- 09-Security Command Reference
- 01-Security zone commands
- 02-AAA commands
- 03-User identification commands
- 04-Password control commands
- 05-Public key management commands
- 06-PKI commands
- 07-SSH commands
- 08-SSL commands
- 09-ASPF commands
- 10-APR commands
- 11-Session management commands
- 12-Connection limit commands
- 13-Object group commands
- 14-Security policy commands
- 15-Attack detection and prevention commands
- 16-ARP attack protection commands
- 17-ND attack defense commands
- 18-uRPF commands
- 19-Crypto engine commands
- 20-Trusted access control commands
| 20-Trusted access control commands | 170.01 KB |
display trusted-access api-id-url
display trusted-access controller
display trusted-access permitted-record
display trusted-api-proxy statistics
display trusted-app-proxy statistics
reset trusted-access permitted-record
reset trusted-api-proxy statistics
reset trusted-app-proxy statistics
service enable (trusted access controller view)
service enable (trusted app proxy/trusted api proxy view)
ssl-client-policy (trusted access controller view)
ssl-client-policy (trusted app proxy/trusted api proxy view)
ssl-server-policy (trusted access controller view)
ssl-server-policy (trusted app proxy/trusted api proxy view)
trusted-access-controller (trusted app proxy/trusted api proxy view)
api-access-mode
Use api-access-mode to specify the API access mode.
Use undo api-access-mode to restore the default.
api-access-mode { app-initiated | user-initiated }
The application-initiated API access mode is adopted.
Trusted API proxy view
context-admin
app-initiated: Specifies the application-initiated API access mode.
user-initiated: Specifies the user-initiated API access mode.
The trusted API proxy carries different tokens based on the specified API access mode when performing authorization with the trusted access controller. You must specify the correct API access mode according to the network environment as follows:
· Application-initiated API access mode—Applies to the network environment where the front end and backend are separated. In this mode, the trusted API proxy carries both the user token and application token when performing API authorization with the trusted access controller. The trusted access controller verifies the API access permission for both the associated user and application.
· User-initiated API access mode—Applies to the network environment where the front end and backend are not separated. In this mode, the trusted API proxy carries only the user token when performing API authorization with the trusted access controller. The trusted access controller verifies the API access permission for only the associated user.
# Specify the user-initiated API access mode for HTTP trusted API proxy api.
[Sysname] trusted-api-proxy api type http
[Sysname-tip-http-api] api-access-mode user-initiated
app-url-level
Use app-url-level to specify the URL resource path extraction scope for application authorization.
Use undo app-url-level to restore the default.
app-url-level level
undo app-url-level
Only the domain name section of URLs is extracted for application authorization.
Trusted access proxy view
context-admin
level: Specifies the sections (separated by forwarded slashes) to extract from URLs for application authorization. The value range for the level argument is 0 to 10. Value 0 represents the domain name section of URLs.
The trusted access proxy extracts a specific portion from URLs in user requests to perform application authorization with the IAM trusted access controller.
Use this command to specify the portion (domain name section plus the specified resource path sections) to extract from URLs. Suppose a user attempts to access application URL www.test.com/aaa/bbb/ccc/ddd/default=eee.
· If you set the value for the level argument to 0, the trusted access proxy extracts www.test.com from the URL to perform application authorization.
· If you set the value for the level argument to 3, the trusted access proxy extracts www.test.com/aaa/bbb/ccc from the URL to perform application authorization.
Typically, you only need to use the default setting for this command to implement application permission control because each application has a unique domain name.
If multiple applications use the same domain name, specify a URL resource path extraction scope with the command to extract the associated portions from the application URLs for application authorization.
# Specify the level-3 URL resource path extraction scope for HTTP trusted application proxy app.
[Sysname] trusted-app-proxy app type http
[Sysname-tap-http-app] app-url-level 3
connection-count
Use connection-count to specify the maximum number of connections between the device and the IAM trusted access controller.
Use undo connection-count to restore the default.
connection-count count
The device can establish a maximum of one connection to the IAM trusted access controller.
IAM trusted access controller view
context-admin
count: Specifies the maximum number of connections between the device and the IAM trusted access controller, in the range of 1 to 20.
