18-EVPN命令参考
01-EVPN命令
本章节下载 01-EVPN命令  (417.50 KB)
01-EVPN命令
  录
1 EVPN
1.1 EVPN配置命令
1.1.1 address-family evpn (public instance view)
1.1.2 address-family evpn (VPN instance view)
1.1.3 address-family ipv4 (public instance view)
1.1.4 address-family ipv6 (public instance view)
1.1.5 address-family l2vpn evpn (BGP instance view)
1.1.6 advertise evpn route
1.1.7 advertise l2vpn evpn
1.1.8 advertise l3vpn route
1.1.9 arp mac-learning disable
1.1.10 arp-advertising disable
1.1.11 dci enable
1.1.12 display bgp l2vpn evpn
1.1.13 display evpn auto-discovery
1.1.14 display evpn route arp
1.1.15 display evpn route arp suppression
1.1.16 display evpn route mac
1.1.17 display evpn route nd
1.1.18 display evpn routing-table
1.1.19 evpn edge group
1.1.20 evpn encapsulation
1.1.21 evpn route arp-mobility suppression
1.1.22 export route-policy
1.1.23 import evpn mac-ip
1.1.24 import route-policy
1.1.25 ip forwarding-conversational-learning
1.1.26 ip public-instance
1.1.27 ip-prefix-route generate disable
1.1.28 ipv6 forwarding-conversational-learning
1.1.29 l3-vni
1.1.30 mac-address forwarding-conversational-learning
1.1.31 mac-advertising disable
1.1.32 mapping vni
1.1.33 nd mac-learning disable
1.1.34 peer advertise evpn-route suppress
1.1.35 peer default-gateway no-advertise
1.1.36 peer next-hop-invariable
1.1.37 peer re-originated
1.1.38 peer router-mac-local
1.1.39 policy vpn-target
1.1.40 route-distinguisher (EVPN instance view)
1.1.41 route-distinguisher (public instance view)
1.1.42 rr-filter
1.1.43 vpn-route cross multipath
1.1.44 vpn-target
1 EVPN
1.1  EVPN配置命令
address-family evpn命令用来进入公网实例EVPN视图。
undo address-family evpn命令用来删除公网实例EVPN视图下的所有配置。
address-family evpn
公网实例视图
在公网实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入公网实例EVPN视图。
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
address-family evpn命令用来进入VPN实例EVPN视图。
undo address-family evpn命令用来删除VPN实例EVPN视图下的所有配置。
address-family evpn
VPN实例视图
在VPN实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入VPN实例EVPN视图。
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
address-family ipv4命令用来进入公网实例IPv4 VPN视图。
undo address-family ipv4命令用来删除公网实例IPv4 VPN视图下的所有配置。
address-family ipv4
公网实例视图
# 进入公网实例IPv4 VPN视图。
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family ipv6命令用来进入公网实例IPv6 VPN视图。
undo address-family ipv6命令用来删除公网实例IPv6 VPN视图下的所有配置。
address-family ipv6
公网实例视图
# 进入公网实例IPv6 VPN视图。
[Sysname-public-instance] address-family ipv6
[Sysname-public-instance-ipv6]
address-family l2vpn evpn命令用来创建BGP EVPN地址族,并进入BGP EVPN地址族视图。如果BGP EVPN地址族已经存在,直接进入BGP EVPN地址族视图。
undo address-family l2vpn evpn命令用来删除BGP EVPN地址族,及相应地址族视图下的所有配置。
不存在BGP EVPN地址族。
BGP实例视图
BGP EVPN地址族视图下的配置,只对公网BGP EVPN地址族的路由和对等体生效。
# 创建BGP EVPN地址族,并进入BGP EVPN地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise evpn route命令用来配置允许BGP EVPN路由通过VPNv4或VPNv6地址族发布给邻居。
undo advertise evpn route命令用来禁止BGP EVPN路由通过VPNv4或VPNv6地址族发布给邻居。
advertise evpn route [ replace-rt ][ advertise-policy policy-name ]
BGP EVPN路由不会通过VPNv4或VPNv6地址族向外发送。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
replace-rt:指定将BGP EVPN路由的RT修改为VPNv4或VPNv6路由的RT。如果不指定本参数,则不修改BGP EVPN路由的RT。
advertise-policy policy-name:指定仅将通过路由策略过滤的BGP EVPN路由发布给VPNv4或VPNv6邻居。policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则所有BGP EVPN路由都可以发布给VPNv4或VPNv6邻居。
不同的数据中心之间通过MPLS L3VPN网络互联时,需要在ED上配置BGP EVPN和BGP VPNv4/VPNv6路由相互引入以实现数据中心之间的互通。
执行本命令后,设备会将EVPN的IP前缀路由、携带主机路由信息的MAC/IP发布路由通过VPNv4或VPNv6地址族发布给邻居。
# 配置允许BGP EVPN路由通过VPNv4地址族发布给邻居。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] advertise evpn route
advertise l2vpn evpn命令用来配置允许对外发布 BGP EVPN路由。
undo advertise l2vpn evpn命令用来禁止对外发布 BGP EVPN路由。
允许对外发布BGP EVPN路由。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
配置允许对外发布 BGP EVPN路由后,设备接收到BGP EVPN的IP前缀路由和包含ARP/ND信息的MAC/IP发布路由,并将其添加到某个VPN实例路由表后,会将IP前缀路由和包含ARP/ND信息的MAC/IP发布路由(私网路由)发布到本地站点。
# 配置允许BGP VPN实例vpn1对外发布BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
advertise l3vpn route命令用来配置允许BGP VPNv4或VPNv6路由通过EVPN地址族发布给邻居。
undo advertise l3vpn route命令用来禁止BGP VPNv4或VPNv6路由通过EVPN地址族发布给邻居。
advertise l3vpn route [ replace-rt ][ advertise-policy policy-name ]
BGP VPNv4或VPNv6路由不会通过EVPN地址族向外发送。
BGP EVPN地址族视图
replace-rt:指定将BGP VPNv4或VPNv6路由的RT修改为EVPN路由的RT。如果不指定本参数,则不修改BGP VPNv4或VPNv6路由的RT。
advertise-policy policy-name:指定仅将通过路由策略过滤的BGP VPNv4或VPNv6路由发布给BGP EVPN邻居。policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则所有BGP VPNv4或VPNv6路由均可以发布给BGP EVPN邻居。
执行本命令后,BGP VPNv4或VPNv6路由将作为EVPN的IP前缀路由发布给邻居。
# 配置允许BGP VPNv4或VPNv6路由通过EVPN地址族发布给邻居。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] advertise l3vpn route
arp mac-learning disable命令用来配置禁止EVPN从ARP信息中学习MAC地址表项。
undo arp mac-learning disable命令用来恢复缺省情况。
EVPN可以从ARP信息中学习MAC地址表项。
EVPN实例视图
VTEP可能会同时接收到远端VTEP通告的MAC地址信息和ARP信息。其中,ARP信息中包含MAC地址信息。为了避免重复,可以在VTEP上执行本命令禁止EVPN从ARP信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ARP信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp-advertising disable命令用来配置禁止通告ARP信息,并撤销已经通告的ARP信息。
undo arp-advertising disable命令用来恢复缺省情况。
允许通告ARP信息。
EVPN实例视图
