H3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
HomeSupportSwitchesH3C S9500 Series SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
03-GVRP Commands
03-GVRP Commands 56.08 KB
Chapter 1  GARP/GVRP Configuration Commands
1.1  GARP Configuration Commands
1.1.1  debugging garp event
undo debugging garp event
View
Default Level
1: Monitor level
None
Use the debugging garp event command to enable GARP event debugging, in order to debug GARP timer events.
Use the undo debugging garp event command to disable GARP event debugging.
By default, GARP event debugging is disabled.
# Enable GARP event debugging on a GARP-enabled device.
<Sysname> terminal debugging
<Sysname> debugging garp event
*Mar 26 14:18:10:635 2007 Sysname GARP/7/Timer start:Slot=1:
Gvrp Start Join Timer for port Ethernet1/1/1 value = 200 millisec
// The above information shows the Join timer on port Ethernet1/1/1 started with a value of 200 ms.
*Mar 26 14:18:11:635 2007 Sysname GARP/7/Timer expiry:Slot=1:
Gvrp Join Timer Expired for port Ethernet1/1/1
// The above information shows the Join timer on port Ethernet1/1/1 expired.
(Other timers’ event information is omitted here.)
1.1.2  display garp statistics
display garp statistics [ interface interface-list ]
View
Default Level
1: Monitor level
interface interface-list: Defines one or multiple Ethernet ports. You can provide up to 10 Ethernet port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end-port number specified by interface-number2 must be greater than the start-port number specified by interface-number1.
Use the display garp statistics command to display statistics about GARP for specified or all ports. If no port is specified, the GARP statistics of all ports are displayed.
# Display statistics about GARP for port Ethernet1/1/1.
<Sysname> display garp statistics interface ethernet 1/1/1
        GARP statistics on port Ethernet1/1/1
        Number of GVRP Frames Received          : 0
        Number of GVRP Frames Transmitted       : 0
        Number of Frames Discarded              : 0
1.1.3  display garp timer
display garp timer [ interface interface-list ]
View
Default Level
1: Monitor level
Use the display garp timer command to display the settings of the GARP timers on specified or all ports.
If no interface is specified, the GARP timer settings on all ports are displayed.
Related commands: garp timer, garp timer leaveall.
# Display the GARP timer settings on port Ethernet1/1/1.
<Sysname> display garp timer interface ethernet 1/1/1
        GARP timers on port Ethernet1/1/1
                Garp Join Time          : 20 centiseconds
                Garp Leave Time         : 60 centiseconds
                Garp LeaveAll Time      : 1000 centiseconds
                Garp Hold Time          : 10 centiseconds
1.1.4  garp timer
garp timer { hold | join | leave } timer-value
undo garp timer { hold | join | leave }
View
Ethernet interface view, port group view
Default Level
2: System level
hold: Sets the hold timer.
join: Sets the join timer.
leave: Sets the leave timer.
timer-value: Timer setting (in centiseconds), which must be a multiple of 5.
Use the garp timer command to set a GARP timer for an Ethernet port or all ports in a port group in compliance with the timer setting dependencies shown in Table 1-1.
Use the undo garp timer command to restore the default of a GARP timer. This may fail if the default does not satisfy the dependencies shown in Table 1-1.
By default, the Hold timer is 10 centiseconds, the Join timer is 20 centiseconds, and the Leave timer is 60 centiseconds.
When restoring the default GARP timers, you are recommended to do that on the timers in the order of Hold, Join, Leave, and LeaveAll.
When configuring GARP timers, note that their values are dependent on each other and must be a multiplier of five centiseconds. If the value range for a timer is not desired, you may change it by tuning the value of another timer as shown in the following table:
Table 1-1 Dependencies of GARP timers
Timer
Lower limit
Upper limit
Hold
10 centiseconds
Not greater than half of the Join timer setting
Join
Not less than two times the Hold timer setting
Less than half of the Leave timer setting
Leave
Greater than two times the Join timer setting
Less than the LeaveAll timer setting
LeaveAll
Greater than the Leave timer setting
32765 centiseconds
Related commands: display garp timer.
# Set the GARP Join timer to 25 centiseconds, assuming that both the Hold timer and the Leave timer are using the default.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] garp timer join 25
1.1.5  garp timer leaveall
garp timer leaveall timer-value
undo garp timer leaveall
View
Default Level
2: System level
timer-value: Value for the LeaveAll timer in centiseconds, which is a multiple of 5. This value must be greater than the Leave timer values of all ports.
Use the garp timer leaveall command to set the LeaveAll timer of GARP.
Use the undo garp timer leaveall command to restore the default. This may fail if the default is less than the setting of the current Leave timer.
By default, the LeaveAll timer is 1000 centiseconds, that is, 10 seconds.
A LeaveAll timer starts upon the startup of a GARP application entity. When this timer expires, the entity sends a LeaveAll message so that other entities can re-register its attribute information, and, at the same time, the entity restarts the LeaveAll timer.
Different devices on a network may have different LeaveAll timer values. Each time a device on the network receives a LeaveAll message, it resets its LeaveAll timer. Therefore, each GARP application entity will send LeaveAll messages based on the shortest LeaveAll timer in the network. As a result, only the shortest LeaveAll timer in the network will take effect.
# Set the LeaveAll timer to 100 centiseconds, assuming that the Leave timer is 60 centiseconds.
[Sysname] garp timer leaveall 100
1.1.6  reset garp statistics
reset garp statistics [ interface interface-list ]
View
Default Level
2: System level
Use the reset garp statistics command to clear statistics about GARP on specified or all ports.
