Discover hosts
About host discovery
Perform this task to discovery the hosts installed with Space Console and add them to the system.
Space Console scans hosts based on Layer 2 protocols and can discover all hosts that are in the same VLAN as the management network physical interfaces of Space Console. During the joining process of a host, Space Console will deploy initial settings such as physical NIC IP, subnet mast, LAGG settings, and load balancing modes, to the host. If the host fails to join Space Console, the system will set the management IP and subnet mask of the host to 192.168.0.162 and 255.255.255.0, respectively.
Figure-1 Host discovery process
Application scenarios
Perform host discovery to expand clusters.
For example, if the network settings of Space Console are as follows:
The host and the connected switch settings must be the following:
Discover hosts in a host pool
  1. From the navigation pane, select Data Center > Virtualization > Host pool name.
  1. Click the Hosts tab, and then click Host Discovery.
  1. Click Configure NICs for a host, configure the network parameters as planned, and then click OK.
  1. Click Add to Cluster for a host, select a cluster, and then click OK.
Discover hosts in a cluster
  1. From the navigation pane, select Data Center > Virtualization > Host pool name > Cluster name.
  1. Click Host Discovery.
  1. Click Add to Cluster for a host, and then click OK.
Assume that you enable this feature for Host A, which uses eth0 as the management network NIC, eth1 as the service network NIC, and eth2 and eth3 as the storage network NICs. The system automatically configures network settings for a host only when the host meets the following requirements:
