15-WLAN Command Reference (AC)
HomeSupportReference GuidesCommand ReferencesH3C MSR810[2600][3600] Routers Command Reference(V7)-R0809-6W40115-WLAN Command Reference (AC)
15-WLAN RRM commands
15-WLAN RRM commands 185.19 KB
WLAN RRM commands
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
adjacent-channel interference trap threshold
Use adjacent-channel interference trap threshold to set the trap threshold for adjacent-channel interference.
Use undo adjacent-channel interference trap threshold to restore the default.
adjacent-channel interference trap threshold threshold
In RRM view, the configuration in an AP group's RRM view is used.
In an AP group's RRM view, the trap threshold for adjacent-channel interference is 60 dBm.
RRM view
AP group's RRM view
threshold: Specifies the trap threshold in the range of 10 to 90 dBm.
When the adjacent-channel interference exceeds the trap threshold, the system generates an SNMP notification to inform the network administrator.
# Set the trap threshold for adjacent-channel interference to 16 dBm for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rrm
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacent-channel interference trap threshold 16
# Set the trap threshold for adjacent-channel interference to 16 dBm for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] adjacent-channel interference trap threshold 16
co-channel interference trap threshold
adjacency-factor
Use adjacency-factor to set the adjacency factor.
Use undo adjacency-factor to restore the default.
adjacency-factor neighbor
In an AP group's RRM view, the adjacency factor is 3.
RRM view
AP group's RRM view
neighbor: Specifies the adjacency factor in the range of 1 to 16.
The adjacency factor defines the quantity of manageable detected radios that trigger TPC and the ranking of the RSSI used for comparison with the power adjustment threshold. An AC can manage only radios associated with it.
For example, if the adjacency factor is 3, the AC performs TPC for a radio when the radio detects 3 other manageable radios. After ranking the radio's RSSIs detected by other manageable radios in descending order, the AC selects the third largest RSSI to compare with the power adjustment threshold.
# Set the adjacency factor to 7 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor 7
# Set the adjacency factor to 7 for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] adjacency-factor 7
adjacency-factor radio-selection
Use adjacency-factor radio-selection to specify the type of radios to participate in TPC calculation.
Use undo adjacency-factor radio-selection to restore the default.
adjacency-factor radio-selection { all-channel | overlapping-channel }
In an AP group's RRM view, all-channel radios participate in TPC calculation.
RRM view
AP group's RRM view
all-channel: Specifies radios detected on all channels.
overlapping-channel: Specifies radios detected on overlapping channels.
Radios that can participate in the TPC calculation for a radio include the following types:
·     All-channel radios—Include all radios that detect the radio and are managed by the same AC as the radio. TPC based on all-channel radios can better control the signal coverage.
·     Overlapping-channel radios—Include radios that detect the radio on a channel overlapping with the radio's transmit channel and are managed by the same AC as the radio. TPC based on overlapping-channel radios can expand signal coverage without increasing interference.
# Specify the type of radios to participate in TPC calculation as overlapping-channel for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
# Specify the type of radios to participate in TPC calculation as overlapping-channel for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
ap name
Use ap name to add a radio to an RRM holddown group.
Use undo ap name to remove one or all radios from an RRM holddown group.
ap name ap-name radio radio-id
undo ap { name ap-name [ radio radio-id ] | all }
No radios exist in an RRM holddown group.
RRM holddown group view
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters, numbers, underlines (_), left brackets ([), right brackets (]), slashes (/), and hyphens (-). The specified AP must already exist.
radio radio-id: Specifies a radio by its ID. The value range for this argument varies by device model. If you do not specify this option when executing the undo command, the command deletes all radios of the specified AP from the group.
all: Specifies all radios.
A radio can belong to only one RRM holddown group. Adding a radio to a new RRM holddown group removes the radio from the old RRM holddown group.
# Add radio 2 of AP ap1 to RRM holddown group 10.
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rrm-calibration-group-10] ap name ap1 radio 2
calibrate-channel mode
Use calibrate-channel mode to set the auto-DFS mode.
