ID of the router LSA. l cost: Cost to the root node. l next-hop: Nexthop. |
op-type vertex:Net-Lsa link-id net-mask, Cost to root cost, Nh next-hop |
Operation on the current candidate node (network node) l op-type: Type of operation to perform on the candidate node. It can be Add, Update, Remove, or Get. l link-id: Link ID of the router LSA. l net-mask: Network mask in the network LSA. l cost: Cost to the root node. l next-hop: Nexthop. |
Can’t find old route |
There is no such a route in the routing table. |
op-type path-type route dest-ip net-mask, nh next-hop, cost cost |
Operation on the routing table entry l op-type: Type of operation to perform on the candidate node. It can be Add, Update, Remove, or Get. l path-type: Route type. It can be unrecognized, intra-area, transit, stub, inter-area, ase, type1, or type2. l dest-ip: Destination IP address. l next-hop: Nexthop. l cost: Route cost. |
op-type rotue-type route, cost cost, nh next-hop |
Operation on the router route l op-type: Operation type. It can be Old, Add, or Update. l route-type: Route type. It can be ABR, ASBR, ABR/ASBR, or Rtr. l cost: Route cost. l next-hop: Nexthop. |
Stub Route: DEST: dest-addr MASK: mask-len, cost: cost |
Stub route information l dest-addr: Destination network address. l mask-len: Network mask length. l cost: Route cost. |
Table 1-9 Description on the fields of the debugging ospf spf asbr-summary command
OSPF process-id |
OSPF process ID |
New route is ip-addr, Nh next-hop, Cost cost |
Add a new route l ip-addr: IP address. l next-hop: Nexthop. l cost: Route cost. |
Table 1-10 Description on the fields of the debugging ospf spf ase command
Process(Ase) |
ASE SPF calculation is performed. |
Start (Incr ASE) |
Incremental ASE SPF calculation started. |
FULL SPF ASE Begin at bucket bucket-num |
Full ASE SPF calculation began at bucket bucket-num in the Hash table. |
FULL SPF ASE Stop at bucket bucket-num |
Full ASE SPF calculation stopped at bucket bucket-num in the Hash table. |
INCR SPF ASE Begin |
Incremental ASE SPF calculation began. |
INCR SPF ASE End |
Incremental ASE SPF calculation ended. |
LSA ID inconsistent with netmas. LSID: ls-id, Netmask: net-mask |
ASE LSA ID and network mask are inconsistent. |
MaxAge and No associated route, flush and delete ASE LSA |
Flush or delete the ASE LSAs that are aged out or have no associated routes. |
Table 1-11 Description on the fields of the debugging ospf spf net-summary command
OSPF process-id |
OSPF process ID |
Process (Inter) Area area-id |
Perform the inter-area SPF calculation in area area-id. |
SPF Start (Incr Inter) |
Incremental inter-area SPF calculation started. |
Summary LSA LSID inconsistent with netmask, Area: area-id; LSID: ls-id, NetMask: net-mask |
Summary LSA ID and network mask are inconsistent. |
NetSum-LSA is MaxAge |
Net-Summary LSA has aged out. |
Don’t calculate for reason |
Reason for not calculating network summary LSAs reason: “Self originate LSA” means the self-originated LSAs are not calculated. “Route falling into active ABR range” means the routes fall into the active ABR range. |
Table 1-12 Description on the fields of the debugging ospf spf nssa command
OSPF process-id |
OSPF process ID |
Process (Ase) |
SPF calculates external routes. |
# Switch B is connected to Switch A and Switch C respectively through broadcast networks. Enable SPF debugging for OSPF inter-area LSAs on Switch A.
<Sysname> debugging ospf ase
OSPF 1 Process (Ase)
// ASE SPF calculation started.
OSPF 1 FULL SPF ASE Begin at bucket 0
OSPF 1 New route is better
// SPF calculation started from the beginning of the Hash table.
// Output ASE SPF calculation debugging information.
1.1.11 debugging ospf timer
debugging ospf [ process-id ] timer [ lsa-generate | spf ]
undo debugging ospf [ process-id ] timer [ lsa-generate | spf ]
View
Default level
1: Monitor level
lsa-generate: Enables LSA generation timer debugging.
spf: Enables SPF calculation timer debugging.
Use the debugging ospf timer command to enable OSPF timer debugging.
Use the undo debugging ospf timer command to disable OSPF timer debugging.
By default, OSPF timer debugging is disabled.
# Switch A and Switch B are interconnected over a broadcast network. On Switch A, enable OSPF timer debugging and restart OSPF process 1.
<Sysname> debugging ospf timer
<Sysname>reset ospf 1 process
Warning : Reset OSPF process? [Y/N]:y
%Sep 18 11:21:04:612 2006 R1 RM/3/RMLOG:OSPF-NBRCHANGE: Process 1, Neighbour 150.1.1.2(Vlan-interface 100) from Full to Down
OSPF 1 reset SPF TIMER,timeout value is 5000 ms
// Reset the SPF calculation timer; the timeout value is 5000 milliseconds.
OSPF 1 delete SPF TIMER R1 RM/6/RMDEBUG:
// OSPF deleted the SPF calculation timer.
OSPF 1 delete MIN LS TIMER R1 RM/6/RMDEBUG:
// OSPF deleted the LSA generation timer.
OSPF 1 create SPF TIMER,timeout value is 5000 ms
// OSPF created the SPF calculation timer with a timeout value of 5000 milliseconds
OSPF 1 create MIN LS TIMER,timeout value is 5000 ms
// OSPF created the LSA generation timer with a timeout time of 5000 milliseconds
OSPF 1 reset MIN LS TIMER,timeout value is 714 ms
// OSPF reset the LSA generation timer with a timeout value of 714 milliseconds.
OSPF 1 reset MIN LS TIMER,timeout value is 5000 ms
%Sep 18 11:21:13:908 2006 R1 RM/3/RMLOG:OSPF-NBRCHANGE: Process 1, Neighbour 150.1.1.2(Vlan-interface 100) from Loading to Full
OSPF 1 reset MIN LS TIMER,timeout value is 20 ms
1.1.12 default
default { cost cost | limit limit | tag tag | type type } *
undo default { cost | limit | tag | type } *
View
OSPF view
Default Level
2: System level
cost: Default cost for redistributed routes.
limit: Default upper limit of routes to be redistributed per time.
tag: Default tag for redistributed routes.
type: Default type for redistributed routes.
Use the default command to configure default parameters for redistributed routes: cost, route type (Type1 or Type2), tag, and the upper limit.
Use the undo default command to restore the default.
The cost, route type, tag, and the upper limit are 1, 2, 1 and 1000 by default.
Related commands: import-route.
# Configure default parameters cost as 10, upper limit as 20000, tag as 100 and type as 2 for redistributed external routes.
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 limit 20000 tag 100 type 2
default-cost cost
undo default-cost
View
OSPF area view
Default Level
2: System level
cost: Cost for the default route advertised to the Stub or NSSA area.
Use the default-cost command to specify a cost for the default route advertised to the stub or NSSA area.
Use the undo default-cost command to restore the default.
This command is only applicable to the ABR of a stub area or the ABR/ASBR of an NSSA area.
Related commands: stub, nssa.
# Configure Area 1 as a stub area, and specify the cost of the default route advertised to the stub area as 20.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
default-route-advertise [ [ always | cost cost | type type | route-policy route-policy-name ] * | summary cost cost ]
undo default-route-advertise
View
OSPF view
Default Level
2: System level
always: If the router has no default route configured, this keyword generates a default external route in an ASE LSA into the OSPF routing domain. Without this keyword included, the command cannot generate a default route unless the router has it configured.
cost cost: Specifies a cost for the default route. The default is 1.
type type: Specifies a type for the ASE LSA. The default is 2.
route-policy route-policy-name: Specifies a route policy name. If the default route matches the specified route policy, the route policy affects some value in the ASE LSA.
summary: Advertises the Type-3 summary LSA of the specified default route.
Use the default-route-advertise command to generate a default route into the OSPF routing domain.
Use the undo default-route-advertise command to disable OSPF from distributing a default external route.
By default, no default route is distributed.
Using the import-route command cannot redistribute a default route. To do so, use the default-route-advertise command. If no default route is configured, use the default-route-advertise always command to generate a default route in a Type-5 LSA.
