12-网络管理和监控命令参考
02-NQA命令
本章节下载 02-NQA命令  (558.60 KB)
02-NQA命令
1 NQA
1.1 NQA客户端配置命令
1.1.1 advantage-factor
1.1.2 codec-type
1.1.3 community read
1.1.4 data-fill
1.1.5 data-size
1.1.6 description
1.1.7 destination host
1.1.8 destination ip
1.1.9 destination ipv6
1.1.10 destination port
1.1.11 display nqa history
1.1.12 display nqa reaction counters
1.1.13 display nqa result
1.1.14 display nqa statistics
1.1.15 expect data
1.1.16 expect ip
1.1.17 expect ipv6
1.1.18 expect status
1.1.19 filename
1.1.20 frequency
1.1.21 history-record enable
1.1.22 history-record keep-time
1.1.23 history-record number
1.1.24 init-ttl
1.1.25 key
1.1.26 lsr-path
1.1.27 max-failure
1.1.28 mode
1.1.29 next-hop ip
1.1.30 next-hop ipv6
1.1.31 no-fragment enable
1.1.32 nqa
1.1.33 nqa agent enable
1.1.34 nqa schedule
1.1.35 nqa template
1.1.36 operation (FTP test type view)
1.1.37 operation (HTTP/HTTPS test type view)
1.1.38 out interface
1.1.39 password
1.1.40 probe count
1.1.41 probe packet-interval
1.1.42 probe packet-number
1.1.43 probe packet-timeout
1.1.44 probe timeout
1.1.45 raw-request
1.1.46 reaction checked-element { jitter-ds | jitter-sd }
1.1.47 reaction checked-element { owd-ds | owd-sd }
1.1.48 reaction checked-element icpif
1.1.49 reaction checked-element mos
1.1.50 reaction checked-element packet-loss
1.1.51 reaction checked-element probe-duration
1.1.52 reaction checked-element probe-fail (for trap)
1.1.53 reaction checked-element probe-fail (for trigger)
1.1.54 reaction checked-element rtt
1.1.55 reaction trap
1.1.56 reaction trigger per-probe
1.1.57 reaction trigger probe-fail
1.1.58 reaction trigger probe-pass
1.1.59 resolve-target
1.1.60 resolve-type
1.1.61 route-option bypass-route
1.1.62 source interface(ICMP-echo/UDP-tracert test type view)
1.1.63 source ip
1.1.64 source ipv6
1.1.65 source port
1.1.66 ssl-client-policy
1.1.67 statistics hold-time
1.1.68 statistics interval
1.1.69 statistics max-group
1.1.70 target-only
1.1.71 tos
1.1.72 ttl
1.1.73 type
1.1.74 url
1.1.75 username
1.1.76 version
1.1.77 vpn-instance
1.2 NQA服务器端命令
1.2.1 display nqa server
1.2.2 nqa server enable
1.2.3 nqa server tcp-connect
1.2.4 nqa server udp-echo
1 NQA
1.1  NQA客户端配置命令
advantage-factor命令用来配置用于计算MOS值和ICPIF值的补偿因子。
undo advantage-factor命令用来恢复缺省情况。
advantage-factor factor
补偿因子取值为0。
Voice测试类型视图
factor:用于计算MOS值和ICPIF值的补偿因子,取值范围为0~20。
用户对语音质量的评价具有一定的主观性,不同用户对语音质量的容忍程度不同,因此,衡量语音质量时,需要考虑用户的主观因素。对语音质量容忍程度较强的用户,可以通过advantage-factor命令配置补偿因子,在计算ICPIF值时将减去该补偿因子,修正ICPIF和MOS值,以便在比较语音质量时综合考虑客观和主观因素。
# 在Voice测试类型下配置计算MOS值和ICPIF值的补偿因子为10。
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] advantage-factor 10
1.1.2  codec-type
codec-type命令用来配置语音测试的编码格式。
undo codec-type命令用来恢复缺省情况。
codec-type { g711a | g711u | g729a }
undo codec-type
语音编码格式为G.711 A律。
Voice测试类型视图
g711a:G.711 A律语音编码格式。
g711u:G.711 µ律语音编码格式。
g729a:G.729 A律语音编码格式。
# 在Voice测试类型下配置语音测试的编码格式为G.729 A律。
[Sysname-nqa-admin-test-voice] codec-type g729a
community read命令用来配置用于SNMP测试使用的团体名。
undo community read命令用来恢复缺省情况。
community read { cipher | simple } community-name
undo community read
SNMP测试使用的团体名为public。
SNMP测试类型视图
cipher:以密文方式配置团体名。
simple:以明文方式配置团体名,该密码将以密文形式存储。
community-name:测试使用的团体名,区分大小写。当以明文形式配置时,团体名为1~32个字符的字符串;当以密文形式配置时,团体名为33~73个字符的字符串。
当被测试的SNMP Agent的版本为SNMPv1或者SNMPv2c时,若SNMP Agent配置了团体名,则SNMP测试组必须配置本命令,且配置的团体名必须与SNMP Agent上已配置的只读或读写权限团体名保持一致,才能通过SNMP Agent的认证,并进行探测。当SNMP Agent的版本为SNMPv3时,由于SNMPv3没有团体名概念,不需要配置团体名,直接进行探测。有关团体名及SNMP认证的具体介绍请参见“网络管理和监控”中的“SNMP”。
# 配置SNMP探测报文使用的团体名称为readaccess。
[Sysname-nqa-admin-test] type snmp
[Sysname-nqa-admin-test-snmp] community read simple readaccess
1.1.4  data-fill
data-fill命令用来配置探测报文的填充字符串。
undo data-fill命令用来恢复缺省情况。
data-fill string
undo data-fill
探测报文的填充内容为十六进制00010203040506070809。
ICMP-echo/UDP-echo测试类型视图
Path-jitter/UDP-jitter/Voice测试类型视图
ICMP/TCP/UDP类型的NQA模板视图
string:探测报文的填充内容,为1~200个字符的字符串,区分大小写。
如果探测报文的数据段长度比配置的填充数据长度小,系统在报文封装时以报文的数据段长度为界截取该字符串的前一部分;
如果探测报文的数据段长度比配置的填充数据长度大,系统在报文封装时用该字符串进行循环填充,直到填满。
例如,配置填充数据为“abcd”,当探测报文数据段长度为3字节时,则取“abc”作为填充数据;当探测报文大小为6字节时,则使用“adcdab”作为填充数据。
对于不同的测试类型,填充字符串的情况有所不同:
·     在ICMP-echo测试中,配置的字符串用来填充ICMP Echo消息的数据字段。
·     在UDP-echo测试中,由于UDP报文数据字段的前5个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
·     在UDP-jitter测试中,UDP报文数据字段的前68个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
·     在Voice测试中,UDP报文数据字段的前16个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
·     在Path-jitter测试中,由于ICMP探测阶段ICMP报文数据字段的前4个字节具有特定用途,所以只用所配置的字符串填充ICMP报文中剩余的字节。
# 在ICMP-echo测试类型下配置探测报文的填充字符串为abcd。
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
# 在TCP类型的NQA模板视图下配置探测报文的填充字符串为abcd。
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] data-fill abcd
1.1.5  data-size
data-size命令用来配置探测报文中的填充内容的大小。
undo data-size命令用来恢复缺省情况。
data-size size
undo data-size
缺省情况如表1-1所示。
表1-1 探测报文中的填充内容大小的缺省值
测试类型
编码类型
缺省值(字节)
ICMP-echo
100
UDP-echo
100
UDP-jitter
100
UDP-tracert
100
Path-jitter
100
Voice
G.711 A律
172
Voice
G.711 µ律
172
Voice
G.729 A律
32
ICMP-echo/UDP-echo 测试类型视图
UDP-tracert测试类型视图
ICMP/UDP类型的NQA模板视图
size:探测报文中的填充内容的大小,单位为字节,ICMP-echo、UDP-echo和UDP-tracert测试类型取值范围为20~65507,UDP-jitter和Path-jitter测试类型取值范围为68~65507,Voice测试类型取值范围为16~65507。
对于ICMP-echo和Path-jitter测试,探测报文中填充内容的大小为ICMP Echo消息中数据字段的长度。
对于UDP-echo、UDP-jitter、UDP-tracert和Voice测试,探测报文中填充内容的大小为UDP报文中数据字段的长度。
# 在ICMP-echo测试类型下配置探测报文中的填充内容的大小为80字节。
[Sysname-nqa-admin-test-icmp-echo] data-size 80
# 在ICMP类型的NQA模板视图下配置ICMP-echo探测报文中的填充内容的大小为80字节。
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] data-size 80
1.1.6  description
description命令用来配置测试组的描述信息,通常用于描述一个测试组的测试类型或测试目的。undo description命令用来恢复缺省情况。
未配置描述信息。
任意测试类型视图
任意类型的NQA模板视图
text:测试组的描述,为1~200个字符的字符串,区分大小写。
# 在ICMP-echo测试类型下配置测试组的描述信息为icmp-probe。
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
# 在ICMP类型的NQA模板视图下配置描述信息为icmp-probe。
[Sysname-nqatplt-icmp-icmptplt] description icmp-probe
destination host命令用来配置探测报文的目的主机名。
undo destination host命令用来恢复缺省情况。
destination host host-name
未配置探测报文的目的主机名。
UDP-tracert测试类型视图
host-name:探测报文的目的主机名,为1~254个字符的字符串,区分大小写,字符串中可以包含字母、数字、“-”、“_”和“.”,不能出现连续的“.”。如果目的主机名由“.”分隔成多个段,则每段不能超过63个字符。
# 在UDP-Tracert测试类型下配置探测报文的目的主机名为www.test.com。
[Sysname-nqa-admin-test] type udp-tracert
[Sysname-nqa-admin-test-udp-tracert] destination host www.test.com
destination ip命令用来配置探测报文的目的IPv4地址。
undo destination ip命令用来恢复缺省情况。
destination ip ip-address
undo destination ip
未配置探测报文的目的IPv4地址。
ICMP-echo/TCP/UDP-echo测试类型视图
DHCP/DLSw/DNS/SNMP测试类型视图
UDP-tracert测试类型视图
ICMP-jitter/Path-jitter/UDP-jitter/Voice测试类型视图
DNS/ICMP/RADIUS/SSL/TCP/TCP Half Open/UDP类型的NQA模板视图
ip-address:探测报文的目的IPv4地址。
# 在ICMP-echo测试类型下配置探测报文的目的IPv4地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# 在ICMP类型的NQA模板视图下配置探测报文的目的IPv4地址为10.1.1.1。
[Sysname-nqatplt-icmp-icmptplt] destination ip 10.1.1.1
destination ipv6命令用来配置探测报文的目的IPv6地址。
undo destination ipv6命令用来恢复缺省情况。
destination ipv6 ipv6-address
未配置探测报文的目的IPv6地址。
ICMP-echo测试类型视图
ipv6-address:探测报文的目的IPv6地址,不支持IPv6链路本地地址。
# 在ICMP-echo测试类型下配置探测报文的目的IPv6地址为1::1。
[Sysname-nqa-admin-test-icmp-echo] destination ipv6 1::1
# 在ICMP类型的NQA模板视图下配置探测报文的目的IPv6地址为1::1。
[Sysname-nqatplt-icmp-icmptplt] destination ipv6 1::1
destination port命令用来配置测试操作的目的端口号。
undo destination port命令用来恢复缺省情况。
destination port port-number
对于UDP-tracert测试,目的端口号缺省为33434;对于SNMP测试,目的端口号缺省为161;对于其他类型测试,未配置测试操作的目的端口号。
对于各类型的NQA模板,各种操作类型的端口号缺省为DNS(53)、RADIUS(1812);对于其他模板类型,未配置测试操作的目的端口号。
TCP/UDP-echo测试类型视图
UDP-tracert测试类型视图
DNS/RADIUS/SSL/TCP/UDP类型的NQA模板视图
port-number:测试操作的目的端口号,取值范围为1~65535。
# 在UDP-echo测试类型视图下配置测试操作的目的端口号为9000。
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
# 在TCP类型的NQA模板视图下配置测试操作的目的端口号为9000。
[Sysname-nqatplt-tcp-tcptplt] destination port 9000
display nqa history命令用来显示NQA测试组的历史记录。
display nqa history [ admin-name operation-tag ]
admin-name:创建NQA测试组的管理员名称,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
operation-tag:测试操作的标签,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
display nqa history命令的显示信息无法反映ICMP-jitter、Path-jitter、UDP-jitter和Voice测试的结果。如果想了解ICMP-jitter、Path-jitter、UDP-jitter和Voice测试的结果,建议通过display nqa result命令查看最近一次NQA测试的结果,或通过display nqa statistics命令查看NQA测试的统计信息。
不指定任何参数,则表示显示所有测试组的历史记录。
# 显示管理员名称为administrator、测试类型标签为tracert的UDP-tracert测试项的历史记录。
<Sysname> display nqa history administrator tracert
NQA entry (admin administrator, tag tracert) history records:
Index      TTL  Response  Hop IP          Status          Time
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:06.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:05.2
1          2    328       4.1.1.1         Succeeded       2013-09-09 14:46:04.2
1          1    328       3.1.1.2         Succeeded       2013-09-09 14:46:03.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:02.2
1          1    328       3.1.1.1         Succeeded       2013-09-09 14:46:01.2