Use undo calibrate-channel mode to restore the default.
calibrate-channel mode { periodic | scheduled }
In an AP group's RRM view, the auto-DFS mode is periodic.
RRM view
AP group's RRM view
periodic: Specifies periodic auto-DFS.
scheduled: Specifies scheduled auto-DFS.
In periodic auto-DFS mode, the AC automatically performs DFS for a radio at the channel calibration interval.
In scheduled auto-DFS mode, the AC performs DFS at the specified time in a time range. Use this mode when interference is severe to avoid affecting ongoing wireless services.
# Set the auto-DFS mode to scheduled for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode scheduled
# Set the auto-DFS mode to scheduled for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-channel self-decisive enable
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-channel mode scheduled
calibrate-channel monitoring time-range
calibrate-channel pronto
wlan rrm calibration-channel interval
Use calibrate-channel monitoring time-range to specify a time range for channel monitoring.
Use undo calibrate-channel monitoring time-range to delete the specified time range for channel monitoring.
calibrate-channel monitoring time-range time-range-name
In an AP group's RRM view, no time range is specified for channel monitoring.
RRM view
AP group's RRM view
time-range-name: Specifies the name of a time range, a case-insensitive string of 1 to 32 characters. The string must start with a letter and cannot be all.
In scheduled auto-DFS, the AC collects statistics in the specified time range to generate channel reports and neighbor reports.
# Specify a time range for channel monitoring for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel monitoring time-range time1
# Specify a time range for channel monitoring for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-channel monitoring time-range time1
time-range
Use calibrate-channel pronto to execute scheduled auto-DFS.
RRM view
AP group's RRM view
# Create a job and assign commands to the job for radio 1 of AP ap1.
[Sysname] scheduler job calibration1
[Sysname-job-calibration1] command 1 system-view
[Sysname-job-calibration1] command 2 wlan ap ap1
[Sysname-job-calibration1] command 3 radio 1
[Sysname-job-calibration1] command 4 rrm
[Sysname-job-calibration1] command 5 calibrate-channel pronto
# Create a job and assign commands to the job for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname] scheduler job calibration2
[Sysname-job-calibration2] command 1 system-view
[Sysname-job-calibration2] command 2 wlan ap-group g1
[Sysname-job-calibration2] command 3 ap-model WA4320i-ACN
[Sysname-job-calibration2] command 4 radio 1
[Sysname-job-calibration2] command 5 rrm
[Sysname-job-calibration2] command 6 calibrate-channel pronto
Use calibrate-channel self-decisive enable to enable auto-DFS.
Use calibrate-channel self-decisive disable to disable auto-DFS.
Use undo calibrate-channel self-decisive to restore the default.
calibrate-channel self-decisive { disable | enable }
In an AP group's RRM view, auto-DFS is disabled.
RRM view
AP group's RRM view
# Enable auto-DFS for radio 1 of AP ap1.
# Enable auto-DFS for radio 1 of APs with model WA4320i-ACN in AP group group1.
calibrate-power min
Use calibrate-power min to set the minimum transmit power for a radio after TPC is performed.
Use undo calibrate-power min to restore the default.
calibrate-power min tx-power
In an AP group's RRM view, the minimum transmit power of a radio is 1 dBm after TPC is performed.
RRM view
AP group's RRM view
tx-power: Specifies the minimum transmit power for a radio, in the range of 1 to 20 dBm.
This command ensures that the transmit power of a radio can still meet network requirements after TPC is performed.
# Set the minimum transmit power to 10 dBm for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power min 10
# Set the minimum transmit power to 10 dBm for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-power min 10
calibrate-power mode
Use calibrate-power mode to set the TPC mode.
Use undo calibrate-power mode to restore the default.
calibrate-power mode { coverage | custom | density }
In an AP group's RRM view, the TPC mode is custom.
RRM view
AP group's RRM view
coverage: Specifies the coverage mode.
custom: Specifies the custom mode.
density: Specifies the density mode.