在EVPN分布式网关组网中,如果同一个VXLAN内的所有用户终端都部署在同一台EVPN网关下,则EVPN不需要通告该VXLAN的ARP信息(同时携带MAC和IP地址的MAC/IP发布路由),只需通告IP前缀路由,其他VXLAN内的用户终端通过IP前缀路由即可访问该VXLAN。此时,可以配置本命令禁止EVPN通告ARP信息,以减少占用的设备和网络资源。执行本命令后,设备还会撤销已经发布的ARP信息。
# 配置EVPN实例禁止通告ARP信息,并撤销已经通告的ARP信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] arp-advertising disable
1.1.11  dci enable
dci enable命令用来在接口上开启DCI功能。
undo dci enable命令用来关闭接口的DCI功能。
dci enable
undo dci enable
接口上DCI功能处于关闭状态。
EVPN数据中心互联组网中,需要在ED间互连的三层接口上开启DCI功能。
在主接口上开启DCI功能后,子接口会继承主接口的配置。
# 在接口Vlan-interface10上开启DCI功能。
[Sysname-Vlan-interface10] dci enable
display bgp l2vpn evpn命令用来显示BGP EVPN路由信息。
display bgp [ instance instance-name ] l2vpn evpn [ peer ipv4-address { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | igmp-ls | igmp-js | imet | ip-prefix | mac-ip | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
peer ipv4-address:显示向指定对等体发布或者从指定对等体收到的BGP EVPN路由。ipv4-address表示对等体的IP地址。
advertised-routes:显示向指定对等体发布的BGP EVPN路由信息。
received-routes:显示从指定对等体接收到的BGP EVPN路由信息。
statistics:显示BGP EVPN路由的统计信息。
route-distinguisher route-distinguisher:显示指定路由标识符的BGP EVPN路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
route-type:显示指定类型的BGP EVPN路由。
auto-discovery:显示以太网自动发现路由(Ethernet auto-discovery route)。
es:显示以太网段路由(Ethernet segment route)。
igmp-ls:显示IGMP离开同步路由(IGMP leave synch route)。
igmp-js:显示IGMP加入同步路由(IGMP join synch route)。
imet:显示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)。
ip-prefix:显示IP前缀路由(IP prefix advertisement route)。
mac-ip:显示MAC/IP发布路由(MAC/IP advertisement route)。
smet:显示选择性组播以太网标签路由(Selective multicast Ethernet tag route)。
evpn-route:显示指定BGP EVPN路由的详细信息。evpn-route表示EVPN路由信息,为1~512个字符的字符串,不区分大小写。
route-length:BGP EVPN路由信息的长度,取值范围为0~65535,单位为比特。
evpn-prefix:显示指定BGP EVPN路由的详细信息。evpn-prefix包含EVPN路由信息和路由信息长度,组成格式为evpn-route/route-length,为1~512个字符的字符串,不区分大小写。
advertise-info:显示BGP EVPN路由的通告信息。
ipv4-address:显示包含指定IPv4地址的EVPN路由信息。
ipv6-address:显示包含指定IPv6地址的EVPN路由信息。
mac-address:显示包含指定MAC地址的MAC/IP发布路由信息。执行本命令时,如果指定了route-type参数,则只有指定路由类型为mac-ip时,才可以指定本参数。
如果未指定任何参数,则显示所有BGP EVPN路由的简要信息。
# 显示所有BGP EVPN路由的简要信息。
<Sysname> display bgp l2vpn evpn
 BGP local router ID is 8.8.8.8
               a - additional-path
 Total number of routes from all PEs: 3
 Route distinguisher: 1:1
 Total number of routes: 2
* >i [2][0][48][7010-0000-0001][0][0.0.0.0]/104
                        7.7.7.7         0          100        0       i
*  i                    7.7.7.7         0          100        0       i
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011-0022-0033][32][11.22.33.55]/136
                        30.30.1.2       0                     0       100i
表1-1 display bgp l2vpn evpn命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     s - suppressed:聚合抑制路由
·     S - Stale:过期路由
·     a - additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? - incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
来自所有PE设备的BGP EVPN路由总数
Route distinguisher
路由标识符
公网实例的路由标识符
路由标识符为指定值的BGP EVPN路由总数
Network
BGP EVPN路由/路由长度,BGP EVPN路由取值包括:
·     [1][ESI][EthernetTagID]:
¡     1:表示以太网自动发现路由(Ethernet auto-discovery route)
¡     ESI:以太网段标识
¡     EthernetTagID:以太网标签
·     [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress]
¡     2:表示MAC/IP发布路由(MAC/IP advertisement route)
¡     MACLength:MAC地址长度
¡     MAC:MAC地址
¡     IPAddressLength:IP地址长度
¡     IPAddress:IP地址
·     [3][EthernetTagID][IPAddressLength][IPAddress]
¡     3:表示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)
¡     IPAddress:始发路由器的IP地址
·     [4][ESI][IPAddressLength][IPAddress]
¡     4:表示以太网段路由(Ethernet segment route)
¡     ESI:以太网段标识
·     [5][EthernetTagID][IPAddressLength][IPAddress]
¡     5:表示IP前缀路由(IP prefix advertisement route)
·     [6][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP]
¡     6:表示选择性组播以太网标签路由(Selective multicast Ethernet tag route)
¡     Source Len:组播源IP地址长度,(*,G)情况下设置为0
¡     Source IP:IGMP成员报告的源IP地址,(*,G)情况下该字段不存在
¡     Group Len:组播组IP地址长度
¡     Group IP:IGMP成员报告的组IP地址
¡     Originator Len:始发路由器IP地址长度
¡     Originator IP:始发路由器IP地址
·     [7][ESI][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP]
¡     7:表示IGMP加入同步路由(IGMP join synch route
¡     ESI:以太网标识段
·     [8][ESI][EthernetTagID] [Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP][ [LeaveGroup Synchronization]
¡     8:表示IGMP离开同步路由(IGMP leave synch route
¡     ESI:以太网标识段
¡     LeaveGroup Synchronization:离开组播组的同步序列号值
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[1][0001.0203.0405.0607.0809][5]/120的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][0001.0203.0405.0607.0809][5] 120
 BGP local router ID: 172.16.250.133
 Local AS number: 100
 Route distinguisher: 1.1.1.1:100
 Paths:   1 available, 1 best
 BGP routing table information of [1][0001.0203.0405.0607.0809][5]/120:
 Rely nexthop    : 10.1.1.2
 Original nexthop: 10.1.1.2
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
                   Label 1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet auto-discovery route
 ESI             : 0001.0203.0405.0607.0809
 Ethernet tag ID : 5
 MPLS label      : 10
表1-2 display bgp l2vpn evpn命令中Ethernet auto-discovery route详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