The default-route-advertise summary cost command is applicable only to VPNs, and the default route is redistributed in a Type-3 LSA. The PE device advertises the redistributed default route to the CE device.
# Generate a default route in an ASE LSA into the OSPF routing domain.
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
description description
View
OSPF view/OSPF area view
Default Level
2: System level
description: Describes the OSPF process in OSPF view, or describes the OSPF area in OSPF area view.
Use the description command to configure a description for an OSPF process or area.
Use the undo description command to remove the description.
No description is configured by default.
Use of this command is only for identification of an OSPF process or area. The description has no special meaning.
# Configure a description for the OSPF process 100 as “abc”.
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# Configure a description for the OSPF area0 as “bone area”.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
1.1.16 display ospf abr-asbr
display ospf [ process-id ] abr-asbr
View
Default Level
1: Monitor level
Use the display ospf abr-asbr command to display information about ABR/ASBR.
If no process ID is specified, ABR/ASBR information of all OSPF processes is displayed.
If you use this command on devices in a stub area, no ASBR information is displayed.
# Display information about ABR/ASBR.
<Sysname> display ospf abr-asbr
OSPF Process 1 with Router ID 192.168.1.2
Routing Table to ABR and ASBR
Type Destination Area Cost Nexthop RtType
Intra 192.168.1.1 0.0.0.0 1562 192.168.1.1 ABR
Table 1-13 Description on the fields of the display ospf abr-asbr command
Type |
Intra-area router or Inter-area router |
Destination |
Router ID of an ABR/ASBR |
Area |
ID of the area of the next hop |
Cost |
Cost from the device to the ABR/ASBR |
Nexthop |
Next hop address |
RtType |
Device type: ABR, ASBR |
display ospf [ process-id ] asbr-summary [ ip-address { mask | mask-length } ]
View
Default Level
1: Monitor level
ip-address: Matched IP address, in dotted decimal format.
mask: IP address mask, in dotted decimal format.
Use the display ospf asbr-summary command to display information about the redistributed routes that are summarized.
If no OSPF process is specified, related information of all OSPF processes is displayed.
If no IP address is specified, information about all summarized redistributed routes will be displayed.
Related commands: asbr-summary.
# Display information about all summarized redistributed routes.
<Sysname> display ospf asbr-summary
Summary Addresses
Total Summary Address Count: 1
Summary Address
Net : 30.1.0.0
Mask : 255.255.0.0
Tag : 20
Status : Advertise
Cost : 10 (Configured)
The Count of Route is : 2
Destination Net Mask Proto Process Type Metric
30.1.2.0 255.255.255.0 OSPF 1 2 1
30.1.1.0 255.255.255.0 OSPF 1 2 1
Table 1-14 Description on the fields of the display ospf asbr-summary command
Total Summary Address Count |
Total summary route number |
Net |
The address of the summary route |
Mask |
The mask of the summary route address |
Tag |
The tag of the summary route |
Status |
The advertisement status of the summary route |
Cost |
The cost to the summary route |
The Count of Route |
The count of routes that are summarized |
Destination |
Destination address of a summarized route |
Net Mask |
Network mask of a summarized route |
Proto |
Routing protocol |
Process |
Process ID of routing protocol |
Type |
Type of a summarized route |
Metric |
Metric of a summarized route |
1.1.18 display ospf brief
display ospf [ process-id ] brief
View
Default Level
1: Monitor level
Use the display ospf brief command to display OSPF brief information. If no OSPF process is specified, brief information of all OSPF processes is displayed.
# Display OSPF brief information.
<Sysname> display ospf brief
OSPF Protocol Information
RouterID: 192.168.1.2 Border Router: NSSA
Route Tag: 0
Applications Supported: MPLS Traffic-Engineering
SPF-schedule-interval: 5 0 5000
LSA generation interval: 5 0 5000
LSA arrival interval: 1000
Default ASE Parameter: Metric: 1 Tag: 1 Type: 2
Route Preference: 10
ASE Route Preference: 150
SPF Computation Count: 22
RFC 1583 Compatible
Area Count: 1 Nssa Area Count: 1
ExChange/Loading Neighbors: 0
Area: 0.0.0.1 (MPLS TE not enabled)
Authtype: None Area flag: NSSA
SPF Scheduled Count: 5
Interface: 192.168.1.2 (vlan-interface 12)
Cost: 1 State: DR Type: Broadcast MTU: 1500
Priority: 1
Designated Router: 192.168.1.2
Backup Designated Router: 192.168.1.1
Timers: Hello 10 , Dead 40 , Poll 40 , Retransmit 5 , Transmit Delay 1
Table 1-15 Description on the fields of the display ospf brief command
RouterID |
The current router ID |
Border Router |
An ABR, ASBR or NSSA ABR |
Route Tag |
The tag of redistributed routes |
Multi-VPN-Instance is not enabled |
The current OSPF process does not support multi-VPN-instance. |
Applications Supported |
Applications supported |
SPF-schedule-interval |
Interval for SPF calculation |
LSA generation interval |
LSA arrival interval |
The minimum LSA repeat arrival interval |
Default ASE Parameter |
Default ASE Parameter: metric, tag, route type. |
Route Preference |
Internal route priority |
ASE Route Preference |
External route priority |
SPF Computation count |
The total number of routes calculated by SPF |
RFC1583 Compatible |
Compatible with routing rules defined in RFC1583 |
Area Count |
Area number of the current process |
Nssa Area Count |
NSSA area number of the current process |
ExChange/Loading Neighbors |
Neighbors in ExChange/Loading state |
Area |
Area ID in the IP address format |
Authtype |
Authentication type of the area: Non-authentication, simple authentication, or MD5 authentication |
Area flag |
The type of the area |
SPF scheduled Count |
SPF calculation count |
IP address of the interface |
Cost |
Interface cost |
State |
Interface state |
Type |
Interface network type |
MTU |
Interface MTU |
Priority |
Device priority |
Designated Router |
The Designated Router |
Backup Designated Router |
The Backup Designated Router |
Timers |
OSPF timers: l Hello means the interval at which the interface transmits hello packets. l Dead means the dead timer of the neighbor. l Poll means the interval at which the interface transmits polling packets. l Retransmit means the LSA retransmit interval of the interface |
Transmit Delay |
LSA transmit delay on the interface |
display ospf [ process-id ] cumulative
View
Default Level
1: Monitor level
Use the display ospf cumulative command to display OSPF statistics.
Use of this command is helpful for troubleshooting.
# Display OSPF statistics.
<Sysname> display ospf cumulative
Cumulations
IO Statistics
Type Input Output
Hello 808 809
DB Description 4 3
Link-State Req 1 1
Link-State Update 12 18
Link-State Ack 18 11
LSAs originated by this router
Router: 6
Network: 0
Sum-Net: 0
Sum-Asbr: 0
External: 1
NSSA: 0
Opq-Link: 0
Opq-Area: 0
Opq-As: 0
LSAs Originated: 7 LSAs Received: 15
Routing Table:
Intra Area: 1 Inter Area: 1 ASE: 0
Table 1-16 Description on the fields of the display ospf cumulative command
IO statistics |
Statistics about inbound/outbound packets and LSAs |
Type |
OSPF packet type |
Input |
Packets received |
Output |
Packets sent |
Hello |
Hell packet |
DB Description |
Database Description packet |
Link-State Req |
Link-State Request packet |
Link-State Update |
Link-State Update packet |
Link-State Ack |
Link-State Acknowledge packet |
LSAs originated by this router |
LSAs originated by this device |
Router |
Type-1 LSA |
Network |
Type-2 LSA |
Sum-Net |
Type-3 LSA |
Sum-Asbr |
Type-4 LSA |
External |
Type-5 LSA |
NSSA |
Type-7 LSA |
Opq-Link |
Type-9 LSA |
Opq-Area |
Type-10 LSA |
Opq-As |
Type-11 LSA |
LSA originated |
LSA originated |
LSA Received |
LSA received |
Routing Table |
Routing table |
Intra Area |
Intraarea route number |
Inter Area |
Interarea route number |
ASE/NSSA |
ASE/NSSA route number |
1.1.20 display ospf error
display ospf [ process-id ] error
View
Default Level
1: Monitor level
Use the display ospf error command to display OSPF error information.
