09-High Availability Configuration Guide
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C SecPath F50X0-D[F5000-AK] Firewalls Series Configuration Guides (V7) (R9620)-6W40109-High Availability Configuration Guide
05-Track configuration
05-Track configuration 341.63 KB
Configuring Track· 1
About Track· 1
Collaboration mechanism·· 1
Supported detection modules· 2
Supported application modules· 2
Restrictions and guidelines: Track configuration· 2
Collaboration application example· 3
Track tasks at a glance· 3
Associating Track with a detection module object 4
Associating Track with NQA· 4
Associating Track with BFD·· 4
Associating Track with interface management 5
Associating Track with route management 6
Associating Track with a tracked list 6
Associating Track with a Boolean list 6
Associating Track with a percentage threshold list 7
Associating Track with a weight threshold list 7
Associating the Track module with an application module· 8
Prerequisites for associating the Track module with an application module· 8
Associating Track with VRRP· 8
Associating Track with static routing· 10
Associating Track with PBR· 11
Associating Track with interface backup· 13
Associating Track with the redundancy group module· 14
Associating Track with VXLAN· 14
Associating Track with EAA· 15
Associating Track with a security policy rule· 15
Display and maintenance commands for Track· 16
Track configuration examples· 16
Example: Configuring VRRP-Track-NQA collaboration· 16
Example: Configuring BFD for a VRRP backup to monitor the master 20
Example: Configuring BFD for the VRRP master to monitor the uplink· 23
Example: Configuring static routing-Track-NQA collaboration· 26
Example: Configuring static routing-Track-BFD collaboration· 30
Example: Configuring VRRP-Track-interface management collaboration· 34
Example: Configuring VRRP-Track-route management collaboration· 36
Configuring Track
About Track
The Track module works between application modules and detection modules. It shields the differences between various detection modules from application modules.
The Track module collaborates with detection modules and application modules.
As shown in Figure 1, collaboration is enabled when you associate the Track module with a detection module and an application module, and it operates as follows:
1.     The detection module probes specific objects such as interface status, link status, network reachability, and network performance, and informs the Track module of detection results.
2.     The Track module sends the detection results to the application module.
3.     When notified of changes for the tracked object, the application modules can react to avoid communication interruption and network performance degradation.
Figure 1 Collaboration through the Track module
Collaboration between the Track module and a detection module
The detection module sends the detection result of the tracked object to the Track module. The Track module changes the status of the track entry as follows:
·     If the tracked object operates correctly, the state of the track entry is Positive. For example, the track entry state is Positive in one of the following conditions:
¡     The target interface is up.
¡     The target network is reachable.
·     If the tracked object does not operate correctly, the state of the track entry is Negative. For example, the track entry state is Negative in one of the following conditions:
¡     The target interface is down.
¡     The target network is unreachable.
·     If the detection result is invalid, the state of the track entry is NotReady. For example, the track entry state is NotReady if its associated NQA operation does not exist.
Collaboration between the Track module and an application module
The track module reports the track entry status changes to the application module. The application module can then take correct actions to avoid communication interruption and network performance degradation.
The following detection modules can be associated with the Track module:
·     NQA.
·     BFD.
·     Interface management.
·     Route management.
You can associate a track entry with an object of a detection module, such as the state of an interface or reachability of an IP route. The state of the track entry is determined by the state of the tracked object.
You can also associate a track entry with a list of objects called a tracked list. The state of a tracked list is determined by the states of all objects in the list. The following types of tracked lists are supported:
·     Boolean AND list—The state of a Boolean AND list is determined by the states of the tracked objects using the Boolean AND operation.
·     Boolean OR list—The state of a Boolean OR list is determined by the states of the tracked objects using the Boolean OR operation.
·     Percentage threshold list—The state of a percentage threshold list is determined by comparing the percentage of Positive and Negative objects in the list with the percentage thresholds configured for the list.
·     Weight threshold list—The state of a weight threshold list is determined by comparing the weight of Positive and Negative objects in the list with the weight thresholds configured for the list.
The following application modules can be associated with the Track module:
·     VRRP.
·     Static routing.
·     PBR.
·     Interface backup.
·     Redundancy group.
·     VXLAN.
·     EAA.
·     Security policy.
When configuring a track entry for an application module, you can set a notification delay to avoid immediate notification of status changes.
When the delay is not configured and the route convergence is slower than the link state change notification, communication failures occur. For example, when the master in a VRRP group detects an uplink interface failure through Track, Track immediately notifies the master to decrease its priority. A backup with a higher priority then preempts as the new master. When the failed uplink interface recovers, the Track module immediately notifies the original master to restore its priority. If the uplink route has not recovered, forwarding failure will occur.
The following is an example of collaboration between NQA, Track, and static routing.
Configure a static route with next hop 192.168.0.88 on the device. If the next hop is reachable, the static route is valid. If the next hop becomes unreachable, the static route is invalid. For this purpose, configure NQA-Track-static routing collaboration as follows:
1.     Create an NQA operation to monitor the accessibility of IP address 192.168.0.88.
2.     Create a track entry and associate it with the NQA operation.
¡     When next hop 192.168.0.88 is reachable, NQA sends the result to the Track module. The Track module sets the track entry to Positive state.
¡     When the next hop becomes unreachable, NQA sends the result to the Track module. The Track module sets the track entry to Negative state.
3.     Associate the track entry with the static route.
¡     When the track entry is in Positive state, the static routing module considers the static route to be valid.
¡     When the track entry is in Negative state, the static routing module considers the static route to be invalid.
To implement the collaboration function, establish associations between the Track module and detection modules, and between the Track module and application modules.
