H3C RA5300 Router Hardware Information and Specifications-6W100
HomeSupportRouters5G IPRAN Access RoutersProduct LiteratureHardware Information & SpecificationsH3C RA5300 Router Hardware Information and Specifications-6W100
04-Slot Arrangement and Interface Numbering
04-Slot Arrangement and Interface Numbering 506.72 KB
4 Slot arrangement and interface numbering
Slot arrangement
"RSU" in Table4-1 refers to a routing and switching unit.
Table4-1 Slot arrangement
: Routing and switching unit slot
: HRIC module slot
: Power supply slot
: Fan tray slot
Interface numbering
Conventions
RSU
The interfaces on a routing and switching unit are numbered in the interface-type X format. The management port number on the routing and switching unit is M-Ethernet 0.
Where,
·     interface-type—Interface type, for example, Console.
·     XNumber of the slot where the RSU resides, as shown in Table4-1.
Interface module
The interfaces on an interface module are numbered in the interface-type X/Y/Z format.
Where,
·     interface-type—Interface type, for example, GigabitEthernet and Twenty-FiveGigE.
·     XNumber of the slot where the interface module resides, as shown in Table4-1.
·     Y—The numbers is 0.
·     Z—Number of the interface on the interface module. The number starts from 0.
·     If an RSU-300 routing and switching unit is installed in slot 0 of the router, the console port of the RSU-300 is numbered Console 0.
·     If an RSU-300 routing and switching unit is installed in slot 1 of the router, the console port of the RSU-300 is numbered Console 1.
·     If an HRIC-GP8 module is installed in slot 8 of the router, ports 0 to 7 on the HRIC-GP8 module are numbered GigabitEthernet 8/0/0 to GigabitEthernet 8/0/7, respectively.
