01-Installation Guide | 2.82 MB |
Examining the installation environment
Examining the installation site
Checking power distribution or power supply environment
Installing the switch in a 19-inch rack
Attaching mounting brackets to the switch
Mounting the switch in the rack
Grounding the switch by using a grounding strip
Verifying the connection after grounding the switch
Installing and removing fan trays
Installing and removing power supplies
Connecting the power cord for a PSR250-12A/PSR250-12A1 power supply
Connecting the power cord for a PSR450-12D power supply
3 Accessing the switch for the first time
Connecting the switch to a configuration terminal
Connecting a DB9-to-RJ45 console cable
Connecting a USB-to-RJ45 console cable
Planning IRF fabric size and the installation site
Identifying the master switch and planning IRF member IDs
Planning IRF topology and connections
Reserving physical IRF ports on the member switches
Configuring basic IRF settings
Connecting the physical IRF ports
Verifying the IRF fabric setup
5 Maintenance and troubleshooting
Configuration terminal display issues
1 Preparing for installation
This document is applicable to the following Ethernet switches:
Table1-1 Switch series and models
Switch series |
Switch model |
Product code (PID) |
S6530X switch series |
S6530X-48Y8C |
LS-6530X-48Y8C |
S6530X-48X8C |
LS-6530X-48X8C |
S6530X-24Y8C |
LS-6530X-24Y8C |
S6530X-24X8C |
LS-6530X-24X8C |
Safety recommendations
To avoid any equipment damage or bodily injury caused by improper use, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
· Before cleaning the switch, remove all power cords from the power supplies. Do not clean the switch with wet cloth or liquid.
· Do not place the switch near water or in a damp environment. Prevent water or moisture from entering the switch chassis.
· Do not place the switch on an unstable case or desk. The switch might be severely damaged in case of a fall.
· Ensure good ventilation of the equipment room and keep the air inlet and outlet vents of the switch free of obstruction.
· Make sure the power input voltage is as required by the power supply.
· To avoid electrical shocks, do not open the chassis while the switch is operating or when the switch is just powered off.
· Wear an ESD wrist strap when you replace a removable power supply or fan tray. Make sure the strap makes good skin contact and is reliably grounded.
To ensure correct operation of your switch, make sure the installation environment meets the requirements listed in Table1-2.
Table1-2 Checking list for the installation environment
Item |
Requirements |
Ventilation and heat dissipation |
To ensure correct operation of your device, make sure the installation environment is adequately ventilated to prevent the switch from overheating. · Ensure a minimum clearance of 10 cm (3.94 in) around the chassis. · Do not install the device near a heat source, for example, a stove or heater. · Ensure air ventilation in the installation environment. · Do not block the ventilation holes in the device or power adapter. |
Anti-moisture |
Water or moisture might damage the circuits of the device. · Do not place the device near water or in a damp environment. · Install the switch in a clean, dry, and ventilated place where temperature is controlled in a stable range. · Make sure the installation environment is free from water leakage or condensation. If required, install a dehumidification device (such as an air conditioner with a dehumidification function or a dedicated dehumidifier). · Do not operate the device under or near the water source, such as the wash basin, laundry room, or areas with high humidity. · Do not touch the device with wet hands. |
Temperature/humidity |
For correct operation and long service life of your switch, maintain the temperature and humidity in the equipment room at acceptable ranges. · Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion. · Lasting low relative humidity can cause washer contraction and ESD and cause issues including loose mounting screws and circuit failure. · High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the switch. For the temperature and humidity requirements of the switch, see technical specifications in the hardware information and specifications for the switch. |
Lightning protection |
