- H3C Data Center Switches M-LAG Configuration Guide-6W101
- 00-M-LAG network planning
- 01-M-LAG+IPv4 and IPv6 Dual-Active VLAN Gateway Configuration Example
- 02-Multi-Layer M-LAG+STP+Dual-Active VLAN Gateway Configuration Examples
- 03-Multi-Layer M-LAG+Dual-Active VLAN Gateway+OSPF Configuration Examples
- 04-Multi-tier M-LAG+Spine Gateways+ECMP Paths to External Network Configuration Example
- 05-M-LAG and VRRP Configuration Example
- 06-M-LAG+RDMA Configuration Example
- 07-M-LAG and EVPN Distributed Gateway (IS-IS for underlay routing) Configuration Example
- 08-M-LAG and EVPN Distributed Gateway (BGP for Underlay Routing) Configuration Example
- 09-M-LAG+EVPN Distributed Gateway (OSPF on Underlay Network)+DHCP Relay+Microsegmentation+Service Chain Configuration Example
- 10-M-LAG+EVPN Centralized Gateway Configuration Example
- 11-Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example
- 12-M-LAG+EVPN+Monitor Link Configuration Examples
- 13-M-LAG and MVXLAN Configuration Example
- 14-M-LAG and DCI Configuration Example
- 15-M-LAG+EVPN DC Switchover Upon Border Failure Configuration Examples
- 16-Cascaded M-LAG Systems with Attached Multicast Source and Receivers Configuration Examples
16-Cascaded M-LAG Systems with Attached Multicast Source and Receivers Configuration Examples | 364.08 KB |
Example: Setting up two cascaded M-LAG systems with directly attached multicast source and receivers
Configuring the dual-active gateways
Underlay traffic characteristics
Testing network convergence upon single points of failure
Verifying the status of the M-LAG system
Verifying multicast forwarding information
Verifying the traffic interruption time during the upgrade
Replacing a switching fabric module
Configuring OSPF for establishing Layer 3 connectivity between M-LAG member devices
Verifying routing configuration
To improve network reliability, set up a two-tier cascaded M-LAG structure to support Layer 3 multicast services, as shown in Figure 1. The receivers receive video-on-demand traffic through multicast. PIM protocol is enabled on each device interface, and the entire PIM domain uses SM non-administrative domain mode.
Multicast receivers can be singlehomed to the receiver side M-LAG member devices or be attached to M-LAG interfaces. The multicast source is connected to an M-LAG system through M-LAG interfaces.
Device |
IP address |
Peer device and interface |
Device A |
WGE1/0/11 |
IPv4: 221.1.2.1/24 |
Device B: WGE1/0/11 |
Vlan-int20 |
IPv4: 20.1.1.1/24 |
Receiver 2 |
Vlan-int21 |
IPv4: 21.1.1.1/24 |
Receiver 1 |
Loopback0 |
IPv4: 3.3.3.3/32 |
N/A |
HGE1/0/28 |
IPv4: 11.2.1.2/24 |
Device C: HGE1/0/4 |
HGE1/0/29 |
IPv4: 12.2.1.2/24 |
Device D: HGE1/0/4 |
Device B |
WGE1/0/11 |
IPv4: 221.1.2.2/24 |
Device A: WGE1/0/11 |
Vlan-int20 |
IPv4: 20.1.1.1/24 |
Receiver 2 |
Loopback0 |
IPv4: 4.4.4.4/32 |
N/A |
HGE1/0/28 |
IPv4: 11.3.1.2/24 |
Device C: HGE1/0/5 |
HGE1/0/29 |
IPv4: 12.3.1.2/24 |
Device D: HGE1/0/5 |
Device C |
HGE1/0/6 |
IPv4: 220.1.1.1/24 |
Device D: HGE1/0/6 |
Vlan-int10 |
IPv4: 10.1.1.1/24 |
Source |
Loopback0 |
IPv4: 1.1.1.1/32 |
N/A |
HGE1/0/4 |
IPv4: 11.2.1.1/24 |
Device A: HGE1/0/28 |
HGE1/0/5 |
IPv4: 11.3.1.1/24 |
Device B: HGE1/0/28 |
Device D |
HGE1/0/6 |
IPv4: 220.1.1.2/24 |
Device C: HGE1/0/6 |
Vlan-int10 |
IPv4: 10.1.1.1/24 |
Source |
Loopback0 |
IPv4: 2.2.2.2/32 |
N/A |
HGE1/0/4 |
IPv4: 12.2.1.1/24 |
Device A: HGE1/0/29 |
HGE1/0/5 |
IPv4: 12.3.1.1/24 |
Device B: HGE1/0/29 |
Applicable product matrix
IMPORTANT: In addition to running an applicable software version, you must also install the most recent patch, if any. |
Device |
Software version |
S6805, S6825, S6850, S9850 |
R6710 |
S9820-64H, S9820-8C |
Not supported |
S6800, S6860, S6900 |
Not supported |
S12500X-AF, S12500F-AF, S6890 |
R2825 |
S12500R |
Not supported |
S12500G-AF |
R7625 |
S6812, S6813 |
F6628P22 |
Analysis
· Set up one M-LAG system with Device A and Device B and another with Device C and Device D.
· Create one VLAN interface for the same VLAN on Device A and Device B, respectively. In this example, create VLAN-interface 20. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
· Create one VLAN interface for the same VLAN on Device C and Device D, respectively. In this example, create VLAN-interface 10. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
· Enable IP multicast forwarding and IGMP snooping on Device A through Device D. A device with IGMP snooping enabled forwards multicast traffic of known multicast groups to the designated receivers instead of broadcasting the multicast traffic. Configure PIM on interfaces of the devices.
