- 05-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-mDNS gateway commands
- 06-mDNS relay commands
- 07-NAT commands
- 08-IP forwarding basics commands
- 09-Fast forwarding commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-Tunneling commands
- 18-GRE commands
- 19-HTTP redirect commands
07-NAT commands | 382.15 KB |
NAT commands
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
NAT address group view
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address. An address range can contain a maximum of 256 addresses.
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the address ranges.
For a NAT address group, make sure the address ranges do not overlap.
# Add two address ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
nat address-group
display nat address-group
Use display nat address-group to display NAT address group information.
display nat address-group [ group-id ]
group-id: Specifies the ID of a NAT address group. The value range for this argument varies by device model. If you do not specify the group-id argument, this command displays information about all NAT address groups.
# Display information about all NAT address groups.
<Sysname> display nat address-group
NAT address group information:
Totally 5 NAT address groups.
Address group 1:
Port range: 1-65535
Address information:
Start address End address
202.110.10.10 202.110.10.15
Address group 2:
Port range: 1-65535
202.110.10.20 202.110.10.25
202.110.10.30 202.110.10.35
Address group 3:
Port range: 1024-65535
202.110.10.40 202.110.10.50
Address group 4:
Port range: 10001-65535
Port block size: 500
Extended block number: 1
202.110.10.60 202.110.10.65
Address group 6:
Port range: 1-65535
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
Address group 1:
Port range: 1-65535
Address group |
ID of the NAT address group. |
Port range |
Port range for public IP addresses. |
Block size |
Number of ports in a port block. This field is not displayed if the port block size is not set. |
Extended block number |
Number of extended port blocks. This field is not displayed if the number of extended port blocks is not set. |
Address information |
Information about the IP addresses in the address group. |
Start address |
Start IP address of an address range. If you do not specify a start address for the range, this field displays hyphens (---). |
End address |
End IP address of an address range. If you do not specify an end address for the range, this field displays hyphens (---). |
nat address-group
display nat all
Use display nat all to display all NAT configuration information.
display nat all
# Display all NAT configuration information.
<Sysname> display nat all
Totally 1 NAT address groups.
Address group 0:
Port block size: 300
202.38.1.2 202.38.1.3
NAT outbound information:
Totally 2 NAT outbound rules.
Interface: Vlan-interface300
ACL: 2000 Address group: 0 Port-preserved: N
NO-PAT: N Reversible: N
Config status: Active
Interface: Vlan-interface301
ACL: 3002 Address group: 0 Port-preserved: N
Static NAT mappings:
Totally 2 inbound static NAT mappings.
Net-to-net:
Global IP : 202.100.1.1 - 202.100.1.255
Local IP : 192.168.1.0
Netmask : 255.255.255.0
Local flow-table status: Inactive
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 3000
Reversible : Y
Config status: Inactive
Reasons for inactive status:
The following items don't exist or aren't effective: ACL.
Totally 2 outbound static NAT mappings.
Net-to-net:
Local IP : 192.168.1.1 - 192.168.1.255
Global IP : 2.2.2.0
ACL : 3002
IP-to-IP:
Local IP : 10.110.10.8
Global IP : 202.38.1.100
Interfaces enabled with static NAT:
Totally 1 interfaces enabled with static NAT.
Interface: Vlan-interface200
NAT logging:
Log enable : Disabled
Flow-begin : Disabled
Flow-end : Disabled
Flow-active : Disabled
Port-block-assign : Disabled
Port-block-withdraw : Disabled
Alarm : Disabled
NAT mapping behavior:
Mapping mode : Address and Port-Dependent
ACL : ---
Static NAT load balancing: Disabled
The output shows all NAT configuration information. Table 2 describes only the fields for the output of the nat hairpin enable, nat mapping-behavior, and nat alg commands.
NAT address group information |
Information about the NAT address group. See Table 1 for output description. |
NAT inbound information: |
Inbound dynamic NAT configuration. See Table 4 for output description. |
NAT outbound information |
Outbound dynamic NAT configuration. See Table 7 for output description. |
Static NAT mappings |
Static NAT mappings. See Table 10 for output description. |
NAT logging |
NAT logging configuration. See Table 5 for output description. |
NAT hairpinning |
NAT hairpin configuration. |
Totally n interfaces enabled NAT hairpinning |
Number of interfaces with NAT hairpin enabled. |
NAT hairpin-enabled interface. |
Service card |
Service card that processes NAT traffic. If no service card is specified on the interface, this field displays hyphens (---). |
Config status |
Status of the NAT hairpin configuration: · Active—The configuration is taking effect. · Inactive—The configuration is not taking effect. |
Reasons for inactive status |
Reasons why the NAT hairpin configuration does not take effect. This field is available when the Config status field displays Inactive. |
NAT mapping behavior |
Mapping behavior mode of PAT: Endpoint-Independent or Address and Port-Dependent. |
ACL |
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---). |
Config status |
Status of the NAT mapping behavior configuration: · Active—The configuration is taking effect. · Inactive—The configuration is not taking effect. |
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status field displays Inactive. |
Static NAT load balancing |
This field is not supported in the current software version. Enabling status of load sharing for static NAT on NAT service engines: · Enabled. · Disabled. |
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
display nat eim [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays EIM entry information for all member devices.