To avoid interference among APs, use the density mode. To increase signal coverage performance, use the coverage mode. If these two modes cannot meet your network requirements, use the custom mode to customize power adjustment settings.
In either density or coverage mode, power adjustment settings are defined by the system and cannot be changed.
# Set the TPC mode to coverage for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power mode coverage
# Set the TPC mode to density for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-power mode density
calibrate-power self-decisive
Use calibrate-power self-decisive enable to enable periodic auto-TPC for the AC to perform TPC at the power calibration interval.
Use calibrate-power self-decisive disable to disable periodic auto-TPC.
Use undo calibrate-power self-decisive to restore the default.
calibrate-power self-decisive { disable | enable }
In an AP group's RRM view, periodic auto-TPC is disabled.
RRM view
AP group's RRM view
# Enable periodic auto-TPC for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power self-decisive enable
# Enable periodic auto-TPC for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-power self-decisive enable
wlan rrm calibration-power interval
calibrate-channel self-decisive sensitivity
Use calibrate-channel self-decisive sensitivity to set the DFS sensitivity mode.
Use calibrate-channel self-decisive sensitivity to restore the default.
calibrate-channel self-decisive sensitivity { custom | high | low | medium }
undo calibrate-channel self-decisive sensitivity
In an AP group's RRM view, the DFS sensitivity mode is custom.
RRM view
AP group's RRM view
custom: Specifies the custom sensitivity mode.
high: Specifies the high sensitivity mode.
low: Specifies the low sensitivity mode.
medium: Specifies the medium sensitivity mode.
DFS configured with a higher sensitivity can be triggered more easily.
DFS trigger parameters will be restored to the default if you change the sensitivity mode. The default settings vary by sensitivity mode. Record the configured DFS trigger parameters if necessary before you change the sensitivity mode from custom to low, medium, or high.
You can configure DFS trigger parameters only when the sensitivity mode is custom.
# Set the DFS sensitivity mode to low for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive sensitivity low
# Set the DFS sensitivity mode to high for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-channel self-decisive sensitivity high
crc-error-threshold
interference-threshold
tolerance-level
calibrate-channel suppression
Use calibrate-channel suppression enable to enable DFS suppression.
Use calibrate-channel suppression disable to disable DFS suppression.
Use undo calibrate-channel suppression to restore the default.
calibrate-channel suppression { disable | enable [ client-number number ] }
In an AP group's RRM view, DFS suppression is disabled.
RRM view
AP group's RRM view
client-number number: Specifies the online client threshold in the range of 1 to 124. The value is 124 by default.
This feature takes effect only when periodic auto-DFS is configured.
For wireless service stability, you can configure DFS suppression to suppress periodic auto-DFS when the online client quantity reaches the specified threshold.
# Enable DFS suppression  for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel suppression enable
# Disable DFS suppression for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-channel suppression disable
calibrate-power threshold
Use calibrate-power threshold to set the power adjustment threshold.
Use undo calibrate-power threshold to restore the default.
calibrate-power threshold value
In an AP group's RRM view, the power adjustment threshold is 65.
RRM view
AP group's RRM view
value: Specifies the power adjustment threshold in the range of 50 to 90. The value range indicates that the power of the radio is in the range of –90 dBm to –50 dBm.
As a best practice to avoid interference among radios, set the power adjustment threshold to –80 dBm for high-density WLANs.
# Set the power adjustment threshold to 70 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power threshold 70
# Set the power adjustment threshold to 70 for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] calibrate-power threshold 70
channel holddown-time
Use channel holddown-time to set the channel holddown time.
Use undo channel holddown-time to restore the default.
channel holddown-time minutes
The channel holddown time is 720 minutes.
minutes: Specifies the channel holddown time in the range of 10 to 1440 minutes.
Each time the channel of a radio in the RRM holddown group changes, the system starts the channel holddown timer for the radio. The channel for every radio in the RRM holddown group remains unchanged during the specified channel holddown time.
# Set the channel holddown time to 600 minutes for RRM holddown group 10.
[Sysname-wlan-rrm-calibration-group-10] channel holddown-time 600
channel-usage-threshold
Use channel-usage-threshold to set the channel usage threshold.
