- H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
- 00-1Cover
- 01-Login Commands
- 02-VLAN Commands
- 03-IP Addressing and IP Performance Commands
- 04-QinQ-BPDU TUNNEL Commands
- 05-Port Correlation Commands
- 06-Link Aggregation Commands
- 07-MAC Address Table Management Commands
- 08-Port Security Commands
- 09-MSTP Commands
- 10-IPv6 Commands
- 11-IP Routing Overview Commands
- 12-IPv4 Routing Commands
- 13-IPv6 Routing Commands
- 14-Multicast Commands
- 15-802.1x-HABP-MAC Authentication Commands
- 16-AAA RADIUS HWTACACS Commands
- 17-ARP Commands
- 18-DHCP Commands
- 19-ACL Commands
- 20-QoS Commands
- 21-Port Mirroring Commands
- 22-UDP Helper Commands
- 23-Cluster Management Commands
- 24-SNMP-RMON Commands
- 25-NTP Commands
- 26-DNS Commands
- 27-File System Management Commands
- 28-Information Center Commands
- 29-System Maintaining and Debugging Commands
- 30-NQA Commands
- 31-SSH Commands
- 32-Track Commands
- 33-PoE Commands
- 34-SSL-HTTPS Commands
- 35-PKI Commands
- 36-Stack Management Commands
- 37-Appendix
14-Multicast Commands | 253 KB |
Table of Contents
Chapter 1 IGMP Snooping Configuration Commands
1.1 IGMP Snooping Configuration Commands
1.1.1 display igmp-snooping group
1.1.2 display igmp-snooping statistics
1.1.7 igmp-snooping drop-unknown
1.1.9 igmp-snooping fast-leave
1.1.10 igmp-snooping general-query source-ip
1.1.11 igmp-snooping group-limit
1.1.12 igmp-snooping group-policy
1.1.13 igmp-snooping host-aging-time
1.1.14 igmp-snooping host-join
1.1.15 igmp-snooping last-member-query-interval
1.1.16 igmp-snooping max-response-time
1.1.17 igmp-snooping overflow-replace
1.1.19 igmp-snooping query-interval
1.1.20 igmp-snooping router-aging-time
1.1.21 igmp-snooping source-deny
1.1.22 igmp-snooping special-query source-ip
1.1.23 igmp-snooping static-group
1.1.24 igmp-snooping static-router-port
1.1.26 last-member-query-interval
1.1.30 reset igmp-snooping group
1.1.31 reset igmp-snooping statistics
Chapter 2 MLD Snooping Configuration Commands
2.1 MLD Snooping Configuration Commands
2.1.1 display mld-snooping group
2.1.2 display mld-snooping statistics
2.1.6 last-listener-query-interval
2.1.9 mld-snooping drop-unknown
2.1.11 mld-snooping fast-leave
2.1.12 mld-snooping general-query source-ip
2.1.13 mld-snooping group-limit
2.1.14 mld-snooping group-policy
2.1.15 mld-snooping host-aging-time
2.1.17 mld-snooping last-listener-query-interval
2.1.18 mld-snooping max-response-time
2.1.19 mld-snooping overflow-replace
2.1.21 mld-snooping query-interval
2.1.22 mld-snooping router-aging-time
2.1.23 mld-snooping source-deny
2.1.24 mld-snooping special-query source-ip
2.1.25 mld-snooping static-group
2.1.26 mld-snooping static-router-port
2.1.30 reset mld-snooping group
2.1.31 reset mld-snooping statistics
Chapter 3 Multicast VLAN Configuration Commands
3.1 Multicast VLAN Configuration Commands
Chapter 4 IPv6 Multicast VLAN Configuration Commands
4.1 IPv6 Multicast VLAN Configuration Commands
4.1.1 display multicast-vlan ipv6
4.1.2 multicast-vlan ipv6 enable
4.1.3 multicast-vlan ipv6 subvlan
display igmp-snooping group [ vlan vlan-id ] [ verbose ]
View
vlan vlan-id: Displays the IGMP Snooping forwarding table information in the specified VLAN, where vlan-id is in the range of 1 to 4094. If you do not specify a VLAN, this command will display the multicast group information in all VLANs.
verbose: Specifies to display the detailed IGMP Snooping forwarding table information.
Use the display igmp-snooping group command to view the IGMP Snooping forwarding table information.
# View the detailed IGMP Snooping forwarding table information in VLAN 2.
<Sysname> display igmp-snooping group vlan 2 verbose
Total 1 IP Group(s).
Total 1 IP Source(s).
Total 1 MAC Group(s).
Port flags: D-Dynamic port, S-Static port, A-Aggregation port, C-Copy port
Subvlan flags: R-Real VLAN, C-Copy VLAN
Vlan(id):2.
Router port(s):total 1 port.
GE1/0/2 (D) ( 00:01:30 )
IP group(s):the following ip group(s) match to one mac group.
IP group address:224.1.1.1
(1.1.1.1, 224.1.1.1):
Attribute: Host Port
Host port(s):total 1 port.
GE1/0/1 (D) ( 00:03:23 )
MAC group(s):
MAC group address:0100-5e01-0101
GE1/0/1
Table 1-1 Description of the fields of the display igmp-snooping group command
Total 1 IP Group(s). |
Total number of IP multicast groups |
Total 1 IP Source(s). |
Total number of multicast sources |
Total 1 MAC Group(s). |
Total number of MAC multicast groups |
Port flags: D-Dynamic port, S-Static port, A-Aggregation port, C-Copy port |
Port flags: D for dynamic port, S for static port, A for aggregation port, C for port copied from a (*, G) entry to an (S, G) entry |
Subvlan flags: R-Real VLAN, C-Copy VLAN |
Sub-VLAN flags: R for real egress sub-VLAN under the current entry, C for sub-VLAN copied from a (*, G) entry to an (S, G) entry |
Router port(s) |
Number of router ports |
IP group address |
Address of IP multicast group |
MAC group address |
Address of MAC multicast group |
Attribute |
Attribute of IP multicast group |
Host port(s) |
Number of host member ports |
View
None
Use the display igmp-snooping statistics command to view the statistics information of IGMP messages learned by IGMP Snooping.