By default, the device can establish a maximum of one connection to the IAM trusted access controller. When a large number of authentication and authorization requests exist, the IAM trusted access controller might fail to respond the requests in time, affecting user experience. You can configure this command to increase the concurrent connection count between the device and IAM trusted access controller, reduce the authentication and authorization delay, and improve user experience.
# Specify the maximum number of connections as 5 between trusted application controller c1 and the IAM trusted access controller.
[Sysname] trusted-access-controller c1 type iam
[Sysname-tac-iam-c1]connection-count 5
connection-limit max
Use connection-limit max to configure the maximum number of connections for the trusted proxy.
Use undo connection-limit max to restore the default.
connection-limit max max-number
The maximum number of connections is 0 (not limited) for the trusted proxy.
HTTP trusted application proxy view
HTTP trusted API proxy view
context-admin
max-number: Specifies the maximum number of connections, in the range of 0 to 4294967295. The value 0 means the maximum number of connections is not limited for the trusted proxy.
# Configure the maximum number of connections as 10000 for HTTP trusted application proxy app3.
[Sysname] trusted-app-proxy app3 type http
[Sysname-tap-http-app3] connection-limit max 10000
description
Use description to configure a description for the trusted access controller.
No description is configured for the trusted access controller.
context-admin
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description iam server for IAM trusted access controller tac.
[Sysname] trusted-access controller tac type iam
[Sysname-tac-iam-tac] description iam server
Use display trusted-access api-id-url to display API ID-to-URL mappings.
display trusted-access api-id-url [ name controller-name ] [ slot slot-number ]
context-admin
context-operator
name controller-name: Specifies a trusted access controller by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays API ID-to-URL mappings for all trusted access controllers.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays API ID-to-URL mappings for all member devices.
The device maps URLs in API requests to API IDs of shorter length to reduce resource consumption on the IAM server. Upon receiving an API authorization request, the device maps the API URL in the request to an API ID before forwarding the request to the trusted access controller. After the authorization is complete, the device maps the API ID in the authorization result to an API URL before sending the result to the user.
# Display API ID-to-URL mappings.
<Sysname> display trusted-access api-id-url
Slot 2:
API ID URL
888 http://888.com
666 http://666.com
Use display trusted-access controller to display trusted access controller information.
display trusted-access controller [ name controller-name ]
context-admin
context-operator
name controller-name: Specifies a trusted access controller by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all trusted access controllers.
# Display information about all trusted access controllers.
<Sysname> display trusted-access controller
Trusted access controller: tac
Description:
Type: IAM
State: Active
Local service URL: http://10.153.10.120:80
Peer service URL: http://10.153.10.121:80
SSL client policy: scp
SSL server policy: ssp
Connection count: 1
Slot 1:
Peer service state: Active
Serial ID: 38ad-be93-e0c4-0008-0100
Slot 2:
Peer service state: Inactive
Serial ID: 38ad-be93-e0c4-0010-0100
Trusted access controller |
Name of the trusted access controller. |
Description of the trusted access controller. |
Type |
Type of the trusted access controller. Only IAM is supported in the current software version. |
State |
State of the trusted access controller: · Active—The trusted access controller is available. · Inactive—The trusted access controller is not available although it is enabled. · Inactive(disabled)—The trusted access controller is not available because it is disabled. |
Serial ID |
Serial ID that identifies the trusted proxy device. |
Connection count |
Maximum number of connections between the device and the IAM trusted access controller. |
Use display trusted-access permitted-record to display user authorization success records.
display trusted-access permitted-record { api-auth | app-auth } user { brief | user-name } [ slot slot-number ]
context-admin
context-operator
api-auth: Specifies API authorization success records.
app-auth: Specifies application authorization success records.
user: Displays authorization success records for the specified user.
brief: Displays brief authorization success records for all users.
user-name: Specifies a user by username, a case-sensitive string of 1 to 63 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user authorization success records for all member devices.
Use this command to view the URLs that have been authorized as permitted.
If an access request is permitted by the trusted access controller in an authorization, the associated application URL or API URL is added as an authorization success record. Before this record expires, the associated resource is available for matching requests through a lookup. If the record expires, authorization is required for the access requests on the trusted access controller.