To configure the Track module, perform the following tasks:
1.     Associating Track with a detection module object
¡     Associating Track with NQA
¡     Associating Track with BFD
¡     Associating Track with interface management
¡     Associating Track with route management
2.     Associating Track with a tracked list
¡     Associating Track with a Boolean list
¡     Associating Track with a percentage threshold list
¡     Associating Track with a weight threshold list
3.     Associating the Track module with an application module
¡     Associating Track with VRRP
¡     Associating Track with static routing
¡     Associating Track with PBR
¡     Associating Track with interface backup
¡     Associating Track with the redundancy group module
¡     Associating Track with VXLAN
¡     Associating Track with EAA
¡     Associating Track with a security policy rule
NQA supports multiple operation types to analyze network performance and service quality. For example, an NQA operation can periodically detect whether a destination is reachable, or whether a TCP connection can be established.
An NQA operation operates as follows when it is associated with a track entry:
·     If the consecutive probe failures reach the specified threshold, the NQA module notifies the Track module that the tracked object has malfunctioned. The Track module then sets the track entry to Negative state.
·     If the specified threshold is not reached, the NQA module notifies the Track module that the tracked object is operating correctly. The Track module then sets the track entry to Positive state.
For more information about NQA, see Network Management and Monitoring Configuration Guide.
If you associate a track entry with a nonexistent NQA operation or reaction entry, the state of the track entry is NotReady.
2.     Create a track entry, associate it with an NQA reaction entry, and enter its view.
track track-entry-number nqa entry admin-name operation-tag reaction item-number
3.     Set the delay for notifying the application module of track entry state changes.
delay { negative negative-time | positive positive-time } *
By default, the Track module notifies the application module immediately when the track entry state changes.
BFD supports the control packet mode and echo packet mode. A track entry can be associated only with the echo-mode BFD session. For more information about BFD, see "Configuring BFD."
The associated Track and BFD operate as follows:
·     If the BFD detects that the link fails, it informs the Track module of the link failure. The Track module sets the track entry to Negative state.
·     If the BFD detects that the link is operating correctly, the Track module sets the track entry to Positive state.
When you associate a track entry with BFD, do not configure the virtual IP address of a VRRP group as the local or remote address of the BFD session.
Before you associate Track with BFD, configure the source IP address of BFD echo packets. For more information, see "Configuring BFD."
2.     Create a track entry, associate it with a BFD session, and enter its view.
track track-entry-number bfd echo interface interface-type interface-number remote ip remote-ip-address local ip local-ip-address
The interface management module monitors the link status, physical status, or network-layer protocol status of interfaces. The associated Track and interface management operate as follows:
·     When the link status, physical status, or network-layer protocol status of the interface changes to up, the interface management module informs the Track module of the change. The Track module sets the track entry to Positive state.
·     When the link status, physical status, or network-layer protocol status of the interface changes to down, the interface management module informs the Track module of the change. The Track module sets the track entry to Negative state.
2.     Create a track entry, associate it with an interface, and enter its view.
¡     Create a track entry to monitor the link status of an interface.
track track-entry-number interface interface-type interface-number
¡     Create a track entry to monitor the physical status of an interface.
track track-entry-number interface interface-type interface-number physical
¡     Create a track entry to monitor the network layer protocol status of an interface.
track track-entry-number interface interface-type interface-number protocol { ipv4 | ipv6 }
The route management module monitors route entry changes in the routing table. The associated Track and route management operate as follows:
·     When a monitored route entry is found in the routing table, the route management module informs the Track module. The Track module sets the track entry to Positive state.
·     When a monitored route entry is removed from the routing table, the route management module informs the Track module of the change. The Track module sets the track entry to Negative state.
2.     Create a track entry, associate it with an IP route, and enter its view.
track track-entry-number ip route [ vpn-instance vpn-instance-name ] ip-address { mask-length | mask } reachability
A Boolean list is a list of tracked objects based on a Boolean logic. It can be further divided into the following types:
·     Boolean AND list—A Boolean AND list is set to the Positive state only when all objects are in Positive state. If one or more objects are in Negative state, the tracked list is set to the Negative state.
·     Boolean OR list—A Boolean OR list is set to the Positive state if any object is in Positive state. If all objects are in Negative state, the tracked list is set to the Negative state.
2.     Create a track entry.
See "Associating Track with a detection module object."
Create a track entry before you add it as a tracked object to a tracked list.
A minimum of one track entry must be created.
3.     Create a Boolean tracked list and enter its view.
track track-entry-number list boolean { and | or }
4.     Add the track entry as an object to the tracked list.
object track-entry-number [ not ]
Repeat this step to add all interested objects to the tracked list.
5.     (Optional.) Set the delay for notifying the application module of tracked list state changes.
By default, the Track module notifies the application module immediately when the tracked list state changes.
A percentage threshold list uses a percentage threshold to measure the state of the list.
·     If the percentage of Positive objects is equal to or above the positive state threshold, the list is set to the Positive state.
·     If the percentage of Positive objects is equal to or below the negative state threshold, the list is set to the Negative state.
·     The state of a percentage threshold list remains unchanged if the percentage of Positive objects is below the positive state threshold and above the negative state threshold.
3.     Create a percentage threshold list and enter its view.
track track-entry-number list threshold percentage
5.     Configure the threshold values used to determine the state of the percentage threshold list.
threshold percentage { negative negative-threshold | positive positive-threshold } *
By default, the negative state threshold is 0% and the positive state threshold is 1%.
6.     (Optional.) Set the delay for notifying the application module of tracked list state changes.
A weight threshold list uses a weight threshold to measure the state of the list.
·     If the total weight of Positive objects is equal to or above the positive state threshold, the list is set to the Positive state.
·     If the total weight of Positive objects is equal to or below the negative state threshold, the list is set to the Negative state.
·     The state of a weight threshold list remains unchanged if the total weight of Positive objects is below the positive state threshold and above the negative state threshold.
3.     Create a weight threshold list and enter its view.
track track-entry-number list threshold weight
object track-entry-number [ weight weight ]
5.     Configure the threshold values used to determine the state of the weight threshold list.
threshold weight { negative negative-threshold | positive positive-threshold } *
By default, the negative state threshold is 0 and the positive state threshold is 1.
