16-VXLAN命令参考
01-VXLAN命令
本章节下载 01-VXLAN命令  (809.90 KB)
01-VXLAN命令
目
1 VXLAN
1.1 VXLAN基础配置命令
1.1.1 ac statistics enable
1.1.2 arp suppression enable
1.1.3 arp suppression mode
1.1.4 description
1.1.5 display arp suppression vsi
1.1.6 display ipv6 nd suppression vsi
1.1.7 display l2vpn m-lag arp
1.1.8 display l2vpn m-lag arp suppression
1.1.9 display l2vpn m-lag mac-address
1.1.10 display l2vpn m-lag nd
1.1.11 display l2vpn m-lag nd suppression
1.1.12 display l2vpn mac-address
1.1.13 display l2vpn mac-address mac-move
1.1.14 display l2vpn service-instance
1.1.15 display l2vpn vsi
1.1.16 display vxlan tunnel
1.1.17 display vxlan tunnel-interface
1.1.18 display vxlan tunnel termination
1.1.19 encapsulation
1.1.20 flooding disable
1.1.21 ipv6 nd suppression enable
1.1.22 ipv6 nd suppression mode
1.1.23 l2vpn enable
1.1.24 l2vpn statistics interval
1.1.25 mac-address static vsi
1.1.26 mac-based ac
1.1.27 overlay oam enable
1.1.28 ping vxlan
1.1.29 reserved vxlan
1.1.30 reset arp suppression vsi
1.1.31 reset ipv6 nd suppression vsi
1.1.32 reset l2vpn mac-address
1.1.33 reset l2vpn mac-address mac-move
1.1.34 reset l2vpn statistics ac
1.1.35 reset l2vpn statistics vsi
1.1.36 selective-flooding mac-address
1.1.37 service-instance
1.1.38 shutdown
1.1.39 statistics enable (Ethernet service instance view)
1.1.40 statistics enable (Tunnel interface view)
1.1.41 statistics enable (VSI view)
1.1.42 tracert vxlan
1.1.43 tunnel
1.1.44 tunnel global source-address
1.1.45 tunnel statistics vxlan auto
1.1.46 vsi
1.1.47 vxlan
1.1.48 vxlan default-decapsulation enable
1.1.49 vxlan default-decapsulation source
1.1.50 vxlan invalid-vlan-tag discard
1.1.51 vxlan ipv6 default-decapsulation enable
1.1.52 vxlan ipv6 default-decapsulation source
1.1.53 vxlan local-mac report
1.1.54 vxlan tunnel mac-learning disable
1.1.55 vxlan udp-port
1.1.56 vxlan vlan-based
1.1.57 vxlan vni
1.1.58 xconnect vsi
1.2 VXLAN IP网关配置命令
1.2.1 arp distributed-gateway dynamic-entry synchronize
1.2.2 arp send-rate
1.2.3 bandwidth
1.2.4 default
1.2.5 description
1.2.6 display interface vsi-interface
1.2.7 distributed-gateway local
1.2.8 gateway subnet
1.2.9 gateway vsi-interface
1.2.10 interface vsi-interface
1.2.11 ipv6 nd distributed-gateway dynamic-entry synchronize
1.2.12 mac-address
1.2.13 mtu
1.2.14 reset counters interface vsi-interface
1.2.15 shutdown
1.2.16 vtep group member local
1.2.17 vtep group member remote
1.2.18 vxlan tunnel arp-learning disable
1.2.19 vxlan tunnel nd-learning disable
1.3 OVSDB-VTEP配置命令
1.3.1 ovsdb server bootstrap ca-certificate
1.3.2 ovsdb server enable
1.3.3 ovsdb server pki domain
1.3.4 ovsdb server pssl
1.3.5 ovsdb server ptcp
1.3.6 ovsdb server ssl
1.3.7 ovsdb server tcp
1.3.8 vtep access port
1.3.9 vtep acl disable
1.3.10 vtep enable
1 VXLAN
仅以下端口支持VXLAN功能:
·     LSCM2系列SC主控板的业务端口
·     LSCM2SRP6C4Y06A0主控板的业务端口
·     SF系列接口板的所有端口
·     SD系列接口板的所有端口
1.1  VXLAN基础配置命令
ac statistics enable命令用来开启VLAN下对应AC的统计功能。
undo ac statistics enable命令用来关闭VLAN下对应AC的统计功能。
VLAN下对应AC的统计功能处于关闭状态。
VLAN视图
采用VLAN与VXLAN关联方式时,开启VLAN下对应AC的统计功能后,可以对该VLAN下自动生成的AC进行报文统计。
开启本功能前,必须先执行vxlan vlan-based命令开启VLAN关联VXLAN功能。
# 配置VLAN 10关联VXLAN 100,并开启VLAN 10下对应AC的统计功能。
[Sysname] vxlan vlan-based
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
[Sysname-vlan10] ac statistics enable
·     display l2vpn service-instance
·     reset l2vpn statistics ac
·     vxlan vlan-based
arp suppression enable命令用来开启ARP泛洪抑制功能。
undo arp suppression enable命令用来关闭ARP泛洪抑制功能。
VSI视图:
arp suppression enable [ no-broadcast ]
VLAN视图:
ARP泛洪抑制功能处于关闭状态。
VSI视图
VLAN视图
no-broadcast:表示没有对应的ARP泛洪抑制表项时不泛洪ARP请求。
应用场景
在网络中出现过多的ARP报文时,会导致设备CPU负载加重,影响设备正常处理用户的其它业务。为了避免广播发送的ARP请求报文过多占用核心网络带宽,用户可以在VTEP上开启ARP泛洪抑制功能,保证整个核心网络通信的正常运行。
工作机制
开启本功能后,VTEP从本地站点、VXLAN隧道接收到ARP请求和ARP应答报文后,会根据该报文在本地建立ARP泛洪抑制表项。后续当VTEP收到本站点内虚拟机请求其它虚拟机MAC地址的ARP请求时,优先根据ARP泛洪抑制表项进行代答。如果没有对应的ARP泛洪抑制表项且开启ARP泛洪抑制功能时未配置no-broadcast参数,则将ARP请求泛洪到核心网。ARP泛洪抑制功能可以大大减少ARP泛洪的次数。
# 在VSI vsi1下开启ARP泛洪抑制功能,且没有对应的ARP泛洪抑制表项时不泛洪ARP请求。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable no-broadcast
# 在VLAN 1下开启ARP泛洪抑制功能。
[Sysname] vlan 1
[Sysname-vlan1] arp suppression enable
·     arp suppression mode
·     display arp suppression vsi
·     reset arp suppression vsi
arp suppression mode命令用来配置ARP泛洪抑制模式。
undo arp suppression mode命令用来恢复缺省情况。
arp suppression mode { proxy-reply | unicast-forward } [  mismatch-discard ]
开启ARP泛洪抑制功能后,ARP泛洪抑制模式为设备代答模式。当ARP请求报文的目标IP地址不是本端设备的IP地址,且不能匹配本端设备的ARP泛洪抑制表项时,广播转发ARP请求报文。
VSI视图
proxy-reply:设备代答模式,即当ARP请求报文请求的目标IP地址不是本端设备的IP地址,且目标IP地址匹配本端设备的ARP泛洪抑制表项时,本端设备不转发ARP请求报文,而是直接代替目标IP对应的设备回应ARP应答报文。此ARP应答报文的发送端IP地址为ARP请求报文的目标IP地址,ARP应答报文内部的发送端MAC地址和链路层的源MAC地址均为ARP泛洪抑制表项中目标IP地址对应的MAC地址。
unicast-forward:单播转发模式,即当ARP请求报文的目标IP地址不是本端设备的IP地址,且目标IP地址匹配本端设备的ARP泛洪抑制表项时,本端设备将ARP请求报文内部的目标MAC地址和链路层的目的MAC地址均修改为泛洪抑制表项中与目标IP地址对应的MAC地址,然后单播转发ARP请求报文。
mismatch-discard:当ARP请求报文的目标IP地址不是本端设备的IP地址,且不能匹配本端设备的ARP泛洪抑制表项时,丢弃报文。如果未指定本参数,则设备将对不能匹配本端设备的ARP泛洪抑制表项的ARP请求报文进行广播转发。
使用设备代答模式时,本端不会转发ARP请求报文,占用的系统资源较少。使用单播转发模式时,虽然占用更多的系统资源,但是可以减少泛洪抑制表项未及时更新造成的ARP表项学习错误。
# 在VSI vsi1下开启ARP泛洪抑制功能,并配置ARP泛洪抑制模式为单播转发模式。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression mode unicast-forward
·     arp suppression enable
1.1.4  description
description命令用来配置VSI的描述信息。
undo description命令用来恢复缺省情况。
未配置VSI的描述信息。
VSI视图
text:VSI的描述信息,为1~80个字符的字符串,区分大小写。
# 配置名为vpn1的VSI的描述信息为“vsi for vpn1”。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
·     display l2vpn vsi
display arp suppression vsi命令用来显示VSI的ARP泛洪抑制表项信息。
(独立运行模式)
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ARP泛洪抑制表项。
slot slot-number:显示指定单板的ARP泛洪抑制表项。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的ARP泛洪抑制表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP泛洪抑制表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上的ARP泛洪抑制表项。(IRF模式)
count:显示ARP泛洪抑制表项的个数。
# 显示VSI的ARP泛洪抑制表项信息。
<Sysname> display arp suppression vsi
IP address      MAC address    VSI name                    Link ID    Aging(min)
1.1.1.2         000f-e201-0101 vsi1                        0x70000    14
1.1.1.3         000f-e201-0202 vsi1                        0x80000    18
1.1.1.4         000f-e201-0203 vsi2                        0x90000    10
# 显示VSI的ARP泛洪抑制表项个数。
<Sysname> display arp suppression vsi count
Total entries: 3
表1-1 display arp suppression vsi命令显示信息描述表
IP address
ARP泛洪抑制表项的IP地址
MAC address
ARP泛洪抑制表项的MAC地址
VSI name
VSI名称
Link ID
ARP泛洪抑制表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging(min)
ARP泛洪抑制表项的老化时间,单位为分钟
Total entries
ARP泛洪抑制表项的数目
display ipv6 nd suppression vsi命令用来显示VSI的ND泛洪抑制表项信息。
(独立运行模式)
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
display ipv6 nd suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ND泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ND泛洪抑制表项。
slot slot-number:显示指定单板的ND泛洪抑制表项。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的ND泛洪抑制表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ND泛洪抑制表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上的ND泛洪抑制表项。(IRF模式)
count:显示ND泛洪抑制表项的个数。
# 显示VSI的ND泛洪抑制表项信息。
<Sysname> display ipv6 nd suppression vsi
IPv6 address            MAC address     VSI name         Link ID    Aging (min)
1000::2                 000f-e201-0101 vsi1             0x70000    5
1000::3                 000f-e201-0202 vsi1             0x80000    5
1000::4                 000f-e201-0203 vsi2             0x90000    5
# 显示VSI的ND泛洪抑制表项个数。
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
表1-2 display ipv6 nd suppression vsi命令显示信息描述表
IPv6 address
ND泛洪抑制表项的IPv6地址
MAC address
ND泛洪抑制表项的MAC地址
VSI name
VSI名称
Link ID
ND泛洪抑制表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging (min)
ND泛洪抑制表项的老化时间,单位为分钟
Total entries
ND泛洪抑制表项的数目
·     ipv6 nd suppression enable
·     reset ipv6 nd suppression vsi
display l2vpn m-lag arp命令用来显示M-LAG设备上L2VPN的ARP信息。
display l2vpn m-lag arp [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ count | ip-address ] ]
local:显示L2VPN本地学习的ARP信息。
remote:显示L2VPN远端同步的ARP信息。
count:显示ARP表项的数目。如果不指定本参数,则显示ARP表项的具体信息。
public-instance:显示公网实例的ARP信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip-address:显示指定IP地址的ARP表项。如果不指定本参数,则显示L2VPN的所有ARP信息。
执行本命令时,如果没有指定localremote参数,则显示M-LAG设备上L2VPN本地学习和远端同步的ARP信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示M-LAG设备上公网实例和所有VPN实例的ARP信息。
# 显示M-LAG设备上公网实例和所有VPN实例的本地及远端ARP信息。
<Sysname> display l2vpn m-lag arp
Flags: D – Dynamic   L - Local   R – Remote   S – Static   I - Invalid
       G - Gateway   V - MLAG Virtual
