H3C WX5860X Access Controllers Installation Guide-5W102
HomeSupportWirelessWX5800X Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX5860X Access Controllers Installation Guide-5W102
07-Appendix B LEDs
07-Appendix B LEDs 250.68 KB
1 Appendix B  LEDs
LEDs
Figure1-1 LEDs on the front panel
(1) System status LED (SYS)
(2) Management Ethernet copper port status LEDs (LINK/ACT)
(3) Power supply status LEDs (3 and 4, 7 and 8)
(4) Fan tray status LEDs (5 and 6)
Figure1-2 LEDs on the rear panel
(1) 1000Base-T Ethernet port status LED
(2) SFP port status LED
(3) 10G SFP+ port status LED
(4) 40G QSFP+ port status LED
LED description
Table1-1 LED description
LED
Mark
Status
System status LED
SYS
Fast flashing green (4 Hz)
The system is starting up.
Slow flashing green (0.5 Hz)
The system is operating correctly.
Steady red
A critical alarm has been triggered, for example, power supply alarm, fan tray alarm, high temperature alarm, and software loss.
Off
No power is present.
LINK/ACT
Steady green
A 100/1000 Mbps link is present.
Flashing green
The port is receiving or transmitting data at 100/1000 Mbps.
Off
No link is present.
N/A
Steady green
The power supply is operating correctly and in active state.
Flashing green
The power supply is operating correctly and in standby state.
Steady red
The power supply is faulty or has entered self-protection mode.
Alternative flashing red/green
An alarm has occurred on the power supply. The power supply has exceptional power output issues, for example, overvoltage output, undervoltage output, overcurrent output, overload, and overtemperature, but does not enter protection state.
Flashing red
The power supply does not have power input. The device has two power supplies. If one has power input, but the other does not, the status LED of the power supply that does not have power input flashes red.
Off
No power input.
Fan tray status LED
N/A
On
The fan tray is operating incorrectly.
Off
The fan tray is operating correctly or the device is not powered on.
10/100/1000BASE-T Ethernet port status LED
N/A
Steady green
A 1000 Mbps link is present on the port.
Flashing green
The port is receiving or transmitting data at 1000 Mbps.
Off
No link is present on the port.
SFP port status LED
N/A
Steady green
Flashing green
Off
N/A
Steady green
A 10 Gbps link is present on the port.
Flashing green
The port is receiving or transmitting data at 10 Gbps.
Off
N/A
Steady green
A 40 Gbps link is present on the port.
Flashing green
The port is receiving or transmitting data at 40 Gbps.
Off