EIM entries are created when PAT operates in EIM mode. An EIM entry is a 3-tuple entry, and it records the mapping between a private address/port and a public address/port.
The EIM entry provides the following functions:
· The same EIM entry applies to subsequent connections initiated from the same source IP and port.
· The EIM entries allow reverse translation for connections initiated from external hosts to internal hosts.
# Display information about EIM entries for the specified slot.
<Sysname> display nat eim slot 1
Slot 1:
Local IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Local VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Local IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
# Display information about NAT EIM entries for CPU 0 on the specified slot.
<Sysname> display nat eim slot 1 cpu 0
CPU 0 on slot 1:
Local VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Protocol: UDP(17)
CPU |
Number of the CPU. |
Local VPN |
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field is not displayed. |
Global VPN |
MPLS L3VPN instance to which the public IP address belongs. If the public IP address does not belong to any VPN instance, this field is not displayed. |
Protocol |
Protocol name and number. |
Total entries found |
Total number of EIM entries. |
nat outbound
display nat inbound
Use display nat inbound to display inbound dynamic NAT configuration.
display nat inbound
# Display inbound dynamic NAT configuration.
<Sysname> display nat inbound
Totally 2 NAT inbound rules.
Interface: Ten-GigabitEthernet1/0/2
ACL: 2038 Address group: 2 Add route: Y
NO-PAT: Y Reversible: N
VPN instance: vpn1
Interface: Ten-GigabitEthernet1/0/3
ACL: 2037 Address group: 1 Add route: Y
VPN instance: vpn2
The following items don't exist or aren't effective: local VPN, and ACL.
VPN instance: vpn1
Service card: Slot 5
VPN instance: vpn2
Service card: ---
Service card not specified.
NAT inbound information |
Information about inbound dynamic NAT configuration. |
Interface where the inbound dynamic NAT rule is configured. |
ACL |
ACL number or name. |
Address group |
NAT address group used by the inbound dynamic NAT rule. |
Add route |
Whether to add a route when a packet matches the inbound dynamic NAT rule: · Y—Adds a route. · N—Does not add a route. |
NO-PAT |
Whether NO-PAT or PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
Whether reverse address translation is allowed: · Y—Reverse address translation is allowed. · N—Reverse address translation is not allowed. |
VPN instance |
MPLS L3VPN instance to which the NAT address group belongs. If the NAT address group does not belong to any VPN instance, the field is not displayed. |
Service card |
Config status |
Status of the inbound dynamic NAT configuration: · Active—The configuration is taking effect. · Inactive—The configuration is not taking effect. |
Reasons why the inbound dynamic NAT configuration does not take effect. This field is available when the Config status field displays Inactive. |
nat inbound
display nat log
Use display nat log to display NAT logging configuration.
display nat log
# Display NAT logging configuration.
<Sysname> display nat log
NAT logging:
Log enable : Enabled(ACL 2000)
Flow-end : Disabled
Flow-active : Enabled(10 minutes)
Alarm : Disabled
NAT logging |
NAT logging configuration. |
Log enable |
Whether NAT logging is enabled. If an ACL is specified for NAT logging, this field also displays the ACL number or name. |
Flow-begin |
Whether logging is enabled for NAT session establishment events. |
Flow-end |
Whether logging is enabled for NAT session removal events. |
Flow-active |
Whether logging is enabled for active NAT flows. If logging for active NAT flows is enabled, this field also displays the interval in minutes at which active flow logs are generated. |
Port-block-assign |
Whether logging is enabled for NAT444 port block assignment. |
Port-block-withdraw |
Whether logging is enabled for NAT444 port block withdrawal. |
Alarm |
Whether logging is enabled for NAT444 alarms. |
nat log enable
nat log flow-active
nat log flow-begin
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
display nat no-pat [ slot slot-number ]
Default user roles
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NO-PAT entry information for all member devices.
A NO-PAT entry records the mapping between a private address and a public address.
The NO-PAT entry provides the following functions:
· The same entry applies to subsequent connections initiated from the same source IP address.
· The NO-PAT entries allow reverse translation for connections initiated from external hosts to internal hosts.
Outbound and inbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# Display information about NO-PAT entries for the specified slot.
<Sysname> display nat no-pat slot 1
Slot 1:
Global IP: 200.100.1.100
Local IP: 192.168.100.100
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Local IP: 192.168.100.200
Global IP: 200.100.1.200
Reversible: Y
Type : Outbound
# Display information about NO-PAT entries for CPU 0 on the specified slot.
<Sysname> display nat no-pat slot 1 cpu 0
CPU 0 on slot 1:
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Reversible: Y
Type : Outbound
Table 6 Command output
CPU |
Local VPN |
Global VPN |
Reversible |
Type |
Type of the NO-PAT entry: · Inbound—A NO-PAT entry created during inbound dynamic NAT. · Outbound—A NO-PAT entry created during outbound dynamic NAT. |
Total number of NO-PAT entries. |
nat inbound
nat outbound
display nat outbound
Use display nat outbound to display information about outbound dynamic NAT.