Ground the switch correctly and verify the grounding. For more information, see "Grounding the switch." · If you ground the switch by using a grounding strip, make sure the grounding resistance of the grounding strip in the equipment room is less than 1W. · If you ground the switch by using a grounding conductor buried in the earth ground, make sure the grounding resistance of the grounding conductor in the ground is less than 10W. · Route the signal cables along indoor walls, bury the cables in the earth ground, or thread the cables through steel tubes. Install a signal lightning arrester with a nominal discharge current for a corresponding network interface. · Keep the signal cables far from power cords and lightning rod down conductors. · As a best practice, route power cords indoors. If an AC power cord is routed from outdoors, connect the AC power cord first to a power lightning arrester before leading it to the AC power port on the switch. Make sure the power lightning arrester has a nominal discharge current and the total length of the power cord from the power lighting arrester to the power port on the switch is less than 5 m (16.40 ft). · Ground the switch, rack, independent power supplies, and lightning arresters separately. · You must ground optical fibers with reinforcing metal stiffener from outdoors on an optical distribution frame (ODF) or fiber splice enclosure. |
Cable routing |
Do not run an Ethernet cable and power cord in parallel. · Route different types of cables separately. · Keep power cords a minimum of 5 cm (1.97 in) away from other cables. |
ESD prevention |
· Ground the switch correctly. · To avoid ESD damage to the device or removable components, always wear an ESD wrist strap when you install or remove the device or removable components. · Make sure the wrist strap has good skin contact and is reliably grounded. |
Cleanliness |
For more information, see "Cleanliness." |
Corrosive gas prevention |
The installation site must be free from corrosive gases such as acid gases and alkaline gases. For more information, see "Corrosive gas limits." |
EMI |
· If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid. · Keep the device far away from radio transmitting stations, radar stations, and high-frequency devices. · Use electromagnetic shielding, for example, shielded interface cables, when necessary. |
Cleanliness
Dust buildup on the chassis might cause electrostatic adsorption and dust corrosion, resulting in poor contact of metal connectors and contact points. This might shorten the device's lifetime and even cause device failure in the worst case. Table1-3 describes the switch requirement for cleanliness.
Table1-3 Switch requirement for cleanliness
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 0.5 µm |
≤ 1.8 × 107 particles/m3 |
To maintain cleanliness in the equipment room, follow these guidelines:
· Keep the equipment room away from pollution sources. Do not smoke, eat, or drink in the equipment room.
· Use double-layer glass in windows and seal doors and windows with dust-proof rubber strips. Use screen doors and window screens for doors and windows open to the outside and make sure the external windows are air tight.
· Use dustproof materials for floors, walls, and ceilings and use wallpaper or matt paint that does not produce powders.
· Clean the equipment room regularly and clean the air filters of the rack each month.
· Wear ESD clothing and shoe covers before entering the equipment room, keep the ESD clothing and shoe covers clean, and change them frequently.
Corrosive gases can accelerate corrosion and aging of metal components. Make sure the corrosive gases do not exceed the concentration limits as shown in Table1-4.
Table1-4 Corrosive gas concentration limits
Gas |
Average concentration (mg/m3) |
Maximum concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
CAUTION: As a best practice, control the corrosive gas concentrations in the equipment room at their average values. Make sure the corrosive gas concentrations do not exceed 30 minutes per day at their maximum values. |
To control corrosive gases, use the following guidelines:
· As a best practice, do not build the equipment room in a place with a high concentration of corrosive gases.
· Make sure the equipment room is not connected to sewer, vertical shaft, or septic tank pipelines and keep it far away from these pipelines. The air inlet of the equipment room must be away from such pollution sources.
· Use environmentally friendly materials to decorate the equipment room. Avoid using organic materials that contains harmful gases, such as sulfur or chlorine-containing insulation cottons, rubber mats, sound-proof cottons, and avoid using plasterboards with high sulfur concentration.
· Place fuel (diesel or gasoline) engines separately. Do not place them in the same equipment room with the device. Make sure the exhausted air of the engines will not flow into the equipment room or towards the air inlet of the air conditioners.
· Place batteries separately. Do not place them in the same room with the device.
· Employ a professional company to monitor and control corrosive gases in the equipment room regularly.
Before you install the switch, verify that the installation site meets the installation requirements. The switch can operate correctly in an A1 or A2 installation site. Availability issues might occur if you install the switch in an A3, B1, B2, or C installation site.
