On UIS Cloud, click Cloud Services on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Firewalls.
Click the Firewalls tab, and then click Create.
Configure the firewall parameters as described in "Parameters."
Click Create.
Name: Specify a name for the firewall.
Description: Specify a description for the firewall.
Rule Set: Select a rule set. If you select Auto Create, the system will create a rule set that has the same name as the firewall.