BGP routing table information of [1][00:00:00:00:00:00:00:00:00:00][5]/120
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
OutLabel
路由的出标签值
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Encapsulation Type:封装类型
·     ESI Label:ESI标签
RxPathID
接收到的路由的Add-Path ID值
BGP EVPN地址族暂不支持本字段
TxPathID
发送的路由的Add-Path ID值
BGP EVPN地址族暂不支持本字段
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
IP precedence
路由的IP优先级,取值范围为0~7,N/A表示无效值
QoS local ID
‌路由的Qos-Local-ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围为1~64,N/A表示无效值
EVPN route type
BGP EVPN路由类型,取值为Ethernet auto-discovery route,表示以太网自动发现路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MPLS label
MPLS标签,目前此字段无意义
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[2][5][48][0001-0203-0405][32][4.5.5.5]/136的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
 BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
                   >, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
                   >, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : MAC/IP advertisement route
 Ethernet tag ID : 5
 MAC address     : 0001-0203-0405
 IP address      : 5.5.5.5/32
 MPLS label1     : 10
 MPLS label2     : 0
表1-3 display bgp l2vpn evpn命令中MAC/IP advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Router's Mac:路由器MAC
·     MAC Mobility:MAC迁移属性。Flags表示是否为固定MAC地址,1为固定不可移动MAC,0为可以移动MAC;SeqNum用来标识最新的一次迁移
·     Default GateWay:默认网关路由
EVPN route type
BGP EVPN路由类型,取值为MAC/IP advertisement route,表示MAC/IP发布路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MAC address
MAC地址
IP address
IP地址
MPLS label1
用于二层转发的VXLAN ID
MPLS label2
‌用于三层转发的VXLAN ID,即L3VNI
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[3][0][32][5.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
 BGP routing table information of [3][0][32][4.5.5.5]/80:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>
 RxPathID        : 0x0
 TxPathID        : 0x0
 PMSI tunnel     : Flag 0, TunnelType 6, Label 10, EndPointAddress 10.1.1.2
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0,pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Inclusive multicast Ethernet tag route
 Ethernet tag ID : 0
 Origin address  : 5.5.5.5/32
表1-4 display bgp l2vpn evpn命令中Inclusive multicast Ethernet tag route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
PMSI tunnel
运营商组播服务接口的隧道信息,包括:
·     Flag:标志位,目前取值只能为0
·     TunnelType:隧道类型,目前取值只能为6,表示头端复制隧道
·     Label:VXLAN ID
·     EndPointAddress:隧道目的端地址
EVPN route type
BGP EVPN路由类型,取值为Inclusive multicast Ethernet tag route,表示包含性组播以太网标签路由
Ethernet tag ID
以太网标签
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][0000.0000.0000.0000.000a][32][4.5.5.5]/128的详细信息。
<Sysname>  display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][0000.0000.0000.0000.000a][32][4.5.5.5] 128
 BGP routing table information of [4][0000.0000.0000.0000.000a][32][4.5.5.5]/128:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <ES-Import RT: 1:1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet segment route
 ESI             : 0000.0000.0000.0000.000a
 Origin address  : 4.5.5.5/32
表1-5 display bgp l2vpn evpn命令中Ethernet segment route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     ES-Import RT:ES-Import Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Ethernet segment route,表示以太网段路由
ESI
以太网段标识
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[5][10][32][4.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
 BGP routing table information of [5][10][32][4.5.5.5]/80:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
                   0006-0708-0910>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 Ethernet tag ID : 10
 IP address      : 4.5.5.5/32
 Gateway address : 0.0.0.0
 MPLS Label      : 1
表1-6 display bgp l2vpn evpn命令中IP prefix advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
EVPN route type
BGP EVPN路由类型,取值为IP prefix advertisement route,表示IP前缀路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
IP address
IP网络前缀
Gateway address
网关地址
MPLS Label
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1] 160
 BGP routing table information of [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160:
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Selective multicast Ethernet tag route
 Ethernet tag ID : 0
 Source length   : 32
 Source address  : 10.1.1.1
 Group length    : 32
 Group address   : 224.224.224.224
 Origin address  : 192.168.3.1
 IGMP flags      : v3, include
表1-7 display bgp l2vpn evpn命令中Selective multicast Ethernet tag route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Selective multicast Ethernet tag route,表示SMET路由
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
IGMP flags
IGMP标记位信息
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][16][224.224.224.224][32][192.168.3.1] 240
 BGP routing table information of [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 0:0>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IGMP join synch route
 ESI             : 0000.0000.0000.0000.0000
 Ethernet tag ID : 0
 Source length   : 32
