09-射频资源管理命令参考
06-WLAN RRM命令
本章节下载 06-WLAN RRM命令  (432.40 KB)
06-WLAN RRM命令
  录
1 WLAN RRM
1.1 WLAN RRM配置命令
1.1.1 adjacency-factor
1.1.2 adjacency-factor radio-selection
1.1.3 ap name
1.1.4 calibrate-bandwidth self-decisive
1.1.5 calibrate-channel 2.4g channel-usage-threshold
1.1.6 calibrate-channel 2.4g crc-error-threshold
1.1.7 calibrate-channel 2.4g interference-threshold
1.1.8 calibrate-channel 2.4g noise-threshold
1.1.9 calibrate-channel 2.4g receive-service-traffic threshold
1.1.10 calibrate-channel 2.4g retransmission-threshold
1.1.11 calibrate-channel 2.4g tolerance-level
1.1.12 calibrate-channel 5g channel-usage-threshold
1.1.13 calibrate-channel 5g crc-error-threshold
1.1.14 calibrate-channel 5g interference-threshold
1.1.15 calibrate-channel 5g noise-threshold
1.1.16 calibrate-channel 5g receive-service-traffic threshold
1.1.17 calibrate-channel 5g retransmission-threshold
1.1.18 calibrate-channel 5g tolerance-level
1.1.19 calibrate-channel interference–threshold
1.1.20 calibrate-channel mode
1.1.21 calibrate-channel monitoring time-range
1.1.22 calibrate-channel pronto
1.1.23 calibrate-channel receive-service-traffic threshold
1.1.24 calibrate-channel self-decisive
1.1.25 calibrate-channel self-decisive sensitivity
1.1.26 calibrate-channel suppression
1.1.27 calibrate-channel track spectrum-analysis
1.1.28 calibrate-power 2.4g adjacency-factor
1.1.29 calibrate-power 2.4g min
1.1.30 calibrate-power 2.4g threshold
1.1.31 calibrate-power 5g adjacency-factor
1.1.32 calibrate-power 5g min
1.1.33 calibrate-power 5g threshold
1.1.34 calibrate-power min
1.1.35 calibrate-power mode
1.1.36 calibrate-power self-decisive
1.1.37 calibrate-power threshold
1.1.38 channel holddown-time
1.1.39 channel-usage-threshold
1.1.40 crc-error-threshold
1.1.41 description
1.1.42 display wlan rrm baseline
1.1.43 display wlan rrm baseline apply-history
1.1.44 display wlan rrm-calibration-group
1.1.45 display wlan rrm-history ap
1.1.46 display wlan rrm-status ap
1.1.47 interference-threshold
1.1.48 power holddown-time
1.1.49 rrm
1.1.50 scan-only
1.1.51 snmp-agent trap enable wlan rrm
1.1.52 tolerance-level
1.1.53 wlan calibrate-channel pronto ap all
1.1.54 wlan calibrate-power pronto ap all
1.1.55 wlan rrm baseline apply
1.1.56 wlan rrm baseline remove
1.1.57 wlan rrm baseline save
1.1.58 wlan rrm calibration-bandwidth interval
1.1.59 wlan rrm calibration-channel ap
1.1.60 wlan rrm calibration-channel interval
1.1.61 wlan rrm calibration-power interval
1.1.62 wlan rrm-calibration-group
1 WLAN RRM
本手册中的AP型号和序列号仅为举例,具体支持的AP型号和序列号请以设备的实际情况为准。
1.1  WLAN RRM配置命令
adjacency-factor命令用来配置邻居因子。
undo adjacency-factor命令用来恢复缺省情况。
adjacency-factor neighbor
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
neighbor:邻居因子,取值范围为1~16。
邻居因子既作为功率比较门限,也用于在功率比较时选择一个功率值来和功率调整门限进行比较。
·     功率比较门限:当检测到Radio信息的其它Radio的数目达到功率比较门限,AC才会进行功率比较,判断出是否调整Radio的功率。否则,将Radio的发射功率调整为最大发射功率。以邻居因子等于3为例,则当检测到Radio信息的其它Radio的数目达到3个时,AC才会进行功率比较。
·     选择用于功率比较的功率值:功率比较时,AC会将其它Radio检测到的该Radio功率值进行从大到小排序后,挑选出排名与邻居因子相同的功率值,即,如果邻居因子为3,则选择排名第3位的功率值来和功率调整门限进行比较。
RRM视图下配置的优先级高于AP组RRM视图下的配置,AP组RRM视图下配置的优先级高于全局视图下的配置。
# 配置邻居因子为7。(RRM视图)
[Sysname] wlan ap ap1
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rrm
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor 7
# 配置邻居因子为7。(AP组RRM视图)
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacency-factor 7
adjacency-factor radio-selection命令用来配置参与邻居因子计算的邻居选择方式。
undo adjacency-factor radio-selection命令用来恢复缺省情况。
adjacency-factor radio-selection { all-channel | overlapping-channel }
RRM视图:继承AP组RRM配置。
AP组RRM视图:参与邻居因子计算的邻居选择方式为全信道邻居选择。
RRM视图
AP组RRM视图
all-channel:全信道邻居选择方式。
overlapping-channel:频谱交叠邻居选择方式。
参与邻居因子计算的邻居选择方式有两种:全信道邻居选择与频谱交叠邻居选择。
·     全信道邻居选择:在所有支持的信道上捕获到本Radio所发射无线信号的同一AC管理的其它Radio,计算邻居因子时将依据这些Radio的邻居报告。
·     频谱交叠邻居选择:在有频谱交集的信道上捕获到本Radio所发射无线信号的同一AC管理的其它Radio,计算邻居因子时将依据这些Radio的邻居报告。
全信道邻居选择方式可以更严格的控制信号覆盖范围;频谱交叠邻居选择方式可以更精确的调整功率大小,在不对其它有频谱交集的信道造成更多干扰的同时,可以扩大信号的覆盖范围。
# 配置参与邻居因子计算的邻居选择方式为频谱交叠邻居选择。(RRM视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
# 配置参与邻居因子计算的邻居选择方式为频谱交叠邻居选择。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
1.1.3  ap name
ap name命令用来将指定的Radio加入到RRM保持调整组中。
undo ap name用来删除RRM保持调整组中的Radio。
ap name ap-name radio radio-id
undo ap { name ap-name [ radio radio-id ] | all }
RRM保持调整组中不存在任何AP的Radio。
RRM保持调整组视图
name ap-name:加入RRM保持调整组的AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
radio radio-id:将AP的射频加入RRM保持调整组,其中radio-id为射频编号。如果未指定本参数,则删除RRM保持调整组中指定AP的所有射频。
all:删除RRM保持调整组中的所有射频。
加入RRM保持调整组的Radio必须已经存在。
一个Radio只能加入一个RRM保持调整组,将Radio加入到新的RRM保持调整组中,则原先的RRM保持调整组会删除该Radio。
# 将ap1的Radio 2加入到ID为10的RRM保持调整组中。
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rrm-calibration-group-10] ap name ap1 radio 2
calibrate-bandwidth self-decisive enable命令用来开启自动频宽调整。
calibrate-bandwidth self-decisive disable命令用来关闭自动频宽调整。
undo calibrate-bandwidth self-decisive命令用来恢复缺省情况。
RRM视图/AP组RRM视图:
calibrate-bandwidth self-decisive { disable | enable }
全局配置视图:
undo calibrate-bandwidth self-decisive enable
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
全局配置视图:自动频宽调整处于关闭状态。
RRM视图
AP组RRM视图
全局配置视图
当某射频的邻居Radio数量过多时,需要降低频宽,以减少干扰;当某射频的邻居Radio数量较少时,需要增大频宽,以提高数据传输速率。增大频宽或减小频宽是通过将相邻的信道绑定或拆分完成的。
开启自动频宽调整后,AC在每一个自动频宽调整周期到达时,都会开始频宽调整流程。