Category |
Definition |
Example |
A1: indoor controlled environment |
· Indoor environments where temperature and humidity are controlled. · Completely enclosed or shielded indoor environments. |
Central equipment rooms, IDC equipment rooms, mobile cabins with air conditioners, outdoor air conditioner cabinets, and heat exchanger cabinets. |
A2: indoor partially controlled environment |
· Indoor environments where temperature and humidity are partially controlled. · Incompletely enclosed or shielded places. · Places far from pollution sources. |
Simple equipment rooms, ordinary houses, garages, corridors, and direct ventilation cabinets far from pollution sources, houses without direct exposure to sunlight or rain, railway station platforms, and stadiums. |
A3: indoor uncontrolled environment |
· Indoor environments where temperature and humidity are uncontrolled. · Incompletely enclosed or shielded places. · Places near pollution sources. |
Simple equipment rooms, ordinary houses, garages, corridors, and direct ventilation cabinets near pollution sources, houses without direct exposure to sunlight or rain, railway station platforms, stadiums, uncleaned rooms after decoration, and rooms under decoration. |
B1: outdoor general environment |
· Unshielded places where the temperature and humidity are not controlled. · Places far from pollution sources. |
Completely exposed outdoor places far from pollution sources. |
B2: harsh environment |
· Unshielded places where the temperature and humidity are not controlled. · Sea environments or outdoor land environments near pollution sources. |
Islands, ships, and completely exposed outdoor places near pollution sources. |
C: special environments |
Special application environments |
Buried, underwater, or undersea environments and manholes. |
Table1-6 Pollution sources
Category |
Radius range |
Saline water areas such as oceans and saline lakes |
≤ 3.7 km (2.30 miles) |
Serious pollution sources such as metallurgic plants, coal mines, and heat and power plants |
≤ 3 km (1.86 miles) |
Medium pollution sources such as chemical factories, rubber plants, and electroplating factories |
≤ 2 km (1.24 miles) |
Light pollution sources, such as food factories, tanneries, and heating boilers |
≤ 1 km (0.62 miles) |
Table1-7 Requirements for power distribution or power supply environment
Item |
Requirements |
Preparation |
The power supply must be available before you install the switch. |
Voltage |
The voltage provided to the switch must be within the operating voltage range. For the operating voltage range, see technical specifications in the hardware information and specifications for the switch. |
Power receptacle and cables |
· If the external power supply system provides an AC power outlet, prepare a country-specific AC power cord yourself. Make sure the PE wire of the AC power supply is grounded reliably. · If the external power supply system provides a DC distribution box, prepare DC power cords yourself. · Do not use the power cord provided with the switch on other devices. |
Laser safety
WARNING! The switch is Class 1 laser device. Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the switch is operating. |
Installation tools
No installation tools are provided with the switch. Prepare the following tools yourself as required:
· Flathead screwdriver
· Phillips screwdriver
· ESD wrist strap
· Marker
Installation accessories
Table1-8 Installation accessories
Part number |
Quantity |
2150A0JG |
Mounting bracket kit, including a pair of mounting brackets and eight M4 screws |
1 kit, provided |
N/A |
M6 screw |
4, user supplied |
N/A |
Cage nut |
4, user provided |
N/A |
Grounding cable |
1, provided |
26010496 |
Grounding screw |
1, provided |
N/A |
AC/HVDC power cord The appearance and parameters for AC/HVDC power cords vary by country and region. The power cord in this table is a standard AC power cord in China. |
1, provided with PSR250-12A and PSR250-12A1 power supplies |
N/A |
DC power cord |
1, provided with the PSR450-12D power supply |
04042967 |
DB9-to-RJ45 console cable |
1, optional |
0404A1EE |
USB-to-RJ45 console cable |
1, optional |
2 Installing the switch
CAUTION: Keep the tamper-proof seal on a mounting screw on the chassis cover intact, and if you want to open the chassis, contact H3C for permission. Otherwise, H3C shall not be liable for any consequence. |
Figure2-1 Hardware installation flow
IMPORTANT: · M4 screws are used for attaching the mounting brackets to the chassis. As a best practice, use a torque of 12 kgf-cm (1.18 Nm) to fasten M4 screws. · M6 screws and cage nuts are user supplied. As a best practice, use a torque of 30 kgf-cm (2.94 Nm) to fasten M6 screws. |
The switch has one mounting position near the network ports and the other mounting position near the power supplies for the mounting brackets. Select one position as needed.
To attach the mounting brackets to the chassis:
1. Place the wide flange of the mounting bracket against the chassis side panel. Align the mounting bracket installation holes with the screw holes in the chassis.
¡ To install the mounting brackets at the port-side mounting position, see Figure2-2.
¡ To install the mounting brackets at the power supply-side mounting position, see Figure2-3.
