H3C WX5860X Access Controllers Installation Guide-5W102
HomeSupportWirelessWX5800X Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX5860X Access Controllers Installation Guide-5W102
08-Appendix C Removable components and compatibility matrixes
1 Removable components and compatibility matrixes
Table1-1 Compatibility matrix between the device and removable components
Removable component model
Product code
BOM code
Removable power supplies
PSR650B-12A1
PSR650B-12A1-D
0231AE0D
PSR650B-12D1
PSR650B-12D1-GL
0231ABDH
Removable fan trays
LSWM1BFANSCB
LSWM1BFANSCB
0231ACJP
Expansion modules
EWPXM1BSTX80
EWPXM1BSTX80
0231AFH1
WARNING
WARNING!
To avoid device damage or even bodily injury, make sure the power supply is powered off when you install or remove a power supply.
The device uses removable power supplies and supports the PSR650B-12A1 and PSR650B-12D1 power supplies.
You can install one power supply, two power supplies, three power supplies, or four power supplies in redundancy for the device.
Table1-2 Power supplies available for the device
Power supply model
Specifications
PSR650B-12A1
·     Rated input voltage range: 100 to 240 VAC @ 56/60 Hz
·     Max input voltage range: 90 to 264 VAC @ 47 to 63 Hz
·     Max output power: 650 W
PSR650B-12D1
·     Rated input voltage range: –40 to –60 VDC
·     Max input voltage range: –40 to –72 VDC
·     Melting current of power supply fuse: 30 A/250 V
Removable fan trays
The device uses removable fan trays and supports the LSWM1BFANSCB fan trays.
Table1-3 LSWM1BFANSCB fan tray specifications
Item
Specifications
Dimensions (H × W × D)
80 × 80 × 232.6 mm (3.15 × 3.15 × 9.16 in)
Fan speed
20000 R.P.M
Max airflow
120 CFM
Input voltage
12 V
Maximum power consumption
57 W
Airflow direction
From the port side to the power supply side
Expansion modules
Table1-4 Expansion module specifications
Item
Specifications
EWPXM1BSTX80
Hardware acceleration module
Port type and quantity
·     8 × 1000BASE-T Ethernet copper ports
·     8 × GE SFP fiber ports
·     8 × 10GE SFP+ fiber ports
·     2 × 40GE QSFP+ fiber ports
A 1000BASE-T Ethernet copper port and a GE SFP fiber port form a combo interface. A 10GE SFP+ fiber port and a 40GE QSFP+ fiber port cannot be used simultaneously.
Available transceiver modules and cables
SFP-GE-SX-MM850-A and SFP-GE-LX-SM1310-A transceiver modules in Table1-5.
SFP+ transceiver modules and cables in Table1-6 and Table1-7.
QSFP+ transceiver modules and cables in Table1-8 and Table1-9..
Transceiver module, fiber connector, and optical fiber views
To connect a fiber port on the device, use an SFP transceiver module and an optical fiber with LC connectors.
Figure1-1 SFP transceiver module
Figure1-2 SFP+ transceiver module
Figure1-3 Optical fiber with LC connectors
(1) LC connector
(2) Optical fiber
Transceiver module specifications
Table1-5 GE SFP transceiver modules available for the SFP and SFP+ ports
Central wavelength (nm)
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
Max transmission distance
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
Multi-mode, 62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
Table1-6 10-GE SFP+ transceiver modules available for the SFP+ ports
10-GE SFP+ module
Connector
Fiber diameter (µm)
Multimode fiber modal bandwidth (MHz × km)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-SX-MM850-E
850
LC
Multi-mode, 50/125
N/A
300 m (984.25 ft)
N/A
33 m (108.27 ft)
Table1-7 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
Cable length
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
Table1-8 QSFP+ transceiver modules available for the QSFP+ ports
Connector
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
Table1-9 QSFP+ cables available for the QSFP+ ports
QSFP+ network cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