# 查看管理员名称为administrator、测试操作标签为test的NQA测试组的历史记录。
<Sysname> display nqa history administrator test
NQA entry (admin administrator, tag test) history records:
  Index      Response     Status           Time
  10         329          Succeeded        2011-04-29 20:54:26.5
  9          344          Succeeded        2011-04-29 20:54:26.2
  8          328          Succeeded        2011-04-29 20:54:25.8
  7          328          Succeeded        2011-04-29 20:54:25.5
  6          328          Succeeded        2011-04-29 20:54:25.1
  5          328          Succeeded        2011-04-29 20:54:24.8
  4          328          Succeeded        2011-04-29 20:54:24.5
  3          328          Succeeded        2011-04-29 20:54:24.1
  2          328          Succeeded        2011-04-29 20:54:23.8
  1          328          Succeeded        2011-04-29 20:54:23.4
表1-2 display nqa history命令显示信息描述表
Index
历史记录的编号,一次UDP-tracert测试中的所有记录此编号一致
TTL
本次探测发送的探测报文的TTL值。如果设备配置了路由旁路功能,则TTL显示值与init-ttl命令配置相关,实际发送的TTL值固定为1
Response
测试成功时,为探测报文的往返时延;如果测试超时,则为超时时间;不能完成测试时,则为0。单位为毫秒
Hop IP
回复应答的节点IP地址
Status
测试结果的状态值,具体如下:
·     Succeeded:测试成功,接收到响应报文
·     Unknown error:未知错误
·     Internal error:内部错误
·     Timeout:请求超时
Time
测试完成时间
display nqa reaction counters命令用来显示阈值告警组的当前监测结果。
display nqa reaction counters [ admin-name operation-tag [ item-number ] ]
item-number:显示指定阈值告警组的当前监测结果。如果不指定该参数,将显示所有阈值告警组的当前监测结果。item-number为阈值告警组的编号,取值范围为1~10。
如果NQA阈值告警组的阈值类型为平均值,或监测对象为Voice测试的ICPIF或MOS值,则显示的监测结果为无效值。
测试结束后,不会清除监测结果,即测试组启动后,监测结果会不断累加。
不指定任何参数,则表示显示所有测试组中所有阈值告警组的当前监测结果。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-echo测试组的所有阈值告警组的当前监测结果。
<Sysname> display nqa reaction counters admin test
NQA entry (admin admin, tag test) reaction counters:
  Index  Checked Element  Threshold Type  Checked Num  Over-threshold Num
  1      probe-duration   accumulate      12           4
  2      probe-duration   average         -            -
  3      probe-duration   consecutive     160          56
  4      probe-fail       accumulate      12           0
  5      probe-fail       consecutive     162          2
表1-3 display nqa reaction counters命令显示信息描述
Index
阈值告警组的编号
Checked Element
监测的对象(不同的NQA测试类型支持的监测对象不同,具体请参见表1-4表1-5
Threshold Type
阈值类型
Checked Num
已监测的样本个数
Over-threshold Num
超出阈值的样本个数
表1-4 display nqa reaction counters命令显示字段取值描述(DHCP/DLSw/DNS/FTP/HTTP/ICMP-echo/SNMP/TCP/UDP-echo测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
Over-threshold Num取值
probe-duration
accumulate
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后累计的探测持续时间不在阈值范围内的探测次数
average
consecutive
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后连续的探测持续时间不在阈值范围内的探测次数
probe-fail
accumulate
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后累计的探测失败次数
consecutive
启动NQA测试组后进行的探测
启动NQA测试组后已完成的探测次数
启动NQA测试组后连续的探测失败次数
表1-5 display nqa reaction counters命令显示字段取值描述(ICMP-jitter/UDP-jitter/Voice测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
RTT
accumulate
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后累计的往返时间不在阈值范围内的报文个数
average
jitter-DS/jitter-SD
accumulate
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后累计的单向抖动时间不在阈值范围内的报文个数
average
OWD-DS/OWD-SD
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后单向时延不在阈值范围内的报文个数
packet-loss
accumulate
启动NQA测试组后发送的报文
启动NQA测试组后已发送的报文个数
启动NQA测试组后累计的丢包数
ICPIF/MOS(仅Voice测试支持)
display nqa result命令用来显示最近一次NQA测试的结果。
display nqa result [ admin-name operation-tag ]
operation-tag:为测试操作的标签,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
不指定任何参数,则表示显示所有测试组的最近一次测试的结果。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的TCP测试的最近一次测试结果。
<Sysname> display nqa result admin test
NQA entry (admin admin, tag test) test results:
    Send operation times: 1              Receive response times: 1
    Min/Max/Average round trip time: 35/35/35
    Square-Sum of round trip time: 1225
    Last succeeded probe time: 2011-05-29 10:50:33.2
  Extended results:
    Packet loss ratio: 0%
    Failures due to timeout: 0
    Failures due to disconnect: 0
    Failures due to no connection: 0
    Failures due to internal error: 0
    Failures due to other errors: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-jitter测试的最近一次测试结果。
    Send operation times: 10             Receive response times: 10
    Min/Max/Average round trip time: 1/2/1
    Square-Sum of round trip time: 13
    Last packet received time: 2015-03-09 17:40:29.8
  Extended results:
    Packets out of sequence: 0
    Packets arrived late: 0
  ICMP-jitter results:
   RTT number: 10
    Min positive SD: 0                     Min positive DS: 0
    Max positive SD: 0                     Max positive DS: 0
    Positive SD number: 0                  Positive DS number: 0
    Positive SD sum: 0                     Positive DS sum: 0
    Positive SD average: 0                 Positive DS average: 0
    Positive SD square-sum: 0              Positive DS square-sum: 0
    Min negative SD: 1                     Min negative DS: 2
    Max negative SD: 1                     Max negative DS: 2
    Negative SD number: 1                  Negative DS number: 1
    Negative SD sum: 1                     Negative DS sum: 2
    Negative SD average: 1                 Negative DS average: 2
    Negative SD square-sum: 1              Negative DS square-sum: 4
    SD average: 1                          DS average: 2
  One way results:
    Max SD delay: 1                        Max DS delay: 2
    Min SD delay: 1                        Min DS delay: 2
    Number of SD delay: 1                  Number of DS delay: 1
    Sum of SD delay: 1                     Sum of DS delay: 2
    Square-Sum of SD delay: 1              Square-Sum of DS delay: 4
    Lost packets for unknown reason: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-jitter测试的最近一次测试结果。
    Min/Max/Average round trip time: 15/46/26
    Square-Sum of round trip time: 8103
    Last packet received time: 2011-05-29 10:56:38.7
  Extended results:
  UDP-jitter results:
   RTT number: 10
    Min positive SD: 8                     Min positive DS: 8
    Max positive SD: 18                    Max positive DS: 8
    Positive SD number: 5                  Positive DS number: 2
    Positive SD sum: 75                    Positive DS sum: 32
    Positive SD average: 15                Positive DS average: 16
    Positive SD square-sum: 1189           Positive DS square-sum: 640
    Min negative SD: 8                     Min negative DS: 1
    Max negative SD: 24                    Max negative DS: 30
    Negative SD number: 4                  Negative DS number: 7
    Negative SD sum: 56                    Negative DS sum: 99
    Negative SD average: 14                Negative DS average: 14
    Negative SD square-sum: 946            Negative DS square-sum: 1495
    SD average: 14                         DS average: 14
  One way results:
    Max SD delay: 22                       Max DS delay: 23
    Min SD delay: 7                        Min DS delay: 7
    Number of SD delay: 10                 Number of DS delay: 10
    Sum of SD delay: 125                   Sum of DS delay: 132
    Square-Sum of SD delay: 1805           Square-Sum of DS delay: 1988
    SD lost packets: 0                     DS lost packets: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Voice测试的最近一次测试结果。
    Send operation times: 1000           Receive response times: 0
    Min/Max/Average round trip time: 0/0/0
    Square-Sum of round trip time: 0
    Last packet received time: 0-00-00 00:00:00.0
  Extended results:
    Packet loss ratio: 100%
    Failures due to timeout: 1000
  Voice results:
   RTT number: 0
    Min negative SD: 0                     Min negative DS: 0
    Max negative SD: 0                     Max negative DS: 0
    Negative SD number: 0                  Negative DS number: 0
    Negative SD sum: 0                     Negative DS sum: 0
    Negative SD average: 0                 Negative DS average: 0
    Negative SD square-sum: 0              Negative DS square-sum: 0
    SD average: 0                          DS average: 0
  One way results:
    Max SD delay: 0                        Max DS delay: 0
    Min SD delay: 0                        Min DS delay: 0
    Number of SD delay: 0                  Number of DS delay: 0
    Sum of SD delay: 0                     Sum of DS delay: 0
    Square-Sum of SD delay: 0              Square-Sum of DS delay: 0
    Lost packets for unknown reason: 1000
  Voice scores:
    MOS value: 0.99                        ICPIF value: 87
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Path-jitter测试的最近一次测试结果。
  Hop IP 192.168.40.210
    Basic Results:
      Min/Max/Average round trip time: 1/1/1
      Square-Sum of round trip time: 10
    Extended Results:
    Path-Jitter Results:
      Jitter number: 9
        Min/Max/Average jitter: 0/0/0
      Positive jitter number: 0