2. Fasten the M4 screws to secure the mounting bracket to the switch.
3. Attach the other mounting bracket to the other side of the chassis in the same way.
Figure2-2 Attaching the mounting brackets to the port-side mounting position
Figure2-3 Attaching the mounting brackets to the power supply-side mounting position
1. Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2. Verify that the mounting brackets have been securely attached to the switch chassis.
3. Attach cage nuts to the front rack posts.
4. One person supports the bottom of the switch, and moves the switch to an appropriate position based on the installation positions of the mounting brackets.
5. Another person uses user supplied M6 screws and cage nuts to attach the mounting brackets to the rack and verifies that the brackets are level and secure.
Figure2-4 Mounting the switch in the rack
WARNING! · Correctly connecting the grounding cable is crucial to lightning, ESD, and EMI protections. Make sure you connect the grounding cable correctly for the switch. · For information about how to protect your switch from lightning strikes, see H3C Network Devices Lightning Protection Guide. |
To protect against the following types of issues, use a grounding cable to connect the switch to the earthing facility at the installation site:
· Bodily injury from electric shocks.
· Device and power and data line damages.
· Electrical fires, lightning strokes, electromagnetic coupling interferences, and ESD damages.
Select a grounding method based on the installation environment.
NOTE: The positions of power supplies and grounding terminals in this section are for illustration only. |
CAUTION: · Connect the grounding cable to the grounding system in the equipment room. Do not connect it to a fire main or lightning rod. · To guarantee the grounding effect and avoid switch damage, use the grounding cable provided with the switch to connect the switch to a grounding strip in the equipment room. |
Connecting the grounding cable to the chassis
IMPORTANT: As a best practice, use a torque of 12 kgf-cm (1.18 Nm) to fasten the grounding screw. |
To connect the grounding cable to the chassis:
1. Remove the grounding screw from the grounding hole in the chassis.
The grounding screw and grounding hole are on the rear panel of the chassis and a grounding sign is provided.
2. Attach the grounding screw to the ring terminal of the grounding cable.
3. Use a screwdriver to fasten the grounding screw into the grounding hole.
IMPORTANT: Orient the grounding cable as shown in Figure2-5 so that you can easily install or remove the fan trays. |
Figure2-5 Connecting the grounding cable to the chassis
(1) Ring terminal |
(2) Grounding sign |
(3) Grounding hole |
(4) Grounding screw |
(5) Grounding cable |
Connecting the grounding cable to a grounding strip
1. Remove the hex nut of a grounding post on the grounding strip.
2. Attach the ring terminal of the grounding cable to the grounding post and use the hex nut to secure the ring terminal to the post.
Figure2-6 Connecting the grounding cable to a grounding strip
(1) Grounding post |
(2) Grounding strip |
(3) Grounding cable |
(4) Hex nut |
1. Use a multimeter to measure the resistance between the switch grounding terminal and grounding point, and make sure the resistance is less than 0.1W.
2. Use a grounding resistance tester to measure the grounding resistance of the grounding strip, and make sure the grounding resistance is less than 1W.
For information about resistance measurement, see H3C Network Devices Lightning Protection Guide.
CAUTION: · You can power on the switch only when the switch is installed with five fan trays of the same model. · If more than one fan tray fails during switch operation, do not remove the failed fan trays simultaneously. Replace the fan trays one by one and finish replacing each fan tray within three minutes. |
The switch can be delivered with removable fan trays installed on it. Contact the H3C marketing personnel if you want the switch to be delivered with the ordered fan trays installed on it.
The switch came with empty fan tray slots. Choose fan tray models for the switch based on the heat dissipation requirements.
· The LSPM1FANSA-SN fan tray provides power supply side-intake and port side-exhaust airflow. Its handle is blue.
· The LSPM1FANSB-SN fan tray provides port side-intake and power supply side-exhaust airflow. Its handle is red.
Installing a fan tray
CAUTION: To prevent damage to the fan tray or the connectors on the backplane, insert the fan tray gently. If you encounter a hard resistance while inserting the fan tray, pull out the fan tray and insert it again. |
To install a fan tray:
2. Unpack the fan tray and verify that the fan tray model is correct.
3. Grasp the two handles of the fan tray with the side marked TOP facing up, and slide the fan tray along the guide rails into the slot until the fan tray seats in the slot and has a firm contact with the backplane.