· Create VLAN-interface 21 on Device A to accommodate Receiver 1, which is singlehomed to the device.
Procedure summary
· Configuring the dual-active gateways
· Configuring Layer 3 multicast
Configuring M-LAG
NOTE: For the S12500X-AF, S12500F-AF, and S6890 series switches, first configure the MAC base address, and then assign MAC addresses on each device in the M-LAG systems based on the MAC base address. For more information about MAC address configuration, see M-LAG network planning. |
Configuring Device A and Device B
Device A |
Device B |
Remarks |
m-lag system-mac 1-1-2 |
Configure the M-LAG system MAC address. |
You must configure the same M-LAG system MAC address for devices in the same M-LAG system. |
m-lag system-number 1 |
m-lag system-number 2 |
Set the M-LAG system number. |
You must set different M-LAG system numbers for devices in the same M-LAG system. |
m-lag system-priority 122 |
Set the M-LAG system priority. |
You must set the same M-LAG system priority for devices in the same M-LAG system. |
m-lag standalone enable |
Enable M-LAG standalone mode. |
N/A |
m-lag keepalive ip destination 221.1.2.2 source 221.1.2.1 |
m-lag keepalive ip destination 221.1.2.1 source 221.1.2.2 |
Configure the destination and source IP addresses of keepalive packets. |
N/A |
interface Twenty-FiveGigE1/0/11 |
Enter the view of the interface used for setting up the keepalive link. |
N/A |
port link-mode route |
Configure the keepalive link interface to operate in route mode as a Layer 3 interface. |
N/A |
ip address 221.1.2.1 24 |
ip address 221.1.2.2 24 |
Assign an IP address to the keepalive link interface. |
N/A |
quit |
quit |
Return to system view. |
N/A |
m-lag mad exclude interface Twenty-FiveGigE1/0/11 |
Exclude the interface used for M-LAG keepalive detection from the shutdown action by M-LAG MAD. |
N/A |
interface HundredGigE1/0/28 |
Enter Ethernet interface view. |
N/A |
Configure the Ethernet interface to operate in route mode as a Layer 3 interface. |
N/A |
ip address 11.2.1.2/24 |
ip address 11.3.1.2/24 |
Assign an IP address to the interface. |
N/A |
quit |
quit |
N/A |
interface HundredGigE1/0/29 |
N/A |
N/A |
ip address 12.2.1.2/24 |
ip address 12.3.1.2/24 |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface HundredGigE1/0/28 |
Exclude an interface-facing a peer M-LAG system from the shutdown action by M-LAG MAD. |
N/A |
m-lag mad exclude interface HundredGigE1/0/29 |
N/A |
interface bridge-aggregation 1000 |
Create the Layer 2 aggregate interface to be used as the peer-link interface and enter Layer 2 aggregate interface view. |
N/A |
quit |
quit |
N/A |
Interface HundredGigE 1/0/26 |
interface HundredGigE 1/0/26 |
Enter the view of a physical interface used for setting up the peer link. |
N/A |
port link-aggregation group 1000 |
Assign the physical interface to the aggregation group of the peer link. |
N/A |
quit |
quit |
N/A |
Enter the view of the aggregation group for the peer link. |
N/A |
undo mac-address static source-check enable |
Disable source MAC check on the interface. |
N/A |
link-aggregation mode dynamic |
Configure the peer-link aggregate interface to operate in dynamic mode. |
N/A |
port m-lag peer-link 1 |
Specify the aggregate interface as the peer-link interface. |
N/A |
quit |
quit |
N/A |
interface bridge-aggregation 1 |
Create an aggregate interface. |
N/A |
Configure the aggregate interface to operate in dynamic mode. |
N/A |
port m-lag group 1 |
Assign the aggregate interface to M-LAG group 1. |
N/A |
quit |
quit |
N/A |
interface HundredGigE1/0/30 |
N/A |
port link-aggregation group 1 |
Assign the interface to the aggregation group of an M-LAG interface. |
N/A |
quit |
quit |
N/A |
Configuring Device C and Device D
Device C |
Device D |
Remarks |
m-lag system-mac 1-1-1 |
m-lag system-priority 121 |
N/A |
m-lag keepalive ip destination 220.1.1.2 source 220.1.1.1 |
m-lag keepalive ip destination 220.1.1.1 source 220.1.1.2 |
N/A |
interface HundredGigE1/0/6 |
N/A |
N/A |
ip address 220.1.1.1 24 |
ip address 220.1.1.2 24 |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface HundredGigE1/0/6 |
N/A |
interface HundredGigE1/0/4 |
N/A |
N/A |
ip address 11.2.1.1/24 |
ip address 11.3.1.1/24 |
N/A |
quit |
quit |
N/A |
interface HundredGigE1/0/5 |
N/A |
N/A |
ip address 12.2.1.1/24 |
ip address 12.3.1.1/24 |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface HundredGigE1/0/4 |
N/A |
m-lag mad exclude interface HundredGigE1/0/5 |
N/A |
N/A |
quit |
quit |
N/A |
Interface HundredGigE 1/0/8 |
interface HundredGigE 1/0/8 |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
Configure the aggregate interface as the peer-link interface. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
interface HundredGigE 1/0/7 |
N/A |
N/A |
quit |
quit |
N/A |
Device A |
Device B |
vlan 20 |
vlan 20 |
Create VLAN 20. |
Enter aggregate interface view. |
port link-type trunk |
Set the link type of the Layer 2 aggregate interface to trunk. |
port trunk permit vlan 20 |
Assign the interface to VLAN 20. |
undo port trunk permit vlan 1 |
Remove the interface from VLAN 1. |
quit |
quit |
interface vlan-interface 20 |
Create VLAN-interface 20. |
ip address 20.1.1.1 255.255.255.0 |
Assign an IPv4 address to VLAN-interface 20. |
mac-address 0020-0020-0020 |
Assign a MAC address to VLAN-interface 20. |
quit |
quit |
m-lag mad exclude interface Vlan-interface20 |
Exclude VLAN-interface 20 from the shutdown action by M-LAG MAD. |