        Min/Max/Average positive jitter: 0/0/0
        Sum/Square-Sum positive jitter: 0/0
      Negative jitter number: 0
        Min/Max/Average negative jitter: 0/0/0
        Sum/Square-Sum negative jitter: 0/0
  Hop IP 192.168.50.209
    Basic Results:
    Extended Results:
      Jitter number: 9
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-tracert测试的最近一次测试结果。
    Send operation times: 6              Receive response times: 6
    Last succeeded probe time: 2013-09-09 14:23:24.5
  Extended results:
  UDP-tracert results:
    TTL    Hop IP             Time
    1      3.1.1.1            2013-09-09 14:23:24.5
    2      4.1.1.1            2013-09-09 14:23:24.5
表1-6 display nqa result命令显示信息描述
Data collecting in progress
测试正在进行中
Path jitter result is not available
测试没有生成结果
发送的探测报文数
收到的响应报文数
最小/最大/平均往返时间,单位为毫秒
往返时间平方和
一次测试中最后一次成功探测的完成时间,如果一次测试中的探测均失败,则该时间显示为全0,UDP-jitter、Path-jitter和Voice测试中无此信息
一次探测中最后一次成功收到正确响应报文的时间,如果一次探测中没有收到过正确的响应报文,则该时间显示为全0,只在UDP-jitter和Voice测试中存在此信息
Packet loss ratio
平均丢包率
测试过程中超时的次数
对方强制断开连接的次数
和对方建立连接失败的次数
因内部错误失败的次数
因其它错误失败的次数
报文失序的次数
ICMP-jitter results
ICMP-jitter测试的结果,只在ICMP-jitter测试中存在此信息
探测超时后,收到的响应报文个数
UDP-jitter results
UDP-jitter测试的结果,只在UDP-jitter测试中存在此信息
Voice results
Voice测试的结果,只在Voice测试中存在此信息
RTT number
收到的响应报文数
Min positive SD
源到目的方向正抖动时延的最小值
Min positive DS
目的到源方向正抖动时延的最小值
Max positive SD
源到目的方向正抖动时延的最大值
Max positive DS
目的到源方向正抖动时延的最大值
Positive SD number
源到目的方向正抖动时延的数目
Positive DS number
目的到源方向正抖动时延的数目
Positive SD sum
源到目的方向正抖动时延之和
Positive DS sum
目的到源方向正抖动时延之和
Positive SD average
源到目的方向正抖动时延的平均值
Positive DS average
目的到源方向正抖动时延的平均值
源到目的方向正抖动时延的平方和
目的到源方向正抖动时延的平方和
Min negative SD
源到目的方向负抖动时延的绝对值的最小值
Min negative DS
目的到源方向负抖动时延的绝对值的最小值
Max negative SD
源到目的方向负抖动时延的绝对值的最大值
Max negative DS
目的到源方向负抖动时延的绝对值的最大值
Negative SD number
源到目的方向负抖动时延的数目
Negative DS number
目的到源方向负抖动时延的数目
Negative SD sum
源到目的方向负抖动时延的绝对值之和
Negative DS sum
目的到源方向负抖动时延的绝对值之和
Negative SD average
源到目的方向负抖动时延的绝对值的平均值
Negative DS average
目的到源方向负抖动时延的绝对值的平均值
源到目的方向负抖动时延的平方和
目的到源方向负抖动时延的平方和
SD average
源到目的方向抖动时延的平均值
DS average
目的到源方向抖动时延的平均值
One way results
单向延迟测试结果,只有ICMP-jitter、UDP-Jitter和Voice类型测试有单向延迟测试结果
Max SD delay
源到目的的最大时延
Max DS delay
目的到源的最大时延
Min SD delay
源到目的的最小时延
Min DS delay
目的到源的最小时延
Number of SD delay
源到目的计算的时延数
Number of DS delay
目的到源计算的时延数
Sum of SD delay
源到目的的时延和
Sum of DS delay
目的到源的时延和
源到目的的时延的平方和
目的到源的时延的平方和
SD lost packets
源到目的方向丢失的报文个数
DS lost packets
目的到源方向丢失的报文个数
不能确定原因丢失的报文个数
Voice scores
语音参数,只在Voice类型测试有此信息
MOS value
为语音计算的MOS值
ICPIF value
为语音计算的ICPIF值
Hop IP
本跳IP地址,只在Path-jitter测试中存在此信息
Path-jitter results
Path-jitter测试的结果,只在Path-jitter测试中存在此信息
Jitter number
计算抖动次数,只在Path-jitter测试中存在此信息
最小/最大/平均抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息
正抖动时延的数目,只在Path-jitter测试中存在此信息
最小/最大/平均正抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息
正抖动时延之和/平方和,只在Path-jitter测试中存在此信息
负抖动时延的数目,只在Path-jitter测试中存在此信息
最小/最大/平均负抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息
负抖动时延之和/平方和,只在Path-jitter测试中存在此信息
TTL
Hop IP
回复应答的节点IP地址
Time
收到应答报文的时间
display nqa statistics命令用来显示NQA测试的统计信息。
display nqa statistics [ admin-name operation-tag ]
admin-name :创建NQA测试组的管理员名称,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
测试开始后,如果第一次测试中的所有探测尚未完成,则无法生成统计信息。若此时通过该命令查看统计信息,则显示信息为全0。
如果配置了阈值告警组,将显示在statistics interval命令指定的统计周期内的监测结果。若阈值告警组的阈值类型为平均值,或监测对象为Voice测试的ICPIF或MOS值,则显示的监测结果为无效值。
UDP-tracert测试类型不支持用该命令显示统计信息。
不指定任何参数,则表示显示所有测试组的统计信息。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的TCP测试的统计信息。
<Sysname> display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
  NO. : 1
    Start time: 2007-01-01 09:30:20.0
    Life time: 2 seconds
    Min/Max/Average round trip time: 13/13/13
    Square-Sum of round trip time: 169
  Extended results:
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-jitter测试的统计信息。
  NO. : 1
    Start time: 2015-03-09 17:42:10.7
    Life time: 156 seconds
    Send operation times: 1560           Receive response times: 1560
    Square-Sum of round trip time: 1563
  Extended results:
   RTT number: 1560
    Min positive SD: 1                     Min positive DS: 1
    Max positive SD: 1                     Max positive DS: 2
    Positive SD number: 18                 Positive DS number: 46
    Positive SD sum: 18                    Positive DS sum: 49
    Positive SD average: 1                 Positive DS average: 1
    Positive SD square-sum: 18             Positive DS square-sum: 55
    Min negative SD: 1                     Min negative DS: 1
    Negative SD number: 24                 Negative DS number: 57
    Negative SD sum: 24                    Negative DS sum: 58
    Negative SD average: 1                 Negative DS average: 1
    Negative SD square-sum: 24             Negative DS square-sum: 60
    SD average: 1                          DS average: 1
  One way results:
    Min SD delay: 1                        Min DS delay: 1
    Number of SD delay: 4                  Number of DS delay: 4
    Sum of SD delay: 4                     Sum of DS delay: 5
    Square-Sum of SD delay: 4              Square-Sum of DS delay: 7
  Reaction statistics:
    1      jitter-DS        accumulate      1500         10
    2      jitter-SD        average         -            -
    3      OWD-DS           -               1560         2
    4      OWD-SD           -               1560         0
    5      packet-loss      accumulate      0            0
    6      RTT              accumulate      1560         0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-jitter测试的统计信息。
  NO. : 1
    Start time: 2007-01-01 09:33:22.3
    Life time: 23 seconds
    Send operation times: 100            Receive response times: 100
    Min/Max/Average round trip time: 1/11/5
    Square-Sum of round trip time: 24360
  Extended results:
  UDP-jitter results:
   RTT number: 550
    Max positive SD: 7                     Max positive DS: 1
    Positive SD number: 220                Positive DS number: 97
    Positive SD sum: 283                   Positive DS sum: 287
    Positive SD average: 1                 Positive DS average: 2
    Positive SD square-sum: 709            Positive DS square-sum: 1937
    Min negative SD: 2                     Min negative DS: 1
    Max negative SD: 10                    Max negative DS: 1
    Negative SD number: 81                 Negative DS number: 94
    Negative SD sum: 556                   Negative DS sum: 191
    Negative SD average: 6                 Negative DS average: 2
    Negative SD square-sum: 4292           Negative DS square-sum: 967
    SD average: 2                          DS average: 2
  One way results:
    Max SD delay: 5                        Max DS delay: 5
    Number of SD delay: 550                Number of DS delay: 550
    Sum of SD delay: 1475                  Sum of DS delay: 1201
    Square-Sum of SD delay: 5407           Square-Sum of DS delay: 3959
    1      jitter-DS        accumulate      90           25
    3      OWD-DS           -               100          24
    4      OWD-SD           -               100          13
    6      RTT              accumulate      100          52
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Voice测试的统计信息。
  NO. : 1
    Start time: 2007-01-01 09:33:45.3
    Life time: 120 seconds
    Min/Max/Average round trip time: 1/12/7
    Square-Sum of round trip time: 620
  Extended results:
  Voice results:
   RTT number: 10
    Min positive SD: 3                     Min positive DS: 1
    Max positive SD: 10                    Max positive DS: 1
    Positive SD number: 3                  Positive DS number: 2
    Positive SD sum: 18                    Positive DS sum: 2
    Positive SD average: 6                 Positive DS average: 1
    Positive SD square-sum: 134            Positive DS square-sum: 2
    Min negative SD: 3                     Min negative DS: 1
    Max negative SD: 9                     Max negative DS: 1
    Negative SD number: 4                  Negative DS number: 2
    Negative SD sum: 25                    Negative DS sum: 2
    Negative SD average: 6                 Negative DS average: 1
    Negative SD square-sum: 187            Negative DS square-sum: 2
    SD average: 6                          DS average: 1
  One way results:
  Voice scores:
    Max MOS value: 4.40                    Min MOS value: 4.40
    Max ICPIF value: 0                     Min ICPIF value: 0
    1      ICPIF            -               -            -
    2      MOS              -               -            -
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Path-jitter测试的统计信息。
  NO. : 1
  Path 1:
    Basic Results:
    Extended Results:
      Jitter number: 9
    Basic Results:
    Extended Results:
      Jitter number: 9
表1-7 display nqa statistics命令显示信息描述
No.