Before you associate the Track module with an application module, make sure the associated track entry has been created.
Create a track entry first before you associate it with an application module.
An application module might obtain incorrect track entry status information if the associated track entry does not exist.
When VRRP is operating in standard mode or load balancing mode, associate the Track module with the VRRP group to implement the following actions:
·     Change the priority of a router according to the status of the uplink. If a fault occurs on the uplink of the router, the VRRP group is not aware of the uplink failure. If the router is the master, hosts in the LAN cannot access the external network. To resolve this problem, configure a detection module-Track-VRRP collaboration. The detection module monitors the status of the uplink of the router and notifies the Track module of the detection result.
When the uplink fails, the detection module notifies the Track module to change the status of the monitored track entry to Negative. The priority of the master decreases by a user-specified value. A router with a higher priority in the VRRP group becomes the master.
·     Monitor the master on a backup. If a fault occurs on the master, the backup operating in switchover mode will switch to the master immediately to maintain normal communication.
When VRRP is operating in load balancing mode, associate the Track module with the VRRP VF to implement the following functions:
·     Change the priority of the AVF according to its uplink state. When the uplink of the AVF fails, the track entry changes to Negative state. The weight of the AVF decreases by a user-specified value. The VF with a higher priority becomes the new AVF to forward packets.
·     Monitor the AVF status from the LVF. When the AVF fails, the LVF that is operating in switchover mode becomes the new AVF to ensure continuous forwarding.
For more information about configuring VRRP, see "Configuring VRRP."
Restrictions and guidelines for Track association with VRRP
·     VRRP tracking does not take effect on an IP address owner. The configuration takes effect when the router does not act as the IP address owner.
An IP address owner is the router with its interface IP address used as the virtual IP address of the VRRP group.
·     When the status of the track entry changes from Negative to Positive or NotReady, the associated router or VF restores its priority automatically.
Associating Track with a VRRP group
2.     Enter interface view.
3.     Associate a track entry with a VRRP group.
vrrp [ ipv6 ] vrid virtual-router-id track track-entry-number { forwarder-switchover member-ip ip-address | priority reduced [ priority-reduced ] switchover | weight reduced [ weight-reduced ] }
By default, no track entry is associated with a VRRP group.
This command is supported when VRRP is operating in both standard mode and load balancing mode.
Associating Track with a VRRP VF
3.     Associate Track with a VRRP VF.
By default, no track entry is associated with a VRRP VF.
This command is configurable when VRRP is operating in standard mode or load balancing mode. However, the configuration takes effect only when VRRP is operating in load balancing mode.
A static route is a manually configured route to route packets. For more information about static route configuration, see Layer 3—IP Routing Configuration Guide.
Static routes cannot adapt to network topology changes. Link failures or network topological changes can make the routes unreachable and cause communication interruption.
To resolve this problem, configure another route to back up the static route. When the static route is reachable, packets are forwarded through the static route. When the static route is unreachable, packets are forwarded through the backup route.
To check the accessibility of a static route in real time, associate the Track module with the static route.
If you specify the next hop but not the output interface when configuring a static route, you can configure the static routing-Track-detection module collaboration. This collaboration enables you to verify the accessibility of the static route based on the track entry state.
·     If the track entry is in Positive state, the following conditions exist:
¡     The next hop of the static route is reachable.
¡     The configured static route is valid.
·     If the track entry is in Negative state, the following conditions exist:
¡     The next hop of the static route is not reachable.
¡     The configured static route is invalid.
·     If the track entry is in NotReady state, the following conditions exist:
¡     The accessibility of the next hop of the static route is unknown.
¡     The static route is valid.
In static routing-Track-NQA collaboration, you must configure the same VPN instance name for the NQA operation and the next hop of the static route. Otherwise, the accessibility detection cannot operate correctly.
If a static route needs route recursion, the associated track entry must monitor the next hop of the recursive route. The next hop of the static route cannot be monitored. Otherwise, a valid route might be considered invalid.
2.     Associate a static route with a track entry to check the accessibility of the next hop.
Public network:
ip route-static { dest-address { mask-length | mask } | group group-name } { interface-type interface-number [ next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent | track track-entry-number ] | next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name { dest-address { mask-length | mask } | group group-name } { interface-type interface-number [ next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent | track track-entry-number ] | next-hop-address [ public ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ description text ]
By default, Track is not associated with static routing.
PBR uses user-defined policies to route packets. You can specify parameters in a PBR policy to guide the forwarding of the packets that match specific criteria. For more information about PBR, see Layer 3—IP Routing Configuration Guide.
PBR cannot detect the availability of any action taken on packets. When an action is not available, packets processed by the action might be discarded. For example, if the output interface specified for PBR fails, PBR cannot detect the failure, and continues to forward matching packets out of the interface.
To enable PBR to detect topology changes and improve the flexibility of the PBR application, configure Track-PBR-detection module collaboration.
After you associate a track entry with an apply clause, the detection module associated with the track entry sends Track the detection result of the availability of the tracked object.
·     The Positive state of the track entry indicates that the object is available, and the apply clause is valid.
·     The Negative state of the track entry indicates that the object is not available, and the apply clause is invalid.
·     The NotReady state of the track entry indicates that the apply clause is valid.
The following objects can be associated with a track entry:
·     Output interface.
·     Next hop.
·     Default output interface.
·     Default next hop.
Prerequisites for Track association with PBR
Before you associate Track with PBR, create a policy node, and set the match criteria.
2.     Create a policy node and enter its view.
3.     Set match criteria. Choose the options to configure as needed:
¡     Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
¡     Set a packet length match criterion.
if-match packet-length min-len max-len
By default, no packet length match criterion is set.
4.     Set actions and associate the policy node with a track entry. Choose the options to configure as needed:
¡     Set the output interface.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no output interface is set.
¡     Set the next hop.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ]  { ip-address [ direct ] [ track track-entry-number ] [ weight weight-value ]  }&<1-4>
By default, no next hop is set.