# Display information about outbound dynamic NAT.
<Sysname> display nat outbound
ACL: 2036 Address group: 1 Port-preserved: Y
Interface: Vlan-interface201
ACL: 2037 Address group: 2 Port-preserved: N
NO-PAT: Y Reversible: Y
Information about outbound dynamic NAT. |
Interface where the outbound dynamic NAT rule is configured. |
ACL |
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT, this field displays hyphens (---). |
DS-Lite B4 ACL |
Number or name of the IPv6 ACL used by DS-Lite NAT444. |
Address group |
Address group used by the outbound dynamic NAT rule. If no address group is specified for address translation, the field displays hyphens (---). |
Port-preserved |
Whether to try to preserve the port numbers for PAT. |
NO-PAT |
Whether NO-PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
VPN instance |
Service card |
Config status |
Status of the outbound dynamic NAT configuration: · Active—The configuration is taking effect. · Inactive—The configuration is not taking effect. |
Reasons why the outbound dynamic NAT configuration does not take effect. This field is available when the Config status field displays Inactive. |
nat outbound
display nat server
Use display nat server to display NAT server mappings.
display nat server
# Display NAT server mappings.
<Sysname> display nat server
NAT internal server information:
Totally 4 internal servers.
Protocol: 6(TCP)
Global IP/port: 50.1.1.1/23
Local IP/port : 192.168.10.15/23
Service card : ---
Config status : Inactive
Interface: Ten-GigabitEthernet1/0/4
Protocol: 6(TCP)
Global IP/port: 50.1.1.1/23-30
Local IP/port : 192.168.10.15-192.168.10.22/23
Global VPN : vpn1
Local VPN : vpn3
Service card : ---
The following items don't exist or aren't effective: local VPN.
Protocol: 255(Reserved)
Global IP/port: 50.1.1.100/---
Local IP/port : 192.168.10.150/---
Global VPN : vpn2
Local VPN : vpn4
Service card : Slot 5
Config status : Active
Interface: Ten-GigabitEthernet1/0/5
Protocol: 17(UDP)
Global IP/port: 50.1.1.2/23
Local IP/port : server group 1
1.1.1.1/21 (Connections: 10)
192.168.100.200/80 (Connections: 20)
Global VPN : vpn1
Local VPN : vpn10
NAT internal server information |
Information about NAT server mapping. |
Interface where NAT server mapping is configured. |
Protocol |
Protocol number and name of the internal server. |
Global IP/port |
Public IP address and port number of the internal server. · Global IP—A single IP address or an IP address range. If you use Easy IP, this field displays the IP address of the specified interface. If you do not specify an address for the interface, the Global IP field displays hyphens (---). · port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---). |
Local IP/port |
For common NAT server mappings, this field displays the private IP address and port number of the internal server. · Local IP—A single IP address or an IP address range. · port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---). For a load sharing NAT server mapping, this field displays the internal server group ID, IP address, port number, and number of connections of each member. |
Global VPN |
MPLS L3VPN instance to which the public IP addresses belong. If the public IP addresses do not belong to any VPN instance, this field is not displayed. |
Local VPN |
MPLS L3VPN instance to which the private IP addresses belong. If the private IP addresses do not belong to any VPN instance, this field is not displayed. |
ACL |
ACL number or name. If no ACL is specified, this field is not displayed. |
Service card |
Config status |
Status of the NAT server mapping configuration: · Active—The configuration is taking effect. · Inactive—The configuration is not taking effect. |
Reasons why the NAT server mapping configuration does not take effect. This field is available when the Config status field displays Inactive. |
nat server
display nat session
Use display nat session to display NAT sessions.
display nat session [ { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ verbose ]
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN must be the VPN inside the packet. If you do not specify a VPN instance, this command displays NAT sessions that do not belong to any VPN instance.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT sessions for all member devices.
verbose: Displays detailed information about NAT sessions. If you do not specify this keyword, this command displays brief information about NAT sessions.
If you do not specify any parameters, this command displays all NAT sessions.