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address      VSI index      Link ID       Flags
10.1.1.1        0003-0003-0003   0              0x1           DL
10.1.1.11       0001-0001-0001   0              0x1           DL
10.1.1.12       0001-0001-0011   0              0x2           DR
10.1.1.13       0001-0001-0021   0              0x2           DR
10.1.1.101      0001-0011-0101   0              0x1           SL
10.1.1.102      0001-0011-0102   0              0x1           SL
Public instance                               Interface: Vsi-interface2
11.1.1.1        0033-0033-0033   0              0x1           DL
11.1.1.11       0011-0011-0011   0              0x1           DL
# 显示M-LAG设备上公网实例和所有VPN实例的本地及远端ARP表项总数目。
<Sysname> display l2vpn m-lag arp count
Total number of entries: 8
表1-3 display l2vpn m-lag arp命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
VSI虚接口
IP address
IP地址
MAC address
MAC地址
VSI index
VSI索引
Link ID
ARP对应的出链路标识符,即AC或VXLAN隧道在VSI内的链路标识符
Flags
ARP表项类型,取值包括:
·     D:表示生效的ARP表项是动态学习的ARP表项
·     L:表示生效的ARP表项是本地的ARP表项
·     R:表示生效的ARP表项是对端M-LAG设备同步的ARP表项
·     S:表示生效的ARP表项是静态配置的ARP表项
·     I:表示该ARP表项无效,原因可能是:
¡     通过shutdown命令手工关闭VSI
¡     出方向Tunnel接口不存在
·     G:表示生效的ARP表项是网关的ARP表项
·     V:表示生效的ARP表项是网关接口的M-LAG虚拟ARP表项
M-LAG设备上的ARP表项总数目
display l2vpn m-lag arp suppression命令用来显示M-LAG设备上L2VPN的ARP泛洪抑制表项信息。
display l2vpn m-lag arp suppression [ local | remote ] [ count | vsi vsi-name [ count | ip-address ] ]
local:显示L2VPN本地学习的ARP泛洪抑制表项。
remote:显示L2VPN远端同步的ARP泛洪抑制表项。
count:显示ARP泛洪抑制表项的数目。如果不指定本参数,则显示ARP泛洪抑制表项的具体信息。
vsi vsi-name:显示指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ARP泛洪抑制表项。
ip-address:显示指定IP地址的ARP泛洪抑制表项。如果不指定本参数,则显示VSI所有的ARP泛洪抑制表项。
执行本命令时,如果没有指定localremote参数,则显示M-LAG设备上L2VPN本地学习和远端同步的ARP泛洪抑制表项信息。
# 显示所有VSI本地学习和远端同步的ARP泛洪抑制表项信息。
<Sysname> display l2vpn m-lag arp suppression
Flags: D - Dynamic   L – Local   R – Remote   S - Static   I – Invalid
VSI name: vpna
IP address      MAC address     Link ID         Flags
10.1.1.12       0002-0002-0002  0x1             DL
10.1.1.13       0002-0002-0002  0x2             RI
10.1.1.101      0001-0011-0101  0x2             SR
# 显示所有VSI本地学习和远端同步的ARP泛洪抑制表项总数。
<Sysname> display l2vpn m-lag arp suppression count
Total number of entries: 3
表1-4 display l2vpn m-lag arp suppression命令显示信息描述表
VSI name
VSI名称
IP address
IP地址
MAC address
MAC地址
Link ID
ARP泛洪抑制表项对应的出链路标识符,即AC或VXLAN隧道在VSI内的链路标识符
Flags
ARP泛洪抑制表项类型,取值包括:
·     D:表示生效的ARP泛洪抑制表项为动态学习的ARP泛洪抑制表项
·     L:表示生效的ARP泛洪抑制表项为本地ARP泛洪抑制表项
·     R:表示生效的ARP泛洪抑制表项为M-LAG对端设备同步的ARP泛洪抑制表项
·     S:表示生效的ARP泛洪抑制表项为静态配置的ARP泛洪抑制表项
·     I:表示该ARP泛洪抑制表项无效,原因可能是:
·     出方向Tunnel接口不存在
ARP泛洪抑制表项的总数
display l2vpn m-lag mac-address命令用来显示M-LAG设备上L2VPN的MAC地址表信息。
display l2vpn m-lag mac-address [ local | remote ] [ count | vsi vsi-name [ count | mac-address ] ]
local:显示L2VPN本地学习的MAC地址表信息。
remote:显示L2VPN远端同步的MAC地址表信息。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址表项的具体信息。
vsi vsi-name:显示指定VSI的MAC地址表信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的L2VPN的MAC地址表信息。
mac-address:显示指定的MAC地址表项。mac-address的格式为H-H-H,在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定本参数,则显示指定VSI的所有MAC地址表项信息。
执行本命令时,如果没有指定localremote参数,则显示M-LAG设备上L2VPN本地学习和远端同步的MAC地址表信息。
# 显示M-LAG设备上所有VSI的L2VPN本地学习和远端同步的MAC地址表信息。
<Sysname> display l2vpn m-lag mac-address
Flags: D – Dynamic   L - Local   R – Remote   S – Static   A - MAC-authentication
VSI name: bbb
MAC address           Link ID       Interface       Flags
0000-0000-000a        0x1           BAGG10          DL
0000-0000-0009        0x1           Tunnel1         DL
# 显示M-LAG设备上所有VSI的L2VPN本地学习和远端同步的MAC地址表项总数目。
<Sysname> display l2vpn m-lag mac-address count
Total number of entries: 2
表1-5 display l2vpn m-lag mac-address命令显示信息描述表
VSI name
VSI名称
MAC address
MAC地址
Link ID
MAC地址对应的出链路标识符,即AC或VXLAN隧道在VSI内的链路标识符
MAC地址表项的出接口名称
Flags
MAC地址表项类型,取值包括:
·     D:表示生效的MAC地址表项是动态学习的MAC地址表项
·     L:表示生效的MAC地址表项是本地的MAC地址表项
·     R:表示生效的MAC地址表项是M-LAG对端设备同步过来的MAC地址表项
·     S:表示生效的MAC地址表项是静态配置的MAC地址表项
·     A:表示生效的MAC地址表项是MAC地址认证学习的MAC地址表项
M-LAG设备上的MAC地址表项总数目
display l2vpn m-lag nd命令用来显示M-LAG设备上L2VPN的ND信息。
display l2vpn m-lag nd [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ ipv6-address | count ] ]
local:显示L2VPN本地学习的ND信息。
remote:显示L2VPN远端同步的ND信息。
count:显示ND表项的数目。如果不指定本参数,则显示ND表项的具体信息。
public-instance:显示公网实例的ND信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ND信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ipv6-address:显示指定IPv6地址的ND表项。如果不指定本参数,则显示L2VPN的所有ND信息。
执行本命令时,如果没有指定localremote参数,则显示M-LAG设备上L2VPN本地学习和远端同步的ND信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示M-LAG设备上公网实例和所有VPN实例的ND信息。
# 显示M-LAG设备上公网实例和所有VPN实例的本地及远端ND信息。
<Sysname> display l2vpn m-lag nd
Flags: D - Dynamic   L – Local  R – Remote   S - Static   I - Invalid
VPN instance: vpna                            Interface: Vsi-interface1
IPv6 address :   20::2
MAC address  :   0001-0001-0001          Flags        :   DL
VSI index    :   0                       Link ID      :   0x1
# 显示M-LAG设备上公网实例和所有VPN实例的本地及远端ND表项总数目。
<Sysname> display l2vpn m-lag nd count
Total number of entries: 1
表1-6 display l2vpn m-lag nd命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
VSI虚接口
IPv6 address
IPv6地址
MAC address
MAC地址
Flags
ND表项类型,取值包括:
·     D:表示生效的ND表项是动态学习的ND表项
·     L:表示生效的ND表项是本地的ND表项
·     R:表示生效的ND表项是对端M-LAG设备同步的ND表项
·     S:表示生效的ND表项是静态配置的ND表项
·     I:表示该ND表项无效,原因可能是:
¡     出方向Tunnel接口不存在
·     G:表示生效的ND表项是网关的ND表项
·     V:表示生效的ND表项是网关接口的M-LAG虚拟ND表项
VSI index
VSI索引
Link ID
ND对应的出链路标识符,即AC或VXLAN隧道在VSI内的链路标识符
M-LAG设备上的ND表项总数目
display l2vpn m-lag nd suppression命令用来显示M-LAG设备上的ND泛洪抑制表项信息。
display l2vpn m-lag nd suppression [ local | remote ] [ count | vsi vsi-name [ ipv6-address | count ] ]
local:显示L2VPN本地学习的ND泛洪抑制表项。
remote:显示L2VPN远端同步的ND泛洪抑制表项。
count:显示ND泛洪抑制表项的数目。如果不指定本参数,则显示ND泛洪抑制表项的具体信息。
vsi vsi-name:显示指定VSI的ND泛洪抑制表项信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ND泛洪抑制表项信息。
ipv6-address:显示指定IPv6地址的ND泛洪抑制表项信息。如果不指定本参数,则显示所有的ND泛洪抑制表项。
执行本命令时,如果没有指定localremote参数,则显示M-LAG设备上L2VPN本地学习和远端同步的ND泛洪抑制表项信息。
# 显示所有VSI本地学习和远端同步的ND泛洪抑制表项信息。
[Sysname]display l2vpn m-lag nd suppression
VSI name: vpna
IPv6 address                            MAC address     Link ID   Flags
11::8                                   72cb-ce9b-0a06 0x1       DL
11::9                                   0001-0001-0001  0x2       SR
# 显示所有VSI本地学习和远端同步的ND泛洪抑制表项总数。
<Sysname> display l2vpn m-lag nd suppression count
表1-7 display l2vpn m-lag nd suppression命令显示信息描述表
VSI name
VSI名称
IPv6 address
IPv6地址
MAC address
MAC地址
Link ID
ND泛洪抑制表项对应的出链路标识符,即AC或VXLAN隧道在VSI内的链路标识符
Flags
ND泛洪抑制表项类型,取值包括:
·     D:表示生效的ND泛洪抑制表项为动态学习的ND泛洪抑制表项
·     L:表示生效的ND泛洪抑制表项为本地ND泛洪抑制表项生效
·     R:表示生效的ND泛洪抑制表项为M-LAG对端设备同步的ARP泛洪抑制表项
·     S:表示生效的ND泛洪抑制表项为静态配置的ND表项
·     I:表示该ND泛洪抑制表项无效,原因可能是:
¡     出方向Tunnel接口不存在
ND泛洪抑制表项的总数目
display l2vpn mac-address命令用来显示VSI的MAC地址表信息。
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name:显示指定VSI的MAC地址表信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址表信息。
dynamic:显示通过源MAC地址动态学习的MAC地址表项。如果不指定本参数,则显示通过源MAC地址动态学习的本地和远端MAC地址表项、通过BGP EVPN协议学习的远端MAC地址表项、静态配置的远端MAC地址表项、通过OpenFlow下发的远端MAC地址表项和通过OVSDB生成的远端MAC地址表项。
count:显示MAC地址表项的数目。
verbose:显示MAC地址表项的详细信息。
执行本命令时,如果没有指定countverbose参数,则显示MAC地址表项的简要信息。
# 显示所有VSI的MAC地址表简要信息。
<Sysname> display l2vpn mac-address
* - The output interface is issued to another VSI
MAC Address    State     VSI Name                        Link ID/Name   Aging
0001-0001-0001 Static    aaa                             Tunnel10       NotAging
52f6-bc1e-0d06 Dynamic   vpna                            XGE3/0/1       Aging
0000-0000-000c Dynamic   TTP_vxlan10                     XGE3/0/1*       Aging
--- 3 mac address(es) found  ---
# 显示所有VSI的MAC地址表项总数。
<Sysname> display l2vpn mac-address count
2 mac address(es) found
表1-8 display l2vpn mac-address命令显示信息描述表
MAC Address
MAC地址
MAC地址的状态,取值包括:
·     Dynamic:表示通过源MAC地址动态学习的本地或远端MAC地址表项
·     Static:表示静态配置的远端MAC地址表项
·     EVPN:表示通过BGP EVPN协议学习的远端MAC地址表项
·     OpenFlow:表示通过OpenFlow下发的远端MAC地址表项
·     OVSDB:表示通过OVSDB生成的远端MAC地址表项
VSI Name
VSI名称
Link ID/Name
对于本端MAC地址,为MAC地址对应以太网服务实例所在接口的名称
对于远端MAC地址,为MAC地址对应的隧道接口名称
带有*时,表示控制器使用TTP协议将属于vsi1的MAC地址下发到vsi2,Link ID属于vsi2,具体信息可在详细信息中查看
Aging
MAC地址表项是否老化,取值包括Aging和NotAging
XX mac address(es) found
VSI的MAC地址表项的总数
# 显示所有VSI的MAC地址表详细信息。
<Sysname> display l2vpn mac-address verbose
MAC Address      : 0000-0000-000b
VSI Name         : vpn1
VXLAN ID         : 123