vlan 21 |
Create VLAN 21. |
interface Twenty-FiveGigE1/0/1 |
Set the link type of the interface to trunk. |
port trunk permit vlan 21 |
Assign the interface to VLAN 21. |
quit |
interface vlan-interface 21 |
Create VLAN-interface 21. |
ip address 21.1.1.1 255.255.255.0 |
Assign an IPv4 address to VLAN-interface 21. |
mac-address 0020-0020-0021 |
Assign a MAC address to VLAN-interface 21. |
quit |
m-lag mad exclude interface Vlan-interface21 |
Exclude VLAN-interface 21 from the shutdown action by M-LAG MAD. |
Device C |
Device D |
vlan 10 |
vlan 10 |
Create VLAN 10. |
port trunk permit vlan 10 |
Assign the interface to VLAN 10. |
quit |
quit |
interface vlan-interface 10 |
Create VLAN-interface 10. |
ip address 10.1.1.1 255.255.255.0 |
Assign an IPv4 address to VLAN-interface 10. |
mac-address 0010-0010-0010 |
Assign a MAC address to VLAN-interface 10. |
quit |
quit |
m-lag mad exclude interface Vlan-interface10 |
Exclude VLAN-interface 10 from the shutdown action by M-LAG MAD. |
Device A |
Device B |
multicast routing |
multicast routing |
Enable IP multicast routing. |
igmp-snooping |
igmp-snooping |
Enable IGMP snooping. |
Vlan 20 |
Vlan 20 |
Enter VLAN view. |
igmp-snooping enable |
Enable IGMP snooping in the VLAN. |
Enable VLAN interface view. |
pim sm |
pim sm |
Enable PIM SM. |
igmp enable |
igmp enable |
Enable IGMP. |
pim distributed-dr |
Configure the interface as a DR interface to forward multicast traffic. This command is not supported by the S12500X-AF, S12500F-AF, or S6890 switches. |
pim passive |
pim passive |
Enable PIM passive mode for the interface to forward multicast traffic. Execute this command only on the S12500X-AF, S12500F-AF, or S6890 switch. |
quit |
quit |
Return to the upper-level view. |
pim sm |
Enable PIM SM. |
igmp enable |
Enable IGMP. |
quit |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
interface LoopBack0 |
Enter loopback interface view. |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
pim |
pim |
Enter PIM view. |
static-rp 4.4.4.4 |
static-rp 4.4.4.4 |
Configure a static RP. |
Device C |
Device D |
multicast routing |
multicast routing |
igmp-snooping |
igmp-snooping |
Vlan 10 |
Vlan 10 |
Enter VLAN view. |
quit |
quit |
pim sm |
pim sm |
Enable PIM SM. |
pim passive |
pim passive |
quit |
quit |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
pim sm |
pim sm |
Enable PIM SM. |
quit |
quit |
pim |
pim |
Enter PIM view. |
static-rp 4.4.4.4 |
static-rp 4.4.4.4 |
Traffic forwarding models
The forwarding model matrix provides the following characteristics of underlay traffic:
· No.—Traffic number in the U-X-XXX format:
¡ U—Underlay traffic.
¡ X—Protocol number, which can be 4 (IPv4)
¡ XXX—Traffic sequence number.
· Traffic type—Type of underlay traffic, which can only be IPv4 known multicast
· Direction—Direction of underlay traffic. The value is south-north, which indicates traffic from the south to north.
· Forwarding path—Nodes that underlay traffic traverses.
· Traffic simulation—Traffic simulation method. Typically, a tester is used to simulate server traffic.
· Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
· Traffic direction to firewalls/LB—No firewalls or LBs are used in this example. This field is not involved.
Forwarding models
No. |
Traffic type |
Direction |
Forwarding path |
Traffic simulation |
Load |
Traffic direction to firewalls/LB |
U-4-101 |
IPv4 known multicast |
South-north |
100 multicast groups Source > Device C and Device D > Device A and Device B > Receiver 2 |
Tester |
Light |
N/A |
U-4-102 |
IPv4 known mutlicsat |
South-north |
100 multicast groups Source > Device C and Device D > Device A and Device B > Receiver 1 |
Tester |
Light |
N/A |
Table 1 Network convergence upon single points of failure
Device |
Failure type |
Traffic interruption time (U-4-101/U-4-102) |
M-LAG |
Multicast source-side single point of failure on M-LAG member links |
≤ 100 ms |
Multicast source-side single point of failure restored on M-LAG member links |
≤ 100 ms |
Multicast source-side peer link failure |
≤ 500 ms |
Multicast source-side peer link failure restored |
≤ 100 ms |
Multicast source-side keepalive link failure |
0 ms |
Multicast source-side keepalive link failure restored |
0 ms |
Multicast source-side keepalive link and peer link failure |
≤ 500 ms |
Multicast source-side keepalive link and peer link failure restored |
≤ 500 ms |
Single ECMP link failure between the M-LAG systems |
≤ 500 ms/1000 ms |
Single ECMP link restored between the M-LAG systems |
≤ 100 ms |
Multicast-receiver side single point of failure on M-LAG member links |
≤ 100 ms/0 ms |
Multicast-receiver side single point of failure restored on M-LAG member links |
≤ 100 ms/0 ms |
Multicast-receiver side peer link failure |
≤ 100 ms/0 ms |
Multicast-receiver side peer link failure restored |
≤ 100 ms/0 ms |
Multicast-receiver side keepalive link failure |
0 ms |
Multicast-receiver side keepalive link failure restored |
0 ms |
Multicast-receiver side keepalive link and peer link failure |
≤ 500 ms/0 ms |
Multicast-receiver side keepalive link and peer link restored |
≤ 500 ms/0 ms |
Upgrade |
≤ 10000 ms (upgrade the M-LAG member devices one after another) |
Hardware replacement |
Fixed-port device replacement: ≤ 10000 ms |
Verify that the M-LAG system is working correctly on Device A and Device B. Use Device A as an example. The verification procedure is the same for Device B, Device C, and Device D.