 Group length    : 32
表1-8 display bgp l2vpn evpn命令中IGMP join synch route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     EVI-RT:与EVI关联的Route Target属性
EVPN route type
BGP EVPN路由类型,取值为IGMP join synch route,表示IGMP-JS路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
IGMP flags
IGMP 标记位信息
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0] 272
 BGP routing table information of [8][0000.0000.0000.0000.0000]  [0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 1:200>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IGMP leave synch route
 Ethernet tag ID : 0
 Source length   : 32
 Group length    : 32
 Leave group sync: 0
 Max ResponseTime: 2500ms
 Max ResponseCode: 25
表1-9 display bgp l2vpn evpn命令中IGMP leave synch route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     ESI-RT:与ESI关联的Route Target属性
EVPN route type
BGP EVPN路由类型,取值为IGMP leave synch route,表示IGMP-LS路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
Leave group sync
离开组播组的同步序列号值
Max ResponseTime
最大响应时间,单位为毫秒
Max ResponseCode
接收到的报文中携带的最大响应值,单位为十分之一秒
IGMP flags
IGMP标记位信息
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][0000.0000.0000.0000.000a][32][4.5.5.5]/128的通告信息。
<Sysname> display bgp l2vpn  evpn  route-distinguisher 1.1.1.1:100 [4][0000.0000.0000.0000.000a] [32][4.5.5.5] 128 advertise-info
 Paths:   1 best
    10.2.1.2
表1-10 display bgp l2vpn evpn advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
到达指定目的网络的优选路由数目
BGP routing table information of [4][0000.0000.0000.0000.000a] [32] [4.5.5.5]/128
BGP EVPN路由[4][0000.0000.0000.0000.000a][32][4.5.5.5]/128的通告信息
该路由已经向哪些BGP EVPN对等体发送,以及对等体的数目
display evpn auto-discovery命令用来显示EVPN通过BGP自动发现的邻居信息。
display evpn auto-discovery { imet [ peer ip-address] [ vsi vsi-name ] | mac-ip | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的邻居信息。
peer ip-address:显示指定邻居的自动发现相关信息。ip-address为邻居的IP地址。如果未指定本参数,则显示自动发现的所有邻居的信息。
vsi vsi-name:显示指定VSI内自动发现的邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的邻居信息。
mac-ip:显示通过MAC/IP发布路由(MAC/IP Advertisement route)发现的邻居信息。
macip-prefix:显示通过携带L3VNI的MAC/IP发布路由或IP前缀路由发现的邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。如果未指定本参数,则显示从所有路由下一跳学习到的邻居信息。
count:显示自动发现的邻居数目。如果未指定本参数,则显示邻居的具体信息。
# 显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: vpna
RD                    PE_address      Tunnel_address  Tunnel mode VXLAN ID
1:10                  2.2.2.2         2.2.2.2         VXLAN       10
2:100                 3.3.3.3         3.3.3.3         VXLAN       10
表1-11 display evpn auto-discovery imet命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
RD
路由标识符
PE_address
远端VTEP在VSI内的标识
Tunnel_address
隧道的目的端地址
Tunnel mode
隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     VXLAN-DCI:表示VXLAN数据中心互联隧道
VXLAN ID
VXLAN编号
# 显示通过MAC/IP发布路由发现的邻居信息。
<Sysname> display evpn auto-discovery mac-ip
Total number of automatically discovered peers: 1
VSI name: vpna
Destination IP  Source IP       VXLAN ID    Tunnel mode     Tunnel name
6.6.6.6         1.1.1.9         100         VXLAN           Tunnel1
表1-12 display evpn auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
VXLAN ID
VXLAN编号
Tunnel mode
隧道模式,取值为VXLAN,表示VXLAN隧道
Tunnel name
隧道名称
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居信息。
<Sysname> display evpn auto-discovery macip-prefix
Destination IP  Source IP       L3VNI           Tunnel mode Outgoing interface
1.1.1.1         3.3.3.3         200             VXLAN       Vsi-interface3
2.2.2.2         3.3.3.3         200             VXLAN       Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居总数。
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
表1-13 display evpn auto-discovery macip-prefix命令显示信息描述表
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
L3VNI
用于三层转发的VXLAN ID
Tunnel mode
隧道的模式,取值包括
·     VXLAN:表示VXLAN隧道
Outgoing interface
出接口,即与L3VNI关联的VSI虚接口
邻接表项的总数
display evpn route arp命令用来显示EVPN的ARP信息。
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
local:显示本地ARP信息。
remote:显示远端ARP信息。
public-instance:显示公网实例的ARP信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP信息。vpn-instance-name表示 MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示ARP表项的数目。如果不指定本参数,则显示ARP表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端ARP信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ARP信息。
# 显示所有EVPN的ARP信息。
<Sysname> display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping        I - Invalid
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  a0ce-7e40-0400  0           GL
10.1.1.11       0001-0001-0001  a0ce-7e40-0400  0           DL
10.1.1.12       0001-0001-0011  a0ce-7e41-0401  0           B
10.1.1.13       0001-0001-0021  a0ce-7e42-0402  0           B
10.1.1.101      0001-0011-0101  a0ce-7e40-0400  0           SL
10.1.1.102      0001-0011-0102  0011-9999-0000  0           BS
Public instance                               Interface: Vsi-interface2
11.1.1.1        0033-0033-0033  a0ce-7e40-0400  0           GL
11.1.1.11       0011-0011-0011  a0ce-7e40-0400  0           DL
# 显示EVPN的ARP表项总数。
<Sysname> display evpn route arp count
Total number of entries: 8