¡     Set the default output interface.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no default output interface is set.
¡     Set the default next hop.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ]  { ip-address [ direct ] [ track track-entry-number ] }&<1-4>
By default, no default next hop is set.
Associating Track with IPv6 PBR
2.     Create an IPv6 policy node and enter its view.
¡     Set an IPv6 packet length match criterion.
¡     Set the next hop.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ipv6-address [ direct ] [ track track-entry-number ] [ weight weight-value ] } &<1-4>
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-4>
To enable a standby interface to detect the status of the active interface, you can associate the standby interface with a track entry.
¡     The link where the active interface resides operates correctly.
¡     The standby interfaces stay in backup state.
¡     The link where the active interface resides has failed.
¡     A standby interface changes to the active interface for data transmission.
·     If the track entry is in always NotReady state, the following conditions exist:
¡     The association does not take effect.
¡     Each interface keeps its original forwarding state.
When the track entry turns to NotReady from other state, a standby interface becomes the active interface.
For more information about configuring interface backup, see "Configuring interface backup."
3.     Associate the interface with a track entry.
backup track track-entry-number
By default, no track entry is associated with an interface.
You can associate an interface with only one track entry.
The redundancy group can fast detect the link and interface failures after you associate it with Track.
Track changes the track entry state based on the monitoring result of a detection module, and notifies the track entry state change to the redundancy group.
·     If the track entry state changes to Positive, the system increases the weight value of the redundancy group node. When the value of the redundancy group is greater than 0, the node can operate correctly.
·     If the track entry state changes to Negative or NotReady, the system reduces the weight value of redundancy group node. If the value of the redundancy group is less than 0, the node cannot operate correctly. A node switchover occurs. The members (including Reth interfaces) on the other node take over.
For more information about redundancy groups, see "Configuring redundancy groups."
To associate Track with a redundancy group configured with automatic node switchover, you must specify the interface interface-type interface-number option in the track command. When the specified interface fails, it will not be shut down by the Reth module.
2.     Create a redundancy group and enter its view.
redundancy group group-name
3.     Create a redundancy group node and enter its view.
node node-id
4.     Associate Track with the redundancy group.
track track-entry-number [ reduced weight-reduced ] [ interface interface-type interface-number ]
By default, no track entry is associated with a redundancy group.
When you associate Track with an AC on a VXLAN network, the AC is up only when one or more of the associated track entries are positive.
The AC can be a Layer 3 interface.
Associating a Layer 3 interface with a track entry
2.     Enter Layer 3 interface view.
3.     Bind the interface to a VSI and associate it with a track entry.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] track track-entry-number&<1-3>
By default, a Layer 3 interface is not bound to any VSI or associated with any track entries.
When the AC to be bound to a VSI is a Layer 3 subinterface, you can use the access-mode keyword to specify the AC access mode. The default access mode is VLAN.
The access-mode keyword is not configurable when the AC is a Layer 3 interface.
You can configure EAA track event monitor policies to monitor the positive-to-negative or negative-to-positive state changes of track entries.
·     If you specify only one track entry for a policy, EAA triggers the policy when it detects the specified state change on the track entry.
·     If you specify multiple track entries for a policy, EAA triggers the policy when it detects the specified state change on the last monitored track entry. For example, if you configure a policy to monitor the positive-to-negative state change of multiple track entries, EAA triggers the policy when the last positive track entry monitored by the policy is changed to the Negative state.
You can set a suppression time for a track event monitor policy. The timer starts when the policy is triggered. The system does not process messages that report the monitored track event until the timer times out.
For more information about EAA, see Network Management and Monitoring Configuration Guide.
2.     Create a CLI-defined monitor policy and enter its view, or enter the view of an existing CLI-defined monitor policy.
rtm cli-policy policy-name
3.     Configure a track event.
event track track-entry-number-list state { negative | positive } [ suppress-time suppress-time ]
By default, a monitor policy does not monitor any track event.
Perform this task to enable the collaboration between Track and a security policy rule. The collaboration operates as follows:
·     If the rule is associated with the Negative state of a track entry, the device takes the following actions:
¡     Sets the rule state to Active if the track entry is in Negative state.
¡     Sets the rule state to Inactive if the track entry is in Positive state.
·     If the rule is associated with the Positive state of a track entry, the device takes the following actions:
¡     Sets the rule state to Active if the track entry is in Positive state.
¡     Sets the rule state to Inactive if the track entry is in Negative state.
2.     Enter IPv4 or IPv6 security policy view.
security-policy { ip | ipv6 }
3.     Enter security policy rule view.
rule { rule-id | name name } *
4.     Associate the rule with a track entry.
track { negative | positive } track-entry-number
By default, no track entry is associated with a security policy rule.
Display information about track entries.
display track { track-entry-number | all [ negative | positive ] } [ brief ]
As shown in Figure 2:
·     Host A requires access to Host B. The default gateway of Host A is 10.1.1.10/24.
·     Device A and Device B belong to VRRP group 1. The virtual IP address of VRRP group 1 is 10.1.1.10.
Configure VRRP-Track-NQA collaboration to monitor the uplink on the master and meet the following requirements:
·     When Device A operates correctly, it forwards packets from Host A to Host B.
·     When NQA detects a fault on the uplink of Device A, Device B forwards packets from Host A to Host B.
Figure 2 Network diagram
1.     Assign IP addresses to interfaces and configure routes, security zones, zone pairs, and interzone policies. Make sure the network connections are available. (Details not shown.)