# Display summary information about the peer-link interface and M-LAG interface.
[Device A]display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
Peer-link interface: BAGG1000
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
M-LAG interface information
M-LAG IF M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG1 1 UP UP -
# Verify that keepalive link is working correctly.
[Device A]display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 256 s 620 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 221.1.2.2
Time: 2023/06/13 05:00:51
Action: Accept
M-LAG keepalive parameters:
Destination IP address: 221.1.2.2
Source IP address: 221.1.2.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
# Display the M-LAG system information.
[Device A]display m-lag system
System information
Local system number: 1 Peer system number: 2
Local system MAC: 0001-0001-0002 Peer system MAC: 0001-0001-0002
Local system priority: 122 Peer system priority: 122
Local bridge MAC: dcda-8037-2bc0 Peer bridge MAC: bc22-4720-d5b9
Local effective role: Secondary Peer effective role: Primary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: No
System timer information
Timer State Value (s) Remaining time (s)
Auto recovery Disabled - -
Restore delay Disabled 60 -
Consistency-check delay Disabled 30 -
Standalone delay Disabled 0 -
Role to None delay Disabled 60 -
# Display detailed information about the peer-link interface and M-LAG interfaces.
[Device A]display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1000/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE1/0/26 (30)
Peer Selected ports indexes: 225
M-LAG interface/M-LAG group ID: BAGG1/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0002
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0002
Local M-LAG interface LACP priority: Config=32768, Effective=122
Peer M-LAG interface LACP priority: Config=32768, Effective=122
Local Selected ports (index): HGE1/0/30 (50)
Peer Selected ports indexes: 245
# Verify that PIM neighbor relationships are established correctly.
[Device A]display pim neighbor
Total Number of Neighbors = 3
Neighbor Interface Uptime Expires DR-Priority Mode
221.1.2.2 WGE1/0/11 00:06:12 00:01:37 1 P
11.2.1.1 HGE1/0/28 2d:00h 00:01:44 1 P
12.2.1.1 HGE1/0/29 00:15:52 00:01:44 1 P
[Device B]display pim neighbor
221.1.2.1 WGE1/0/11 00:06:40 00:01:35 1 P
11.3.1.1 HGE1/0/28 2d:00h 00:01:44 1 P
12.3.1.1 HGE1/0/29 2d:00h 00:01:32 1 P
[Device C]display pim neighbor
11.2.1.2 HGE1/0/4 2d:00h 00:01:42 1 P
11.3.1.2 HGE1/0/5 2d:00h 00:01:27 1 P
220.1.1.2 HGE1/0/6 00:19:34 00:01:37 1 P
[Device D]display pim neighbor
12.2.1.2 HGE1/0/4 00:16:32 00:01:26 1 P
12.3.1.2 HGE1/0/5 2d:00h 00:01:20 1 P
220.1.1.1 HGE1/0/6 00:19:38 00:01:26 1 P
# Verify that multicast forwarding entries are created correctly.
[Device A]dis igmp group
IGMP groups in total: 200
Vlan-interface20(20.1.1.1):
IGMP groups reported in total: 100
Group address Last reporter Uptime Expires
225.0.0.1 20.1.1.2 00:07:34 00:03:04
225.0.0.2 20.1.1.2 00:07:26 00:03:03
225.0.0.3 20.1.1.2 00:07:30 00:03:07
225.0.0.98 20.1.1.2 00:07:28 00:03:07
225.0.0.99 20.1.1.2 00:07:27 00:03:10
225.0.0.100 20.1.1.2 00:07:26 00:03:06
Vlan-interface21(21.1.1.1):