# View the statistics information of IGMP messages learned by IGMP Snooping.
<Sysname> display igmp-snooping statistics
Received IGMP general queries:0.
Received IGMPv1 reports:0.
Received IGMPv2 reports:19.
Received IGMP leaves:0.
Received IGMPv2 specific queries:0.
Sent IGMPv2 specific queries:0.
Received IGMPv3 reports:1.
Received IGMPv3 reports with right and wrong records:0.
Received IGMPv3 specific queries:0.
Received IGMPv3 specific sg queries:0.
Sent IGMPv3 specific queries:0.
Sent IGMPv3 specific sg queries:0.
Received error IGMP messages:19.
Table 1-2 Description of the fields of the display igmp-snooping statistics command
general queries |
General query messages |
specific queries |
Group-specific query messages |
reports |
Report messages |
leaves |
Leave messages |
reports with right and wrong records |
Report messages with correct and incorrect records |
specific sg query packet(s) |
Group-and-source-specific query message(s) |
error IGMP messages |
IGMP messages with errors |
1.1.3 fast-leave
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
IGMP-Snooping view
vlan vlan-list: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094.
Use the fast-leave command to enable the fast leave feature globally.
Use the undo fast-leave command to disable the fast leave feature globally.
By default, the fast leave feature is disabled.
Note that:
If you do not specify any VLAN, the command will take effect for all VLANs; if you specify a VLAN or multiple VLANs, the command will take effect for the specified VLAN(s) only.
Related commands: igmp-snooping fast-leave.
# Enable the fast leave feature globally in VLAN 2.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] fast-leave vlan 2
1.1.4 group-policy
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
IGMP-Snooping view
acl-number: Basic ACL number, in the range of 2000 to 2999.
Use the group-policy command to configure a global multicast group filter.
Use the undo group-policy command to remove the configured global multicast group filter.
By default, no global multicast group filter is configured, namely a host can join any multicast group.
Note that:
l If you do not specify any VLAN, the command will take effect for all VLANs; if you specify a VLAN or multiple VLANs, the command will take effect for the specified VLAN(s) only.
l If the specified ACL does not exist or the ACL rule is null, all multicast groups will be filtered out.
l You can configure different ACL rules for a port in different VLANs; for a given VLAN, a newly configured ACL rule will override the existing one.
Related commands: igmp-snooping group-policy.
# Configure ACL 2000 as the multicast group filter in VLAN 2.
[Sysname-igmp-snooping] group-policy 2000 vlan 2
1.1.5 host-aging-time
host-aging-time interval
undo host-aging-time
View
IGMP-Snooping view
interval: Member port aging time, in units of seconds. The effective range is 200 to 1,000.
Use the host-aging-time command to configure the aging time of group member ports globally.
Use the undo host-aging-time command to restore the default setting.
By default, the aging time of group member ports is 260 seconds.
This command works only on IGMP Snooping–enabled VLANs, but not on VLANs with IGMP enabled on the corresponding VLAN interfaces.
Related commands: igmp-snooping host-aging-time.
# Set the aging time of group member ports globally to 300 seconds.
[Sysname-igmp-snooping] host-aging-time 300
1.1.6 igmp-snooping
igmp-snooping
undo igmp-snooping
View
None
Use the igmp-snooping command to enable IGMP Snooping globally and enter IGMP-Snooping view.
Use the undo igmp-snooping command to disable IGMP Snooping globally.
By default, IGMP Snooping is disabled.
Related commands: igmp-snooping enable.
# Enable IGMP Snooping globally and enter IGMP-Snooping view.
undo igmp-snooping drop-unknown
View
VLAN view
None
Use the igmp-snooping drop-unknown command to enable the function of dropping unknown multicast data in the current VLAN.
Use the undo igmp-snooping drop-unknown command to disable the function of dropping unknown multicast data in the current VLAN.
By default, this function is disabled, that is, unknown multicast data is flooded.
This command takes effect only if IGMP Snooping is enabled in the VLAN.
# In VLAN 2, enable the function of dropping unknown multicast data.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
1.1.8 igmp-snooping enable
undo igmp-snooping enable
View
VLAN view
None
Use the igmp-snooping enable command to enable IGMP Snooping in the current VLAN.
Use the undo igmp-snooping enable command to disable IGMP Snooping in the current VLAN.
By default, IGMP Snooping is disabled in a VLAN.
IGMP Snooping must be enabled globally before it can be enabled in a VLAN.
Related commands: igmp-snooping.
# Enable IGMP Snooping in VLAN 2.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
View
Ethernet port view, port group view
Use the igmp-snooping fast-leave command to enable the fast leave feature on the current port or group of ports.
Use the undo igmp-snooping fast-leave command to disable the fast leave feature on the current port or group of ports.
Note that:
l If you do not specify any VLAN when you use this command in Ethernet port view, the command will take effect no matter which VLAN the port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect only if the port belongs to the specified VLAN(s).
l If you do not specify any VLAN in manual port group view, the command will take effect on all the ports in this group no matter which VLANs these port belong to; if you specify a VLAN or multiple VLANs, the command will take effect on those ports in this group that belong to the specified VLAN(s).
l Configurations made in aggregation port group view are effective only for the master port in the group. If you do not specify any VLAN in aggregation port group view, the command will take effect no matter which VLAN the master port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect only if the master port belongs to the specified VLAN(s).
Related commands: fast-leave.
# Enable the fast leave feature on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitGigabitEthernet1/0/1] igmp-snooping fast-leave vlan 2
igmp-snooping general-query source-ip { current-interface | ip-address }
undo igmp-snooping general-query source-ip
View
VLAN view
current-interface: Sets the source address of IGMP general queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP general queries.
ip-address: Specifies the source address of IGMP general queries, which can be any legal IP address.
