Create a VDI desktop pool
  1. From the left navigation pane, select Desktop Pools & Groups.
  1. Click Create, or click a desktop pool group name and then click Create Desktop Pool.
  1. Select the VDI desktop type, configure basic desktop pool information, and then click Next: Login Info. By default, a desktop pool is not assigned to any desktop pool group. If you create a desktop pool in a desktop pool group, the desktop pool is assigned to that group.
  1. Configure settings for desktop login, and then click Next: Configuration.
  1. Configure the desktop pool, and then click Next: Confirm Configuration.
  1. Verify that the desktop pool configuration is correct, and then click Finish.
Local users must access shared desktops via the H3C security gateway, not the Microsoft RD gateway. For more information, See H3C Workspace Cloud Desktop Gateway Access to Virtual Application Configuration Guide (Office Scenario).
In a dynamic desktop pool authorized to domain users, if a VM remains in shutdown state for longer than 30 days, the VM will be removed from its domain upon bootup. To use the VM, you must manually assign the VM to its domain again.
·          You must use fast initialization if you are creating the VDI desktop pool for application servers.
·          As a best practice, limit the number of desktops in each bulk deployment or start operation to three if full initialization is used.
·          ARM hosts do not support full initialization.