226.0.0.1 21.1.1.2 00:32:50 00:04:17
226.0.0.2 21.1.1.2 00:32:50 00:02:12
226.0.0.3 21.1.1.2 00:32:50 00:02:12
226.0.0.98 21.1.1.2 00:32:50 00:04:15
226.0.0.99 21.1.1.2 00:32:50 00:04:18
226.0.0.100 21.1.1.2 00:32:50 00:02:11
# Verify that PIM routing entries are created correctly.
[Device A]dis pim routing-table
Total 200 (*, G) entries; 200 (S, G) entries
(*, 225.0.0.1)
RP: 4.4.4.4
Protocol: pim-sm, Flag: WC
UpTime: 00:08:57
Upstream interface: HundredGigE1/0/29
Upstream neighbor: 12.2.1.1
RPF prime neighbor: 12.2.1.1
Downstream interface information:
1: Vlan-interface20
Protocol: igmp, UpTime: 00:08:57, Expires: -
(10.1.1.2, 225.0.0.1)
RP: 4.4.4.4
Protocol: pim-sm, Flag: SPT ACT 2MVPN
UpTime: 00:41:07
1: Vlan-interface20
Protocol: pim-sm, UpTime: 00:08:57, Expires: -
(*, 226.0.0.1)
RP: 4.4.4.4
UpTime: 00:34:27
1: Vlan-interface21
Protocol: igmp, UpTime: 00:34:27, Expires: -
(10.1.1.2, 226.0.0.1)
RP: 4.4.4.4
UpTime: 00:37:01
1: Vlan-interface21
Protocol: pim-sm, UpTime: 00:34:27, Expires: -
[Device B]display pim routing-table
Total 200 (*, G) entries; 201 (S, G) entries
(*, 225.0.0.1)
RP: 4.4.4.4 (local)
UpTime: 00:15:09
Upstream interface: Register-Tunnel0
Upstream neighbor: NULL
RPF prime neighbor: NULL
Total number of downstream interfaces: 2
1: HundredGigE1/0/29
Protocol: pim-sm, UpTime: 00:10:02, Expires: 00:03:28
2: Vlan-interface20
Protocol: igmp, UpTime: 00:15:09, Expires: -
RP: 4.4.4.4 (local)
Protocol: pim-sm, Flag: SPT 2MSDP ACT 2MVPN
UpTime: 00:44:11
Upstream neighbor: 12.3.1.1
RPF prime neighbor: 12.3.1.1
1: Vlan-interface20
Protocol: pim-sm, UpTime: 00:15:09, Expires: -
(*, 226.0.0.1)
RP: 4.4.4.4 (local)
UpTime: 00:23:10
Protocol: pim-sm, UpTime: 00:20:31, Expires: 00:02:58
RP: 4.4.4.4 (local)
Protocol: pim-sm, Flag: RPT 2MSDP ACT 2MVPN
UpTime: 00:45:34
Downstream interface information: None
Upgrading the devices
Checking the environment
Execute the commands in "Verifying the configuration" and the following commands to verify that the devices are available for an upgrade.
M-LAG 1 |
M-LAG 2 |
display device |
display device |
Displays device information. |
display boot-loader |
Displays current software images and startup software images. |
display version |
display version |
Displays system version information. |
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
See "Testing network convergence upon single points of failure."
Verifying the upgrade result
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is upgraded successfully.
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Replacing a service module
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for a replacement.
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Switch service and management traffic on the target service module to other service modules.
Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
For more information, see "Testing network convergence upon single points of failure."
Verifying the replacement result
Execute the commands in "Checking the environment."
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
Replace a device
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Example: Setting up two cascaded M-LAG systems with multicast source and receivers attached via intermediate devices
To improve network reliability, set up a two-tier cascaded M-LAG structure to support Layer 3 multicast services, as shown in Figure 2. The receivers receive video-on-demand traffic through multicast. PIM protocol is enabled on each device interface, and the entire PIM domain uses SM non-administrative domain mode.
Configure M-LAG dual-active gateways, and run the OSPF protocol in the network to establish dynamic routing neighbors between the two-tier cascaded M-LAG systems and between the M-LAG systems and user-side devices. OSPF reduces the difficulty of network operation and enhances flexible deployment capabilities.
Enable M-LAG standalone mode and set the priority of aggregate interfaces for the following purposes:
· When an access link fails, traffic can be quickly switched to another link to ensure reliability.
· The two access links can forward user traffic simultaneously to increase bandwidth, and traffic load can be shared between the two access links.
· If multiple link failures cause an M-LAG system to split, M-LAG switches to standalone mode. Only the designated device forwards business traffic to avoid abnormal traffic forwarding.
IP address |
Device A |
HGE1/0/25 |
IPv4: 221.1.3.1/24 |
Device B: HGE1/0/25 |
Vlan-int10 |
IPv4: 10.1.1.1/24 |
Device F: Vlan-int10 |
Vlan-int20 |
IPv4: 20.1.1.1/24 |
Device C and Device D: Vlan-int20 |
Loopback0 |
IPv4: 5.5.5.5/32 |
N/A |
Device B |
HGE1/0/25 |
IPv4: 221.1.3.2/24 |
Device A: HGE1/0/25 |
Vlan-int10 |
IPv4: 10.1.1.1/24 |
Vlan-int20 |
IPv4: 20.1.1.1/24 |
Loopback0 |
IPv4: 6.6.6.6/32 |
N/A |
Device C |
HGE1/0/25 |
Device D: HGE1/0/25 |
Vlan-int20 |
IPv4: 20.1.1.2/24 |
Device A and Device B: Vlan-int20 |
Vlan-int30 |
IPv4: 30.1.1.1/24 |
Device E: Vlan-int30 |
Loopback0 |
IPv4: 3.3.3.3/32 |
N/A |
Device D |
HGE1/0/25 |
Device C: HGE1/0/25 |
Vlan-int20 |
IPv4: 20.1.1.2/24 |
Vlan-int30 |
IPv4: 30.1.1.1/24 |
Loopback0 |
IPv4: 4.4.4.4/32 |
N/A |
Device E |
Vlan-int30 |
IPv4: 30.1.1.3/24 |
Device C and Device D: Vlan-int30 |
Vlan-int40 |
IPv4: 40.1.0.1/16 |
N/A |
Loopback0 |
IPv4: 1.1.1.1/32 |
N/A |
Device F |
Vlan-int10 |
IPv4: 10.1.1.2/24 |
Device A and Device B: Vlan-int10 |
Vlan-int50 |
IPv4: 50.1.1.1/24 |
N/A |
Loopback0 |
IPv4: 2.2.2.2/32 |
N/A |
Device |
Software version |
S6805/S6825/S6850/S9850 |
R6710 |
S9820-64H/S9820-8C |
Not supported |
S6800/S6860/S6900 |
Not supported |
S12500X-AF/S12500F-AF/S6890 |
R2825 |
S12500R |
Not supported |
S12500G-AF |
R7625 |
S6812/S6813 |
F6628P22 |
Analysis
· Create one VLAN interface for the same VLAN on Device A and Device B, respectively. In this example, create VLAN-interface 10. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
· Create one VLAN interface for the same VLAN on Device C and Device D, respectively. In this example, create VLAN-interface 20. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
· Assign M-LAG virtual IP addresses to the VLAN interfaces for the M-LAG member devices to set up OSPF neighbor relationships among them and with Device E and Device F.
