07-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesH3C S9500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guide-Release1728-6W17007-Layer 3 - IP Routing Configuration Guide
03-RIP Configuration
03-RIP Configuration 402.76 KB
Configuring RIP· 1
RIP overview·· 1
RIP working mechanism·· 1
RIP versions 2
RIP message format 3
TRIP· 4
Supported RIP features 5
Protocols and standards 5
RIP configuration task list 6
Configuring RIP basic functions 6
Configuration prerequisites 6
Configuration procedure· 7
Configuring RIP route control 8
Configuring an additional routing metric· 9
Configuring RIPv2 route summarization· 9
Disabling host route reception· 10
Advertising a default route· 11
Configuring inbound/outbound route filtering· 11
Configuring a priority for RIP· 12
Configuring RIP route redistribution· 12
Tuning and optimizing RIP networks 13
Configuring RIP timers 13
Configuring split horizon and poison reverse· 13
Configuring the maximum number of load balanced routes 14
Enabling zero field check on incoming RIPv1 messages 15
Enabling source IP address check on incoming RIP updates 15
Configuring RIPv2 message authentication· 15
Specifying a RIP neighbor 16
Configuring TRIP· 16
Configuring RIP-to-MIB binding· 17
Configuring the RIP packet sending rate· 18
Configuring RIP FRR· 18
Configuring BFD for RIP· 19
Single-hop detection in BFD echo packet mode· 19
Bidirectional detection in BFD control packet mode· 20
Displaying and maintaining RIP· 20
RIP configuration examples 21
Configuring RIP version· 21
Configuring RIP route redistribution· 22
Configuring an additional metric for a RIP interface· 24
Configuring RIP to advertise a summary route· 26
RIP FRR configuration example· 29
Configuring BFD for RIP (single-hop detection in BFD echo packet mode) 30
Configuring BFD for RIP (bidirectional detection in BFD control packet mode) 34
Troubleshooting RIP· 38
No RIP updates received· 38
Route oscillation occurred· 38
RIP overview
RIP is a simple Interior Gateway Protocol (IGP), mainly used in small-sized networks, such as academic networks and simple LANs. RIP is not applicable to complex networks.
RIP is widely used in practical networking because it is easy to implement, configure, and maintain.
Introduction
RIP is a distance vector routing protocol, using UDP packets for exchanging information through port 520.
RIP uses a hop count to measure the distance to a destination. The hop count from a router to a directly connected network is 0. The hop count from a router to a directly connected router is 1. To limit convergence time, the range of RIP metric value is from 0 to 15. A metric value of 16 (or greater) is considered infinite, which means the destination network is unreachable. RIP is not suitable for large-scaled networks for this reason.
RIP prevents routing loops by implementing the split horizon and poison reverse functions.
RIP routing table
A RIP router has a routing table containing routing entries of all reachable destinations, and each routing entry contains the following elements:
·           Destination address—IP address of a host or a network.
·           Next hop—IP address of the adjacent router’s interface to reach the destination.
·           Egress interface—Packet outgoing interface.
·           Metric—Cost from the local router to the destination.
·           Route time—Time elapsed since the routing entry was last updated. The time is reset to 0 every time the routing entry is updated.
·           Route tag—Identifies a route, which is used in a routing policy to flexibly control routes. For information about routing policy, see the chapter “Configuring routing policy.”
RIP timers
RIP employs the following timers:
·           Update timer—Defines the interval between routing updates.
·           Timeout timer—Defines the route aging time. If no update for a route is received within the aging time, the metric of the route is set to 16 in the routing table.
·           Suppress timer—Defines how long a RIP route stays in suppressed state. When the metric of a route is 16, the route enters the suppressed state. In the suppressed state, only routes that come from the same neighbor and whose metric is less than 16 will be received by the router to replace unreachable routes.
·           Garbage-collect timer—Defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIP advertises the route with the routing metric set to 16. If no update is announced for that route before the garbage-collect timer expires, the route is deleted from the routing table.
Routing loops prevention
RIP is a distance vector (D-V) routing protocol. Because a RIP router advertises its own routing table to neighbors, routing loops may occur.
RIP uses the following mechanisms to prevent routing loops:
·           Counting to infinity—The metric value of 16 is defined as unreachable. When a routing loop occurs, the metric value of the route will increment to 16.
·           Split horizon—To prevent routing loops and save bandwidth, a router does not send routing information back on the interface the information was learned from.
·           Poison reverse—A router sets the metric of routes received from a neighbor to 16 (unreachable) and sends back these routes to the neighbor to help delete such information from the neighbor’s routing table.
·           Triggered updates—A router advertises updates once the metric of a route is changed instead of after the update period expires to speed up network convergence.
RIP operation
The following procedure describes how RIP works:
1.      After RIP is enabled, the router sends request messages to neighboring routers. Neighboring routers return response messages, including information about their routing tables.
2.      After the router receives this information, it updates its local routing table, and sends triggered update messages to its neighbors. All routers on the network do this to keep the latest routing information.
3.      RIP ages out routes to keep only valid routes.
RIP versions
RIP has the following versions: RIPv1 and RIPv2
RIPv1 is a classful routing protocol, and supports message advertisement through broadcast only. RIPv1 protocol messages do not carry mask information, so it can only recognize routing information of natural networks such as Class A, B, and C. For this reason, RIPv1 does not support discontiguous subnets.
RIPv2 is a classless routing protocol, and has the following advantages over RIPv1:
·           Supports route tags, which are used in routing policies to flexibly control routes.
·           Supports masks, route summarization, and Classless Inter-Domain Routing (CIDR).
·           Supports designated next hops to select the best next hops on broadcast networks.
·           Supports multicast routing update to reduce resource consumption. Only RIPv2 routers can receive these update messages.
·           Supports plain text authentication and MD5 authentication to enhance security.