本命令仅对5GHz频段射频生效。
# 开启自动频宽调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-bandwidth self-decisive enable
# 开启自动频宽调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-bandwidth self-decisive enable
# 开启所有AP的5GHz频段射频的自动频宽调整功能。(全局配置视图)
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] calibrate-bandwidth self-decisive enable
calibrate-channel 2.4g channel-usage-threshold命令用来配置2.4GHz频段信道使用率门限值。
undo calibrate-channel 2.4g channel-usage-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g channel-usage-threshold percent percent
undo calibrate-channel 2.4g channel-usage-threshold percent
2.4GHz频段信道使用率门限值为60。
全局配置视图
percent percent:信道使用率门限值,以百分比表示,取值范围为1~100。
在满足以下所有条件时,设备将进行信道质量计算:
·     射频口在当前信道收发的报文占报文处理能力的百分比达到门限值;
·     干扰在信道使用率中的占比达到门限值;
·     射频接收流量中业务流量未达到设定的阈值。
# 配置所有AP的2.4GHz频段信道使用率门限值为40。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-usage-threshold percent 40
·     calibrate-channel 2.4g interference-threshold
·     calibrate-channel 2.4g receive-service-traffic threshold
calibrate-channel 2.4g crc-error-threshold命令用来配置2.4GHz频段信道的CRC错误门限值。
undo calibrate-channel 2.4g crc-error-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g crc-error-threshold percent
2.4GHz频段信道的CRC错误门限值为0。
全局配置视图
percent:CRC错误门限值,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不考虑CRC错误门限值。
CRC错误门限值是触发自动信道调整的条件之一。当AC检测到2.4GHz频段信道中CRC错误的帧占所有802.11帧的百分比达到或超过设定值时,将触发自动信道调整。
RRM视图下CRC错误门限值配置的优先级高于AP组RRM视图下的配置,AP组RRM视图下CRC错误门限值配置的优先级高于全局视图下的配置。
# 配置所有AP的2.4GHz频段信道的CRC错误门限值为10,即CRC错误率达到或超过10%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g crc-error-threshold 10
·     crc-error-threshold
calibrate-channel 2.4g interference-threshold命令用来配置2.4GHz频段干扰在信道使用率中的占比门限值。
undo calibrate-channel 2.4g interference-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g interference-threshold percent percent
undo calibrate-channel 2.4g interference-threshold percent
2.4GHz频段干扰在信道使用率中的占比门限值为70。
全局配置视图
percent percent:干扰在信道使用率中的占比门限值,以百分比表示,取值范围为0~100。
增大门限值将降低自动信道调整的概率,减小门限值将提高自动信道调整的概率。
# 配置所有AP的2.4GHz频段干扰在信道使用率的占比门限值为50%。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g interference-threshold percent 50
·     calibrate-channel 2.4g channel-usage-threshold
calibrate-channel 2.4g noise-threshold命令用来配置2.4GHz频段信道噪声门限值。
undo calibrate-channel 2.4g noise-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g noise-threshold value
2.4GHz频段信道噪声门限值为0。
全局配置视图
value:噪声门限值,取值范围为0~127,代表功率范围为0~-127dBm,即噪声门限值越大,表示的噪声越小。取值为0时表示自动信道调整不考虑噪声因素。
噪声门限值是触发自动信道调整的条件之一。当AC检测到2.4GHz频段信道中的噪声达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的2.4GHz频段信道噪声门限值为50,即噪声达到或超过-50dBm时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g noise-threshold 50
calibrate-channel 2.4g receive-service-traffic threshold命令用来配置2.4GHz频段射频接收流量中业务流量阈值。
undo calibrate-channel 2.4g receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel 2.4g receive-service-traffic threshold value
2.4GHz频段射频接收流量中业务流量阈值为10Mbps。
全局配置视图
threshold value:业务流量阈值,取值范围为0~1000,单位为Mbps。
设备对AP的2.4GHz频段射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置所有AP的2.4GHz频段射频接收流量中业务流量阈值为30Mbps。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g receive-service-traffic threshold 30
calibrate-channel 2.4g retransmission-threshold命令用来配置2.4GHz频段信道重传门限值。
undo calibrate-channel 2.4g retransmission-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g retransmission-threshold value
2.4GHz频段信道重传门限值为0。
全局配置视图
value:重传门限值,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不考虑重传因素。
重传是触发自动信道调整的条件之一。当AC检测到2.4GHz频段信道的重传率达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的2.4GHz频段信道重传门限值为50,即重传率达到或超过50%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g retransmission-threshold 50
calibrate-channel 2.4g tolerance-level命令用来配置2.4GHz频段信道的容限系数。
undo calibrate-channel 2.4g tolerance-level命令用来恢复缺省情况。
calibrate-channel 2.4g tolerance-level percent
2.4GHz频段信道的容限系数为1。
全局配置视图
percent:容限系数,取值范围为0~100,单位为百分比。取值为0时表示2.4GHz频段信道在进行自动信道调整时不考虑容限系数。
容限系数为信道调整前后,两信道的信道质量差值。
AC开始计算信道质量后,只有在备选信道质量优于当前信道且达到或超过容限系数时,备选信道才会被应用。
RRM视图下容限系数配置的优先级高于AP组RRM视图下的配置,AP组RRM视图下容限系数配置的优先级高于全局视图下的配置。
# 配置所有AP的2.4GHz频段信道的容限系数为10,即两信道的信道质量差值达到或超过10时进行信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g tolerance-level 10
·     tolerance-level
calibrate-channel 5g channel-usage-threshold命令用来配置5GHz频段信道使用率门限值。
undo calibrate-channel 5g channel-usage-threshold命令用来恢复缺省情况。
calibrate-channel 5g channel-usage-threshold percent percent
undo calibrate-channel 5g channel-usage-threshold percent
5GHz频段信道使用率门限值为60。
全局配置视图
# 配置所有AP的5GHz频段信道使用率门限值为40。
[Sysname-wlan-global-configuration] calibrate-channel 5g channel-usage-threshold percent 40
·     calibrate-channel 5g interference-threshold
·     calibrate-channel 5g receive-service-traffic threshold
calibrate-channel 5g crc-error-threshold命令用来配置5GHz频段信道的CRC错误门限值。
undo calibrate-channel 5g crc-error-threshold命令用来恢复缺省情况。
calibrate-channel 5g crc-error-threshold percent
5GHz频段信道的CRC错误门限值为0。
全局配置视图
CRC错误门限值是触发自动信道调整的条件之一。当AC检测到5GHz频段信道中CRC错误的帧占所有802.11帧的百分比达到或超过设定值时,将触发自动信道调整。
# 配置所有AP的5GHz频段信道的CRC错误门限值为10,即CRC错误率达到或超过10%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g crc-error-threshold 10
calibrate-channel 5g interference-threshold命令用来配置5GHz频段干扰在信道使用率中的占比门限值。