2.     Configure an NQA operation on Device A:
# Create an NQA operation with administrator name admin and operation tag test.
[DeviceA] nqa entry admin test
# Specify the ICMP echo operation type.
[DeviceA-nqa-admin-test] type icmp-echo
# Specify 10.1.2.2 as the destination address of ICMP echo requests.
[DeviceA-nqa-admin-test-icmp-echo] destination ip 10.1.2.2
# Configure the ICMP echo operation to repeat every 100 milliseconds.
[DeviceA-nqa-admin-test-icmp-echo] frequency 100
# Configure reaction entry 1 so that five consecutive probe failures will trigger collaboration with the Track module.
[DeviceA-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[DeviceA-nqa-admin-test-icmp-echo] quit
# Start the NQA operation.
[DeviceA] nqa schedule admin test start-time now lifetime forever
3.     On Device A, configure track entry 1, and associate it with reaction entry 1 of the NQA operation.
[DeviceA] track 1 nqa entry admin test reaction 1
[DeviceA-track-1] quit
4.     Configure VRRP on Device A:
# Specify VRRPv2 to run on GigabitEthernet 1/2/5/1.
[DeviceA] interface gigabitethernet 1/2/5/1
[DeviceA-GigabitEthernet1/2/5/1] vrrp version 2
# Create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
[DeviceA-GigabitEthernet1/2/5/1] vrrp vrid 1 virtual-ip 10.1.1.10
# Set the priority of Device A to 110 in VRRP group 1.
[DeviceA-GigabitEthernet1/2/5/1] vrrp vrid 1 priority 110
# Set the authentication mode of VRRP group 1 to simple, and the authentication key to hello.
[DeviceA-GigabitEthernet1/2/5/1] vrrp vrid 1 authentication-mode simple plain hello
# Configure the master to send VRRP packets every 500 centiseconds.
[DeviceA-GigabitEthernet1/2/5/1] vrrp vrid 1 timer advertise 500
# Configure Device A to operate in preemptive mode and set the preemption delay to 5000 centiseconds.
[DeviceA-GigabitEthernet1/2/5/1] vrrp vrid 1 preempt-mode delay 5000
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 30 when the state of track entry 1 changes to Negative.
[DeviceA-GigabitEthernet1/2/5/1] vrrp vrid 1 track 1 priority reduced 30
[DeviceA-GigabitEthernet1/2/5/1] quit
5.     Configure VRRP on Device B:
[DeviceB] interface gigabitethernet 1/2/5/1
[DeviceB-GigabitEthernet1/2/5/1] vrrp version 2
[DeviceB-GigabitEthernet1/2/5/1] vrrp vrid 1 virtual-ip 10.1.1.10
[DeviceB-GigabitEthernet1/2/5/1] vrrp vrid 1 authentication-mode simple plain hello
[DeviceB-GigabitEthernet1/2/5/1] vrrp vrid 1 timer advertise 500
# Configure Device B to operate in preemptive mode and set the preemption delay to 5000 centiseconds.
[DeviceB-GigabitEthernet1/2/5/1] vrrp vrid 1 preempt-mode delay 5000
# Ping Host B from Host A to verify that Host B is reachable. (Details not shown.)
# Display detailed information about VRRP group 1 on Device A.
[DeviceA-GigabitEthernet1/2/5/1] display vrrp verbose
 Running Mode      : Standard
   Interface GigabitEthernet1/2/5/1
     VRID           : 1               Adver Timer  : 500
     Admin Status   : Up              State        : Master
     Config Pri     : 110             Running Pri  : 110
     Preempt Mode   : Yes             Delay Time   : 5000
     Auth Type      : Simple          Key          : ******
     Virtual IP     : 10.1.1.10
     Virtual MAC    : 0000-5e00-0101
     Master IP      : 10.1.1.1
   VRRP Track Information:
     Track Object   : 1              State : Positive          Pri Reduced : 30
# Display detailed information about VRRP group 1 on Device B.
[DeviceB-GigabitEthernet1/2/5/1] display vrrp verbose
     Admin Status   : Up              State        : Backup
     Config Pri     : 100             Running Pri  : 100
     Become Master  : 2200ms left
The output shows that in VRRP group 1, Device A is the master and Device B is a backup. Device A forwards packets from Host A to Host B.
# Disconnect the link between Device A and Device C, and verify that Host A can still ping Host B. (Details not shown.)
     Config Pri     : 110             Running Pri  : 80
     Master IP      : 10.1.1.2
     Track Object   : 1              State : Negative          Pri Reduced : 30
# Display detailed information about VRRP group 1 on Device B when the link between Device A and Device C is faulty.
The output shows that Device A has become the backup, and Device B has become the master. Device B forwards packets from Host A to Host B.
As shown in Figure 3:
·     Device A and Device B belong to VRRP group 1. The virtual IP address of VRRP group 1 is 192.168.0.10.
·     The default gateway of the hosts in the LAN is 192.168.0.10.
Configure VRRP-Track-BFD collaboration to monitor the master on the backup and meet the following requirements:
·     When Device A operates correctly, the hosts in the LAN access the Internet through Device A.
·     When Device A fails, the backup (Device B) can detect the state change of the master through BFD and become the new master. The hosts in the LAN access the Internet through Device B.
Figure 3 Network diagram
2.     Configure Device A:
# Create VRRP group 1, and configure virtual IP address 192.168.0.10 for the group.
[DeviceA-GigabitEthernet1/2/5/1] vrrp vrid 1 virtual-ip 192.168.0.10
[DeviceA-GigabitEthernet1/2/5/1] return
3.     Configure Device B:
# Specify 10.10.10.10 as the source address of BFD echo packets.
[DeviceB] bfd echo-source-ip 10.10.10.10
# Create track entry 1, and associate it with the BFD session to verify the reachability of Device A.
[DeviceB] track 1 bfd echo interface gigabitethernet 1/2/5/1 remote ip 192.168.0.101 local ip 192.168.0.102
[DeviceB-track-1] quit
[DeviceB-GigabitEthernet1/2/5/1] vrrp vrid 1 virtual-ip 192.168.0.10
# Configure VRRP group 1 to monitor the status of track entry 1.
[DeviceB-GigabitEthernet1/2/5/1] vrrp vrid 1 track 1 switchover
[DeviceB-GigabitEthernet1/2/5/1] return
<DeviceA> display vrrp verbose
     VRID           : 1               Adver Timer  : 100
     Preempt Mode   : Yes             Delay Time   : 0
     Auth Type      : None
     Virtual IP     : 192.168.0.10
     Master IP      : 192.168.0.101
<DeviceB> display vrrp verbose
     Auth Type      : None
     Track Object   : 1              State : Positive          Switchover
# Display information about track entry 1 on Device B.
<DeviceB> display track 1
Track ID: 1
  State: Positive
  Tracked object type: BFD
  Notification delay: Positive 0, Negative 0 (in seconds)
  Tracked object:
    BFD session mode: Echo
    Outgoing Interface: GigabitEthernet1/2/5/1
    VPN instance name: --
    Remote IP: 192.168.0.101
    Local IP: 192.168.0.102
The output shows that when the status of the track entry becomes Positive, Device A is the master, and Device B is the backup.