统计组的组号
Start time
测试组启动时间
Life time
测试的持续时间,单位为秒
发送的探测报文数
收到的响应报文数
最小/最大/平均往返时间,单位为毫秒
往返时间平方和
Packet loss ratio
平均丢包率
测试过程中超时的次数
对方强制断开连接的次数
和对方建立连接失败的次数
因内部错误失败的次数
因其它错误失败的次数
报文失序的次数
迟到报文个数
ICMP-jitter results
UDP-jitter results
Voice results
RTT number
收到的响应报文数
Min positive SD
源到目的方向抖动时延为正值的最小值
Min positive DS
目的到源方向抖动时延为正值的最小值
Max positive SD
源到目的方向抖动时延为正值的最大值
Max positive DS
目的到源方向抖动时延为正值的最大值
Positive SD number
源到目的方向抖动时延为正值的数目
Positive DS number
目的到源方向抖动时延为正值的数目
Positive SD sum
源到目的方向抖动时延为正值的和
Positive DS sum
目的到源方向抖动时延为正值的和
Positive SD average
源到目的方向抖动时延为正值的平均值
Positive DS average
目的到源方向抖动时延为正值的平均值
源到目的方向抖动时延为正值的平方和
目的到源方向抖动时延为正值的平方和
Min negative SD
源到目的方向抖动时延为负值的最小绝对值
Min negative DS
目的到源方向抖动时延为负值的最小绝对值
Max negative SD
源到目的方向抖动时延为负值的最大绝对值
Max negative DS
目的到源方向抖动时延为负值的最大绝对值
Negative SD number
源到目的方向抖动时延为负值的数目
Negative DS number
目的到源方向抖动时延为负值的数目
Negative SD sum
源到目的方向抖动时延为负值的绝对值和
Negative DS sum
目的到源方向抖动时延为负值的绝对值和
Negative SD average
源到目的方向抖动时延为负值的绝对值的平均值
Negative DS average
目的到源方向抖动时延为负值的绝对值的平均值
源到目的方向抖动时延为负值的平方和
目的到源方向抖动时延为负值的平方和
SD average
源到目的方向抖动时延的平均值
DS average
目的到源方向抖动时延的平均值
One way results
Max SD delay
源到目的的最大时延
Max DS delay
目的到源的最大时延
Min SD delay
源到目的的最小时延
Min DS delay
目的到源的最小时延
Number of SD delay
源到目的计算的时延数
Number of DS delay
目的到源计算的时延数
Sum of SD delay
源到目的的时延和
Sum of DS delay
目的到源的时延和
源到目的的时延的平方和
目的到源的时延的平方和
SD lost packets
源到目的方向丢失的报文个数
DS lost packets
目的到源方向丢失的报文个数
不能确定原因丢失的报文个数
Voice scores
语音参数,只在voice类型测试有此信息
Max MOS value
最大MOS值
Min MOS value
最小MOS值
Max ICPIF value
最大ICPIF值
Min ICPIF value
最小ICPIF值
Reaction statistics
阈值告警组在统计周期内的监测结果
Index
阈值告警组的编号
Checked Element
监测对象
Threshold Type
阈值类型
Checked Num
已监测的样本个数
Over-threshold Num
超出阈值的样本个数
Path
Path-jitter测试结果的路径序号,只在Path-jitter测试中存在此信息
Hop IP
Path-jitter results
Jitter number
表1-8 display nqa statistics命令显示阈值告警功能相关字段取值描述(DHCP/DLSw/DNS/FTP/HTTP/ICMP-echo/SNMP/TCP/UDP-echo测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
probe-duration
accumulate
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,累计的探测持续时间不在阈值范围内的探测次数
average
consecutive
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,连续的探测持续时间不在阈值范围内的探测次数
probe-fail
accumulate
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,累计的失败的探测次数
consecutive
统计周期内,进行的探测
统计周期内,已完成的探测次数
统计周期内,连续的失败的探测次数
表1-9 display nqa statistics命令显示阈值告警功能相关字段取值描述(ICMP-jitter/UDP-jitter/Voice测试类型)
监测对象
阈值类型
监测的样本范围
Checked Num取值
RTT
accumulate
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内,累计的往返时间不在阈值范围内的报文个数
average
jitter-DS/jitter-SD
accumulate
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内,累计的单向抖动时间不在阈值范围内的报文个数
average
OWD-DS/OWD-SD
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内,单向时延不在阈值范围内的报文个数
packet-loss
accumulate
统计周期内,发送的报文
统计周期内,已发送的报文个数
统计周期内累计的丢包数
·     statistics interval
1.1.15  expect data
expect data命令用来配置期望的应答内容。
undo expect data命令用来恢复缺省情况。
expect data expression [ offset number ]
undo expect data
未配置期望的应答内容。
HTTP/HTTPS/TCP/UDP类型的NQA模板视图
expression:期望收到的应答内容,为1~200个字符的字符串,区分大小写。
offset number:所期望的内容在返回报文中的偏移量,取值范围为0~1000,缺省值为0。如果不指定本参数,则设备直接从返回报文的第一个字节开始匹配。
NQA客户端对于返回报文中期望的应答内容匹配方式如下:
·     如果未配置offset参数,则设备直接从返回报文的第一个字节开始匹配,若不匹配,继续从第二个字节开始匹配,以此类推;
·     如果配置了offset参数,则设备从返回报文偏移量之后的第一个字节开始匹配,若匹配失败,则忽略该偏移量,从返回报文的第一个字节开始匹配,若不匹配,继续从第二个字节开始匹配,以此类推。
无论使用以上哪种匹配方式,只要返回报文中包含期望收到的应答内容,则表示当前NQA目的端设备合法;否则为非法设备。
对于HTTP/HTTPS类型的NQA模板,仅当回应报文中存在Content-Length头域时,进行期望应答内容的检查,否则不做检查。
对于TCP类型的NQA模板,仅当data-fillexpect data命令都配置时,进行期望应答内容的检查,否则不做检查。
对于UDP类型的NQA模板,:
·     仅当data-fillexpect data命令都配置时,进行期望应答内容的检查,否则不做检查。
·     由于UDP报文数据字段的前5个字节具有特定用途。缺省情况下,配置expect data后从第6个字节开始进行偏移检查。
# 在HTTP类型的NQA模板视图下配置期望的应答内容为welcome!。
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] expect data welcome!
1.1.16  expect ip
expect ip命令用来配置期望返回的IP地址。
undo expect ip命令用来恢复缺省情况。
expect ip ip-address
undo expect ip
未配置期望返回的IP地址。
DNS类型的NQA模板视图
ip-address:DNS探测期望返回的IP地址。
在DNS测试中,NQA客户端通过该命令配置的IP地址与DNS服务器通过域名解析出的IP地址进行比较,若相同,则证明目前测试的DNS服务器合法,否则为非法DNS服务器。
# 在DNS类型的NQA模板视图下配置期望返回的IP地址为1.1.1.1。
[Sysname] nqa template dns dnstplt
[Sysname-nqatplt-dns-dnstplt] expect ip 1.1.1.1
1.1.17  expect ipv6
expect ipv6命令用来配置期望返回的IPv6地址。
undo expect ipv6命令用来恢复缺省情况。
expect ipv6 ipv6-address
undo expect ipv6
未配置期望返回的IPv6地址。
DNS类型的NQA模板视图
ipv6-address:DNS探测期望返回的IPv6地址。
在DNS测试中,NQA客户端通过该命令配置的IPv6地址与DNS服务器通过域名解析出的IPv6地址进行比较,若相同,则证明目前测试的DNS服务器合法,否则为非法DNS服务器。
# 在DNS类型的NQA模板视图下配置期望返回的IPv6地址为1::1。
[Sysname-nqatplt-dns-dnstplt] expect ipv6 1::1
expect status命令用来配置期望的应答状态码。
undo expect status命令用来恢复缺省情况。
expect status status-list
undo expect status [ status-list ]
未配置期望的应答状态码。
HTTP/HTTPS类型的模板视图
status-list:状态码列表,即HTTP/HTTPS模板类型期望收到的状态码范围。表示方式为status-list = { status-num1 [ to status-num2 ] }&<1-10>status-num取值范围为0~999,status-num2的值要大于或等于status-num1的值,&<1-10>表示前面的参数最多可以重复输入10次。
HTTP/HTTPS类型的NQA模板支持配置状态码。报文的状态码是由3位十进制数组成的字段,它包含服务器的状态信息,用户可以根据该状态码了解服务器的状态。状态码的第一位规定状态码的类型。
# 在HTTP类型的NQA模板视图下配置期望的应答状态码,允许状态码为200、300、400~500。
[Sysname-nqatplt-http-httptplt] expect status 200 300 400 to 500
1.1.19  filename
filename命令用来配置FTP服务器和客户端之间传送文件的文件名。
undo filename命令用来恢复缺省情况。
filename filename
undo filename
未配置FTP服务器和客户端之间传送文件的文件名。
FTP测试类型视图
FTP类型的NQA模板视图
filename:FTP服务器和客户端之间传送文件的文件名,为1~200个字符的字符串,字符串中不能包括“/”,区分大小写。
# 在FTP测试类型下配置FTP服务器和客户端之间要传送文件的文件名为config.txt。
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
# 在FTP类型的NQA模板视图下配置FTP服务器和客户端之间要传送文件的文件名为config.txt。
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] filename config.txt
1.1.20  frequency
frequency命令用来配置测试组连续两次测试开始时间的时间间隔。
undo frequency命令用来恢复缺省情况。
frequency interval
undo frequency
在NQA测试类型视图下,Voice、Path-jitter测试中连续两次测试开始时间的时间间隔为60000毫秒;其他类型的测试中连续两次测试开始时间的时间间隔为0毫秒,即只进行一次测试。
在NQA模板视图下,测试中连续两次测试开始时间的时间间隔为5000毫秒。
ICMP-echo/TCP/UDP-echo 测试类型视图
DHCP/DLSw/DNS/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
interval:连续两次测试开始时间的时间间隔,取值范围为0~604800000,单位为毫秒。时间间隔为0,表示两次测试的时间间隔为无穷,即只进行一次测试,此时不会生成统计结果。
通过nqa schedule命令启动NQA测试组后,每隔interval时间启动一次测试。
需要注意的是,如果到达frequency指定的时间间隔时,上次测试尚未完成,则不启动新一轮测试。
# 在ICMP-echo测试类型下配置连续两次测试开始时间的时间间隔为1000毫秒。
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
# 在DNS类型的NQA模板视图下配置连续两次测试开始时间的时间间隔为1000毫秒。
[Sysname-nqatplt-dns-dnstplt] frequency 1000
history-record enable命令用来开启NQA测试组的历史记录保存功能。
undo history-record enable命令用来关闭NQA测试组的历史记录保存功能。
UDP-tracert测试类型的历史记录保存功能处于开启状态,其他类型的NQA测试组的历史记录保存功能处于关闭状态。
UDP-tracert测试类型视图
如果开启NQA测试组的历史记录保存功能,则系统会记录该NQA测试组的历史信息,通过display nqa history命令可以查看该测试组的历史记录信息。
如果关闭NQA测试组的历史记录保存功能,则系统不会记录该测试组的历史信息,原有的历史记录信息也会被删除。
# 在ICMP-echo测试类型下开启NQA测试组的历史记录保存功能。
[Sysname-nqa-admin-test-icmp-echo] history-record enable
·     display nqa history
history-record keep-time命令用来配置NQA测试组中历史记录的保存时间。
undo history-record keep-time命令用来恢复缺省情况。
history-record keep-time keep-time
NQA测试组中历史记录的保存时间为120分钟。
UDP-tracert测试类型视图
keep-time:历史记录的保存时间,取值范围为1~1440,单位为分钟。
NQA测试结束后,开始计算该测试组中所有历史记录的保存时间。保存时间达到配置的值后,将删除这些记录。
# 在ICMP-echo测试类型下配置NQA测试组中历史记录的保存时间为100分钟。
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
history-record number命令用来配置在一个测试组中能够保存的最大历史记录个数。
undo history-record number命令用来恢复缺省情况。
history-record number number
一个测试组中能够保存的最大历史记录个数为50。
UDP-tracert测试类型视图
number:在一个测试组中能够保存的最大历史记录个数,取值范围为0~50。
如果一个测试组中历史记录个数超过设定的最大数目,则最早的历史记录将会被删除。
# 在ICMP-echo测试类型下配置一个测试组中能够保存的最大历史记录数为10个。
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
1.1.24  init-ttl
init-ttl命令用来配置UDP-tracert探测报文的初始跳数。
undo init-ttl命令用来恢复缺省情况。
init-ttl value
undo init-ttl
UDP-tracert探测报文的初始跳数为1。
UDP-tracert测试类型视图
value:UDP-tracert探测报文的初始跳数,取值范围1~255。
# 在UDP-tracert测试类型下配置UDP-tracert探测报文的初始跳数为5跳。
[Sysname-nqa-admin-test-udp-tracert] init-ttl 5
1.1.25  key
key命令用来设置RADIUS认证使用的共享密钥。
undo key命令用来恢复缺省情况。
key { cipher | simple } string
undo key
未设置RADIUS认证使用的共享密钥。
