H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesH3C S3600 Switch SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
28-Cluster Configuration Guide
28-Cluster Configuration Guide 123.07 KB
The cluster function is implemented through Huawei Group Management Protocol version 2 (HGMPv2). Using HGMPv2, you can manage multiple switches through the public IP address of a master device. In a cluster, the master switch is called the management device, and the managed switches are called member devices. The member devices are not configured with public IP addresses. They are managed and maintained through the management device redirection.
Network Diagram
Figure 1-1 Network diagram for cluster
Networking and Configuration Requirements
Three switches form a cluster, where:
l          Switch A serves as the management device.
l          The other two switches are member devices.
Serving as the management device, Switch A manages the two member devices. The configurations for the cluster are as follows:
l          The two member devices are connected to Ethernet 1/0/2 and Ethernet 1/0/3 of the management device.
l          The management device connects to the Internet through Ethernet 1/0/1.
l          Ethernet 1/0/1 belongs to VLAN 2, whose interface IP address is 163.172.55.1.
l          All the devices in the cluster share the same FTP/TFTP server.
l          The FTP/TFTP server uses IP address 63.172.55.1.
l          The NMS/logging host uses IP address 69.172.55.4.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
1)        Configure the member devices (taking one member as an example, and the configuration on the other member is the same as that in the example)
# Enable NDP globally and on Ethernet 1/0/1.
[SwitchB] ndp enable
[SwitchB] interface Ethernet 1/0/1
[SwitchB-Ethernet1/0/1] ndp enable
[SwitchB-Ethernet1/0/1] quit
# Enable NTDP globally and on Ethernet 1/0/1.
[SwitchB] ntdp enable
[SwitchB-Ethernet1/0/1] ntdp enable
# Enable the cluster function.
[SwitchA] cluster enable
2)        Configure the management device
# Create VLAN 2 and add port Ethernet 1/0/1 to VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] port Ethernet 1/0/1
[SwitchA-vlan2] quit
# Configure the IP address for VLAN-interface 2 as 163.172.55.1.
[SwitchA] interface Vlan-interface 2
[SwitchA-Vlan-interface2] ip address 163.172.55.1 255.255.255.0
# Disable NDP on Ethernet 1/0/1 of the management device.
[SwitchA] ndp enable
[SwitchA] undo ndp enable intferface Ethernet 1/0/1
[SwitchA] interface Ethernet 1/0/1
[SwitchA-Ethernet1/0/1] undo ntdp enable
[SwitchA-Ethernet1/0/1] quit
# Enable NDP on Ethernet 1/0/2 and Ethernet 1/0/3.
[SwitchA] interface Ethernet 1/0/2
[SwitchA-Ethernet1/0/2] ndp enable
[SwitchA-Ethernet1/0/2] quit
[SwitchA] interface Ethernet 1/0/3
[SwitchA-Ethernet1/0/3] ndp enable
[SwitchA-Ethernet1/0/3] quit
# Set the holdtime of NDP information to 200 seconds.
[SwitchA] ndp timer aging 200
# Set the interval between sending NDP packets to 70 seconds.
[SwitchA] ndp timer hello 70
# Enable NTDP globally and on Ethernet 1/0/2 and Ethernet 1/0/3.
[SwitchA] ntdp enable
[SwitchA-Ethernet1/0/2] ntdp enable
[SwitchA-Ethernet1/0/3] ntdp enable
# Set the topology collection range to two hops.
[SwitchA] ntdp hop 2
# Set the delay for a member device to forward topology collection request to 150 ms.
[SwitchA] ntdp timer hop-delay 150
# Set the delay for a port of a member device to forward topology collection request to 15 ms.
[SwitchA] ntdp timer port-delay 15
# Set the topology collection interval to three minutes.
[SwitchA] ntdp timer 3
# Enter cluster view.
[SwitchA] cluster
[SwitchA-cluster]
# Configure a private IP address pool for a cluster. The IP address pool contains six IP addresses, starting from 172.16.0.1.