Figure2-7 Installing a fan tray
Removing a fan tray
WARNING! · Do not touch any bare wires or terminals on the fan tray. · Do not place a fan tray in a moist location or let liquid flow into it. · Contact H3C Support if the circuits or components on a fan tray are faulty. Do not remove any fan tray components. |
To remove a fan tray:
2. Grasp the two handles of the fan tray, as shown by callout 1 in Figure2-5, and pull out the fan tray slowly along the guide rails.
3. Put the removed fan tray in an antistatic bag.
The switch can be delivered with removable power supplies installed on it. Contact the H3C marketing personnel if you want the switch to be delivered with the ordered power supplies installed on it.
WARNING! · To avoid bodily injury or switch damage, strictly follow the procedures in Figure2-6 and Figure2-7 to install and remove a power supply. · You must provide a circuit breaker for each power supply. |
CAUTION: To use two power supplies for the switch, make sure they are the same model. |
Figure2-9 Installation procedure
Installing a power supply
The installation procedure is the same for the PSR250-12A, PSR250-12A1, and PSR450-12D power supplies. The following procedure installs a PSR250-12A1 power supply.
To install a PSR250-12A1 power supply:
1. Wear an ESD wrist strap. Make sure the strap makes good skin contact and is reliably grounded.
2. Remove the filler panel, if any, from the target power supply slot.
Figure2-11 Removing the filler panel from the target power supply slot
3. Unpack the power supply. Make sure the power supply model is as required.
Keep the packaging box and packaging bag for the power supply secure for future use.
4. Correctly orient the power supply. Make sure the lettering on the power supply is upward.
5. Grasping the handle of the power supply with one hand and supporting its bottom with the other, slide the power supply slowly into the slot along the guide rails until the latch of the power supply clicks into place.
To prevent damage to the power supply or the connectors on the backplane, insert the power supply gently. If you encounter a hard resistance when inserting the power supply, pull out the power supply and insert it again.
Figure2-12 Installing a power supply
Removing a power supply
2. Disconnect the power cord.
3. Grasping the handle of the power supply with one hand with the thumb pressing the latch towards the handle direction, pull the power supply part way out of the slot. Then supporting the power supply bottom with the other, pull the power supply slowly out of the slot.
4. Place the removed power supply on an antistatic mat or its packaging bag for future use.
5. If you are not to install a new power supply after removing the old one, install a filler panel in the slot in time.
Figure2-13 Removing a power supply
Connecting the power cords
CAUTION: Provide a circuit breaker for each power input and make sure the circuit breaker is off before connecting the power cord. |
Table2-2 Power cord connection procedures at a glance
Power supply model |
Available power source |
Connection procedure reference |
PSR250-12A PSR250-12A1 |
AC power source |
Connecting the power cord for a PSR250-12A/PSR250-12A1 power supply |
PSR450-12D |
–48 VDC power source in the equipment room |
RPS1600-A |
The power cord connection procedure is the same for the PSR250-12A and PSR250-12A1 power supplies. The following uses a PSR250-12A1 as an example.
To connect the power cord:
2. Plug the female connector of the power cord into the power receptacle on the power supply, as shown by callout 1 in Figure2-11.
3. Use a releasable cable tie to secure the power cord to the handle of the power supply, as shown by callout 2 in Figure2-2.
4. Connect the other end of the power cord to an AC power source.
Figure2-14 Connecting the power cord for a PSR250-12A1 power supply (1)
Figure2-15 Connecting the power cord for a PSR250-12A1 power supply (2)
CAUTION: · To use a –48 VDC power source in the equipment room to supply power to the power supply, use the DC power cord supplied with the power supply. When connecting the DC power cord, identify the positive (+) and negative (-) marks on the two wires to avoid connection mistakes. · To use an H3C RPS to supply power to the power supply, use a compatible RPS power cord to connect the RPS to the power supply. |
To connect the power cord for a PSR450-12D power supply:
2. Use a flathead screwdriver to loosen the screws on the protection cover over the DC power receptacle on the power supply and then remove the protection cover (see callouts 1 and 2 in Figure2-4).
