02-Removable Components | 713.57 KB |
2 Removable components
The component figures in this section are for illustration only.
Component views
Routing and switching units
The routing and switching unit is the core component of the router. It runs the system software and saves system configuration information. It delivers the following functions:
· Protocol processing
· Data packet forwarding
· Interface control
· Fault detection
RSU-300
Figure2-1 RSU-300 routing and switching unit front panel
(1) Ejector lever |
(2) ALMI/ALMO port |
(3) ToD port |
(4) Console port (CONSOLE) |
(5) CLK port |
(6) Management Ethernet port |
(7) Reset button (RESET) |
(8) Captive screw |
RSU-400
Figure2-2 RSU-400 routing and switching unit front panel
(1) Ejector lever |
(2) Diagnostic button (DIAG) |
(3) ALMI/ALMO port |
(4) ToD port |
(5) Console port (CONSOLE) |
(6) CLK port |
(7) Management Ethernet port |
(8) Reset button (RESET) |
(9) Captive screw |
RSU-400S
Figure2-3 RSU-400S routing and switching unit front panel
(1) Ejector lever |
(4) ToD port |
(6) CLK port |
(9) Captive screw |
Interface modules
The router supports HRIC interface modules. For more information of the HRIC interface modules, see H3C RA5300 Router Interface Module Manual.
Power supplies
Figure2-4 DC power supply front panel
(1) DC power receptacle |
(2) Captive screw |
Fan trays
FAN-60-6-A
Figure2-5 FAN-60-6-A fan tray front panel
(1) Handle |
(2) Captive screw |
(3) ESD jack |
Technical specifications
Table2-1 Specifications of the routing and switching units
Item |
RSU-300 |
RSU-400/RSU-400S |
Console port |
1 |
1 |
1 |
1 |
ALMI/ALMO port |
1 |
1 |
ToD port |
1 |
1 |
CLK port |
1 |
1 |
Reset button |
1 |
1 |
N/A |
1 |
Memory |
8GB DDR4 |
8GB DDR4 |
Flash |
4 GB |
4 GB |
IMPORTANT: · Do not install routing and switching units of different models on the same router. · For correct clock synchronization, use a shielded cable to connect the ToD port on a routing and switching unit. |
Interface modules
Power supplies
Table2-2 DC power supply specifications
Item |
Specifications |
Model |
RT-PWR-RA5300-D |
Rated input voltage range |
–48 VDC to –60 VDC |
Max input current |
30 A |
Table2-3 Fan tray specifications
Item |
Specifications |
Model |
FAN-60-6-A |
Number of fans |
6 (support for automatic speed adjustment) |
Hot swapping |
Supported |
Power cables
A DC power cable is used to connect a DC power supply to an external DC power supply system.
See Table2-4 for the DC power cables supported by the PWR-RA5300-D DC power supply available for the router.
Table2-4 DC power cable specifications
BOM No. |
Length |
0404A17M |
5 m (16.40 ft) |
Fan trays
The FAN-60-6-A fan tray is available for the router. The fan tray has six fans and can automatically adjust the rotation speed based on the device temperature. The fan tray is hot swappable.