If no process is specified, OSPF error information of all OSPF processes is displayed.
# Display OSPF error information.
<Sysname> display ospf error
OSPF Process 1 with Router ID 192.168.80.100
OSPF Packet Error Statistics
0 : OSPF Router ID confusion 0 : OSPF bad packet
0 : OSPF bad version 0 : OSPF bad checksum
0 : OSPF bad area ID 0 : OSPF drop on unnumber interface
0 : OSPF bad virtual link 0 : OSPF bad authentication type
0 : OSPF bad authentication key 0 : OSPF packet too small
0 : OSPF Neighbor state low 0 : OSPF transmit error
0 : OSPF interface down 0 : OSPF unknown neighbor
0 : HELLO: Netmask mismatch 0 : HELLO: Hello timer mismatch
0 : HELLO: Dead timer mismatch 0 : HELLO: Extern option mismatch
0 : HELLO: NBMA neighbor unknown 0 : DD: MTU option mismatch
0 : DD: Unknown LSA type 0 : DD: Extern option mismatch
0 : LS ACK: Bad ack 0 : LS ACK: Unknown LSA type
0 : LS REQ: Empty request 0 : LS REQ: Bad request
0 : LS UPD: LSA checksum bad 0 : LS UPD: Received less recent LSA
0 : LS UPD: Unknown LSA type
Table 1-17 Description on the fields of the display ospf error command
OSPF Router ID confusion |
Packets with duplicate route ID |
OSPF bad packet |
Packets illegal |
OSPF bad version |
Packets with wrong version |
OSPF bad checksum |
Packets with wrong checksum |
OSPF bad area ID |
Packets with invalid area ID |
OSPF drop on unnumber interface |
Packets dropped on the unnumbered interface |
OSPF bad virtual link |
Packets on wrong virtual links |
OSPF bad authentication type |
Packets with invalid authentication type |
OSPF bad authentication key |
Packets with invalid authentication key |
OSPF packet too small |
Packets too small in length |
OSPF Neighbor state low |
Packets received in low neighbor state |
OSPF transmit error |
Packets with error occurred when being transmitted |
OSPF interface down |
Shutdown times of the interface |
OSPF unknown neighbor |
Packets received from unknown neighbors |
HELLO: Netmask mismatch |
Hello packets with mask mismatch |
HELLO: Hello timer mismatch |
Hello packets with hello timer mismatch |
HELLO: Dead timer mismatch |
Hello packets with dead timer mismatch |
HELLO: Extern option mismatch |
Hello packets with option field mismatch |
HELLO: NBMA neighbor unknown |
Hello packets received from unknown NBMA neighbors |
DD: MTU option mismatch |
DD packets with MTU mismatch |
DD: Unknown LSA type |
DD packets with unknown LSA type |
DD: Extern option mismatch |
DD packets with option field mismatch |
LS ACK: Bad ack |
LSAck packets for LSU packets error acknowledgement |
LS ACK: Unknown LSA type |
LSAck packets with unknown LSA type |
LS REQ: Empty request |
LSR packets with no request information |
LS REQ: Bad request |
LSR packets with wrong request |
LS UPD: LSA checksum bad |
LSU packets with wrong LSA checksum |
LS UPD: Received less recent LSA |
LSU packets without latest LSA |
LS UPD: Unknown LSA type |
LSU packets with unknown LSA type |
1.1.21 display ospf interface
display ospf [ process-id ] interface [ all | interface-type interface-number ]
View
Default Level
1: Monitor level
all: Display OSPF information of all interfaces.
interface-type interface-number: Interface type and interface number.
Use the display ospf interface command to display OSPF interface information.
If no OSPF process is specified, OSPF interface information of all OSPF processes is displayed.
# Display OSPF interface information.
<Sysname> display ospf interface
OSPF Process 1 with Router ID 192.168.1.1
Interfaces
Area: 0.0.0.0
IP Address Type State Cost Pri DR BDR
192.168.1.1 PTP P-2-P 1562 1 0.0.0.0 0.0.0.0
Area: 0.0.0.1
172.16.0.1 Broadcast DR 1 1 172.16.0.1 0.0.0.0
Table 1-18 Description on the fields of the display ospf interface command
Area |
The ID of the area the interface attached to |
IP address |
Interface IP address (regardless of TE enabled or not) |
Type |
Interface network type: PTP, PTMP, Broadcast, or NBMA |
State |
Interface state defined by interface state machine: DOWN, Waiting, p-2-p, DR, BDR, or DROther |
Cost |
Interface cost |
Pri |
DR priority |
DR |
The DR on the interface’s network segment |
BDR |
The BDR on the interface’s network segment |
1.1.22 display ospf lsdb
display ospf [ process-id ] lsdb [ brief | [ { ase | router | network | summary | asbr | nssa | opaque-link | opaque-area | opaque-as } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ]
View
Default Level
1: Monitor level
brief: Displays brief LSDB information.
ase: Displays Type5 LSA (AS External LSA) information in the LSDB.
router: Displays Type1 LSA (Router LSA) information in the LSDB.
network: Displays Type2 LSA (Network LSA) information in the LSDB.
summary: Displays Type3 LSA (Network Summary LSA) information in the LSDB.
asbr: Displays Type4 LSA (ASBR Summary LSA) information in the LSDB.
nssa: Displays Type7 LSA (NSSA External LSA) information in the LSDB.
opaque-link: Displays Type-9 LSA (Opaque-link LSA) information in the LSDB.
opaque-area: Displays Type-10 LSA (Opaque-area LSA) information in the LSDB.
opaque-as: Displays Type-11 LSA (Opaque-AS LSA) information in the LSDB.
link-state-id: Link state ID, in the IP address format.
originate-router advertising-router-id: Displays information about LSAs originated by the router.
self-originate: Displays information about self-originated LSAs.
Use the display ospf lsdb command to display LSDB information.
If no OSPF process is specified, LSDB information of all OSPF processes is displayed.
# Display OSPF LSDB information.
<Sysname> display ospf lsdb
OSPF Process 1 with Router ID 192.168.0.1
Link State Database
Area: 0.0.0.0
Type LinkState ID AdvRouter Age Len Sequence Metric
Router 192.168.0.2 192.168.0.2 474 36 80000004 0
Router 192.168.0.1 192.168.0.1 21 36 80000009 0
Network 192.168.0.1 192.168.0.1 321 32 80000003 0
Sum-Net 192.168.1.0 192.168.0.1 321 28 80000002 1
Sum-Net 192.168.2.0 192.168.0.2 474 28 80000002 1
Area: 0.0.0.1
Router 192.168.0.1 192.168.0.1 21 36 80000005 0
Sum-Net 192.168.2.0 192.168.0.1 321 28 80000002 2
Sum-Net 192.168.0.0 192.168.0.1 321 28 80000002 1
Table 1-19 Description on the fields of the display ospf lsdb command
Area |
Area |
Type |
LSA type |
LinkState ID |
LSA link state ID |
AdvRouter |
The router that advertised the LSA |
Age |
Aging time of the LSA |
Len |
Length of the LSA |
Sequence |
Sequence number of the LSA |
Metric |
Cost of the LSA |
# Display Type2 LSA (Network LSA) information in the LSDB.
[Sysname] display ospf 1 lsdb network
Area: 0.0.0.0
Link State Database
Type : Network
LS ID : 192.168.0.2
Adv Rtr : 192.168.2.1
LS Age : 922
Len : 32
Options : E
Seq# : 80000003
Chksum : 0x8d1b
Net Mask : 255.255.255.0
Attached Router 192.168.1.1
Attached Router 192.168.2.1
Area: 0.0.0.1
Link State Database
Type : Network
LS ID : 192.168.1.2
Adv Rtr : 192.168.1.2
LS Age : 782
Len : 32
Options : NP
Seq# : 80000003
Chksum : 0x2a77
Attached Router 192.168.1.2
Table 1-20 Description on the fields of the display ospf 1 lsdb network command
Type |
LSA type |
LS ID |
DR IP address |
Adv Rtr |
Router that advertised the LSA |
LS Age |
LSA age time |
Len |
LSA length |
Options |
LSA options |
Seq# |
LSA sequence number |
Chksum |
LSA checksum |
Net Mask |
Network mask |
Attached Router |
Router ID of the device that established adjacency with the DR, and ID of the DR itself |
1.1.23 display ospf nexthop
View
Default Level
1: Monitor level
Use the display ospf nexthop command to display OSPF next hop information.