3. Correctly orient the power cord plug, and then insert the plug into the power receptacle (see callout 3 in Figure2-5).
If you orient the plug upside down, you cannot insert it into the power receptacle.
4. Use a flathead screwdriver to fasten the screws on the plug to secure the plug in the power receptacle (see callout 4 in Figure2-5).
5. Connect the other end of the power cord to a –48 VDC power source or an RPS.
Figure2-16 Connecting the power cord for a PSR450-12D power supply (1)
Figure2-17 Connecting the power cord for a PSR450-12D power supply (2)
Verifying the installation
Before powering on the switch, verify the following items:
· There is enough space around the switch for heat dissipation.
· The rack on which the switch is mounted is stable.
· The grounding cable is securely connected.
· The power source specifications are as required by the device.
· The power input cables are correctly connected.
· If part of the network cable for a port is routed outdoors, verify that a network port lightning protector is used for the port.
· If a power line is routed from outdoors, verify that a surge protected power strip is used for the switch.
As shown in Figure3-1, you can access the switch by connecting the serial console port on the switch to a configuration terminal.
Figure3-1 Connecting the switch to a configuration terminal
As shown in Table3-1, two types of console cables can be used for connecting the switch to a configuration terminal.
Table3-1 Connection methods and console cables
Connection method |
Console cable type |
Configuration terminal-side connector |
Switch-side connector |
Using the serial console port for connection |
DB-9 female connector |
RJ-45 connector |
USB connector |
RJ-45 connector |
The RJ-45 signal pinout varies by the vendor of the cable. To avoid abnormal display on the configuration terminal, use a console cable provided by H3C (as shown in Table1-8).. To prepare a serial console cable yourself, make sure the RJ-45 connector signal pinout is as shown in Table3-2.
CAUTION: Follow these guidelines when you connect a DB9-to-RJ45 console cable: · Identify the mark on the serial console port and make sure you are connecting to the correct port. · The serial ports on PCs do not support hot swapping. To connect a PC to an operating switch, first connect the PC end. To disconnect a PC from an operating switch, first disconnect the switch end. |
A DB9-to-RJ45 console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connecting to the serial console port of the switch, and a DB-9 female connector at the other end for connecting to the serial port on the console terminal.
Figure3-2 DB9-to-RJ45 console cable
Table3-2 Serial console cable signal pinout
RJ-45 |
Signal |
DB-9 |
Signal |
1 |
RTS |
8 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
2 |
RXD |
4 |
SG |
5 |
SG |
5 |
SG |
5 |
SG |
6 |
RXD |
3 |
TXD |
7 |
DSR |
4 |
DTR |
8 |
CTS |
7 |
RTS |
To connect the switch to a configuration terminal (for example, a PC) through a DB9-to-RJ45 console cable:
1. Plug the DB-9 female connector of the DB9-to-RJ45 console cable to the serial port on the PC.
2. Connect the RJ-45 connector to the serial console port on the switch.
IMPORTANT: · To use a USB-to-RJ45 console cable to connect the switch to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal and then connect the USB-to-RJ45 console cable to the configuration terminal. · If you have connected a USB-to-RJ45 console cable to the configuration terminal before driver installation, you must remove and reconnect the USB-to-RJ45 console cable to the configuration terminal. |
NOTE: For the RJ-45 connector signal pinout of the USB-to-RJ45 console cable, see Table3-2. |
The following installs the driver on the Windows system. To install the driver on other operating systems, see the installation guide in the driver compression package named by the corresponding operating system.
To connect the switch to the configuration terminal through a USB-to-RJ45 console cable:
1. Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2. View the TXT file Read me in the Windows folder to check whether the Windows system of the configuration terminal supports the driver.
3. If the Windows system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4. Click Next on the welcome page of the driver installation wizard.
Figure3-3 Driver installation wizard
5. Click Finish after the drive installation is completed.
Figure3-4 Finishing the driver installation
6. Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7. Connect the RJ-45 connector of the cable to the console port of the switch.
Setting terminal parameters
To configure and manage the switch through the console port, you must run a terminal emulator program, such as TeraTermPro, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs.
Configure the terminal parameters as follows:
· Bits per second—9,600.
· Data bits—8.
· Parity—None.
· Stop bits—1.
· Flow control—None.
Starting the switch
Pre-start checklist
· The power cord is correctly connected.