· Enable IP multicast forwarding and IGMP snooping on Device A through Device F. A device with IGMP snooping enabled forwards multicast traffic of known multicast groups to the designated receivers instead of broadcasting the multicast traffic. Configure PIM on interfaces of the devices.
Procedure summary
· Configuring OSPF for establishing Layer 3 connectivity between M-LAG member devices
Configuring M-LAG
Device A |
Device B |
Remarks |
m-lag system-mac 5-5-5 |
m-lag system-priority 123 |
N/A |
m-lag keepalive ip destination 221.1.3.2 source 221.1.3.1 |
m-lag keepalive ip destination 221.1.3.1 source 221.1.3.2 |
N/A |
interface HundredGigE 1/0/25 |
N/A |
N/A |
ip address 221.1.3.1 24 |
ip address 221.1.3.2 24 |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface HundredGigE 1/0/25 |
N/A |
interface bridge-aggregation 3 |
N/A |
quit |
quit |
N/A |
N/A |
port link-aggregation group 3 |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
interface bridge-aggregation 2 |
N/A |
N/A |
port m-lag group 2 |
Assign the aggregate interface to M-LAG group 2. |
N/A |
quit |
quit |
N/A |
interface range HundredGigE 1/0/27 HundredGigE 1/0/29 |
N/A |
N/A |
quit |
quit |
N/A |
interface HundredGigE 1/0/30 |
N/A |
port link-aggregation group 2 |
N/A |
quit |
quit |
N/A |
Device C |
Device D |
Remarks |
m-lag system-mac 3-3-3 |
m-lag system-mac 3-3-3- |
N/A |
m-lag keepalive ip destination 221.1.2.1 source 221.1.1.2 |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
interface undredGigE 1/0/30 |
Enter the view of the interface connecting to Device A and Device B. |
N/A |
N/A |
quit |
quit |
N/A |
Device A |
Device B |
Remarks |
vlan 10 20 |
vlan 10 20 |
Create VLAN 10 and VLAN 20. |
N/A |
N/A |
N/A |
N/A |
N/A |
port lacp system-priority 101 |
port lacp system-priority 100 |
Set the LACP priority. |
Set different LACP priorities for different M-LAG member devices, so that only member ports with a higher priority are selected upon brain split. |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Assign an IPv4 address to VLAN-interface 10. The VLAN interface will act as a dual-active gateway interface. |
N/A |
mac-address 0010-0010-0070 |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface vlan-interface10 |
N/A |
N/A |
N/A |
mac-address 0010-0010-0071 |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface vlan-interface20 |
N/A |
Device C |
Device D |
Remarks |
vlan 20 30 |
vlan 20 30 |
Create VLAN 20 and VLAN 30. |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
port trunk permit vlan 30 |
Assign the interface to VLAN 30. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
ip address 20.1.1.2 255.255.255.0 |
Assign an IPv4 address to VLAN-interface 20. The VLAN interface will act as a dual-active gateway interface. |
N/A |
mac-address 0010-0010-0080 |
N/A |
quit |
quit |
N/A |
N/A |
interface vlan-interface 30 |
Create VLAN-interface 30. |
N/A |
ip address 30.1.1.1 255.255.255.0 |
Assign an IPv4 address to VLAN-interface 30. |
N/A |
mac-address 0010-0010-0081 |
Assign a MAC address to VLAN-interface 30. |
N/A |
quit |
quit |
N/A |
m-lag mad exclude interface vlan-interface30 |
Exclude VLAN-interface 30 from the shutdown action by M-LAG MAD. |
N/A |
Device A |
Device B |
Remarks |
router id 5.5.5.5 |
router id 6.6.6.6 |
Configure a router ID. |
N/A |
ospf 1 |
ospf 1 |
Enable an OSPF process. |
N/A |
area 0 |
area 0 |
Configure an OSPF area. |
N/A |
quit |
quit |
N/A |
Enter VLAN interface view. |
N/A |
port m-lag virtual-ip 10.1.1.100 255.255.255.0 active |
port m-lag virtual-ip 10.1.1.101 255.255.255.0 active |
Assign an M-LAG virtual IP address to the VLAN interface. |
The IPv4 address is used to set up an OSPF neighbor relationship with Device F. |
ospf 1 area 0.0.0.0 |
Enable OSPF on the interface. |
N/A |
ospf peer sub-address enable 10.1.1.100 |
ospf peer sub-address enable 10.1.1.101 |
Enable OSPF to establish neighbor relationships through the secondary IP addresses of the interface. |
Because the same gateway interface on different M-LAG member devices use the same IP address and MAC address, the M-LAG member devices cannot establish a routing neighbor relationship with other devices by using their primary IP addresses. You must enable OSPF to establish neighbor relationships through the secondary IP addresses of the interface. |
quit |
quit |
N/A |
N/A |
port m-lag virtual-ip 20.1.1.100 255.255.255.0 active |
port m-lag virtual-ip 20.1.1.101 255.255.255.0 active |
The IPv4 address is used to set up OSPF neighbor relationships with Device C and Device D. |
N/A |
ospf peer sub-address enable 20.1.1.100 |
ospf peer sub-address enable 20.1.1.101 |
