H3C RA5300 Router Hardware Information and Specifications-6W100
HomeSupportRouters5G IPRAN Access RoutersProduct LiteratureHardware Information & SpecificationsH3C RA5300 Router Hardware Information and Specifications-6W100
03-LEDs
03-LEDs 499.66 KB
3 LEDs
Routing and switching unit LEDs
RSU-300
Figure3-1 RSU-300 routing and switching unit LEDs
(1) System status LED (SYS)
(2) Running status LED (RUN)
(3) Active/standby status LED (ACT)
(4) Management Ethernet port LED (MANAGEMENT)
(5) Clock synchronization LED (SYNC)
(6) High severity alarm LED (ALARM H)
(7) Low severity alarm LED (ALARM L)
Table3-1 RSU-300 routing and switching unit LED descriptions
LED
Status
Descriptions
SYS
Flashing green (eight times per second)
·     BIOS stage—BIOS is starting up.
·     BootWare stage—The system software image is being decompressed.
Flashing yellow (once per second)
·     BIOS stage—The memory does not exist or system initialization has failed.
·     BootWare stage—The SDRAM has failed the POST.
Flashing yellow (eight times per second)
The extended segment does not exist (BIOS stage).
Steady green
·     BootWare stage—The SDRAM is being tested.
·     Comware stage—The kernel is starting up.
Flashing green (once per second)
The Comware system is starting up or is operating correctly (Comware stage).
Steady yellow
The boot.bin file does not exist (BootWare stage).
Off
A system hardware failure has occurred.
RUN
BIOS has started up and BootWare is starting up.
Flashing red (once per second)
Steady green
The Comware system is starting up or is operating correctly.
Off
No power is present.
ACT
Steady green
The routing and switching unit is in active mode.
The routing and switching units are establishing active and standby roles.
Off
The routing and switching unit is in standby mode.
MANAGEMENT
Steady green
A 100 Mbps link is present on the port.
Flashing green
The port is sending or receiving data at 100 Mbps.
Off
No link is present on the port.
SYNC
Steady green
The system clock is in free-run mode and no clock source is specified for the system clock.
Steady yellow
The system clock is in traced mode and is tracing a clock source in the clock source priority list.
Off
The system clock is in locked mode, and the PTP clock is tracing a clock source.
ALARM H
Steady red
A high severity alarm has occurred on the device.
Off
No high severity alarm has occurred on the device.
ALARM L
Steady yellow
A low severity alarm has occurred on the device.
Off
No low severity alarm has occurred on the device.
RSU-400
Figure3-2 RSU-400 routing and switching unit LEDs
Table3-2 RSU-400 routing and switching unit LED descriptions
LED
Status
Descriptions
SYS
Steady green
Steady yellow
Off
RUN
The routing and switching unit is collecting diagnostic information.
Steady green
Off
ACT
Steady green
Off
MANAGEMENT
Steady green
Flashing green
Off
SYNC
Steady green
·     The system clock is in free running mode and no clock source priority list is configured for the system clock.
·     The system clock is tracing a clock source in the clock source priority list.
·     The system clock is in time synchronization mode, and the PTP clock and system clock are tracing clock sources.
Steady yellow
All the clock sources except for the internal source have been lost, and system clock works in holdover or free running mode.
Off
The system is not powered on, or synchronization is not performed during the startup process of the module.
ALARM H
Steady red
Off
ALARM L
Steady yellow
Off
RSU-400S
Figure3-3 RSU-400S routing and switching unit LEDs
Table3-3 RSU-400S routing and switching unit LED descriptions
LED
Status
Descriptions
SYS
Steady green
Steady yellow
Off
RUN
Steady green
Off
ACT
Steady green
Off
MANAGEMENT
Steady green
Flashing green
Off
SYNC
Steady green
Steady yellow
Off
ALARM H
Steady red
Off
ALARM L
Steady yellow
Off
Interface module LEDs
The router supports HRIC interface modules. For more information of the HRIC interface module LEDs, see H3C RA5300 Router Interface Module Manual.
Fan tray LEDs
FAN-60-6-A
Figure3-4 FAN-60-6-A fan tray LEDs
(1) Fan tray status LED (FAN)
Table3-4 Fan tray LED descriptions
LED
Status
Descriptions
FAN
Steady green
The fan tray is operating correctly.
Steady red
The fan tray is faulty.
Off
No power is present on the fan tray, or the fan tray is not in place.
Power supply LEDs
Figure3-5 Power supply LEDs
(1) Power supply status LED (PWR)
Table3-5 Power supply LED descriptions
LED
Status
Descriptions
PWR
Steady green
The power supply is operating correctly.
Off
