02-Removable Component Views and Technical Specifications | 778.21 KB |
2 Removable component views and technical specifications
FIP modules
Figure2-1 FIP-30 front panel
(1) MIC-X interface module slot 1 |
(2) MIC-X interface module slot 2 |
(3) Latch |
(4) Ejector lever |
(5) Remove button/LED |
(6) 1000BASE-X-SFP Ethernet fiber ports 4 through 19 |
(7) 10GBASE-R-SFP+ Ethernet fiber ports 0 through 3 |
AC power supplies
PSR250-12A1
Figure2-2 PSR250-12A1 front panel
(1) Latch |
(2) Power supply status LED |
(3) Handle |
(4) Power receptacle |
PSR450-12A1
Figure2-3 PSR450-12A1 front panel
(1) Latch |
(3) Handle |
DC power supplies
Figure2-4 PSR450-12D front panel
(1) Latch |
(3) Handle |
High voltage DC supplies
Figure2-5 PSR450-12AHD front panel
(1) Latch |
(3) Handle |
Fan trays
Figure2-6 FAN-80-1 front panel
(1) Fan tray release button |
(2) Fan tray status LED |
Riser modules
Figure2-7 Riser module view
(1) PCIe slot (for a storage controller or GPU) |
(2) GPU power connector |
(3) GPU support bracket and screw |
(4) Cable tie (for GPU power cables) |
NOTE: The GPU support bracket and four screws are shipped with the riser module. Three are used for installing the GPU support bracket and one is used for securing the storage controller or GPU to the riser module. |
Storage controllers
Figure2-8 Storage controller view
(1) Storage controller golden plating |
(2) Storage controller cable connector |
(3) Storage controller cable |
NOTE: No storage controller cable is provided with the storage controller. Purchase one as required. |
GPUs
Figure2-9 GPU view
(1) GPU power connector |
(2) Screw hole in the GPU support bracket |
(3) GPU golden plating |
(4) GPU power cable |
DIMMs
Figure2-10 DIMM view
(1) Notch of DIMM golden plating |
M.2 SSD drives
Figure2-11 M.2 SSD drive view
(1) Screw location of the M.2 SSD drive |
(2) Golden plating of the M.2 SSD drive |
(3) Screw for the M.2 SSD drive (shipped with the document bag for the chassis) |
Technical specifications
FIP modules
Table2-1 FIP-30 specifications
Item |
Specifications |
1000BASE-X-SFP Ethernet fiber ports |
16 |
10GBASE-R-SFP+ Ethernet fiber ports |
4 |
MIC-X interface module slots |
2 |
Hot swappable |
Yes |
MIC-X interface modules
The SR6602-I and SR6602-IE ICT converged devices support MIC-X interface modules. For more information about MIC-X interface modules, see H3C SR6602-I[IE] AI Series ICT Converged Gateways Interface Module Guide.
Power supplies
IMPORTANT: To ensure correct operation of the device when it is installed with a GPU, use two 450W power supplies to supply power to the device. |
The device supports AC and DC power supplies but does not support the mixture of AC and DC power supplies. If you install two power supplies, make sure they are the same model. The power supplies are hot swappable. With two power supplies present in the device, you can hot swap a power supply.
AC power supplies
Table2-2 AC power supply specifications
Model |
Rated input voltage range |
Maximum output current |
Maximum power |
PSR250-12A1 |
100 VAC to 240 VAC @ 50/60 Hz |
5 A |
250 W |
PSR450-12A1 |
7 A |
450 W |
DC power supplies
Table2-3 DC power supply specifications
Model |
Maximum power |
PSR450-12D |
–48 VDC to –60 VDC |
15 A |
450 W |
High voltage DC power supplies
Table2-4 High voltage DC power supply specifications
Model |
Maximum power |
PSR450-12AHD |
AC input |
7 A |
450 W |
High voltage DC input |
240 VDC to 380 VDC |
3.5 A |
450 W |
DC power cords
A DC power cord is used for connecting a DC power supply on the device to the external DC power supply system.
Table2-5 describes DC power cord available for the PSR450-12D power supply.
Table2-5 DC power cord specifications
Product code |
Power cord length |
Cross-sectional area |
0404A00E |
2 m (6.56 ft) |
2 × 3.3 mm2 (0.0051 in2) |
Fan trays
The device provides three fan tray slots. Slots FAN1 and FAN2 are used for installing fan trays, and slot FAN3 is reserved for future use. The fan trays are hot swappable. With two fan trays present in the device, you can hot swap a fan tray.
Table2-6 FAN-80-1 specifications
Item |
Specifications |
Maximum rotating speed |
16500 RPM |
Maximum air flow rate |
71.3 CFM |
Number of fans |
2 |
Automatic speed adjustment |
Yes |
Anti-misinsertion |
Yes |
Hot swappable |
Yes |
SATA drives
Table2-7 SATA HDD specifications
Model |
Capacity |
Rate |
Rotating speed |
HDD-500G-SATA-3G-5.4K-SFF |
500 GB |
3 Gbps |
5400 RPM |
HDD-2T-SATA-6G-5.4K-SFF |
2 TB |
6 Gbps |
5400 RPM |
NS-HDD-1T-SATA-SFF |
1 TB |
3 Gbps |
5400 RPM |
Riser modules
Table2-8 Riser module specifications
Model |
Installation slot |
Supported PCIe module |
RT-RISER-FHFL-X16 |
Slot 2 |
· UN-GPU-P40-X · UN-HBA-H460-B1 |
Storage controllers
IMPORTANT: The device supports RAID only when two external SATA drives are installed in the device. Make sure the SATA drives are the same capacity. |
Redundant Array of Independent Disks (RAID) is a data storage virtualization technology that combines multiple physical disks into one logical drive group for performance improvement and data redundancy.
Table2-9 HBA-H460-B1 specifications
Item |
Specifications |
Ports |
2 internal SATA ports |
Connectors |
One ×8 mini-SAS connector |
Drive interface |
6 Gbps SATA 3.0, supporting hot swapping of the drive |
PCIe interface |
PCIe3.0 ×8 |
RAID levels |
0, 1 |
Built-in cache memory |
N/A |
Power fail safeguard module |
Not supported |
Firmware upgrade |
Online upgrade |
Table2-10 Storage controller cable specifications
Product code |
Model |
Cable length |
0404A1BA |
CAB-SAS HD-0.26m-36S-68S |
0.26 m (0.85 ft) |
GPUs
Table2-11 GPU-P40-X specifications
Item |
Specifications |
PCIe interface |
PCIe3.0 ×16 |
Memory size |
24 GB GDDR5 |
Memory bus width |
384 bits |
Memory bandwidth |
346 Gbps |
Power connector |
Yes |
DIMMs
Table2-12 DIMM specifications
Model |
Type |
RANK |
Capacity |
Data rate |
DDR4-2666-32G-2Rx4-R |
RDIMM |
Dual-rank |
32 GB |
2666 MHz |
M.2 SSD drives
Table2-13 M.2 SSD drive specifications
Model |
Capacity |
Port type |
Rate |
SSD-480G-SATA-M.2 |
480 GB |
SATA |
6 Gbps |
