H3C WX5860X Access Controllers Installation Guide-5W102
HomeSupportWirelessWX5800X Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX5860X Access Controllers Installation Guide-5W102
05-Hardware management and maintenance
05-Hardware management and maintenance 98.74 KB
1 Hardware management and maintenance
The command lines and outputs depend on the software version that runs on the device and the numbers of power supplies, expansion modules, and fan trays installed on the device.
Displaying hardware information for the device
Use the display version command to display software and hardware version information about the device. The output includes the following information:
·     Current software version.
·     Current hardware version.
·     Device operating time.
The output depends on the software and hardware version of the device.
<H3C> display version
H3C Comware Software, Version 7.1.064, ESS 5457
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C WX5860X uptime is 0 weeks, 0 days, 15 hours, 51 minutes
Last reboot reason : User soft reboot
Boot image: flash:/boot.bin
Boot image version: 7.1.064, ESS 5457
  Compiled Jul 11 2022 16:00:00
System image: flash:/system.bin
System image version: 7.1.064, ESS 5457
Slot 1
Uptime is 0 week, 0 day, 15 hour, 51 minutes
with 1 1899MHz Multi-core Processor
47840M bytes SDRAM
7139M bytes Flash
PCB 1 Version is Ver.A
PCB 2 Version is Ver.A
CPLD 1 Version is 003
CPLD 2 Version is 003
CPLD 3 Version is 003
Basic Bootrom Version is 1.03
Extend Bootrom Version is 1.07
[Subslot 0]WX5860X Hardware Version is Ver.A
[Subslot 1]EWPXM1BSTX80 Hardware Version is Ver.A
[Subslot 1]EWPXM1BSTX80 CPLD Version is 002
[Subslot 1]EWPXM1BSTX80 FPGA1 Logic Version 008
[Subslot 1]EWPXM1BSTX80 FPGA2 Logic Version 005
Displaying operational statistics for the device
When you perform routine maintenance or the system fails, you might need to display the operational information of each feature module to locate failures. Typically, you need to run the display commands individually. However, you can use the display diagnostic-information command in any view to display or save the operational statistics of multiple feature modules of the device. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
·     Save the operational statistics for each feature module of the device:
<H3C> display diagnostic-information
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_H3C_20220713-021712.tar.gz]:
Diagnostic information is outputting to flash:/diag_H3C_20220713-021712.tar.gz.
Please wait...
Save successfully.
To view the contents of the default.diag file, execute the more default.diag command in user view, and then press the Page Up and Page Down keys.
·     Display the operational statistics for each feature module of the device. (Details not shown.)
11:11:27 Beijing Tue 09/14/2022
Time Zone : Beijing add 08:00:00
H3C Comware Software, Version 7.1.064, Alpha ESS 5457
Slot 1
Uptime is 0 week, 0 day, 15 hours, 51 minutes
47840M bytes SDRAM
7139M bytes Flash
[Subslot 0]WX5560X Hardware Version is Ver.A
Displaying information about the device
Use the display device command to display information about the device.
<H3C> display device
Slot No.  Subslot No. Board Type        Status    Max Ports
2         0           WX5860X           Normal    1
2         1           EWPXM1BSTX80      Normal    18
Table1-1 Command output
Board Type
Device type.
Status
Device status:
·     Fault—The device is faulty and cannot start up correctly.
·     Normal—The device is operating correctly.
Max Ports
Maximum number of ports supported.
Displaying the electronic label data for the device
An electronic label is a profile of a device. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name.
Use the display device manuinfo command to display the electronic label data for the device.
<H3C> display device manuinfo
 Slot 2 CPU 0:
DEVICE_NAME:WX5860X
DEVICE_SERIAL_NUMBER:210235A4C7CM00000528
MAC_ADDRESS:a069-d93c-b650
MANUFACTURING_DATE:2022-03-08
VENDOR_NAME:H3C
Subslot 1:
DEVICE_NAME          :EWPXM1BSTX80
DEVICE_SERIAL_NUMBER :210231AFH1B222000089
MANUFACTURING_DATE   :2022-02-26
VENDOR_NAME          :H3C
Fan 1:
DEVICE_NAME          :LSWM1BFANSCB-SN
DEVICE_SERIAL_NUMBER :210231AG9KP2180000CW
MANUFACTURING_DATE   :2021-08-13
VENDOR_NAME          :H3C
Fan 2:
DEVICE_SERIAL_NUMBER :210231AG9KP21800006S
VENDOR_NAME          :H3C
Power 4:
DEVICE_NAME          :LSVM1AC650
DEVICE_SERIAL_NUMBER :210231AE0DH173001734
MANUFACTURING_DATE   :2021-02-15
VENDOR_NAME          :H3C
Table1-2 Command output
DEVICE_NAME
Device model.