# Display detailed information about NAT sessions.
<Sysname> display nat session verbose
Slot 1:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
DS-Lite tunnel peer: -
VPN instance/VLAN ID/VLL ID: -/-/-
Protocol: TCP(6)
Inbound interface: Vlan-interface100
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.10/1877
Protocol: TCP(6)
Inbound interface: Vlan-interface200
State: TCP_SYN_SENT
Application: SSH
Start time: 2022-05-11 10:06:55 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Total sessions found: 1
Table 9 Command output
Source IP/port |
Source IP address and port number. |
Destination IP/port |
Destination IP address and port number. |
DS-Lite tunnel peer |
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
VPN instance/VLAN ID/VLL ID |
The fields identify the following information: · VPN instance—MPLS L3VPN instance to which the session belongs. · VLAN ID—VLAN to which the session belongs for Layer 2 forwarding. · VLL ID—INLINE to which the session belongs for Layer 2 forwarding. If no VPN instance, VLAN ID, or VLL ID is specified, a hyphen (-) is displayed for the related field. |
Protocol |
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite. |
Inbound interface |
Input interface. |
Source security zone |
Security zone to which the input interface belongs. If the input interface does not belong to any security zone, this field displays a hyphen (-). |
State |
NAT session status. |
Application |
Application layer protocol type, such as FTP and DNS. This field displays OTHER for the protocol types identified by non-well-known ports. |
Start time |
Time when the session starts. |
TTL |
Remaining NAT session lifetime in seconds. |
Initiator->Responder |
Number of packets and packet bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and packet bytes from the responder to the initiator. |
Total sessions found |
Total number of sessions. |
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# Display static NAT mappings.
<Sysname> display nat static
Net-to-net:
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 3000
Reversible : Y
Net-to-net:
Global IP : 2.2.2.0
ACL : 3002
IP-to-IP:
Information about static NAT mapping configuration. |
Totally n inbound static NAT mappings |
Total number of inbound static NAT mappings. |
Totally n outbound static NAT mappings |
Total number of outbound static NAT mappings. |
Net-to-net |
Net-to-net static NAT mapping. |
IP-to-IP |
One-to-one static NAT mapping. |
Local IP |
Private IP address or address range. |
Global IP |
Public IP address or address range. |
Netmask |
Network mask. |
Local VPN |
Global VPN |
ACL |
Reversible |
Whether reverse address translation is allowed. If reverse address translation is allowed, this field displays Y. If reverse address translation is not allowed, this field is not displayed. |
Interfaces enabled with static NAT |
Interfaces on which static NAT is enabled. |
Totally n interfaces enabled with static NAT |
Total number of interfaces where static NAT is enabled. |
Interface on which static NAT is enabled. |
Service card |
Config status |
Status of the static NAT mapping configuration: · Active—The configuration is taking effect. · Inactive—The configuration is not taking effect. |
Reasons why the static NAT mapping configuration does not take effect. This field is available when the Config status field displays Inactive. |
nat static
nat static net-to-net
nat static enable
display nat statistics
Use display nat statistics to display NAT statistics.
display nat statistics [ summary ] [ slot slot-number ]
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT statistics for all member devices.
# Display detailed information about NAT statistics.
<Sysname> display nat statistics
Slot 1:
Total session entries: 100
Total EIM entries: 1
Total inbound NO-PAT entries: 0
Total outbound NO-PAT entries: 0
Total static port block entries: 10
Total dynamic port block entries: 15
Active static port block entries: 0
Active dynamic port block entries: 0
# Display detailed information about all NAT statistics.
CPU 0 on slot 1:
Table 11 Command output
Total session entries |
Total number of NAT session entries. |
Total EIM entries |
Total inbound NO-PAT entries |
Total number of inbound NO-PAT entries. |
Total outbound NO-PAT entries |
Total number of outbound NO-PAT entries. |
Total static port block entries |
Total number of static NAT444 mappings. |
Total dynamic port block entries |
Total number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
Active static port block entries |
Total number of static port block mappings that are in use. |
Active dynamic port block entries |
Total number of dynamic NAT port block mappings that have been created. It equals the number of dynamically assigned port blocks. |
# Display NAT statistics summary.
<Sysname> display nat statistics summary
EIM: Total EIM entries.
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions EIM SPB DPB ASPB ADPB
2 0 0 0 1572720 0 0
Slot CPU Sessions EIM SPB DPB ASPB ADPB
2 1 0 0 0 1572720 0 0
Table 12 Command output
Sessions |
Number of NAT session entries. |
EIM |
Number of EIM entries. |
SPB |
Number of static port block mappings. |
DPB |
Number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
ASPB |
Number of static port block mappings in use. |
ADPB |
Number of dynamic port block mappings that have been created. It equals the number of dynamically assigned port blocks. |
nat address-group
Use nat address-group to create a NAT address group and enter its view, or enter the view of an existing NAT address group.
Use undo nat address-group to delete a NAT address group.
nat address-group group-id
undo nat address-group group-id
No NAT address groups exist.
A NAT address group can contain multiple address ranges by using the address command. Dynamic NAT translates the source IP address of a packet into an IP address in the address group.
# Create a NAT address group numbered 1.
[Sysname] nat address-group 1
address
display nat all
nat inbound
nat outbound
nat alg
Use nat alg to enable NAT ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet |tftp | xdmcp }
NAT ALG for all supported protocols is enabled.
all: Enables NAT ALG for all supported protocols.
dns: Enables NAT ALG for DNS.
ftp: Enables NAT ALG for FTP.