# Display authorization success records for user test.
<Sysname> display trusted-access permitted-record app-auth user test
Slot 1:
Username: test
Created at: 2020-04-15 14:34:54
Application access list:
Application URL Time of last access
test.iam.com/aaa/ 2020-04-15 14:34:54
test.iam.com/bbb/
# Display brief authorization success records for all users.
<Sysname> display trusted-access record app-auth user brief
Slot 1:
Total users: 1
Username Creation time
test 2020-04-15 14:34:54
test1 2020-04-15 14:37:21
Created at |
Time when the user authorization success record was created. |
Total users |
Total number of users that have been successfully authorized. |
Time of last access |
Most recent time when the application URL or API URL was accessed. |
Use display trusted-api-proxy to display trusted API proxy information.
display trusted-api-proxy [ brief | name trusted-proxy-name ]
context-admin
context-operator
brief: Displays brief trusted API proxy information. If you do not specify this keyword, the command displays detailed trusted API proxy information.
name trusted-proxy-name: Specifies a trusted API proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all trusted API proxies.
# Display brief information about all trusted API proxies.
<Sysname> display trusted-api-proxy brief
Trusted API proxy State Type Proxy address Port
api Active HTTP 172.40.0.10/32 80
1::1/128
api2 Inactive HTTP -- 80
(disabled)
# Display detailed information about all trusted API proxies.
Trusted API proxy: api
Type: HTTP
State: Active
Proxy IPv4 address: 172.40.0.10/32
Proxy IPv6 address: 1::1/128
Port: 80
LB policy: api
LB limit-policy: lmitp
TCP parameter profile: tcp
HTTP parameter profile: p1
Connection limit: 10000
Rate limit:
Connections: 10000
IAM trusted access controller: tac
API access mode: App-initiated
Trusted API proxy: api2
Type: HTTP
State: Inactive (disabled)
IPv4 address: --
IPv6 address: --
Port: 80
LB policy:
LB limit-policy:
Connection limit: --
Rate limit:
Connections: --
SSL server policy:
SSL client policy:
Trusted API proxy |
Name of the trusted API proxy. |
State |
State of the trusted API proxy: · Active—The trusted API proxy is available. · Inactive—The trusted API proxy is not available although the proxy is enabled. · Inactive (disabled)—The trusted API proxy is not available because it is disabled. |
Type |
Type of the trusted API proxy. Only HTTP is supported in the current software version. |
Proxy IPv4 address |
IPv4 address and mask length of the trusted API proxy. |
Proxy IPv6 address |
IPv6 address and prefix length of the trusted API proxy. |
Port |
Port number of the trusted API proxy. |
LB policy |
LB policy used by the trusted API proxy. |
LB limit-policy |
LB connection limit policy used by the trusted API proxy. |
TCP parameter profile |
TCP parameter profile used by the trusted API proxy. This field is displayed only when the TCP parameter profile is configured. |
TCP parameter profile (client-side) |
Client-side TCP parameter profile used by the trusted API proxy. This field is displayed only when the client-side TCP parameter profile is configured. |
TCP parameter profile (server-side) |
Server-side TCP parameter profile used by the trusted API proxy. This field is displayed only when the server-side TCP parameter profile is configured. |
HTTP parameter profile |
HTTP parameter profile used by the trusted API proxy. This field is displayed only when the HTTP parameter profile is configured. |
DPI application profile |
DPI application profile used by the trusted API proxy. This field is displayed only when a DPI application profile has been specified. |
Connection limit |
Maximum number of connections for the trusted API proxy. |
Rate limit |
Connection rate limit setting for the trusted API proxy. |
Connections |
Maximum connection rate for the trusted API proxy. |
SSL server policy |
Name of the SSL server policy. This field is displayed only for an HTTP trusted API proxy. |
SSL client policy |
Name of the SSL client policy. This field is displayed only for an HTTP trusted API proxy. |
HTTP protection policy |
HTTP protection policy used by the trusted API proxy. |
IAM trusted access controller |
Name of the IAM trusted access controller used by the trusted API proxy. |
API access mode |
API access mode: App-initiated or User-initiated. |
Use display trusted-api-proxy statistics to display trusted API proxy statistics.
display trusted-api-proxy statistics [ name trusted-proxy-name ] [ slot slot-number ]
context-admin
context-operator
name trusted-proxy-name: Specifies a trusted API proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all trusted API proxies.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays trusted API proxy statistics for all member devices.