# Enable VRRP state debugging and BFD event notification debugging on Device B.
<DeviceB> terminal debugging
<DeviceB> terminal monitor
<DeviceB> debugging vrrp fsm
<DeviceB> debugging bfd ntfy
# When Device A fails, the following output is displayed on Device B.
*Dec 17 14:44:34:142 2019 DeviceB BFD/7/DEBUG: Notify application:TRACK State:DOWN
*Dec 17 14:44:34:144 2019 DeviceB VRRP4/7/FSM
 IPv4 GigabitEthernet1/2/5/1 | Virtual Router 1 : Backup --> Master   reason: The status of the tracked object changed
# Display detailed information about the VRRP group on Device B.
     Auth Type      : None
     Master IP      : 192.168.0.102
     Track Object   : 1                    State : Negative   Switchover
The output shows that when BFD detects that Device A fails, the Track module notifies VRRP to change the status of Device B to master. The backup can quickly preempt as the master without waiting for a period three times the advertisement interval plus the Skew_Time.
As shown in Figure 4:
Configure VRRP-Track-BFD collaboration to monitor the uplink on the master and meet the following requirements:
·     When Device A operates correctly, hosts in the LAN access the Internet through Device A.
·     When Device A detects that the uplink is down through BFD, Device B can preempt as the master. The hosts in the LAN can access the Internet through Device B.
Figure 4 Network diagram
[DeviceA] bfd echo-source-ip 10.10.10.10
# Create track entry 1 for the BFD session on Device A to verify the reachability of the uplink device (1.1.1.2).
[DeviceA] track 1 bfd echo interface gigabitethernet 1/2/5/1 remote ip 1.1.1.2 local ip 1.1.1.1
# Create VRRP group 1, and specify 192.168.0.10 as the virtual IP address of the group.
[DeviceA] interface gigabitethernet 1/2/5/2
[DeviceA-GigabitEthernet1/2/5/2] vrrp vrid 1 virtual-ip 192.168.0.10
[DeviceA-GigabitEthernet1/2/5/2] vrrp vrid 1 priority 110
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 20 when the state of track entry 1 changes to Negative.
[DeviceA-GigabitEthernet1/2/5/2] vrrp vrid 1 track 1 priority reduced 20
[DeviceA-GigabitEthernet1/2/5/2] return
3.     On Device B, create VRRP group 1, and specify 192.168.0.10 as the virtual IP address of the group.
[DeviceB] interface gigabitethernet 1/2/5/2
[DeviceB-GigabitEthernet1/2/5/2] vrrp vrid 1 virtual-ip 192.168.0.10
[DeviceB-GigabitEthernet1/2/5/2] return
# Display detailed information about the VRRP group on Device A.
   Interface GigabitEthernet1/2/5/2
     Auth Type      : None
     Track Object   : 1              State : Positive          Pri Reduced : 20
# Display information about track entry 1 on Device A.
<DeviceA> display track 1
Track ID: 1
  State: Positive
  Tracked object:
    Outgoing interface: GigabitEthernet1/2/5/1
    Remote IP: 1.1.1.2
    Local IP: 1.1.1.1
     Auth Type      : None
The output shows that when the status of track entry 1 becomes Positive, Device A is the master and Device B is the backup.
# Display information about track entry 1 when the uplink of Device A goes down.
Track ID: 1
  State: Negative
  Tracked object:
    Remote IP: 1.1.1.2
    Local IP: 1.1.1.1
     Config Pri     : 110             Running Pri  : 90
     Auth Type      : None
     Track Object   : 1              State : Negative          Pri Reduced : 20
     Auth Type      : None
The output shows that when Device A detects that the uplink fails through BFD, it decreases its priority by 20. Device B then preempts as the master.
As shown in Figure 5:
·     Device A is the default gateway of the hosts in network 20.1.1.0/24.
·     Device D is the default gateway of the hosts in network 30.1.1.0/24.
·     Hosts in the two networks communicate with each other through static routes.
To ensure network availability, configure route backup and static routing-Track-NQA collaboration on Device A and Device D as follows:
·     On Device A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Device B. This route is the master route. The static route to 30.1.1.0/24 with next hop Device C acts as the backup route. When the master route is unavailable, the backup route takes effect.
·     On Device D, assign a higher priority to the static route to 20.1.1.0/24 with next hop Device B. This route is the master route. The static route to 20.1.1.0/24 with next hop Device C acts as the backup route. When the master route is unavailable, the backup route takes effect.
Figure 5 Network diagram
# Configure a static route to 30.1.1.0/24 with next hop 10.1.1.2 and the default priority (60). Associate this static route with track entry 1.