H323: Enables NAT ALG for H.323.
icmp-error: Enables NAT ALG for ICMP error packets.
ils: Enables NAT ALG for ILS.
mgcp: Enables NAT ALG for MGCP.
nbt: Enables NAT ALG for NBT.
pptp: Enables NAT ALG for PPTP.
rsh: Enables NAT ALG for RSH.
rtsp: Enables NAT ALG for RTSP.
sccp: Enables NAT ALG for SCCP.
sip: Enables NAT ALG for SIP.
sqlnet: Enables NAT ALG for SQLNET.
tftp: Enables NAT ALG for TFTP.
xdmcp: Enables NAT ALG for XDMCP.
NAT ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT ALG to translate the address and port information to establish the data connection.
# Enable NAT ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat hairpin enable
Use nat hairpin enable to enable NAT hairpin.
Use undo nat hairpin enable to disable NAT hairpin.
nat hairpin enable
NAT hairpin is disabled.
Interface view
NAT hairpin allows internal hosts to access each other or allows internal hosts to access internal servers. It must cooperate with NAT Server, outbound dynamic NAT, or outbound static NAT. The source and destination IP addresses of the packets are translated on the interface connected to the internal network.
# Enable NAT hairpin on interface Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] nat hairpin enable
display nat all
nat inbound
Use nat inbound to configure an inbound dynamic NAT rule.
Use undo nat inbound to delete an inbound dynamic NAT rule.
nat inbound { ipv4-acl-number | name ipv4-acl-name } address-group group-id [ vpn-instance vpn-instance-name ] [ no-pat [ reversible ] [ add-route ] ]
undo nat inbound { ipv4-acl-number | name ipv4-acl-name }
No inbound dynamic NAT rules exist.
Interface view
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group for address translation. The value range for the group-id argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the addresses in the address group belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the addresses in the address group do not belong to any VPN instance, do not specify this option.
no-pat: Uses NO-PAT for inbound NAT. If you do not specify this keyword, PAT is used. PAT supports only TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the internal network to the external network.
add-route: Automatically adds a route to the source address after translation. The output interface is the NAT interface and the next hop is the source address before translation.
Inbound dynamic NAT translates the source IP addresses of incoming packets permitted by the ACL into IP addresses in the address group.
Inbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation.
· NO-PAT—Performs only IP address translation.
The NO-PAT mode supports reverse address translation. Reverse address translation uses ACL reverse matching to identify packets to be translated. ACL reverse matching works as follows:
· Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
· Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Inbound dynamic NAT typically cooperates with one of the following to implement bidirectional NAT:
· Outbound dynamic NAT (the nat outbound command).
· NAT Server (the nat server command).
· Outbound static NAT (the nat static command).
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat inbound command in both PAT and NO-PAT modes.
Do not specify the add-route keyword if the subnets where the internal and external networks reside overlap. For other network scenarios:
· If you specify the add-route keyword, the device automatically adds a route to the source address after translation for a packet. The destination address is the NATed address in the NAT address group, the output interface is the interface where the command is executed, and the next hop is the source address before translation.
· If you do not specify the add-route keyword, you must manually add the route. As a best practice, add routes manually because automatic route adding is slow.
When you specify an ACL, follow these restrictions and guidelines:
· An ACL can be used by only one inbound dynamic NAT rule on an interface.
· If the ACL does not exist or does not contain a rule, the ACL cannot match any packet.
· If you specify the vpn-instance keyword for an ACL rule, the rule takes effect only on VPN packets. If you do not specify the vpn-instance keyword for an ACL rule, the rule takes effect only on public network packets.
You can configure multiple inbound dynamic NAT rules on an interface.
The vpn-instance parameter is required if you deploy inbound dynamic NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 in VPN vpn10 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit vpn-instance vpn10 source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Configure the MPLS L3VPN instance named vpn10.
[Sysname] ip vpn-instance vpn10
[Sysname-vpn-instance-vpn10] route-distinguisher 100:001
[Sysname-vpn-instance-vpn10] vpn-target 100:1 export-extcommunity
[Sysname-vpn-instance-vpn10] vpn-target 100:1 import-extcommunity
[Sysname-vpn-instance-vpn10] quit
# Create address group 1 and add the address range of 202.110.10.10 to 202.110.10.12 to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an inbound NO-PAT rule on interface Ten-GigabitEthernet 1/0/1. NAT translates the source addresses of incoming packets into the addresses in address group 1, and automatically adds routes for translated packets.
[Sysname-Ten-GigabitEthernet1/0/1] nat inbound 2001 address-group 1 vpn-instance vpn10 no-pat add-route
display nat all
display nat inbound
display nat no-pat
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
NAT logging is disabled.
acl: Specifies an ACL.
You must enable NAT logging before you enable NAT session logging.
· The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
[Sysname] nat log enable
display nat all
display nat log
nat log flow-active
nat log flow-begin
nat log flow-end
nat log flow-active
Use nat log flow-active to enable logging for active NAT flows and set the logging interval.
Use undo nat log flow-active to disable logging for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
Active NAT flows are NAT sessions that last for a long time. The logging feature helps track active NAT flows by periodically logging the active NAT flows.
Logging for active NAT flows takes effect only after you enable NAT logging.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
display nat all
display nat log
nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT session establishment events.
Use undo nat log flow-begin to disable logging for NAT session establishment events.
nat log flow-begin
Logging for NAT session establishment events is disabled.