undo calibrate-channel 5g interference-threshold命令用来恢复缺省情况。
calibrate-channel 5g interference-threshold percent percent
undo calibrate-channel 5g interference-threshold percent
5GHz频段干扰在信道使用率中的占比门限值为70。
全局配置视图
# 配置所有AP的5GHz频段干扰在信道使用率的占比门限值为50%。
[Sysname-wlan-global-configuration] calibrate-channel 5g interference-threshold percent 50
·     calibrate-channel 5g channel-usage-threshold
calibrate-channel 5g noise-threshold命令用来配置5GHz频段信道噪声门限值。
undo calibrate-channel 5g noise-threshold命令用来恢复缺省情况。
calibrate-channel 5g noise-threshold value
5GHz频段信道噪声门限值为0。
全局配置视图
value:噪声门限值,取值范围为0~127,代表功率范围为0~-127dBm,即噪声门限值越大,表示噪声越小。取值为0时表示自动信道调整不考虑噪声因素。
噪声门限值是触发自动信道调整的条件之一。当AC检测到5GHz频段信道中的噪声达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的5GHz频段信道噪声门限值为50,即噪声达到或超过-50dBm时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g noise-threshold 50
calibrate-channel 5g receive-service-traffic threshold命令用来配置5GHz频段射频接收流量中业务流量阈值。
undo calibrate-channel 5g receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel 5g receive-service-traffic threshold value
5GHz频段射频接收流量中业务流量阈值为10Mbps。
全局配置视图
设备对AP的5GHz频段射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置所有AP的5GHz频段射频接收流量中业务流量阈值为30Mbps。
[Sysname-wlan-global-configuration] calibrate-channel 5g receive-service-traffic threshold 30
calibrate-channel 5g retransmission-threshold命令用来配置5GHz频段信道重传门限值。
undo calibrate-channel 5g retransmission-threshold命令用来恢复缺省情况。
calibrate-channel 5g retransmission-threshold value
5GHz频段信道重传门限值为0。
全局配置视图
重传是触发自动信道调整的条件之一。当AC检测到5GHz频段信道的重传率达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的5GHz频段信道重传门限值为50,即重传率达到或超过50%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g retransmission-threshold 50
calibrate-channel 5g tolerance-level命令用来配置5GHz频段信道的容限系数。
undo calibrate-channel 5g tolerance-level命令用来恢复缺省情况。
calibrate-channel 5g tolerance-level percent
5GHz频段信道的容限系数为0。
全局配置视图
percent:容限系数,取值范围为0~100,单位为百分比。取值为0时表示5GHz频段信道在进行自动信道调整时不考虑容限系数。
# 配置所有AP的5GHz频段信道的容限系数为10,即两信道的信道质量差值达到或超过10时进行信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g tolerance-level 10
·     tolerance-level
calibrate-channel interference-threshold命令用来配置干扰在信道使用率中的占比门限值。
undo calibrate-channel interference-threshold命令用来恢复缺省情况。
calibrate-channel interference-threshold percent percent
undo calibrate-channel interference-threshold percent
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
percent percent:干扰在信道使用率中的占比门限值,取值范围为0~100,单位为百分比。
# 配置干扰在信道使用率的占比门限值为50%。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel interference-threshold percent 50
# 配置干扰在信道使用率的占比门限值为50%。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel interference-threshold percent 50
·     calibrate-channel receive-service-traffic threshold
·     channel-usage-threshold
calibrate-channel mode命令用来配置自动信道调整模式。
undo calibrate-channel mode命令用来恢复缺省情况。
calibrate-channel mode { periodic | scheduled }
RRM视图:继承AP组RRM配置。
AP组RRM视图:自动信道调整模式为周期性调整。
RRM视图
AP组RRM视图
periodic:周期性调整。
scheduled:定时调整。
周期性调整模式下,AC按用户设置的调整周期重复进行信道质量检测,根据检测结果评估是否需要进行信道调整。
定时调整模式下,设备在指定的时间段收集信道质量信息,而后进行信道质量的评估并决定是否调整信道。
# 配置自动信道调整模式为定时调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode scheduled
# 配置自动信道调整模式为定时调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel self-decisive enble
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel mode scheduled
·     calibrate-channel monitoring time-range
·     calibrate-channel pronto
·     wlan rrm calibration-channel interval
calibrate-channel monitoring time-range命令用来为信道质量检测功能指定时间段。
undo calibrate-channel monitoring time-range命令用来取消为信道质量检测功能指定的时间段。
calibrate-channel monitoring time-range time-range-name
RRM视图:继承AP组RRM配置。
AP组RRM视图:未指定时间段用于收集射频环境信息。
RRM视图
AP组RRM视图
time-range-name:指定时间段的名称,为1~32个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,时间段的名称不允许使用英文单词all。
为信道质量检测功能指定时间段后,AC将在指定的时间段内执行信道质量检测任务,并收集数据生成信道报告与邻居报告,为信道质量评估提供依据。
# 为信道质量检测功能指定时间段,该时间段名称为time1。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel monitoring time-range time1
# 为信道质量检测功能指定时间段,该时间段名称为time1。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel monitoring time-range time1
·     time-range
calibrate-channel pronto命令用来执行一次信道自动调整。
RRM视图
AP组RRM视图
本命令用于定时自动信道调整。
# 执行一次信道自动调整。(RRM视图)
[Sysname] scheduler job calibration1
[Sysname-job-calibration1] command 1 system-view
[Sysname-job-calibration1] command 2 wlan ap ap1
[Sysname-job-calibration1] command 3 radio 1
[Sysname-job-calibration1] command 4 rrm
[Sysname-job-calibration1] command 5 calibrate-channel pronto
# 执行一次信道自动调整。(AP组RRM视图)
[Sysname] scheduler job calibration2
[Sysname-job-calibration2] command 1 system-view
[Sysname-job-calibration2] command 2 wlan ap-group g1
[Sysname-job-calibration2] command 3 ap-model WA6320
[Sysname-job-calibration2] command 4 radio 1
[Sysname-job-calibration2] command 5 rrm
[Sysname-job-calibration2] command 6 calibrate-channel pronto
calibrate-channel receive-service-traffic threshold命令用来配置射频接收流量中业务流量阈值。
undo calibrate-channel receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel receive-service-traffic threshold value
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
设备对AP射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置射频接收流量中业务流量阈值为30Mbps。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel receive-service-traffic threshold 30
