Create a VDI image source VM based on an OVF file
Open Virtualization Format (OVF) defines the open-source VM file format specifications. An OVF template enables VMs to be compatible with different virtualization management platforms. In the current software version, the system supports OVS templates exported from virtualization platforms such as H3C CAS CVM, VMware vSphere, Oracle VM, and ZTE iECS.
  1. From the left navigation pane, select Images.
  1. Click the Image Source VMs tab, and click Create.
  1. In the dialog box that opens, select Deploy VMs from OVF Template for the creation type, select the host where the image source VM resides, and upload the OVF file. After the file is successfully uploaded, configure basic information for the image source VM, and click Next to configure the VM disks.
  1. Select the target storage file and bus type for the VM, and click Next to configure the NIC.
  1. Click Next, verify that the image source VM configuration is correct, and click Finish.
Basic Info
Disks
NIC