Use the igmp-snooping general-query source-ip command to configure the source address of IGMP general queries.
Use the undo igmp-snooping general-query source-ip command to restore the default configuration.
By default, the source IP address of IGMP general queries is 0.0.0.0.
# Set the IP address of the interface of VLAN 2 to 10.1.1.1, with the subnet mask of 255.255.255.0, and specify this IP address as the source IP address of IGMP general queries.
[Sysname-Vlan-interface2] ip address 10.1.1.1 255.255.255.0
[Sysname-Vlan-interface2] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip current-interface
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
View
limit: Maximum number of multicast groups that can be joined on a port. The effective range is 1 to 128.
vlan vlan-list: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094. If you do not provide this option, the command will take effect on each VLAN to which this port belongs.
Use the undo igmp-snooping group-limit command to restore the default setting.
The default setting is 128.
Note that:
l If you do not specify any VLAN in Ethernet port view, the command will take effect on the port no matter which VLAN the port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect on the port only if the port belongs to the specified VLAN(s).
l If you do not specify any VLAN in port group view, the command will take effect on all the ports in this group no matter which VLANs these ports belong to; if you specify a VLAN or multiple VLANs, the command will take effect on those ports in this group that belong to the specified VLAN(s).
# Specify to allow a maximum of 10 multicast groups to be joined on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
View
Use the undo igmp-snooping group-policy command to remove a multicast group filter on the current port(s).
Be default, no multicast group filter is configured on an interface, namely a host can join any multicast group
Note that:
l If you do not specify any VLAN in port group view, the command will take effect on all the ports in this group no matter which VLANs these port belong to; if you specify a VLAN or multiple VLANs, the command will take effect on those ports in this group that belong to the specified VLAN(s).
Related commands: group-policy.
# Configure ACL 2000 as the multicast group filter on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
View
VLAN view
Use the igmp-snooping host-aging-time command to configure the aging time of group member ports in the current VLAN.
Use the undo igmp-snooping host-aging-time command to restore the default setting.
Related commands: host-aging-time.
# Set the aging time of group member ports to 300 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
View
group-address: Address of the multicast group that the simulated host is to join, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Address of the multicast source that the simulated host is to join. The value of this argument should be a valid unicast address or 0.0.0.0. If the value is 0.0.0.0, this means that no multicast source is specified.
vlan vlan-id: Specifies the VLAN that comprises the Ethernet port(s), where vlan-id is in the range of 1 to 4094.
Use the undo igmp-snooping host-join command to remove the current port(s) as simulated multicast group member host(s).
By default, this function is disabled.
Note that:
l This command works on IGMP Snooping–enabled VLANs and VLANs with IGMP enabled on the corresponding VLAN interfaces. The version of IGMP on the simulated host depends on the version of IGMP Snooping running in the VLAN or the version of IGMP running on the VLAN interface.
l The source-ip source-address option in the command is meaningful only for IGMP Snooping version 3. If IGMP Snooping version 2 is running, although you can include source-ip source-address in the command, the simulated host does not respond to a query message.
l If configured in Ethernet port view, this feature takes effect on the port only if the port belongs to the specified VLAN.
l If configured in port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN.
# Configure GigabitEthernet 1/0/1 as a simulated member host in VLAN 2 for multicast source 1.1.1.1 and multicast group 224.0.0.1.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GigabitEthernet1/0/1] igmp-snooping host-join 224.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
View
VLAN view
interval: Interval between IGMP last-member queries, in units of seconds. The effective range is 1 to 5.
Use the igmp-snooping last-member-query-interval command to configure the interval between IGMP last-member queries in the VLAN.
Use the undo igmp-snooping last-member-query-interval command to restore the default setting.
By default, the IGMP last-member query interval is 1 second.
Related commands: last-member-query-interval.
# Set the interval between IGMP last-member queries to 3 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
View
VLAN view
interval: Maximum response time to IGMP general queries, in units of seconds. The effective range is 1 to 25.
Use the igmp-snooping max-response-time command to configure the maximum response time to IGMP general queries in the VLAN.
Use the undo igmp-snooping max-response-time command to restore the default setting.
By default, the maximum response time to IGMP general queries is 10 seconds.
Related commands: max-response-time, igmp-snooping query-interval.
# Set the maximum response time to IGMP general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
View
Use the igmp-snooping overflow-replace command to enable the multicast group replacement function on the current port(s).
Use the undo igmp-snooping overflow-replace command to disable the multicast group replacement function on the current port(s).
By default, the multicast group replacement function is disabled.
Note that:
Related commands: overflow-replace.
# Enable the multicast group replacement function on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
1.1.18 igmp-snooping querier
undo igmp-snooping querier
View
VLAN view
None
Use the igmp-snooping querier command to enable the IGMP Snooping querier function.
Use the undo igmp-snooping querier command to disable the IGMP Snooping querier function.
By default, the IGMP Snooping querier function is disabled.
# Enable the IGMP Snooping querier function in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
igmp-snooping query-interval interval
undo igmp-snooping query-interval
View
VLAN view
interval: Interval between IGMP general queries, in units of seconds. The effective range is 2 to 300.
Use the igmp-snooping query-interval command to configure the interval between IGMP general queries.
Use the undo igmp-snooping query-interval command to restore the default setting.
By default, the IGMP general query interval is 60 seconds.
Related commands: igmp-snooping querier, igmp-snooping max-response-time, max-response-time.
# Set the interval between IGMP general queries to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
View
VLAN view
interval: Router port aging time, in units of seconds. The effective range is 1 to 1,000.
Use the igmp-snooping router-aging-time command to configure the aging time of router ports in the current VLAN.
Use the undo igmp-snooping router-aging-time command to restore the default setting.