If no OSPF process is specified, next hop information of all OSPF processes is displayed.
# Display OSPF next hop information.
<Sysname> display ospf nexthop
Routing Nexthop Information
Next Hops:
Address Refcount IntfAddr Intf Name
192.168.0.1 1 192.168.0.1 vlan-interface12
192.168.0.2 1 192.168.0.1 vlan-interface12
192.168.1.1 1 192.168.1.1 vlan-interface14
Table 1-21 Description on the fields of the display ospf nexthop command
Next hops |
Information about Next hops |
Address |
Next hop address |
Refcount |
Reference count |
IntfAddr |
Outbound interface address |
Intf Name |
Outbound interface name |
1.1.24 display ospf peer
display ospf [ process-id ] peer [ verbose | [ interface-type interface-number ] [ neighbor-id ] ]
View
Default Level
1: Monitor level
interface-type interface-number: Interface type and number
verbose: Displays detailed neighbor information.
neighbor-id: Neighbor router ID.
Use the display ospf peer command to display information about OSPF neighbors.
Note that:
If no OSPF process is specified, OSPF neighbor information of all OSPF processes is displayed.
If an interface is specified, the neighbor on the interface is displayed.
If a neighbor ID is specified, detailed information about the neighbor is displayed,
If neither interface nor neighbor ID is specified, brief information about neighbors of the specified OSPF process or all OSPF processes is displayed.
# Display detailed OSPF neighbor information.
<Sysname> display ospf peer verbose
Router ID: 47.47.47.47 Address: 1.1.5.5 GR State: Normal
State: Full Mode: Nbr is Master Priority: 1
DR: 1.1.5.5 BDR: 1.1.5.6 MTU: 0
Dead timer due in 33 sec
Neighbor is up for 93:12:38
Router ID: 192.168.1.48 Address: 1.1.3.2 GR State: Normal
DR: 1.1.3.1 BDR: 1.1.3.2 MTU: 0
Dead timer due in 31 sec
Neighbor is up for 93:10:45
Neighbor state change count: 5
Table 1-22 Description on the fields of the display ospf peer verbose command
Area |
Area neighbors attached to |
Interface connected to neighbor |
Router ID |
Neighbor router ID |
Address |
Neighbor router address |
GR State |
GR state |
State |
Neighbor state: Down, Init, Attempt, 2-Way, Exstart, Exchange, Loading or Full |
Mode |
Neighbor mode for DD exchange: Master or Slave |
Priority |
Router priority |
DR |
BDR |
MTU |
Interface MTU |
Dead timer due in 33 sec |
Dead timer times out in 33 seconds |
Neighbor is up for 93:12:38 |
The neighbor has been up for 93:12:38 |
Authentication Sequence |
Authentication sequence number |
Neighbor state change count |
Counts of neighbor state changes |
# Display brief OSPF neighbor information.
Neighbor Brief Information
Area: 0.0.0.0
Router ID Address Pri Dead-Time Interface State
47.47.47.47 1.1.5.5 1 40 Vlan600 Full/BDR
Area: 0.0.0.2
192.168.1.48 1.1.3.2 1 38 Vlan900 Full/DR
Table 1-23 Description on the fields of the display ospf peer command
Area |
Area of neighbors |
Router ID |
Address |
Neighbor interface address |
Pri |
Router priority |
Dead time(s) |
Dead interval remained |
The Interface connected to neighbors |
State |
View
Default Level
1: Monitor level
Use the display ospf peer statistics command to display OSPF neighbor statistics.
If no OSPF process is specified, OSPF neighbor statistics of all OSPF processes is displayed.
# Display OSPF neighbor statistics.
<Sysname> display ospf peer statistics
Neighbor Statistics
Area ID Down Attempt Init 2-Way ExStart Exchange Loading Full Total
0.0.0.1 0 0 0 0 0 0 0 1 1
Total 0 0 0 0 0 0 0 1 1
Table 1-24 Description on the fields of the display ospf peer statistics command
Area ID |
Area ID |
Down |
Under this state, neighbor initial state, the router has not received any information from a neighboring router for a period of time. |
Attempt |
Available only in an NBMA network, such as Frame Relay, X.25 or ATM. Under this state, the OSPF router has not received any information from a neighbor for a period but can send Hello packets with a longer interval to keep neighbor relationship. |
Init |
Under this state, the router received a Hello packet from a neighbor but the packet contains no IP address of itself, so mutual communication is not established. |
2-Way |
Indicates mutual communication between the router and its neighbor is available. DR/BDR election is finished under this state (or higher). |
ExStart |
Under this state, the router decides on sequence numbers of DD packets, to guarantee the neighbor always gets the latest link state information. |
Exchange |
Under this state, the router exchanges routing information with the neighbor. |
Loading |
Under this state, the router requests the neighbor for needed LSAs. |
Full |
Indicates LSDB synchronization has been accomplished between neighbors. |
Total |
Total number of neighbors under the same state |
1.1.26 display ospf request-queue
View
Default Level
1: Monitor level
interface-type interface-number: Interface type and number.
neighbor-id: Neighbor’s router ID.
Use the display ospf request-queue command to display OSPF request queue information.
If no OSPF process is specified, the OSPF request queue information of all OSPF processes is displayed.
# Display OSPF request queue information.
<Sysname> display ospf request-queue
OSPF Request List
The Router's Neighbor is Router ID 2.2.2.2 Address 10.1.1.2
Interface 10.1.1.1 Area 0.0.0.0
Request list:
Type LinkState ID AdvRouter Sequence Age
Router 2.2.2.2 1.1.1.1 80000004 1
Network 192.168.0.1 1.1.1.1 80000003 1
Sum-Net 192.168.1.0 1.1.1.1 80000002 2
Table 1-25 Description on the fields of the display ospf request queue command
The Router's Neighbor is Router ID |
Address |
Neighbor interface IP address |
Local interface IP address |
Area |
Area ID |
Request list |
Request list information |
Type |
LSA type |
LinkState ID |
Link state ID |
AdvRouter |
Sequence |
Age |
LSA age time |
1.1.27 display ospf retrans-queue
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface.
Use the display ospf retrans-queue command to display retransmission queue information.
If no OSPF process is specified, the retransmission queue information of all OSPF processes is displayed.
# Display OSPF retransmission queue information.
<Sysname> display ospf retrans-queue
OSPF Retransmit List
Retransmit list:
Router 2.2.2.2 2.2.2.2 80000004 1
Network 12.18.0.1 2.2.2.2 80000003 1
Sum-Net 12.18.1.0 2.2.2.2 80000002 2
Table 1-26 Description on the fields of the display ospf retrans-queue command
Address |
Interface address of the router |
Area |
Area ID |
Retrans List |
Retransmit list |
Type |
LSA type |
LinkState ID |
Link state ID |
AdvRouter |
Sequence |
Age |
LSA age time |
1.1.28 display ospf routing
display ospf [ process-id ] routing [ interface interface-type interface-number ] [ nexthop nexthop-address ]
View
Default Level
1: Monitor level
process-id: OSPF process ID, in the range 1 to 65535.
interface interface-type interface-number: Displays OSPF routing information advertised via the interface.
nexthop nexthop-address: Displays OSPF routing information with the specified next hop.
Use the display ospf routing command to display the OSPF routing information.
If no OSPF process is specified, routing information of all OSPF processes is displayed.
# Display OSPF routing information.
<Sysname> display ospf routing
Routing Tables
Routing for Network
Destination Cost Type NextHop AdvRouter Area
192.168.1.0/24 1562 stub 192.168.1.2 192.168.1.2 0.0.0.0
172.16.0.0/16 1563 Inter 192.168.1.1 192.168.1.1 0.0.0.0
Total Nets: 2
Intra Area: 1 Inter Area: 1 ASE: 0 NSSA: 0
Table 1-27 Description on the fields of the display ospf routing command
Destination |
Destination network |
Cost |
Cost to destination |
Type |
Route type: intra-area, Transit, stub, Inter-area, Type1 External, Type2 External. |
NextHop |
Next hop address |
AdvRouter |
Advertising router |
Area |
Area ID |
Total Nets |
Total routes |
Intra Area |
Total intraarea routes |
Inter Area |
Total interarea routes |
ASE |
Total ASE routes |
NSSA |
Total NSSA routes |
1.1.29 display ospf vlink
View
Default Level
1: Monitor level
Use the display ospf vlink command to display OSPF virtual link information.