RIPv2 has two types of message transmission: broadcast and multicast. Multicast is the default type using 224.0.0.9 as the multicast address. The interface working in the RIPv2 broadcast mode can also receive RIPv1 messages.
RIP message format
A RIP message consists of a header and up to 25 route entries. (A RIPv2 authentication message uses the first route entry as the authentication entry, leaving 24 available.)
RIPv1 message format
Figure 1 RIPv1 message format
·           Command—Type of message. 1 indicates request, which is used to request all or part of the routing information from the neighbor; 2 indicates response, which contains all or part of the routing information. A response message consists of up to 25 route entries.
·           Version—Version of RIP; 0x01 for RIPv1.
·           Must be zero—This field must be zero.
·           AFI—Address Family Identifier, 2 for IP.
·           IP address—Destination IP address of the route. It can be a natural network, subnet or a host address.
·           Metric—Cost of the route.
RIPv2 message format
The format of a RIPv2 message is similar to RIPv1.
Figure 2 RIPv2 message format
The differences between RIPv1 and RIPv2 messages are stated as follows:
·           Version—Version of RIP. For RIPv2, the value is 0x02.
·           Route tag—RIPv2 added route tags.
·           IP address—In RIPv2, destination IP address can be a natural network address, subnet address, or host address.
·           Subnet mask—RIPv2 supports mask of the destination address.
·           Next hop—RIPv2 messages include next hop information. If set to 0.0.0.0, it indicates that the originator of the route is the best next hop; otherwise, it indicates a next hop better than the originator of the route.
RIPv2 authentication message format
RIPv2 sets the AFI field of the first route entry to 0xFFFF to identify authentication information.
Figure 3 RIPv2 authentication message
·           Authentication type—A value of 2 represents plain text authentication, while a value of 3 represents MD5.
·           Authentication—Authentication data, including password information when plain text authentication is adopted or including key ID, MD5 authentication data length, and sequence number when MD5 authentication is adopted.
·       RFC 1723 only defines plain text authentication. For MD5 authentication information, see RFC 2453, RIP Version 2.
·       With RIPv1, you can configure the authentication mode in interface view; however, the configuration will not take effect because RIPv1 does not support authentication.
TRIP
Triggered RIP (TRIP), a RIP extension for WANs, is mainly used in dial-up networks.
Working mechanism
Routing information is sent in triggered updates rather than in periodic broadcasts to reduce route management cost on WANs.
·           A routing update message is sent when data in the routing table changes or the next hop is unreachable.
·           Since the periodic update delivery is canceled, an acknowledgement and retransmission mechanism is required to guarantee successful updates transmission on WANs.
Message types
RIP uses the following new types of message which are identified by the value of the command field.
·           Update request (Type-9)—Requests the needed routes from the neighbor
·           Update response (Type-10)—Contains the routes requested by the neighbor
·           Update Acknowledge (Type-11—Acknowledges received update responses
TRIP retransmission mechanism
·           If the router receives no update responses within a specified interval after sending an update request, it sends the request again. If the router still receives no update response after the upper limit for sending requests is reached, it considers the neighbor unreachable.
·           If the router receives no update acknowledge within a specified interval after sending an update response, it sends the update response again. If the router still receives no update acknowledge after the upper limit for sending update responses is reached, it considers the neighbor unreachable.
The current implementation supports the following RIP features:
·           RIPv1 and RIPv2
·           RIP VPN
RIP can serve as the IGP running between CE and PE on a BGP/MPLS VPN network. For related information, see MPLS Configuration Guide.
·           TRIP
·           RIP FRR
·           BFD
RIP periodically sends route updates to neighbors. If no route update for a route is received within the specified interval, RIP considers the route unreachable. This mechanism cannot detect link faults quickly. After BFD is configured for RIP, when BFD detects a broken link, RIP can quickly age out the unreachable route, thus avoiding interference to other services.
·           RFC 1058, Routing Information Protocol
·           RFC 1723, RIP Version 2 - Carrying Additional Information
·           RFC 1721, RIP Version 2 Protocol Analysis
·           RFC 1722, RIP Version 2 Protocol Applicability Statement
·           RFC 1724, RIP Version 2 MIB Extension
·           RFC 2082, RIPv2 MD5 Authentication
·           RFC 2091, Triggered Extensions to RIP to Support Demand Circuits
·           RFC 2453, RIP Version 2
Complete the following tasks to configure RIP:
Remarks
Required
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Configuring TRIP
Optional
Optional
Optional
Configuring RIP FRR
Optional
Optional
Optional
Before you configure RIP basic functions, complete the following tasks:
·           Configure the link layer protocol.
·           Configure IP addresses for interfaces, and make sure that all neighboring routers are reachable to each other.
Enabling RIP and a RIP interface
To enable RIP:
Step
Remarks
1.     Enter system view.
N/A
2.     Enable a RIP process and enter RIP view.
rip [ process-id ] [ vpn-instance vpn-instance-name ]
Not enabled by default
3.     Enable RIP on the interface attached to the specified network.
network network-address
Disabled by default
·       If you make some RIP configurations in interface view before enabling RIP, those configurations will take effect after RIP is enabled.
·       RIP runs only on the interfaces residing on the specified networks; therefore, you must specify the network after enabling RIP to validate RIP on a specific interface.
·       You can enable RIP on all interfaces using the command network 0.0.0.0.
·       If a physical interface is attached to multiple networks, you cannot advertise these networks in different RIP processes.
Configuring the interface behavior
To configure the interface behavior:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Disable the specific interface or all interfaces from sending routing updates (the interfaces can still receive updates).
Optional.
By default, all interfaces can send routing updates.
4.     Return to system view.
N/A
5.     Enter interface view.
N/A
6.     Enable the interface to receive RIP messages.
rip input
Optional.
Enabled by default.
7.     Enable the interface to send RIP messages.
rip output
Optional.
Enabled by default.