RADIUS类型的NQA模板视图
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~64个字符的字符串,密文密钥为1~117个字符的字符串。
必须保证设备上设置的共享密钥与RADIUS服务器上的完全一致。
# 在RADIUS类型的NQA模板视图下设置RADIUS认证使用的共享密钥为明文abc。
[Sysname] nqa template radius radiustplt
[Sysname-nqatplt-radius-radiustplt] key simple abc
1.1.26  lsr-path
lsr-path命令用来配置松散路由。
undo lsr-path命令用来恢复缺省情况。
lsr-path ip-address&<1-8>
undo lsr-path
未配置松散路由。
Path-jitter测试类型视图
ip-address&<1-8>:松散路由IP地址,&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
通过本命令配置松散路由,用户只需给出NQA探测报文必须经过的一些“节点”,并不需要给出一条完备的路径,无直接连接的“节点”之间的路由需要路由器寻址功能补充。
Path-jitter测试中,NQA客户端通过tracert过程使用该命令配置的松散路由进行探路,并根据收到ICMP报文计算主要“节点”时延和抖动时间。
# 在Path-jitter测试类型下配置松散路由为10.1.1.20和10.1.2.10两跳。
[Sysname-nqa-admin-test] type path-jitter
[Sysname-nqa-admin-test- path-jitter] lsr-path 10.1.1.20 10.1.2.10
1.1.27  max-failure
max-failure命令用来配置一次UDP-tracert测试中连续探测失败的最大次数。
undo max-failure命令用来恢复缺省情况。
max-failure times
undo max-failure
一次UDP-tracert测试中连续探测失败的最大次数为5。
UDP-tracert测试类型视图
times:表示一次UDP-tracert测试中连续探测失败的最大次数,取值范围0~255。0和255意味着UDP-tracert探测不会因为连续探测失败而停止测试。
当UDP-tracert测试中连续探测失败的次数达到指定的最大值时,设备认为测试失败并停止探测。
# 在UDP-tracert测试类型下配置一次UDP-tracert测试中连续探测失败的最大次数为20次。
[Sysname-nqa-admin-test-udp-tracert] max-failure 20
1.1.28  mode
mode命令用来配置FTP测试的数据传输方式。
undo mode命令用来恢复缺省情况。
mode { active | passive }
undo mode
FTP测试的数据传输方式为主动方式。
FTP测试类型视图
FTP类型的NQA模板视图
active:设置FTP的数据传输方式为主动方式。表示在建立数据连接时由服务器主动发起连接请求。
passive:设置FTP的数据传输方式为被动方式。表示在建立数据连接时由客户端主动发起连接请求。
# 在FTP测试类型下配置FTP测试的数据传输方式为被动方式。
[Sysname-nqa-admin-test-ftp] mode passive
# 在FTP类型的NQA模板视图下配置数据传输方式为被动方式。
[Sysname-nqatplt-ftp-ftptplt] mode passive
1.1.29  next-hop ip
next-hop ip命令用来配置探测报文的下一跳IP地址。
undo next-hop ip命令用来恢复缺省情况。
next-hop ip ip-address
undo next-hop ip
未配置探测报文的下一跳IP地址。
ICMP-echo测试类型视图
ICMP/TCP Half Open类型的NQA模板视图
ip-address:探测报文的下一跳IP地址。
配置本命令之后,设备按照指定的下一跳地址发送探测报文;若未配置本命令,则按照路由表缺省的转发规则发送探测报文。
# 在ICMP-echo测试类型下配置探测报文的下一跳IP地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.1
next-hop ipv6命令用来配置探测报文的下一跳IPv6地址。
undo next-hop ipv6命令用来恢复缺省情况。
next-hop ipv6 ipv6-address
undo next-hop ipv6
未配置探测报文的下一跳IPv6地址。
ICMP-echo测试类型视图
ipv6-address:探测报文的下一跳IPv6地址,不支持IPv6链路本地地址。
# 在ICMP-echo测试类型下配置探测报文的下一跳IPv6地址为10::1。
[Sysname-nqa-admin-test-icmp-echo] next-hop ipv6 10::1
no-fragment enable命令用来开启UDP-tracert探测类型的禁止报文分片功能。
undo no-fragment enable命令用来关闭UDP-tracert探测类型的禁止报文分片功能。
no-fragment enable
UDP-tracert测试类型的禁止报文分片功能处于关闭状态。
UDP-tracert测试类型视图
开启此功能后,设备发送的IP报文头部的DF(don't fragment)字段会被置一,这样报文在转发过程中将无法被分片。通过配置这条命令可以对一条链路的路径MTU值进行测试。
# 在UDP-tracert测试类型下开启UDP-tracert探测类型的禁止报文分片功能。
[Sysname-nqa-admin-test-udp-tracert] no-fragment enable
1.1.32  nqa
nqa命令用来创建NQA测试组,并进入NQA测试组视图。如果指定的NQA测试组视图已经存在,则直接进入NQA测试组视图。
undo nqa命令用来删除指定的NQA测试组。
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
不存在NQA测试组。
all:所有NQA测试组。
# 创建一个管理员名为admin,测试操作标签为test的NQA测试组,并进入NQA测试组视图。
nqa agent enable命令用来开启NQA客户端功能。
undo nqa agent enable命令用来关闭NQA客户端功能,并停止所有正在进行的测试。
nqa agent enable
NQA客户端功能处于开启状态。
# 开启NQA客户端功能。
[Sysname] nqa agent enable
·     nqa server enable
1.1.34  nqa schedule
nqa schedule命令用来配置测试组的启动时间和持续时间。
undo nqa schedule命令用来停止指定测试组的测试。
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ]
undo nqa schedule admin-name operation-tag
未配置NQA调度功能。
start-time:指定测试组的启动时间和日期。
hh:mm:ss:测试组的启动时间,小时:分钟:秒。
yyyy/mm/dd:测试组的启动日期,年:月:日,缺省值为系统的当前日期,年的取值范围为2000~2035。
mm/dd/yyyy:测试组的启动日期,月:日:年,缺省值为系统的当前日期,年的取值范围为2000~2035。
now:测试组立即开始测试。
lifetime:指定测试的持续时间。
lifetime:测试的持续时间,取值范围为1~2147483647,单位为秒。
forever:测试组将一直进行测试。
recurring:指定测试组每天都被调度运行。每天启动测试的时间由start-time参数指定。若不指定该参数,则测试组只在当天的指定时间内调度运行一次。
系统时间在启动时间~启动时间+持续时间范围内时,测试组进行测试。执行nqa schedule命令时,如果系统时间尚未到达启动时间,则到达启动时间后,启动测试;如果系统时间在启动时间~启动时间+持续时间之间,则立即启动测试;如果系统时间已经超过启动时间+持续时间,则不会启动测试。通过display clock命令可以显示系统的当前时间。
测试组被调度后不允许进入测试类型视图。若需要重新进入测试类型视图,请使用undo nqa schedule命令停止指定测试组的测试。
配置lifetime时间请保证一次测试能够完成,否则无法完成正常的联动操作。
# 启动管理员名称为admin,标签为test的测试组进行测试,测试组的启动时间为2008年8月8日以后(包含当天)的每天的08:08:08,测试持续时间为1000秒。
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000 recurring
·     destination ip
·     display clock(基础配置命令参考/设备管理)
·     nqa entry
·     type
1.1.35  nqa template
nqa template命令用来创建指定类型NQA模板,并进入NQA模板视图。如果指定的NQA模板视图已经存在,则直接进入NQA模板视图。
undo nqa template命令用来删除指定类型的NQA模板。
nqa template { dns | ftp | http | https | icmp | radius | ssl | tcp | tcphalfopen | udp } name
undo nqa template { dns | ftp | http | https | icmp | radius | ssl | tcp | tcphalfopen | udp } name
不存在NQA模板。
dns:配置DNS模板类型。
ftp:配置FTP模板类型。
http:配置HTTP模板类型。
https:配置HTTPS模板类型。
icmp:配置ICMP模板类型。
radius:配置RADIUS模板类型。
ssl:配置SSL模板类型。
tcp:配置TCP模板类型。
tcphalfopen:配置TCP Half Open模板类型。
udp:配置UDP模板类型。
# 创建一个类型为ICMP、名称为icmptplt的模板,并进入NQA模板视图。
operation命令用来配置FTP测试的操作方式。
undo operation命令用来恢复缺省情况。
operation { get | put }
undo operation
FTP测试的操作方式为get操作。
FTP测试类型视图
FTP类型的模板视图
get:从FTP服务器获取文件。
put:向FTP服务器传送文件。
进行put操作时,若配置了filename,发送数据前判断filename指定的文件是否存在,如果存在则上传该文件,如果不存在则探测失败。
进行get操作时,如果FTP服务器上没有以url中所配置的文件名为名称的文件,则测试不会成功。进行get操作时,设备上不会保存从服务器获取的文件。
进行getput操作时,请选用较小的文件进行测试,如果文件较大,可能会因为超时而导致测试失败,或由于占用较多的网络带宽而影响其他业务。
# 在FTP测试类型下配置FTP测试的操作方式为put操作。
[Sysname-nqa-admin-test-ftp] operation put
# 在FTP类型的NQA模板视图下配置测试的操作方式为put操作。
[Sysname-nqatplt-ftp-ftptplt] operation put
·     password
·     username
operation命令用来配置HTTP/HTTPS测试的操作方式。
operation { get | post | raw }
undo operation
HTTP/HTTPS测试的操作方式为get操作。
HTTP测试类型视图
HTTP/HTTPS类型的NQA模板视图
get:从HTTP/HTTPS服务器获取数据。
post:向HTTP/HTTPS服务器提交数据。
raw:向HTTP/HTTPS服务器发送RAW请求报文。
HTTP/HTTPS测试中以HTTP/HTTPS请求报文作为探测报文。
测试的操作方式为getpost时,请求报文内容从url中获取。
测试的操作方式为raw时,请求报文为raw-request子视图中配置的内容。在配置HTTP/HTTPS操作方式中的raw操作可以通过在raw-request子视图中配置getpost或其他服务器支持的请求类型的HTTP/HTTPS报文,以此直接作为探测报文。请确保raw-request子视图中所配置报文内容的正确性。
# 在HTTP测试类型下配置HTTP测试的操作方式为raw操作。
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] operation raw
# 在HTTP类型的NQA模板视图下配置测试的操作方式为raw操作。
[Sysname-nqatplt-http-httptplt] operation raw
·     password
·     raw-request
·     username
out interface命令用来指定探测报文的出接口。
undo out interface命令用来恢复缺省情况。
out interface interface-type interface-number
undo out interface
未指定探测报文的出接口。
ICMP-echo测试类型视图
DHCP测试类型视图
UDP-tracert测试类型视图
interface-type interface-number:探测报文出接口的接口类型和接口编号。
该命令指定的接口必须处于UP状态,否则NQA探测过程将会失败。
对于ICMP-echo测试类型,如果配置next-hop命令,此配置不生效。
# 在UDP-tracert测试类型下配置VLAN接口1作为UDP-tracert探测报文的出接口。
[Sysname-nqa-admin-test-udp-tracert] out interface vlan-interface 1
1.1.39  password
password命令用来配置测试服务器的用户登录密码。
undo password命令用来恢复缺省情况。
undo password
未配置测试服务器的用户登录密码。
FTP/HTTP测试类型视图
FTP/HTTP/HTTPS/RADIUS类型的NQA模板视图
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。对于FTP/HTTP/HTTPS,明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串;对于RADIUS,明文密码为1~64个字符的字符串,密文密码为1~117个字符的字符串。
# 在FTP测试类型下配置FTP服务器的用户登录密码为ftpuser。
[Sysname-nqa-admin-test-ftp] password simple ftpuser
# 在FTP类型的NQA模板视图下配置FTP服务器的用户登录密码为ftpuser。
[Sysname-nqatplt-ftp-ftptplt] password simple ftpuser
·     operation
·     username
1.1.40  probe count
probe count命令用来配置一次NQA测试中探测的次数。
undo probe count命令用来恢复缺省情况。
probe count times
undo probe count
对于UDP-tracert测试类型,对于一个TTL值的节点发送的探测报文次数为3次;其他类型的NQA测试一次NQA测试中的探测次数为1次。
UDP-tracert测试类型视图
ICMP-jitter/UDP-jitter测试类型视图
times:对于UDP-tracert测试类型,表示对于一个TTL值的节点发送的探测报文次数,取值范围为1~10;对于其他测试类型,表示一次NQA测试中进行探测的次数,取值范围为1~15。
不同测试类型中,探测的含义不同:
·     对于TCP和DLSw测试,一次探测操作是指建立一次连接。
·     对于ICMP-jitter和UDP-jitter测试,一次探测操作是指连续发送多个探测报文,发送探测报文的个数由probe packet-number命令指定。
·     对于FTP、HTTP、DHCP和DNS测试,一次探测操作是指完成一次相应的功能,例如上传或下载一个文件,获取一个Web页面,为接口申请一个IP地址,将一个域名解析为IP地址。
·     对于ICMP-echo和UDP-echo测试,一次探测操作是指发送一个探测报文。
·     对于SNMP测试,一次探测操作是指发送三个SNMP协议报文,分别对应SNMP v1、SNMP v2c和SNMP v3三个版本。
·     对于UDP-tracert测试,一次探测操作是指一个特定TTL值的节点发送一个探测报文的操作。
对于UDP-tracert测试,同一个TTL的节点,设备会发送数量为probe count命令配置的探测报文,系统在进行第一次探测之后,等待回应;对于其他类型的测试,如果配置的次数大于1,那么系统在进行第一次探测之后,等待回应。如果到达probe timeout命令指定的探测超时时间时,仍然没有收到回应,则发起第二次探测。如此反复,直到完成指定次数的探测。