If no OSPF process is specified, the OSPF virtual link information of all OSPF processes is displayed.
# Display OSPF virtual link information.
<Sysname> display ospf vlink
Virtual Links
Virtual-link Neighbor-ID -> 2.2.2.2, Neighbor-State: Full
Interface: 10.1.2.1 (vlan-interface763)
Cost: 1562 State: P-2-P Type: Virtual
Transit Area: 0.0.0.1
Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
Table 1-28 Description on the fields of the display ospf vlink command
Virtual-link Neighbor-id |
ID of neighbor connected to the router via the virtual link |
Neighbor-State |
Neighbor State: Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, Full. |
Local interface’s IP address and name of the virtual link |
Cost |
Interface route cost |
State |
Interface state |
Type |
Type: virtual link |
Transit Area |
Transit area ID if the interface attached to a virtual link |
Timers |
Values of timers: Hello, Dead, Poll (NBMA), Retransmit, and Interface transmit delay |
1.1.30 enable log
enable log [ config | error | state ]
undo enable log [ config | error | state ]
View
OSPF view
Default Level
2: System level
config: Enables configuration logging.
error: Enables error logging.
state: Enables state logging.
Use the enable command to enable specified OSPF logging.
Use the undo enable command to disable specified logging.
OSPF logging is disabled by default.
If no keyword is specified, all logging is enabled.
# Enable OSPF logging.
[Sysname] ospf 100
[Sysname-ospf-100] enable log
1.1.31 filter
filter { acl-number | ip-prefix ip-prefix-name } { import | export }
undo filter { import | export }
View
OSPF area view
Default Level
2: System level
acl-number: ACL number.
ip-prefix-name: IP prefix list name.
import: Filters incoming LSAs.
export: Filters outgoing LSAs.
Use the filter command to configure incoming/outgoing Summary LSAs filtering on an ABR.
Use the undo filter command to disable Summary LSA filtering.
By default, Summary LSAs filtering is disabled.
& Note:
This command is only available on an ABR.
# Apply IP prefix list “my-prefix-list” to filter inbound Type-3 LSAs, and ACL 2000 to filter outbound Type-3 LSAs in OSPF area 1.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] filter ip-prefix my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
1.1.32 filter-policy export (OSPF view)
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
View
OSPF view
Default Level
2: System level
protocol: Filters redistributed routes from the protocol. Protocols include direct, static, rip, ospf, isis or bgp. If no protocol is specified, all redistributed routes are filtered.
process-id: Process ID, which is required when the protocol is rip, ospf or isis.
Use the filter-policy export command to configure the filtering of redistributed routes.
Use the undo filter-policy export command to disable such filtering.
By default, filtering of redistributed routes is not configured.
You can use this command to filter redistributed routes as needed.
# Filter redistributed routes using ACL 2000.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
1.1.33 filter-policy import (OSPF view)
filter-policy { acl-number | ip-prefix ip-prefix-name | gateway ip-prefix-name } import
undo filter-policy import
View
OSPF view
Default Level
2: System level
acl-number: Number of an ACL used to filter incoming routes.
ip-prefix-name: Name of an IP address prefix list used to filter incoming routes.
gateway ip-prefix-name: Name of an IP address prefix list used to filter routes received from the specified neighbor.
Use the filter-policy import command to configure the filtering of incoming routes.
Use the undo filter-policy import command to disable such filtering.
By default, no filtering of incoming routes is configured.
You can use the command to filter incoming routes as needed.
# Filter incoming routes using ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
1.1.34 host-advertise
host-advertise ip-address cost
undo host-advertise ip-address
View
OSPF area view
Default Level
2: System level
ip-address: IP address of a host
cost: Cost of the host route.
Use the host-advertise command to advertise a host route.
Use the undo host-advertise command to remove a host route.
No host route is configured by default.
# Configure host route 1.1.1.1 and specify cost 100 for it.
[Sysname] ospf 100
[Sysname] area 0
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
1.1.35 import-route (OSPF view)
import-route protocol [ process-id | allow-ibgp ] [ cost cost | type type | tag tag | route-policy route-policy-name ]*
undo import-route protocol [ process-id ]
View
OSPF view
Default Level
2: System level
protocol: Redistributes routes from the protocol, which can be direct, static, rip, ospf, isis or bgp.
process-id: Process ID, which is optional when the protocol is rip, ospf or isis, in the range 1 to 65535.
allow-ibgp: Allows to redistribute IBGP routes; optional only when the protocol is bgp.
cost cost: Specifies a route cost. The default is 1.
type type: Specifies a cost type. The default is 2.
tag tag : Specifies a tag for external LSAs. The default is 1.
route-policy: Specifies a route policy to redistribute qualified routes only.
route-policy-name: Route policy name, a string of 1 to 19 characters.
Use the import-route command to redistribute routes from another protocol.
Use the undo import-route command to disable route redistribution from a protocol.
Route redistribution from another protocol is not configured by default.
OSPF prioritize routes as follows:
l Intra-area route
l Inter-area route
l Type1 External route
l Type2 External route
An intraarea route is a route in an OSPF area. An interarea route is between any two OSPF areas. Both of them are internal routes.
An external route is a route to a destination outside the OSPF AS.
A Type1 external route is an IGP route, such as RIP or STATIC, which has high reliability and whose cost is comparable with the cost of OSPF internal routes: Cost from an OSPF router to a Type1 external route’s destination= Cost from the device to the corresponding ASBR+ Cost from the ASBR to the external route’s destination.
A Type2 external route is an EGP route, which has low credibility, so OSPF considers the cost from ASBR to a Type2 external route is much bigger than the cost from the ASBR to an OSPF internal router. Therefore, Cost from an internal router to a Type2 external route=Cost from the ASBR to the Type2 external route.
# Redistribute routes from RIP process 40 and specify the type as type2, tag as 33, and cost as 50 for redistributed routes.
[Sysname> ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
1.1.36 log-peer-change
log-peer-change
undo log-peer-change
View
OSPF view
Default Level
2: System level
None
Use the log-peer-change command to enable the logging on OSPF neighbor state changes.
Use the undo log-peer-change command to disable the logging.
The logging is enabled by default.
With this feature enabled, information about neighbor state changes is display on the terminal until the feature is disabled.
# Disable the logging on neighbor state changes of OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
1.1.37 lsa-arrival-interval
lsa-arrival-interval interval
undo lsa-arrival-interval
View
OSPF view
Default Level
2: System level
interval: Minimum interval between two received identical LSAs in milliseconds.
Use the lsa-arrival-interval command to specify the minimum interval between two identical received LSAs.
Use the undo lsa-arrival-interval command to restore the default.
The interval defaults to 1000 milliseconds.
If an LSA that has the same LSA type, LS ID, originating router ID with the previous LSA is received within the interval, the LSA will be discarded. This feature helps you protect routers and bandwidth from being over-consumed due to frequent network changes.
It is recommended the interval set by the lsa-arrival-interval command is smaller or equal to the minimum-interval set by the lsa-generation-interval command.
Related commands: lsa-generation-interval.
# Set the LSA minimum repeat arrival interval to 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-arrival-interval 200
1.1.38 lsa-generation-interval
lsa-generation-interval maximum-interval [ initial-interval [ incremental-interval ] ]
undo lsa-generation-interval
View
OSPF view
Default Level
2: System level
maximum-interval: Maximum LSA generation interval in seconds.
initial-interval: Minimum LSA generation interval in milliseconds. The default is 0.
incremental-interval: LSA generation incremental interval in milliseconds. The default is 5000 milliseconds.
Use the lsa-generation-interval command to configure the OSPF LSA generation interval.
Use the undo lsa-generation-interval command to restore the default.
The LSA generation interval defaults to 5 seconds.
With this command configured, when network changes are not frequent, an LSA is generated at the initial-interval. If network changes become frequent, LSA generation interval is incremented by a specified value each time a generation happens, up to the maximum-interval.
Related commands: lsa-arrival-interval.