Configuring a RIP version
You can configure a RIP version in RIP view or interface view under the following conditions:
·           If neither global nor interface RIP version is configured, the interface sends RIPv1 broadcasts, and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
·           If an interface has no RIP version configured, it uses the global RIP version; otherwise, it uses the RIP version configured on it.
·           With RIPv1 configured, an interface sends RIPv1 broadcasts, and can receive RIPv1 broadcasts and unicasts.
·           With RIPv2 configured, a multicast interface sends RIPv2 multicasts, and can receive RIPv2 unicasts, broadcasts, and multicasts.
·           With RIPv2 configured, a broadcast interface sends RIPv2 broadcasts, and can receive RIPv1 unicasts and broadcasts and RIPv2 broadcasts, multicasts, and unicasts.
To configure a RIP version:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Specify a global RIP version.
version { 1 | 2 }
Optional.
By default, if an interface has a RIP version specified, the version takes precedence over the global one. If no RIP version is specified for an interface, the interface can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
N/A
N/A
6.     Specify a RIP version for the interface.
rip version { 1 | 2 [ broadcast | multicast ] }
Optional.
By default, if an interface has no RIP version specified, the global version takes effect. If no global RIP version is specified, the interface can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts and unicasts.
In complex networks, you must configure advanced RIP features.
Before you configure RIP routing feature, complete the following tasks:
·           Configure RIP basic functions.
An additional routing metric can be added to the metric of an inbound or outbound RIP route.
If the outbound additional metric is added to the metric of a sent route, the route’s metric in the routing table is not changed.
The inbound additional metric is added to the metric of a received route before the route is added into the routing table, and the route’s metric is changed. If the sum of the additional metric and the original metric is greater than 16, the metric of the route will be 16.
To configure additional routing metrics:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Define an inbound additional routing metric.
rip metricin [ route-policy route-policy-name ] value
Optional
0 by default
4.     Define an outbound additional routing metric.
rip metricout [ route-policy route-policy-name ] value
Optional
1 by default
Route summarization means that subnets in a natural network are summarized into a natural network that is sent to other networks. This feature can reduce the size of routing tables.
After route summarization, the smallest metric among all the summarized routes is used as the metric of the summary route.
Enabling RIPv2 route automatic summarization
You can disable RIPv2 route automatic summarization if you want to advertise all subnet routes.
To enable RIPv2 route automatic summarization:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Enable RIPv2 automatic route summarization.
summary
Optional.
Enabled by default.
If the subnet routes in the routing table are not consecutive, disable automatic route summarization to avoid black hole routing.
Advertising a summary route
To configure RIPv2 to advertise a summary route on the specified interface:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Disable RIPv2 automatic route summarization.
undo summary
Enabled by default
N/A
N/A
6.     Advertise a summary route.
rip summary-address ip-address { mask | mask-length }
N/A
You must disable RIPv2 route automatic summarization before advertising a summary route on an interface.
A router can receive many host routes from the same network, which is not helpful for routing and consumes a large amount of network resources. In this case, disable RIP from receiving host routes to save network resources.
To disable RIP from receiving host routes:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Disable RIP from receiving host routes.
undo host-route
Enabled by default
RIPv2 can be disabled from receiving host routes, but RIPv1 cannot.
Under the following conditions, you can configure RIP to advertise a default route with a specified metric to RIP neighbors.
·           In RIP view, you can configure all the interfaces of the RIP process to advertise a default route; in interface view, you can configure a RIP interface of the RIP process to advertise a default route. The latter takes precedence over the former on the interface.
·           If a RIP process is enabled to advertise a default route, to disable an interface of the RIP process from default route advertisement, you can use the rip default-route no-originate command on the interface.
To configure RIP to advertise a default route:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Enable RIP to advertise a default route.
default-route { only | originate } [ cost cost ]
Optional.
Not enabled by default.
N/A
N/A
6.     Configure the RIP interface to advertise a default route.
rip default-route { { only | originate } [ cost cost ] | no-originate }
Optional.
By default, a RIP interface can advertise a default route if the RIP process is configured with default route advertisement.
The router enabled to advertise a default route does not receive default routes from RIP neighbors.
The switch supports route filtering. You can filter routes by configuring the inbound and outbound route filtering policies by referencing an ACL or IP prefix list. You can also configure the router to receive routes only from a specified neighbor.
To configure route filtering:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Configure the filtering of incoming routes.
filter-policy { acl-number | gateway ip-prefix-name | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] } import [ interface-type interface-number ]
Not configured by default
4.     Configure the filtering of outgoing routes.
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] | interface-type interface-number ]
·       The filter-policy import command filters incoming routes. Routes not passing the filtering will be neither installed into the routing table nor advertised to neighbors.
·       The filter-policy export command filters outgoing routes, including routes redistributed with the import-route command.
Multiple IGP protocols can run in a router. If you want RIP routes to have a higher priority than those learned by other routing protocols, assign RIP a smaller priority value to influence optimal route selection.
To configure a priority for RIP:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Configure a priority for RIP.
preference [ route-policy route-policy-name ] value
Optional
100 by default
If a router runs RIP and other routing protocols, you can configure RIP to redistribute OSPF, IS-IS, BGP, static, and direct routes.
To configure RIP route redistribution:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Configure a default metric for redistributed routes.
default cost value
Optional.
The default metric of a redistributed route is 0.
4.     Redistribute routes from another protocol.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | route-policy route-policy-name | tag tag ] *
By default, no redistribution is configured.
Only active routes can be redistributed. You can use the display ip routing-table protocol command to display route state information.
Before you tune and optimize RIP networks, complete the following tasks:
·           Configure IP addresses for interfaces, and make sure that all neighboring nodes are reachable to each other.
You can change the RIP network convergence speed by adjusting RIP timers.
To configure RIP timers:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Configure values for RIP timers.
Optional.
The default update timer, timeout timer, suppress timer, and garbage-collect timer are 30s, 180s, 120s and 120s respectively.
Based on network performance, make RIP timers of RIP routers identical to each other to avoid unnecessary traffic or route oscillation.