Use undo channel-usage-threshold to restore the default.
channel-usage-threshold percent percent
undo channel-usage-threshold percent
In an AP group's RRM view, the channel usage threshold is 60.
RRM view
AP group's RRM view
percent: Specifies the channel usage threshold in the range of 1 to 80.
When the AC detects that the actual channel usage on a radio reaches the channel usage threshold, it performs DFS for the radio.
# Set the channel usage threshold to 40 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] channel-usage-threshold percent 40
# Set the channel usage threshold to 40 for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] channel-usage-threshold percent 40
crc-error-threshold
Use co-channel interference trap threshold to set the trap threshold for co-channel interference.
Use undo co-channel interference trap threshold to restore the default.
co-channel interference trap threshold threshold
In an AP group's RRM view, the trap threshold for co-channel interference is 60 dBm.
RRM view
AP group's RRM view
When the co-channel interference exceeds the trap threshold, the system generates an SNMP notification to inform the network administrator.
# Set the trap threshold for co-channel interference to 16 dBm for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] co-channel interference trap threshold 16
# Set the trap threshold for co-channel interference to 16 dBm for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] co-channel interference trap threshold 16
crc-error-threshold
Use crc-error-threshold to set the CRC error threshold.
Use undo crc-error-threshold to restore the default.
crc-error-threshold percent
In an AP group's RRM view, the CRC error threshold is 20.
RRM view
AP group's RRM view
percent: Specifies the CRC error threshold in the range of 1 to 100.
When the AC detects that the proportion of CRC-error packets in all 802.11 packets reaches the CRC error threshold on a radio, it performs DFS for the radio.
# Set the CRC error threshold to 50 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] crc-error-threshold 50
# Set the CRC error threshold to 50 for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] crc-error-threshold 50
description
Use description to set a description for an RRM holddown group.
No description is set for an RRM holddown group.
text: Specifies the RRM holddown group description, a case-sensitive string of 1 to 64 characters.
# Set the description for RRM holddown group 10 to office.
[Sysname-wlan-rrm-calibration-group-10] description office
display wlan rrm baseline
Use display wlan rrm baseline to display radio baseline information.
display wlan rrm baseline { all | name baseline-name } [ verbose ]
all: Specifies all radio baselines.
name baseline-name: Specifies a radio baseline by its name, a case-insensitive string of 1 to 32 characters.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief radio baseline information.
You cannot display information about a radio baseline if you do not have the right to manage radios with the location identifier in the radio baseline.
# Display brief radio baseline information.
<Sysname> display wlan rrm baseline all
 Baseline name  : apbaseline
 Radio range    : AP
 Created at     : 2015-06-22 19:56:31
 Baseline name  : groupbaseline
 Radio range    : AP group
 Created at     : 2015-06-22 19:56:12
 Baseline name  : globalbaseline
 Radio range    : Global
 Created at     : 2015-06-22 19:55:12
Radio range
Range of radios saved in the baseline:
·     AP—Radios on an AP.
·     AP group—Radios on APs in an AP group.
·     Global—Radios on all APs associated with the AC.
Created at
Time and date when the baseline was created.
# Display detailed radio baseline information.
<Sysname> display wlan rrm baseline all verbose
 Radio range   : AP
 APName             RadioID RadioType Bandwidth Channel Power RegionCode
 ap1                2       dot11gn   20        13      20    CN
 ap1                1       dot11an   40        157     20    CN
 ap2                1       dot11an   40        149     20    CN
 ap1                1       dot11an   40        149     20    CN
 ap2                2       dot11gn   20        1       20    CN
Radio range
·     AP group—Radios on all APs in an AP group.
Created at
Power
Transmit power of the radio in dBm.
RegionCode
Region code of the AP.
display wlan rrm baseline apply-history
Use display wlan rrm baseline apply-history to display the history records of radio baseline application.
display wlan rrm baseline apply-history [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
This command displays information about the most recent ten baseline applications.