表1-14 display evpn route arp命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
VSI虚接口
IP address
IP地址
MAC address
MAC地址
Router MAC
设备的Router MAC
VSI index
VSI索引
Flags
ARP表项类型,取值包括:
·     D:表示存在动态学习的ARP表项
·     B:表示存在通过BGP EVPN路由学习的ARP表项
·     L:表示本地ARP表项生效,未设置该标志表示通过BGP EVPN路由学习的ARP表项生效
·     G:表示生效的ARP表项是网关的ARP表项
·     S:表示生效的ARP表项是静态配置的ARP表项‌
·     M:表示生效的ARP表项是来自映射的远端VXLAN的ARP表项‌
·     I:表示该ARP表项无效,原因如下:
¡     通过shutdown命令手工关闭VSI
¡     出方向Tunnel接口不存在
ARP表项的总数
display evpn route arp suppression命令用来显示EVPN的ARP泛洪抑制信息。
display evpn route arp suppression [ local | remote ] [ vsi vsi-name ] [ count ]
local:显示本地ARP泛洪抑制信息。
remote:显示远端ARP泛洪抑制信息。
vsi vsi-name:显示指定VSI的ARP泛洪抑制信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ARP泛洪抑制信息。
count:显示ARP泛洪抑制表项的数目。如果不指定本参数,则显示ARP泛洪抑制表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ARP泛洪抑制信息。
# 显示所有EVPN的ARP泛洪抑制信息。
<Sysname> display evpn route arp suppression
VSI name: vpna
IP address      MAC address     Flags
10.1.1.12       0002-0002-0002  B
10.1.1.13       0002-0002-0002  BI
10.1.1.101      0001-0011-0101  BS
10.1.1.102      0001-0011-0102  DL
# 显示EVPN的ARP泛洪抑制表项总数。
<Sysname> display evpn route arp suppression count
Total number of entries: 4
表1-15 display evpn route arp suppression命令显示信息描述表
VSI name
VSI名称
IP address
IP地址
MAC address
MAC地址
Flags
ARP泛洪抑制表项类型,取值包括:
·     D:表示存在动态学习的ARP泛洪抑制表项
·     B:表示存在通过BGP EVPN路由学习的ARP泛洪抑制表项
·     L:表示本地ARP泛洪抑制表项生效,未设置该标志表示通过BGP EVPN路由学习的ARP泛洪抑制表项生效
·     G:表示生效的ARP泛洪抑制表项是网关的ARP表项
·     S:表示生效的ARP泛洪抑制表项是静态配置的ARP表项‌
·     M:表示生效的ARP泛洪抑制表项是来自映射的远端VXLAN的ARP表项‌
¡     出方向Tunnel接口不存在
ARP泛洪抑制表项的总数
display evpn route mac命令用来显示EVPN的MAC地址信息。
display evpn route mac [ local | remote ] [ vsi vsi-name ] [ count ]
local:显示本地MAC地址信息。
remote:显示远端MAC地址信息。
vsi vsi-name:显示指定VSI的MAC地址信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的MAC地址信息。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端MAC地址信息。
# 显示所有EVPN的本地和远端MAC地址信息。
<Sysname> display evpn route mac
VSI name: bbb
MAC address     Link ID/Name    Flags   Next hop
0000-0000-000a  1               DL      -
0000-0000-0009  Tunnel1         B       2.2.2.2
0001-2000-4000  -               BI      3.3.3.3
# 显示EVPN的MAC地址表项数目。
<Sysname> display evpn route mac count
Total number of entries: 3
表1-16 display evpn route mac命令显示信息描述表
VSI name
VSI名称
MAC address
MAC地址
Link ID/Name
Link ID表示路由表项的出链路标识符,即AC在VSI内的链路标识符
Name表示Tunnel接口名称
Flags
表项类型,取值包括:
·     D:表示存在动态学习的MAC地址表项
·     B:表示存在通过BGP EVPN路由学习的MAC地址表项
·     L:表示本地MAC地址表项生效,未设置该标志表示通过BGP EVPN路由学习的MAC地址表项生效
·     G:表示生效的MAC地址表项是网关的MAC地址表项
·     S:表示生效的MAC地址表项是静态配置的MAC地址表项‌
·     M:表示生效的MAC地址表项是来自映射的远端VXLAN的MAC地址表项‌
·     I:表示该MAC表项无效,原因如下:
¡     出方向Tunnel接口不存在
Nexthop
远端VTEP的地址,取值为“-”表示本地MAC
MAC地址表项的总数
display evpn route nd命令用来显示EVPN的ND表项信息。
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
local:显示本地ND表项信息。
remote:显示远端ND表项信息。
public-instance:显示公网实例的ND表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ND表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示ND表项的数目。如果不指定本参数,则显示ND表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ND表项信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ND表项信息。
# 显示所有EVPN的ND表项信息。
<Sysname> display evpn route nd
IPv6 address :   AD80:0300:1000:0050:0200:0300:0100:0012
MAC address  :   0001-0001-0001       Router MAC   :   a0ce-7e40-0400
VSI index    :   0                    Flags        :   GL
IPv6 address :   AD10:0300:1000:0020:0200:0300:0100:0022
MAC address  :   0001-0001-0002       Router MAC   :   a0ce-7e40-0411
Public instance                               Interface: Vsi-interface1
IPv6 address :   BC80:0300:1000:0050:0200:0300:0100:0033
MAC address  :   0002-0002-0001       Router MAC   :   a0ce-7e40-0422
IPv6 address :   BC10:0300:1000:0020:0200:0300:0100:0034
MAC address  :   0002-0002-0002       Router MAC   :   a0ce-7e40-0433
#显示EVPN的ND表项总数。
<Sysname>display evpn route nd count
表1-17 display evpn route nd命令显示信息描述表
VPN instance
VPN实例名称
Public instance
公网实例
VSI虚接口名称
IPv6 address
IPv6地址
MAC address
MAC地址
Router MAC
设备的Router MAC
VSI index
ND表项所属VSI的索引
Flags
ND表项类型,取值包括:
·     D:表示动态学习的ND表项
·     B:表示通过BGP EVPN路由学习的ND表项
·     L:表示本地ND表项生效,未设置该标志表示通过BGP EVPN路由学习的ND表项生效
·     G:表示生效的ND表项是网关的ND表项
·     S:表示生效的ND表项是静态配置的ND表项(暂不支持)
·     M:表示生效的ND表项是来自映射的远端VXLAN的ND表项
ND表项的总数
display evpn routing-table命令用来显示EVPN的路由表信息。
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6:显示EVPN的IPv6路由表信息。如果不指定本参数,则显示EVPN的IPv4路由表信息。
public-instance:显示公网实例的路由信息。
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示路由表项的数目。如果不指定本参数,则显示路由表项的具体信息。
# 显示VPN实例vpn1对应EVPN的IPv4路由信息。
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI   A – A-D ready   L - Local ES exists
VPN instance name: vpn1                             Local L3VNI: 7
IP address       Nexthop          Outgoing interface    NibID       Flags
10.1.1.11        1.1.1.1          Vsi-interface3        0x18000000  EAL
10.1.1.12        2.2.2.2          Vsi-interface3        0x18000001  EA
# 显示公网实例的EVPN IPv4路由信息。
<Sysname> display evpn routing-table public-instance
Public instance                                     Local L3VNI: 3900
