- 16-Security Configuration Guide
- 01-ACL configuration
- 02-Packet filter configuration
- 03-Time range configuration
- 04-User profile configuration
- 05-Password control configuration
- 06-Keychain configuration
- 07-Public key management
- 08-PKI configuration
- 09-IPsec configuration
- 10-IKE configuration
- 11-IKEv2 configuration
- 12-SSH configuration
- 13-SSL configuration
- 14-SSL VPN configuration
- 15-Session management
- 16-Connection limit configuration
- 17-Attack detection and prevention configuration
- 18-IP-based attack prevention configuration
- 19-IP source guard configuration
- 20-ARP attack protection configuration
- 21-ND attack defense configuration
- 22-Protocol packet rate limit configuration
- 23-Security policy configuration
- 24-Object group configuration
- 25-ASPF configuration
16-Connection limit configuration | 107.54 KB |
Connection limit tasks at a glance
Creating a connection limit policy
Configuring the connection limit policy
About connection limit policies
Restrictions and guidelines for connection limit policy configuration
Configuring an IPv4 connection limit policy
Configuring an IPv6 connection limit policy
Applying the connection limit policy
About connection limit application
Restrictions and guidelines for connection limit application
Applying a connection limit policy to an interface
Applying a connection limit policy globally
Configuring logging suppression
Verifying and maintaining connection limits
Verifying connection limit configuration
Displaying information about connection limit statistics nodes
Displaying and clearing connection limit statistics
Troubleshooting connection limits
ACLs in the connection limit rules with overlapping segments
Configuring connection limits
About connection limits
The connection limit feature enables the device to monitor and limit the number of established connections.
As shown in Figure 1, configure the connection limit feature to resolve the following issues:
· If Host B initiates a large number of connections in a short period of time, it might exhaust system resources and cause Host A to be unable to access the Internet.
· If the internal server receives a large number of connection requests in a short period of time, the server cannot process other requests.
To configure connection limits, perform the following tasks:
1. Creating a connection limit policy
2. Configuring the connection limit policy
¡ Configuring an IPv4 connection limit policy
¡ Configuring an IPv6 connection limit policy
3. Applying the connection limit policy
¡ Applying a connection limit policy to an interface
¡ Applying a connection limit policy globally
4. Configuring logging suppression
1. Enter system view.
2. Create a connection limit policy and enter its view.
connection-limit { ipv6-policy | policy } policy-id
To use a connection limit policy, you need to add limit rules to the policy. Each rule defines a range of connections and the criteria for limiting the connections. Connections in the range will be limited based on the criteria. When the number of matching connections reaches the upper limit, the device does not accept new connections until the number of connections drops below the lower limit. The device will send logs when the number of connections exceeds the upper limit and when the number of connections drops below the lower limit. The connections that do not match any connection limit rules are not limited.
In each connection limit rule, an ACL is used to define the connection range. In addition, the rule also uses the following filtering methods to further limit the connections:
· per-destination—Limits user connections by destination IP address.
· per-service—Limits user connections by service (transport layer protocol and service port).
· per-source—Limits user connections by source IP address.
You can select more than one filtering method, and the selected methods take effect at the same time. For example, if you specify both per-destination and per-service, the user connections using the same service and destined to the same IP address are limited. If you do not specify any filtering methods in a limit rule, all user connections in the range are limited.
When a connection limit policy is applied, connections on the device match all limit rules in the policy in ascending order of rule IDs. As a best practice, specify a smaller range and more filtering methods in a rule with a smaller ID.
2. Create an IPv4 connection limit policy and enter its view.
connection-limit policy policy-id
3. Configure a connection limit rule.
¡ Configure a connection limit rule based on destination IP address, service, or source IP address.
limit limit-id acl { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount [ description text ]
4. (Optional.) Configure a description for the connection limit policy.
By default, an IPv4 connection limit policy does not have a description.