# Configure the LSA generation maximum interval as 2 seconds, minimum interval as 100 milliseconds and incremental interval as 100 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
1.1.39 lsdb-overflow-limit
lsdb-overflow-limit number
undo lsdb-overflow-limit
View
OSPF view
Default Level
2: System level
number: Upper limit of external LSAs in the LSDB.
Use the lsdb-overflow-limit command to specify the upper limit of external LSAs in the LSDB.
Use the undo lsdb-overflow-limit command to restore the default.
The upper limit is unlimited by default.
# Specify the upper limit of external LSAs as 400000.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
1.1.40 maximum load-balancing (OSPF view)
maximum load-balancing maximum
undo maximum load-balancing
View
OSPF view
Default Level
2: System level
maximum: Maximum number of equal cost routes for load balancing.
Use the maximum load-balancing command to specify the maximum number of equal cost routes for load balancing.
Use the undo maximum load-balancing command to restore the default.
The default number is 8.
# Specify the maximum number of equal cost routes for load balancing as 2.
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
1.1.41 maximum-routes
maximum-routes { external | inter | intra } number
undo maximum-routes { external | inter | intra }
View
OSPF view
Default Level
2: System level
number: Maximum route number.
external: Specifies the maximum number of external routes.
inter: Specifies the maximum number of interarea routes.
intra: Specifies the maximum number of intraarea routes.
Use the maximum-routes command to specify the maximum route number of a specified type: interarea, intraarea, external.
Use the undo maximum-routes command to restore the default route maximum value of a specified type.
By default, OSPF can generate up to 524288 external routes, up to 10000 inter-area routes, and up to 2000 intra-area routes.
# Specify the maximum number of intraarea routes as 500.
[Sysname] ospf 100
[Sysname-ospf-100] maximum-routes intra 500
1.1.42 network (OSPF area view)
undo network ip-address wildcard-mask
View
OSPF area view
Default Level
2: System level
ip-address: IP address of a network.
wildcard-mask: Wildcard mask of the IP address. For example, the wildcard mask of mask 255.0.0.0 is 0.255.255.255.
Use the network command to specify a network to belong to the area and enable OSPF on the interface attached to the network.
Use the undo network command to remove an OSPF interface.
By default, an interface neither belongs to any area nor runs OSPF.
You can configure in an area one or multiple interfaces to run OSPF. Note that the interface’s primary IP address must fall into the specified network segment to make the interface run OSPF. If only the interface’s secondary IP address falls into the segment, the interface cannot run OSPF.
Related commands: ospf.
# Specify the interface whose primary IP address falls into 131.108.20.0/24 to run OSPF, and specify the interface to belong to area 2.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
1.1.43 nssa
nssa [ default-route-advertise | no-import-route | no-summary ]*
undo nssa
View
OSPF area view
Default Level
2: System level
default-route-advertise: Used on an NSSA ABR or an ASBR only. If configured on an NSSA ABR, the ABR generates a default route in a Type7 LSA into the NSSA regardless of whether the default route is available. If configured on an ASBR, only a default route is available on the ASBR can it generates a Type7 LSA into the attached area.
no-import-route: Used only on the NSSA ABR that is also the ASBR of the OSPF routing domain to disable redistributing any route in Type7 LSA into the NSSA area, making sure routes can be redistributed correctly.
no-summary: Used only on an NSSA ABR to advertise only a default route in a Type3 summary LSA into the NSSA area, and all other summary LSAs are not advertised into the area. Area of this kind is known as NSSA Totally Stub area.
Use the nssa command to configure the current area as an NSSA area.
Use the undo nssa command to restore the default.
By default, no NSSA area is configured.
All routers attached to an NSSA area must be configured with the nssa command in area view.
Related commands: default-cost.
# Configure area 1 as an NSSA area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] nssa
1.1.44 opaque-capability enable
undo opaque-capability
View
OSPF view
Default Level
2: System level
None
Use the opaque-capability enable command to enable Opaque LSA advertisement and reception. With the command configured, the OSPF device can receive and advertise the Type 9, Type 10 and Type 11 opaque LSAs.
Use the undo opaque-capability command to restore the default.
The feature is disabled by default.
# Enable advertising and receiving opaque LSAs.
[Sysname] ospf 100
[Sysname-ospf-100]opaque-capability enable
1.1.45 ospf
ospf [ process-id | router-id router-id | vpn-instance instance-name ]*
undo ospf process-id
View
Default Level
2: System level
process-id: OSPF process ID. The default is 1.
router-id: OSPF router ID, in dotted decimal format.
instance-name: VPN instance name, case insensitive.
Use the ospf command to enable an OSPF process.
Use the undo ospf command to disable an OSPF process.
OSPF is not enabled by default.
You can specify multiple OSPF processes on a device and different Router IDs for these processes.
When using OSPF as the VPN internal routing protocol for MPLS VPN implementation, you need to bind the OSPF process with a VPN instance.
Enabling OSPF first is required before performing other tasks.
# Enable OSPF process 100 and specify Router ID as 10.10.10.1.
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
1.1.46 ospf authentication-mode
For MD5/HMAC-MD5 authentication:
ospf authentication-mode { md5 | hmac-md5 } key-id [ plain | cipher ] password
undo ospf authentication-mode { md5 | hmac-md5 } key-id
For simple authentication:
ospf authentication-mode simple [ plain | cipher ] password
undo ospf authentication-mode simple
View
Interface view
Default Level
2: System level
md5: MD5 authentication.
hmac-md5: HMAC-MD5 authentication.
simple: Simple authentication.
key-id: Authentication key ID.
plain | cipher : Plain or cipher password. If plain is specified, only plain password is supported and displayed upon displaying the configuration file. If cipher is specified, both plain and cipher are supported, but only cipher password is displayed when displaying the configuration file. If no keyword is specified, the cipher type is the default for the MD5/HMAC-MD5 authentication mode, and the plain type is the default for the simple authentication mode.
password: Password of plain or cipher. Simple authentication: For plain type password, a plain password is a string of up to 8 characters. For cipher type password, a plain password is a string of up to 8 characters, and a cipher password is a string of up to 24 characters. MD5/HMAC-MD5 authentication: For plain type password, a plain password is a string of up to 16 characters. For cipher type password, a plain password is a string of up to 16 characters, and a cipher password is a string of up to 24 characters.
Use the ospf authentication-mode command to set the authentication mode and key ID on an interface.
Use the undo ospf authentication-mode command to remove specified configuration.
By default, no authentication is available on an interface.
Interfaces attached to the same network segment must have the same authentication password and mode.
This configuration is not supported on the null interface.
Related commands: authentication-mode.
# Configure the network 131.119.0.0/16 in area 1 to support MD5 cipher authentication, and set the interface key ID to 15, authentication password to “password”, and password type to cipher.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] network 131.119.0.0 0.0.255.255
[Sysname-ospf-100-area-0.0.0.1] authentication-mode md5
[Sysname-ospf-100-area-0.0.0.1] quit
[Sysname-ospf-100] quit
[Sysname] interface Vlan-interface 12
[Sysname-Vlan-interface12] ospf authentication-mode md5 15 cipher password
# Configure the network 131.119.0.0/16 in area 1 to support simple authentication, and set for the interface the authentication password to password, and password type to cipher.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] authentication-mode simple
[Sysname] interface Vlan-interface 14
[Sysname-Vlan-interface14] ospf authentication-mode simple cipher password
1.1.47 ospf cost
ospf cost value
undo ospf cost
View
Interface view
Default Level
2: System level
value: OSPF cost, in the range 1 to 65535.
Use the ospf cost command to set the OSPF cost of the interface.
Use the undo ospf cost command to restore the default OSPF cost of the interface.
By default, an OSPF interface calculates its cost automatically: Interface default cost=100 Mbps /Interface bandwidth(Mbps), default costs of some interfaces are:
l 1785 for the 56 kbps serial interface
l 1562 for the 64 kbps serial interface
l 48 for the E1 (2.048 Mbps) interface
l 1 for the Ethernet interface
You can use the ospf cost command to set an interface’s OSPF cost manually.
This configuration is not supported on the NULL interface.
# Set the OSPF cost of VLAN-interface 12 to 65.
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] ospf cost 65
1.1.48 ospf dr-priority
ospf dr-priority priority
undo ospf dr-priority
View
Interface view
Default Level
2: System level
priority: DR Priority of the interface.