Interface        : XGE3/0/1
Link ID          : 1
State            : Dynamic
Aging            : Aging
MAC address      : 0000-0000-abcd
VSI name         : TTP_vxlan10
VXLAN ID         : 10
Link ID(VSI name): 1(TTP_vxlan20)
State            : Openflow
Aging            : Aging
表1-9 display l2vpn mac-address verbose命令显示信息描述表
MAC Address
MAC地址
VSI Name
VSI名称,显示形式包括:
·     vsi-name:MAC地址所属的VSI名称
·     vsi1 (vsi2):表示该MAC地址属于vsi1,且被控制器下发至vsi2
VXLAN ID
VXLAN编号
对于本端MAC地址,为以太网服务实例所在接口的名称
Link ID
MAC地址的状态,取值包括:
·     Openflow:表示通过OpenFlow下发的远端MAC地址表项
Aging
·     reset l2vpn mac-address
display l2vpn mac-address mac-move命令用来显示设备启动后所有VSI内的MAC地址迁移记录。
(独立运行模式)
display l2vpn mac-address mac-move [ slot slot-number ]
display l2vpn mac-address mac-move [ chassis chassis-number slot slot-number ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)
如果MAC地址迁移频繁出现,且同一MAC地址总是在特定的两个接口之间迁移,那么网络中可能存在二层环路。可以通过查看MAC地址迁移记录,发现和定位环路。
每个单板最多能记录最近发生的200次MAC地址迁移过程。(独立运行模式)
每个成员设备的每个单板最多能记录最近发生的200次MAC地址迁移过程。(IRF模式)
# 显示所有VSI内的MAC地址迁移记录。
<Sysname> display l2vpn mac-address mac-move
MAC address : 0000-4900-03e7      VSI name   : 3
Current port: XXGE3/0/1 srv2       Source port: XGE3/0/2 srv3
Last time   : 2019-02-19 20:44:15 Move count : 1
---  1 MAC address moving records found  ---
表1-10 display mac-address mac-move命令显示信息描述表
MAC address
MAC地址
VSI name
VSI名称
Current port
MAC地址迁移新接口
Source port
MAC地址迁移源接口
Last time
最近一次发生MAC地址迁移的时间
Move count
MAC地址迁移的次数
display l2vpn service-instance命令用来显示以太网服务实例的信息。
interface interface-type interface-number:显示指定二层以太网接口或二层聚合接口上的以太网服务实例信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有二层以太网接口和二层聚合接口上的以太网服务实例信息。
service-instance instance-id:显示指定以太网服务实例的信息。instance-id为以太网服务实例的ID,取值范围为1~4096。如果指定了interface interface-type interface-number参数,未指定本参数,则显示指定二层以太网接口或二层聚合接口上所有以太网服务实例的信息。
verbose:显示详细信息。如果未指定本参数,则显示简要信息。
# 显示所有以太网服务实例的简要信息。
<Sysname> display l2vpn service-instance
Total number of service-instances: 2, 2 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface                ID    Owner                           LinkID State Type
XGE1/0/1                 3     vsi12                           1      Up    VSI
XGE1/0/1                 4     vsi13                           1      Up    VSI
表1-11 display l2vpn service-instance命令显示信息描述表
以太网服务实例的总数,及处于up和down状态的以太网服务实例数目
Total number of ACs
AC的总数,及处于up和down状态的AC数目
二层以太网接口或二层聚合接口名称
ID
以太网服务实例的ID
Owner
VSI名称,如果以太网服务实例上尚未关联VSI,则该字段显示为空
LinkID
以太网服务实例在VSI内的链路标识符
以太网服务实例的状态,取值包括Up和Down
以太网服务实例所属的L2VPN类型,取值包括VSI和VPWS
# 显示二层以太网接口Ten-GigabitEthernet3/0/1上所有以太网服务实例的详细信息。
<Sysname> display l2vpn service-instance interface ten-gigabitethernet 3/0/1 verbose
Interface: XGE3/0/1
  Service Instance: 1
    Type          : Manual
    Encapsulation : s-vid 16
    Bandwidth     : -
    VSI Name      : vsi10
    Link ID       : 1
    State         : Up
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
表1-12 display l2vpn service-instance verbose命令显示信息描述表
二层以太网接口或二层聚合接口
Service Instance
以太网服务实例ID
以太网服务实例的类型和报文匹配方式,取值包括:
·     Dynamic (M-LAG):peer-link链路上动态创建,采用VLAN匹配方式
·     Dynamic (VLAN-based):动态创建,采用VLAN匹配方式
·     Manual:手工创建,采用VLAN匹配方式
Encapsulation
以太网服务实例的报文匹配规则,如果未配置报文匹配规则,则不显示本字段
Bandwidth
(暂不支持)以太网服务实例对应AC上流量的最大带宽,单位为kbps
取值为“Unlimited”时,表示不限制AC上的流量
VSI Name
与以太网服务实例关联的VSI的名称
Link ID
以太网服务实例在VSI内的链路标识符
Statistics
是否使能以太网服务实例的统计功能,取值包括:
·     Enabled:使能了以太网服务实例的统计功能
·     Disabled:禁止以太网服务实例的统计功能
Input Statistics
入方向的以太网服务实例报文统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)
Output Statistics
出方向的以太网服务实例报文统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)
·     service-instance
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的信息。
verbose:显示VSI的详细信息。如果不指定本参数,则显示VSI的简要信息。
# 显示所有VSI的简要信息。
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
表1-13 display l2vpn vsi命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
MTU
VSI上配置的最大传输单元
VSI的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Admin down:通过shutdown命令手工关闭VSI
# 显示所有VSI的详细信息。
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : Unlimited
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Input statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Input Rate              :
    Bytes per second   : 0
    Packets per second : 0
  Output Rate             :
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  VLAN ID                 : -
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
    MTunnel0             0x6002710  Up     Auto      Disabled
  ACs:
    AC                               Link ID    State    Type
    XGE3/0/1 srv1000                 0          Up       Manual
表1-14 display l2vpn vsi verbose命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Bandwidth
‌(暂不支持)VSI内流量的最大带宽值,单位为kbps
取值为Unlimited时,表示不限制VSI内的流量
Broadcast Restrain
‌(暂不支持)VSI的广播抑制带宽值,单位为kbps
Multicast Restrain
‌(暂不支持)VSI的组播抑制带宽值,单位为kbps
‌(暂不支持)VSI的未知单播抑制带宽值,单位为kbps
MAC Learning
是否使能了MAC地址学习功能
MAC Table Limit
(暂不支持)VSI内MAC地址表项的最大数目
Drop Unknown
(暂不支持)当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文
Flooding
是否使能VSI的泛洪功能,取值包括:
·     Enabled:表示使能了VSI的泛洪功能
·     Disabled:表示禁止VSI的泛洪功能
Statistics
是否使能VSI的统计功能,取值包括:
·     Enabled:使能了VSI的统计功能
·     Disabled:禁止VSI的统计功能
Input statistics
入方向的VSI报文统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)、接收的错误报文数(Errors)和丢弃的报文数(Discards)
Output statistics
出方向的VSI报文统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)、错误报文数(Errors)和丢弃的报文数(Discards)
Input Rate
入方向的VSI报文速率,包括每秒接收的字节数(Bytes per second)和每秒接收的报文数(Packets per second)
Output Rate
出方向的VSI报文速率,包括每秒发送的字节数(Bytes per second)和每秒发送的报文数(Packets per second)
Gateway Interface
VSI网关虚接口编号
VXLAN ID
VXLAN编号
VLAN ID
VXLAN映射的VLAN
Tunnels
与VXLAN关联的隧道信息
Tunnel Name
隧道名称
Link ID
隧道在VSI内的链路标识符
隧道状态,取值包括:
·     Up:Tunnel接口状态Up,隧道可正常转发数据
·     Blocked:该隧道为备用隧道,不进行数据转发,Tunnel接口状态Up‌
·     Down:Tunnel接口状态Down,隧道停止数据转发
VXLAN和VXLAN隧道的关联方式,取值包括:
·     Auto:表示自动关联
¡     EVPN自动将VXLAN和VXLAN隧道关联
¡     在组播路由方式下,自动创建用于转发泛洪流量的组播VXLAN隧道(MTunnel),并将其与VXLAN关联
·     Manual:表示手动关联VXLAN和VXLAN隧道
Flood proxy
隧道是否开启了泛洪代理功能,设备暂时不支持该功能
ACs
VSI的AC列表
AC
接入电路
Link ID
AC在VSI内的链路标识符
AC的状态,取值包括Up和Down
display vxlan tunnel命令用来显示与VXLAN关联的VXLAN隧道的信息。
display vxlan tunnel [ vxlan-id vxlan-id [ tunnel tunnel-number ] ]
vxlan-id:显示与指定VXLAN关联的隧道的信息。vxlan-id为VXLAN的编号,取值范围为1~16777215。不指定此参数,则显示所有与VXLAN关联的隧道的信息。
tunnel tunnel-number:显示与指定VXLAN关联的指定隧道的信息。tunnel-number为Tunnel的编号,取值范围为1~5120。不指定此参数,则显示与指定VXLAN关联的所有隧道的信息。
# 显示所有与VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
Total number of VXLAN tunnels: 1
VXLAN ID: 10, VSI name: aaa, Total tunnels: 1 (1 up, 0 down, 0 defect, 0 blocked)
Tunnel name Source          Destination     State   Type   Flood proxy Out VNI
Tun1        1.1.1.1         3.3.3.3         UP      Manual Disabled    -
# 显示与编号为10的VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel vxlan-id 10
# 显示与编号为17的VXLAN关联的隧道Tunnel77的信息。
<Sysname> display vxlan tunnel vxlan-id 17 tunnel 77
Interface: Tun77
  Source     : -
  Destination: -
  State      : Down
  Type       : Manual
  Flood proxy: Disabled
  Out VNI    : -
表1-15 display vxlan tunnel命令显示信息描述表
已创建的VXLAN的总数
与所有VXLAN关联的隧道的总数
VXLAN ID
VXLAN ID
VSI name
VXLAN所属的VSI名称
Total tunnels
与指定VXLAN关联的隧道的总数,包括处于up、down、defect和blocked状态的VXLAN隧道数目
Tunnel name
隧道名称
Source
隧道的源端地址
Destination
隧道的目的端地址
隧道的状态,取值包括:
·     Auto:表示自动关联
Flood proxy
Out VNI
(暂不支持)出方向的VXLAN ID
·     tunnel
·     vxlan
display vxlan tunnel-interface命令用来显示VXLAN隧道接口的信息。
display vxlan tunnel-interface [ tunnel number [ verbose ] ]
tunnel number:显示指定Tunnel接口的信息。number为设备上已创建的Tunnel接口的编号。如果不指定本参数,则显示所有VXLAN隧道接口的信息。
verbose:显示指定Tunnel接口的详细信息。如果不指定本参数,则显示Tunnel接口的简要信息。
# 显示所有VXLAN隧道接口的简要信息。
<Sysname> display vxlan tunnel-interface
Tunnel name Source          Destination     State    Type    Uptime
Tunnel10    192.2.2.2       192.5.5.5       Up       Manual  00:00:27
# 显示编号为10的VXLAN隧道接口的详细信息。
<Sysname> display vxlan tunnel-interface tunnel 10 verbose
Tunnel Name     : Tunnel10
Source          : 192.2.2.2
Destination     : 192.5.5.5
State           : Up
Type            : Manual
MAC learning    : Enabled
Down reason     : -
Uptime          : 00:00:19
表1-16 display vxlan tunnel-interface命令显示信息描述表
VXLAN隧道的总数
Tunnel name
隧道名称
Source
隧道的源端地址
Destination
隧道的目的端地址
隧道的状态,取值包括:
·     Auto:表示通过EVPN自动将VXLAN和VXLAN隧道关联
MAC learning
是否开启VXLAN隧道的MAC地址学习功能,取值包括:
·     Enabled:表示开启了隧道的MAC地址学习功能
·     Disabled:表示关闭了隧道的MAC地址学习功能
Down reason
隧道Down的原因,取值包括:
·     Source or destination address not set:未配置隧道源端地址或目的端地址