2. Create an IPv6 connection limit policy and enter its view.
connection-limit ipv6-policy policy-id
limit limit-id acl ipv6 { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount [ description text ]
By default, an IPv6 connection limit policy does not have a description.
To make a connection limit policy take effect, apply it globally or to an interface. The connection limit policy applied to an interface takes effect only on the specified connections on the interface. The connection limit policy applied globally takes effect on all the specified connections on the device.
Different connection limit policies can be applied to individual interfaces as well as globally on the device. In this case, the device matches connections against these policies in the order of the policy on the inbound interface, the global policy, and the policy on the outbound interface. It cannot accept new connections as long as the number of connections reaches the smallest upper connection limit defined by these policies.
A connection limit policy or its modification takes effect only on new connections. It does not take effect on existing connections.
On a cloud cluster fabric where session synchronization is enabled, connection limit policies applied to a subordinate device do not take effect on sessions switched from the master device.
2. Enter interface view.
3. Apply a connection limit policy to the interface.
connection-limit apply { ipv6-policy | policy } policy-id
By default, no connection limit policy is applied to an interface.
Only one IPv4 connection limit policy and one IPv6 connection limit policy can be applied to an interface. A new IPv4 or IPv6 connection limit policy overwrites the old policy.
2. Apply a connection limit policy globally.
connection-limit apply global { ipv6-policy | policy } policy-id
By default, no connection limit policy is applied globally.
Only one IPv4 connection limit policy and one IPv6 connection limit policy can be applied globally. A new IPv4 or IPv6 connection limit policy overwrites the old policy.
By default, the device records a log message each time a connection limit rule is matched. If a connection limit rule is matched frequently in a short period after the upper limit is reached, the device records a large number of repeated log messages for the rule. This feature suppresses the generation of repeated log messages for the same rule in the specified period.
2. Set the logging suppression interval.
connection-limit log-suppress interval time-value
By default, connection limit log messages are not suppressed.
To verify the connection limit policy configuration, execute the following command in any view:
display connection-limit { ipv6-policy | policy } { policy-id | all }
· Display statistics about connections matching IPv4 connection limit rules globally or on an interface.
display connection-limit stat-nodes { global | interface interface-type interface-number } [ slot slot-number ] [ destination destination-ip | service-port port-number | source source-ip ] * [ count ]
· Display statistics about connections matching IPv6 connection limit rules globally or on an interface.
display connection-limit ipv6-stat-nodes { global | interface interface-type interface-number } [ slot slot-number ] [ destination destination-ip | service-port port-number | source source-ip ] * [ count ]
To display the connection limit statistics globally or on an interface, execute the following command in any view:
display connection-limit statistics { global | interface interface-type interface-number } [ slot slot-number ]
To clear the connection limit statistics globally or on an interface, execute the following command in any view:
reset connection-limit statistics { global | interface interface-type interface-number } [ slot slot-number ]
Symptom
A connection limit policy has two rules. Rule 1 sets the upper limit to 10 for the connections from each host on segment 192.168.0.0/24. Rule 2 sets the upper limit to 100 for the connections from 192.168.0.100/24.
[Device] acl basic 2001
[Device-acl-ipv4-basic-2001] rule permit source 192.168.0.0 0.0.0.255
[Device-acl-ipv4-basic-2001] quit
[Device] acl basic 2002
[Device-acl-ipv4-basic-2002] rule permit source 192.168.0.100 0
[Device-acl-ipv4-basic-2002] quit
[Device] connection-limit policy 1
[Device-connection-limit-policy-1] limit 1 acl 2001 per-destination amount 10 5
[Device-connection-limit-policy-1] limit 2 acl 2002 per-destination amount 100 10
As a result, the host at 192.168.0.100 can only initiate a maximum of 10 connections to the external network.
Solution
To resolve the issue:
1. Rearrange the two connection limit rules by exchanging their rule IDs.
2. If the issue persists, contact H3C Support.
