Configure a vGPU resource pool
Figure-1 vGPU resource pool configuration flow chart
Table-1 vGPU resource pool configuration workflow
Remarks
Add a vGPU
Required.
CAS integrates the NVIDIA Virtual GPU technology to provide GPU virtualization services for VM users.
Before creating a vGPU, make sure the host has GPUs that support NVIDIA GRID vGPU installed.
Required.
Perform this task to add vGPUs on different hosts in the same cluster to a vGPU resource pool and add VMs to use the vGPUs to a VM group.
The system assigns vGPUs to VMs based on the resource usage in the vGPU resource pool and the VM priority when the VMs in the VM group start or restart.
Install an NVIDIA graphics driver on the VM
Required.
Perform this task to install an NVIDIA graphics driver on a VM for the VM to identify vGPUs.