Use the ospf dr-priority command to set the priority for DR/BDR election on an interface.
Use the undo ospf dr-priority command to restore the default value.
By default, the priority is 1.
The bigger the value, the higher the priority.
# Set the DR priority of VLAN-interface12 to 8.
[Sysname-Vlan-interface12] ospf dr-priority 8
1.1.49 ospf mib-binding
ospf mib-binding process-id
undo ospf mib-binding
View
Default Level
2: System level
Use the ospf mib-binding command to bind an OSPF process to MIB operation.
Use the undo ospf mib-binding command to restore the default.
By default, MIB operation is bound to the first enabled OSPF process.
# Bind OSPF process 100 to MIB operation.
[Sysname] ospf mib-binding 100
# Restore the default, that is, bind the first enabled OSPF process to MIB operation
[Sysname] undo ospf mib-binding
1.1.50 ospf mtu-enable
ospf mtu-enable
undo ospf mtu-enable
View
Interface view
Default Level
2: System level
None
Use the ospf mtu-enable command to enable an interface to add the real MTU into DD packets.
Use the undo ospf mtu-enable command to restore the default.
By default, an interface adds the MTU value of 0 into DD packets, that is, no real MTU is added.
Note that:
l After a virtual link is established via the Virtual-Template or Tunnel, two devices on the link from different vendors may have different default MTU values. To make them consistent, set the attached interfaces’ default MTU to 0 for sending DD packets.
l This configuration is not supported on the null interface.
# Enable the VLAN-interface12 to add the real MTU value into DD packets.
[Sysname-Vlan-interface12] ospf mtu-enable
1.1.51 ospf network-type
ospf network-type { broadcast | nbma | p2mp | p2p }
undo ospf network-type
View
Interface view
Default Level
2: System level
broadcast: Specifies the network type as Broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
p2p: Specifies the network type as P2P.
Use the ospf network-type command to set the network type of an interface.
Use the undo ospf network-type command to restore the default network type for an interface.
By default, the network type of an interface depends on its physical media. The network type for Ethernet interfaces is Broadcast, for serial interfaces is P2P, and for ATM interfaces is NBMA.
If a router attached to a broadcast network does not support multicast, you can configure the interface’s network type as NBMA or change NBMA to Broadcast.
The requirements for changing the network type from NBMA to Broadcast on an interface: Any two routers in the network are directly connected via a virtual link, or the network is fully meshed. If a network cannot meets the requirements, you have to change the network type of an attached interface to P2MP, thus two routers having no direct link can exchange routing information via another router. After changing the network type to P2MP, you do not need to configure any neighbor.
If only two routers run OSPF on a network segment, you can configure associated interfaces’ network type as P2P.
Related commands: ospf dr-priority.
& Note:
When changing an interface’s network type to NBMA or the interface’s network type is NBMA, you need to use the peer command to configure adjacencies.
# Configure the network type of VLAN–interface12 as NBMA.
[Sysname-Vlan-interface12] ospf network-type nbma
1.1.52 ospf timer dead
ospf timer dead seconds
undo ospf timer dead
View
Interface view
Default Level
2: System level
seconds: Dead interval in seconds.
Use the ospf timer dead command to set the dead interval.
Use the undo ospf timer dead command to restore the default.
The dead interval defaults to 40s for Broadcast, P2P interfaces and defaults to 120s for P2MP and NBMA interfaces
If an interface receives no Hello packet from the neighbor after the dead interval elapsed, the interface considers the neighbor as dead. The dead interval on an interface is at least four times the hello interval. Any two routers attached to the same segment must have the same dead interval.
Related commands: ospf timer hello.
# Configure the dead interval on VLAN-interface12 as 60 seconds.
[Sysname-Vlan-interface12] ospf timer dead 60
1.1.53 ospf timer hello
ospf timer hello seconds
undo ospf timer hello
View
Interface view
Default Level
2: System level
seconds: Hello interval in seconds.
Use the ospf timer hello command to set the hello interval on an interface.
Use the undo ospf timer hello command to restore the default hello interval on an interface.
The hello interval defaults to 10s for P2P and Broadcast interfaces, and defaults to 30s for P2MP and NBMA interfaces
The shorter the hello interval, the faster the topology convergence speed and the more resources consumed. Make sure the hello interval on two neighboring interfaces is the same.
Related commands: ospf timer dead.
# Configure the hello interval on VLAN-interface12 as 20 seconds.
[Sysname-Vlan-interface12] ospf timer hello 20
1.1.54 ospf timer poll
ospf timer poll seconds
undo ospf timer poll
View
Interface view
Default Level
2: System level
seconds: Poll interval in seconds.
Use the ospf timer poll command to set the poll interval on an NBMA interface.
Use the undo ospf timer poll command to restore the default value.
By default, the poll interval is 120s.
When an NBMA or P2MP interface finds its neighbor is dead, it will send hello packets at the poll interval. The poll interval is at least four times the hello interval.
# Set the poll interval on VLAN-interface12 to 130 seconds.
[Sysname-Vlan-interface12] ospf timer poll 130
1.1.55 ospf timer retransmit
ospf timer retransmit interval
undo ospf timer retransmit
View
Interface view
Default Level
2: System level
interval: LSA retransmission interval in seconds, in the range 1 to 3600.
Use the ospf timer retransmit command to set the LSA retransmission interval on an interface.
Use the undo ospf timer retransmit command to restore the default.
The interval defaults to 5s.
After sending an LSA, an interface waits for an acknowledgement packet. If the interface receives no acknowledgement when the retransmission interval elapses, it will retransmit the LSA.
The retransmission interval should not be so small to avoid unnecessary retransmissions.
# Set the LSA retransmission interval of VLAN-interface12 to 8 seconds.
[Sysname-Vlan-interface12] ospf timer retransmit 8
1.1.56 ospf trans-delay
ospf trans-delay seconds
undo ospf trans-delay
View
Interface view
Default Level
2: System level
seconds: LSA transmission delay in seconds.
Use the ospf trans-delay command to set the LSA transmission delay of an interface.
Use the undo ospf trans-delay command to restore the default.
The default LSA transmission delay is 1 second.
Each LSA in the LSDB has an age that incremented by 1 every second, but the age does not change during transmission. It is necessary to add a transmit delay into its age time, which is important for transmission on low speed networks.
# Set the LSA transmission delay to 3 seconds on VLAN-interface12.
[Sysname-Vlan-interface12] ospf trans-delay 3
1.1.57 peer
peer ip-address [ dr-priority dr-priority ]
undo peer ip-address
View
OSPF view
Default Level
2: System level
ip-address: Neighbor IP address.
dr-priority: Neighbor DR priority; The bigger the value, the higher the priority.
Use the peer command to specify the IP address and DR priority of a neighbor.
Use the undo peer command to remove the configuration.
After startup, a router sends a Hello packet to routers with DR priorities higher than 0. When the DR and BDR are elected, they will send Hello packets to all neighbors for adjacency establishment.
A router uses the priority set with the peer command to determine whether to send a Hello packet to the neighbor rather than for DR election. The DR priority set with the ospf dr-priority command is used for DR election.
# Specify the neighbor IP address 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100] peer 1.1.1.1
1.1.58 preference
preference [ ase [ route-policy route-policy-name ] ] value
undo preference [ ase ]
View
OSPF view
Default Level
2: System level
ase: Sets a priority for ASE routes. If the keyword is not specified, using the command sets a priority for internal routes.
route-policy: Applies a route policy to set priorities for specified routes.
route-policy-name: Routing policy name.
value: Priority for OSPF routes. A smaller value represents a higher priority.
Use the preference command to set the priority of OSPF routes.
Use the undo preference command to restore the default.
The priority of OSPF internal routes defaults to 10, and the priority of OSPF external routes defaults to 150.
If a route-policy is applied, priorities defined by the route-policy will apply, and priorities not defined by the policy will still use values set by the preference command.
Since a device may run multiple routing protocols, it has to decide on routes found by these protocols. Every protocol has a priority to help the router determine which route to use especially when multiple routes to the same destination are found by several routing protocols. The route found by the protocol with the highest priority will be used.
# Set OSPF priority to 150.
[Sysname] ospf 100
[Sysname-ospf-100] preference 150
1.1.59 reset ospf counters
reset ospf [ process-id ] counters [ neighbor [ interface-type interface-number ] [ router-id ] ]
View
Default Level
2: System level
neighbor: Clears neighbor statistics on an interface.
router-id: Neighbor router ID.