If both split horizon and poison reverse are configured, only the poison reverse function takes effect.
The split horizon and poison reverse functions can avoid routing loops.
Enabling split horizon
The split horizon function disables an interface from sending routing information back on the same interface the information was learned from. This prevents routing loops between adjacent routers.
To enable split horizon:
Step
Remarks
N/A
N/A
3.     Enable split horizon.
rip split-horizon
Optional
Enabled by default
Disabling the split horizon function does not take effect on a point-to-point link.
Enabling poison reverse
The poison reverse function allows an interface to advertise the routes back to the sending router, but sets the metric of these routes to 16 (unreachable). This can avoid routing loops between neighbors.
To enable poison reverse:
Step
Remarks
N/A
N/A
3.     Enable poison reverse.
rip poison-reverse
Disabled by default
This task allows you to implement load balancing over multiple equal-cost RIP routes.
To configure the maximum number of load balanced routes:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Configure the maximum number of load balanced routes.
maximum load-balancing number
Optional
16 by default.
Some fields in the RIPv1 message must be zero. These fields are called zero fields. You can enable zero field check on received RIPv1 messages. If a zero field contains a non-zero value, the RIPv1 message will not be processed. If you are certain that all messages are trustworthy, disable zero field check to save CPU resources.
This feature does not apply to RIPv2 packets, because they have no zero fields.
To enable zero field check on incoming RIPv1 messages:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Enable zero field check on received RIPv1 messages.
Checkzero
Optional
Enabled by default
You can enable source IP address check on incoming RIP updates.
For a message received on an Ethernet interface, RIP compares the source IP address of the message with the IP address of the interface. If they are not in the same network segment, RIP discards the message.
For a message received on a serial interface, RIP checks whether the source address of the message is the IP address of the peer interface. If not, RIP discards the message.
To enable source IP address check on incoming RIP updates:
Step
Remarks
N/A
2.     Enter RIP view.
V
3.     Enable source IP address check on incoming RIP messages.
validate-source-address
Optional
Enabled by default
Disable the source IP address check feature if the RIP neighbor is not directly connected.
In a network requiring high security, you can configure this task to implement RIPv2 message validity check and authentication.
RIPv2 supports two authentication modes: plain text and MD5.
In plain text authentication, the authentication information is sent with the RIP message, which however cannot meet high security needs.
To configure RIPv2 message authentication:
Step
3.     Configure RIPv2 authentication.
rip authentication-mode { md5 { rfc2082 key-string key-id | rfc2453 key-string } | simple password }
This feature does not apply to RIPv1 because RIPv1 does not support authentication. Although you can specify an authentication mode for RIPv1 in interface view, the configuration does not take effect.
Usually, RIP sends messages to broadcast or multicast addresses. On non-broadcast or multicast links, you must manually specify RIP neighbors.
To specify a RIP neighbor:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Specify a RIP neighbor.
peer ip-address
N/A
4.     Disable source address check on incoming RIP updates.
undo validate-source-address
Not disabled by default
·       Do not use the peer ip-address command when the neighbor is directly connected; otherwise, the neighbor may receive both the unicast and multicast (or broadcast) of the same routing information.
·       If a specified neighbor is not directly connected, disable source address check on incoming updates.
Configuring TRIP
In a connection oriented network, a router may establish connections to multiple remote devices. In a WAN, links are created and removed as needed. In such applications, a link created between two nodes for data transmission is temporary and infrequently.
TRIP should be enabled when it is necessary to exchange routing information through on-demand links or triggered RIP.
Enabling TRIP
To enable TRIP:
Step
Remarks
N/A
2.     Enable RIP.
N/A
3.     Return to system view.
N/A
4.     Enter interface view.
interface pos interface-number
N/A
5.     Enable TRIP.
rip triggered
Disabled by default
If RIP is disabled, TRIP is also disabled.
Configuring TRIP retransmission parameters
You can specify the interval and count for retransmitting a request or response as needed.
For two routers on an analog dial-up link, the difference between retransmission intervals on the two ends must be greater than 50 seconds; otherwise, they cannot become TRIP neighbors.
To configure TRIP retransmission parameters:
Step
Remarks
N/A
2.     Enable RIP and enter its view.
N/A
3.     Configure the interval for retransmitting an update request or update response.
trip retransmit timer retransmit-time-value
5 seconds by default
4.     Configure the maximum count for retransmitting an update request or update response.
trip retransmit count retransmit-count-value
Optional
36 by default
The maximum retransmission interval (count × interval) for a packet cannot be so long that the router still resends the packet when its neighbor is down.
This task allows you to enable a specific RIP process to receive SNMP requests.
To bind RIP to MIB:
Step
Remarks
N/A
2.     Bind RIP to MIB.
rip mib-binding process-id
Optional.
By default, MIB is bound to RIP process 1.
RIP periodically sends routing information in RIP packets to RIP neighbors.
Sending large numbers of RIP packets at the same time may affect switch performance and consume large network bandwidth. To solve this problem, specify the maximum number of RIP packets that can be sent at the specified interval.
To configure the RIP packet sending rate:
Step
Remarks
N/A
N/A
3.     Configure the maximum number of RIP packets that can be sent at the specified interval.
output-delay time count count
Optional.
By default, an interface sends up to three RIP packets every 20 milliseconds.
Configuring RIP FRR
·       RIP FRR is only effective for non-recursive RIP routes (that are learned from directly connected neighbors).
·       Do not use RIP FRR and BFD (for RIP) at the same time; otherwise, RIP FRR may fail to take effect.
When a link in a RIP network fails, the traffic is interrupted until RIP completes routing convergence based on the new network topology.
You can enable RIP fast reroute (FRR) to reduce traffic recovery time.