# Display the brief history records of radio baseline application.
<Sysname> display wlan rrm baseline apply-history
Applied at  : 2016-01-23   12:19:50
Applied to  : global
# Display the detailed history records of radio baseline application.
<Sysname> display wlan rrm baseline apply-history verbose
Applied to  : global
Radios      : 6
Success     : 4
Failure     : 2
Failure reason
  Radio doesn't exist           : 0
  Radio is down                 : 0
  Mismatching radio type        : 0
  Mismatching region code       : 1
  Ineffective service template  : 0
  Illegal channel               : 0
  Mismatching bandwidth         : 1
  Channel locked                : 0
  Channel fixed                 : 0
  Within channel holddown time  : 0
  Mismatching channel gap policy: 0
  Power locked                  : 0
  Within power holddown time    : 0
  Power lower than min. power   : 0
  Power greater than max. power : 0
Name
Radio baseline name.
Applied at
Time at which the radio baseline was applied.
Applied to
Radio baseline application range:
·     ap—Applied to an AP.
·     apgroup—Applied to an AP group.
·     global—Applied to all APs.
Radios
Number of radios in the radio baseline.
Success
Number of successful applications.
Failure
Number of failed applications.
The radio mode saved in the baseline does not match the actual radio mode.
The region code saved in the baseline does not match the actual region code of the AP.
No service template is bound to a radio in the baseline or the bound service template is disabled.
The channel in the baseline does not match the specified channel gap.
The transmit power in the baseline is lower than the specified minimum transmit power for the radio.
The transmit power in the baseline is higher than the specified maximum transmit power for the radio.
display wlan rrm-calibration-group
Use display wlan rrm-calibration-group to display RRM holddown group information.
display wlan rrm-calibration-group { all | group-id }
all: Specifies all RRM holddown groups.
group-id: Specifies an RRM holddown group by its IDin the range of 1 to 128.
# Display information about RRM holddown group 10.
<Sysname> display wlan rrm-calibration-group 10
          RRM Calibration Group Information
Group ID                : 10
Description             : office
Channel holddown time   : 720 minutes
Power holddown time     : 60 minutes
Location name           : default-location
Group members           : ap4-radio2, ap3-radio2
Group ID
ID of the RRM holddown group.
Description for the RRM holddown group.
Channel holddown time.
Power holddown time
Power holddown time.
Location name
Name of the location identifier assigned to the RRM holddown group.
Group members
Radios in the RRM holddown group.
display wlan rrm-history ap
Use display wlan rrm-history ap to display historical channel and power adjustment information.
display wlan rrm-history ap { all | name ap-name }
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The name can include letters, numbers, underscores (_), left brackets ([), right brackets (]), slashes (/), and minus signs (-).
You can use this command to display detailed information about the most recent three channel and power adjustments. The detailed information includes adjustment time, cause, power, and interference.
# Display historical channel and power adjustment information for radios of AP ap1.
<Sysname> display wlan rrm-history ap name ap1
                         AP RRM History
 Flags : I - Interference,   P - Packets discarded,    F - Retransmission,
         R - Radar,          C - Coverage,             O - Others
                         AP RRM History : ap1
 Radio : 1                                Basic BSSID : 000f-e2ff-7700
        Ch  Power Load Util Intf PER Retry Reason  Date         Time
            (dBm) (%)  (%)  (%)  (%) (%)           (yyyy-mm-dd) (hh:mm:ss)
 Before 6   20    24   2    21   11  18    -P----  2014-07-07   17:31:50
 After  1   20    9    0    8    0   27    -       -            -
 Before 1   20    54   1    53   11  15    IP----  2014-07-08   12:19:50
 After  6   20    10   0    10   3   29    -       -            -
 Before 6   20    29   1    28   21  20    -P----  2014-07-08   12:59:50
 After  1   20    30   0    29   2   24    -       -            -
Table 5 Command output
Radio
Radio ID.
Basic BSSID
Basic service set identifier.
Ch
Working channel of the radio.
Power
Transmit power of the radio.
Load
Channel load in percentage.