[DeviceA] ip route-static 30.1.1.0 24 10.1.1.2 track 1
# Configure a static route to 30.1.1.0/24 with next hop 10.3.1.3 and priority 80.
[DeviceA] ip route-static 30.1.1.0 24 10.3.1.3 preference 80
# Configure a static route to 10.2.1.4 with next hop 10.1.1.2.
[DeviceA] ip route-static 10.2.1.4 24 10.1.1.2
# Specify 10.2.1.4 as the destination address of the operation.
[DeviceA-nqa-admin-test-icmp-echo] destination ip 10.2.1.4
# Specify 10.1.1.2 as the next hop of the operation.
[DeviceA-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.2
# Configure track entry 1, and associate it with reaction entry 1 of the NQA operation.
# Configure a static route to 30.1.1.0/24 with next hop 10.2.1.4.
[DeviceB] ip route-static 30.1.1.0 24 10.2.1.4
# Configure a static route to 20.1.1.0/24 with next hop 10.1.1.1.
[DeviceB] ip route-static 20.1.1.0 24 10.1.1.1
4.     Configure Device C:
# Configure a static route to 30.1.1.0/24 with next hop 10.4.1.4.
<DeviceC> system-view
[DeviceC] ip route-static 30.1.1.0 24 10.4.1.4
# Configure a static route to 20.1.1.0/24 with next hop 10.3.1.1.
[DeviceC] ip route-static 20.1.1.0 24 10.3.1.1
5.     Configure Device D:
# Configure a static route to 20.1.1.0/24 with next hop 10.2.1.2 and the default priority (60). Associate this static route with track entry 1.
<DeviceD> system-view
[DeviceD] ip route-static 20.1.1.0 24 10.2.1.2 track 1
# Configure a static route to 20.1.1.0/24 with next hop 10.4.1.3 and priority 80.
[DeviceD] ip route-static 20.1.1.0 24 10.4.1.3 preference 80
# Configure a static route to 10.1.1.1 with next hop 10.2.1.2.
[DeviceD] ip route-static 10.1.1.1 24 10.2.1.2
[DeviceD] nqa entry admin test
[DeviceD-nqa-admin-test] type icmp-echo
# Specify 10.1.1.1 as the destination address of the operation.
[DeviceD-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# Specify 10.2.1.2 as the next hop of the operation.
[DeviceD-nqa-admin-test-icmp-echo] next-hop ip 10.2.1.2
[DeviceD-nqa-admin-test-icmp-echo] frequency 100
[DeviceD-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[DeviceD-nqa-admin-test-icmp-echo] quit
[DeviceD] nqa schedule admin test start-time now lifetime forever
[DeviceD] track 1 nqa entry admin test reaction 1
[DeviceD-track-1] quit
# Display track entry information on Device A.
[DeviceA] display track all
Track ID: 1
  State: Positive
  Tracked object type: NQA
  Tracked object:
    NQA entry: admin test
    Reaction: 1
    Remote IP/URL: 10.2.1.4
    Local IP:--
    Interface:--
The output shows that the status of track entry 1 is Positive, indicating that the NQA operation has succeeded and the master route is available.
# Display the routing table of Device A.
[DeviceA] display ip routing-table
Destinations : 10       Routes : 10
10.1.1.0/24         Direct 0    0            10.1.1.1        GE1/2/5/1
10.1.1.1/32         Direct 0    0            127.0.0.1       InLoop0
10.2.1.0/24         Static 60   0            10.1.1.2        GE1/2/5/1
10.3.1.0/24         Direct 0    0            10.3.1.1        GE1/2/5/2
10.3.1.1/32         Direct 0    0            127.0.0.1       InLoop0
20.1.1.0/24         Direct 0    0            20.1.1.1        GE1/2/5/3
20.1.1.1/32         Direct 0    0            127.0.0.1       InLoop0
30.1.1.0/24         Static 60   0            10.1.1.2        GE1/2/5/1
The output shows that Device A forwards packets to 30.1.1.0/24 through Device B.
# Remove the IP address of GigabitEthernet 1/2/5/1 on Device B.
[DeviceB-GigabitEthernet1/2/5/1] undo ip address
# Display information about the track entry on Device A.
Track ID: 1
  State: Negative
  Tracked object:
    Reaction: 1
    Local IP:--
    Interface:--
The output shows that the status of the track entry is Negative, indicating that the NQA operation has failed and the master route is unavailable.
30.1.1.0/24         Static 80   0            10.3.1.3        GE1/2/5/2
The output shows that Device A forwards packets to 30.1.1.0/24 through Device C. The backup static route has taken effect.
# Verify that hosts in 20.1.1.0/24 can communicate with the hosts in 30.1.1.0/24 when the master route fails.
[DeviceA] ping -a 20.1.1.1 30.1.1.1
Ping 30.1.1.1: 56  data bytes, press CTRL_C to break
Reply from 30.1.1.1: bytes=56 Sequence=1 ttl=254 time=2 ms
Reply from 30.1.1.1: bytes=56 Sequence=2 ttl=254 time=1 ms
Reply from 30.1.1.1: bytes=56 Sequence=3 ttl=254 time=1 ms
Reply from 30.1.1.1: bytes=56 Sequence=4 ttl=254 time=2 ms
Reply from 30.1.1.1: bytes=56 Sequence=5 ttl=254 time=1 ms
--- Ping statistics for 30.1.1.1 ---
5 packet(s) transmitted, 5 packet(s) received, 0.00% packet loss
round-trip min/avg/max/std-dev = 1/1/2/1 ms
# Verify that the hosts in 30.1.1.0/24 can communicate with the hosts in 20.1.1.0/24 when the master route fails.
[DeviceD] ping -a 30.1.1.1 20.1.1.1
Ping 20.1.1.1: 56  data bytes, press CTRL_C to break
Reply from 20.1.1.1: bytes=56 Sequence=1 ttl=254 time=2 ms
Reply from 20.1.1.1: bytes=56 Sequence=2 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=3 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=4 ttl=254 time=1 ms
Reply from 20.1.1.1: bytes=56 Sequence=5 ttl=254 time=1 ms
--- Ping statistics for 20.1.1.1 ---
As shown in Figure 6:
·     Device B is the default gateway of the hosts in network 30.1.1.0/24.
To ensure network availability, configure route backup and static routing-Track-BFD collaboration on Device A and Device B as follows:
·     On Device A, assign a higher priority to the static route to 30.1.1.0/24 with next hop Device B. This route is the master route. The static route to 30.1.1.0/24 with next hop Device C acts as the backup route. When the master route is unavailable, BFD can quickly detect the route failure to make the backup route take effect.