Figure 4 Network diagram
In Figure 4, after you enable FRR on Router B, RIP designates a backup next hop using a routing policy when a network failure is detected. Packets are then directed to the backup next hop for forwarding, reducing traffic recovery time. At the same time, RIP calculates the shortest path based on the new network topology, and forwards packets over that path after network convergence.
You must specify a next hop by using the apply fast-reroute backup-interface command in a routing policy and reference the routing policy with RIP FRR. For more information about routing policy configuration, see the chapter “Configuring routing policy.”
To configure RIP FRR:
Step
Remarks
N/A
2.     Configure the source address of echo packets.
bfd echo-source-ip ip-address
3.     Enter RIP view.
N/A
4.     Enable RIP FRR and reference a routing policy to designate a backup next hop.
Disabled by default
For more information about BFD, see High Availability Configuration Guide.
BFD for RIP provides the following link detection modes:
·           Single-hop detection in BFD echo packet mode for a directly connected neighbor. In this mode, a BFD session is established only when the neighbor has route information to send.
·           Bidirectional detection in BFD control packet mode for an indirectly connected neighbor. In this mode, a BFD session is established only when both ends have routes to send and BFD is enabled on the receiving interface.
To configure BFD for RIP (single-hop detection in BFD echo packet mode):
Step
Remarks
N/A
2.     Configure the source IP address of BFD echo packets.
By default, no source IP address is configured for BFD echo packets.
3.     Enter interface view.
N/A
4.     Enable BFD on the RIP interface.
rip bfd enable
Disabled by default.
To configure BFD for RIP (bidirectional detection in BFD control packet mode):
Step
Remarks
N/A
2.     Create a RIP process and enter RIP view.
By default, RIP is disabled.
peer ip-address
By default, RIP does not unicast updates to any peer.
N/A
5.     Enable BFD on the RIP interface.
rip bfd enable
·       Unidirectional detection in BFD echo packet mode only works for RIP neighbors that are directly connected, namely, one hop away from each other.
·       Using the undo peer command does not remove the neighbor relationship at once; therefore, it cannot bring down the BFD session at once.
Remarks
Display RIP current status and configuration information.
display rip [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display all active routes in RIP database.
display rip process-id database [ | { begin | exclude | include } regular-expression ]
Display RIP interface information.
display rip process-id interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Display routing information about a specified RIP process.
display rip process-id route ip-address { mask | mask-length } | peer ip-address | statistics ] [ | { begin | exclude | include } regular-expression ]
Reset a RIP process.
reset rip process-id process
Available in user view
Clear the statistics of a RIP process.
reset rip process-id statistics
By default, Ethernet, VLAN, and aggregate interfaces are down. Before configuring these interfaces, bring them up by using the undo shutdown command.
Network requirements
As shown in Figure 5, enable RIPv2 on all interfaces on Switch A and Switch B.
Figure 5 Network diagram
1.      Configure IP addresses for interfaces. (Details not shown)
2.      Configure basic RIP functions:
# Configure Switch A.
[SwitchA] rip
[SwitchA-rip-1] network 192.168.1.0
[SwitchA-rip-1] network 172.16.0.0
[SwitchA-rip-1] network 172.17.0.0
# Configure Switch B.
[SwitchB] rip
[SwitchB-rip-1] network 192.168.1.0
[SwitchB-rip-1] network 10.0.0.0
# Display the RIP routing table of Switch A.
[SwitchA] display rip 1 route
 Peer 192.168.1.2  on Vlan-interface100
      Destination/Mask        Nexthop     Cost    Tag   Flags   Sec
         10.0.0.0/8        192.168.1.2      1       0    RA      11
From the routing table, you can see that RIPv1 uses a natural mask.
3.      Configure RIP version:
# Configure RIPv2 on Switch A.
[SwitchA] rip
[SwitchA-rip-1] version 2
[SwitchA-rip-1] undo summary
# Configure RIPv2 on Switch B.
[SwitchB] rip
[SwitchB-rip-1] version 2
[SwitchB-rip-1] undo summary
# Display the RIP routing table on Switch A.
         10.0.0.0/8        192.168.1.2      1       0    RA      50
         10.2.1.0/24       192.168.1.2      1       0    RA      16
         10.1.1.0/24       192.168.1.2      1       0    RA      16
From the routing table, you can see that RIPv2 uses classless subnet mask.
RIPv1 routing information has a long aging time, so it will exist until it ages out after RIPv2 is configured.
Two RIP processes, as shown in Figure 6, are running on Switch B, which communicates with Switch A through RIP 100 and with Switch C through RIP 200.
Configure route redistribution on Switch B to make RIP 200 redistribute direct routes and routes from RIP 100. Switch C can then learn routes destined for 10.2.1.0/24 and 11.1.1.0/24, while Switch A cannot learn routes destined for 12.3.1.0/24 and 16.4.1.0/24.
Configure a filtering policy on Switch B to filter out route 10.2.1.1/24 from RIP 100, making the route not advertised to Switch C.