·     Resources not ready:资源未就绪
·     Resources not enough:资源不足
·     Tunneling not supported:不支持隧道
·     DCI tunneling not supported:不支持DCI模式的隧道
·     Specification exceeded:参数错误,超规格
·     Source address changed:隧道源地址已修改
·     Global source address changed:全局源地址已修改
·     Tunnel interface administratively down:隧道接口下配置了shutdown命令
·     Tunnel mode check failed:隧道模式检查错误
·     Tunnel already exists:已存在相同的隧道
Uptime
VXLAN隧道处于UP状态的时间,显示格式包括:
·     hh:mm:ss:表示时分秒,当隧道处于UP状态的时间≤24小时时,采用该格式显示
·     xxxxhxxm:表示时分,当24小时<隧道处于UP状态的时间≤9999小时时,采用该格式显示
·     ****hxxm:表示时分,并且不再显示具体小时数,隧道处于UP状态的时间大于9999小时时,采用该格式显示
·     -:表示隧道目前处于down状态
·     tunnel
·     vxlan
display vxlan tunnel termination命令用来显示VXLAN隧道终结的IP地址信息。
通过本命令可以查看开启缺省解封装VXLAN报文的功能后,当前VXLAN隧道终结的IP地址信息。VXLAN隧道终结的IP地址包含如下类型:
·     虚拟VTEP/ED地址(evpn m-lag group)。
·     M-LAG系统的本地地址(evpn m-lag local)。
·     Peer-link接口的IP地址。
·     虚拟ED地址(evpn edge group)。
·     BGP邻居地址。
# 显示VXLAN隧道终结的IP地址信息。
<Sysname> display vxlan tunnel termination
Flags: G - Mlag Group address        L - Mlag Local address
       P - Peer-link source address  E - Edge Group address
       B - BGP Local address
Total number of tunnel terminations: 1
IPV4 address     Flags
1.1.1.1          G
表1-17 display vxlan tunnel命令显示信息描述表
所有VXLAN隧道终结的IP地址总数
IPV4 address
IPv4地址
Flags
标记位,取值包括:
·     G:虚拟VTEP地址
·     L:M-LAG系统的本地地址
·     P:Peer-link接口的IP地址
·     E:虚拟ED地址
·     B:BGP邻居地址
IPV6 address
IPv6地址
·     vxlan default-decapsulation enable
·     vxlan ipv6 default-decapsulation enable
encapsulation命令用来配置以太网服务实例的报文匹配规则。
undo encapsulation命令用来恢复缺省情况。
encapsulation s-vid vlan-id [ only-tagged ]
encapsulation s-vid vlan-id c-vid { vlan-id | all }
encapsulation c-vid vlan-id
encapsulation untagged
undo encapsulation
未配置报文匹配规则。
以太网服务实例视图
s-vid:匹配外层VLAN标签(Service VLAN ID)为指定值的报文。
c-vid:匹配内层VLAN标签(Customer VLAN ID)为指定值的报文。
vlan-id:VLAN的编号,取值范围为1~4094。
only-tagged:表示只匹配携带VLAN标签的报文。当匹配的VLAN为缺省VLAN时,如果未指定本关键字,则会同时匹配所携带VLAN标签为缺省VLAN的报文和未携带VLAN标签的报文;如果指定了本参数,则只匹配所携带VLAN标签为缺省VLAN的报文。
all:所有VLAN。
untagged:表示匹配未携带VLAN标签的报文。
如果同一接口的不同以太网服务实例上分别通过encapsulation s-vid vlan-id [ only-tagged ]命令和encapsulation s-vid vlan-id c-vid { vlan-id | all }命令配置匹配相同外层VLAN tag(s-vid)的报文匹配规则,则携带指定外层和内层VLAN tag的报文匹配encapsulation s-vid vlan-id c-vid { vlan-id | all }命令所属的以太网服务实例。
以太网服务实例的匹配规则为encapsulation tagged时,请使用Ethernet接入模式将该以太网服务实例与VSI关联。
同一个接口上创建了多个以太网服务实例时,不同以太网服务实例的报文匹配规则之间存在以下配置限制:
·     如果既存在仅匹配外层VLAN标签(s-vid)的以太网服务实例,又存在同时匹配外层和内层VLAN标签(s-vidc-vid)的以太网服务实例,则两个规则中指定的s-vid可以相同。
·     如果存在多个仅匹配内层VLAN标签(c-vid)或外层VLAN标签(s-vid)的以太网服务实例,则不同规则中指定的c-vids-vid不能相同。
·     如果存在多个同时匹配外层和内层VLAN标签(s-vidc-vid)的以太网服务实例,则不同规则匹配的外层标签(s-vid)不同时,c-vid可以相同;匹配的内层标签(c-vid)不同时,s-vid可以相同。
·     请不要同时配置仅匹配外层VLAN标签(s-vid)的以太网服务实例和仅匹配内层VLAN标签(c-vid)的以太网服务实例。否则,两种类型的以太网服务实例会产生冲突,后创建的那一类以太网服务实例无法生效。
不能通过重复执行本命令修改报文匹配规则。如需修改报文匹配规则,请先通过undo encapsulation命令删除报文匹配规则,再执行encapsulation命令。
删除以太网服务实例下的报文匹配规则后,会自动取消以太网服务实例与VSI的关联。
端口下存在多个以太网服务实例时,在这些AC中最多配置两种不同的报文匹配。例如,如果已经存在了仅匹配内层VLAN标签(c-vid)的以太网服务实例和同时匹配外层和内层VLAN标签(s-vidc-vid)的以太网服务实例,就不能再配置匹配未携带VXLAN标签(untagged)的以太网服务实例。否则,可能造成部分以太网服务实例的匹配规则不生效。
# 在二层以太网接口Ten-GigabitEthernet3/0/1的以太网服务实例1上配置如下报文匹配规则:匹配外层VLAN标签为111的报文。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet3/0/1-srv1] encapsulation s-vid 111
flooding disable命令用来关闭VSI的泛洪功能。
undo flooding disable命令用来开启VSI的泛洪功能。
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction ]
VSI的泛洪功能处于开启状态。
VSI视图
all:禁止泛洪广播、未知单播和未知组播数据帧。
broadcast:禁止泛洪广播数据帧。
unknown-multicast:禁止泛洪未知组播数据帧。
unknown-unicast:禁止泛洪未知单播数据帧。
all-direction:禁止将AC和VXLAN隧道上接收到的泛洪流量转发给相同VSI内的其他AC和VXLAN隧道。如果不指定本参数,则表示仅禁止将AC上接收到的泛洪流量转发给相同VSI内的VXLAN隧道。
缺省情况下,VTEP从本地站点内接收到目的MAC地址为广播、未知单播和未知组播的数据帧后,会在该VXLAN内除接收接口外的所有本地接口和VXLAN隧道上泛洪该数据帧,将该数据帧发送给VXLAN内的所有站点;VTEP从VXLAN隧道接收到目的MAC地址为广播、未知单播和未知组播的数据帧后,会在该VXLAN内的所有本地接口上泛洪该数据帧。通过本命令可以手工禁止某类数据帧在VXLAN内泛洪,以减少网络中的泛洪流量。
执行本命令时,必须同时指定unknown-multicastbroadcastunknown-unicast参数。
# 在VSI实例vsi1内禁止将本地站点内接收到的广播数据帧泛洪到远端站点。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
ipv6 nd suppression enable命令用来开启ND泛洪抑制功能。
undo ipv6 nd suppression enable命令用来关闭ND泛洪抑制功能。
ipv6 nd suppression enable [ no-broadcast ]
ND泛洪抑制功能处于关闭状态。
VSI视图
no-broadcast:表示没有对应的ND泛洪抑制表项时不泛洪ND请求。
为了避免组播发送的ND请求报文占用核心网络带宽,VTEP从本地站点或VXLAN隧道接收到ND请求和ND应答报文后,根据该报文在本地建立ND泛洪抑制表项。后续当VTEP收到本站点内用户终端请求其它用户终端MAC地址的ND请求时,优先根据ND泛洪抑制表项进行代答。如果没有对应的ND泛洪抑制表项且开启ND泛洪抑制功能时未配置no-broadcast参数,则将ND请求泛洪到核心网。ND泛洪抑制功能可以大大减少ND泛洪的次数。
# 在VSI vsi1下开启ND泛洪抑制功能,且没有对应的ND泛洪抑制表项时不泛洪ARP请求。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable no-broadcast
·     display ipv6 nd suppression vsi
·     ipv6 nd suppression mode
ipv6 nd suppression mode命令用来配置ND泛洪抑制模式。
undo ipv6 nd suppression mode命令用来恢复缺省情况。
ipv6 nd suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
开启ND泛洪抑制功能后,ND泛洪抑制模式为设备代答模式。当NS报文的目标IPv6地址不是本端设备的IPv6地址,且不能匹配本端设备的ND泛洪抑制表项时,广播转发NS报文。
VSI视图
proxy-reply:设备代答模式,即当NS报文请求的目标IPv6地址不是本端设备的IPv6地址,且目标IPv6地址匹配本端设备的ND泛洪抑制表项时,本端设备不转发NS报文,而是直接代替目标IPv6对应的设备回应NA报文。此NA报文的发送端IPv6地址为NS报文的目标IPv6地址,链路层的源MAC地址为ND泛洪抑制表项中目标IPv6地址对应的MAC地址。
unicast-forward:单播转发模式,即当NS报文的目标IPv6地址不是本端设备的IPv6地址,且目标IPv6地址匹配本端设备的ND泛洪抑制表项时,本端设备将NS报文的链路层的目的MAC地址修改为泛洪抑制表项中与目标IPv6地址对应的MAC地址,然后单播转发NS报文。
mismatch-discard:当NS报文的目标IPv6地址不是本端设备的IPv6地址,且不能匹配本端设备的ND泛洪抑制表项时,丢弃报文。如果未指定本参数,则设备将对不能匹配本端设备的ND泛洪抑制表项的NS报文进行广播转发。
使用设备代答模式时,本端不会转发NS报文,占用的系统资源较少。使用单播转发模式时,虽然占用更多的系统资源,但是可以减少泛洪抑制表项未及时更新造成的ND表项学习错误。
# 在VSI vsi1下开启ND泛洪抑制功能,并配置ND泛洪抑制模式为单播转发模式。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] nd suppression mode unicast-forward
1.1.23  l2vpn enable
l2vpn enable命令用来开启L2VPN功能。
undo l2vpn enable命令用来关闭L2VPN功能。
l2vpn enable
undo l2vpn enable
L2VPN功能处于关闭状态。
只有开启L2VPN功能后,才能进行L2VPN的相关配置。
# 开启L2VPN功能。
[Sysname] l2vpn enable
l2vpn statistics interval命令用来设置L2VPN统计信息收集的时间间隔。
undo l2vpn statistics interval命令用来恢复缺省情况。
l2vpn statistics interval interval
L2VPN统计信息收集的时间间隔为15分钟。
interval:L2VPN统计信息收集的时间间隔,取值范围为5~65535,单位为秒。
# 配置L2VPN统计信息收集的时间间隔为30秒。
[Sysname] l2vpn statistics interval 30
mac-address static vsi命令用来添加静态MAC地址表项。
undo mac-address static vsi命令用来删除指定的静态MAC地址表项。
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] interface tunnel tunnel-number vsi vsi-name
不存在静态MAC地址表项。
mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址和全0的MAC地址。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
interface tunnel tunnel-number:指定远端MAC地址对应的VXLAN隧道接口或VXLAN-DCI隧道接口。tunnel-number为VXLAN隧道接口或VXLAN-DCI隧道接口的编号,只能指定设备上已创建的Tunnel接口的编号。
vsi vsi-name:指定MAC地址所属的VSI。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址既可以通过本命令静态配置,也可以通过报文中的源MAC地址、BGP EVPN协议等学习。
对于远端MAC地址表项,interface tunnel interface-number参数指定的隧道接口必须与vsi vsi-name参数指定的VSI对应的VXLAN关联,否则配置将失败。
执行undo mac-address static vsi命令时如果没有指定任何参数,则删除该VSI下的所有静态MAC地址表项。
建议不要将EVPN动态创建的隧道接口指定为远端MAC地址对应的隧道接口。否则,配置恢复时,EVPN会重新创建隧道,隧道接口的编号可能发生变化,从而导致静态远端MAC地址表项的配置无法恢复。
# 添加一条静态远端MAC地址表项:MAC地址为000f-e201-0101,VXLAN隧道接口为Tunnel1,MAC地址所属的VSI为vsi1。
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
·     vxlan tunnel mac-learning disable
1.1.26  mac-based ac
mac-based ac命令用来开启动态创建的以太网服务实例匹配MAC地址功能。
undo mac-based ac命令用来关闭动态创建的以太网服务实例匹配MAC地址功能。
mac-based ac
undo mac-based ac
动态创建的以太网服务实例匹配MAC地址功能处于关闭状态,即动态创建的以太网服务实例只匹配VLAN。
二层以太网接口视图
二层聚合接口视图
802.1X或MAC地址认证为用户下发授权VSI、Guest VSI、Auth-Fail VSI或Critical VSI后,将用户信息(接入端口、所属VLAN、MAC地址等)及VSI信息通知给VXLAN,VXLAN根据用户信息动态创建以太网服务实例,并将其与VSI关联。
动态创建的以太网服务实例可以通过以下匹配方式判断接口接收到的报文是否属于该AC:
·     VLAN方式:检查报文携带的VLAN ID是否与以太网服务实例匹配的VLAN ID相同。只有二者相同,报文才属于该AC。
·     MAC地址方式:检查报文携带的VLAN ID、源MAC地址是否分别与以太网服务实例匹配的VLAN ID、MAC地址相同。只有VLAN ID、源MAC地址均相同时,报文才属于该AC。
缺省情况下,动态创建的以太网服务实例采用VLAN匹配方式。如需要采用MAC地址方式,那么必须采用MAC地址认证或基于MAC接入控制的802.1X认证,并开启动态创建的以太网服务实例匹配MAC地址功能。
本命令对Hybrid端口上的两类报文不生效:
·     以Untagged方式通过的VLAN报文
·     匹配Hybrid端口PVID的报文
有关Hybrid端口的详细介绍,请参见“二层技术-以太网交换配置指导”中的“VLAN”。
动态创建的以太网服务实例匹配MAC地址功能与以太网服务实例同时匹配报文的内(c-vid)外层(s-vid)VLAN tag功能互斥,请不要在同一个端口下同时配置。
本命令仅对动态创建的以太网服务实例生效。通过service-instance命令创建的静态以太网服务实例只能通过encapsulation命令配置匹配的VLAN ID,不能匹配MAC地址。
若接口下已存在动态创建的以太网服务实例,则不能通过本命令修改动态创建以太网服务实例匹配MAC地址功能的开启、关闭状态。
# 开启动态创建的以太网服务实例匹配MAC地址功能。
[Sysname-Ten-GigabitEthernet3/0/1] mac-based ac
overlay oam enable命令用来开启VXLAN隧道的连通性检测功能。
undo overlay oam enable命令用来关闭VXLAN隧道的连通性检测功能。
overlay oam enable
VXLAN隧道的连通性检测功能处于关闭状态。
通过行ping vxlan/tracert vxlan命令检测VXLAN隧道的连通性时,需要在VXLAN隧道的尾节点上配置本命令才可以正常使用。如果隧道源节点执行ping vxlan/tracert vxlan命令时指定-r reply-mode参数为3,则还需要在源节点上执行本命令。
# 开启VXLAN隧道的连通性检测功能。
[Sysname] overlay oam enable
·     ping vxlan
·     tracert vxlan
1.1.28  ping vxlan