# Display statistics for trusted API proxy api.
<Sysname> display trusted-api-proxy statistics name api
Total connections: 979
Active connections: 618
Max connections: 661
Recorded at 11:02:49 on Tue May 21 2019
Connections per second: 146
Max connections per second: 156
Client input: 333332 bytes
Client output: 472054 bytes
Throughput: 4088 bps
Inbound throughput: 1214 bps
Outbound throughput: 2874 bps
Max throughput: 4368 bps
Max inbound throughput: 1214 bps
Max outbound throughput: 3154 bps
recorded at 11:02:49 on Tue May 21 2019
Received packets: 979
Sent packets: 0
Dropped packets: 0
Received requests: 0
Dropped requests: 0
Sent responses: 0
Dropped responses: 0
Authentication permitted requests: 0
Authentication denied requests: 0
Trusted API proxy |
Client input |
Traffic received from clients in bytes. |
Client output |
Traffic sent to clients in bytes. |
Throughput |
Total packet throughput in bps. |
Inbound throughput |
Total inbound packet throughput in bps. |
Outbound throughput |
Total outbound packet throughput in bps. |
Max throughput |
Maximum packet throughput in bps. |
Max inbound throughput |
Maximum inbound packet throughput in bps. |
Max outbound throughput |
Maximum outbound packet throughput in bps. |
Received packets |
Number of received packets. |
Sent packets |
Number of packets sent by the trusted API proxy to clients. |
Dropped packets |
Number of dropped packets. |
Received requests |
Number of received HTTP requests. This field is displayed only for an HTTP trusted API proxy. |
Dropped requests |
Number of dropped HTTP requests. This field is displayed only for an HTTP trusted API proxy. |
Sent responses |
Number of sent HTTP responses. This field is displayed only for an HTTP trusted API proxy. |
Dropped responses |
Number of dropped HTTP responses. This field is displayed only for an HTTP trusted API proxy. |
Authentication permitted requests |
Number of requests that are permitted in authorization. |
Authentication denied requests |
Number of requests that are denied in authorization. |
Use display trusted-app-proxy to display trusted application proxy information.
display trusted-app-proxy [ brief | name trusted-proxy-name ]
context-admin
context-operator
brief: Displays brief trusted application proxy information. If you do not specify this keyword, the command displays detailed trusted application proxy information.
name trusted-proxy-name: Specifies a trusted application proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all trusted application proxies.
# Display brief information about all trusted application proxies.
<Sysname> display trusted-app-proxy brief
Trusted App proxy State Type Proxy address Port
app Active HTTP 172.40.0.10/32 80
1::1/128
app2 Inactive HTTP -- 80
(disabled)
# Display detailed information about all trusted application proxies.
Trusted application proxy: app
Type: HTTP
State: Active
Port: 80
LB policy: app
LB limit-policy: a
Rate limit:
Connections: 10000
Application URL level: 0
Trusted application proxy: app2
Type: HTTP
Proxy IPv4 address: --
Proxy IPv6 address: --
Port: 80
LB policy:
LB limit-policy:
Rate limit:
Connections: --
SSL server policy:
SSL client policy:
Table 5 Command output
Trusted application proxy |
Name of the trusted application proxy. |
State |
State of the trusted application proxy: · Active—The trusted application proxy is available. · Inactive—The trusted application proxy is not available although the proxy is enabled. · Inactive (disabled)—The trusted application proxy is not available because it is disabled. |
Type |
Type of the trusted application proxy. Only HTTP is supported in the current software version. |
IPv4 address and mask length of the trusted application proxy. |
IPv6 address and prefix length of the trusted application proxy. |
Port |
Port number of the trusted application proxy. |
LB policy |
LB policy used by the trusted application proxy. |
LB limit-policy |
LB connection limit policy used by the trusted application proxy. |
TCP parameter profile used by the trusted application proxy. This field is displayed only when the TCP parameter profile is configured. |
Client-side TCP parameter profile used by the trusted application proxy. This field is displayed only when the client-side TCP parameter profile is configured. |
HTTP parameter profile used by the trusted application proxy. This field is displayed only when the HTTP parameter profile is configured. |
Server-side TCP parameter profile used by the trusted application proxy. This field is displayed only when the server-side TCP parameter profile is configured. |
DPI application profile used by the trusted application proxy. This field is displayed only when a DPI application profile has been specified. |
External authentication app-policy |
External application authentication policy used by the trusted application proxy. |
Connection limit |
Maximum number of connections for the trusted application proxy. |
Rate limit |
Connection rate limit setting for the trusted application proxy. |
Connections |
Maximum connection rate for the trusted application proxy. |
SSL server policy |
Name of the SSL server policy. This field is displayed only for an HTTP trusted application proxy. |
SSL client policy |
Name of the SSL client policy. This field is displayed only for an HTTP trusted application proxy. |
HTTP protection policy used by the trusted application proxy. This field is displayed only when the HTTP protection policy is configured. |
Name of the IAM trusted access controller used by the trusted application proxy. |
Application URL level |
URL resource path extraction scope for application authorization. |
Use display trusted-app-proxy statistics to display trusted application proxy statistics.