By default, the aging time of router ports is 105 seconds.
Related commands: router-aging-time.
# Set the aging time of router ports to 100 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
undo igmp-snooping source-deny
View
None
Use the igmp-snooping source-deny command to enable multicast source port filtering.
Use the undo igmp-snooping source-deny command to disable multicast source port filtering.
By default, multicast source port filtering is disabled.
# Enable source port filtering for multicast data on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp-snooping source-deny
igmp-snooping special-query source-ip { current-interface | ip-address }
undo igmp-snooping special-query source-ip
View
VLAN view
current-interface: Sets the source address of IGMP group-specific queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP group-specific queries.
ip-address: Sets the source address of IGMP group-specific queries to the specified address.
Use the igmp-snooping special-query source-ip command to configure the source IP address of IGMP group-specific queries.
Use the undo igmp-snooping special-query source-ip command to restore the default configuration.
By default, the source IP address of IGMP group-specific queries is 0.0.0.0.
# Set the IP address of the interface of VLAN 2 to 10.1.1.1, with the subnet mask of 255.255.255.0, and specify this IP address as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip current-interface
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
View
group-address: Address of the multicast group to be statically joined, in the range of 224.0.0.0 to 239.255.255.255.
source-address: Address of multicast source to be statically joined. The value of this argument should be a valid unicast address or 0.0.0.0. If the value is 0.0.0.0, this means no multicast source is specified.
Use the igmp-snooping static-group command to enable the static (*, G) or (S, G) joining function, namely to configure the current port or port group as static multicast group or source-group member(s).
Use the undo igmp-snooping static-group command to disable the static (*, G) or (S, G) joining function.
Note that:
l The source-ip source-address option in the command is meaningful only for IGMP Snooping version 3. If IGMP Snooping version 2 is running, although you can include the source-ip source-address option in your command, the configuration will not take effect.
# Configure GigabitEthernet 1/0/1 in VLAN 2 to be a static member port for (1.1.1.1, 224.1.1.1).
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-group 224.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
View
vlan vlan-id: Specifies a VLAN in which one or more static router ports are to be configured, where vlan-id is in the range of 1 to 4094.
Use the igmp-snooping static-router-port command to enable the static router port function.
Use the undo igmp-snooping static-router-port command to disable the static router port function.
By default, the static router port function is not enabled.
Note that:
# Enable the static router port function on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
1.1.25 igmp-snooping version
igmp-snooping version version-number
undo igmp-snooping version
View
VLAN view
version-number: IGMP snooping version, in the range of 2 to 3.
Use the igmp-snooping version command to configure the IGMP Snooping version.
Use the undo igmp-snooping version command to restore the default setting.
By default, the IGMP version is 2.
This command can take effect only if IGMP Snooping is enabled in the VLAN.
# Enable IGMP Snooping in VLAN 2, and set the IGMP Snooping version to version 3.
[Sysname] vlan 2
undo last-member-query-interval
View
IGMP-Snooping view
Use the last-member-query-interval command to configure the interval between IGMP last-member queries globally.
Use the undo last-member-query-interval command to restore the default setting.
By default, the interval between IGMP last-member queries is 1 second.
Related commands: igmp-snooping last-member-query-interval.
# Set the interval between IGMP last-member queries globally to 3 seconds.
[Sysname-igmp-snooping] last-member-query-interval 3
1.1.27 max-response-time
undo max-response-time
View
IGMP-Snooping view
Use the max-response-time command to configure the maximum response time to IGMP general queries globally.
Use the undo max-response-time command to restore the default value.
Related commands: igmp-snooping max-response-time, igmp-snooping query-interval.
# Set the maximum response time to IGMP general queries globally to 5 seconds.
[Sysname-igmp-snooping] max-response-time 5
1.1.28 overflow-replace
undo overflow-replace [ vlan vlan-list ]
View
IGMP-Snooping view
Use the overflow-replace command to enable the multicast group replacement function globally.
Use the undo overflow-replace command to disable the multicast group replacement function globally.
Note that:
Related commands: igmp-snooping overflow-replace.
# Enable the multicast group replacement function globally in VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
1.1.29 report-aggregation
report-aggregation
undo report-aggregation
View
IGMP-Snooping view
None
Use the report-aggregation command to enable IGMP report suppression.
Use the undo report-aggregation command to disable IGMP report suppression.
By default, IGMP report suppression is enabled.
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
View
group-address: Address of the multicast group for which the IGMP Snooping forwarding entries are to be cleared. The value range is 224.0.1.0 to 239.255.255.255.
all: Specifies to clear all IGMP Snooping forwarding entries.
vlan vlan-id: Specifies a VLAN in which all IGMP Snooping forwarding entries are to be cleared, where vlan-id is in the range of 1 to 4094.
Use the reset igmp-snooping group command to clear IGMP Snooping forwarding entries.
Note that:
l This command works only on IGMP Snooping–enabled VLANs, but not on VLANs with IGMP enabled on the corresponding VLAN interfaces.
l This command cannot clear IGMP Snooping forwarding entries of static joins.
# Clear all IGMP Snooping forwarding entries saved in the switch.
<Sysname> reset igmp-snooping group all
View
None
Use the reset igmp-snooping statistics command to clear the statistics information of IGMP messages learned by IGMP Snooping.
# Clear the statistics information of all kinds of IGMP messages learned by IGMP Snooping.
<Sysname> reset igmp-snooping statistics
1.1.32 router-aging-time
undo router-aging-time
View
IGMP-Snooping view
Use the router-aging-time command to configure the aging time of router ports globally.
Use the undo router-aging-time command to restore the default setting.
Related commands: igmp-snooping router-aging-time.
# Set the aging time of router ports globally to 100 seconds.
[Sysname-igmp-snooping] router-aging-time 100
1.1.33 source-deny
undo source-deny port interface-list
View
IGMP-Snooping view
interface-list: Ethernet port list. You can specify multiple Ethernet ports or port ranges by providing the this argument in the form of interface-list = { interface-type interface-number [ to interface-type interface-number ] }, where interface-type is port type and interface-number is port number.