Util
Channel usage in percentage.
Intf
Interference detected on the channel, in percentage.
PER
Bit error rate detected on the channel, in percentage.
Retry
Retransmission rate detected on the channel, in percentage.
Reason
Channel or power adjustment reason.
Date
Channel or power adjustment date.
Time
Channel or power adjustment time.
display wlan rrm-status ap
Use display wlan rrm-status ap to display detailed RRM information.
display wlan rrm-status ap { all | name ap-name }
If both channel adjustment and power adjustment are disabled, this command displays only the working channel and power level for radios on the AP.
# Display detailed information about channel and power adjustments for radios of AP ap1.
<Sysname> display wlan rrm-status ap name ap1
                          AP RRM Profile : ap1
 Radio   : 1                              Basic BSSID    : 70f9-6d31-2fe0
 Channel : 157                            Tx Power (dBm) : 18
    Ch    Nbrs    Load    Util    Intf    PER    Retry    Radar
    36    0       0       -       0       0      -        -
    40    0       0       -       0       0      -        -
    44    0       0       -       0       0      -        -
    48    0       0       -       0       0      -        -
    52    0       0       -       0       0      -        -
    56    0       0       -       0       0      -        -
    60    0       0       -       0       0      -        -
    64    0       0       -       0       0      -        -
    100   0       0       -       0       0      -        -
    104   0       0       -       0       0      -        -
    108   0       0       -       0       0      -        -
    112   0       0       -       0       0      -        -
    116   0       0       -       0       0      -        -
    132   0       0       -       0       0      -        -
    136   0       0       -       0       0      -        -
    140   0       0       -       0       0      -        -
    149   1       0       -       0       0      -        -
    153   4       0       -       0       0      -        -
    157   0       0       0       0       0      0        -
    161   2       0       -       0       0      -        -
    165   0       0       -       0       0      -        -
   Nbr-MACAddress   Ch    Intf   SignalStrength   Type
                           (%)    (dBm)
   000f-e212-ff01   161   0      -60              Unmanaged
   5866-ba74-e461   153   0      -72              Unmanaged
   70f9-6d30-9020   153   0      -40              Managed
   70f9-6d31-3080   149   0      -54              Managed
   70f9-6d31-34e0   161   0      -59              Managed
   7425-8a86-bbe0   153   0      -48              Unmanaged
   7425-8a86-c720   153   0      -63              Unmanaged
 Radio   : 2                              Basic BSSID    : 70f9-6d31-2ff0
 Channel : 1                              Tx Power (dBm) : 19
    1     6       4       0       4       0      0        -
    6     4       2       -       2       0      -        -
    11    6       2       -       2       0      -        -
                           (%)    (dBm)
   000f-e212-ff11   1     49     -77              Unmanaged
   0023-89e1-ed00   11    0      -87              Unmanaged
   006a-55f6-ae10   1     57     -88              Unmanaged
   5866-ba64-aa31   1     10     -60              Unmanaged
   5866-ba74-e471   6     0      -76              Unmanaged
   5866-baa9-a610   11    0      -62              Unmanaged
   70f9-6d30-9030   6     0      -63              Managed
   70f9-6d31-3090   1     51     -86              Managed
   70f9-6d31-34f0   6     0      -85              Managed
   7425-8a86-bbf0   6     0      -73              Unmanaged
   7425-8a86-c731   11    0      -93              Unmanaged
   80f6-2ec0-3330   11    0      -76              Unmanaged
   80f6-2ec0-3331   11    0      -73              Unmanaged
   80f6-2edd-d2d0   1     40     -60              Unmanaged
   80f6-2edd-d2d1   1     44     -68              Unmanaged
   80f6-2ede-0b30   11    0      -74              Unmanaged
Table 6 Command output
Radio
Radio ID.
Basic BSSID
Channel
Tx Power
Ch
Channels supported by the radio.
Nbrs
Number of detected radios.
Load
Load detected on the channel, in percentage. Channel load refers to the ratio between the outbound packets and the inbound packets as well as the interferences. Interferences refer to the error packets that are received by the radio.