Voice和Path-jitter测试不支持该命令,一次测试中只能进行一次探测。
# 在ICMP-echo测试类型下配置一次ICMP-echo测试中探测的次数为10次。
[Sysname-nqa-admin-test-icmp-echo] probe count 10
probe packet-interval命令用来配置发送探测报文的时间间隔。
undo probe packet-interval命令用来恢复缺省情况。
probe packet-interval interval
发送探测报文的时间间隔为20毫秒。
interval:测试中发送探测报文的时间间隔,取值范围为10~60000,单位为毫秒。
# 在UDP-jitter测试类型下配置测试中发送探测报文的时间间隔为100毫秒。
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number命令用来配置一次探测中发送探测报文的个数。
undo probe packet-number命令用恢复缺省情况。
probe packet-number packet-number
一次ICMP-jitter、UDP-jitter或Path-jitter探测中发送10个探测报文;一次Voice探测中发送1000个探测报文。
packet-number:一次探测中发送探测报文的个数,对于ICMP-jitter、UDP-jitter和Path-jitter测试,取值范围为10~1000;对于Voice测试,取值范围为10~60000。
# 在UDP-jitter测试类型下配置一次探测中发送100个探测报文。
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
probe packet-timeout命令用来配置一次探测中等待响应报文的超时时间。
undo probe packet-timeout命令用来恢复缺省情况。
probe packet-timeout timeout
ICMP-jitter、UDP-jitter和Path-jitter测试中等待响应报文的超时时间为3000毫秒;Voice测试中等待响应报文的超时时间为5000毫秒。
timeout:一次探测中等待响应报文的超时时间,取值范围为10~3600000,单位为毫秒。
# 在UDP-jitter测试类型下配置一次探测中等待响应报文的超时时间为100毫秒。
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout命令用来配置探测的超时时间。
undo probe timeout命令用来恢复缺省情况。
probe timeout timeout
undo probe timeout
探测的超时时间为3000毫秒。
UDP-tracert测试类型视图
任意类型的NQA模板视图
timeout:一次探测的超时时间,单位为毫秒。在FTP、HTTP探测中,取值范围为10~86400000;在DHCP、DLSw、DNS、ICMP-echo、SNMP、TCP、UDP-echo和UDP-tracert探测中,取值范围为10~3600000。对于NQA模板类型来说,FTP、HTTP和HTTPS模板的范围为10~86400000,其他模板范围为10~3600000。
如果NQA探测没有在probe timeout命令指定的时间内完成,则认为本次探测超时。
# 在DHCP测试类型下配置探测的超时时间为10000毫秒。
[Sysname-nqa-admin-test] type dhcp
[Sysname-nqa-admin-test-dhcp] probe timeout 10000
# 在HTTP类型的NQA模板视图下配置探测的超时时间为10000毫秒。
[Sysname-nqatplt-http-httptplt] probe timeout 10000
1.1.45  raw-request
raw-request命令用来进入raw-request子视图,并在该子视图下配置HTTP/HTTPS测试请求报文内容。
undo raw-request命令用来恢复缺省情况。
raw-request
undo raw-request
未配置HTTP/HTTPS测试请求报文的内容。
HTTP测试类型视图
每次使用raw-request命令进入raw-request子视图时,之前在该子视图下配置的HTTP测试请求报文内容会被清除。
HTTP/HTTPS测试的操作方式为raw时,必须配置该命令。raw-request子视图中所配置报文内容为HTTP/HTTPS的请求报文,要求报文内容中不能包含alias命令配置的别名,请用户自行确保报文的正确性,否则探测将失败。有关alias命令的详细介绍请参见“基础配置命令参考”中的“CLI”。
# 进入raw-request子视图,并在该子视图下配置HTTP测试GET操作的请求报文的内容。
[Sysname-nqa-admin-test-http] raw-request
[Sysname-nqa-admin-test-http-raw-request] GET /sdn/ui/app/index HTTP/1.0\r\nHost: 172.0.0.2\r\n\r\n
# 在HTTP类型的NQA模板视图下,进入raw-request子视图,并在该子视图下配置HTTP测试POST操作的请求报文的内容。
[Sysname-nqatplt-http-httptplt] raw-request
[Sysname-nqatplt-http-httptplt-raw-request] POST /sdn/ui/app/index HTTP/1.0\r\nHost:
 172.0.0.2\r\nAuthorization: Basic cm9vdDoxMjM0NTY=\r\n\r\n
reaction checked-element { jitter-ds | jitter-sd }命令用来创建监测单向抖动时间的阈值告警组。
undo reaction命令用来删除指定的阈值告警组。
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
不存在监测单向抖动时间的阈值告警组。
ICMP-jitter/UDP-jitter/Voice测试类型视图
item-number:阈值告警组编号,取值范围为1~10。
jitter-ds:监测从目的到源的单向抖动时间。
jitter-sd:监测从源到目的的单向抖动时间。
threshold-type:指定阈值类型。
accumulate accumulate-occurrences:每次测试中,累计的单向抖动时间超出阈值的报文个数。对于ICMP-jitter与UDP-jitter测试,取值为1~14999;对于Voice测试,取值范围为1~59999。
average:每次测试中,单向抖动时间的平均值。
threshold-value:指定阈值范围。
upper-threshold:阈值上限,取值范围为0~3600000,单位为毫秒。
lower-threshold:阈值下限,取值范围为0~3600000,且必须小于等于阈值上限,单位为毫秒。
action-type:触发的动作类型,缺省动作类型为none
none:只在显示信息中记录监测结果,不向网管发送Trap消息。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。
阈值告警组创建后,不能再通过reaction命令修改该阈值告警组的内容。若要修改阈值告警组的内容,则需要先通过undo reaction命令用来删除阈值告警组,再利用新的参数创建阈值告警组。
监测的对象是探测成功的报文,探测失败的报文不参与计数。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测UDP-jitter探测报文的从目的到源的单向抖动时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均单向抖动时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# 在UDP-jitter测试类型下创建编号为2的阈值告警组,监测UDP-jitter探测报文的从目的到源的单向抖动时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的单向抖动时间超出阈值的报文个数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction checked-element { owd-ds | owd-sd }命令用来创建监测单向时延的阈值告警组。
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
不存在监测单向时延的阈值告警组。
owd-ds:监测每个探测报文的从目的到源的单向时延。
owd-sd:监测每个探测报文的从源到目的的单向时延。
lower-threshold:阈值下限,取值范围为0~3600000,单位为毫秒,且必须小于等于阈值上限。
监测单向时延的阈值告警组不支持触发动作,但可以通过相关显示命令display nqa reaction countersdisplay nqa statistics显示当前的监测结果。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测每个UDP-jitter探测报文的从目的到源的单向时延,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。收到探测报文的应答报文后,计算该探测报文从目的到源的单向时延,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
reaction checked-element icpif命令用来创建监测Voice测试ICPIF值的阈值告警组。
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测Voice测试ICPIF值的阈值告警组。
Voice测试类型视图
upper-threshold:阈值上限,取值范围为1~100。
lower-threshold:阈值下限,取值范围为1~100,且必须小于等于阈值上限。
# 在Voice测试类型下创建编号为1的阈值告警组,监测每次Voice测试的ICPIF值,阈值上限为50,下限为5。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的ICPIF值,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-voice] reaction 1 checked-element icpif threshold-value 50 5 action-type trap-only
reaction checked-element mos命令用来创建监测Voice测试MOS值的阈值告警组。
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测Voice测试MOS值的阈值告警组。
Voice测试类型视图
item-number:阈值告警组的编号,取值范围为1~10。
upper-threshold:阈值上限,取值范围为1~500。
lower-threshold:阈值下限,取值范围为1~500,且必须小于等于阈值上限。
实际的阈值下限(或阈值上限)为输入的阈值下限/100(或阈值上限/100),即如果输入的阈值下限和阈值上限分别为100、200,则MOS值在1~2之间时,未超出阈值。
# 在Voice测试类型下创建编号为1的阈值告警组,监测每次Voice测试的MOS值,阈值上限为200,下限为100。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的MOS值,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-voice] reaction 1 checked-element mos threshold-value 200 100 action-type trap-only
reaction checked-element packet-loss命令用来创建监测每次测试中丢包数的阈值告警组。
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
不存在监测每次测试中丢包数的阈值告警组。
accumulate accumulate-occurrences:每次测试中,累计的丢包数。对于ICMP-jitter与UDP-jitter测试,取值范围为1~15000;对于Voice测试,取值范围为1~60000。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测每次UDP-jitter测试的丢包数。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的丢包数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
reaction checked-element probe-duration命令用来创建监测探测持续时间的阈值告警组。
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测探测持续时间的阈值告警组。
accumulate accumulate-occurrences:每次测试中,累计的探测持续时间超出阈值的探测次数。accumulate-occurrences取值范围为1~15。
average:每次测试中,探测持续时间的平均值。
consecutive consecutive-occurrences:测试组启动后,连续的探测持续时间超出阈值的探测次数。consecutive-occurrences取值范围为1~16。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。DNS测试不支持发送Trap,DNS测试类型视图下无此参数。
监测的对象是成功的探测,失败的探测不参与计数。
# 在ICMP-echo测试类型下创建编号为1的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均探测持续时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# 在ICMP-echo测试类型下创建编号为2的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的持续时间超出阈值的探测次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# 在ICMP-echo测试类型下创建编号为3的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次探测结束后,检查测试组启动以来连续的持续时间超出阈值的探测次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
reaction checked-element probe-fail命令用来创建监测探测失败次数的阈值告警组。
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
不存在监测探测失败次数的阈值告警组。
accumulate accumulate-occurrences:一次测试中,累计的探测失败次数。accumulate-occurrences取值范围为1~15。
consecutive consecutive-occurrences:NQA测试组启动以来,连续的探测失败次数。consecutive-occurrences取值范围为1~16。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。DNS测试不支持发送trap,DNS测试类型视图下无此参数。
# 在ICMP-echo测试类型下创建编号为1的阈值告警组,监测ICMP-echo探测的失败次数。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的探测失败次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# 在ICMP-echo测试类型下创建编号为2的阈值告警组,监测ICMP-echo探测的失败次数。NQA测试组启动前,初始的阈值状态为invalid。每次探测结束后,检查测试组启动以来连续的探测失败次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
reaction checked-element probe-fail命令用来建立联动项,对当前所在测试组中的探测进行监测,当连续探测失败次数达到阈值时,就触发其他模块联动。
undo reaction命令用来删除指定的联动项。
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