· The input power voltage is as required by the switch.
· The console cable is correctly connected.
· The PC has started, and the terminal parameters have been correctly configured.
Powering on the switch
During the startup process, you can access Boot ROM menus to perform tasks such as software upgrade and file management. The Boot ROM interface and menu options differ with software versions. For more information about Boot ROM menu options, see the software-matching release notes for the device.
After the startup process is completed, you can access the CLI to configure the switch.
For more information about the configuration commands, see the configuration guides and command references for the switch.
4 Setting up an IRF fabric
You can use H3C IRF technology to connect and virtualize multiple S6530X switches into a large virtual switch called an "IRF fabric" for flattened network topology, and high availability, scalability, and manageability.
A switch can set up an IRF fabric only with switches from the same switch series.
IRF fabric setup flowchart
Figure4-1 IRF fabric setup flowchart
To set up an IRF fabric:
Step |
1. Plan IRF fabric setup |
Plan the installation site and IRF fabric setup parameters: · Planning IRF fabric size and the installation site · Identifying the master switch and planning IRF member IDs · Planning IRF topology and connections |
2. Install IRF member switches |
3. Connect grounding cables and power cords |
See "Grounding the switch" and "Connecting the power cord." |
4. Power on the switches |
N/A |
5. Configure basic IRF settings |
See IRF Configuration Guide for the switch series. |
6. Connect the physical IRF ports |
Connect IRF member switches. Use QSFP+/QSFP28 transceiver modules and optical fibers for long distance connection. Use QSFP+/QSFP28 copper cables for short distance connection. All switches except the master switch automatically reboot, and the IRF fabric is established. |
Planning IRF fabric setup
This section describes issues that an IRF fabric setup plan must cover.
Choose switch models and identify the number of required IRF member switches, depending on the user density and upstream bandwidth requirements. The switching capacity of an IRF fabric equals the total switching capacities of all member switches.
Plan the installation site depending on your network solution, as follows:
· Place all IRF member switches in one rack for centralized high-density access.
· Distribute the IRF member switches in different racks to implement the ToR access solution for a data center.
Determine which switch you want to use as the master for managing all member switches in the IRF fabric.
An IRF fabric has only one master switch. You configure and manage all member switches in the IRF fabric at the CLI of the master switch. IRF member switches automatically elect a master.
You can affect the election result by assigning a high member priority to the intended master switch. For more information about master election, see the configuration guides and command references for the switch.
Prepare an IRF member ID assignment scheme. An IRF fabric uses member IDs to uniquely identify and manage its members, and you must assign each IRF member switch a unique member ID.
You can create an IRF fabric in daisy chain topology or more reliable ring topology. In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy chain topology. Instead, the IRF fabric changes to a daisy chain topology without interrupting network services.
You connect the IRF member switches through IRF ports, the logical interfaces for the connections between IRF member switches. Each IRF member switch has two IRF ports: IRF-port 1 and IRF-port 2. To use an IRF port, you must bind a minimum of one physical port to it.
When connecting two neighboring IRF member switches, you must connect the physical ports of IRF-port 1 on one switch to the physical ports of IRF-port 2 on the other switch. The QSFP28 ports on the switch can provide 40GE/100GE IRF connection. You can bind several IRF physical ports to an IRF port for increased bandwidth and availability.
Figure4-2 and Figure4-3 show the topologies of an IRF fabric. The IRF port connections in the two figures are for illustration only, and more connection methods are available.
Figure4-2 IRF fabric in daisy chain topology
Figure4-3 IRF fabric in ring topology
Reserve the physical IRF ports on the member switches according to your topology and connection scheme.
QSFP28 ports on the switch can be used for IRF connection. 25-GE/10-GE breakout interfaces split from a QSFP28 port cannot be used for IRF connection.
IMPORTANT: · All physical ports to be bound to an IRF logical interface must have the same data rate. · QSFP28 ports on the switch operate at 40 Gbps by default. Licenses are available for you to increase the QSFP28 port speed to 100 Gbps. |
Planning the cabling scheme
You can use QSFP+/QSFP28 transceiver modules and optical fibers or QSFP+/QSFP28 copper cables for IRF connection:
· For a short-distance IRF connection in an equipment room, use a QSFP+/QSFP28 cable.