display trusted-app-proxy statistics [ name trusted-proxy-name ] [ slot slot-number ]
context-admin
context-operator
name trusted-proxy-name: Specifies a trusted application proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all trusted application proxies.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays trusted application proxy statistics for all member devices.
# Display statistics for trusted application proxy app.
<Sysname> display trusted-app-proxy statistics name app
Sent packets: 0
Dropped packets: 0
Redirected requests for login: 4
Redirected requests for re-authentication: 0
Table 6 Command output
Client input |
Client output |
Throughput |
Inbound packet throughput in bps. |
Outbound packet throughput in bps. |
Max throughput |
Maximum total packet throughput in bps. |
Received packets |
Sent packets |
Number of packets sent by the trusted application proxy to clients. |
Dropped packets |
Received requests |
Number of received HTTP requests. This field is displayed only for an HTTP trusted application proxy. |
Dropped requests |
Number of dropped HTTP requests. This field is displayed only for an HTTP trusted application proxy. |
Sent responses |
Number of sent HTTP responses. This field is displayed only for an HTTP trusted application proxy. |
Dropped responses |
Number of dropped HTTP responses. This field is displayed only for an HTTP trusted application proxy. |
Redirected requests for login |
Number of requests redirected to the login page. |
Redirected requests for re-authentication |
Number of requests redirected to the reauthentication page. |
lb-limit-policy
Use lb-limit-policy to specify an LB connection limit policy for the trusted proxy.
Use undo lb-limit-policy to restore the default.
lb-limit-policy policy-name
No LB connection limit policy is specified for a trusted proxy.
context-admin
policy-name: Specifies an LB connection limit policy by its name, a case-insensitive string of 1 to 63 characters.
Use this command to limit the number of connections for traffic matching a trusted proxy.
The LB connection limit policy takes effect only on newly created sessions. Existing sessions are not affected. For more information about LB connection limit policies, see server load balancing configuration in Load Balancing Configuration Guide.
# Specify LB connection limit policy llp for HTTP trusted application policy app3.
[Sysname-tap-http-app3] lb-limit-policy llp
loadbalance limit-policy (Load Balancing Command Reference)
lb-policy
Use lb-policy to specify an LB policy for the trusted proxy.
Use undo lb-policy to restore the default.
lb-policy policy-name
undo lb-policy
No LB policy is specified for a trusted proxy.
context-admin
policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 63 characters.
This command enables the trusted proxy to perform load balancing for packets matching the specified LB policy.
You can specify only a general or HTTP LB policy for an HTTP trusted proxy.
For more information about LB policies, see server load balancing configuration in Load Balancing Configuration Guide.
# Specify LB policy lbp1 for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] lb-policy lbp1
lb-policy (Load Balancing Command Reference)
local-service url
Use local-service url to specify the local service URL used to collaborate with the trusted access controller.
Use undo local-service url to restore the default.
local-service url service-url
No local service URL is specified.
context-admin
service-url: Specifies a local service URL, a case-insensitive string of 1 to 255 characters.
The local service URL is used to collaborate with the trusted access controller. The trusted access controller can notify the device of events such as user offline and user permission changes through the local service URL.
The local service URL must be in the format of protocol type://server IP address:port number.
· The protocol type is HTTP or HTTPS.