quit |
quit |
N/A |
Device C |
Device D |
Remarks |
router id 3.3.3.3 |
router id 4.4.4.4 |
N/A |
ospf 1 |
ospf 1 |
N/A |
area 0 |
area 0 |
N/A |
quit |
quit |
N/A |
N/A |
port m-lag virtual-ip 20.1.1.102 255.255.255.0 active |
port m-lag virtual-ip 20.1.1.103 255.255.255.0 active |
The IPv4 address is used to set up OSPF neighbor relationships with Device A and Device B. |
N/A |
ospf peer sub-address enable 20.1.1.102 |
ospf peer sub-address enable 20.1.1.103 |
quit |
quit |
N/A |
N/A |
port m-lag virtual-ip 30.1.1.100 255.255.255.0 active |
port m-lag virtual-ip 30.1.1.101 255.255.255.0 active |
N/A |
ospf peer sub-address enable 30.1.1.100 |
ospf peer sub-address enable 30.1.1.101 |
quit |
quit |
N/A |
Configuring Device E
Device E |
router id 1.1.1.1 |
ospf 1 |
area 0 |
network 30.1.1.0 0.0.0.255 |
Enable OSPF for a network. |
network 40.1.0.0 0.0.255.255 |
quit |
Configuring Device F
Device F |
router id 2.2.2.2 |
ospf 1 |
area 0 |
network 10.1.1.0 0.0.0.255 |
network 50.1.1.0 0.0.0.255 |
quit |
Device A |
Device B |
multicast routing |
multicast routing |
igmp-snooping |
igmp-snooping |
Vlan 10 |
Vlan 10 |
N/A |
Vlan 20 |
Vlan 20 |
N/A |
pim sm |
pim sm |
Enable PIM SM. |
(Optional.) Configure the interface as a DR interface to forward multicast traffic. This command is not supported by the S12500X-AF, S12500F-AF, or S6890 switches. |
pim passive |
pim passive |
(Optional.) Enable PIM passive mode for the interface to forward multicast traffic. Execute this command only on the S12500X-AF, S12500F-AF, or S6890 switch. |
quit |
quit |
N/A |
pim sm |
pim sm |
Enable PIM SM. |
pim passive |
pim passive |
quit |
quit |
N/A |
pim |
pim |
Enter PIM view. |
static-rp 5.5.5.5 |
static-rp 5.5.5.5 |
Device C |
Device D |
multicast routing |
multicast routing |
igmp-snooping |
igmp-snooping |
Vlan 20 |
Vlan 20 |
N/A |
Vlan 30 |
Vlan 30 |
N/A |
pim sm |
pim sm |
Enable PIM SM. |
pim passive |
pim passive |
quit |
quit |
N/A |
pim sm |
pim sm |
Enable PIM SM. |
pim passive |
pim passive |
quit |
quit |
N/A |
pim |
pim |
Enter PIM view. |
static-rp 5.5.5.5 |
static-rp 5.5.5.5 |
Device E |
multicast routing |
igmp-snooping |
Vlan 30 |
N/A |
Vlan 40 |
N/A |
pim sm |
Enable PIM SM. |
quit |
N/A |
interface vlan-interface40 |
pim sm |
Enable PIM SM. |
igmp enable |
Enable IGMP. |
quit |
N/A |
Device F |
multicast routing |
igmp-snooping |
Vlan 10 |
N/A |
Vlan 50 |
N/A |
pim sm |
Enable PIM SM. |
quit |
N/A |
interface vlan-interface50 |
pim sm |
Enable PIM SM. |
quit |
N/A |
¡ X—Protocol number, which can be 4 (IPv4).
· Traffic type—Type of underlay traffic, which can only be IPv4 known unicast
Forwarding models
No. |
Traffic type |
Direction |
Forwarding path |
Load |
U-4-101 |
South-north |
Device F > Device A and Device B > Device C and Device D > Device E |
Tester |
Light |
N/A |
Table 2 Network convergence upon single points of failure
Device |
Failure type |
Traffic interruption time |
M-LAG |
Single point of failure on M-LAG member links |
≤ 100 ms |
Single point of failure restored on M-LAG member links |
≤ 100 ms |
Peer link failure |
≤ 500 ms |
Peer link failure restored |
≤ 100 ms |
Keepalive link failure |
0 ms |
Keepalive link failure restored |
0 ms |
Keepalive link and peer link failure |
≤ 1000 ms |
Keepalive link and peer link restored |
≤ 10000 ms |
Upgrading the devices |
Replacing hardware |
Fixed-port device: ≤ 10000 ms |
[DeviceA]display m-lag summary
Peer-link interface: BAGG3
BAGG1 1 UP UP -
BAGG2 2 UP UP -
[DeviceA]display m-lag keepalive
Neighbor is alive for: 102480 s 811 ms
Sent: Successful
Source IP address: 221.1.3.2
Time: 2023/02/16 19:28:27
Action: Accept
Destination IP address: 221.1.3.2
Source IP address: 221.1.3.1
[DeviceA]display m-lag system
System information
Local system MAC: 0001-0001-0003 Peer system MAC: 0001-0001-0003
Local system priority: 123 Peer system priority: 123
Local bridge MAC: 00ec-fc00-050a Peer bridge MAC: 00ec-fc00-050b
Local effective role: Primary Peer effective role: Secondary
Health level: 0
[DeviceA]display m-lag verbose
Peer-link interface/Peer-link interface ID: BAGG3/1
State: UP
Cause: -
Local Selected ports (index): HGE1/0/26 (25)
Peer Selected ports indexes: 220
Local M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0003
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0003
Local M-LAG interface LACP priority: Config=32768, Effective=123
Peer M-LAG interface LACP priority: Config=32768, Effective=123
Local Selected ports (index): HGE1/0/27 (26), HGE1/0/30 (37)
Peer Selected ports indexes: 221, 232
M-LAG interface/M-LAG group ID: BAGG2/2
Local Selected ports (index): HGE1/0/30 (6)