[SwitchA-cluster] ip-pool 172.16.0.1 255.255.255.248
# Name and build a cluster.
[SwitchA-cluster] build aaa
[aaa_0.SwitchA-cluster]
# Add the two switches attached to the management device to the cluster.
[aaa_0.SwitchA-cluster] add-member 1 mac-address 00e0-fc01-0011
[aaa_0.SwitchA-cluster] add-member 17 mac-address 00e0-fc01-0012
# Set the holdtime of member device information to 100 seconds.
[aaa_0.SwitchA-cluster] holdtime 100
# Set the interval between sending handshake packets to 10 seconds.
[aaa_0.SwitchA-cluster] timer 10
# Configure VLAN-interface 2 as the network management interface.
[aaa_0. SwitchA-cluster] nm-interface Vlan-interface 2
# Configure the shared FTP server, TFTP server, logging host and SNMP host for the cluster.
[aaa_0.SwitchA-cluster] ftp-server 63.172.55.1
[aaa_0.SwitchA-cluster] tftp-server 63.172.55.1
[aaa_0.SwitchA-cluster] logging-host 69.172.55.4
[aaa_0.SwitchA-cluster] snmp-host 69.172.55.4
3)        Perform the following operations on the member devices (taking Switch B as an example)
After the devices attached to the management device are added to the cluster, perform the following operations on the member devices.
# Connect the member device to the remote FTP server shared by the cluster.
<aaa_1.SwitchB> ftp cluster
# Download file aaa.txt from the shared TFTP server to the member device.
<aaa_1.SwitchB> tftp cluster get aaa.txt
# Upload file bbb.txt from the member device to the shared TFTP server.
<aaa_1.SwitchB> tftp cluster put bbb.txt
Complete Configuration
1)        Configurations on the management device
interface Vlan-interface2
 ntdp hop 2
 ntdp timer 3
 ndp timer hello 70
 ndp timer aging 200
cluster
 build aaa
 holdtime 100
 nm-interface Vlan-interface2
2)        Configurations on the member devices
Functions configured on the member devices are enabled by default and thus are not in the configuration file.
Precautions
l          After the above configuration, you can execute the cluster switch-to { member-number | mac-address H-H-H } command on the management device to switch to the view of a member device to maintain and manage the member device, and then use the cluster switch-to administrator command to return to the view of the management device.
l          On the management device, you can use the reboot member command to reboot a member device.
l          After the above configuration, you can receive logs and SNMP trap messages of all the cluster members on the NMS.
l          The switches cannot be used as TFTP servers.
l          It is recommended not to transmit data packets in the management VLAN.
Network Management Interface Configuration
Through the network management interface of a cluster, you can manage the member devices of the cluster from outside of the cluster.
Network Diagram
Figure 1-2 Network diagram for network management interface configuration
l          Configure VLAN-interface 2 as the network management interface.
l          Configure VLAN 3 as the management VLAN.
l          The IP address of the FTP server is 192.168.4.3.
l          Switch A is the management switch.
l          Switches B and C are the member switches.
Table 1-1 Connection information of the management switch
VLAN
IP address
Connection port
VLAN 3, connecting Switch B or Switch C)
192.168.5.30/24
Ethernet 1/0/1
VLAN 2, connecting the FTP Sever)
192.168.4.22/24
Ethernet 1/0/2
Product series
Software version
Hardware version
S5600 series
Release 1510, Release 1602
All versions
S3600-SI/EI series
All versions
Perform the following configurations on Switch A.
# Enter system view, create VLAN 3 and add Ethernet 1/0/1 to VLAN 3.
[SwitchA] vlan 3
[SwitchA-vlan3] port Ethernet 1/0/1
[SwitchA-vlan3] quit
# Configure VLAN 3 as the management VLAN.
[SwitchA] management-vlan 3
# Configure the IP address of VLAN-interface 3 as 192.168.5.30.
[SwitchA] interface Vlan-interface 3
[SwitchA-Vlan-interface3] ip address 192.168.5.30 255.255.255.0
[SwitchA-Vlan-interface3] quit
# Add Ethernet 1/0/2 to VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] port Ethernet 1/0/2
# Configure the IP address of VLAN-interface 2 as 192.168.4.22.
[SwitchA-Vlan-interface2] ip address 192.168.4.22 255.255.255.0
[SwitchA] cluster
[SwitchA -cluster]
# Configure a private IP address pool for a cluster. The IP address pool contains 30 IP addresses, starting from 192.168.5.1.