· The server IP address must be an IPv4 address.
You cannot specify the same local service URL for different trusted access controllers on a device.
# Configure local service URL https://10.153.10.120:443 for IAM trusted access controller tac.
[Sysname-tac-iam-tac] local-service url https://10.153.10.120:443
peer-service url
parameter
Use parameter to specify a parameter profile for the trusted proxy.
Use undo parameter to remove the parameter profile from the trusted proxy.
parameter { http | tcp } profile-name [ client-side | server-side ]
undo parameter { http | tcp } [ client-side | server-side ]
No parameter profile is specified for a trusted proxy.
Trusted application proxy view
context-admin
http: Specifies an HTTP parameter profile.
tcp: Specifies a TCP parameter profile.
profile-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters.
client-side: Specifies a client-side TCP parameter profile. This keyword is supported only by TCP parameter profiles.
server-side: Specifies a server-side TCP parameter profile. This keyword is supported only by TCP parameter profiles.
A parameter profile is used to analyze, process, and optimize traffic received by the trusted proxy. The trusted proxy uses the settings in the parameter profile to process matching traffic.
If you specify a client-side TCP parameter profile for the trusted proxy, the system optimizes and processes TCP connections between the client and the device. If you specify a server-side TCP parameter profile for the trusted proxy, the system optimizes and processes TCP connections between the device and the server.
If you do not specify the client-side or server-side keyword, you configure a TCP parameter profile for both the client side and server side. Only TCP parameter profiles can be configured for the client side and server side, respectively.
For more information about parameter profiles, see server load balancing configuration in Load Balancing Configuration Guide.
# Specify TCP parameter profile pp for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] parameter tcp pp
parameter-profile (Load Balancing Command Reference)
peer-service url
Use peer-service url to specify the peer service URL used for providing trusted access control services.
Use undo peer-service url to restore the default.
peer-service url service-url
No peer service URL is specified.
context-admin
service-url: Specifies a peer service URL, a case-insensitive string of 1 to 255 characters.
The device uses the peer service URL to perform registration and authorization with the trusted access controller.
The peer service URL must be in the format of protocol type://server IP address:port number.
# Configure peer service URL http://10.153.10.121:80 for IAM trusted access controller tac.
[Sysname-tac-iam-tac] peer-service url https://10.153.10.120:443
port
Use port to configure the port number for the trusted proxy.
Use undo port to restore the default.
port port-number
undo port
The port number is 80 for a trusted proxy
context-admin
port-number: Specifies a port number in the range of 1 to 65535.
Use this command to configure port number used for providing trusted application proxy or trusted API proxy services.
If the trusted proxy uses an SSL policy, you must specify a non-default port number for it (a typical example is 443).
# Configure port 8080 for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] port 8080
protection-policy
Use protection-policy to specify a HTTP protection policy for the trusted proxy.
Use undo protection-policy to restore the default.
protection-policy http policy-name
undo protection-policy http
No protection policy is specified for a trusted proxy.
context-admin
http: Specifies an HTTP protection policy.
policy-name: Specifies a protection policy by its name, a case-insensitive string of 1 to 63 characters.
Use this command to protect URLs specified in an HTTP protection policy in order to prevent the application and API servers from being overwhelmed by a large number of forged requests.
For more information about HTTP protection policies, see server load balancing configuration in Load Balancing Configuration Guide.
# Specify HTTP protection policy p1 for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] protection-policy http p1
loadbalance protection-policy (Load Balancing Command Reference)
proxy ip address
Use proxy ip address to configure the IP address for the trusted proxy.
Use undo proxy ip address to restore the default.
proxy ip address ipv4-address
No IP address is configured for a trusted proxy.
context-admin
ipv4-address: Specifies an IPv4 address. The IPv4 address cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
Use this command to configure the IPv4 address used for providing trusted application proxy or trusted API proxy services.
# Configure IPv4 address 1.1.1.1 for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] proxy ip address 1.1.1.1
proxy ipv6 address
Use proxy ipv6 address to configure the IPv6 address for the trusted proxy.
Use undo proxy ipv6 address to restore the default.
proxy ipv6 address ipv6-address
No IPv6 address is configured for a trusted proxy.
context-admin
ipv6-address: Specifies an IPv6 address. The IPv6 address cannot be a loopback address, multicast address, link-local address, or an all-zero address.