Use the source-deny command to enable multicast source port filtering so that all multicast data packets are blocked.
Use the undo source-deny command to disable multicast source port filtering.
By default, multicast source port filtering is not enabled.
# Enable source port filtering for multicast data on interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5.
source-deny port GigabitEthernet1/0/1 to
GigabitEthernet1/0/5
display mld-snooping group [ vlan vlan-id ] [ verbose ]
View
vlan vlan-id: Displays the IPv6 multicast group information in the specified VLAN, where vlan-id is in the range of 1 to 4094. If you do not specify a VLAN, this command will display the information of IPv6 multicast groups in all VLANs.
verbose: Displays the detailed IPv6 multicast group information.
Use the display mld-snooping group command to view the IPv6 multicast group information learned by MLD Snooping.
# View the detailed information of IPv6 multicast groups in VLAN 2 learned by MLD Snooping.
<Sysname> display mld-snooping group vlan 2 verbose
Vlan(id):2.
IP group address:FF1E::101
(::, FF1E::101):
MAC group(s):
MAC group address:3333-0000-0101
GE1/0/1
Table 2-1 Description on the fields of the display mld-snooping group command
Total number of IPv6 multicast sources |
Router port(s) |
IP group address |
Address of IPv6 multicast group |
MAC group address |
Attribute |
Attribute of IPv6 multicast group |
Host port(s) |
View
None
Use the display mld-snooping statistics command to view the statistics information of MLD messages learned by MLD Snooping.
# View the statistics information of all kinds of MLD messages learned by MLD Snooping.
<Sysname> display mld-snooping statistics
Received MLD general queries:0.
Received MLDv1 specific queries:0.
Received MLDv1 reports:0.
Received MLD dones:0.
Sent MLDv1 specific queries:0.
Received MLDv2 reports:0.
Received MLDv2 reports with right and wrong records:0.
Received MLDv2 specific queries:0.
Received MLDv2 specific sg queries:0.
Sent MLDv2 specific queries:0.
Sent MLDv2 specific sg queries:0.
Received error MLD messages:0.
Table 2-2 Description on the fields of the display mld-snooping statistics command
general queries |
specific queries |
reports |
Report messages |
dones |
Done messages |
Reports containing correct and incorrect records |
specific sg queries |
Source-and-group-specific queries |
error MLD messages |
Error MLD messages |
2.1.3 fast-leave
View
MLD-Snooping view
Use the fast-leave command to enable fast leave processing globally.
Use the undo fast-leave command to disable fast leave processing globally.
By default, fast leave processing is disabled globally.
Note that:
Related commands: mld-snooping fast-leave.
# Enable fast leave processing globally in VLAN 2.
[Sysname] mld-snooping
[Sysname-mld-snooping] fast-leave vlan 2
2.1.4 group-policy
group-policy acl6-number [ vlan vlan-list ]
View
MLD-Snooping view
Acl6-number: Basic IPv6 ACL number, in the range of 2000 to 2999.
Use the group-policy command to configure a global IPv6 multicast group filter.
Use the undo group-policy command to remove the configured global IPv6 multicast group filter.
By default, no IPv6 multicast group filter is configured globally, namely any host can join any IPv6 multicast group.
Note that:
l If the specified IPv6 ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
l You can configure different IPv6 ACL rules for each port in different VLANs; for a given VLAN, a newly configured IPv6 ACL rule will override the existing one.
Related commands: mld-snooping group-policy.
# Configure ACL 2000 as the IPv6 multicast group filter in VLAN 2.
[Sysname-mld-snooping] group-policy 2000 vlan 2
2.1.5 host-aging-time
View
MLD-Snooping view
Use the host-aging-time command to configure the global aging time of group member ports.
By default, the aging time of member ports is 260 seconds.
Related commands: mld-snooping host-aging-time.
[Sysname-mld-snooping] host-aging-time 300
undo last-listener-query-interval
View
MLD-Snooping view
interval: MLD last listener query interval in units of seconds, namely the length of time the device waits between sending MLD multicast-address-specific queries. The effective range is 1 to 5.
Use the last-listener-query-interval command to configure the MLD last listener query interval globally.
Use the undo last-listener-query-interval command to restore the system default.
By default, the MLD last listener query interval is 1 second.
Related commands: mld-snooping last-listener-query-interval.
# Set the MLD last listener query interval to 3 seconds globally.
[Sysname-mld-snooping] last-listener-query-interval 3
2.1.7 max-response-time
View
MLD-Snooping view
interval: Maximum response time for MLD general queries, in units of seconds. The effective range is 1 to 25.
Use the max-response-time command to configure the maximum response time for MLD general queries globally.
Use the undo max-response-time command to restore the system default.
By default, the maximum response time for MLD general queries is 10 seconds.
Related commands: mld-snooping max-response-time, mld-snooping query-interval.
# Set the maximum response time for MLD general queries globally to 5 seconds.
[Sysname-mld-snooping] max-response-time 5
2.1.8 mld-snooping
mld-snooping
undo mld-snooping
View
None
Use the mld-snooping command to enable MLD Snooping globally and enter MLD-Snooping view.
Use the undo mld-snooping command to disable MLD Snooping globally.
By default, MLD Snooping is disabled.
Related commands: mld-snooping enable.
# Enable MLD Snooping globally and enter MLD-Snooping view.
undo mld-snooping drop-unknown
View
VLAN view
None
Use the mld-snooping drop-unknown command to enable dropping unknown IPv6 multicast data in the current VLAN.
Use the undo mld-snooping drop-unknown command to disable dropping unknown IPv6 multicast data in the current VLAN.
By default, this function is disabled, unknown IPv6 multicast data is flooded in the VLAN.