ping vxlan命令用来检测VXLAN隧道的连通性。
ping vxlan [ -a inner-src-address | -c count | -m interval | -r reply-mode | -t timeout | -tos tos-value ] * vxlan-id vxlan-id tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-a inner-src-address:指定VXLAN Echo Request报文的内层IP头的源IP地址。如果未指定本参数,则VXLAN Echo Request报文的内层IP头的源IP地址为报文出接口的主IP地址。如果对端设备上不存在到达该源IP地址的路由,则建议通过本参数指定VXLAN Echo Request报文的源地址为隧道的源IP地址。
-c count:指定发送VXLAN Echo Request报文的数目。count为报文的发送数目,取值范围为1~4294967295,缺省值为5。
-m interval:指定连续发送VXLAN Echo Request报文的时间间隔。interval为连续发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为200。
-r reply-mode:指定接收者对VXLAN Echo Request报文的应答模式。reply-mode为应答模式,取值范围为1~3,缺省值为2。1表示不进行应答;2表示根据目的IP地址查找IP转发表进行应答;3表示采用VXLAN封装进行应答。
-t timeout:指定发送VXLAN Echo Request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000。
-tos tos-value:指定VXLAN Echo Request报文中外层IP头的ToS值。tos-value为ToS值,取值范围为0~255,缺省值为0。
vxlan-id vxlan-id:指定发送VXLAN Echo Request报文的VXLAN。vxlan-id表示VXLAN编号,取值范围为0~16777215。
tunnel-source source-address:指定VXLAN隧道源IPv4地址。
tunnel-destination dest-address:指定VXLAN隧道目的IPv4地址。
destination-udpport dest-port:指定VXLAN Echo Request报文的内层目的UDP端口号。dest-port为目的UDP端口号,取值范围为1~65535,缺省值为50001。本参数主要用于对端设备对内层目的UDP端口号有要求的场景下。
vxlan-source-address vxlan-source-address:指定VXLAN Echo Request报文的外层IP头的源IPv4地址。如果未指定本参数,则使用tunnel-source source-address参数指定的VXLAN隧道的源地址。在M-LAG组网中,M-LAG设备发起Ping VXLAN操作时,需将本参数指定为M-LAG系统中本地VTEP的IP地址,以防止远端VTEP将VXLAN Echo Reply报文发给另一台M-LAG设备。
load-balance:指定负载分担参数。如果未指定本参数,则仅对多路径中的一条路径进行检测。
vxlan-source-udpport vxlan-source-udpport end-vxlan-src-udpport:指定VXLAN Echo Request报文的源UDP端口号的起始值与结束值,取值范围为49152~65535,源UDP端口号起始值的缺省值为4789,如果未指定结束值,则起始值即为结束值。
source-address lb-src-address:指定用于负载均衡运算的源IPv4地址。
destination-address lb-dest-address:指定用于负载均衡运算的目的IPv4地址。
protocol:指定用于负载均衡运算的协议类型。
udp:指定用于负载均衡运算的协议类型为UDP协议。
lb-protocol-id:指定用于负载均衡运算的协议号,取值范围为1~255。
source-port lb-src-port:指定用于负载均衡运算的源端口号,取值范围为1~65535。
destination-port lb-dest-port:指定用于负载均衡运算的目的端口号,取值范围为1~65535。
source-mac lb-source-mac:指定用于负载均衡运算的源MAC地址。
destination-mac lb-destination-mac:指定用于负载均衡运算的目的MAC地址。
在VXLAN或EVPN VXLAN组网中,VTEP之间通过VXLAN隧道传输数据报文,当VTEP间出现丢包或断流现象时,可以通过本命令检测VTEP设备间VXLAN隧道的连通性。
VTEP基于VXLAN Echo Request报文的源UDP端口号进行负载分担,当两个VTEP之间的VXLAN隧道对应多条路径时,为了保证检测结果的准确性,可以通过配置负载分担参数实现对多条路径的遍历检测。执行本命令时可以通过如下两种方式指定VXLAN Echo Request报文的源UDP端口号:
·     直接指定源UDP端口号的起始值和结束值,使设备发出的VXLAN Echo Request报文中的UDP端口号从起始值依次+1递增到结束值,实现对多条等价路径的遍历检测。
·     通过指定不同的MAC地址、IP地址以及协议类型参数动态计算生成VXLAN的源UDP号,实现对多条等价路径的遍历检测。采用该方式时,需要多次执行ping vxlan命令实现对多条等价路径的遍历检测。
配置本命令时,指定负载分担参数仅改变VXLAN Echo Request报文的源UDP端口号并不会改变设备发送的VXLAN Echo Request报文的其他信息。
指定vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ]参数后,每个源UDP端口号对应VXLAN Echo Request报文的发送数目由-c count参数决定。
通过本命令检测VXLAN隧道的连通性时,需要在VXLAN隧道的对端VTEP上配置overlay oam enable命令。
# 检测VXLAN 1内隧道源IP地址为11.11.11.11、目的IP地址为22.22.22.22的VXLAN隧道的连通性。
<Sysname> ping vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Ping VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
Press CTRL+C to break.
40 bytes from 30.0.0.2: sequence=1 time=6 ms
40 bytes from 30.0.0.2: sequence=2 time=4 ms
40 bytes from 30.0.0.2: sequence=3 time=3 ms
40 bytes from 30.0.0.2: sequence=4 time=3 ms
40 bytes from 30.0.0.2: sequence=5 time=2 ms
--- Ping statistics for VXLAN 1 source 11.11.11.11 destination 22.22.22.22 ---
Round-trip min/avg/max = 2/3/6 ms
表1-18 ping vxlan命令显示信息描述表
检测VXLAN ID为1、源地址为11.11.11.11、目的地址为22.22.22.22的VXLAN隧道的连通性
按组合键Ctrl+C可以终止ping操作
从30.0.0.2接收到长度为40字节的应答报文,若超时仍没有收到VXLAN Echo Reply报文,则不输出信息
·     bytes:表示VXLAN Echo Reply报文中的数据字节数
·     sequence:表示报文序号,用来判断报文是否有丢失、失序或重复
·     time:表示响应时间
Return code
返回码,取值包括:
·     0:无返回码
·     1:Echo Request报文错误
·     2:不存在对应VXLAN
·     3:VXLAN内没有Up的隧道
·     括号内为返回子码,目前暂无定义,取值为0
Ping操作中收发数据的统计结果
packets transmitted
发送的VXLAN Echo Request报文数
packets received
接收的VXLAN echo reply报文数
packet loss
未响应请求报文占发送的总请求报文的百分比
往返时延的最小值、平均值和最大值
·     overlay oam enable
·     tracert vxlan
reserved vxlan命令用来配置保留VXLAN。
undo reserved vxlan命令用来恢复缺省情况。
reserved vxlan vxlan-id
undo reserved vxlan
未指定保留VXLAN。
vxlan-id:保留VXLAN的ID,取值范围为1~16777215。
只能在系统视图下配置一个全局保留VXLAN,该VXLAN不能与VSI下创建的VXLAN相同。
配置的保留VXLAN不能与mapping vni命令配置的映射远端VXLAN相同。
# 配置保留VXLAN为VXLAN 10000。
[Sysname] reserved vxlan 10000
·     mapping vni(EVPN命令参考/EVPN)
reset arp suppression vsi命令用来清除VSI的ARP泛洪抑制表项。
reset arp suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ARP泛洪抑制表项。
# 清除所有VSI的ARP泛洪抑制表项。
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
reset ipv6 nd suppression vsi命令用来清除VSI的ND泛洪抑制表项。
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ND泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ND泛洪抑制表项。
# 清除所有VSI的ND泛洪抑制表项。
<Sysname> reset ipv6 nd suppression vsi
reset l2vpn mac-address命令用来清除通过源MAC地址动态学习的MAC地址表项。
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name:清除指定VSI动态学习的MAC地址表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI动态学习的MAC地址表项。
VSI通过源MAC地址学习到错误的MAC地址表项,或学习的MAC地址表项数目达到最大值时,可以执行本命令,以便重新学习MAC地址表项。
# 清除名为vpn1的VSI通过源MAC地址动态学习的MAC地址表项。
<Sysname> reset l2vpn mac-address vsi vpn1
·     display l2vpn mac-address vsi
reset l2vpn mac-address mac-move命令用来清除设备启动后所有VSI内的MAC地址迁移记录。
# 清除设备启动后所有VSI内的MAC地址迁移记录。
<Sysname> reset l2vpn mac-address mac-move
·     display l2vpn mac-address mac-move
reset l2vpn statistics ac命令用来清除AC的报文统计信息。
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id]
interface interface-type interface-number service-instance instance-id:清除指定接口上以太网服务实例的报文统计信息。interface-type interface-number表示接口类型和接口编号,instance-id表示以太网服务实例的ID,取值范围为1~4096。
执行本命令时,如果未指定任何参数,则清除所有AC的报文统计信息。
# 清除接口Ten-GigabitEthernet3/0/1上以太网服务实例1的报文统计信息。
<Sysname> reset l2vpn statistics ac interface ten-gigabitethernet 3/0/1 service-instance 1
·     display l2vpn service-instance verbose
·     statistics enable (Ethernet service instance view)
reset l2vpn statistics vsi命令用来清除VSI的报文统计信息。
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name:清除指定VSI的报文统计信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的信息。
# 清除本设备上所有VSI报文统计信息。
<Sysname> reset l2vpn statistics vsi
·     statistics enable (VSI view)
selective-flooding mac-addres命令用来配置VSI选择性泛洪的MAC地址。
undo selective-flooding mac-addres命令用来删除VSI的选择性泛洪MAC地址。
selective-flooding mac-addres mac-addres
undo selective-flooding mac-addres mac-addres
不存在VSI选择性泛洪MAC地址。
VSI视图
mac-address:选择性泛洪的MAC地址。该MAC地址不能为全F。
通过flooding disable命令禁止通过VXLAN隧道向远端站点泛洪后,为了将某些单播或组播MAC地址的数据帧泛洪到远端站点以保证某些业务的流量在站点间互通,可以配置选择性泛洪的MAC地址。当数据帧的目的MAC地址匹配选择性泛洪的MAC地址时,该数据帧可以泛洪到远端站点。
请不要将三层接口的MAC地址配置为选择性泛洪的MAC地址,否则可能导致选择性泛洪功能不可用。
# 在VSI vsi1下配置选择性泛洪的MAC地址为000f-e201-0101。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
·     flooding disable
service-instance命令用来创建以太网服务实例,并进入以太网服务实例视图。如果指定的以太网服务实例已经存在,则直接进入以太网服务实例视图。
undo service-instance命令用来删除指定的以太网服务实例。
undo service-instance instance-id
不存在以太网服务实例。
二层以太网接口视图
二层聚合接口视图
instance-id:以太网服务实例的编号,取值范围为1~4096。
# 在二层以太网接口Ten-GigabitEthernet3/0/1上创建以太网服务实例1,并进入以太网服务实例1的视图。
1.1.38  shutdown
shutdown命令用来关闭VSI。
undo shutdown命令用来开启VSI。
shutdown
VSI处于开启状态。
VSI视图
关闭VSI后,该VSI将不能提供二层交换服务。
关闭VSI功能通常用于暂时禁用二层交换服务,但还需要再次启用该服务的场景。关闭VSI后,该VSI所有已存在的配置保持不变。在关闭状态下还可以对VSI进行配置。VSI再次被开启后,基于最新的配置提供二层交换服务。
# 关闭名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
·     display l2vpn vsi
statistics enable命令用来开启以太网服务实例的报文统计功能。
undo statistics enable命令用来关闭以太网服务实例的报文统计功能。
statistics enable
以太网服务实例的报文统计功能处于关闭状态。
以太网服务实例视图
只有为以太网服务实例配置了报文匹配方式并绑定了VSI实例,报文统计功能才会生效。如果在报文统计过程中修改报文匹配方式或绑定的VSI实例,则报文统计重新开始。
# 开启接口Ten-GigabitEthernet3/0/1上以太网服务实例200的报文统计功能。
[Sysname-Ten-GigabitEthernet3/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet3/0/1-srv200] statistics enable
statistics enable命令用来开启手工创建VXLAN隧道或VXLAN-DCI隧道的报文统计功能。
undo statistics enable命令用来关闭手工创建VXLAN隧道或VXLAN-DCI隧道的报文统计功能。
statistics enable
手工创建VXLAN隧道和VXLAN-DCI隧道的报文统计功能处于关闭状态。
VXLAN模式或VXLAN-DCI模式的Tunnel接口视图
# 开启手工创建VXLAN隧道的报文统计功能。
[Sysname] interface tunnel 10 mode vxlan
[Sysname-Tunnel10] statistics enable
·     display interface tunnel(三层技术-IP业务命令参考/隧道)
·     reset counters interface tunnel(三层技术-IP业务命令参考/隧道)
·     tunnel statistics vxlan auto
statistics enable命令用来开启VSI的报文统计功能。
undo statistics enable命令用来关闭VSI的报文统计功能。
statistics enable
VSI的报文统计功能处于关闭状态。
VSI视图
# 开启名为vsi1的VSI的报文统计功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
·     display l2vpn vsi verbose
·     reset l2vpn statistics vsi
tracert vxlan命令用来查看VXLAN隧道所经过的路径,并根据应答信息对错误点进行定位。