Use the reset ospf counters command to reset OSPF counters. If no OSPF process is specified, counters of all OSPF processes are reset.
# Clear OSPF counters.
<Sysname> reset ospf counters
1.1.60 reset ospf process
reset ospf [ process-id ] process
View
Default Level
2: System level
Use the reset ospf process command to reset all OSPF processes or a specified process.
Using the reset ospf process command will:
l Clear all invalid LSAs without waiting for their timeouts
l Make a newly configured Router ID take effect
l Start a new round of DR/BDR election
l Not remove any previous OSPF configurations.
The system prompts whether to reset OSPF process upon execution of this command.
# Reset all OSPF processes.
<Sysname> reset ospf process
1.1.61 reset ospf redistribution
View
Default Level
2: System level
Use the reset ospf redistribution command to restart route redistribution. If no process ID is specified, using the command restarts route redistribution for all OSPF processes.
# Restart route redistribution.
<Sysname> reset ospf redistribution
1.1.62 rfc1583 compatible
rfc1583 compatible
undo rfc1583 compatible
View
OSPF view
Default Level
2: System level
None
Use the rfc1583 compatible command to make routing rules defined in RFC1583 compatible.
Use the undo rfc1583 compatible command to disable the function.
By default, RFC1583 routing rules are compatible.
On selecting the best route when multiple AS external LSAs describe routes to the same destination, RFC1583 and RFC2328 have different routing rules.
# Make RFC1583 routing rules compatible.
[Sysname] ospf 100
[Sysname-ospf-100] rfc1583 compatible
1.1.63 silent-interface (OSPF view)
silent-interface { all | interface-type interface-number }
undo silent-interface { all | interface-type interface-number }
View
OSPF view
Default Level
2: System level
all: Disables all interfaces from sending OSPF packet.
Use the silent-interface command to disable specified interfaces from sending any OSPF packet.
Use the undo silent-interface command to restore the default.
By default, an interface sends OSPF packets.
A disabled interface is a passive interface, which cannot send any Hello packet.
To make no routing information obtained by other routers on a network segment, you can use this command to disable the interface from sending OSPF packets.
# Disable VLAN-interface 12 from sending OSPF packets.
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface vlan-interface 10
1.1.64 snmp-agent trap enable ospf
snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | txretransmit | vifauthfail | vifcfgerror | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
undo snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | txretransmit | vifauthfail | vifcfgerror | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
View
Default Level
3: Manage level
ifauthfail: Interface authentication failure information.
ifcfgerror: Interface configuration error information.
ifrxbadpkt: Information about error packets received.
ifstatechange: Interface state change information.
lsdbapproachoverflow: Information about cases approaching LSDB overflow
lsdboverflow: LSDB overflow information.
maxagelsa: LSA max age information.
nbrstatechange: Neighbor state change information.
originatelsa: Information about LSAs originated locally.
txretransmit: Packet receiving and forwarding information.
vifauthfail: Virtual interface authentication failure information.
vifcfgerror: Virtual interface configuration error information.
virifrxbadpkt: Information about error packets received by virtual interfaces.
virifstatechange: Virtual interface state change information.
viriftxretransmit: Virtual interface packet retransmit information.
virnbrstatechange: Virtual interface neighbor state change information.
Use the snmp-agent trap enable ospf command to enable TRAP function for a specified OSPF process. If no process is specified, TRAP function for all processes is enabled.
Use the undo snmp-agent trap enable ospf command to disable the function.
By default, this function is enabled.
Refer to SNMP Commands for related information.
# Enable trap packet transmission for all OSPF processes.
[Sysname] snmp-agent trap enable ospf
1.1.65 spf-schedule-interval
undo spf-schedule-interval
View
OSPF view
Default Level
2: System level
maximum-interval: Maximum SPF calculation interval in seconds. The default is 5 seconds.
minimum-interval: Minimum SPF calculation interval in milliseconds. The default is 0.
incremental-interval: Incremental value for increasing SPF calculation interval in milliseconds. The default is 5000.
Use the spf-schedule-interval command to set intervals for OSPF SPF calculation.
Use the undo spf-schedule-interval command to restore the default.
By default, SPF calculation interval is 5 seconds.
Based on its LSDB, an OSPF router calculates the shortest path tree with itself being the root, using which to determine the next hop to a destination. Through adjusting SPF calculation interval, you can protect bandwidth and router resources from being over-consumed due to frequent network changes.
With this command configured, when network changes are not frequent, SPF calculation applies at the minimum-interval. If network changes become frequent, SPF calculation interval is incremented each time a calculation happens, up to the maximum-interval.
# Configure the SPF calculation interval as 6 seconds.
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 6
1.1.66 stub (OSPF area view)
stub [ no-summary ]
undo stub
View
OSPF area view
Default Level
2: System level
no-summary: Used only on a stub ABR. With it configured, the ABR advertises only a default route in a Summary LSA into the stub area (Stub area of this kind is known as totally stub area).
Use the stub command to configure an area as a stub area.
Use the undo stub command to remove the configuration.
No area is stub area by default. To configure an area as a stub area, all routers attached to it must be configured with this command.
# Configure area 1 as a stub area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
1.1.67 stub-router
stub-router
undo stub-router
View
OSPF view
Default Level
2: System level
None
Use the stub-router command to configure the router as a stub router.
Use the undo stub-router command to restore the default.
By default, no router is configured as a stub router.
The router LSAs from the stub router may contain different link type values. A value of 3 means a link to the stub network, so the cost of the link remains unchanged. A value of 1, 2 or 4 means a point-to-point link, a link to a transit network or a virtual link, in such cases, a maximum cost value of 65535 is used. Thus, other neighbors find the links to the stub router have such big costs, they will not send packets to the stub router for forwarding as long as there is a route with a smaller cost.
# Enable a stub-router.
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
1.1.68 vlink-peer (OSPF area view)
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | simple [ plain | cipher ] password | { md5 | hmac-md5 } key-id [ plain | cipher ] password ]*
undo vlink-peer router-id [ hello | retransmit | trans-delay | dead | [ simple | { md5 | hmac-md5 } key-id ] ]*
View
OSPF area view
Default Level
2: System level
router-id: Router ID of the neighbor on the virtual link.
hello seconds: Hello interval in seconds. The default is 10. It must be identical to the hello interval of the neighbor on the virtual link.
retransmit seconds: LSA retransmission interval in seconds. The default is 5.
trans-delay seconds: Transmission delay in seconds. The default is 1.
dead seconds: Dead interval in seconds. The default is 40. It must be identical to the dead interval on its virtual link neighbor. The dead interval is at least four times the hello interval.
key-id: Key ID for MD5 or HMAC-MD5 authentication.
plain | cipher: Plain or cipher type. If plain is specified, only plain password is supported. If cipher is specified, both plain and cipher password are supported, but only cipher password is displayed when displaying the configuration file. If no keyword is specified, MD5 and HMAC-MD5 use cipher password, and the simple authentication mode uses plain password.
password: Plain or cipher password. Simple authentication: For plain type, a plain password is a string of up to 8 characters. For cipher type, a plain password is a string of up to 8 characters, and a cipher password is a string of up to 24 characters. MD5/HMAC-MD5 authentication: For plain type, a plain password is a string of up to 16 characters. For cipher type, a plain password is a string of up to 16 characters, and a cipher password is a string of up to 24 characters.
Use the vlink-peer command to create and configure a virtual link.
Use the undo vlink-peer command to remove a virtual link.
As defined in RFC2328, all non-backbone areas must maintain connectivity to the backbone. You can use the vlink-peer command to configure a virtual link to connect an area to the backbone.
Considerations on parameters:
l The smaller the hello interval is, the faster the network changes are found and the more network resources are consumed.
l A so small retransmission interval will lead to unnecessary retransmissions. A bigger value is appropriate for a low speed link.
l You need to consider the interface transmission delay when specifying the trans-delay value.
The authentication mode (MD5 or Simple) at the non-backbone virtual link end follows the one at the backbone virtual link end. The two authentication modes are independent. You can specify neither of them.
Related commands: authentication-mode, display ospf.
# Configure a virtual link to the neighbor with router ID 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