This command takes effect only if MLD Snooping is enabled in the VLAN.
# Enable dropping unknown IPv6 multicast data in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
2.1.10 mld-snooping enable
mld-snooping enable
undo mld-snooping enable
View
VLAN view
None
Use the mld-snooping enable command to enable MLD Snooping in the current VLAN.
Use the undo mld-snooping enable command to disable MLD Snooping in the current VLAN.
By default, MLD Snooping is disabled in a VLAN.
MLD Snooping must be enabled globally before it can be enabled in a VLAN
Related commands: mld-snooping.
# Enable MLD Snooping in VLAN 2.
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
undo mld-snooping fast-leave [ vlan vlan-list ]
View
Use the mld-snooping fast-leave command to enable fast leave processing on the current port or group of ports.
Use the undo mld-snooping fast-leave command to disable fast leave processing on the current port or group of ports.
By default, fast leave processing is disabled.
Note that:
l If you do not specify any VLAN when you use this command in port group view, the command will take effect for all the ports in this group no matter which VLANs these port belong to; if you specify a VLAN or multiple VLANs, the command will take effect for those ports in this group that belong to the specified VLAN(s).
# Enable fast leave processing on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mld-snooping fast-leave vlan 2
mld-snooping general-query source-ip { current-interface | ipv6-address }
undo mld-snooping general-query source-ip
View
VLAN view
current-interface: Sets the source IPv6 link-local address of MLD general queries to the IPv6 address of the current VLAN interface. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 will be used as the source IPv6 address of MLD general queries.
ipv6-address: Specifies the source IPv6 address of MLD general queries, which can be any legal IPv6 link-local address.
Use the mld-snooping general-query source-ip command to configure the source IPv6 address of MLD general queries.
Use the undo mld-snooping general-query source-ip command to restore the default configuration.
By default, the source IPv6 address of MLD general queries is FE80::02FF:FFFF:FE00:0001.
# In VLAN 2, specify FE80:0:0:1::1 as the source IPv6 address of MLD general queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
undo mld-snooping group-limit [ vlan vlan-list ]
View
limit: Maximum number of IPv6 multicast groups that can be joined on a port. The effective range is 1 to 128.
vlan vlan-list: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094. If you do not provide this option, the command will take effect respectively for each VLAN to which this port belongs.
Use the undo mld-snooping group-limit command to restore the default setting.
By default, the default setting is 128.
l If you do not specify any VLAN in Ethernet port view, the command will take effect for the port no matter which VLAN the port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect for the port only if the port belongs to the specified VLAN(s).
l If you do not specify any VLAN in port group view, the command will take effect for all the ports in this group no matter which VLANs these ports belong to; if you specify a VLAN or multiple VLANs, the command will take effect for those ports in this group that belong to the specified VLAN(s).
# Specify to allow a maximum of 10 IPv6 multicast groups that can be joined on GigabitEthernet 1/0/1 in VLAN 2. GigabitEthernet 1/0/1 belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mld-snooping group-limit 10 vlan 2
mld-snooping group-policy acl6-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
View
acl6-number: Basic IPv6 ACL number, in the range of 2000 to 2999.
Use the mld-snooping group-policy command to configure an IPv6 multicast group filter on the current port(s).
Use the undo mld-snooping group-policy command to remove the configured IPv6 multicast group filter on the current port(s).
By default, no IPv6 multicast group filter is configured on a port, namely a host can join any IPv6 multicast group.
Note that:
l If you do not specify any VLAN in port group view, the command will take effect for all the ports in this group no matter which VLANs these port belong to; if you specify a VLAN or multiple VLANs, the command will take effect for those ports in this group that belong to the specified VLAN(s).
l If the specified ACL does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
# Configure ACL 2000 as the IPv6 multicast group filter on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mld-snooping group-policy 2000 vlan 2
mld-snooping host-aging-time interval
undo mld-snooping host-aging-time
View
VLAN view
Use the mld-snooping host-aging-time command to configure the aging time of group member ports in the current VLAN.
Use the undo mld-snooping host-aging-time command to restore the system default.
By default, the member port aging time is 260 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
2.1.16 mld-snooping host-join
undo mld-snooping host-join ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
ipv6-group-address: Address of IPv6 multicast group which the simulated host is to join. The effective range is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
ipv6-source-address: Address of the IPv6 multicast source that the simulated host is to join.
vlan vlan-id: Specifies a VLAN that comprises the Ethernet port(s), where vlan-id is in the range of 1 to 4094.
Use the mld-snooping host-join command to enable the simulated IPv6 (*, G) or (S, G) joining function, namely to configure the current port or port group as simulated IPv6 multicast group or source-group member(s).
Use the undo mld-snooping host-join command to disable the simulated IPv6 (*, G) or (S, G) joining function.
Note that:
l The source-ip ipv6-source-address option in the command is meaningful only for MLD Snooping version 2. If MLD Snooping version 1 is running, although you can include source-ip ipv6-source-address in your command, the simulated host responses with only an MLDv1 report when receiving a query message.
# Configure GigabitEthernet 1/0/1 in VLAN 2 to join (2002::22, FF1E::101) as a simulated host.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
[Sysname-GigabitEthernet1/0/1] mld-snooping host-join ff1e::101 source-ip 2002::22 vlan 2
undo mld-snooping last-listener-query-interval
View
VLAN view
interval: MLD last listener query interval in units of seconds, namely the length of time the device waits between sending IGMP multicast-address-specific queries. The effective range is 1 to 5.
Use the mld-snooping last-listener-query-interval command to configure the MLD last-listener query interval in the VLAN.
Use the undo mld-snooping last-listener-query-interval command to restore the system default.
Related commands: last-listener-query-interval.
# Set the MLD last-listener query interval to 3 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
mld-snooping max-response-time interval
undo mld-snooping max-response-time
View
VLAN view
Use the mld-snooping max-response-time command to configure the maximum response time for MLD general queries in the VLAN.
