00-Preface | 22.26 KB |
Preface
This Web configuration guide describes the fundamentals and configuration procedures for features on the H3C SecCenter SMP.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C SecCenter SMP.
Conventions
The following information describes the GUI conventions used in the documentation.
Convention |
Boldface |
Documentation feedback
We appreciate your comments.
