- H3C WX5860X Access Controllers Installation Guide-5W102
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Troubleshooting
- 05-Hardware management and maintenance
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Removable components and compatibility matrixes
06-Appendix A Chassis views and technical specifications | 370.01 KB |
1 Appendix A Chassis views and technical specifications
Chassis views
(1) USB ports |
(2) Serial console port |
(3) SHUT DOWN button LED |
(4) Fan tray 1 |
(5) Fan tray 2 |
(6) Grounding screw (auxiliary grounding point 2) |
(7) Power supply 4 |
(8) Power supply 3 |
(9) Power supply 2 |
(10) Management Ethernet copper port |
(11) Power supply 1 |
NOTE: Pressing the SHUT DOWN button LED powers on the device. If you press and hold the button LED for more than 2 seconds, the LED is fast flashing at 1 Hz. You must wait for the device to notify the x86 operating system to shut down, and you can power off the device only when the LED turns off. |
(1) Expansion module slot 1 |
(2) Expansion module slot 2 |
(3) Expansion module slot 4 (reserved) |
(4) Expansion module slot 3 (reserved) |
The device comes with the expansion module slot 1 empty and the other expansion module slots each installed with a filler panel. You can install expansion modules only in Slot 1 and Slot 2. Slot 3 and Slot 4 are reserved. You can install one to two expansion modules for the device as needed. In Figure1-2, expansion modules are installed in two expansion module slots.
The device comes with power supply slot PWR1 empty and the other power supply slots each installed with a filler panel. You can install one to four power supplies for the device as needed. In Figure1-1, four power supplies are installed in the power supply slots.
The device comes with the two fan tray slots empty. In Figure1-1, two fan trays are installed in the fan tray slots.
Figure1-3 Left panel
(1) Fan tray handle |
(2) Primary grounding point |
(3) Auxiliary grounding points |
(4) Power supply handle |
Technical specifications
Table1-1 Technical specifications
Item |
Specification |
Console port |
One |
1 × 100M/1000M Base-T copper port |
USB port |
2 |
Memory |
64GB DDR4 |
Storage media |
32GB eMMC |
Dimensions (H × W × D) (excluding rubber feet and mounting brackets) |
88.1 × 440 × 660 mm (3.47 × 17.32 × 25.98 in) |
AC power supply |
Rated voltage range: 100 to 240 VAC @ 50/60 Hz |
DC power supply |
Rated voltage range: –40 VDC to –60 VDC |
System power consumption |
184W~502W |
Weight |
< 22.9 kg (50.48 lb) |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Ports
Console port
The device has a serial console port.
Table1-2 Console port specifications
Item |
Connector type |
RJ-45 |
Compliant standard |
EIA/TIA-232 |
Transmission baud rate |
9600 bps |
Services |
Provides connection to the serial port of a local terminal (a PC for example) running a terminal emulation program |
Management Ethernet port
The device has on management Ethernet copper port. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table1-3 Management Ethernet copper port specifications
Item |
Specification |
Connector type |
RJ-45 |
Port transmission rate, duplex mode, and auto MDI/MDI-X |
100/1000BASE-T management port:. · 100 Mbps, half/full duplex, auto MDI/MDI-X. · 1000 Mbps, full duplex, auto MDI/MDI-X. |
Transmission medium and max transmission distance |
100 m (328.08 ft) over category-5 UTP cable. |
Functions and services |
Software upgrade and network management. |
USB port
The device has one OHCI-compliant USB 2.0 port that can upload and download data at a rate up to 480 Mbps. You can use this USB port to access the file system on the flash of the device, for example, to upload or download application and configuration files.
The USB port supplies power as per USB 2.0 specifications. Use only USB 2.0-compliant USB devices for the USB port. The port might not identify USB devices that are not compliant with USB 2.0.
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices of all vendors on the device. If a USB device fails to operate on the device, replace it with one from another vendor. |