Peer Selected ports indexes: 238
# Verify that OSPF neighbor relationships are correctly set up.
[DeviceA]dis ospf peer
OSPF Process 1 with Router ID 5.5.5.5
Neighbor Brief Information
Area: 0.0.0.0
Router ID Address Pri Dead-Time State Interface
6.6.6.6 20.1.1.101 1 36 Full/BDR Vlan20
3.3.3.3 20.1.1.102 1 38 Full/DROther Vlan20
4.4.4.4 20.1.1.103 1 36 Full/DROther Vlan20
2.2.2.2 10.1.1.2 1 34 Full/BDR Vlan10
6.6.6.6 10.1.1.101 1 37 Full/DROther Vlan10
[DeviceB]display ospf peer
OSPF Process 1 with Router ID 6.6.6.6
Area: 0.0.0.0
5.5.5.5 20.1.1.100 1 32 Full/DR Vlan20
3.3.3.3 20.1.1.102 1 36 Full/DROther Vlan20
4.4.4.4 20.1.1.103 1 34 Full/DROther Vlan20
2.2.2.2 10.1.1.2 1 32 Full/BDR Vlan10
5.5.5.5 10.1.1.100 1 36 Full/DR Vlan10
[DeviceC]display ospf peer
Area: 0.0.0.0
1.1.1.1 30.1.1.3 1 39 Full/DR Vlan30
4.4.4.4 30.1.1.101 1 38 Full/DROther Vlan30
5.5.5.5 20.1.1.100 1 38 Full/DR Vlan20
6.6.6.6 20.1.1.101 1 39 Full/BDR Vlan20
4.4.4.4 20.1.1.103 1 39 2-Way/ - Vlan20
[DeviceD]display ospf peer
OSPF Process 1 with Router ID 4.4.4.4
Area: 0.0.0.0
1.1.1.1 30.1.1.3 1 36 Full/DR Vlan30
3.3.3.3 30.1.1.100 1 38 Full/BDR Vlan30
5.5.5.5 20.1.1.100 1 35 Full/DR Vlan20
3.3.3.3 20.1.1.102 1 39 2-Way/ - Vlan20
[DeviceE]dis ospf peer
Area: 0.0.0.0
3.3.3.3 30.1.1.100 1 39 Full/BDR Vlan30
4.4.4.4 30.1.1.101 1 37 Full/DROther Vlan30
[DeviceF]display ospf peer
Area: 0.0.0.0
5.5.5.5 10.1.1.100 1 37 Full/DR Vlan10
6.6.6.6 10.1.1.101 1 35 Full/DROther Vlan10
[DeviceA]display pim neighbor
Total Number of Neighbors = 2
20.1.1.2 Vlan20 08:24:02 00:01:33 1 P
10.1.1.2 Vlan10 1d:00h 00:01:30 1 P
[DeviceB]display pim neighbor
20.1.1.2 Vlan20 08:24:14 00:01:39 1 P
10.1.1.2 Vlan10 09:17:11 00:01:17 1 P
[DeviceC]display pim neighbor
30.1.1.3 Vlan30 02:13:33 00:01:24 1 P
20.1.1.1 Vlan20 02:13:32 00:01:43 1 P
[DeviceD]display pim neighbor
30.1.1.3 Vlan30 02:04:36 00:01:43 1 P
20.1.1.1 Vlan20 02:04:50 00:01:31 1 P
[DeviceE]display pim neighbor
Total Number of Neighbors = 1
30.1.1.1 Vlan30 03:16:01 00:01:33 1 P
[DeviceF]display pim neighbor
10.1.1.1 Vlan10 1d:00h 00:01:39 1 P
# Verify that multicast forwarding entries are generated.
<DeviceA> display multicast forwarding-table
Total 1 entries, 1 matched
00001. (10.1.1.2, 227.0.0.1)
Flags: 0x0
Incoming interface: Vlan-interface10
List of 1 outgoing interfaces:
1: Vlan-interface20
Matched 19648 packets(20512512 bytes), Wrong If 0 packet
<DeviceB> display multicast forwarding-table
Flags: 0x0
1: Vlan-interface20
<DeviceC> display multicast forwarding-table
Flags: 0x0
Incoming interface: Vlan-interface20
1: Vlan-interface30
<DeviceD> display multicast forwarding-table
Flags: 0x0
1: Vlan-interface30
# Verify that PIM multicast forwarding entries are generated.
<DeviceA> display pim routing-table
Total 0 (*, G) entries; 1 (S, G) entries
RP: 5.5.5.5
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: Vlan-interface10
1: Vlan-interface20
Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
<DeviceB> display pim routing-table
RP: 5.5.5.5
UpTime: 02:54:43
1: Vlan-interface20
<DeviceC> display pim routing-table
RP: 5.5.5.5
UpTime: 02:54:43
Upstream interface: Vlan-interface20
1: Vlan-interface30
<DeviceD> display pim routing-table
RP: 5.5.5.5
UpTime: 02:54:43
1: Vlan-interface30
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Replace a device
M-LAG 1 |
M-LAG 2 |
display device |
display device |
display version |
display version |
Replacing hardware