# 配置射频接收流量中业务流量阈值为30Mbps。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel receive-service-traffic threshold 30
·     calibrate-channel interference-threshold
calibrate-channel self-decisive enable命令用来开启自动信道调整。
calibrate-channel self-decisive disable命令用来关闭自动信道调整。
undo calibrate-channel self-decisive命令用来恢复缺省情况。
RRM视图/AP组RRM视图:
calibrate-channel self-decisive { disable | enable }
全局配置视图:
calibrate-channel self-decisive enable { 2.4g | 5g | all }
undo calibrate-channel self-decisive enable { 2.4g | 5g | all }
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
全局配置视图:自动信道调整处于关闭状态。
RRM视图
AP组RRM视图
全局配置视图
2.4g:开启或关闭所有AP的2.4GHz频段射频的自动信道调整功能。
5g:开启或关闭所有AP的5GHz频段射频的自动信道调整功能。
all:开启或关闭所有AP的2.4GHz和5GHz频段射频的自动信道调整功能。
开启自动信道调整后,AC将按照自动信道调整模式来执行信道的检测、评估和调整。
# 开启自动信道调整。(RRM视图)
# 开启自动信道调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel self-decisive enable
# 开启所有AP的2.4GHz和5GHz频段射频的自动信道调整功能。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-channel self-decisive enable all
·     calibrate-channel mode
calibrate-channel self-decisive sensitivity命令用来配置自动信道调整的敏感度模式。
undo calibrate-channel self-decisive sensitivity命令用来恢复缺省情况。
calibrate-channel self-decisive sensitivity { custom | high | low | medium }
RRM视图:继承AP组RRM配置。
AP组RRM视图:自动信道调整敏感度模式为自定义。
RRM视图
AP组RRM视图
custom:自定义敏感度模式的自动信道调整。
high:高敏感度模式的自动信道调整,此模式下设备容易进行自动信道调整。
low:低敏感度模式的自动信道调整,此模式下设备不易进行自动信道调整。
medium:中等敏感度的自动信道调整,此模式下设备进行自动信道调整的难易程度适中。
配置自动信道调整敏感度模式为自定义模式后,可根据实际环境调整信道干扰门限、CRC错误门限和容限系数。
配置自动信道调整敏感度模式时应注意:
·     在自定义模式与高/中/低敏感度模式间切换时,所有自动信道调整配置参数都将被恢复为缺省值(不同模式,缺省值不同)。自定义模式下手工配置的各自动信道调整参数如有必要应在切换前做记录。
·     只有在自定义敏感度模式下,才能配置自动信道调整参数。
# 配置自动信道调整的敏感度模式为低敏感度模式。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive sensitivity low
# 配置自动信道调整的敏感度模式为高敏感度模式。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel self-decisive sensitivity high
·     interference-threshold
·     tolerance-level
calibrate-channel suppression enable命令用来开启自动信道调整抑制功能。
calibrate-channel suppression disable命令用来关闭自动信道调整抑制功能。
undo calibrate-channel suppression命令用来恢复缺省情况。
calibrate-channel suppression { disable | enable [ client-number number ] }
RRM视图:继承AP组RRM配置。
AP组RRM视图:自动信道调整抑制功能处于关闭状态,自动信道调整不受在线客户端数影响。
RRM视图
AP组RRM视图
client-number number:上线客户端数量,取值范围为1~124,缺省值为124。
本功能仅适用于周期性自动信道调整。
进行信道调整会导致在线客户端掉线,影响用户的正常接入。当自动信道调整模式为周期性调整,且本功能为开启状态时,若在线客户端数达到或超过配置的阈值时,不进行本周期的自动信道调整,以保证工作信道的稳定。
# 开启自动信道调整抑制功能,当在线客户端数达到或超过124个,则阻止此次自动信道调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel suppression enable
# 关闭自动信道调整抑制功能,周期性自动信道调整不受在线客户端数影响。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel suppression disable
calibrate-channel track spectrum-analysis enable命令用来开启WSA联动。
calibrate-channel track spectrum-analysis disable用来关闭WSA联动。
undo calibrate-channel track spectrum-analysis用来恢复缺省情况。
calibrate-channel track spectrum-analysis { disable | enable }
RRM视图:继承AP组RRM配置。
AP组RRM视图:WSA联动处于关闭状态。
RRM视图
AP组RRM视图
开启WSA(Wireless Spectrum Analysis,无线频谱分析)联动后,当频谱分析检测到信道质量变差达到调整门限时,会触发一次自动信道调整。关于WSA的介绍和配置请参见“WLAN高级功能配置指导”中的“频谱分析”。
# 开启WSA联动。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel track spectrum-analysis enable
# 开启WSA联动。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel track spectrum-analysis enable
·     spectrum-analysis calibrate-channel sensitivity(WLAN高级功能命令参考/频谱分析)
calibrate-power 2.4g adjacency-factor命令用来配置2.4GHz频段邻居因子。
undo calibrate-power 2.4g adjacency-factor命令用来恢复缺省情况。
calibrate-power 2.4g adjacency-factor neighbor
2.4GHz频段邻居因子为1。
全局配置视图
# 配置所有AP的2.4GHz频段邻居因子为7。
[Sysname-wlan-global-configuration] calibrate-power 2.4g adjacency-factor 7
calibrate-power 2.4g min命令用来配置2.4GHz频段射频的最小发射功率。
undo calibrate-power 2.4g min命令用来恢复缺省情况。
calibrate-power 2.4g min tx-power
2.4GHz频段射频的最小发射功率为6dBm。
全局配置视图
tx-power:射频的最小发射功率,取值范围为1~20,单位为dBm。
完成自动功率调整后,射频的发射功率不会小于本命令设置的值。
# 配置所有AP的2.4GHz频段射频的最小发射功率为15dBm。
[Sysname-wlan-global-configuration] calibrate-power 2.4g min 15
calibrate-power 2.4g threshold命令用来配置2.4GHz频段功率调整门限值。
undo calibrate-power 2.4g threshold命令用来恢复缺省情况。
calibrate-power 2.4g threshold value
功率调整门限值为65。
全局配置视图
threshold value:功率调整门限值,取值范围为1~196,代表功率范围为-1dBm~-196dBm。功率门限值越大,表示功率越小。
需要合理设置门限值,既保证AP上的Radio有较大的覆盖范围,不会出现弱信号,满足正常的使用需求,同时也要减少AP间相互干扰。
# 配置所有AP的2.4GHz频段功率调整门限值为-70dBm。
[Sysname-wlan-global-configuration] calibrate-power 2.4g threshold 70
calibrate-power 5g adjacency-factor命令用来配置5GHz频段邻居因子。
undo calibrate-power 5g adjacency-factor命令用来恢复缺省情况。
calibrate-power 5g adjacency-factor neighbor
5GHz频段邻居因子为1。
全局配置视图
# 配置所有AP的5GHz频段邻居因子为7。
[Sysname-wlan-global-configuration] calibrate-power 5g adjacency-factor 7
calibrate-power 5g min命令用来配置5GHz频段射频的最小发射功率。
undo calibrate-power 5g min命令用来恢复缺省情况。
calibrate-power 5g min tx-power
5GHz频段射频的最小发射功率为11dBm。
全局配置视图
# 配置所有AP的5GHz频段射频的最小发射功率为15dBm。
[Sysname-wlan-global-configuration] calibrate-power 5g min 15
calibrate-power 5g threshold命令用来配置5GHz频段功率调整门限值。
undo calibrate-power 5g threshold命令用来恢复缺省情况。
calibrate-power 5g threshold value
功率调整门限值为65。
全局配置视图
# 配置所有AP的5GHz频段功率调整门限值为-75dBm。
[Sysname-wlan-global-configuration] calibrate-power 5g threshold 75
calibrate-power min命令用来配置Radio的最小发射功率。
undo calibrate-power min命令用来恢复缺省情况。
calibrate-power min tx-power
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
tx-power:Radio的最小发射功率,取值范围为1~20,单位为dBm。