· For a long-distance IRF connection, use QSFP+/QSFP28 transceiver modules and optical fibers.
The following subsections describe several H3C recommended IRF connection schemes. All these schemes use a ring topology. The ring topology is not applicable to IRF setup with two devices.
IMPORTANT: In these schemes, all physical IRF ports are located on the same side. If physical IRF ports are on different sides, you must measure the distance between them to select an appropriate cable. |
Connecting the IRF member switches in one rack
Connect the IRF member switches (4 switches in this example) in a rack as shown in Figure4-4. The switches in the ring topology (see Figure4-5) are in the same order as connected in the rack.
Figure4-4 Connecting the switches in one rack
Connecting the IRF member switches in a ToR solution
You can install IRF member switches (4 switches in this example) in different racks side by side to deploy a top of rack (ToR) solution as shown in Figure4-6. Use QSFP+/QSFP28 transceiver modules and optical fibers for connection if a large distance exists between the member switches.
After you install the IRF member switches, power on the switches, and log in to each IRF member switch to configure their member IDs, member priorities, and IRF port bindings.
For information about accessing the switch, see Fundamentals Configuration Guide for the switch.
For more information about configuring basic IRF settings, see IRF Configuration Guide for the switch.
Connect the IRF member switches as planned.
Wear an ESD wrist strap when you connect cables or transceiver modules and fibers. For information about how to connect them, see H3C Transceiver Modules and Network Cables Installation Guide.
To verify the basic functionality of the IRF fabric after you finish configuring basic IRF settings and connecting IRF ports:
1. Log in to the IRF fabric through the console port of any member switch.
2. Create a Layer 3 interface, assign it an IP address, and make sure the IRF fabric and the remote network management station can reach each other.
3. Use Telnet, web, or SNMP to access the IRF fabric from the network management station. (See Fundamentals Configuration Guide for the switch.)
4. Verify that you can manage all member switches as if they were one node.
5. Display the running status of the IRF fabric by using the commands in Table4-2.
Table4-1 Displaying and maintaining IRF configuration and running status
Task |
Command |
Display information about the IRF fabric. |
display irf |
Display all members’ IRF configurations that take effect at a reboot. |
display irf configuration |
Display IRF fabric topology information. |
display irf topology |
NOTE: To avoid IP address collision and network problems, configure a minimum of one multi-active detection (MAD) mechanism to detect the presence of multiple identical IRF fabrics and handle collisions. For more information about MAD detection, see IRF Configuration Guide for the switch. |
Power supply failure
The switch uses removable power supplies. You can determine whether a power supply is faulty by observing the status LED on the power supply.
Symptom
The status LED on the power supply is not steady green, which indicates that the power supply is faulty.
Solution
To resolve the issue:
1. Verify that the power supply model is as required by the switch.
2. Verify that the power supply is securely installed in the switch.
3. Verify that the operating temperature of the switch is in an acceptable range and the power supply has good ventilation.
4. If the issue persists, contact H3C Support.
To replace a power supply, see "Installing and removing power supplies."
Fan tray failure
CAUTION: If more than one fan tray fails during the switch operation, do not remove the failed fan trays simultaneously. Replace the fan trays one by one and finish replacing each fan tray within 3 minutes. |
The switch uses removable fan trays. You can determine whether a fan tray is faulty by observing the status LED on the fan tray.
Symptom
The status LED on a fan tray indicates that the fan tray is faulty..
Solution
Replace the fan tray. For information about how to replace the fan tray, see "Installing and removing fan tray."
If the configuration environment setup is correct, the configuration terminal displays booting information when the switch is powered on. If the setup is incorrect, the configuration terminal displays nothing or garbled text.
No display
Symptom
The configuration terminal does not have display when the switch is powered on.
Solution
1. Verify that the power supply is supplying power to the switch correctly.
2. Verify that the console cable is correctly connected.
3. Verify that the console cable does not have any issues and the terminal settings are correct.
Garbled display
Symptom
The display on the configuration terminal is garbled.
Solution
1. Verify that the following settings are configured for the terminal:
¡ Baud rate—9,600.
¡ Data bits—8.
¡ Stop bits—1.
¡ Parity—None.
¡ Flow control—None.
2. If the issue persists, contact H3C Support.