Logging for NAT session establishment events takes effect only after you enable NAT logging.
# Enable logging for NAT session establishment events.
[Sysname] nat log flow-begin
display nat all
display nat log
nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT session removal events.
Use undo nat log flow-end to disable logging for NAT session removal events.
nat log flow-end
Logging for NAT session removal events is disabled.
Logging for NAT session removal events takes effect only after you enable NAT logging.
# Enable logging for NAT session removal events.
[Sysname] nat log flow-end
display nat all
display nat log
nat log enable
Use nat mapping-behavior to configure the mapping behavior mode for PAT.
Use undo nat mapping-behavior to restore the default.
nat mapping-behavior endpoint-independent [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat mapping-behavior endpoint-independent
Address and Port-Dependent Mapping applies.
acl: Specifies an ACL to define the applicable scope of Endpoint-Independent Mapping.
PAT supports the following NAT mappings modes:
· Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the translated IP address and port. It allows internal hosts behind different NAT gateways to access each other.
· Address and Port-Dependent Mapping—Uses different IP and port mappings for packets with the same source IP and port to different destination IP addresses and ports. APDM allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host. It is secure, but it does not allow internal hosts behind different NAT gateways to access each other.
This command takes effect only on outbound PAT. Address and Port-Dependent Mapping always applies to inbound PAT.
· If you specify an ACL, Endpoint-Independent Mapping applies to packets that are permitted by the ACL. If you do not specify an ACL, Endpoint-Independent Mapping applies to all packets.
# Apply the Endpoint-Independent Mapping mode to all packets for address translation.
[Sysname] nat mapping-behavior endpoint-independent
# Apply the Endpoint-Independent Mapping mode to FTP and HTTP packets, and the Address and Port-Dependent Mapping mode to other packets for address translation.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
nat outbound
display nat eim
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule.
Use undo nat outbound to delete an outbound dynamic NAT rule.
NO-PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group group-id [ vpn-instance vpn-instance-name ] no-pat [ reversible ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group group-id ] [ vpn-instance vpn-instance-name ] [ port-preserved ]
No outbound dynamic NAT rules exist.
Interface view
address-group group-id: Specifies an address group for NAT. The value range for the group-id argument varies by device model. If you do not specify an address group, the IP address of the interface is used as the NAT address. Easy IP is used.
no-pat: Uses NO-PAT for outbound NAT. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
port-preserved: Tries to preserve port number for PAT.
Outbound dynamic NAT is typically configured on the interface connected to the external network. You can configure multiple outbound dynamic NAT rules on an interface.
Outbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation. The PAT mode allows external hosts to actively access the internal hosts if the Endpoint-Independent Mapping behavior is used.
· NO-PAT—Performs only IP address translation. The NO-PAT mode allows external hosts to actively access the internal hosts if you specify the reversible keyword. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
¡ Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
¡ Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
When you specify a NAT address group, follow these restrictions and guidelines:
· An address group cannot be used by both the nat inbound and nat outbound commands.
· An address group cannot be used by the nat outbound command in both PAT and NO-PAT modes.
· An ACL can be used by only one outbound dynamic NAT rule on an interface.
· If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
· Outbound dynamic NAT rules with ACLs configured on an interface takes precedence over those without ACLs. If two ACL-based dynamic NAT rules are configured, the rule with the higher ACL number has higher priority.
The vpn-instance parameter is required if you deploy outbound dynamic NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
Or
# Configure an outbound dynamic PAT rule on VLAN-interface 100 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Vlan-interface100] nat outbound 2001 address-group 1
[Sysname-Vlan-interface100] quit
Or
# Configure an outbound NO-PAT rule on VLAN-interface 100 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Vlan-interface100] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of VLAN-interface 100 as the translated address.
Or
# Configure an outbound NO-PAT rule on VLAN-interface 100 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1. Enable reverse address translation.
[Sysname-Vlan-interface100] nat outbound 2001 address-group 1 no-pat reversible
display nat eim
nat outbound ds-lite-b4
Use nat outbound ds-lite-b4 to configure DS-Lite B4 address translation.
Use undo nat outbound ds-lite-b4 to remove the DS-Lite B4 address translation.
nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name } address-group group-id
undo nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name }
No DS-Lite B4 address translation configuration exists.
Interface view
ipv6-acl-number: Specifies the number of an IPv6 ACL to match the IPv6 addresses of B4 elements. The value range for the argument is 2000 to 2999.
name ipv6-acl-name: Specifies the name of an IPv6 ACL to match the IPv6 addresses of B4 elements. The ACL name is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group by its ID. The value range for the group-id argument varies by device model. Port block parameters are required in the address group for DS-Lite B4 address translation.
DS-Lite B4 address translation dynamically maps a public IPv4 address and a port block to the IPv6 address of the B4 element. The DS-Lite host or hosts behind the B4 router use the mapped public IPv4 address and port block to access the public IPv4 network.