完成自动功率调整后,Radio的发射功率不会小于本命令设置的值。
# 配置Radio的最小发射功率为15dBm。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power min 15
# 配置Radio的最小发射功率为15dBm。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power min 15
calibrate-power mode命令用来配置自动功率调整模式。
undo calibrate-power mode命令用来恢复缺省情况。
calibrate-power mode { coverage | custom | density }
RRM视图:继承AP组RRM配置。
AP组RRM视图:自动功率调整模式为自定义模式。
RRM视图
AP组RRM视图
coverage:覆盖模式,该模式下功率调整方式偏向于扩大AP信号的覆盖范围,适用于AP数量较少的无线环境。
custom:自定义模式,AC根据手动配置的功率调整参数来进行功率调整。
density:高密模式,该模式下的功率调整方式偏向于避免AP之间的信号干扰,适用于AP数量较多,存在大量信号重叠区域的无线环境。
覆盖模式和高密模式使用系统定义的功率调整参数进行自动功率调整,自定义模式使用手动配置的功率调整参数进行自动功率调整。
# 配置自动功率调整模式为覆盖模式。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power mode coverage
# 配置自动功率调整模式为高密模式。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power mode density
calibrate-power self-decisive enable命令用来开启自动功率调整。
calibrate-power self-decisive disable命令用来关闭自动功率调整。
undo calibrate-power self-decisive命令用来恢复缺省情况。
RRM视图/AP组RRM视图:
calibrate-power self-decisive { disable | enable }
全局配置视图:
calibrate-power self-decisive enable { 2.4g | 5g | all }
undo calibrate-power self-decisive enable { 2.4g | 5g | all }
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
全局配置视图:自动功率调整处于关闭状态。
RRM视图
AP组RRM视图
全局配置视图
2.4g:开启或关闭所有AP的2.4GHz频段射频的自动功率调整功能。
5g:开启或关闭所有AP的5GHz频段射频的自动功率调整功能。
all:开启或关闭所有AP的2.4GHz和5GHz频段射频的自动功率调整功能。
开启自动功率调整后,AC在每一个自动功率调整周期到达时,都会开始功率调整流程。
若为射频配置了最大传输功率,则当前射频的自动功率调整功能将失效。
# 开启自动功率调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power self-decisive enable
# 开启自动功率调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power self-decisive enable
# 开启所有AP的2.4GHz和5GHz频段射频的自动功率调整功能。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-power self-decisive enable all
·     wlan rrm calibration-power interval
calibrate-power threshold命令用来配置功率调整门限值。
undo calibrate-power threshold命令用来恢复缺省情况。
calibrate-power threshold value
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
threshold value:功率调整门限值,取值范围为1~196,代表功率范围为-1dBm~-196dBm。即功率门限值越大,表示的功率值越小。
# 配置功率调整门限值为-70dBm。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power threshold 70
# 配置功率调整门限值为-70dBm。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power threshold 70
channel holddown-time命令用来配置信道保持时长。
undo channel holddown-time命令用来恢复缺省情况。
channel holddown-time minutes
信道保持时长为720分钟。
RRM保持调整组视图
minutes:信道保持时长,取值范围为10~1440,单位为分钟。
加入到RRM保持调整组的射频信道在每次调整后的信道保持时长内将不作调整。
# 为RRM保持调整组10配置信道保持时长为600分钟。
[Sysname-wlan-rrm-calibration-group-10] channel holddown-time 600
channel-usage-threshold命令用来配置信道使用率门限值。
undo channel-usage-threshold命令用来恢复缺省情况。
undo channel-usage-threshold percent
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
percent percent:信道使用率门限值,取值范围为1~100,单位为百分比。
# 配置信道使用率门限值为40。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] channel-usage-threshold percent 40
# 配置信道使用率门限值为40。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] channel-usage-threshold percent 40
crc-error-threshold命令用来配置CRC错误门限值。
undo crc-error-threshold命令用来恢复缺省情况。
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
CRC错误门限值是触发自动信道调整的条件之一,当AC检测到信道中CRC错误的帧占所有802.11帧的百分比超过设定值时,将触发信道调整。
# 配置CRC错误门限值为50,即CRC错误率达到或超过50%时触发自动信道调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] crc-error-threshold 50
# 配置CRC错误门限值为50,即CRC错误率达到或超过50%时触发自动信道调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] crc-error-threshold 50
1.1.41  description
description命令用来配置RRM保持调整组的描述信息。
undo description命令用来恢复缺省情况。
不存在RRM保持调整组的描述信息。
RRM保持调整组视图
text:RRM保持调整组的描述信息,为1~64个字符的字符串,区分大小写。
# 配置RRM保持调整组10的描述信息为office。
[Sysname-wlan-rrm-calibration-group-10] description office
display wlan rrm baseline命令用来显示射频工作参数基线的信息。
display wlan rrm baseline { all | name baseline-name } [ verbose ]
all:显示所有已保存的射频工作参数基线信息。
name baseline-name:显示已保存的射频工作参数基线信息。其中baseline-name表示基线的名称,为1~32个字符的字符串,不区分大小写。
verbose:显示射频工作参数基线的详细信息。若不指定本参数,则显示基线的概要信息。
射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息时,该用户无法查看此射频工作参数基线。
# 显示所有已保存基线的概要信息。
<Sysname> display wlan rrm baseline all
 Baseline name  : apbaseline
 Radio range    : AP
 Created at     : 2015-06-22 19:56:31
 Baseline name  : groupbaseline
 Radio range    : AP group
 Created at     : 2015-06-22 19:56:12
 Baseline name  : globalbaseline
 Radio range    : Global
 Created at     : 2015-06-22 19:55:12
表1-1 display wlan rrm baseline all命令显示信息描述表
Baseline name
射频工作参数基线的名称
Radio range
射频工作参数基线中保存的射频的范围,取值包括:
·     AP:AP的射频
·     AP group:AP组内的射频
·     Global:AC上所有AP的射频
Created at
射频工作参数基线的创建时间
# 显示所有已保存射频工作参数基线的详细信息。
<Sysname> display wlan rrm baseline all verbose
 Radio range   : AP
 APName             RadioID RadioType Bandwidth Channel Power RegionCode
 ap1                2       dot11gn   20        13      20    CN
 ap1                1       dot11an   40        157     20    CN
 ap2                1       dot11an   40        149     20    CN
 ap1                1       dot11an   40        149     20    CN
 ap2                2       dot11gn   20        1       20    CN
表1-2 display wlan rrm baseline all verbose命令显示信息描述表
Baseline name
射频工作参数基线的名称
Radio range
·     AP:AP的射频
·     AP group:AP组内的射频
·     Global:AC上所有AP的射频
Created at
射频工作参数基线的创建时间
APName
AP的名称
RadioID
射频号
RadioType
射频类型
Bandwidth
射频带宽
Channel
射频工作信道
Power
射频传输功率,单位为dBm
RegionCode