# 显示VPN实例vpn1对应的EVPN的IPv4路由表项总数。
<Sysname> display evpn routing-table vpn-instance vpn1 count
# 显示VPN实例vpna对应的EVPN的IPv6路由信息。
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna                              Local L3VNI: 7
Next hop            :      1.1.1.1
Outgoing interface  :      Vsi-interface3
NibID               :      0x18000000
IPv6 address        :      BC10:0300:1000:0020:0200:0300:0100:0035
Next hop            :      2.2.2.2
NibID               :      0x18000001
表1-18 display evpn routing-table命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
Local L3VNI
与VPN实例或公网实例关联的L3VNI
IP address
目的IPv4地址
IPv6 address
目的IPv6地址
Nexthop
下一跳地址
Outgoing interface
出接口
NibID
下一跳ID
Flags
表项等价属性,取值包括:
·     E:表示路由携带了有效的ESI字段
·     A:表示1类路由收全,可以下发该下一跳对应的等价路径
·     L:表示本地有激活的ESI,不下发远端路由表项
·     -:表示该2类路由未携带有效的ESI字段,不支持等价
路由表项的总数
evpn edge group命令用来配置ED设备的虚拟IP地址。
undo evpn edge group命令用来恢复缺省情况。
evpn edge group group-ip
未指定ED设备的虚拟IP地址。
group-ip:ED设备的虚拟IP地址。
为了提高ED的可靠性,避免单点故障,在数据中心的边缘可以部署两台ED设备与其他数据中心互联。在这两台ED设备上执行本命令后,它们将虚拟成一台ED设备,采用虚拟IP地址与VTEP、远端ED建立隧道,以实现冗余保护和负载分担。
两台ED设备被虚拟成一台设备以后,ED设备不能在本地接入虚拟机,只能作为数据中心互联的边缘设备使用,且不能在单台ED设备上引入外部路由。
两台ED设备上配置的虚拟IP地址必须相同,该虚拟IP地址应为ED设备上某个LoopBack接口的IP地址,且该地址不能与BGP对等体的地址相同。
# 配置ED设备的虚拟IP地址为1.2.3.4。
[Sysname] evpn edge group 1.2.3.4
evpn encapsulation命令用来创建EVPN实例,并进入EVPN实例视图。如果EVPN实例已经存在,则直接进入EVPN实例视图。
undo evpn encapsulation命令用来恢复缺省情况。
不存在EVPN实例。
VSI视图
vxlan:表示EVPN采用VXLAN封装方式。
只有创建EVPN实例后,才能进行EVPN相关配置。
# 创建EVPN实例,并进入EVPN实例视图。
[Sysname] vsi aaa
evpn route arp-mobility suppression命令用来开启ARP反复迁移抑制功能。
undo evpn route arp-mobility suppression命令用来关闭ARP反复迁移抑制功能。
ARP反复迁移抑制功能处于关闭状态。
分布式EVPN网关组网中,不同分布式EVPN网关下的设备如果错误地配置了相同的IP地址,会造成分布式EVPN网关间不断同步ARP信息并更新本地EVPN的ARP表项信息,此时分布式EVPN网关认为该设备在不断迁移。这种情况可能会使分布式EVPN网关间形成环路,占用大量的链路带宽。开启本功能后,若180秒内某站点在分布式EVPN网关间进行了5次迁移,则抑制最后一次迁移,也不对外通告该设备的ARP信息,避免分布式EVPN网关间形成环路。
# 开启ARP反复迁移抑制功能。
[Sysname] evpn route arp-mobility suppression
export route-policy命令用来在VPN实例下配置EVPN的出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
在VPN实例下未配置EVPN的出方向路由策略,即不对发布的路由进行过滤。
VPN实例EVPN视图
route-policy:出方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的出方向路由策略,则EVPN在发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制路由的发布。
多次执行本命令,最后一次执行的命令生效。
VPN实例视图和VPN实例EVPN视图下配置的出方向路由策略均能用于EVPN路由。如果同时配置二者,则EVPN采用VPN实例EVPN视图下的配置。
# 在VPN实例vpn1下配置EVPN的出方向路由策略为poly-1。
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
·     route-policy(三层技术-IP路由命令参考/路由策略)
import evpn mac-ip命令用来配置将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表。
undo import evpn mac-ip命令用来禁止将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表。
import evpn mac-ip
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
在BGP IPv4或BGP IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到BGP IPv4或BGP IPv6路由表,并发布到本地站点。
在BGP-VPN IPv4或BGP-VPN IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到VPN实例对应的BGP IPv4或BGP IPv6单播路由表,如果执行了advertise l2vpn evpn命令配置允许向本地站点发布BGP EVPN路由,则该路由会发布到本地站点,否则,该路由不会发布到本地站点。
# 配置将从对等体/对等体组收到的MAC/IP路由引入VPN实例vpna对应的BGP IPv4单播路由表。
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
import route-policy命令用来在VPN实例下配置EVPN的入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
在VPN实例下未配置EVPN的入方向路由策略,即如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
VPN实例EVPN视图
route-policy:入方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的入方向路由策略,则EVPN在接收路由时,将利用指定的路由策略对接收的路由进行过滤、改变接收路由的属性等。使用本命令可以更加精确、灵活地控制路由的接收。
VPN实例视图和VPN实例EVPN视图下配置的入方向路由策略均能用于EVPN路由。如果同时配置二者,则EVPN采用VPN实例EVPN视图下的配置。
# 在VPN实例vpn1下配置EVPN的入方向路由策略为poly-1。
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
ip forwarding-conversational-learning命令用来开启报文转发时下发主机路由FIB表项功能。
undo ip forwarding-conversational-learning命令用来关闭报文转发时下发主机路由FIB表项功能。
ip forwarding-conversational-learning [ aging aging-time ]
报文转发时下发主机路由FIB表项功能处于关闭状态。
aging aging-time:主机路由FIB表项的老化时间,取值范围为60~1440,单位为分钟,缺省值为60。
本功能仅用于EVPN组网。非EVPN组网中,不要开启本功能。
缺省情况下,设备会直接生成主机路由FIB表项,并下发到硬件。开启报文转发时下发主机路由FIB表项功能后,设备不会直接将主机路由FIB表项下发到硬件,只有在报文转发过程中需要使用主机路由FIB表项时,才会将其下发到硬件,以节省设备的硬件资源。
用户配置的老化时间过长或者过短,都可能影响设备的运行性能:
·     如果用户配置的老化时间过长,设备可能会保存许多过时的主机路由FIB表项,从而耗尽主机路由FIB表项资源,导致设备无法根据网络的变化及时更新主机路由FIB表项。
·     如果用户配置的老化时间太短,设备可能会删除有效的主机路由FIB表项,导致表项震荡,影响设备的运行性能。
所以用户需要根据实际情况,配置合适的老化时间来有效地实现主机路由FIB表项老化功能。
# 开启报文转发时下发主机路由FIB表项功能。
[Sysname] ip forwarding-conversational-learning
ip public-instance命令用来创建公网实例,并进入公网实例视图。如果公网实例已经存在,则直接进入公网实例视图。
undo ip public-instance命令用来删除公网实例。
ip public-instance
不存在公网实例。
公网实例用来实现分布式EVPN网关转发公网的三层流量及公私网互通。公网实例可以看作是特殊的VPN实例,分布式EVPN网关对公网实例的处理与VPN实例完全相同。
# 创建公网实例,并进入公网实例视图。
ip-prefix-route generate disable命令用来配置分布式VXLAN IP网关中VSI虚接口IP地址所在网段不产生IP前缀路由。
undo ip-prefix-route generate disable命令用来配置分布式VXLAN IP网关中VSI虚接口IP地址所在网段可以产生IP前缀路由。
对于集中式VXLAN IP网关,VSI虚接口IP地址所在网段不产生IP前缀路由,只产生VSI虚接口IP地址和MAC对应关系的MAC/IP发布路由;对于分布式VXLAN IP网关,VSI虚接口IP地址所在网段会产生IP前缀路由。
VSI虚接口视图
本命令仅对分布式VXLAN IP网关(在VSI虚接口上执行distributed-gateway local命令)生效。在集中式VXLAN IP网关上,只产生VSI虚接口IP地址和MAC对应关系的MAC/IP发布路由,不会产生IP前缀路由,不受本命令的控制。
# 配置接口VSI-interface1的IP地址所在网段不产生IP前缀路由。
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] ip-prefix-route generate disable