Figure 6 Network diagram
# Enable RIP 100 and specify RIP version 2 on Switch A.
[SwitchA] rip 100
[SwitchA-rip-100] network 10.0.0.0
[SwitchA-rip-100] network 11.0.0.0
[SwitchA-rip-100] version 2
[SwitchA-rip-100] undo summary
[SwitchA-rip-100] quit
# Enable RIP 100 and RIP 200 and specify RIP version 2 on Switch B.
[SwitchB] rip 100
[SwitchB-rip-100] network 11.0.0.0
[SwitchB-rip-100] version 2
[SwitchB-rip-100] undo summary
[SwitchB-rip-100] quit
[SwitchB] rip 200
[SwitchB-rip-200] network 12.0.0.0
[SwitchB-rip-200] version 2
[SwitchB-rip-200] undo summary
[SwitchB-rip-200] quit
# Enable RIP 200 and specify RIP version 2 on Switch C.
[SwitchC] rip 200
[SwitchC-rip-200] network 12.0.0.0
[SwitchC-rip-200] network 16.0.0.0
[SwitchC-rip-200] version 2
[SwitchC-rip-200] undo summary
# Display the routing table of Switch C.
[SwitchC] display ip routing-table
Routing Tables: Public
         Destinations : 6        Routes : 6
12.3.1.0/24         Direct 0    0            12.3.1.2        Vlan200
12.3.1.2/32         Direct 0    0            127.0.0.1       InLoop0
16.4.1.0/24         Direct 0    0            16.4.1.1        Vlan400
16.4.1.1/32         Direct 0    0            127.0.0.1       InLoop0
3.      Configure route redistribution:
# On Switch B, configure RIP 200 to redistribute direct routes and routes from RIP 100.
[SwitchB] rip 200
[SwitchB-rip-200] import-route rip 100
[SwitchB-rip-200] import-route direct
         Destinations : 8        Routes : 8
10.2.1.0/24         RIP    100  1            12.3.1.1        Vlan200
11.1.1.0/24         RIP    100  1            12.3.1.1        Vlan200
4.      Configure a filtering policy to filter redistributed routes:
# Define ACL 2000 and reference it to a filtering policy to filter routes redistributed from RIP 100 on Switch B, making the route not advertised to Switch C.
[SwitchB] acl number 2000
[SwitchB-acl-basic-2000] rule deny source 10.2.1.1 0.0.0.255
[SwitchB-acl-basic-2000] rule permit
[SwitchB-acl-basic-2000] quit
[SwitchB] rip 200
[SwitchB-rip-200] filter-policy 2000 export rip 100
         Destinations : 7        Routes : 7
RIP is enabled on all the interfaces of Switch A, Switch B, Switch C, Switch D, and Switch E, as shown in Figure 7. The switches are interconnected through RIPv2.
Switch A has two links to Switch D. The link from Switch B to Switch D is more stable than that from Switch C to Switch D. Configure an additional metric for RIP routes received through VLAN-interface 200 on Switch A so Switch A prefers the 1.1.5.0/24 network learned from Switch B.
Figure 7 Network diagram
2.      Configure RIP basic functions:
[SwitchA] rip 1
[SwitchA-rip-1] network 1.0.0.0
[SwitchA-rip-1] quit
[SwitchB] rip 1
[SwitchB-rip-1] network 1.0.0.0
# Configure Switch C.
[SwitchB] rip 1
[SwitchC-rip-1] network 1.0.0.0
[SwitchC-rip-1] version 2
[SwitchC-rip-1] undo summary
# Configure Switch D.
<SwitchD> system-view
[SwitchD] rip 1
[SwitchD-rip-1] network 1.0.0.0
[SwitchD-rip-1] version 2
[SwitchD-rip-1] undo summary
# Configure Switch E.
<SwitchE> system-view
[SwitchE] rip 1
[SwitchE-rip-1] network 1.0.0.0
[SwitchE-rip-1] version 2
[SwitchE-rip-1] undo summary
# Display the IP routing table of Switch A.
[SwitchA] display rip 1 database
   1.0.0.0/8, cost 0, ClassfulSumm
       1.1.1.0/24, cost 0, nexthop 1.1.1.1, Rip-interface
       1.1.2.0/24, cost 0, nexthop 1.1.2.1, Rip-interface
       1.1.3.0/24, cost 1, nexthop 1.1.1.2
       1.1.4.0/24, cost 1, nexthop 1.1.2.2
       1.1.5.0/24, cost 2, nexthop 1.1.1.2
       1.1.5.0/24, cost 2, nexthop 1.1.2.2
The output shows two RIP routes to network 1.1.5.0/24. Their next hops are Switch B (1.1.1.2) and Switch C (1.1.2.2), respectively, with the same cost of 2. Switch C is the next hop router to reach network 1.1.4.0/24, with a cost of 1.
3.      Configure an additional metric for the RIP interface:
# Configure an additional metric of 3 for VLAN-interface 200 on Switch A.
[SwitchA-Vlan-interface200] rip metricin 3
[SwitchA-Vlan-interface200] display rip 1 database
       1.1.4.0/24, cost 2, nexthop 1.1.1.2
The output shows only one RIP route to network 1.1.5.0/24, with the next hop as Switch B (1.1.1.2) and a cost of 2.
As shown in Figure 8, Switch A and Switch B run OSPF; Switch D runs RIP; and Switch C runs OSPF and RIP.
Configure RIP to redistribute OSPF routes on Switch C so Switch D has routes destined for networks 10.1.1.0/24, 10.2.1.0/24, 10.5.1.0/24, and 10.6.1.0/24.
Configure route summarization on Switch C to advertise only the summary route 10.0.0.0/8, reducing the routing table size of Switch D.
Figure 8 Network diagram
2.      Configure OSPF basic functions:
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
3.      Configure RIP basic functions:
[SwitchC] rip 1
[SwitchC-rip-1] network 11.3.1.0
[SwitchD] rip 1
[SwitchD-rip-1] network 11.0.0.0
[SwitchD-rip-1] quit
# Configure RIP to redistribute the routes from OSPF process 1 and direct routes on Switch C.
[SwitchC-rip-1] import-route direct
[SwitchC-rip-1] import-route ospf 1
# Display the routing table information of Switch D.
[SwitchD] display ip routing-table
         Destinations : 10       Routes : 10
10.1.1.0/24         RIP    100  1            11.3.1.1        Vlan300
10.2.1.0/24         RIP    100  1            11.3.1.1        Vlan300
10.5.1.0/24         RIP    100  1            11.3.1.1        Vlan300
10.6.1.0/24         RIP    100  1            11.3.1.1        Vlan300
11.3.1.0/24         Direct 0    0            11.3.1.2        Vlan300
11.3.1.2/32         Direct 0    0            127.0.0.1       InLoop0
11.4.1.0/24         Direct 0    0            11.4.1.2        Vlan400
11.4.1.2/32         Direct 0    0            127.0.0.1       InLoop0
4.      Configure route summarization on Switch C and advertise only the summary route 10.0.0.0/8:
[SwitchC-Vlan-interface300] rip summary-address 10.0.0.0 8
10.0.0.0/8          RIP    100  1            11.3.1.1        Vlan300
Switch S, Switch A, and Switch D are interconnected through RIPv2, as illustrated in Figure 9. When Link A fails, services will be switched to Link B immediately.