If no port is specified, the GARP statistics of all ports are cleared.
Related commands: display gvrp statistics.
# Clear statistics about GARP on all ports.
<Sysname> reset garp statistics
1.2  GVRP Configuration Commands
1.2.1  debugging gvrp
debugging gvrp { packet | event }
undo debugging gvrp { packet | event }
View
Default Level
1: Monitor level
packet: Specifies GVRP packet debugging.
event: Specifies GVRP event debugging.
Use the debugging gvrp command to enable GVRP packet or event debugging on all GVRP-enabled ports.
Use the undo debugging gvrp command to disable GVRP packet or event debugging.
By default, both GVRP packet debugging and GVRP event debugging are disabled.
# Enable GVRP packet debugging on a GVRP-enabled device.
<Sysname> debugging gvrp packet
*Mar 26 14:18:40:635 2007 Sysname GARP/7/debug_case:Slot=1:
Tx GVRP message on port Ethernet1/1/1
// The above information shows a GVRP message was transmitted on port Ethernet1/1/1.
*Mar 26 14:18:40:635 2007 Sysname GARP/7/Garp packet:Slot=1:
Vlan Attribute, Event = Join Empty, VLAN Id = 1
// The above information shows the GVRP message transmitted was a Join Empty message carrying a VLAN attribute (VLAN ID of 1).
Table 1-2 Description on the fields of the debugging gvrp packet command
Tx
This is a transmitted message.
Rx
This is a received message.
GVRP message
This is a GVRP message.
port portName
Name of the port that transmits or receives the message
Vlan Attribute
The attribute carried in the message is a VLAN ID.
Event = { Leave All | Join Empty | Join In | Leave Empty | Leave In }
Event type of the message, which can be Leave All, Join Empty, Join In, Leave Empty or Leave In
VLAN Id = n
VLAN ID
Table 1-3 Description on the fields of the debugging gvrp event command
GVRP: Wrong VLAN Id = n to create
VLAN ID error occurred when a VLAN is created
GVRP: Number of static VLANs for port portName = n
Number of static VLANs on a port
1.2.2  display gvrp statistics
display gvrp statistics [ interface interface-list ]
View
Default Level
1: Monitor level
Use the display gvrp statistics command to display statistics about GVRP for specified or all trunk ports.
If no port is specified, the GVRP statistics of all trunk ports are displayed.
# Display statistics about GVRP for trunk port Ethernet1/1/1.
<Sysname> display gvrp statistics interface ethernet 1/1/1
        GVRP statistics on port Ethernet1/1/1
                GVRP Status                     : Enabled
                GVRP Running                    : YES
                GVRP Failed Registrations       : 0
                GVRP Last Pdu Origin            : 00E0-FC12-3456
                GVRP Registration Type          : Normal
Table 1-4 Description on the fields of the display gvrp statistics command
GVRP Status
Indicates whether GVRP is enabled or disabled.
GVRP Running
Indicates whether GVRP is running.
Indicates the number of GVRP registration failures.
Indicates the source MAC address in the last GVRP PDU.
Indicates the GVRP registration mode on the port.
1.2.3  display gvrp status
display gvrp status
View
Default Level
1: Monitor level
None
Use the display gvrp status command to display the global enable/disable state of GVRP.
# Display the global GVRP enable/disable state.
<Sysname> display gvrp status
GVRP is enabled
1.2.4  gvrp
gvrp
undo gvrp
View
System view, Ethernet interface view, port group view
Default Level
2: System level
None
Use the gvrp command to enable GVRP globally, on a port, or on all ports in a port group depending on the view you entered.
Use the undo gvrp command to disable GVRP globally, on a port, or on all ports in a port group depending on the view you entered.
Disabling GVRP globally also disables it on all ports.
By default, GVRP is disabled.
Note that:
l           The port where you enable GVRP must be a trunk port.
l           Before you can enable GVRP on it, you must enable GVRP globally.
l           BPDU tunneling is incompatible with GVRP. Before enabling GVRP, disable BPDU tunneling.
l           Isolate-user-vlan is incompatible with global GVRP. Make sure that no Isolate-user-vlan has been created on the switch before enabling GVRP.
Related commands: display gvrp status.
# Enable GVRP globally.
[Sysname] gvrp
GVRP is enabled globally.
1.2.5  gvrp registration
gvrp registration { fixed | forbidden | normal }
undo gvrp registration
View
Default Level
2: System level
fixed: Sets the registration mode to fixed.
forbidden: Sets the registration mode to forbidden.
normal: Sets the registration mode to normal.
Use the gvrp registration command to configure the GVRP registration mode on a port or all ports in a port group.
Use the undo gvrp registration command to restore the default.
The default GVRP registration mode is normal.
GVRP provides the following three registration modes on a port:
l           Normal –– Enables the port to dynamically register and deregister VLANs, and to propagate both dynamic and static VLAN information.
l           Fixed –– Disables the port to dynamically register and deregister VLANs or propagate information about dynamic VLANs, but allows the port to propagate information about static VLANs. A trunk port in fixed registration mode thus allows only manually configured VLANs to pass through even though it is configured to carry all VLANs.
l           Forbidden –– Disables the port to dynamically register and deregister VLANs and to propagate VLAN information except information about VLAN 1. A trunk port in forbidden registration mode thus allows only VLAN 1 to pass through even though it is configured to carry all VLANs.
Note that this command is only available on trunk ports.
Related commands: display garp statistics.
# Set the GVRP registration mode to fixed on port Ethernet1/1/1.
[Sysname-Ethernet1/1/1] port link-type trunk
[Sysname-Ethernet1/1/1] gvrp registration fixed