ipv6 forwarding-conversational-learning命令用来开启报文转发时下发主机路由IPv6 FIB表项功能。
undo ipv6 forwarding-conversational-learning命令用来关闭报文转发时下发主机路由IPv6 FIB表项功能。
ipv6 forwarding-conversational-learning [ aging aging-time ]
报文转发时下发主机路由IPv6 FIB表项功能处于关闭状态。
aging aging-time:下发到硬件的主机路由IPv6 FIB表项的老化时间,取值范围为60~1440,单位为分钟,缺省值为60。
缺省情况下,设备会直接生成主机路由IPv6 FIB表项,并下发到硬件。开启报文转发时下发主机路由IPv6 FIB表项功能后,设备不会直接将主机路由IPv6 FIB表项下发到硬件,只有在报文转发过程中需要使用主机路由IPv6 FIB表项时,才会将其下发到硬件,以节省设备的硬件资源。
·     如果用户配置的老化时间过长,设备可能会保存许多过时的主机路由IPv6 FIB表项,从而耗尽主机路由IPv6 FIB表项资源,导致设备无法根据网络的变化更新主机路由IPv6 FIB表项。
·     如果用户配置的老化时间太短,设备可能会删除有效的主机路由IPv6 FIB表项,可能导致表项震荡,影响设备的运行性能。
所以用户需要根据实际情况,配置合适的老化时间来有效地实现主机路由IPv6 FIB表项老化功能。
# 开启报文转发时下发主机路由IPv6 FIB表项功能,并配置下发到硬件的表项的老化时间为80分钟。
[Sysname] ipv6 forwarding-conversational-learning aging 80
1.1.29  l3-vni
l3-vni命令用来配置L3VNI。
undo l3-vni用来取消配置的L3VNI。
l3-vni vxlan-id
undo l3-vni
未配置L3VNI。
VSI虚接口视图
公网实例视图
vxlan-id:L3VNI,取值范围为0~16777215。
分布式网关组网中,需要在网关上配置L3VNI。在网关之间通过VXLAN隧道转发流量时,属于同一路由域、能够进行三层互通的流量通过L3VNI来标识。
转发某个VPN的三层流量时,需要在与该VPN实例关联的VSI虚接口视图下执行本命令;转发公网的三层流量时,不仅需要在属于公网的VSI虚接口视图下执行本命令,还需要在公网实例视图下执行本命令配置与VSI虚接口相同的L3VNI。
在公网实例视图下,不能通过重复执行本命令修改公网实例的L3VNI。如需修改公网实例的L3VNI,请先通过undo l3-vni命令删除L3VNI,再执行l3-vni命令。
本命令中指定的L3VNI不能与mapping vni命令配置的映射远端VXLAN ID相同。
# 在VSI虚接口100上配置L3VNI为1000。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] l3-vni 1000
mac-address forwarding-conversational-learning命令用来开启报文转发时下发远端MAC地址表项功能。
undo mac-address forwarding-conversational-learning命令用来关闭报文转发时下发远端MAC地址表项功能。
报文转发时下发远端MAC地址表项功能处于关闭状态。
缺省情况下,通过BGP EVPN路由同步过来的远端MAC地址表项会直接下发到硬件。开启本功能后,同步过来的远端MAC地址表项不会直接下发到硬件,当报文转发过程中需要使用远端MAC地址表项时,才会将其下发到硬件。该功能可以有效节省设备的硬件资源。
开启本功能后,当设备在一个MAC地址表项老化时间内收到50次目的MAC地址相同的报文,且设备的MAC地址表中不存在该MAC地址,设备会将此报文的目的MAC地址加入到黑洞MAC地址表项中。MAC地址表项老化时间和黑洞MAC地址的详细介绍,请参见“二层技术-以太网交换配置指导”中的“MAC地址表”。
# 开启报文转发时下发远端MAC地址表项功能。
[Sysname] mac-address forwarding-conversational-learning
mac-advertising disable命令用来配置禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
undo mac-advertising disable命令用来恢复缺省情况。
允许通告MAC地址信息。
EVPN实例视图
VTEP可能会同时向远端VTEP通告MAC地址信息和ARP信息。其中,ARP信息中已经包含MAC地址信息。为了避免重复,可以执行本命令来禁止本端VTEP向远端VTEP通告MAC地址信息。执行本命令后,本端VTEP还会撤销已经发布的MAC地址信息。
# 配置EVPN实例禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
1.1.32  mapping vni
mapping vni命令用来指定本地VXLAN映射的远端VXLAN。
undo mapping vni命令用来恢复缺省情况。
mapping vni vxlan-id
undo mapping vni
未指定本地VXLAN映射的远端VXLAN。
EVPN实例视图
vxlan-id:映射的远端VXLAN ID,取值范围为0~16777215。
在不同的数据中心中,同一租户的相同子网可能使用不同的VXLAN。这些数据中心互联时,若要保证同一租户相同子网之间的流量进行二层转发,则ED设备上需要执行本命令,在不同的VXLAN之间建立映射关系。
可以通过以下方式建立映射关系:
·     将本地VXLAN直接映射为另一个数据中心中使用的VXLAN。采用此方式时,只需在一个数据中心的ED上指定映射的远端VXLAN。例如,数据中心1内使用VXLAN 10、数据中心2内使用VXLAN 20时,只需在数据中心1的ED上配置VXLAN 10映射为远端VXLAN 20。
·     将不同数据中心ED上的本地VXLAN映射为相同的VXLAN(称为中间VXLAN)。采用此方式时,需要在所有数据中心的ED上都指定映射的远端VXLAN为中间VXLAN。例如,数据中心1内使用VXLAN 10、数据中心2内使用VXLAN 20、数据中心3内使用VXLAN 30时,需要在三个数据中心的ED上均配置映射的远端VXLAN为中间VXLAN(如VXLAN 500)。当多个数据中心互联,且不同数据中心使用的VXLAN各不相同时,需要使用此方式。中间VXLAN只能用于VXLAN映射,不能用作普通VXLAN来处理VXLAN业务。
·     本地设备上需要创建映射的远端VXLAN,为其配置EVPN实例,并为该EVPN实例配置RD和Route Target属性。
·     本命令中指定的映射远端VXLAN ID不能与l3-vni命令配置的L3VNI相同,也不能与reserved vxlan命令配置的保留VXLAN相同。
# 配置本地VXLAN 100映射为远端VXLAN 200。
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] quit
[Sysname-vsi-aaa-evpn-vxlan] mapping vni 200
·     reserved vxlan(VXLAN命令参考/VXLAN)
nd mac-learning disable命令用来配置禁止EVPN从ND信息中学习MAC地址表项。
undo nd mac-learning disable命令用来恢复缺省情况。
EVPN可以从ND信息中学习MAC地址表项。
EVPN实例视图
VTEP可能会同时接收到远端VTEP通告的MAC地址信息和ND信息。其中,ND信息中包含MAC地址信息。为了避免重复,可以在VTEP上执行本命令禁止EVPN从ND信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ND信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] nd mac-learning disable
peer advertise evpn-route suppress命令用来配置向对等体/对等体组发布EVPN路由时不发送指定类型的路由。
undo peer advertise evpn-route suppress命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } advertise evpn-route suppress { ip-prefix | mac-ip }
undo peer { group-name | ipv4-address [ mask-length ] } advertise evpn-route suppress { ip-prefix | mac-ip }
不抑制向对等体/对等体组发布EVPN路由。
BGP EVPN地址族视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
ip-prefix:指定不向对等体/对等体组发布IP前缀路由(IP Prefix Advertisement Route)。
mac-ip:指定不向对等体/对等体组发布MAC/IP发布路由(MAC/IP Advertisement Route)。
在ED上执行本命令可以使ED之间不发送指定类型的EVPN路由,从而减少ED上的路由条目。例如,在不需要二层互通的网络中,可以通过本命令抑制发布MAC/IP发布路由。
当不同数据中心的EVPN网关VSI虚接口的IP地址相同时,请不要抑制发布MAC/IP发布路由,否则会导致ED间无法互通。
# 配置ED之间不发送EVPN的IP前缀路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise evpn-route suppress ip-prefix
peer default-gateway no-advertise命令用来配置向对等体/对等体组发布EVPN网关路由时不携带Default-gateway扩展团体属性。
undo peer default-gateway no-advertise命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } default-gateway no-advertise
undo peer { group-name | ipv4-address [ mask-length ] } default-gateway no-advertise
向对等体/对等体组发布EVPN网关路由时会携带Default-gateway扩展团体属性。
BGP EVPN地址族视图
EVPN网关路由是指EVPN网关上VSI虚接口的IP地址对应的路由。缺省情况下,EVPN网关在发布该路由时,会携带Default-gateway扩展团体属性。携带Default-gateway扩展团体属性的多条路由间无法形成等价路由。执行本命令配置EVPN网关在发布网关路由时不携带Default-gateway扩展团体属性,可使多条EVPN网关路由间形成等价路由。
# 在BGP EVPN地址族视图下,配置向对等体1.1.1.1发布EVPN网关路由时不携带Default-gateway扩展团体属性。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 default-gateway no-advertise
peer next-hop-invariable命令用来配置向EBGP对等体/对等体组发布路由时不改变下一跳。