Serial number of the device.
MAC_ADDRESS
MAC address of the device.
MANUFACTURING_DATE
Manufacturing data of the device.
VENDOR_NAME
Vendor name.
Displaying the CPU usage of the device
Use the display cpu-usage command to display the CPU usage statistics for the device.
<H3C> display cpu-usage
Slot 2 CPU 0 CPU usage:
      0% in last 5 seconds
      1% in last 1 minute
      1% in last 5 minutes
Table1-3 Command output
CPU usage information.
Average CPU usage in the last 5 seconds (after the device boots, the device calculates and records the average CPU usage at the interval of 5 seconds).
1% in last 1 minute
Average CPU usage in the last minute (after the device boots, the device calculates and records the average CPU usage at the interval of 1 minute).
Average CPU usage in the last 5 minutes (after the device boots, the device calculates and records the average CPU usage at the interval of 5 minutes).
Displaying the memory usage of the device
Use the display memory command to display the memory usage statistics for the device.
<H3C> display memory
Memory statistics are measured in KB:
Slot 2:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      48988860   8127136  40861724         0     2740   233348       83.5%
-/+ Buffers/Cache:   7891048  41097812
Swap:           0         0         0
Table1-4 Command output
Slot x
IRF member device ID of the device.
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Used physical memory for cache.
FreeRatio
Free memory ratio.
–/+ Buffers/Cache
·     -/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
·     -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Displaying the operational status of the built-in fans
Use the display fan command to display the operating states of fans.
<H3C> display fan
Fan 1 State: Normal
Fan 2 State: Normal
Table1-5 Command output
Fan n
Fan No..
Fan state:
·     Normal—The fan is operating correctly.
·     Absent—The fan is not in position.
·     Fault—The fan has failed.
Displaying the operating state of power supplies
Use the display power command to display the operating state of power supplies.
<H3C> display power
Power 1 State: Normal
Power 2 State: Normal
Power 3 State: Normal
Power 4 State: Normal
Table1-6 Command output
Power 1, 2, 3, 4
Power supply No..
Power supply state:
·     Normal—The power supply is operating correctly.
·     Absent—The power supply is not in position.
·     Fault—The power supply has failed.
Rebooting the device
To reboot the device, use one of the following methods:
·     Reboot the device at the CLI. You can remotely reboot the device in either of the following ways:
¡     Reboot the device immediately by using the reboot command.
¡     Schedule a reboot to occur at a specific time or date or after a delay by using the schedule reboot command.
·     Power off and power on the device. This method cuts off the power of the device forcibly, which might cause data loss. It is the least-preferred method.
·     Before you reboot the device, perform the following tasks:
¡     Use the save command to save the running configuration. For more information about the save command, see configuration file management commands in the command references.
¡     Use the display startup and display boot-loader commands to verify that you have specified the correct next-startup configuration files and startup software images. If the main startup software image is corrupt or does not exist, a reboot failure will occur. To avoid a reboot failure, use the boot-loader file command to specify a new startup software image. For more information about the display startup and display boot-loader commands, see software upgrade commands in the command references.
·     The device will not reboot if a file is being accessed.
Configuration procedure
Rebooting the device immediately
Remarks
Reboot the device immediately.
reboot [ force ]
Available in user view.
Scheduling a reboot for the device
Remarks
Schedule a reboot.
·     Schedule a reboot to occur at a specific time or date:
schedule reboot at time [ date ]
·     Schedule a reboot to occur after a delay:
schedule reboot delay time
Use either command.
By default, no reboot date or time or reboot delay time is specified.
The most recent configuration takes effect if you execute the scheduler reboot at or scheduler reboot delay command multiple times.