不存在联动项。
item-number:联动项序号,取值范围为1~10。
threshold-type:指定门限类型。
consecutive consecutive-occurrences:NQA测试组启动以来连续的探测失败次数,取值范围为1~16。
action-type:触发的动作类型。
trigger-only:条件满足时,触发其它模块联动。
联动项创建后,不能再通过reaction命令修改该联动项的内容。若要修改联动项的内容,则需要先通过undo reaction命令用来删除联动项,再利用新的参数创建联动项。
# 在TCP测试类型下建立序号为1的联动项,连续探测失败3次,触发其他模块联动。
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
·     track(可靠性命令参考/Track)
reaction checked-element rtt命令用来创建监测报文往返时延的阈值告警组。
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测报文往返时延的阈值告警组。
accumulate accumulate-occurrences:每次测试中,累计的RTT超出阈值的报文个数。对于ICMP-jitter与UDP-jitter测试,取值范围为1~15000;对于Voice测试,取值范围为1~60000。
average:每次测试中,报文往返时间的平均值。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测UDP-jitter探测报文的往返时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均报文往返时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# 在UDP-jitter测试类型下创建编号为2的阈值告警组,监测每个UDP-jitter探测报文的往返时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的RTT超出阈值的报文个数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction trap命令用来配置在指定条件下向网管服务器发送Trap消息。
undo reaction trap命令用来恢复缺省情况。
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure [ accumulate-probe-failures ] }
undo reaction trap { path-change | probe-failure | test-complete | test-failure }
不向网管服务器发送Trap消息。
UDP-tracert测试类型视图
path-change:当进行UDP-tracert类型测试时,在配置了frequency命令后进行连续测试后,如果检测到当前路径相对于上一次测试路径发生变化,则设备发送一次Trap消息。
probe-failure consecutive-probe-failures:每次探测结束后,计算本次NQA测试中探测连续失败的次数,如果连续失败次数大于或等于consecutive-probe-failures,则向网管服务器发送探测失败的Trap消息。一次测试中,可能发送多次Trap消息。consecutive-probe-failures为一次测试中连续探测失败的次数,取值范围为1~15。
test-complete:对于非UDP-tracert类型测试,当测试完成时发送测试完成的Trap消息。对于UDP-tracert类型测试,测试出到达目的设备的路径后,发送测试完成的Trap消息。
test-failure accumulate-probe-failures:对于非UDP-tracert类型测试,一次NQA测试结束后,计算本次NQA测试中探测失败的累计次数,如果累计失败次数大于或等于accumulate-probe-failures,则向网管服务器发送测试失败的Trap消息。accumulate-probe-failures为一次测试中累计探测失败的次数,为必须输入的参数,取值范围为1~15。对于UDP-tracert类型测试,只要未能测试出到达目的地的路径,就发送一次Trap消息。用户不能输入参数accumulate-probe-failures
ICMP-jitter、UDP-jitter 和Voice测试只支持reaction trap test-complete
UDP-tracert测试支持reaction trap path-changereaction trap test-completereaction trap test-failure(其中UDP-tracert测试不支持reaction trap test-failure的accumulate-probe-failures参数)。
# 在ICMP-echo测试类型下配置测试中连续探测失败次数大于或等于5次时,发送探测失败的Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
reaction trigger per-probe命令用来配置每次探测结果发送机制,即每次探测结束时都会将探测结果发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
undo reaction trigger per-probe命令用来恢复缺省情况。
连续探测成功或失败3次时,NQA客户端会把探测成功或失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
本命令与reaction trigger probe-fail命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
本命令与reaction trigger probe-pass命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP类型的NQA模板视图下配置每次探测结果发送机制,即每次探测结束时都会将探测结果发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
[Sysname-nqatplt-icmp-icmptplt] reaction trigger per-probe
·     reaction trigger probe-fail
·     reaction trigger probe-pass
reaction trigger probe-fail命令用来配置连续探测失败的次数。
undo reaction trigger probe-fail命令用来恢复缺省情况。
reaction trigger probe-fail count
连续探测失败3次时,NQA客户端会把探测失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
任意类型的NQA模板视图
count连续探测失败的次数,取值范围为1~15。
当连续探测失败次数达到命令配置的数值时,NQA客户端会把探测失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
外部特性调用NQA模板后进行相应的NQA测试,使用此命令可以设定节点失效的连续测试失败次数。
本命令与reaction trigger per-probe命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在HTTP类型的NQA模板视图下配置确定节点失效需要连续探测失败5次。当连续探测失败的次数达到5次时,NQA客户端把探测失败的消息发送给外部特性,使外部特性能利用NQA测试的结果进行相应处理。
[Sysname-nqatplt-http-httptplt] reaction trigger probe-fail 5
·     reaction trigger per-probe
reaction trigger probe-pass命令用来配置连续探测成功次数。
undo reaction trigger probe-pass命令用来恢复缺省情况。
reaction trigger probe-pass count
连续探测成功3次时,NQA客户端会把探测成功的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
任意类型的NQA模板视图
count连续探测成功的次数,取值范围为1~15。
当连续探测成功次数达到命令配置的数值时,NQA客户端会把探测成功的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
外部特性调用NQA模板后进行相应的NQA测试,使用此命令可以设定节点有效的连续探测成功次数。
# 在HTTP类型的NQA模板视图下配置确定节点有效需要连续探测成功5次。当连续探测成功的次数达到5次时,NQA客户端把探测成功的消息发送给外部特性,使外部特性能利用NQA测试的结果进行相应处理。
[Sysname-nqatplt-http-httptplt] reaction trigger probe-pass 5
resolve-target命令用来配置要解析的域名。
undo resolve-target命令用来恢复缺省情况。
resolve-target domain-name
undo resolve-target
未配置要解析的域名。
DNS测试类型视图
DNS类型的NQA模板视图
domain-name:要解析的域名,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过255个字符,区分大小写。字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。
# 在DNS测试类型下配置DNS测试要解析的域名为domain1。
[Sysname-nqa-admin-test] type dns
[Sysname-nqa-admin-test-dns] resolve-target domain1
# 在DNS类型的NQA模板视图下配置测试要解析的域名为domain1。
[Sysname-nqatplt-dns-dnstplt] resolve-target domain1
1.1.60  resolve-type
resolve-type命令用来配置域名解析类型。
undo resolve-type命令用来恢复缺省情况。
resolve-type { A | AAAA }
undo resolve-type
域名解析类型为A类型。
DNS类型的NQA模板视图
A:域名解析类型为A类型请求,即将域名解析为IPv4地址。
AAAA:域名解析类型为AAAA类型请求,即将域名解析为IPv6地址。
# 在DNS类型的NQA模板视图下,配置测试的域名解析类型为A
[Sysname-nqatplt-dns-dnstplt] resolve-type A
route-option bypass-route命令用来开启路由表旁路功能,探测直连目的地的连通情况。
undo route-option bypass-route命令用来关闭路由表旁路功能。
路由表旁路功能处于关闭状态。
UDP-tracert测试类型视图
ICMP-jitte/UDP-jitter/Voice测试类型视图
开启该功能后,将不进行路由查找,而直接将报文发送到直连网络的目的地。
开启该功能后,设备转发探测报文可以经过的最大跳数为1,ttl命令设置的跳数不会生效。
测试目的端使用IPv6地址时,本命令配置无效。
# 在ICMP-echo测试类型下开启路由旁路功能。
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface命令用来配置指定接口的IP地址作为探测报文的源IP地址。
undo source interface命令用来恢复缺省情况。
source interface interface-type interface-number
以报文发送接口的主IP地址作为探测报文中的源IP地址。
ICMP-echo测试类型视图
UDP-tracert测试类型视图
ICMP类型的NQA模板视图
interface-type interface-number:探测报文源接口的接口类型和接口编号。
本命令指定的接口必须处于UP状态,否则探测将会失败。
对于ICMP-echo测试类型及ICMP类型的NQA模板,本命令与source ipsource ipv6命令作用相同,多次执行这三条命令时,最后一次执行的命令生效;对于UDP-tracert测试类型,本命令与source ip命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下指定VLAN接口1的IP地址作为ICMP-echo探测报文的源IP地址。
[Sysname-nqa-admin-test-icmp-echo] source interface vlan-interface 1
# 在ICMP类型的NQA模板视图下指定VLAN接口1的IP地址作为ICMP-echo探测报文的源IP地址。
[Sysname-nqatplt-icmp-icmptplt] source interface vlan-interface 1
·     source ip
·     source ipv6
1.1.63  source ip
source ip命令用来配置探测报文的源IPv4地址。
undo source ip命令用来恢复缺省情况。
source ip ip-address
undo source ip
以报文发送接口的主IP地址作为探测报文中的源IPv4地址。
DHCP/DLSw/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
ip-address:探测报文的源IPv4地址。
source ip命令配置的源IP地址必须是设备上接口的IPv4地址,且接口为UP状态,否则测试将会失败。
对于NQA模板类型来说,当源地址类型和目的地址类型不一致时,以目的地址类型为准,进行该类型的报文探测,此时源地址的配置不生效。
对于ICMP-echo/UDP-tracert测试类型及ICMP类型的NQA模板,本命令和source interface命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下配置ICMP-echo探测报文中的源IPv4地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
# 在ICMP类型的NQA模板视图下配置探测报文中的源IPv4地址为10.1.1.1。
[Sysname-nqatplt-icmp-icmptplt] source ip 10.1.1.1
·     source interface
1.1.64  source ipv6
source ipv6命令用来配置探测报文的源IPv6地址。
undo source ipv6命令用来恢复缺省情况。
source ipv6 ipv6-address
undo source ipv6
以报文发送接口的IPv6地址作为探测报文中的源IPv6地址。
ICMP-echo测试类型视图
任意类型的NQA模板视图
ipv6-address:探测报文的源IPv6地址,不支持IPv6链路本地地址。
source ipv6命令配置的源IPv6地址必须是设备上接口的IPv6地址,且接口为up状态,否则测试将会失败。
对于ICMP-echo测试类型及ICMP类型的NQA模板,本命令和source interface命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下配置ICMP-echo探测报文中的源IPv6地址为1::1。
[Sysname-nqa-admin-test-icmp-echo] source ipv6 1::1
# 在ICMP类型的NQA模板视图下配置探测报文中的源IPv6地址为1::1。
[Sysname-nqatplt-icmp-icmptplt] source ipv6 1::1
·     source interface
1.1.65  source port
source port命令用来配置探测报文的源端口号。
undo source port命令用来恢复缺省情况。
source port port-number
undo source port
未指定源端口号。
UDP-echo测试类型视图
SNMP测试类型视图
UDP-tracert测试类型视图
DNS类型的NQA模板视图
port-number:探测报文的源端口号,取值范围为1~65535。
# 在UDP-echo测试类型下配置探测报文的源端口号为8000。
[Sysname-nqa-admin-test-udp-echo] source port 8000
# 在DNS类型的NQA模板视图下配置探测报文的源端口号为8000。
[Sysname-nqatplt-dns-dnstplt] source port 8000
ssl-client-policy命令用来为HTTPS/SSL类型的NQA模板绑定SSL客户端策略。
undo ssl-client-policy命令用来恢复缺省情况。