AP的区域码
display wlan rrm baseline apply-history命令用来显示应用射频工作参数基线的历史信息。
display wlan rrm baseline apply-history [ verbose ]
verbose:射频工作参数基线的详细历史信息。若不指定本参数,则显示射频工作参数基线的简要历史信息。
本命令用来显示最近十次应用射频工作参数基线的历史记录,如果应用不足十次,则显示全部。
# 显示应用射频工作参数基线的简要历史信息。
<Sysname> display wlan rrm baseline apply-history
Applied at  : 2016-01-23   12:19:50
Applied to  : global
# 显示应用射频工作参数基线的详细历史信息。
<Sysname> display wlan rrm baseline apply-history verbose
Applied to  : global
Radios      : 6
Success     : 4
Failure     : 2
Failure reason
  Radio doesn't exist           : 0
  Radio is down                 : 0
  Mismatching radio type        : 0
  Mismatching region code       : 1
  Ineffective service template  : 0
  Illegal channel               : 0
  Mismatching bandwidth         : 1
  Channel locked                : 0
  Channel fixed                 : 0
  Within channel holddown time  : 0
  Mismatching channel gap policy: 0
  Power locked                  : 0
  Within power holddown time    : 0
  Power lower than min. power   : 0
  Power greater than max. power : 0
表1-3 display wlan rrm baseline apply-history命令显示信息描述表
Name
射频工作参数基线的名称
Applied at
射频工作参数基线的应用时间
Applied to
射频工作参数基线的应用范围,取值为:
·     ap:应用于指定AP
·     apgroup:应用于指定AP组
·     global:应用于全局
Radio count
射频工作参数基线中的射频总数目
Success
射频工作参数基线应用成功的射频数目
Failure
射频工作参数基线应用失败的射频数目
Failure reason
射频工作参数基线应用失败数目
Radio doesn’t exist
射频不存在
Radio is down
射频状态为Down
射频工作参数基线中保存的射频类型与实际射频类型不匹配
射频工作参数基线中保存的AP的区域码与实际情况不匹配
无线服务未生效
Illegal channel
射频工作参数基线中保存的射频工作信道不合法
射频工作参数基线中保存的射频带宽与实际射频带宽不匹配
Channel locked
工作信道被锁定
Channel fixed
射频工作信道已手动配置为固定值
当前工作信道处于信道保持调整期
射频工作参数基线中保存的射频工作信道与信道间隔策略选取的信道不匹配
Power locked
射频功率被锁定
当前射频功率处于功率保持调整期
射频工作参数基线中保存的射频功率小于配置的最小传输功率
射频工作参数基线中保存的射频功率大于配置的最大传输功率
·     wlan rrm baseline apply name
display wlan rrm-calibration-group命令用来显示RRM保持调整组的相关信息。
display wlan rrm-calibration-group { all | group-id }
all:所有RRM保持调整组。
group-id:RRM保持调整组的ID。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
# 显示RRM保持调整组10的相关信息。
<Sysname> display wlan rrm-calibration-group 10
          RRM Calibration Group Information
Group ID                : 10
Description             : office
Channel holddown time   : 720 minutes
Power holddown time     : 60 minutes
Location name           : default-location
Group members           : ap4-radio2, ap3-radio2
表1-4 display wlan rrm-calibration-group命令显示信息描述表
Group ID
RRM保持调整组的ID
RRM保持调整组的描述信息
信道保持时长
Power holddown time
功率保持时长
Location name
地区标识名称
Group members
加入RRM保持调整组的Radio
display wlan rrm-history ap命令用来显示RRM调整历史信息。
display wlan rrm-history ap { all | name ap-name }
all:所有AP。
name ap-name:AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
该命令显示所有或指定AP上最近10次改变的信道或功率的详细信息。显示输出包括改变时间、触发原因、功率、干扰等参数。
# 显示ap1的RRM历史信息。
<Sysname> display wlan rrm-history ap name ap1
                         AP RRM History
 Flags : I - Interference,   P - Packets discarded,    F - Retransmission,
         R - Radar select,   C - Coverage,             B - Channelbusy
         M – Manual          D – Bandwidth             O - Others
                         AP RRM History : ap1
 Radio : 1                                Basic BSSID : 000f-e2ff-7700
        Ch  Power BW    Load Util Intf   Reason    Date         Time
            (dBm) (MHz) (%)  (%)  (%)              (yyyy-mm-dd) (hh:mm:ss)
 Before 36   20   20    24   2    21     -P------- 2014-07-07   17:31:50
 After  40   20   20    9    0    8      -         -            -
 Before 40   20   20    54   1    53     IP------- 2014-07-08   12:19:50
 After  36   20   20    10   0    10     -         -            -
 Before 36   20   20    29   1    28     -------D- 2014-07-08   12:59:50
 After  36   20   40    30   0    29     -         -            -
表1-5 display wlan rrm-history命令显示信息描述表
Radio
AP的Radio ID
Basic BSSID
基本服务集标识
Ch
Radio的工作信道
Power (dBm)
Radio的发射功率,单位为dBm
BW (MHz)
Radio的运行频宽,单位为MHz
Load (%)
信道的负载,以百分比表示
Util (%)
信道的利用率,以百分比表示
Intf (%)
信道检测到的干扰,以百分比表示
Reason
调整的原因,包括以下取值:
·     I:干扰
·     P:丢包
·     F:重传
·     R:规避雷达信号后,选用更优信道
·     C:信号覆盖
·     B:信道繁忙
·     M:手动触发
·     D:频宽调整
·     O:其它原因
Date
调整的日期
Time
调整的时间
display wlan rrm-status ap命令用来显示AP上射频的RRM详细信息。
display wlan rrm-status ap { all | name ap-name } [ neighbor-type { managed | unmanaged } ]
all:所有AP。
neighbor-type:根据邻居类型显示探测到的RRM详细信息。如果不指定本参数,则显示AP能探测到的所有邻居类型的RRM详细信息。
managed:显示AP能探测到的邻居Radio的RRM详细信息。
unmanaged:显示AP能探测到的非邻居Radio的RRM详细信息。
如果信道和功率调整处于关闭状态,则执行此命令时,只会显示AP上Radio的工作信道和功率级别,其它信息如干扰、邻居的数量等不会显示。
# 显示ap1的信道和功率调整详细信息。
<Sysname> display wlan rrm-status ap name ap1
                          AP RRM Profile : ap1
 Radio   : 1                              Basic BSSID    : 70f9-6d31-2fe0
 Channel : 157                            Tx Power (dBm) : 18
    Ch    Nbrs   Load   Util   Intf   PER   Retry   Radar     Last Detected At
    36    0      0      -      0      0     -       -         2020-04-10 09:35:01
    40    0      0      -      0      0     -       -         2020-04-10 09:35:01
    44    0      0      -      0      0     -       -         2020-04-10 09:35:01
    48    0      0      -      0      0     -       -         2020-04-10 09:35:01
    52    0      0      -      0      0     -       -         2020-04-10 09:35:01