Use this command to configure the IPv6 address used for providing trusted application proxy or trusted API proxy services.
# Configure IPv6 address 1001::1 for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] proxy ip address 1001::1
rate-limit connection
Use rate-limit connection to configure the maximum connection rate for the trusted proxy.
Use undo rate-limit connection to restore the default.
rate-limit connection connection-rate
The maximum connection rate is 0 (not limited) for the trusted proxy.
context-admin
connection-rate: Specifies the maximum connection rate in the range of 0 to 4294967295. The value 0 means the maximum connection rate is not limited for the trusted proxy.
# Configure the maximum connection rate as 10000 for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] rate-limit connection 10000
Use reset trusted-access permitted-record to clear user authorization success records.
reset trusted-access permitted-record { api-auth | app-auth } user user-name
context-admin
user user-name: Specifies a user by username, a case-sensitive string of 1 to 63 characters.
# Clear application authorization success records for user test.
<Sysname> reset trusted-access permitted-record app-auth user test
Use reset trusted-api-proxy statistics to clear trusted API proxy statistics.
reset trusted-api-proxy statistics [ trusted-proxy-name ]
context-admin
trusted-proxy-name: Specifies a trusted API proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command clear statistics for all trusted API proxies.
# Clear statistics for all trusted API proxies.
<Sysname> reset trusted-api-proxy statistics
Use reset trusted-app-proxy statistics to clear trusted application proxy statistics.
reset trusted-app-proxy statistics [ trusted-proxy-name ]
context-admin
trusted-proxy-name: Specifies a trusted application proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command clear statistics for all trusted application proxies.
# Clear statistics for all trusted application proxies.
<Sysname> reset trusted-app-proxy statistics
Use service enable to enable the trusted access controller.
Use undo service enable to disable the trusted access controller.
service enable
undo service enable
The trusted access controller is disabled.
context-admin
# Enable trusted access controller tac.
[Sysname-tac-iam-tac] service enable
Use service enable to enable the trusted proxy.
Use undo service enable to disable the trusted proxy.
service enable
undo service enable
The trusted proxy is disabled.
context-admin
# Enable HTTP trusted application proxy app3.
[Sysname-tap-http-app3] service enable
Use ssl-client-policy to specify an SSL client policy used for establishing an SSL connection to the trusted access controller.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
No SSL client policy is specified for establishing an SSL connection to the trusted access controller.
context-admin
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
This command is required if the peer service URL type is HTTPs. When the device acts as an SSL client, you can specify an SSL client policy to encrypt registration and authorization traffic sent to the trusted access controller.
For modification of the SSL client policy for a trusted access controller take effect, you must delete and then specify the policy again for the trusted access controller. For more information about SSL policies, see SSL configuration in Security Configuration Guide.
The device does not support SSL client policies using the exp_rsa_des_cbc_sha, exp_rsa_rc2_md5, exp_rsa_rc4_md5, or rsa_des_cbc_sha encryption suite.
# Specify SSL client policy scp for IAM trusted access controller tac.
[Sysname-tac-iam-tac] ssl-client-policy scp
peer-service url
ssl client-policy (Security Command Reference)
Use ssl-client-policy to specify an SSL client policy for the trusted proxy to encrypt the traffic exchanged with the SSL server.
undo ssl-client-policy policy-name
No SSL client policy is specified for a trusted proxy.
context-admin
After modifying the SSL client policy for a trusted proxy, you must disable and then enable the trusted proxy for the modification to take effect. To disable the trusted proxy, use the undo service enable command in trusted proxy view. To enable the trusted proxy, use the service enable command in trusted proxy view.
# Specify SSL client policy scp for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] ssl-client-policy scp
Use ssl-server-policy to specify an SSL server policy used for establishing an SSL connection to the trusted access controller.
Use undo ssl-server-policy to restore the default.
ssl-server-policy policy-name
No SSL server policy is specified for establishing an SSL connection to the trusted access controller.
context-admin
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters.
This command is required if the local service URL type is HTTPs. Use this command to encrypt information such as user offline and user permission changes sent by trusted access controller.