tracert vxlan [ -a inner-src-address | -h ttl-value | -r reply-mode | -t timeout ] * vxlan-id vxlan-id  tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-h ttl-value:指定VXLAN Echo Request报文中外层IP头中TTL的最大值(即检测的最大跳数)。ttl-value为TTL最大值,取值范围为1~255,缺省值为30。
vxlan-source-address vxlan-source-address:指定VXLAN Echo Request报文的外层IP头的源IPv4地址。如果未指定本参数,则使用tunnel-source source-address参数指定的VXLAN隧道的源地址。在M-LAG组网中,M-LAG设备发起Tracert VXLAN操作时,需将本参数指定为M-LAG系统中本地VTEP的IP地址,以防止远端VTEP将VXLAN Echo Reply报文发给另一台M-LAG设备。
在VXLAN或EVPN VXLAN组网中,VTEP之间通过VXLAN隧道传输数据报文,当VTEP间出现丢包或断流现象时,可以通过本命令查看VXLAN隧道所经过的路径,并根据应答信息对错误点进行定位。
VTEP基于VXLAN Echo Request报文的源UDP端口号进行负载分担,当两个VTEP之间的VXLAN隧道对应多条路径时,为了保证检测结果的准确性,可以通过配置负载分担参数实现对多条路径的遍历。执行本命令时可以通过如下两种方式指定VXLAN Echo Request报文的源UDP端口号:
·     通过指定不同的MAC地址、IP地址以及协议类型参数动态计算生成VXLAN的源UDP号,实现对多条等价路径的遍历检测。采用该方式时,需要多次执行tracert vxlan命令实现对多条等价路径的遍历检测。
# 查看VXLAN 1内隧道源IP地址为11.11.11.11、目的IP地址为22.22.22.22的VXLAN隧道所经过的路径。
<Sysname> tracert vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Tracert VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
  TTL   Replier            Time    InBound                OutBound
  1     20.0.0.1           2 ms    XGE3/0/1               XGE3/0/2
  2     30.0.0.2           4 ms    XGE3/0/1               --
表1-19 tracert vxlan命令显示信息描述表
检测VXLAN-ID为1、源地址为11.11.11.11、目的地址为22.22.22.22的VXLAN隧道的连通性
TTL
跳数
Replier
节点的IP地址
Time
接收到应答的时间,单位为毫秒
InBound
VXLAN Echo Request报文的入接口
OutBound
VXLAN Echo Request报文的出接口
Return code
返回码,取值包括:
·     0:无返回码
·     2:不存在对应VXLAN
·     3:VXLAN内没有Up的隧道
·     ping vxlan
1.1.43  tunnel
tunnel命令用来配置VXLAN与VXLAN隧道关联。
undo tunnel命令用来取消VXLAN与指定隧道的关联。
tunnel { tunnel-number [ backup-tunnel tunnel-number ] | all }
undo tunnel { tunnel-number | all }
VXLAN未关联VXLAN隧道。
VXLAN视图
tunnel-number:关联指定的VXLAN隧道。tunnel-number为隧道接口的编号,指定的隧道必须是已经创建的VXLAN模式的隧道。
backup-tunnel tunnel-number:指定备用隧道。tunnel-number为隧道接口的编号,指定的隧道必须是已经创建的VXLAN模式的隧道。
all:关联所有VXLAN隧道。
在VXLAN组网中,用户可以手工将VXLAN与VXLAN隧道关联。采用单播路由泛洪方式时,如果VTEP接收到某个VXLAN的泛洪流量,则将在与该VXLAN关联的所有VXLAN隧道上发送该流量,以便将流量转发给所有的远端VTEP。
一个VXLAN可以关联多条VXLAN隧道;一条VXLAN隧道可以关联多个VXLAN。
执行本命令时,可以同时指定与VXLAN关联的主用VXLAN隧道和备用VXLAN隧道。备用VXLAN隧道为主用VXLAN隧道提供保护。当主用VXLAN隧道down时,VXLAN将启用备用VXLAN隧道。
只能通过tunnel tunnel-number命令逐一将VXLAN与每条VXLAN-DCI隧道关联。不能通过tunnel all命令将VXLAN与所有VXLAN-DCI隧道关联。
通过tunnel tunnel-number命令关联的VXLAN隧道,不能通过undo tunnel all命令取消该关联;反之,通过tunnel all命令关联所有VXLAN隧道后,不能通过undo tunnel tunnel-number命令取消关联其中的一条VXLAN隧道,只能执行undo tunnel all命令同时取消关联所有的VXLAN隧道。
通常情况下,不建议使用tunnel all命令。
# 配置VXLAN隧道Tunnel1和Tunnel2与VXLAN 10000关联。
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
·     display vxlan tunnel
tunnel global source-address命令用来配置VXLAN隧道的全局源地址。
undo tunnel global source-address命令用来恢复缺省情况。
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
未配置VXLAN隧道的全局源地址。
ipv4-address:隧道的全局源IPv4地址。
ipv6 ipv6-address:隧道的全局源IPv6地址。执行undo tunnel global source-address命令时,如果没有指定本参数,则表示删除VXLAN隧道的全局源IPv4地址。
目前仅VXLAN隧道支持全局源地址,其它类型的隧道(包括VXLAN-DCI隧道)不支持全局源地址。
如果隧道下未配置源地址或源接口,则隧道会使用全局源地址作为隧道的源地址。
VXLAN over IPv4隧道只会使用全局源IPv4地址,VXLAN over IPv6隧道只会使用全局源IPv6地址。
采用OVSDB对VTEP设备进行部署和控制时,用户不能在VXLAN隧道的Tunnel接口下手工指定源地址,只能通过本命令指定全局源地址,否则会影响控制器对VTEP设备的管理。
# 配置VXLAN隧道的全局源地址为1.1.1.1。
[Sysname] tunnel global source-address 1.1.1.1
tunnel statistics vxlan auto命令用来开启自动VXLAN隧道的报文统计功能。
undo tunnel statistics vxlan auto命令用来关闭自动VXLAN隧道的报文统计功能。
tunnel statistics vxlan auto [ destination ipv4-address ]
undo tunnel statistics vxlan auto [ destination ipv4-address ]
自动VXLAN隧道的报文统计功能处于关闭状态。
destination ipv4-address:指定目的地址的自动VXLAN隧道开启流量统计功能。ipv4-address表示隧道的目的端IPv4地址。如果未指定本参数,则表示开启所有自动VXLAN隧道报文统计功能。
执行本命令后,设备会开启本地所有或根据目的地址统计已经创建的自动VXLAN隧道上转发的流量,也会对之后创建的自动VXLAN隧道进行流量统计,直到删除自动VXLAN隧道或关闭本功能。
目前,自动VXLAN隧道包括EVPN自动创建的VXLAN隧道和OVSDB VTEP自动创建的VXLAN隧道。
# 开启自动VXLAN隧道的报文统计功能。
[Sysname] tunnel statistics vxlan auto
·     statistics enable (Tunnel interface view)
1.1.46  vsi
vsi命令用来创建一个VSI,并进入VSI视图。如果指定的VSI已经存在,则直接进入VSI视图。
undo vsi命令用来删除指定的VSI。
vsi vsi-name
undo vsi vsi-name
不存在VSI。
vsi-name:VSI的名称,为1~31个字符的字符串,区分大小写。
VSI是VTEP上为一个VXLAN提供二层交换服务的虚拟交换实例。VSI可以看作VTEP上的一台基于VXLAN进行二层转发的虚拟交换机,它具有传统以太网交换机的所有功能,包括源MAC地址学习、MAC地址老化、泛洪等。VSI与VXLAN一一对应。
# 创建名为vxlan10的VSI,并进入VSI视图。
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
·     display l2vpn vsi
1.1.47  vxlan
vxlan命令用来创建VXLAN,并进入VXLAN视图。如果指定的VXLAN已经存在,则直接进入VXLAN视图。
undo vxlan命令用来恢复缺省情况。
vxlan vxlan-id
undo vxlan
不存在VXLAN。
VSI视图
vxlan-id:VXLAN ID,取值范围为1~16777215。
在一个VSI下只能创建一个VXLAN。不同VSI下创建的VXLAN,其VXLAN ID不能相同。
# 在名称为vpna的VSI下创建编号为10000的VXLAN,并进入VXLAN视图。
[Sysname] vsi vpna
·     vsi
vxlan default-decapsulation enable命令用来开启缺省解封装IPv4 VXLAN报文的功能。
undo vxlan default-decapsulation enable命令用来关闭缺省解封装IPv4 VXLAN报文的功能。
缺省解封装IPv4 VXLAN报文的功能处于关闭状态。
在建立单向IPv4 VXLAN隧道的组网(即对端建立了指向本端的VXLAN隧道,但本端未建立指向对端的VXLAN隧道)中,本端从对端接收到VXLAN报文后,会因为无法解封装而丢弃该报文。配置本功能后,如果本端接收到的VXLAN报文的目的地址为BGP邻居地址、虚拟VTEP/ED地址(evpn m-lag group)、ED设备的虚拟IP地址(evpn edge group)、Peer-link接口的IP地址或M-LAG系统的本地地址(evpn m-lag local),则本端会解封装该报文,不会丢弃。
# 开启缺省解封装VXLAN报文的功能。
[Sysname] vxlan default-decapsulation enable
vxlan default-decapsulation source命令用来开启缺省解封装指定IPv4 VXLAN报文的功能。
undo vxlan default-decapsulation source命令用来关闭缺省解封装指定IPv4 VXLAN报文的功能。
vxlan default-decapsulation source interface interface-type interface-number
undo vxlan default-decapsulation source interface
缺省解封装指定IPv4 VXLAN报文的功能处于关闭状态。
interface interface-type interface-number:指定缺省解封装指定IPv4 VXLAN报文功能的源接口。interface-type interface-number为接口类型和接口编号。
在建立单向IPv4 VXLAN隧道的组网(即对端建立了指向本端的VXLAN隧道,但本端未建立指向对端的VXLAN隧道)中,本端从对端接收到VXLAN报文后,会因为无法解封装而丢弃该报文。配置本功能后,如果本端接收到的VXLAN报文的目的地址为指定源接口的IPv4地址,则本端会解封装该报文,不会丢弃。
只有指定的接口上配置了IP地址,本功能才生效。
如果在建立单向IPv4 VXLAN隧道的组网中配置本功能后,又建立了以指定源接口下配置的IPv4地址为源地址的、指向对端的VXLAN隧道,则本功能失效。
# 开启缺省解封装指定IPv4 VXLAN报文的功能。
[Sysname] vxlan default-decapsulation source interface ten-gigabitethernet 3/0/1
vxlan invalid-vlan-tag discard命令用来配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
undo vxlan invalid-vlan-tag discard命令用来恢复缺省情况。
不会检查VXLAN报文内层封装的以太网数据帧是否携带VLAN tag。
远端VTEP上通过xconnect vsi命令的access-mode参数配置接入模式为ethernet时,VXLAN报文可能携带VLAN tag。这种情况下建议不要在本端VTEP上执行vxlan invalid-vlan-tag discard命令,以免错误地丢弃报文。
# 配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
[Sysname] vxlan invalid-vlan-tag discard
·     xconnect vsi
vxlan ipv6 default-decapsulation enable命令用来开启缺省解封装IPv6 VXLAN报文的功能。
undo vxlan ipv6 default-decapsulation enable命令用来关闭缺省解封装IPv6 VXLAN报文的功能。
缺省解封装IPv6 VXLAN报文的功能处于关闭状态。
在建立单向IPv6 VXLAN隧道的组网(即对端建立了指向本端的VXLAN隧道,但本端未建立指向对端的VXLAN隧道)中,本端从对端接收到VXLAN报文后,会因为无法解封装而丢弃该报文。配置本功能后,如果本端接收到的VXLAN报文的目的地址为BGP邻居地址、虚拟VTEP/ED地址(evpn m-lag group)、ED设备的虚拟IP地址(evpn edge group)、Peer-link接口的IP地址或M-LAG系统的本地地址(evpn m-lag local),则本端会解封装该报文,不会丢弃。
# 开启缺省解封装IPv6 VXLAN报文的功能。
[Sysname] vxlan ipv6 default-decapsulation enable
vxlan ipv6 default-decapsulation source命令用来开启缺省解封装指定IPv6 VXLAN报文的功能。
undo vxlan ipv6 default-decapsulation source命令用来关闭缺省解封装指定IPv6 VXLAN报文的功能。
vxlan ipv6 default-decapsulation source interface interface-type interface-number
undo vxlan ipv6 default-decapsulation source interface
缺省解封装指定IPv6 VXLAN报文的功能处于关闭状态。
interface interface-type interface-number:指定缺省解封装指定IPv6 VXLAN报文功能的源接口。interface-type interface-number为接口类型和接口编号。
在建立单向IPv6 VXLAN隧道的组网(即对端建立了指向本端的VXLAN隧道,但本端未建立指向对端的VXLAN隧道)中,本端从对端接收到VXLAN报文后,会因为无法解封装而丢弃该报文。配置本功能后,如果本端接收到的VXLAN报文的目的地址为指定源接口的IPv6地址,则本端会解封装该报文,不会丢弃。
如果在建立单向IPv6 VXLAN隧道的组网中配置本功能后,又建立了以指定源接口下配置的IPv6地址为源地址的、指向对端的IPv6 VXLAN隧道,则本功能失效。
# 开启缺省解封装指定IPv6 VXLAN报文的功能。
[Sysname] vxlan ipv6 default-decapsulation source interface ten-gigabitethernet 3/0/1
vxlan local-mac report命令用来开启本地MAC地址的日志记录功能。
undo vxlan local-mac report命令用来关闭本地MAC地址的日志记录功能。
本地MAC地址的日志记录功能处于关闭状态。
开启本地MAC地址的日志记录功能后,VXLAN会立即根据已经学习到的本地MAC地址表项生成日志信息,之后在增加或删除本地MAC地址时也将产生日志信息。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
# 开启本地MAC地址的日志记录功能。
[Sysname] vxlan local-mac report
vxlan tunnel mac-learning disable命令用来关闭远端MAC地址自动学习功能。
undo vxlan tunnel mac-learning disable命令用来开启远端MAC地址自动学习功能。
远端MAC地址自动学习功能处于开启状态。
本命令仅对手工创建的VXLAN隧道生效。
如果网络中存在攻击,为了避免学习到错误的远端MAC地址,可以通过本命令手工关闭远端MAC地址自动学习功能。
# 关闭远端MAC地址自动学习功能。
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port命令用来配置VXLAN报文的目的UDP端口号。
undo vxlan udp-port命令用来恢复缺省情况。
vxlan udp-port port-number
undo vxlan udp-port
VXLAN报文的目的UDP端口号为4789。
port-number:VXLAN报文的目的UDP端口号,取值范围为1~65535。建议不要将VXLAN报文的目的UDP端口号配置为知名端口,即1~1023之间的端口。
属于同一个VXLAN的VTEP设备上需要配置相同的UDP端口号。
# 配置VXLAN报文的目的UDP端口号为6666。
[Sysname] vxlan udp-port 6666
vxlan vlan-based命令用来开启VLAN关联VXLAN功能。
undo vxlan vlan-based命令用来关闭VLAN关联VXLAN功能。
vxlan vlan-based
VLAN关联VXLAN功能处于关闭状态。
可以通过如下两种方式将指定VLAN的数据帧映射到特定VXLAN:
·     配置以太网服务实例关联VSI:在以太网服务实例下配置报文匹配规则匹配指定VLAN的数据帧后,将该以太网服务实例与VSI关联,可以实现将接口上收到的指定VLAN的数据帧映射到VSI对应的VXLAN。
·     配置VLAN关联VXLAN:执行本命令开启VLAN关联VXLAN功能,并在VLAN视图下执行vxlan vni命令配置与该VLAN关联的VXLAN后,如果存在属于该VLAN的接口,则自动在该接口上创建编号为当前VLAN ID、匹配外层VLAN tag为当前VLAN ID的以太网服务实例,并将该以太网服务实例与指定VXLAN对应的VSI关联。
上述两种方式不能同时配置。
# 开启VLAN关联VXLAN功能。
1.1.57  vxlan vni
vxlan vni命令用来配置VLAN与指定的VXLAN关联。
undo vxlan vni命令用来取消VLAN与VXLAN关联。
vxlan vni vxlan-id
undo vxlan vni
未指定与VLAN关联的VXLAN。
VLAN视图
vxlan-id:与VLAN关联的VXLAN ID,取值范围为1~16777215。
配置本命令前,需要先执行vxlan vlan-based命令开启VLAN关联VXLAN功能。
不能通过本命令配置VLAN 1与VXLAN关联。
本命令中指定的VXLAN ID不能为EVPN组网中的L3VNI。
本命令中指定的VXLAN ID可以不存在。在用户创建该VXLAN时,会自动创建AC,并将AC与VXLAN关联。
# 配置VLAN 10关联VXLAN 100。
[Sysname] vlan 10
·     vxlan vlan-based
1.1.58  xconnect vsi
xconnect vsi命令用来将AC与VSI关联。
undo xconnect vsi命令用来恢复缺省情况。
xconnect vsi vsi-name [ access-mode { ethernet | vlan } | microsegment microsegment-id | on-demand ] * [ track track-entry-number&<1-3> ]
undo xconnect vsi
AC未关联VSI。
以太网服务实例视图
access-mode:指定接入模式
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
microsegment microsegment-id:AC关联的微分段ID,取值范围为1~65535。如果未指定本参数,则表示AC未关联微分段ID。
on-demand:指定按需下发AC的转发信息。如果未指定本参数,则AC的转发信息会直接下发到硬件。
track track-entry-number&<1-3>:配置AC与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
在某个接口的以太网服务实例视图下执行本命令后,从该接口接收到的、符合以太网服务实例报文匹配规则的报文,将通过查找关联VSI的MAC地址表进行转发。
在以太网服务实例下配置该命令前,必须先配置encapsulation命令。
接入模式分为以下两种:
·     VLAN接入模式:从本地站点接收到的和发送给本地站点的以太网帧必须带有VLAN Tag。VTEP从本地站点接收到以太网帧后,删除该帧的所有VLAN Tag,再转发该数据帧;VTEP发送以太网帧到本地站点时,为其添加本地站点的VLAN Tag。采用该模式时,VTEP不会传递VLAN Tag信息,不同站点可以独立地规划自己的VLAN,不同站点的不同VLAN之间可以互通。
·     Ethernet接入模式:从本地站点接收到的和发送给本地站点的以太网帧可以携带VLAN Tag,也可以不携带VLAN Tag。VTEP从本地站点接收到以太网帧后,保持该帧的VLAN Tag信息不变,转发该数据帧;VTEP发送以太网帧到本地站点时,不会为其添加VLAN Tag。采用该模式时,VTEP会在不同站点间传递VLAN Tag信息,不同站点的VLAN需要统一规划,否则无法互通。
执行本命令时,通过指定microsegment参数可以将通过该AC接入的用户加入到同一个微分段中。有关微分段的详细介绍,请参见“安全配置指导”中的“微分段”。
不同的AC可以关联相同的微分段ID。
执行本命令时,如果未指定on-demand参数,则设备上AC的转发信息会直接下发到硬件,占用硬件资源。通过on-demand参数指定按需下发AC的转发信息后,只有当AC接收到业务流量时,设备才会将AC的转发信息下发到硬件。若下发AC的转发信息后,从该AC学习到的MAC地址表项都已经老化,则删除该AC的转发信息,以节省设备的硬件资源。
配置了按需下发AC转发信息功能的以太网服务实例的报文匹配规则只能为encapsulation s-vid vlan-id,并且只有vlan-id下的动态MAC地址表项才会触发转发信息的下发。
# 接口Ten-GigabitEthernet3/0/1下采用以太网服务实例200来匹配外层VLAN为200的报文,将该以太网服务实例与名为vpn1的VSI关联。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-Ten-GigabitEthernet3/0/1-srv200] encapsulation s-vid 200
[Sysname-Ten-GigabitEthernet3/0/1-srv200] xconnect vsi vpn1
·     encapsulation
·     vsi
1.2  VXLAN IP网关配置命令
仅SF系列接口板支持VXLAN IP网关功能。
arp distributed-gateway dynamic-entry synchronize命令用来开启分布式网关的动态ARP表项同步功能。
undo arp distributed-gateway dynamic-entry synchronize命令用来关闭分布式网关的动态ARP表项同步功能。
分布式网关的动态ARP表项同步功能处于关闭状态。
分布式VXLAN IP网关上开启本地代理ARP功能时,本地网关不会将目标IP地址为分布式网关VSI虚接口的ARP报文转发给其他网关,只有本地网关能够学习到ARP报文发送者的ARP表项。如果希望所有网关都能学习到该ARP表项,需要开启分布式网关的动态ARP表项同步功能。
分布式VXLAN IP网关之间也可以通过控制器或EVPN等在彼此之间同步ARP表项,此时无需开启本功能。
# 开启分布式网关的动态ARP表项同步功能。
[Sysname] arp distributed-gateway dynamic-entry synchronize
·     distributed-gateway local
·     local-proxy-arp enable(三层技术-IP业务命令参考/代理ARP)
1.2.2  arp send-rate
arp send-rate命令用来开启VSI虚接口的ARP报文发送限速功能。
undo arp send-rate命令用来关闭VSI虚接口的ARP报文发送限速功能。
arp send-rate pps
undo arp send-rate
VSI虚接口的ARP报文发送限速功能处于关闭状态。
VSI虚接口视图
pps:ARP报文发送限速速率,取值范围为1~500,单位为包每秒(pps)。
开启VSI虚接口的ARP报文发送限速功能后,如果VSI虚接口的ARP报文发送速率超过限制的值,则后续待发送的ARP报文将被丢弃,直到接口的ARP发送速率低于限速速率。
本命令仅限制VSI虚接口触发的ARP请求报文的发送速率。
虚拟机的报文处理能力较弱,通过本配置可以控制VTEP发往虚拟机的ARP报文速率,以免影响虚拟机工作。
# 配置VSI虚接口1的ARP报文发送限速为50pps。
<Sysname> system
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] arp send-rate 50
1.2.3  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
VSI虚接口视图
bandwidth-value:接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口VSI-interface100的期望带宽为10000kbps。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
1.2.4  default
default命令用来恢复接口的缺省配置。
default
VSI虚接口视图
# 将接口VSI-interface100恢复为缺省配置。
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
1.2.5  description
description命令用来配置接口的描述信息。
接口的描述信息为“接口名 Interface”,例如:Vsi-interface100 Interface。
VSI虚接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 配置接口VSI-interface100的描述信息为“gateway for VXLAN 10”。
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface命令用来显示VSI虚接口的相关信息。
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]:指定VSI虚接口及其编号。vsi-interface-id为VSI虚接口的编号,只能指定设备上已创建的VSI虚接口的编号。如果不指定vsi-interface,则显示设备支持的所有接口的相关信息;如果指定vsi-interface,不指定vsi-interface-id,则显示所有VSI虚接口的信息。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
down:显示当前物理状态为down的接口的信息以及down的原因。如果不指定该参数,则不会根据接口物理状态来过滤显示信息。
# 显示接口VSI-interface100的相关信息。
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
表1-20 display interface vsi-interface命令显示信息描述表
Vsi-interface100
Current state
接口的物理状态和管理状态,取值包括:
·     DOWN:该接口的管理状态为开启,但物理状态为关闭
·     UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,取值包括:
·     UP:表示该接口的链路层协议状态为开启
·     UP(spoofing):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
·     DOWN:表示该接口的链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     Unnumbered:借用其他接口的IP地址
IP报文发送帧格式
hardware address
硬件地址
IPv6报文发送帧格式
Physical
接口的物理类型,取值为Unknown
baudrate
接口的波特率,单位为kbps
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直未执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
总计输入的报文数,总计输入的字节,总计丢弃的输入报文数
总计输出的报文数,总计输出的字节,总计丢弃的输出报文数
# 显示所有VSI虚接口的概要信息。
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# 显示接口VSI-interface100的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface vsi-interface 100 brief description
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# 显示当前状态为down的接口的信息以及DOWN的原因。
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
表1-21 display interface vsi-interface brief命令显示信息描述表
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     ‌(暂不支持)如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值包括:
·     UP:表示本链路物理上是连通的
·     DOWN:表示本链路物理上是不通的
·     ADM:表示本链路被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
Protocol
接口的链路层协议状态,取值包括:
·     UP (s):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     Not connected:表示没有VSI关联该接口,或者关联该接口的VSI内没有AC或VXLAN隧道
·     reset counters interface vsi-interface
1.2.7  distributed-gateway local
distributed-gateway local命令用来配置VSI虚接口为分布式网关接口。
undo distributed-gateway local命令用来恢复缺省情况。
VSI虚接口不是分布式网关接口。
VSI虚接口视图
在分布式VXLAN IP网关组网中,多个网关上同一VXLAN的VSI虚接口需要配置相同的IP地址。为了避免IP地址冲突,需要在VSI虚接口上执行本命令,以防止VSI虚接口上报地址冲突,导致VSI虚接口不可用。
# 配置接口Vsi-interface100为分布式网关接口。
[Sysname-Vsi-interface100] distributed-gateway local
1.2.8  gateway subnet
gateway subnet命令用来配置VSI所属的子网网段。
undo gateway subnet命令用来删除VSI所属的子网网段。
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
未指定VSI所属的子网网段。
VSI视图
ipv4-address:IPv4子网网段地址,为点分十进制格式。
wildcard-mask:IPv4地址掩码的反码,即将IPv4地址的掩码取反(0变1,1变0)。例如:子网掩码255.0.0.0的反码为0.255.255.255。其中,反码中的“1”表示忽略IPv4地址中对应的位,“0”表示必须保留此位。
ipv6-address prefix-length:IPv6地址及前缀长度。prefix-length为IPv6前缀长度,取值范围为1~128。
多个VXLAN共用一个VSI虚接口时,可以在VSI视图下通过本命令指定VSI所属的子网网段,通过子网网段判断报文所属的VSI,并在该VSI内转发报文。
在VSI视图下配置子网网段前,必须先为该VSI指定网关接口。取消为VSI指定网关接口时,会自动删除为该VSI指定的子网网段。
一个VSI视图下最多可以配置8个子网网段,包括IPv4子网和IPv6子网。
不能为指定了相同网关接口的不同VSI配置相同的子网网段。
通过本命令指定VSI所属的子网网段后,不会限制学习到该VSI的ARP/ND表项所属的网段,该VSI可能会学习到共用同一个VSI虚接口的其他VSI所属子网网段的ARP/ND表项。
# 配置名称为vxlan的VSI所属的子网网段为100.0.10.0/24。
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
1.2.9  gateway vsi-interface
gateway vsi-interface命令用来为VSI指定网关接口。
undo gateway vsi-interface命令用来恢复缺省情况。
gateway vsi-interface vsi-interface-id
未指定VSI的网关接口。
VSI视图
vsi-interface-id:VSI网关虚接口的编号,只能指定设备上已经创建的VSI虚接口。
本命令中指定的VSI网关虚接口必须已经通过interface vsi-interface命令创建。如果将VSI虚接口指定为网关接口后,执行undo interface vsi-interface命令删除该VSI虚接口,则指定网关接口的配置也将删除。
一个VSI只能指定一个网关接口。
不同的VSI可以指定相同的网关接口。
# 为VSI指定网关接口为Vsi-interface100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
·     interface vsi-interface
1.2.10  interface vsi-interface
interface vsi-interface命令用来创建VSI虚接口,并进入VSI虚接口视图。如果指定的VSI虚接口已经存在,则直接进入VSI虚接口视图。
undo interface vsi-interface命令用来删除指定的VSI虚接口。
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
不存在VSI虚接口。
vsi-interface-id:VSI虚接口的编号,取值范围为0~16777215。
如果通过gateway vsi-interface命令将VSI虚接口指定为网关接口后,执行undo interface vsi-interface命令删除该VSI虚接口,则指定网关接口的配置也将删除。
# 创建VSI虚接口100,并进入VSI虚接口视图。
·     gateway vsi-interface
1.2.11  ipv6 nd distributed-gateway dynamic-entry synchronize
ipv6 nd distributed-gateway dynamic-entry synchronize命令用来开启分布式网关的动态IPv6 ND表项同步功能。
undo ipv6 nd distributed-gateway dynamic-entry synchronize命令用来关闭分布式网关的动态IPv6 ND表项同步功能。
分布式网关的动态IPv6 ND表项同步功能处于关闭状态。
分布式VXLAN IP网关上开启本地ND代理功能时,本地网关不会将目标IP地址为分布式网关VSI虚接口的IPv6 ND报文转发给其他网关,只有本地网关能够学习到IPv6 ND报文发送者的ND表项。如果希望所有网关都能学习到该ND表项,需要开启分布式网关的动态IPv6 ND表项同步功能。