# Configure IPv6 ACL 2100 to identify packets from subnet 2000::/64.
[Sysname] acl ipv6 basic 2100
[Sysname-acl-ipv6-basic-2100] rule permit source 2000::/64
[Sysname-acl-ipv6-basic-2100] quit
# Create address group 1 and add public addresses 202.110.10.10 through 202.110.10.12 to the group.
# Set the port block size to 256.
[Sysname-address-group-1] port-block block-size 256
# Configure DS-Lite port block mapping on Ten-GigabitEthernet 1/0/1 to use address group 1 to translate packets permitted by ACL 2100.
[Sysname-Ten-GigabitEthernet1/0/1] nat outbound ds-lite-b4 2100 address-group 1
nat server
Use nat server to create a NAT server mapping (also called NAT server rule). The mapping maps the private IP address and port of an internal server to a public address and port.
Use undo nat server to delete a NAT server mapping.
Common NAT server mapping:
· A single public address with no or a single public port:
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ]
· A single public address with consecutive public ports:
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ]
· Consecutive public addresses with no public port:
nat server protocol pro-type global global-address1 global-address2 [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ]
· Consecutive public addresses with a single public port:
nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ] inside { local-address [ local-port1 local-port2 ] | [ local-address | local-address1 local-address2 ] [ local-port ] } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ]
Load sharing NAT server mapping:
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ] inside server-group group-number [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ]
No NAT server mappings exist.
Interface view
protocol pro-type: Specifies a protocol type. When the protocol is TCP or UDP, NAT Server can be configured with port information. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
· A number in the range of 1 to 255.
· A protocol name of icmp, tcp, or udp.
global: Specifies the external network information that the server uses to provide services to the external network.
global-address: Specifies the public address of an internal server.
global-address1 global address2: Specifies a public IP address range, which can include a maximum of 256 addresses. The global-address1 argument specifies the start address, and the global address2 argument specifies the end address that must be greater than the start address.
current-interface: Enables Easy IP on the current interface. The primary IP address of the interface is used as the public address for the internal server.
interface interface-type interface-number: Enables Easy IP on the interface specified by its type and number. The primary IP address of the interface is used as the public address for the internal server. Only loopback interfaces are supported.
global-port1 global-port2: Specifies a public port number range, which can include a maximum of 256 ports. The global-port1 argument specifies the start port, and the global-port2 argument specifies the end port that must be greater than the start port. The public port number format can be one of the following:
· A number in the range of 1 to 65535. Both the start port and the end port support this format.
· A protocol name, a string of 1 to 15 characters. For example, http and telnet. Only the start port supports this format.
inside: Specifies the internal information of the server.
local-address1 local-address2: Specifies a private IP address range. The local-address1 argument specifies the start address, and the local-address2 argument specifies the end address that must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port number range.
local-port: Specifies the private port number. The private port number format can be one of the following:
· A number in the range of 1 to 65535, excluding FTP port 20.
global-port: Specifies the public port number. The default value and value range are the same as those for the local-port argument.
local-address: Specifies the private IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the advertised public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the internal server belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the internal server does not belong to any VPN instance, do not specify this option.
server-group group-id: Specifies the internal server group to which the internal server belongs. With this parameter, the load sharing NAT Server feature is configured. The group-id argument specifies the internal server group ID. The value range for this argument varies by device model.
acl: Specifies an ACL. If you specify an ACL, only packets permitted by the ACL can be translated by using the mapping.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
You can configure the NAT server mapping to allow internal servers (such as Web, FTP, Telnet, POP3, and DNS servers) in the internal network or an MPLS VPN instance to provide services for external users.
NAT server mappings are usually configured on the interface connected to the external network on a NAT device. By using the global-address and global-port arguments, external users can access the internal server at local-address and local-port. When the protocol type is not udp (protocol number 17) or tcp (protocol number 6), you can configure only one-to-one IP address mappings. The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table 13 Address-port mappings for NAT Server
External network |
Internal network |
One public address |
One private address |
One public address and one public port number |
One private address and one private port number |
One public address and N consecutive public port numbers |
N consecutive private addresses and one private port number |
One private address and N consecutive private port numbers |
N consecutive public addresses |
N consecutive private addresses |
N consecutive public addresses and one public port number |
One internal server group |
Public addresses matching an ACL |
One private address and one private port |
The number of the nat server commands that can be configured on an interface varies by device model. The mapping of the protocol type, public address, and public port number must be unique for an internal server on an interface. This restriction also applies when Easy IP is used. The maximum number of NAT server mappings equals the number of public ports in the specified public port range.
As a best practice, do not configure Easy IP for multiple NAT server mappings by using the same interface.
If the IP address of an interface used by Easy IP changes and conflicts with the IP address of a NAT server mapping not using Easy IP, the Easy IP configuration becomes invalid. If the conflicting IP address is modified to another IP address or the NAT server mapping without Easy IP is removed, the Easy IP configuration takes effect.
When you configure a load shared NAT server mapping, you must make sure a user uses the same public address and public port to access the same service on an internal server. For this purpose, make sure value N in the following mappings is equal to or less than the number of servers in the internal server group:
· One public address and N consecutive public port numbers are mapped to one internal server group.