undo peer next-hop-invariable命令用来配置向EBGP对等体/对等体组发布路由时会将下一跳改为自己的地址。
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable
BGP EVPN地址族视图
在两个数据中心之间,BGP EVPN路由通过IBGP—EBGP—IBGP的路径发布。不同数据中心的两个主机通信时,报文通过入口VTEP和出口VTEP之间的VXLAN隧道传输。因此,需要执行本命令配置IBGP路由通告给EBGP对等体时不改变下一跳地址,使得VTEP学习到的BGP EVPN路由下一跳为远端VTEP的地址,以便在两个VTEP之间建立VXLAN隧道。
本命令与peer next-hop-local命令互斥。
# 配置向EBGP对等体1.1.1.1发布路由时不改变下一跳。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 next-hop-invariable
·     peer next-hop-local(三层技术-IP路由命令参考/BGP)
peer re-originated命令用来配置从对等体/对等体组接收到BGP EVPN的IP前缀路由后,将路由的L3VNI和RD替换为本地VPN实例的L3VNI和RD。
undo peer re-originated命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } re-originated
undo peer { group-name | ipv4-address [ mask-length ] } re-originated
不修改从对等体/对等体组接收到IP前缀路由的L3VNI和RD。
BGP EVPN地址族视图
EVPN数据中心互联组网中,在ED上执行本命令后,ED从VTEP或远端ED接收到EVPN的IP前缀路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则将该路由的L3VNI和RD替换为本地VPN实例的L3VNI和RD,并将替换后的路由发布给远端ED或VTEP。
通常在以下情况下,可以执行本命令:
·     不同数据中心使用的L3VNI不同,通过本配置修改L3VNI,以实现数据中心之间的互通。
·     用户不希望泄露本地数据中心使用的L3VNI时,可以执行本配置将本地所有L3VNI均替换为ED上的L3VNI,对外仅体现ED上的L3VNI。
执行本命令后,ED仅向对等体/对等体组发布L3VNI和RD替换后的路由,L3VNI和RD替换前的路由不会向对等体/对等体组发布。
如果ED上本地VPN实例的RD与接收到的BGP EVPN的IP前缀路由的RD相同,则不会替换该路由的L3VNI也不会重新生成路由,导致该BGP EVPN的IP前缀路由无法向对等体/对等体组发布。因此,执行本命令时,建议在不同设备上为VPN实例配置不同的RD。
# 在BGP EVPN地址族视图下,配置收到BGP EVPN的IP前缀路由后修改路由的L3VNI和RD。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated
peer router-mac-local命令用来配置向对等体/对等体组发布路由、将从对等体/对等体组接收到的路由发布给其他对等体时,将路由的Router MAC修改为自身的Router MAC地址。
undo peer router-mac-local命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] } router-mac-local
undo peer { group-name | ipv4-address [ mask-length ] } router-mac-local
不会修改路由的Router MAC。
BGP EVPN地址族视图
数据中心网络的ED设备上需要执行本命令,以便该设备将从数据中心内的对等体/对等体组学到的路由通告给其他数据中心网络的ED设备,或将从其他数据中心网络的ED设备学到的路由通告给数据中心内的对等体/对等体组时,将路由的Router MAC修改为本地的Router MAC。
# 在BGP EVPN地址族视图下,配置向对等体1.1.1.1发布路由、将从对等体1.1.1.1接收到的路由发布给其他对等体时,将路由的Router MAC修改为自身的Router MAC。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 router-mac-local
policy vpn-target命令用来开启BGP EVPN路由的VPN-Target过滤功能。
undo policy vpn-target命令用来关闭BGP EVPN路由的VPN-Target过滤功能。
policy vpn-target
BGP EVPN路由的VPN-Target过滤功能处于开启状态。
BGP EVPN地址族视图
开启BGP EVPN路由的VPN-Target过滤功能后,设备只将Export Route Target属性与本地Import Route Target属性匹配的BGP EVPN路由加入到BGP EVPN路由表。设备上如需保存所有BGP EVPN路由,则需执行undo policy vpn-target命令,不对BGP EVPN路由进行VPN-Target过滤。
# 关闭BGP EVPN路由的VPN-Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
route-distinguisher命令用来配置EVPN实例的RD(Route Distinguisher,路由标识符)。
undo route-distinguisher命令用来恢复缺省情况。
route-distinguisher { route-distinguisher | auto [ router-id ] }
未指定EVPN实例的RD。
EVPN实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串(不允许为全0)。路由标识符有三种格式:
auto:表示自动生成RD。
router-id:表示根据Router ID 自动生成RD,自动生成的RD取值为“Router ID:N”。如果不指定本参数,则表示根据VXLAN ID自动生成RD,自动生成的RD取值为“N:VXLAN ID”。其中,N为从1开始的整数;如果“Router ID:N”或“N:VXLAN”已被使用,则RD取值改为“Router ID:(N+1)”或“(N+1):VXLAN ID”,如此反复,直到找到未被使用的RD。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告。本命令指定的RD,携带在MP-BGP协议发布的邻居、MAC地址、主机路由信息中,以标识不同EVPN实例的邻居、MAC地址、主机路由信息。
# 配置EVPN的RD为22:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
route-distinguisher命令用来配置公网实例的RD。
未配置公网实例的RD。
公网实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
不能通过重复执行route-distinguisher命令修改公网实例的RD值。如需修改公网实例的RD值,请先通过undo route-distinguisher命令删除公网实例的RD值,再执行route-distinguisher命令配置新的RD值。
# 配置公网实例的RD为22:1。
[Sysname-public-instance] route-distinguisher 22:1
1.1.42  rr-filter
rr-filter命令用来配置路由反射器对反射的EVPN路由进行过滤。
undo rr-filter命令用来恢复缺省情况。
undo rr-filter
路由反射器不会对反射的EVPN路由进行过滤。
BGP EVPN地址族视图
ext-comm-list-number:扩展团体属性列表号,取值范围为1~199。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的EVPN路由进行过滤:只有接收的BGP EVPN路由通过扩展团体属性列表过滤时,路由反射器才会反射该EVPN路由。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置路由反射器只反射通过扩展团体属性列表10过滤的BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
vpn-route cross multipath命令用来开启VPN引入等价路由功能。
undo vpn-route cross multipath命令用来关闭VPN引入等价路由功能。
VPN引入等价路由功能处于关闭状态,对于前缀和RD均相同的多条路由,只会将最优路由引入到BGP EVPN路由表中。
BGP EVPN地址族视图
开启VPN引入等价路由功能后,BGP将前缀和RD均相同的多条路由全部引入到BGP EVPN路由表中。
# 开启VPN引入等价路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
1.1.44  vpn-target
vpn-target命令用来配置EVPN的Route Target属性。
undo vpn-target命令用来删除指定的Route Target属性。
EVPN实例视图:
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN实例EVPN视图/公网实例视图/公网实例IPv4 VPN视图/公网实例IPv6 VPN视图/公网实例EVPN视图:
未指定EVPN的Route Target属性。
EVPN实例视图
VPN实例EVPN视图
公网实例视图
公网实例IPv4 VPN视图
公网实例IPv6 VPN视图
公网实例EVPN视图
vpn-target&<1-8>:Route Target属性值,vpn-target为3~21个字符的字符串。&<1-8>表示前面的参数最多可以输入8次。Route Target有三种格式:
auto:表示自动生成RT。自动生成的RT取值为“BGP AS:VXLAN ID”。
both:指定配置的Route Target值同时作为Import Target和Export Target。没有指定bothexport-extcommunityimport-extcommunity中的任何一个参数时,缺省值为both
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告等。本地设备在通过MP-BGP的Update消息将BGP EVPN路由发送给远端设备时,将Update消息中携带的VPN target属性设置为Export target。远端设备接收到BGP EVPN路由后,将该路由中携带的Export Target属性与本地配置的Import Target进行比较,如果二者中存在相同的值,则接收该信息。
重复执行本命令,Route Target值为多次配置结果的集合。
# 配置EVPN的Import Target为10:1、100:1和1000:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
