09-ACL and QoS Configuration Guide
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release757X-6W10009-ACL and QoS Configuration Guide
03-Time range configuration
03-Time range configuration 43.42 KB
Configuring time ranges
You can implement a service based on the time of the day by applying a time range to it. A time-based service takes effect only in time periods specified by the time range. For example, you can implement time-based ACL rules by applying a time range to them. If a time range does not exist, the service based on the time range does not take effect.
The following basic types of time ranges are available:
·     Periodic time range—Recurs periodically on a day or days of the week.
·     Absolute time range—Represents only a period of time and does not recur.
A time range is uniquely identified by the time range name. You can create a maximum of 1024 time ranges, each with a maximum of 32 periodic statements and 12 absolute statements. The active period of a time range is calculated as follows:
1.     Combining all periodic statements.
2.     Combining all absolute statements.
3.     Taking the intersection of the two statement sets as the active period of the time range.
Configuration procedure
Step
Remarks
N/A
2.     Create or edit a time range.
time-range time-range-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
By default, no time ranges exist.
Displaying and maintaining time ranges
Execute the display command in any view.
Display time range configuration and status.
display time-range { time-range-name | all }
Time range configuration example
Network requirements
As shown in Figure 1, configure an ACL on Device A to allow only Host A to access the server from 8:00 to 18:00 on working days from June 2014 to the end of the year.
Figure 1 Network diagram
# Create a time range for the period from 8:00 to 18:00 on working days from June 2014 to the end of the year.
[DeviceA] time-range work 08:00 to 18:00 working-day from 00:00 6/1/2014 to 24:00 12/31/2014
# Create an IPv4 basic ACL numbered 2001, and configure a rule in the ACL to permit packets only from 192.168.1.2/32 during the time range work.
[DeviceA] acl basic 2001
[DeviceA-acl-ipv4-basic-2001] rule permit source 192.168.1.2 0 time-range work
[DeviceA-acl-ipv4-basic-2001] rule deny source any time-range work
# Apply IPv4 basic ACL 2001 to filter outgoing packets on interface FortyGigE 1/1/2.
[DeviceA] interface FortyGigE 1/1/2
[DeviceA-FortyGigE1/1/2] packet-filter 2001 outbound
[DeviceA-FortyGigE1/1/2] quit
# Verify that the time range work is active on Device A.
[DeviceA] display time-range all
Current time is 13:58:35 6/20/2014 Friday
Time-range : work (Active)
 from 00:00 6/1/2014 to 00:00 1/1/2015