· N consecutive public addresses and a public port number are mapped to one internal server group.
The vpn-instance parameter is required if you deploy NAT Server in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Allow external users to access the internal Web server at 10.110.10.10 through https://202.110.10.10:8080.
[Sysname-Ten-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 https
# Allow external users to access the internal FTP server at 10.110.10.11 in the VPN instance vrf10 through ftp://202.110.10.10.
[Sysname-Ten-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11 vpn-instance vrf10
# Allow external hosts to ping the host at 10.110.10.12 in the VPN instance vrf10 by using the ping 202.110.10.11 command.
[Sysname-Ten-GigabitEthernet1/0/1] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12 vpn-instance vrf10
# Allow external hosts to access the Telnet services of internal servers at 10.110.10.1 to 10.110.10.100 in the VPN instance vrf10 through the public address 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can Telnet to 202.110.10.10:1001 to access 10.110.10.1, Telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-Ten-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet vpn-instance vrf10
display nat all
display nat server
nat server-group
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after static NAT is enabled on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on Vlan-interface 100.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface100] nat static enable
display nat all
display nat static
nat static
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to delete a one-to-one mapping for inbound static NAT.
nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ]
undo nat static inbound global-ip [ vpn-instance global-vpn-instance-name ]
No NAT mappings exist.
global-ip: Specifies a public IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP address does not belong to any VPN instance, do not specify this option.
local-ip: Specifies a private IP address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address does not belong to any VPN instance, do not specify this option.
acl: Specifies an ACL to identify the internal hosts that can access the external network.
ipv4-acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP address.
When the source IP address of a packet from the external network to the internal network matches the global-ip, the source IP address is translated into the local-ip. When the destination IP address of a packet from the internal network to the external network matches the local-ip, the destination IP address is translated into the global-ip.
· If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP address.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡ Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Static NAT takes precedence over dynamic NAT when they are both configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
The vpn-instance parameter is required if you deploy inbound static NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
display nat all
display nat static
nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ]
undo nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ]
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 256 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private network address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private network address does not belong to any VPN instance, do not specify this option.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP addresses.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
When the source address of a packet from the external network matches the public address range, the source address is translated into a private address in the private address range. When the destination address of a packet from the internal network matches the private address range, the destination address is translated into a public address in the public address range.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
display nat all
display nat static
nat static enable
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip global-ip
undo nat static outbound local-ip
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
· If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP address.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
The vpn-instance parameter is required if you deploy outbound static NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
display nat all
display nat static
nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ]
undo nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ]
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 256 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP addresses belong. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP addresses do not belong to any VPN instance, do not specify this option.
global-network: Specifies a public network address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public network address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public network address does not belong to any VPN instance, do not specify this option.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
acl: Specifies an ACL to define the destination IP addresses that internal hosts can access.
ipv4-acl-number: Specifies an ACL number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP addresses.
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
When the source address of a packet from the internal network matches the private address range, the source address is translated into a public address in the public address range. When the destination address of a packet from the external network matches the public address range, the destination address is translated into a private address in the private address range.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
display nat all
display nat static
nat static enable
port-block
Use port block to configure port block parameters for a NAT address group.
Use undo port block to restore the default.
port block block-size block-size [ extended-block-number extended-block-number ]
undo port block
No port block parameters are configured for a NAT address group.
NAT address group view
block-size block-size: Specifies the port block size. The value range for this argument is 1 to the upper limit. In a NAT address group, the port block size cannot be larger than the number of ports in the port range.
extended-block-number extended-block-number: Specifies the number of extended port blocks, in the range of 1 to 5. When a private IP address accesses the public network, but the ports in the selected port block are all occupied, the NAT444 gateway extends port blocks one by one for the private IP address.
To configure dynamic port block mappings, port block parameters are required in the NAT address group. When a private IP address initiates a connection to the public network, the NAT444 gateway assigns it a public IP address and a port block, and creates an entry for the mapping. For subsequent connections from the private IP address, the NAT444 gateway translates the private IP address to the mapped public IP address and the ports to ports in the selected port block.
# Set the port block size to 256 and the number of extended port blocks to 1 in NAT address group 2.
[Sysname] nat address-group 2
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
nat address-group
port-range
Use port-range to specify a port range for public IP addresses.
Use undo port-range to restore the default.
port-range start-port-number end-port-number
undo port-range
The port range for public IP addresses is 1 to 65535.
start-port-number end-port-number: Specifies the start port number and end port number for the port range. The end port number cannot be smaller than the start port number. As a best practice, set the start port number to be equal to or larger than 1024 to avoid an application protocol identification error.
The port range must include all ports that public IP addresses use for address translation.
# Specify the port range as 1024 to 65535 for NAT address group 1.
[Sysname-address-group-1] port-range 1024 65535
nat address-group
reset nat session
Use reset nat session to clear NAT sessions.
reset nat session [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears NAT sessions for all member devices.
# Clear NAT sessions for the specified slot.
<Sysname> reset nat session slot 1
display nat session
