- 12-Security Configuration Guide
- 01-Security zone configuration
- 02-AAA configuration
- 03-802.1X configuration
- 04-MAC authentication configuration
- 05-Portal configuration
- 06-Port security configuration
- 07-User profile configuration
- 08-Password control configuration
- 09-Keychain configuration
- 10-Public key management
- 11-PKI configuration
- 12-IPsec configuration
- 13-Group domain VPN configuration
- 14-SSH configuration
- 15-SSL configuration
- 16-SSL VPN configuration
- 17-ASPF configuration
- 18-APR configuration
- 19-mGRE configuration
- 20-Session management
- 21-Connection limit configuration
- 22-Object group configuration
- 23-Object policy configuration
- 24-Security policy configuration
- 25-Attack detection and prevention configuration
- 26-IP source guard configuration
- 27-ARP attack protection configuration
- 28-ND attack defense configuration
- 29-uRPF configuration
- 30-Crypto engine configuration
- 31-FIPS configuration
- 32-Application account auditing configuration
22-Object group configuration | 61.97 KB |
Restrictions and guidelines: Object group configuration
Configuring an IPv4 address object group
Configuring an IPv6 address object group
Configuring a port object group
Configuring a service object group
Display and maintenance commands for object groups
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
· IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
· IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
· Port object group—A group of port objects used to match the protocol port number in a packet.
· Service object group—A group of service objects used to match the upper-layer service in a packet.
You cannot edit an object group if the group is used by a global static NAT rule.
1. Enter system view.
2. Create an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3. (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4. Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name }
5. Exclude an IPv4 address or a subnet from the IPv4 address object.
object-id network exclude { ip-address | subnet ip-address { mask-length | mask } }
By default, no IPv4 address in an IPv4 address object is excluded.
6. Exclude a host name from the IPv4 address object.
object-id network exclude host-name host-name
By default, no host name in an IPv4 address object is excluded.
7. (Optional.) Specify a security zone for the IPv4 address object group.
security-zone security-zone-name
By default, no security zone is specified for an IPv4 address object group.
2. Create an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3. (Optional.) Configure a description for the IPv6 address object group.
4. Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name }
5. Exclude an IPv6 address or a subnet from the IPv6 address object.
object-id network exclude { ip-address | subnet ipv6-address prefix-length }
By default, no IPv6 address in an IPv6 address object is excluded.
6. Exclude a host name from the IPv6 address object.
By default, no host name in an IPv6 address object is excluded.
7. (Optional.) Specify a security zone for the IPv6 address object group.
By default, no security zone is specified for an IPv6 address object group.
2. Create a port object group and enter its view.
object-group port object-group-name
The system has one default port object group named any.
3. (Optional.) Configure a description for the port object group.
4. Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
2. Create a service object group and enter its view.
object-group service object-group-name
The system has multiple default service object groups.
3. (Optional.) Configure a description for the service object group.
4. Configure a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
Renaming an object group
2. Rename an object group.
object-group rename old-object-group-name new-object-group-name
You can only rename non-default object groups.
Task |
Command |
Display information about object groups. |
display object-group [ { { ip | ipv6 } address | service | port } [ default ] [ name object-group-name ] | name object-group-name ] |
Display IPv4 or IPv6 addresses for host names. |
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name } * |