Util
Channel usage in percentage. Channel usage refers to the ratio between the outbound packets and the inbound packets.
Intf
PER
Retry
Radar
Radar detection status:
·     : No radar signals are detected on the channel.
·     Detected: Radar signals have been detected on the channel.
Nbr-MACAddress
MAC address of the detected radio.
SignalStrength
Signal strength of the radio, in dBm.
Type of the radio:
·     Unmanaged—Radios that can be detected by the radio but are not managed by the same AC.
·     Managed—Radios that can be detected by the radio and are managed by the same AC.
Use interference-threshold to set the channel interference threshold.
Use undo interference-threshold to restore the default.
interference-threshold percent
In an AP group's RRM view, the channel interference threshold is 50.
RRM view
AP group's RRM view
percent: Specifies the channel interference threshold in the range of 1 to 100.
When the AC detects that the proportion of interference packets in all data packets reaches the interference threshold on a radio, it performs DFS for the radio. Interference packets are packets sent to other radios.
# Set the channel interference threshold to 60 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] interference-threshold 60
# Set the channel interference threshold to 60 for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] interference-threshold 60
power holddown-time
Use power holddown-time to set the power holddown time.
Use undo power holddown-time to restore the default.
power holddown-time minutes
The power holddown time is 60 minutes.
minutes: Specifies the power holddown time in the range of 10 to 1440 minutes.
Each time the power of a radio in the RRM holddown group changes, the system starts the power holddown timer for the radio. The power for every radio in the RRM holddown group remains unchanged during the specified power holddown time.
# Set the power holddown time to 600 minutes for RRM holddown group 10.
[Sysname-wlan-rrm-calibration-group-10] power holddown-time 600
rrm
Use rrm to enter Radio Resource Management (RRM) view.
rrm
No RRM view exists.
Radio view
# Enter RRM view.
scan-only
Use scan-only enable to enable radio scanning.
Use scan-only disable to disable radio scanning.
Use undo scan-only to restore the default.
scan-only { disable | enable }
undo scan-only
In an AP group's RRM view, radio scanning is disabled.
RRM view
AP group's RRM view
This feature enables APs to scan the WLAN environment and report collected statistics to the AC at the specified interval. The AC uses the statistics to generate channel reports and neighbor reports.
To view the channel reports and neighbor reports, use the display wlan rrm-status ap command.
If you have configured periodic auto-DFS, scheduled auto-DFS, or periodic auto-TPC, you do not need to enable this feature.
# Enable radio scanning for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] scan-only enable
# Enable radio scanning for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] scan-only enable
snmp-agent trap enable wlan rrm
Use snmp-agent trap enable wlan rrm to enable SNMP notifications for WLAN RRM.
Use undo snmp-agent trap enable wlan rrm to disable SNMP notifications for WLAN RRM..
SNMP notifications are disabled for WLAN RRM.
To report critical WLAN RRM events to an NMS, enable SNMP notifications for WLAN RRM. For WLAN RRM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for WLAN RRM.
[Sysname] snmp-agent trap enable wlan rrm
tolerance-level
Use tolerance-level to set the tolerance level.
Use undo tolerance-level to restore the default.
tolerance-level percent
In an AP group's RRM view, the tolerance level is 20.
RRM view
AP group's RRM view
percent: Specifies the tolerance level in the range of 1 to 45.
The AC selects an optimal channel for a radio when the CRC error threshold, interference threshold, or retransmission threshold is reached on the current channel. The AC does not apply the optimal channel to the radio until the quality gap between the optimal channel and the current channel exceeds the tolerance level.
# Set the tolerance level to 25 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] tolerance-level 25
# Set the tolerance level to 25 for radio 1 of APs with model WA4320i-ACN in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA4320i-ACN-radio-1-rrm] tolerance-level 25
wlan calibrate-channel pronto ap all
IMPORTANT
IMPORTANT:
This command consumes system resources. Use it with caution.
Use wlan calibrate-channel pronto ap all to execute on-demand DFS for radios of all APs.
