Check NICs
This feature enables the system to identify whether the NICs on a cloud host have been managed by the system before cloud host or NIC incorporation. If any of the NICs is not mounted to the cloud host, a NIC conflict has occurred, such as a NIC name or IP address conflict. To incorporate the cloud host, you must process the NIC data.
  1. On the top navigation bar, click Resources.
  1. From the left navigation pane, select Virtualization.
  1. Expand a hypervisor, and then select a cloud host from its resource tree.
  1. Click NIC Check.
  1. Select a user.
  1. Compare the NIC data.
  1. If NIC conflicts exist, delete NICs as needed.
  1. Click Delete Metadata.