For modification of the SSL server policy for a trusted access controller take effect, you must delete and then specify the policy again for the trusted access controller. For more information about SSL policies, see SSL configuration in Security Configuration Guide.
The device does not support SSL server policies using the exp_rsa_des_cbc_sha, exp_rsa_rc2_md5, exp_rsa_rc4_md5, or rsa_des_cbc_sha encryption suite.
# Specify SSL server policy ssp for IAM trusted access controller tac.
[Sysname-tac-iam-tac] ssl-server-policy ssp
local-service url
ssl server-policy (Security Command Reference)
Use ssl-server-policy to specify an SSL server policy for the trusted proxy to encrypt the traffic exchanged with the SSL client.
No SSL server policy is specified for a trusted proxy.
context-admin
After modifying the SSL server policy for a trusted proxy, you must disable and then enable the trusted proxy for the modification to take effect. To disable the trusted proxy, use the undo service enable command in trusted proxy view. To enable the trusted proxy, use the service enable command in trusted proxy view.
# Specify SSL server policy ssp for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] ssl-server-policy ssp
Use trusted-access-controller to specify a trusted access controller for the trusted proxy.
Use undo trusted-access-controller to restore the default.
trusted-access-controller iam controller-name
No trusted access controller is specified for a trusted proxy.
context-admin
iam: Specifies an IAM trusted access controller.
Use this command to enable a trusted application proxy or trusted API proxy to use a trusted access controller for implementing access control on traffic accessing the trusted proxy.
# Specify IAM trusted access controller tac for HTTP trusted application proxy app3.
[Sysname-tap-http-app3] trusted-access-controller iam tac
trusted-access controller (system view)
Use trusted-access controller to create a trusted access controller and enter trusted access controller view, or enter the view of an existing trusted access controller.
Use undo trusted-access controller to delete the specified trusted access controller.
trusted-access controller controller-name type iam
undo trusted-access controller controller-name
No trusted access controllers exist.
context-admin
type: Specifies the trusted access controller type. The controller type is not required when you enter the view of an existing trusted access controller. To specify the controller type, make sure it is the same as the one you specified upon creating the controller.
iam: Specifies the trusted access controller type as IAM.
This command allows the device to send user requests to the IAM trusted access controller for authentication and authorization. For users that have passed the authentication, the IAM trusted access controller validates user permissions to the requested resources.
# Create IAM trusted access controller tac and enter its view.
trusted-api-proxy
Use trusted-api-proxy to create a trusted API proxy and enter trusted API proxy view, or enter the view of an existing trusted API proxy.
Use undo trusted-api-proxy to delete the specified trusted API proxy.
trusted-api-proxy proxy-name type http
undo trusted-api-proxy proxy-name
No trusted API proxies exist.
context-admin
type http: Specifies the trusted API proxy type. Only HTTP is supported in the current software version. To create a trusted API proxy, you must specify the proxy type. The proxy type is not required when you enter the view of an existing trusted API proxy. To specify the proxy type, make sure it is the same as the one you specified upon creating the trusted API proxy.
The trusted API proxy sends matching API requests to the trusted access controller for authentication and authorization. The trusted access controller will return the authentication and authorization results to the device to implement user access permission control.
# Create HTTP trusted API proxy p2 and enter its view.
[Sysname] trusted-api-proxy p2 type http
[Sysname-tip-http-p2]
trusted-app-proxy
Use trusted-app-proxy to create a trusted application proxy and enter trusted application proxy view, or enter the view of an existing trusted application proxy.
Use undo trusted-app-proxy to delete the specified trusted application proxy.
trusted-app-proxy proxy-name type http
undo trusted-app-proxy proxy-name
No trusted application proxies exist.
context-admin
type http: Specifies the trusted application proxy type. Only HTTP is supported in the current software version. To create a trusted application proxy, you must specify the proxy type. The proxy type is not required when you enter the view of an existing trusted application proxy. To specify the proxy type, make sure it is the same as the one you specified upon creating the trusted application proxy.
The trusted application proxy sends matching application requests to the trusted access controller for authentication and authorization. The trusted access controller will return the authentication and authorization results to the device to implement user access permission control.
# Create HTTP trusted application proxy p1 and enter its view.
[Sysname] trusted-app-proxy p1 type http
[Sysname-tap-http-p1]
