The system creates an Istio microservices engine automatically when you create an application group. It cannot be edited or deleted.
Perform this task to view the type, cluster, and associated application group of a microservices engine.
On the top navigation bar, click Business Apps.
From the left navigation pane, select Microservices > Microservices Engines.
To change the display style, click Tile or List from the upper right corner of the page.
Click the name of an Istio engine.