RRM does not execute on-demand DFS for radios.
# Execute on-demand DFS for radios of all APs.
[Sysname] wlan calibrate-channel pronto ap all
wlan calibrate-power pronto ap all
IMPORTANT
IMPORTANT:
Use wlan calibrate-power pronto ap all to execute on-demand TPC for radios of all APs.
RRM does not execute on-demand TPC for radios.
# Execute on-demand TPC for radios of all APs.
[Sysname] wlan calibrate-power pronto ap all
Use wlan rrm baseline apply to apply a radio baseline.
wlan rrm baseline apply name baseline-name
name baseline-name: Specifies a baseline name, a case-insensitive string of 1 to 32 characters.
You cannot apply a radio baseline when one of the following conditions is met:
·     You do not have the right to manage radios with the location identifier in the radio baseline.
·     The name of the radio baseline is start_config_baseline.csv.
# Apply radio baseline bl.
[Sysname] wlan rrm baseline apply name bl
wlan rrm baseline save
wlan rrm baseline remove
Use wlan rrm baseline remove to delete a radio baseline.
wlan rrm baseline remove name baseline-name
You cannot delete a radio baseline if you do not have the right to manage radios with the location identifier in the radio baseline.
# Delete radio baseline bl.
[Sysname] wlan rrm baseline remove name bl
Use wlan rrm baseline save to create a radio baseline by saving the current radio settings.
wlan rrm baseline save name baseline-name { ap ap-name [ radio radio-id ] | ap-group group-name [ ap-model ap-model ] [ radio radio-id ] | global }
ap ap-name: Specifies an AP name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). Make sure the AP is online.
radio radio-id: Specifies a radio ID. The value range for this argument varies by device model. If you do not specify this option, the command saves the current settings of all radios on the specified AP or on APs in the specified AP group.
ap-group group-name: Specifies an AP group name, a case-insensitive string of 1 to 31 characters. Make sure the AP group already exists.
ap-model ap-model: Specifies an AP model. If you do not specify this option, the command saves the current settings of radios on all APs in the specified AP group.
global: Specifies all radios.
A radio baseline saves the working channel, transmit rate, and other radio attributes for a radio or several radios. You can create a radio baseline by saving the current radio settings and apply the baseline to use these settings.
A radio baseline is saved in a .csv file in the file system on the AC.
# Save the settings of radio 1 on AP ap1 and create radio baseline ap1-1.
[Sysname] wlan rrm baseline save name ap1-1 ap ap1 radio 1
# Save the settings of radio 1 of APs with model WA4320i-ACN in AP group group1 and create radio baseline ap1g1-1.
[Sysname] wlan rrm baseline save name ap1g1-1 ap-group group1 ap-model WA4320i-ACN radio 1
# Save the settings of all radios and create radio baseline global.
[Sysname] wlan rrm baseline save name global global
Use wlan rrm calibration-channel interval to set the channel calibration interval.
Use undo wlan rrm calibration-channel interval to restore the default.
wlan rrm calibration-channel interval minutes
The channel calibration interval is 8 minutes.
minutes: Specifies the channel calibration interval, in the range of 3 to 1440 minutes.
# Set the channel calibration interval to 10 minutes.
[Sysname] wlan rrm calibration-channel interval 10
Use wlan rrm calibration-power interval to set the power calibration interval.
Use undo wlan rrm calibration-power interval to restore the default.
wlan rrm calibration-power interval minutes
The power calibration interval is 8 minutes.
minutes: Specifies the power calibration interval, in the range of 3 to 180 minutes.
# Set the power calibration interval to 10 minutes.
[Sysname] wlan rrm calibration-power interval 10
Use wlan rrm-calibration-group to create an RRM holddown group and enter its view, or enter the view of an existing RRM holddown group.
Use undo wlan rrm-calibration-group to remove an RRM holddown group.
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { all | group-id }
No RRM holddown groups exist.
group-id: Specifies an RRM holddown group ID in the range of 1 to 128.
# Create RRM holddown group 10.