    56    0      0      -      0      0     -       -         2020-04-10 09:35:01
    60    0      0      -      0      0     -       -         2020-04-10 09:35:01
    64    0      0      -      0      0     -       -         2020-04-10 09:35:01
    100   0      0      -      0      0     -       -         2020-04-10 09:35:01
    104   0      0      -      0      0     -       -         2020-04-10 09:35:01
    108   0      0      -      0      0     -       -         2020-04-10 09:35:01
    112   0      0      -      0      0     -       -         2020-04-10 09:35:01
    116   0      0      -      0      0     -       -         2020-04-10 09:35:01
    132   0      0      -      0      0     -       -         2020-04-10 09:35:01
    136   0      0      -      0      0     -       -         2020-04-10 09:35:01
    140   0      0      -      0      0     -       -         2020-04-10 09:35:01
    149   1      0      -      0      0     -       -         2020-04-10 09:35:01
    153   4      0      -      0      0     -       -         2020-04-10 09:35:01
    157   0      0      0      0      0     0       -         2020-04-10 09:35:01
    161   2      0      -      0      0     -       -         2020-04-10 09:35:01
    165   0      0      -      0      0     -       -         2020-04-10 09:35:01
   Nbr-MACAddress   Ch    Intf   SignalStrength  Type        Last Detected At
                           (%)    (dBm)
   000f-e212-ff01   161   0      -60             Unmanaged   2020-04-10 09:39:03
   5866-ba74-e461   153   0      -72             Unmanaged   2020-04-10 09:39:03
   70f9-6d30-9020   153   0      -40             Managed     2020-04-10 09:39:03
   70f9-6d31-3080   149   0      -54             Managed     2020-04-10 09:39:03
   70f9-6d31-34e0   161   0      -59             Managed     2020-04-10 09:39:03
   7425-8a86-bbe0   153   0      -48             Unmanaged   2020-04-10 09:39:03
   7425-8a86-c720   153   0      -63             Unmanaged   2020-04-10 09:39:03
 Radio   : 2                              Basic BSSID    : 70f9-6d31-2ff0
 Channel : 1                              Tx Power (dBm) : 19
    1    6      4      0      4      0     0       -         2020-04-10 09:33:06
    6    4      2      -      2      0     -       -         2020-04-10 09:33:06
    11   6      2      -      2      0     -       -         2020-04-10 09:33:06
                           (%)    (dBm)
   000f-e212-ff11   1     49     -77             Unmanaged   2020-04-10 09:31:05
   0023-89e1-ed00   11    0      -87             Unmanaged   2020-04-10 09:31:05
   006a-55f6-ae10   1     57     -88             Unmanaged   2020-04-10 09:31:05
   5866-ba64-aa31   1     10     -60             Unmanaged   2020-04-10 09:31:05
   5866-ba74-e471   6     0      -76             Unmanaged   2020-04-10 09:31:05
   5866-baa9-a610   11    0      -62             Unmanaged   2020-04-10 09:31:05
   70f9-6d30-9030   6     0      -63             Managed     2020-04-10 09:31:05
   70f9-6d31-3090   1     51     -86             Managed     2020-04-10 09:31:05
   70f9-6d31-34f0   6     0      -85             Managed     2020-04-10 09:33:09
   7425-8a86-bbf0   6     0      -73             Unmanaged   2020-04-10 09:33:09
   7425-8a86-c731   11    0      -93             Unmanaged   2020-04-10 09:33:09
   80f6-2ec0-3330   11    0      -76             Unmanaged   2020-04-10 09:33:09
   80f6-2ec0-3331   11    0      -73             Unmanaged   2020-04-10 09:33:09
   80f6-2edd-d2d0   1     40     -60             Unmanaged   2020-04-10 09:33:09
   80f6-2edd-d2d1   1     44     -68             Unmanaged   2020-04-10 09:33:09
   80f6-2ede-0b30   11    0      -74             Unmanaged   2020-04-10 09:33:09
表1-6 display wlan rrm-status命令显示信息描述表
Radio
AP的Radio ID
Basic BSSID
基本服务集标识
Channel
Radio当前的工作信道
Tx Power
Radio的发射功率
Ch
Radio支持的工作信道
Nbrs
信道中的邻居Radio数量
Load
信道的负载,以百分比表示。信道的负载指的是在该信道上,AP发送报文/接收客户端的报文和干扰,这里的干扰指该AP接收到其它AP和客户端发送的错误报文
Util
信道利用率,以百分比显表示。信道利用率指的是在该信道上,AP发送报文/接收客户端的报文
Intf
信道检测到的干扰,以百分比表示
PER
信道检测到的误码率,以百分比表示
Retry
信道检测到的重传率,以百分比表示
Radar
雷达检测状态:
·     -表示没有检测到雷达
·     Detected表示检测到雷达
Nbr-MACAddress
邻居AP的Radio接口的MAC地址
SignalStrength
检测到邻居Radio的信号强度,以dBm为单位
AP类型:
·     Unmanaged:该AP上的Radio能探到的非邻居Radio
·     Managed:该AP上的Radio能探测到的邻居Radio
Last Detected At
最近一次检测到信道和邻居有效数据的时间
interference-threshold命令用来配置信道干扰门限值。
undo interference-threshold命令用来恢复缺省情况。
RRM视图:继承AP组RRM配置。
AP组RRM视图:信道干扰门限值为0。
RRM视图
AP组RRM视图
percent:信道干扰门限,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不参考信道干扰门限。
信道干扰门限值是触发自动信道调整的条件之一,当AC检测到信道中的干扰帧占所有数据帧的百分比超过设定值时,触发信道调整。干扰帧是指目的不是当前工作射频的帧。
# 配置信道干扰门限值为60。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] interference-threshold 60
# 配置信道干扰门限值为60。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] interference-threshold 60
power holddown-time命令用来配置功率保持时长。
undo power holddown-time命令用来恢复缺省情况。
power holddown-time minutes
功率保持时长为60分钟。
RRM保持调整组视图
minutes:功率保持时长,取值范围为10~1440,单位为分钟。
加入到RRM保持调整组的射频功率在每次调整后的功率保持时长内将不作调整。
# 为RRM保持调整组10配置功率保持时长为600分钟。
[Sysname-wlan-rrm-calibration-group-10] power holddown-time 600
1.1.49  rrm
rrm命令用来进入RRM(Radio Resource Management,射频资源管理)视图。
rrm
不存在RRM视图。
Radio视图
# 进入RRM视图。
1.1.50  scan-only
scan-only enable命令用来开启射频的扫描功能。
scan-only disable命令用来关闭射频的扫描功能。