Figure 9 Network diagram
1.      Configure IP addresses of the interfaces on each switch and configure RIPv2.
Follow Figure 9 to configure the IP address and subnet mask of each interface on the switches. (Details not shown)
Configure RIPv2 on the switches, ensuring that Switch A, Switch D, and Switch S can communicate with each other at Layer 3 and dynamic route update can be implemented among them with RIPv2. (Details not shown)
2.      Configure RIP FRR:
# Configure Switch S.
<SwitchS> system-view
[SwitchS] bfd echo-source-ip 1.1.1.1
[SwitchS] ip ip-prefix abc index 10 permit 4.4.4.4 32
[SwitchS] route-policy frr permit node 10
[SwitchS-route-policy] if-match ip-prefix abc
[SwitchS-route-policy] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchS-route-policy] quit
[SwitchS] rip 1
[SwitchS-rip-1] fast-reroute route-policy frr
[SwitchS-rip-1] quit
[SwitchD] bfd echo-source-ip 4.4.4.4
[SwitchD] ip ip-prefix abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy] if-match ip-prefix abc
[SwitchD-route-policy] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchD-route-policy] quit
[SwitchD] rip 1
[SwitchD-rip-1] fast-reroute route-policy frr
3.      Verify the configuration:
# Display route 4.4.4.4/32 on Switch S, then you can view the backup next hop information.
[SwitchS] display ip routing-table 4.4.4.4 verbose
Routing Table : Public
Summary Count : 1
  Destination: 4.4.4.4/32
     Protocol: RIP             Process ID: 1
   Preference: 100                   Cost: 1
 IpPrecedence:                    QosLcId:
      NextHop: 13.13.13.2       Interface: vlan200
    BkNextHop: 12.12.12.2     BkInterface: vlan100
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
  BKTunnel ID: 0x0                BKLabel: NULL
        State: Active Adv             Age: 00h01m27s
          Tag: 0
# Display route 1.1.1.1/32 on Switch D, then you can view the backup next hop information.
[SwitchD] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
  Destination: 1.1.1.1/32
      NextHop: 13.13.13.1       Interface: vlan200
    BkNextHop: 24.24.24.2     BkInterface: vlan101
          Tag: 0
Switch A and Switch C are interconnected through a Layer 2 switch, as shown in Figure 10. VLAN-interface 100 of the two switches runs RIP process 1; BFD is enabled on VLAN-interface 100 of Switch A.
Switch A is connected to Switch C through Switch B. VLAN-interface 200 on Switch A runs RIP process 2; VLAN-interface 300 on Switch C, and VLAN-interface 200 and VLAN-interface 300 on Switch B run RIP process 1.
Configure a static route and enable static route redistribution into RIP on Switch C. Switch A learns the static route sent by Switch C, and the outbound interface of the route is the interface connected to the Layer 2 switch.
When the link between Switch C and the Layer 2 switch fails, BFD can quickly detect the link failure and notify it to RIP, and the BFD session goes down. In response, RIP deletes the neighbor relationship with Switch C and the route information received from Switch C. Then, Switch A learns the static route sent by Switch C, with the outbound interface being the interface connected to Switch B.
Figure 10 Network diagram
[SwitchA] rip 1
[SwitchA-Vlan-interface100] rip bfd enable
[SwitchA] rip 2
[SwitchA-rip-2] version 2
[SwitchA-rip-2] undo summary
[SwitchA-rip-2] network 192.168.2.0
[SwitchA-rip-2] quit
[SwitchB] rip 1
[SwitchB-rip-1] network 192.168.2.0
[SwitchB-rip-1] network 192.168.3.0
[SwitchB-rip-1] quit
[SwitchC] rip 1
[SwitchC-rip-1] network 192.168.1.0
[SwitchC-rip-1] network 192.168.3.0
[SwitchC-rip-1] import-route static
[SwitchC-rip-1] quit
3.      Configure BFD parameters:
[SwitchA] bfd echo-source-ip 11.11.11.11
[SwitchA-Vlan-interface100] bfd min-transmit-interval 500
[SwitchA-Vlan-interface100] bfd min-receive-interval 500
[SwitchA-Vlan-interface100] bfd detect-multiplier 7
[SwitchA] quit
4.      Configure a static route on Switch C:
[SwitchC] ip route-static 100.1.1.1 24 null 0
5.      Verify the configuration:
# Display the BFD session information of Switch A.
<SwitchA> display bfd session
 Total Session Num: 1            Init Mode: Active
 Session Working Under Echo Mode:
 LD          SourceAddr      DestAddr        State   Holdtime    Interface
 5           192.168.1.1     192.168.1.2     Up      2000ms      Vlan100
# Display the RIP route learned from Switch B on Switch A.
<SwitchA> display ip routing-table 100.1.1.0 24 verbose
Summary Count : 2
  Destination: 100.1.1.0/24
      NextHop: 192.168.1.2      Interface: vlan-interface 100
    BkNextHop: 0.0.0.0         BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 192.168.1.2
        State: Active Adv             Age: 00h00m47s
          Tag: 0
     Protocol: RIP             Process ID: 2
   Preference: 100                   Cost: 2
      NextHop: 192.168.2.2      Interface: vlan-interface 200
  RelyNextHop: 0.0.0.0          Neighbor : 192.168.2.2
        State: Inactive Adv           Age: 00h12m50s
        Tag: 0
# Enable RIP event debugging on Switch A.
<SwitchA> debugging rip 1 event
<SwitchA> terminal debugging
# When the link between Switch C and the Layer 2 switch fails, Switch A quickly detects the change.
%Jan 19 10:41:51:203 2008 SwitchA BFD/4/LOG:Sess[192.168.1.1/192.168.1.2, Vlan-interface 100,Ctrl], Sta: UP->DOWN, Diag: 1
*Jan 19 10:33:12:813 2008 SwitchA RM/6/RMDEBUG: RIP-BFD: Message Type Disable, Connect Type Direct-connect, Pkt Type Echo, Src IP Address 192.168.1.1, Src IFIndex4, Nbr IP Address 192.168.1.2.