Use the undo mld-snooping max-response-time command to restore the default setting.
Related commands: max-response-time, mld-snooping query-interval.
# Set the maximum response time for MLD general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
undo mld-snooping overflow-replace [ vlan vlan-list ]
View
Use the mld-snooping overflow-replace command to enable the IPv6 multicast group replacement function on the current port(s).
Use the undo mld-snooping overflow-replace command to disable the IPv6 multicast group replacement function on the current port(s).
By default, the IPv6 multicast group replacement function is disabled.
Note that:
# Enable the IPv6 multicast group replacement function on GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mld-snooping overflow-replace vlan 2
2.1.20 mld-snooping querier
undo mld-snooping querier
View
VLAN view
None
Use the mld-snooping querier command to enable the MLD Snooping querier function.
Use the undo mld-snooping querier command to disable the MLD Snooping querier function.
By default, the MLD Snooping querier function is disabled.
# Enable the MLD Snooping querier function in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
undo mld-snooping query-interval
View
VLAN view
interval: MLD query interval in seconds, namely the length of time the device waits between sending MLD general queries. The effective range is 2 to 300.
Use the mld-snooping query-interval command to configure the MLD query interval.
Use the undo mld-snooping query-interval command to restore the system default.
By default, the MLD query interval is 125 seconds.
Related commands: mld-snooping querier, mld-snooping max-response-time, max-response-time.
# Set the MLD query interval to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
mld-snooping router-aging-time interval
undo mld-snooping router-aging-time
View
VLAN view
Use the mld-snooping router-aging-time command to configure the aging time of router ports in the current VLAN.
Use the undo mld-snooping router-aging-time command to restore the default setting.
By default, the router port aging time is 260 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
undo mld-snooping source-deny
View
None
Use the mld-snooping source-deny command to enable IPv6 multicast source port filtering.
Use the undo mld-snooping source-deny command to disable IPv6 multicast source port filtering.
By default, IPv6 multicast source port filtering is disabled.
# Enable source port filtering for IPv6 multicast data on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mld-snooping source-deny
mld-snooping special-query source-ip { current-interface | ipv6-address }
undo mld-snooping special-query source-ip
View
VLAN view
current-interface: Specifies the source IPv6 link-local address of the VLAN interface of the current VLAN as the source IPv6 address of MLD multicast-address-specific queries. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 will be used as the source IPv6 address of MLD multicast-address-specific queries.
ipv6-address: Specifies an IPv6 link-local address as the source IPv6 address of MLD multicast-address-specific queries.
Use the mld-snooping special-query source-ip command to configure the source IPv6 address of MLD multicast-address-specific queries.
Use the undo mld-snooping special-query source-ip command to restore the default configuration.
By default, the source IPv6 address of MLD multicast-address-specific queries is FE80::02FF:FFFF:FE00:0001.
# In VLAN 2, specify FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
undo mld-snooping static-group ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
View
ipv6-group-address: Address of a IPv6 multicast group the port(s) will be configured to join as static member port(s). The effective range is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
ipv6-source-address: Address of the IPv6 multicast source the port(s) will be configured to join as static member port(s).
Use the mld-snooping static-group command to enable the static IPv6 (*, G) or (S, G) joining function, namely to configure the port or port group as static IPv6 multicast group or source-group member(s).
Use the undo mld-snooping static-group command to disable the static member port function.
By default, the static member port function is disabled.
Note that:
# Configure GigabitEthernet 1/0/1 in VLAN 2, to be a static member port for (2002::22, FF1E::101).
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] mld-snooping static-group ff1e::101 source-ip 2002::22 vlan 2
undo mld-snooping static-router-port vlan vlan-id
View
Use the mld-snooping static-router-port command to enable the static router port function.
Use the undo mld-snooping static-router-port command to disable the static router port function.
By default, the static router port function is disabled.
Note that:
[Sysname-GigabitEthernet1/0/1] mld-snooping static-router-port vlan 2
2.1.27 mld-snooping version
undo mld-snooping version
View
VLAN view
version-number: MLD snooping version, in the range of 2 to 3.
Use the mld-snooping version command to configure the MLD Snooping version.
Use the undo mld-snooping version command to restore the default setting.
By default, the MLD version is 1.
This command can take effect only if MLD Snooping is enabled in the VLAN.
# Enable MLD Snooping in VLAN 2, and set the MLD Snooping version to version 2.
[Sysname] vlan 2
2.1.28 overflow-replace
View
MLD-Snooping view
Use the overflow-replace command to enable the IPv6 multicast group replacement function globally.
Use the undo overflow-replace command to disable the IPv6 multicast group replacement function globally.
By default, the IPv6 multicast group replacement function is disabled globally.
Note that:
Related commands: mld-snooping overflow-replace.
# Enable the IPv6 multicast group replacement function globally in VLAN 2.
[Sysname-mld-snooping] overflow-replace vlan 2
2.1.29 report-aggregation
report-aggregation
View
MLD-Snooping view
None
Use the mld-snooping report-aggregation command to enable MLD report suppression.
Use the undo mld-snooping report-aggregation command to disable MLD report suppression.
By default, MLD report suppression is enabled.
# Disable MLD report suppression.
[Sysname-mld-snooping] undo mld-snooping report-aggregation
reset mld-snooping group { ipv6-group-address | all } [ vlan vlan-id ]
View
ipv6-group-address: Address of the IPv6 multicast group of which the MLD Snooping forwarding entries are to be cleared. The effective range is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
all: Specifies to clear all MLD Snooping entries.
vlan vlan-id: Specifies a VLAN in which all MLD Snooping entries are to be cleared, where vlan-id is in the range of 1 to 4094.
Use the reset mld-snooping group command to clear MLD Snooping entries.
Note that:
This command cannot clear MLD Snooping entries of static joins.