[SwitchA-cluster] ip-pool 192.168.5.1 255.255.255.224
[aaa_0.SwitchA] cluster
[aaa_0.SwitchA-cluster] nm-interface Vlan-interface 2
vlan 2
vlan 3
interface Vlan-interface3
 management-vlan 3
interface Ethernet1/0/1
 port access vlan 3
interface Ethernet1/0/2
 port access vlan 2
cluster
 build aaa
Precautions
l          The default network management interface is the management VLAN interface.
l          There can be only one network management interface. A new configuration will overwrite the previous one.
l          The network management interface can be configured on the management switch only.
Cluster Configuration in Real Networking
In a complicated network, you can manage switches remotely in a bulk through HGMP, reducing the workload of the network configuration.
After you build a cluster and enable HGMP on the management switch, and enable NDP and cluster for the member devices, you can manage the member switches on the management switch.
Network Diagram
Figure 1-3 Network diagram for HGMP cluster
l          The IP address of the management switch (Switch A) is 10.1.1.17.
l          Configure the IP address of the TFTP server as 10.1.1.15.
l          Configure the IP address of the SNMP NMS as 10.1.1.16.
l          The whole cluster shares the same TFTP server and SNMP NMS.
Management switch Switch A:
l          Two member switches are connected to Ethernet 1/0/1 and Ethernet 1/0/2 of the management switch.
The member switches:
l          Member switch Switch B is connected to Switch D through Ethernet 1/0/2.
l          Switch B is connected to Switch E through Ethernet 1/0/3.
l          Switch B is connected to Switch F through Ethernet 1/0/4.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
1)        Configure the member devices (taking Switch B as an example)
# Enable NDP globally.
# Enable NDP on Ethernet 1/0/1, Ethernet 1/0/2, Ethernet1/0/3, and Ethernet1/0/4.
[SwitchA-Ethernet1/0/1] ndp enable
[SwitchA] interface Ethernet 1/0/4
[SwitchA-Ethernet1/0/4] ndp enable
[SwitchA-Ethernet1/0/4] quit
# Enable NTDP globally.
# Enable NTDP on Ethernet 1/0/1, Ethernet 1/0/2, Ethernet1/0/3, and Ethernet1/0/4.
[SwitchA-Ethernet1/0/1] ntdp enable
[SwitchA-Ethernet1/0/4] ntdp enable
On the member switches, ports that connect to other switches all need to be enabled with NDP and NTDP.
2)        Configure the management device (Switch A)
[SwitchA] undo ndp enable interface Ethernet 1/0/1
# Set the holdtime of NDP information to 300 seconds.
[SwitchA] ndp timer aging 300
# Set the interval between sending NDP packets to 100 seconds.
[SwitchA] ndp timer hello 100
# Set the delay for a member device to forward topology collection request to 180 ms.
[SwitchA] ntdp timer hop-delay 180
# Set the delay for a port of a member device to forward topology collection request to 20 ms.
[SwitchA] ntdp timer port-delay 20
[SwitchA] cluster
[SwitchA-cluster]
# Configure the TFTP server and SNMP NMS shared by the cluster.
[aaa_0.SwitchA-cluster] tftp-server 10.1.1.15
[aaa_0.SwitchA-cluster] snmp-host 10.1.1.16
3)        Perform the following operations on the member devices (taking Switch B as an example):
1)        Configuration on Switch A
 ntdp hop 2
 ntdp timer 3
 ndp timer hello 100
 ndp timer aging 300
cluster
 build aaa
 holdtime 100
 snmp-host 10.1.1.16
Precautions
None