# Display the BFD information of Switch A.
Switch A deleted the neighbor relationship with Switch C and displays no output information.
# Display the RIP routes of RIP process 1 on Switch A.
The RIP route learned from Switch C no longer exists.
<SwitchA> display rip 1 route
# Display the RIP route 100.1.1.0/24 learned on Switch A.
Summary Count : 1
        State: Active Adv             Age: 00h18m40s
          Tag: 0
Switch A is connected to Switch C through Switch B, as shown in Figure 11. VLAN-interface 100 on Switch A and VLAN-interface 200 on Switch C run RIP process 1.
Configure a static route to Switch C on Switch A, and configure a static route to Switch A on Switch C. Enable BFD on VLAN-interface 100 of Switch A and VLAN-interface 200 of Switch C.
Switch A is connected to Switch C through Switch D. VLAN-interface 300 on Switch A runs RIP process 2; VLAN-interface 400 on Switch C, and VLAN-interface 300 and VLAN-interface 400 on Switch D run RIP process 1.
Enable static route redistribution into RIP on Switch A and Switch C so Switch A and Switch C have routes to send to each other. Switch A learns the static route sent by Switch C, the outbound interface is the interface connected to Switch B.
When the link between Switch B and Switch C fails, BFD can quickly detect the link failure and notify it to RIP, and the BFD session goes down. In response, RIP deletes the neighbor relationship with Switch C and the route information received from Switch C. Then, Switch A learns the static route sent by Switch C, with the outbound interface of the route being the interface connected to Switch D.
Figure 11 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int300
192.168.3.1/24
Switch B
Vlan-int100
192.168.1.2/24
Vlan-int100
192.168.1.1/24
Vlan-int200
192.168.2.1/24
Switch C
Vlan-int200
192.168.2.2/24
Switch D
Vlan-int300
192.168.3.2/24
Vlan-int400
192.168.4.2/24
Vlan-int400
192.168.4.1/24
2.      Configure RIP basic functions and enable static route redistribution into RIP so Switch A and Switch C have routes to send to each other:
[SwitchA] rip 1
[SwitchA-rip-1] network 101.1.1.0
[SwitchA-rip-1] peer 192.168.2.2
[SwitchA-rip-1] undo validate-source-address
[SwitchA-rip-1] import-route static
[SwitchA] rip 2
[SwitchA-rip-2] network 192.168.3.0
[SwitchC] rip 1
[SwitchC-rip-1] network 192.168.2.0
[SwitchC-rip-1] network 192.168.4.0
[SwitchC-rip-1] network 100.1.1.0
[SwitchC-rip-1] peer 192.168.1.1
[SwitchC-rip-1] undo validate-source-address
[SwitchC-Vlan-interface200] rip bfd enable
[SwitchD] rip 1
[SwitchD-rip-1] network 192.168.3.0
[SwitchD-rip-1] network 192.168.4.0
[SwitchC] bfd session init-mode active
[SwitchC-Vlan-interface200] bfd min-transmit-interval 500
[SwitchC-Vlan-interface200] bfd min-receive-interval 500
[SwitchC-Vlan-interface200] bfd detect-multiplier 7
4.      Configure static routes:
# Configure a static route to Switch C on Switch A.
[SwitchA] ip route-static 192.168.2.0 24 vlan-interface 100 192.168.1.2
 [SwitchA] quit
# Configure a static route to Switch A on Switch C.
[SwitchC] ip route-static 192.168.1.0 24 vlan-interface 200 192.168.2.1
 Session Working Under Ctrl Mode:
 LD/RD         SourceAddr      DestAddr        State Holdtime Interface
 6/3           192.168.1.1     192.168.2.2     Up    1700ms   vlan100
Summary Count : 2
          Tag: 0
      NextHop: 192.168.3.2      Interface: vlan-interface 300
  RelyNextHop: 0.0.0.0          Neighbor : 192.168.3.2
        Tag: 0
# When the link between Switch B and Switch C fails, Switch A quickly detects the link state change.
%Jan 19 10:41:51:203 2008 SwitchA BFD/4/LOG:Sess[192.168.1.1/192.168.2.2, Vlan-interface 100, Ctrl], Sta: UP->DOWN, Diag: 1
*Jan 19 10:41:51:203 2008 SwitchA RM/6/RMDEBUG: RIP-BFD: Message Type Disable, Connect Type Indirect-connect, Pkt Type Control, Src IP Address 192.168.1.1, Src IFIndex 4, Nbr IP Address 192.168.2.2.
Summary Count : 1
          Tag: 0
Troubleshooting RIP
Symptom
No RIP updates are received when the links work well.
Analysis
After enabling RIP, use the network command to enable corresponding interfaces. Make sure no interfaces are disabled from handling RIP messages.
If the peer is configured to send multicast messages, the same should be configured on the local end.
Solution
1.      Use the display current-configuration command to check RIP configuration
2.      Use the display rip command to check whether some interface is disabled
Symptom
When all links work well, route oscillation occurs on the RIP network. After displaying the routing table, you may find some routes appear and disappear in the routing table intermittently.
Analysis
In the RIP network, make sure all the same timers within the entire network are identical and relationships between timers are reasonable. For example, the timeout timer value should be greater than the update timer value.
Solution
1.      Use the display rip command to check the configuration of RIP timers.
2.      Use the timers command to adjust timers properly.