·     On Device B, assign a higher priority to the static route to 20.1.1.0/24 with next hop Device A. This route is the master route. The static route to 20.1.1.0/24 with next hop Device C acts as the backup route. When the master route is unavailable, BFD can quickly detect the route failure to make the backup route take effect.
Figure 6 Network diagram
# Configure a static route to 30.1.1.0/24 with next hop 10.2.1.2 and the default priority (60). Associate this static route with track entry 1.
[DeviceA] ip route-static 30.1.1.0 24 10.2.1.2 track 1
# Configure track entry 1, and associate it with the BFD session to verify the connectivity between Device A and Device B.
[DeviceA] track 1 bfd echo interface gigabitethernet 1/2/5/1 remote ip 10.2.1.2 local ip 10.2.1.1
# Configure a static route to 20.1.1.0/24 with next hop 10.2.1.1 and the default priority (60). Associate this static route with track entry 1.
[DeviceB] ip route-static 20.1.1.0 24 10.2.1.1 track 1
[DeviceB] ip route-static 20.1.1.0 24 10.4.1.3 preference 80
# Specify 1.1.1.1 as the source address of BFD echo packets.
[DeviceB] bfd echo-source-ip 1.1.1.1
# Configure track entry 1, and associate it with the BFD session to verify the connectivity between Device B and Device A.
[DeviceB] track 1 bfd echo interface gigabitethernet 1/2/5/1 remote ip 10.2.1.1 local ip 10.2.1.2
# Configure a static route to 30.1.1.0/24 with next hop 10.4.1.2.
[DeviceC] ip route-static 30.1.1.0 24 10.4.1.2
[DeviceB] ip route-static 20.1.1.0 24 10.3.1.1
Track ID: 1
  State: Positive
  Tracked object:
    Remote IP: 10.2.1.2
    Local IP: 10.2.1.1
The output shows that the status of the track entry is Positive, indicating that next hop 10.2.1.2 is reachable.
Destinations : 9        Routes : 9
10.2.1.0/24         Direct 0    0            10.2.1.1        GE1/2/5/1
10.2.1.1/32         Direct 0    0            127.0.0.1       InLoop0
30.1.1.0/24         Static 60   0            10.2.1.2        GE1/2/5/1
The output shows that Device A forwards packets to 30.1.1.0/24 through Device B. The master static route has taken effect.
Track ID: 1
  State: Negative
  Tracked object:
    Remote IP: 10.2.1.2
    Local IP: 10.2.1.1
The output shows that the status of the track entry is Negative, indicating that next hop 10.2.1.2 is unreachable.
# Verify that the hosts in 20.1.1.0/24 can communicate with the hosts in 30.1.1.0/24 when the master route fails.
[DeviceB] ping -a 30.1.1.1 20.1.1.1
As shown in Figure 7:
Configure VRRP-Track-interface management collaboration to monitor the uplink interface on the master and meet the following requirements:
·     When Device A operates correctly, Device A forwards packets from Host A to Host B.
·     When VRRP detects a fault on the uplink interface of Device A through the interface management module, Device B forwards packets from Host A to Host B.
Figure 7 Network diagram
# Configure track entry 1, and associate it with the link status of the uplink interface (GigabitEthernet 1/2/5/2).
[DeviceA] track 1 interface gigabitethernet 1/2/5/2
3.     On Device B, create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
     Auth Type      : None
     Auth Type      : None
# Shut down the uplink interface (GigabitEthernet 1/2/5/2) on Device A.
[DeviceA-GigabitEthernet1/2/5/1] interface gigabitethernet 1/2/5/2
[DeviceA-GigabitEthernet1/2/5/2] shutdown
[DeviceA-GigabitEthernet1/2/5/2] display vrrp verbose
     Auth Type      : None
     Auth Type      : None
As shown in Figure 8:
·     BGP peer relationships are established between Device A and Device C and between Device B and Device D. Device C and Device D advertise default route 0.0.0.0/0 to Device A and Device B.
Configure VRRP-Track-route management collaboration to meet the following requirements:
·     When VRRP detects the removal of the default route from the routing table of Device A through route management, Device B forwards packets from Host A to Host B.
Figure 8 Network diagram
2.     Establish an IBGP peer relationship between Device A and Device C, and configure Device C to advertise default route 0.0.0.0/0 to Device A.
[DeviceA] bgp 100
[DeviceA-bgp-default] peer 10.1.2.2 as-number 100
[DeviceA-bgp-default] address-family ipv4
[DeviceA-bgp-default-ipv4] peer 10.1.2.2 enable
[DeviceA-bgp-default-ipv4] quit
[DeviceC] bgp 100
[DeviceC-bgp-default] peer 10.1.2.1 as-number 100
[DeviceC-bgp-default] address-family ipv4
[DeviceC-bgp-default-ipv4] peer 10.1.2.1 enable
[DeviceC-bgp-default-ipv4] peer 10.1.2.1 default-route-advertise
[DeviceC-bgp-default-ipv4] quit
3.     Configure Device B and Device D in the same way Device A and Device C are configured. (Details not shown.)
4.     Configure Track and VRRP on Device A:
# Configure track entry 1, and associate it with default route 0.0.0.0/0.
[DeviceA] track 1 ip route 0.0.0.0 0.0.0.0 reachability
5.     On Device B, create VRRP group 1, and configure virtual IP address 10.1.1.10 for the group.
[DeviceB-GigabitEthernet1/2/5/1] quit
[DeviceA] display vrrp verbose
     Auth Type      : None
[DeviceB] display vrrp verbose
     Auth Type      : None
# Disable Device C from exchanging routing information with Device A so that default route 0.0.0.0/0 is removed from Device A.
[DeviceC-bgp-default-ipv4] undo peer 10.1.2.1 enable
     Auth Type      : None
     Auth Type      : None
