Enable IOMMU for a host
  1. On the top navigation bar, click Resources.
  1. From the left navigation pane, select Host Pool Name > Cluster Name > Host Name or Host Pool Name > Host Name.
  1. Select a host that has a GPU.
  1. Click the Advanced Settings tab, and then click Boot Configuration.
  1. Enable IOMMU, and then click Save.
  1. Click Enter Maintenance Mode.
  1. Click More Actions, and then select Restart Host.
  1. After the host restarts, click Exit Maintenance Mode.