# Clear all MLD Snooping entries saved in the switch.
<Sysname> reset mld-snooping group all
View
None
Use the reset mld-snooping statistics command to clear the statistics information of MLD messages learned by MLD Snooping.
# Clear the statistics information of all kinds of MLD messages learned by MLD Snooping.
<Sysname> reset mld-snooping statistics
2.1.32 router-aging-time
View
MLD-Snooping view
Related commands: mld-snooping router-aging-time.
[Sysname-mld-snooping] router-aging-time 100
2.1.33 source-deny
View
MLD-Snooping view
Use the source-deny command to enable IPv6 multicast source port filtering, namely to filter out all the received IPv6 multicast packets.
Use the undo source-deny command to disable IPv6 multicast source port filtering.
# Enable source port filtering for IPv6 multicast data on interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5.
source-deny port GigabitEthernet 1/0/1 to
3.1.1 display multicast-vlan
display multicast-vlan [ vlan-id ]
View
vlan-id: VLAN ID of a multicast VLAN, in the range of 1 to 4094. If this argument is not provided, the information about all multicast VLANs and their sub-VLANs will be displayed.
Use the display multicast-vlan command to view the information about the specified multicast VLAN and its sub-VLANs.
# View the information about all multicast VLANs and their sub-VLANs.
<Sysname> display multicast-vlan
multicast vlan 100's subvlan list:
vlan 2 4-8
3.1.2 multicast-vlan enable
multicast-vlan vlan-id enable
undo multicast-vlan vlan-id enable
View
vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094.
Use the multicast-vlan enable command to configure the specified VLAN as a multicast VLAN.
Use the undo multicast-vlan enable command to remove the specified VLAN as a multicast VLAN.
No VLAN is a multicast VLAN by default.
Note that:
l The specified VLAN must exist.
l The multicast VLAN feature cannot be enabled on a device with IP multicast routing enabled.
l After a VLAN is configured into a multicast VLAN, IGMP Snooping must be enabled in the VLAN before the multicast VLAN feature can be implemented, while it is not necessary to enable IGMP Snooping in the sub-VLANs of the multicast VLAN.
# Configure VLAN 100 as a multicast VLAN.
[Sysname] multicast-vlan 100 enable
3.1.3 multicast-vlan subvlan
multicast-vlan vlan-id subvlan vlan-list
undo multicast-vlan vlan-id subvlan vlan-list
View
vlan-id: VLAN ID of a multicast VLAN, in the range 1 to 4094.
subvlan vlan-list: Defines one or multiple VLANs as sub-VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The effective range of a VLAN ID is 1 to 4094.
Use the multicast-vlan subvlan command to configure sub-VLAN(s) for the specified multicast VLAN.
Use the undo multicast-vlan subvlan command to remove the specified sub-VLAN(s) from the specified multicast VLAN.
A multicast VLAN has no sub-VLANs by default.
Note that:
l The VLAN to be configured as the multicast VLAN and the VLANs to be configured as sub-VLANs of the multicast VLAN must exist.
l The number of sub-VLANs of the multicast VLAN must not exceed the system-defined limit (an S5500-SI series Ethernet switch supports a maximum of one multicast VLAN and 63 sub-VLANs).
# Configure VLAN 10 through VLAN 15 as sub-VLANs of multicast VLAN 100.
[Sysname] multicast-vlan 100 subvlan 10 to 15
display multicast-vlan ipv6 [ vlan-id ]
View
vlan-id: VLAN ID of an IPv6 multicast VLAN, in the range of 1 to 4094. If this argument is not provided, the information about all IPv6 multicast VLANs and their sub-VLANs will be displayed.
Use the display multicast-vlan ipv6 command to view the information about the specified IPv6 multicast VLAN and its sub-VLANs.
# View the information about all IPv6 multicast VLANs and their sub-VLANs.
<Sysname> display multicast-vlan ipv6
IPv6 multicast vlan 100's subvlan list:
vlan 2 4-8
multicast-vlan ipv6 vlan-id enable
undo multicast-vlan ipv6 vlan-id enable
View
Use the multicast-vlan ipv6 enable command to configure the specified VLAN as an IPv6 multicast VLAN.
Use the undo multicast-vlan ipv6 enable command to remove the specified VLAN as an IPv6 multicast VLAN.
By default, no VLAN is an IPv6 multicast VLAN.
Note that:
l You cannot enable IPv6 multicast VLAN on a device with IPv6 multicast routing enabled.
l After a VLAN is configured into an IPv6 multicast VLAN, MLD Snooping must be enabled in the VLAN before the IPv6 multicast VLAN feature can be implemented, while it is not necessary to enable MLD Snooping in the sub-VLANs of the IPv6 multicast VLAN.
# Configure VLAN 100 as an IPv6 multicast VLAN.
[Sysname] multicast-vlan ipv6 100 enable
multicast-vlan ipv6 vlan-id subvlan vlan-list
undo multicast-vlan ipv6 vlan-id subvlan vlan-list
View
vlan-id: Specifies an IPv6 multicast VLAN by its ID, in the range of 1 to 4094.
Use the multicast-vlan ipv6 subvlan command to configure sub-VLAN(s) for the specified IPv6 multicast VLAN.
Use the undo multicast-vlan ipv6 subvlan command to remove the specified sub-VLAN(s) from the specified IPv6 multicast VLAN.
By default, an IPv6 multicast VLAN has no sub-VLANs.
Note that:
l The VLAN to be configured as an IPv6 multicast VLAN and the VLANs to be configured as sub-VLANs of the IPv6 multicast VLAN must exist.
l The total number of sub VLANs of an IPv6 multicast VLAN must not exceed the system-defined limit (an S5500-SI series Ethernet switch supports a maximum of one multicast VLAN and 63 sub-VLANs).
# Configure VLANs 10 through 15 as sub-VLANs of IPv6 multicast VLAN 100.
[Sysname] multicast-vlan ipv6 100 subvlan 10 to 15