ssl-client-policy policy-name
未绑定SSL客户端策略。
HTTPS/SSL类型的NQA模板视图
policy-name:SSL客户端策略名,为1~31个字符的字符串,不区分大小写。
通过绑定SSL客户端策略与服务器建立SSL连接,确认服务器业务的可用性。
# 在SSL类型的NQA模板视图下配置SSL客户端策略为policy。
[Sysname] nqa template ssl ssltplt
[Sysname-nqatplt-ssl-ssltplt] ssl-client-policy policy
statistics hold-time命令用来配置统计组的保留时间。
undo statistics hold-time命令用来恢复缺省情况。
statistics hold-time hold-time
统计组的保留时间为120分钟。
hold-time:统计组的保留时间,取值范围为1~1440,单位为分钟。
统计组具有老化功能。统计组保存一定时间后将被删除,以便记录新的统计组信息。
# 在ICMP-echo测试类型下配置统计组的保留时间为3分钟。
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
statistics interval命令用来配置对测试结果进行统计的时间间隔。
undo statistics interval命令用来恢复缺省情况。
statistics interval interval
对测试结果进行统计的时间间隔为60分钟。
interval:对测试结果进行统计的时间间隔,取值范围为1~35791394,单位为分钟。
NQA将统计时间间隔内完成的NQA测试归为一组,计算该组测试结果的统计值,这些统计值构成一个统计组。通过display nqa statistics命令可以显示该统计组的信息。
# 在ICMP-echo测试类型下配置对测试结果进行统计的时间间隔为2分钟。
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
statistics max-group命令用来配置能够保留的最大统计组个数。
undo statistics max-group命令用来恢复缺省情况。
statistics max-group number
能够保留的最大统计组个数为2。
number:能够保留的最大统计组个数,取值范围为0~100。
当保留的统计组数目达到最大值时,如果形成新的统计组,保存时间最久的统计组将被删除。
能够保留的最大统计组个数为0时,不进行统计。
# 在ICMP-echo测试类型下配置能够保留的最大统计组个数为5。
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
1.1.70  target-only
target-only命令用来配置Path-jitter测试中仅针对到达目的地址的完整路径进行探测,不逐跳进行探测。
undo target-only命令用来恢复缺省情况。
target-only
undo target-only
Path-jitter测试中会逐跳进行探测。
Path-jitter测试类型视图
# 在Path-jitter测试类型下配置仅针对到达目的地址的完整路径进行探测。
[Sysname-nqa-admin-test-path-jitter] target-only
1.1.71  tos
tos命令用来配置NQA探测报文IP报文头中服务类型域的值。
undo tos命令用来恢复缺省情况。
tos value
undo tos
NQA探测报文IP报文头中服务类型域的值为0。
任意测试类型视图
任意类型的NQA模板视图
value:探测报文IP报文头中服务类型域的值,取值范围为0~255。
# 在ICMP-echo测试类型下配置探测报文IP报文头中服务类型域的值为1。
[Sysname-nqa-admin-test-icmp-echo] tos 1
# 在ICMP类型的NQA模板视图下配置探测报文IP报文头中服务类型域的值为1。
[Sysname-nqatplt-icmp-icmptplt] tos 1
1.1.72  ttl
ttl命令用来配置探测报文在网络中可以经过的最大跳数。
undo ttl命令用来恢复缺省情况。
ttl value
undo ttl
UDP-tracert类型探测报文在网络中可以经过的最大跳数是30跳。其它测试类型下探测报文在网络中可以经过的最大跳数为20跳。
UDP-tracert测试类型视图
任意类型的NQA模板视图
value:对于UDP-tracert测试类型,表示允许探测报文填充的最大跳数值;对于其它测试类型,表示探测报文在网络中可以经过的最大跳数。取值范围为1~255。
配置route-option bypass-route命令后,探测报文在网络中可以经过的最大跳数为1,ttl命令不会生效。
配置UDP-tracert类型测试时,如果使用init-ttl命令配置的初始跳数值大于此值,测试将无法启动。
# 在ICMP-echo测试类型下配置探测报文在网络中可以经过的最大跳数为16跳。
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test-icmp-echo] ttl 16
# 在ICMP类型的NQA模板视图下配置探测报文在网络中可以经过的最大跳数为16跳。
[Sysname-nqatplt-icmp-icmptplt] ttl 16
1.1.73  type
type命令用来配置当前测试组的测试类型,并进入测试组测试类型视图。
type { dhcp | dlsw | dns | ftp | http | icmp-echo | icmp-jitter | path-jitter | snmp | tcp | udp-echo | udp-jitter | udp-tracert | voice }
未配置当前测试组的测试类型。
NQA测试组视图
dhcp:测试类型为DHCP。
dlsw:测试类型为DLSw。
dns:测试类型为DNS。
ftp:测试类型为FTP。
http:测试类型为HTTP。
icmp-echo:测试类型为ICMP-echo。
icmp-jitter:测试类型为ICMP-jitter。
path-jitter:测试类型为Path-jitter。
snmp:测试类型为SNMP。
tcp:测试类型为TCP。
udp-echo:测试类型为UDP-echo。
udp-jitter:测试类型为UDP-jitter。
udp-tracert:测试类型为UDP-tracert。
voice:测试类型为Voice。
一个NQA测试组对应一个NQA测试类型。当进入NQA测试组视图后,需要指定测试类型并配置测试类型相应的属性。当NQA测试组指定了一个测试类型后,测试组将与测试类型绑定,若需要重新指定测试类型,请在系统视图下删除测试组之后重新创建测试组并指定测试类型。
# 配置测试组的测试类型为FTP测试,并进入测试组测试类型视图。
1.1.74  url
url命令用来配置测试访问的网址。
undo url命令用来恢复缺省情况。
url url
undo url
未配置测试访问的网址。
FTP/HTTP测试类型视图
FTP/HTTP/HTTPS类型的NQA模板视图
url:测试操作访问的目标资源地址,为1~255个字符的字符串,区分大小写。url中的主机名部分,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,区分大小写;字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。
·     HTTP测试类型时,url格式为http://host/resource或http://host:port/resource
·     HTTPS测试类型时,url格式为https://host/resource或https://host:port/resource
·     FTP测试类型时,url格式为ftp://host/filename或ftp://host:port/filename
filename取值范围的详细介绍,请参见“基础配置指导”中的“文件系统管理”。
# 在HTTP测试类型下配置HTTP测试访问的网址为http://www.company.com/index.html。
[Sysname-nqa-admin-test-http] url http://www.company.com/index.html
# 在HTTP类型的NQA模板视图下配置测试访问的网址为http://www.company.com/index.html。
[Sysname-nqatplt-http-httptplt] url http://www.company.com/index.html
1.1.75  username
username命令用来配置登录用户名。
undo username命令用来恢复缺省情况。
username username
undo username
未配置登录用户名。
FTP/HTTP测试类型视图
username:测试使用的登录用户名,区分大小写。FTP、HTTP或HTTPS登录用户名,为1~32个字符的字符串;RADIUS用户名,为1~253个字符的字符串。
# 在FTP测试类型下配置FTP登录用户名为administrator。
[Sysname-nqa-admin-test-ftp] username administrator
# 在FTP类型的NQA模板视图下配置FTP登录用户名为administrator。
[Sysname-nqatplt-ftp-ftptplt] username administrator
·     operation
·     password
1.1.76  version
version命令用来配置HTTP/HTTPS测试所使用的版本。
undo version命令用来恢复缺省情况。
version { v1.0 | v1.1 }
undo version
HTTP/HTTPS测试所使用的版本为1.0。
HTTP测试类型视图
v1.0:测试使用的版本为1.0。
v1.1:测试使用的版本为1.1。
# 在HTTP测试类型下配置HTTP测试使用的版本为1.1。
[Sysname-nqa-admin-test-http] version v1.1
1.1.77  vpn-instance
vpn-instance命令用来指定测试操作所属的VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
未指定测试操作所属的VPN,NQA用来测试公网的连通性。
UDP-tracert测试类型视图
任意类型的NQA模板视图
vpn-instance-name:VPN实例名称,为1~31个字符的字符串,区分大小写。
指定测试操作所属的VPN实例后,NQA将测试指定VPN实例内隧道的连通情况。
# 在ICMP-echo测试类型下指定测试操作所属的VPN实例为vpn1。
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] vpn-instance vpn1
# 在FTP类型的NQA模板视图下指定测试操作所属的VPN实例为vpn1。
[Sysname-nqatplt-ftp-ftptplt] vpn-instance vpn1
1.2  NQA服务器端命令
只有在测试类型为UDP-jitter、TCP、UDP-echo和Voice时,才需要配置NQA服务器。
1.2.1  display nqa server
display nqa server命令用来显示NQA服务器的状态信息。
display nqa server
# 显示NQA服务器的状态信息。
<Sysname> display nqa server
NQA server status: Enabled
TCP connect:
   IP address          Port      Tos    VPN instance
   2.2.2.2             2000      200    -
UDP echo:
   3.3.3.3             3000      255    -
表1-10 display nqa server命令输出信息描述
描述命令
NQA server status
NQA服务器状态,包括的取值如下:
·     Disabled:未启用NQA服务器功能;
·     Enabled:启用了NQA服务器功能;
TCP connect
NQA TCP测试中服务器的状态信息
UDP echo
NQA UDP测试中服务器的状态信息
IP address
NQA服务器TCP/UDP监听服务的IP地址
Port
NQA服务器TCP/UDP监听服务的端口号
Tos
NQA服务器TCP/UDP监听服务的回应报文携带的Tos值。未配置Tos参数时,本字段显示为-,但:
·     对于TCP监听服务,回应报文中实际携带的Tos值为0;
·     对于UDP监听服务,回应报文中实际携带的Tos值为从客户端发送的请求报文中获取到的Tos值
VPN instance
NQA服务器监听的IP地址所属的VPN实例名称。如果NQA服务器监听的是公网IP地址,则显示为-
·     nqa server enable
·     nqa server tcp-connect
·     nqa server udp-echo
1.2.2  nqa server enable
nqa server enable命令用来开启NQA服务器功能。
undo nqa server enable命令用来关闭NQA服务器功能。
nqa server enable
NQA服务器功能处于关闭状态。
# 开启NQA服务器功能。
[Sysname] nqa server enable
·     display nqa server
1.2.3  nqa server tcp-connect
nqa server tcp-connect命令用来在NQA服务器上创建TCP监听服务。
undo nqa server tcp-connect命令用来删除指定的TCP监听服务。
nqa server tcp-connect ip-address port-number [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server tcp-connect ip-address port-number [ vpn-instance vpn-instance-name ]
不存在TCP监听服务
ip-address:NQA服务器TCP监听服务监听的IP地址。
port-number:NQA服务器TCP监听服务监听的端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:NQA服务器监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示TCP监听的是公网IP地址。
tos tos:NQA服务器应答报文中的ToS域的值。取值范围为0~255。不指定本参数时,取值为0。
只有在测试类型为TCP时,才需在NQA服务器上配置此命令。
所配置的IP地址、端口号及VPN实例必须与NQA客户端的配置一致,且不能与已有的监听服务冲突。
所配置的IP地址必须是作为服务器的设备上的接口的IP地址,否则配置无效。
建议不要配置1~1023之间的端口(知名端口),否则可能导致NQA测试失败或该知名端口对应的服务不可用。
# 创建IP地址为169.254.10.2,端口号为9000的TCP监听服务。
[Sysname] nqa server tcp-connect 169.254.10.2 9000
·     nqa server enable
1.2.4  nqa server udp-echo
nqa server udp-echo命令用来在NQA服务器上创建UDP监听服务。
undo nqa server udp-echo命令用来删除指定的UDP监听服务。
nqa server udp-echo ip-address port-number [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server udp-echo ip-address port-number [ vpn-instance vpn-instance-name ]
不存在UDP监听服务
ip-address:NQA服务器UDP监听服务监听的IP地址。
port-number:NQA服务器UDP监听服务监听的端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:NQA服务器监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示UDP监听的是公网IP地址。
tos tos:NQA服务器应答报文中的ToS域的值。取值范围为0~255。不指定本参数时,取值从客户端发送的请求报文中获取。
只有在测试类型为UDP-jitter、UDP-echo或Voice时,才需在NQA服务器上配置此命令。
# 创建IP地址为169.254.10.2、端口号为9000的UDP监听服务。
[Sysname] nqa server udp-echo 169.254.10.2 9000
·     nqa server enable