undo scan-only命令用来恢复缺省情况。
scan-only { disable | enable }
undo scan-only
RRM视图:继承AP组RRM配置。
AP组RRM视图:射频的扫描功能处于关闭状态。
RRM视图
AP组RRM视图
开启射频的扫描功能后,AP将对无线环境进行扫描与数据采集工作,周期性的将数据上报给AC,由AC生成信道报告和邻居报告。信道报告与邻居报告的详细内容可通过display wlan rrm-status ap命令查看。
配置自动信道调整或自动功率调整会开启射频的扫描功能。因此,如果已经配置了自动信道调整或自动功率调整,则不需要配置本命令。
# 开启射频的信道扫描功能。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] scan-only enable
# 开启射频的信道扫描功能。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] scan-only enable
·     display wlan rrm-status ap
snmp-agent trap enable wlan rrm命令用来开启RRM告警功能。
undo snmp-agent trap enable wlan rrm命令用来关闭RRM告警功能。
RRM告警功能处于关闭状态。
开启RRM的告警功能之后,射频资源管理会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启RRM的告警功能。
[Sysname] snmp-agent trap enable wlan rrm
tolerance-level命令用来配置容限系数。
undo tolerance-level命令用来恢复缺省情况。
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
percent:容限系数,以百分比表示,取值范围为0~45。0表示信道调整计算不参考容限系数。
# 配置容限系数为25。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] tolerance-level 25
# 配置容限系数为25。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] tolerance-level 25
wlan calibrate-channel pronto ap all命令用来手动触发所有AP的射频进行自动信道调整。
执行wlan calibrate-channel pronto ap all命令可能会占用较多系统资源,请谨慎使用。
执行本命令后的10分钟内,所有AP的全部射频将周期性的在工作信道提供无线服务和非工作信道扫描。射频在非工作信道扫描期间可能造成在线终端的报文丢失,建议在网络维护期内执行本命令。
# 手动触发所有AP的射频进行自动信道调整。
[Sysname] wlan calibrate-channel pronto ap all
This operation will change the working channel of all radios and might cause packet loss. Continue? [Y/N]
wlan calibrate-power pronto ap all命令用来手动触发所有AP的射频进行自动功率调整。
执行wlan calibrate-power pronto ap all命令可能会占用较多系统资源,请谨慎使用。
本功能对已经配置了最大传输功率的射频不生效。
# 手动触发所有AP的射频进行自动功率调整。
[Sysname] wlan calibrate-power pronto ap all
wlan rrm baseline apply命令用来将射频工作参数基线应用到对应的射频。
wlan rrm baseline apply name baseline-name
name baseline-name:射频工作参数基线的名称,为1~32个字符的字符串,不区分大小写。
当射频工作参数基线处于以下任一情况时,将无法应用射频工作参数基线到对应的射频。
·     射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息。
·     射频工作参数基线为start_config_baseline.csv。
# 应用名称为bl的射频工作参数基线。
[Sysname] wlan rrm baseline apply name bl
·     display wlan rrm baseline apply-history
·     wlan rrm baseline save
wlan rrm baseline remove命令用来删除射频工作参数基线。
wlan rrm baseline remove name baseline-name
射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息时,该用户无法删除此射频工作参数基线。
# 删除名称为bl的射频工作参数基线。
[Sysname] wlan rrm baseline remove name bl
wlan rrm baseline save命令用来将当前射频的工作参数保存为工作参数基线。
wlan rrm baseline save name baseline-name { ap ap-name [ radio radio-id ] | ap-group group-name [ ap-model ap-model ] [ radio radio-id ] | global }
ap ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。指定本参数时,该AP必须已存在。
radio radio-id:AP射频的编号。如果未指定本参数,将保存指定AP/AP组/AP组下指定型号的所有射频的工作参数。
ap-group group-name:AP组的名称,为1~31个字符的字符串,不区分大小写。指定本参数时,该AP组必须已存在。
ap-model ap-model:AP型号名称。若不指定本参数,将保存AP组下指定或所有射频的工作参数。
global:AC上的所有射频。
如果当前射频的工作信道与功率值合适,则可以使用本命令将射频的信道、功率值存储为射频工作参数基线,在需要的时候重新应用这些保存的值。
射频工作参数基线将以.csv文件的形式被保存到文件系统中。
# 将AP1上Radio 1的工作参数保存为射频工作参数基线,名称为ap1-1。
[Sysname] wlan rrm baseline save name ap1-1 ap ap1 radio 1
# 将AP1上AP组Radio 1的工作参数保存为射频工作参数基线,名称为ap1g1-1。
[Sysname] wlan rrm baseline save name ap1g1-1 ap-group group1 ap-model WA6320 radio 1
# 将AC上所有射频的工作参数保存为射频工作参数基线,名称为global。
[Sysname] wlan rrm baseline save name global global
wlan rrm calibration-bandwidth interval命令用来配置自动频宽调整周期。
undo wlan rrm calibration-bandwidth interval命令用来恢复缺省情况。
wlan rrm calibration-bandwidth interval minutes
自动频宽调整周期为13分钟。
minutes:自动频宽调整周期,取值范围为3~1440,单位为分钟。
# 配置自动频宽调整周期为10分钟。
[Sysname] wlan rrm calibration-bandwidth interval 10
·     calibrate-bandwidth self-decisive
wlan rrm calibration-channel ap命令用来手动触发指定AP的射频进行自动信道调整。
wlan rrm calibration-channel ap name ap-name [ radio radio-id ] [ force ]
name ap-name:指定进行自动信道调整的AP。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
radio radio-id:指定进行自动信道调整的AP射频,其中radio-id为射频编号,本参数的取值范围与AP型号有关,请以设备的实际情况为准。如果未指定本参数,将对指定AP的所有射频进行信道调整。
force:不进行信道质量检测、计算,直接调整信道。如果未指定本参数,射频将经过信道质量检测、计算后调整信道。
配置本命令可让指定的AP射频强制进行一次自动信道调整,或者执行一次标准的信道调整流程(先进行信道质量检测,而后进行信道质量计算,最后进行信道调整)。
同时对多个射频进行信道调整时,某一个射频的信道调整结果不影响其它射频的调整。
配置本命令并指定force参数时,调整后的信道不一定是最优信道;配置本命令但未指定force参数时,最终是否能够调整信道与信道质量分析结果有关。
无论是否指定force参数,执行本命令后,设备会花费几分钟时间进行信道扫描、收集信道数据。在此期间:
·     终端的部分报文将被丢弃。
·     不应关闭射频开关、修改信道扫描相关配置、修改WLAN RRM相关配置。
本功能在分层组网和内置AP中不生效。
# 手动触发ap1的radio 1进行强制自动信道调整。
[Sysname] wlan rrm calibration-channel ap name ap1 radio 1 force
wlan rrm calibration-channel interval命令用来配置自动信道调整周期。
undo wlan rrm calibration-channel interval命令用来恢复缺省情况。
wlan rrm calibration-channel interval minutes
自动信道调整周期为23分钟。
minutes:自动信道调整周期,取值范围为3~1440,单位为分钟。
# 配置自动信道调整周期为10分钟。
[Sysname] wlan rrm calibration-channel interval 10
·     calibrate-channel self-decisive
wlan rrm calibration-power interval命令用来配置自动功率调整周期。
undo wlan rrm calibration-power interval命令用来恢复缺省情况。
wlan rrm calibration-power interval minutes
自动功率调整周期为11分钟。
minutes:自动功率调整周期,取值范围为3~180,单位为分钟。
# 配置自动功率调整周期为10分钟。
[Sysname] wlan rrm calibration-power interval 10
·     calibrate-power self-decisive
wlan rrm-calibration-group命令用来创建RRM保持调整组并进入RRM保持调整组视图。如果指定的RRM保持调整组已经存在,则直接进入保持调整组视图。
undo wlan rrm-calibration-group命令用来删除已创建的RRM保持调整组。
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { all | group-id }
不存在RRM保持调整组。
all:所有的RRM保持调整组。
group-id:RRM保持调整组的ID,取值范围为1~128。
# 创建ID为10的RRM保持调整组。