分布式VXLAN IP网关之间也可以通过控制器或EVPN等在彼此之间同步IPv6 ND表项,此时无需开启本功能。
# 开启分布式网关的动态IPv6 ND表项同步功能。
[Sysname] ipv6 nd distributed-gateway dynamic-entry synchronize
·     local-proxy-nd enable(三层技术-IP业务命令参考/IPv6基础)
1.2.12  mac-address
mac-address命令用来配置VSI虚接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
VSI虚接口的MAC地址为设备上VLAN接口4094的MAC地址。
VSI虚接口视图
mac-address:MAC地址,形式为H-H-H。
请不要将本命令的MAC地址配置为选择性泛洪的MAC地址,否则可能导致选择性泛洪功能不可用。
# 配置VSI虚接口100的MAC地址为0001-0001-0001。
[Sysname-Vsi-interface100] mac-address 1-1-1
1.2.13  mtu
mtu命令用来配置接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
VSI虚接口的MTU值为1444字节。
VSI虚接口视图
# 配置接口VSI-interface100的MTU值为1430字节。
[Sysname-Vsi-interface100] mtu 1430
1.2.14  reset counters interface vsi-interface
reset counters interface vsi-interface命令用来清除VSI虚接口的统计信息。
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
vsi-interface [ vsi-interface-id ]:指定VSI虚接口及其编号。vsi-interface-id为VSI虚接口的编号,只能指定设备上已创建的VSI虚接口的编号。如果不指定vsi-interface,则清除设备支持的所有接口的统计信息;如果指定vsi-interface,不指定vsi-interface-id,则清除所有VSI虚接口的统计信息。
# 清除接口VSI-interface100的统计信息。
<Sysname> reset counters interface vsi-interface 100
·     display interface vsi-interface
1.2.15  shutdown
shutdown命令用来关闭VSI虚接口。
undo shutdown命令用来开启VSI虚接口。
shutdown
VSI虚接口均处于开启状态。
VSI虚接口视图
执行本命令会导致使用该接口作为网关的VXLAN网络不能进行三层通信,请谨慎使用。
# 关闭接口VSI-interface100。
[Sysname-Vsi-interface100] shutdown
1.2.16  vtep group member local
vtep group member local命令用来将本设备加入VXLAN IP网关保护组,并配置本设备的成员地址。
undo vtep group member local命令用来取消本设备加入指定的VXLAN IP网关保护组。
vtep group group-ip member local member-ip
undo vtep group group-ip member local
设备未加入VXLAN IP网关保护组。
group-ip:VXLAN IP网关保护组的VTEP IP地址,该地址必须是本设备上已经存在的地址。
member-ip:本设备在VXLAN IP网关保护组内的成员地址,该地址必须是设备上已经配置的地址。
成员地址不能和保护组的VTEP IP相同;同一个保护组中不同成员的成员地址也不能相同。
# 配置本设备加入VXLAN IP保护组,保护组的VTEP IP地址是1.1.1.1,本设备的成员地址为2.2.2.2。
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
·     vtep group member remote
1.2.17  vtep group member remote
vtep group member remote命令用来配置VXLAN IP网关保护组的成员地址列表。
undo vtep group member remote命令用来删除指定VXLAN IP网关保护组的成员地址列表。
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
未配置VXLAN IP网关保护组的成员地址列表。
group-ip:VXLAN IP网关保护组的VTEP IP地址。
member-ip&<1-8>:VXLAN IP网关保护组成员IP地址列表。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
# 配置VXLAN IP网关保护组1.1.1.1包含的成员设备为2.2.2.2、3.3.3.3和4.4.4.4。
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
·     vtep group member local
1.2.18  vxlan tunnel arp-learning disable
vxlan tunnel arp-learning disable命令用来关闭远端ARP自动学习功能。
undo vxlan tunnel arp-learning disable命令用来开启远端ARP自动学习功能。
远端ARP自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ARP信息,即远端ARP信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel arp-learning disable命令暂时关闭远端ARP自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel arp-learning disable命令开启远端ARP自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel arp-learning disable命令。
# 关闭远端ARP自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
1.2.19  vxlan tunnel nd-learning disable
vxlan tunnel nd-learning disable命令用来关闭远端ND自动学习功能。
undo vxlan tunnel nd-learning disable命令用来开启远端ND自动学习功能。
远端ND自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ND信息,即远端ND信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel nd-learning disable命令暂时关闭远端ND自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel nd-learning disable命令开启远端ND自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel nd-learning disable命令。
# 关闭远端ND自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel nd-learning disable
1.3  OVSDB-VTEP配置命令
1.3.1  ovsdb server bootstrap ca-certificate
ovsdb server bootstrap ca-certificate命令用来指定与控制器进行SSL通信时使用的CA证书文件。
undo ovsdb server bootstrap ca-certificate命令用来恢复缺省情况。
ovsdb server bootstrap ca-certificate ca-filename
与控制器进行SSL通信时使用PKI域中的CA证书文件。
ca-filename:表示与控制器进行SSL通信时使用的CA证书文件名称,不区分大小写,文件名称中不允许出现slot字样。只允许使用主用主控板的CA证书文件。
通过本命令指定与控制器进行SSL通信使用的CA证书文件时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
本命令指定的只能是主用主控板中的CA证书文件。如果指定的文件存在,直接使用。否则,使用开启OVSDB服务器时通过SSL连接获取的自签名证书,并通过本命令指定证书文件名。
执行本命令后,优先使用本命令指定的CA证书文件,不使用PKI域中的CA证书。
# 指定与控制器进行SSL通信时使用的CA证书文件为ca-new。
[Sysname] ovsdb server bootstrap ca-certificate ca-new
·     ovsdb server enable
·     ovsdb server pki domain
·     ovsdb server pssl
·     ovsdb server ssl
1.3.2  ovsdb server enable
ovsdb server enable命令用来开启OVSDB服务器。
undo ovsdb server enable命令用来关闭OVSDB服务器。
ovsdb server enable
OVSDB服务器处于关闭状态。
开启OVSDB服务器后,OVSDB服务器可以与控制器建立连接,接收控制器通过OVSDB控制协议发送的数据,并保存到本地OVSDB数据库中,从而实现控制器对VTEP设备进行VXLAN相关配置。
为了保证OVSDB服务器能够与控制器建立连接,在开启OVSDB服务器前,必须先配置至少一条与控制器的连接。
# 开启OVSDB服务器。
[Sysname] ovsdb server enable
1.3.3  ovsdb server pki domain
ovsdb server pki domain命令用来指定与控制器进行SSL通信时使用的PKI域。
undo ovsdb bootstrap server pki domain命令用来恢复缺省情况。
ovsdb server pki domain domain-name
undo ovsdb server pki domain
未指定与控制器进行SSL通信时使用的PKI域。
domain-name:表示与控制器进行SSL通信时使用的PKI域名称,为1~31个字符的字符串,区分大小写。指定的PKI域必须存在,并且PKI域中包含完整的证书和密钥。PKI域的详细介绍,请参见“安全配置指导”中的“PKI”。
与控制器进行SSL通信时需通过本命令指定PKI域。
通过本命令指定与控制器进行SSL通信时使用的PKI域时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
# 指定与控制器进行SSL通信时使用的PKI域为ovsdb_test。
[Sysname] ovsdb server pki domain ovsdb_test
·     ovsdb server bootstrap ca-certificate
·     ovsdb server pssl
·     ovsdb server ssl
1.3.4  ovsdb server pssl
ovsdb server pssl命令用来配置与控制器建立被动SSL连接。
undo ovsdb server pssl命令用来恢复缺省情况。
ovsdb server pssl [ port port-number ]
不会与控制器建立被动SSL连接。
port port-number:指定与控制器建立SSL连接的端口号,OVSDB服务器监听该端口上的SSL连接请求。port-number取值范围为1~65535。如果不指定本参数,则监听6640端口。
配置与控制器建立被动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立被动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的SSL连接端口号。多次执行本命令,最后一次执行的命令生效。
# 配置与控制器建立被动SSL连接,监听端口号采用默认端口号。
[Sysname] ovsdb server pssl
·     ovsdb server ssl
1.3.5  ovsdb server ptcp
ovsdb server ptcp命令用来配置与控制器建立被动TCP连接。
undo ovsdb server ptcp命令用来恢复缺省情况。
ovsdb server ptcp [ port port-number ] [ acl acl-number ]
不会与控制器建立被动TCP连接。
port port-number:指定与控制器建立TCP连接的监听端口号,取值范围为1~65535,如果不指定本参数,则监听6640端口。
acl acl-number:指定用来过滤控制器的IPv4 ACL。acl-number表示IPv4基本ACL的编号,取值范围为2000~2999。
通过本命令配置与控制器建立被动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的TCP连接端口号。多次执行本命令,最后一次执行的命令生效。
执行本命令时如果通过acl acl-number参数指定了IPv4 ACL,则OVSDB服务器接收到控制器发送的TCP连接请求后,将通过IPv4 ACL匹配该请求:
·     只有IPv4 ACL允许请求报文通过时,控制器才可以与本地的OVSDB服务器建立被动TCP连接。
·     请求报文未匹配IPv4 ACL或IPv4 ACL拒绝其通过时,OVSDB控制器不能与OVSDB服务器建立被动TCP连接。
·     在引用的IPv4 ACL中,若IPv4 ACL规则指定了vpn-instance参数,则表示该规则仅对VPN报文有效;若规则未指定vpn-instance参数,则表示该规则对公网报文和VPN报文均有效。
如果未指定IPv4 ACL、指定的IPv4 ACL不存在或指定的IPv4 ACL下没有配置规则,则表示允许所有控制器与OVSDB服务器建立被动TCP连接。如果修改了指定的IPv4 ACL规则,则该规则仅对新建立的被动TCP连接生效。
# 配置与控制器建立被动TCP连接,监听端口号采用默认端口号。
[Sysname] ovsdb server ptcp
·     ovsdb server tcp
1.3.6  ovsdb server ssl
ovsdb server ssl命令用来配置与控制器建立主动SSL连接。
undo ovsdb server ssl命令用来删除指定的主动SSL连接。
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
不会与控制器建立主动SSL连接。
ssl ip-address:指定SSL连接的目的IP地址。
port port-number:指定SSL连接的目的端口号,取值范围为1~65535。
配置与控制器建立主动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立主动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的SSL主动连接。
# 配置与控制器建立主动SSL连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
·     ovsdb server pssl
1.3.7  ovsdb server tcp
ovsdb server tcp命令用来配置与控制器建立主动TCP连接。
undo ovsdb server tcp命令用来删除指定的主动TCP连接。
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
不会与控制器建立主动TCP连接。
ip ip-address:指定TCP连接的目的IP地址。
port port-number:指定TCP连接的目的端口号。
通过本命令配置与控制器建立主动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的TCP主动连接。
# 配置与控制器建立主动TCP连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
·     ovsdb server ptcp
1.3.8  vtep access port
vtep access port命令用来指定当前接口为用户侧的接入端口。
undo vtep access port命令用来恢复缺省情况。
vtep access port
当前接口不是用户侧的接入端口。
二层以太网接口视图
二层聚合接口视图
三层接口视图
只有将接口配置为用户侧的接入端口后,控制器上才能够显示该端口并对其进行控制。
# 指定二层以太网接口Ten-GigabitEthernet3/0/1为用户侧的接入端口。
[Sysname-Ten-GigabitEthernet3/0/1] vtep access port
1.3.9  vtep acl disable
vtep acl disable命令用来禁止控制器下发的ACL在VTEP上生效。
undo vtep acl disable命令用来恢复缺省情况。
vtep acl disable
控制器下发的ACL在VTEP上生效。
配置本命令前,需要先执行vtep enable命令开启OVSDB VTEP服务。
在OVSDB-VTEP组网中,控制器通过OVSDB控制协议下发ACL到VTEP,占用VTEP上的ACL资源。通过配置本命令,用户可以禁止控制器下发的ACL在VTEP上生效,以便节约设备上的ACL资源。
在执行vtep acl disable命令禁止控制器下发的ACL在VTEP上生效后,可以通过执行undo vtep acl disable命令使控制器下发的ACL重新生效。
# 配置禁止控制器下发的ACL在VTEP上生效。
[Sysname] vtep enable
[sysname] vtep acl disable
·     vtep enable
1.3.10  vtep enable
vtep enable命令用来开启OVSDB VTEP服务。
undo vtep enable命令用来关闭OVSDB VTEP服务。
vtep enable
undo vtep enable
OVSDB VTEP服务处于关闭状态。
# 开启设备的OVSDB VTEP服务。
