- 11-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PTP configuration
- 05-Network synchronization configuration
- 06-SNMP configuration
- 07-NETCONF configuration
- 08-Process monitoring and maintenance configuration
- 09-Mirroring configuration
- 10-Performance management configuration
- 11-Information center configuration
- 12-Packet capture configuration
- 13-GOLD configuration
13-GOLD configuration | 76.35 KB |
Configuring monitoring diagnostics
Configuring the log buffer size
Display and maintenance commands for GOLD
Configuring GOLD
About GOLD
Generic Online Diagnostics (GOLD) performs the following operations:
· Runs diagnostic tests on a device to inspect device ports, RAM, chip, connectivity, forwarding paths, and control paths for hardware faults.
· Reports the problems to the system.
Types of GOLD diagnostics
Among the GOLD diagnostics, the device supports only monitoring diagnostics.
· Monitoring diagnostics—Run diagnostic tests periodically when the system is in operation and record test results. Monitoring diagnostics execute only non-disruptive tests.
GOLD diagnostic tests
Each kind of diagnostics runs its diagnostic tests. The parameters of a diagnostic test include test name, type, description, attribute (disruptive or non-disruptive), default status, and execution interval.
Support for the diagnostic tests and default values for a test's parameters depend on the device model. You can modify part of the parameters by using the commands provided by this document.
The diagnostic tests are released with the system software image of the device. All enabled diagnostic tests run in the background. You can use the display commands to view test results and logs to verify hardware faults.
GOLD tasks at a glance
To configure GOLD, perform the following tasks:
1. Configuring diagnostics
¡ Configuring monitoring diagnostics
2. (Optional.) Configuring the log buffer size
The system automatically executes monitoring diagnostic tests that are enabled by default after the device starts. Use the diagnostic monitor enable command to enable monitoring diagnostic tests that are disabled by default.
1. Enter system view.
2. Enable monitoring diagnostics.
diagnostic monitor enable slot slot-number-list [ test test-name ]
By default, the monitoring diagnostic tests vary in enabling status. To view the enabling status of a monitoring diagnostic test, execute the display diagnostic content command.
3. Set an execution interval for monitoring diagnostic tests.
diagnostic monitor interval slot slot-number-list [ test test-name ] time interval
By default, the execution interval varies by monitoring diagnostic test. To display the execution interval of a monitoring diagnostic test, execute the display diagnostic content command.
The configured interval cannot be smaller than the minimum execution interval of the tests. Use the display diagnostic content verbose command to view the minimum execution interval of the tests.
GOLD saves test results in the form of logs. You can use the display diagnostic event-log command to view the logs.
2. Configure the maximum number of GOLD logs that can be saved.
diagnostic event-log size number
By default, GOLD saves 512 log entries at most.
When the number of logs exceeds the configured log buffer size, the system deletes the oldest entries.
Task |
Command |
Display test content. |
display diagnostic content [ slot slot-number ] [ verbose ] |
Display GOLD logs. |
display diagnostic event-log [ error | info ] |
Display test results. |
display diagnostic result [ slot slot-number [ test test-name ] ] [ verbose ] |
Clear GOLD logs. |
reset diagnostic event-log |
Clear test results. |
reset diagnostic result [ slot slot-number [ test test-name ] ] |
GOLD configuration examples
Support for the diagnostic tests depends on the device model. Monitoring diagnostic test MonitorTest in the following configuration examples is for illustration only.
Example: Configuring GOLD
Enable monitoring diagnostic test Enable monitoring diagnostic test CpuVoqMonitor on slot 0, and set its execution interval to 1 minute.
# View the default status and execution interval of the test on slot 0.
<Sysname> display diagnostic content slot 0 verbose
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
Slot 0 :
Test name : CpuVoqMonitor
Test attributes : **M*PA
Test interval : 01:00:00
Min interval : 00:00:01
Correct-action : -NA-
Description : A Real-time test, enabled by default that checks cpu voq stat
us.
Exec : -NA-
# Enable test CpuVoqMonitor on slot 0.
[Sysname] diagnostic monitor enable slot 0 test CpuVoqMonitor
# Set the execution interval to 1 minute on slot 0.
[Sysname] diagnostic monitor interval slot 0 test CpuVoqMonitor time 0:1:0
# View the test configuration.
[Sysname] display diagnostic content slot 0 verbose
Slot 0:
Test interval : 00:01:00
us.
Exec : -NA-
# View the test result on slot 0.
[Sysname] display diagnostic result slot 0 verbose
Slot 0:
Total run count : 5
Total failure count : 0
Consecutive failure count: 0
Last execution time : Thu Feb 16 17:00:50 2023
First failure time : -NA-
Last failure time : -NA-
Last pass time : Thu Feb 16 17:00:50 2023
Last execution result : Success
Last failure reason : -NA-
Next execution time : Thu Feb 16 17:01:50 2023
